    4. Neuer Robonect HX Adapter
      ChristianF last edited by
      Moin zusammen,
      Fehler bei der Installation habe ich nicht gesehen (vielleicht übersehen?), aber dafür auch die Probleme mit der Verbindung:
      host.iobroker	2018-04-28 01:55:15.794	info	Restart adapter system.adapter.robonect.0 because enabled
      host.iobroker	2018-04-28 01:55:15.793	error	instance system.adapter.robonect.0 terminated with code 0 (OK)
      robonect.0	2018-04-28 01:55:15.738	info	terminating
      robonect.0	2018-04-28 01:55:15.436	info	cleaned everything up...
      robonect.0	2018-04-28 01:55:15.434	error	at emitNone (events.js:72:20)
      robonect.0	2018-04-28 01:55:15.434	error	at IncomingMessage.g (events.js:260:16)
      robonect.0	2018-04-28 01:55:15.434	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.robonect/node_modules/request/request.js:1085:12)
      robonect.0	2018-04-28 01:55:15.434	error	at Request.emit (events.js:169:7)
      robonect.0	2018-04-28 01:55:15.434	error	at emitOne (events.js:77:13)
      robonect.0	2018-04-28 01:55:15.434	error	at Request. (/opt/iobroker/node_modules/iobroker.robonect/node_modules/request/request.js:1163:10)
      robonect.0	2018-04-28 01:55:15.434	error	at Request.emit (events.js:172:7)
      robonect.0	2018-04-28 01:55:15.434	error	at emitTwo (events.js:87:13)
      robonect.0	2018-04-28 01:55:15.434	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.robonect/node_modules/request/request.js:186:22)
      robonect.0	2018-04-28 01:55:15.434	error	at Request._callback (/opt/iobroker/node_modules/iobroker.robonect/lib/robonect.js:3925:81)
      robonect.0	2018-04-28 01:55:15.434	error	TypeError: Cannot read property 'temperature' of undefined
      robonect.0	2018-04-28 01:55:15.430	error	uncaught exception: Cannot read property 'temperature' of undefined
      robonect.0	2018-04-28 01:55:15.391	error	Error: connect ECONNRESET 192.168.1.107:80
      robonect.0	2018-04-28 01:55:15.388	error	Error: connect ECONNRESET 192.168.1.107:80
      robonect.0	2018-04-28 01:55:15.385	error	Error: connect ECONNRESET 192.168.1.107:80
      robonect.0	2018-04-28 01:55:15.371	error	Error: connect ECONNRESET 192.168.1.107:80
      robonect.0	2018-04-28 01:55:15.228	info	Polling done (Initial)
      robonect.0	2018-04-28 01:55:15.017	info	Done
      robonect.0	2018-04-28 01:55:14.880	info	starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.robonect, node: v4.9.1
      Meine eigene Abfrage über Javascript und JSON läuft soweit.
      Firmware ist noch die alte (bin nicht so für Beta auf Produktivgeräten 😉 ).
      Viele Grüße
      Christian
      • braindead
        braindead Developer last edited by
        Hi Christian,
        ich habe den Adpter für die Firmware 1.0 Beta 2 geschrieben, er funktioniert bei mir aber auch mit der Beta 3. Deine Fehler werden damit zu tun haben, dass Du eine ältere Firmware einsetzt. Da die offizielle Firmware 1.0 immer näher rückt, werde ich ältere Firmware Versionen in dem Adapter nicht unterstützen. Ich hoffe Du verstehst das.
        Gruß,
        Markus
          Hallo Markus,
          kaum macht man's richtig, funktioniert es auch 🙂 Mit der 1.0B3 funktioniert es, vielen Dank !
          Ich hätte noch einen Verbesserungsvorschlag: es wäre toll, wenn der Adapter den Datenpunkt robonect.0.timer.next_date und vielleicht auch noch den robonect.0.last_sync <u>als Timestamp</u> auswerfen könnte, dann wäre es wesentlich einfacher, mit den Daten in ioBroker weiter zu arbeiten.
          Ansonsten sieht der Adapter sehr gut aus, ich bin begeistert von der Vielzahl der Informationen, die der Mäher nun ausspuckt 🙂
          Vielen Dank dafür !!!!
          Viele Grüße
          Christian
            StefSign last edited by
            hab' ich total "verschlafen" … peinlich, peinlich.
            Ich schau' mir das mal gleich an und Danke für die Weiterentwicklung.
            Stefan (alias StefSign)
              kann man mit dem neuen Adapter auch "start/stop" Kommandos absetzen?
              Stefan
              • braindead
                Hi Stefan,
                mit dem Datenpunkt status.mode kannst Du den Modus setzen: Auto, Manuell, Home, End of Day und Job. Ist es das, was Du machen möchtest, oder gibt es da noch etwas anderes?
                Gruß,
                Markus
                  ManinBlack last edited by
                  Servus,
                  robonect.0	2018-05-24 10:49:40.173	error	TypeError: Cannot read property 'temperature' of undefined at Request._callback (/opt/iobroker/node_modules/iobroker.robonect/lib/robonect.js:3925:81) at Request.self.callback (/opt/iobroker/n
                  robonect.0	2018-05-24 10:49:40.173	error	uncaught exception: Cannot read property 'temperature' of undefined
                  Wird bei mir alle 30 Sekunden gelogged.
                  Mein Gardena R70LI hat keine Sensoren für Temperatur und Luftfeuchtigkeit. Da gehört wohl ein if drum! 🙂
                    mameier1234 last edited by
                    Mein R70li meldet einwandfrei Zensur und Luftfeuchtigkeit. ….
                      Hm interessant.
                      Wer misst denn eigentlich Temperatur und Luftfeuchtigkeit? Der Roboter oder robonect?
                      Mein Roboter ist von 2015 und ich habe das "alte" Robonect H30x
                      • braindead
                        Also ich habe das Robonect Hx 10p Modul für meinen R70Li von 2016. Ob der Roboter oder das Modul Temperatur und Luftfeuchtigkeit misst weiß ich auch nicht. Hast Du denn die aktuellste Beta Version installiert?
                          Hi Markus,
                          danke für den Hinweis…genau das bräuchte ich. Use Case: "Es fängt an zu regnen und der Mäher soll dann Feierabend machen".
                          Bei der Gelegenheit ein paar Fragen:
                          • Wann soll denn die Version 1 der Robonect Firmware kommen?
                          • Hat jemand schon ein Script was die Regenwahrscheinlichkeit auswertet? Und auch die Regendauer? Beispiel: Es wird heute zu 60% Regnen dann
                          sollte der Mäher später anfangen oder es hat geregnet dann sollte der Mäher eine Zeit warten bis das Gras trocken ist.
                          Danke noch und leider ist mein Fokus momentan auf meinem neuen 3D Drucker (Anet A8), daher werde ich versuchen 1 x mal pro Woche hier reinzuschauen.
                          Stefan
                            @braindead:
                            Also ich habe das Robonect Hx 10p Modul für meinen R70Li von 2016. Ob der Roboter oder das Modul Temperatur und Luftfeuchtigkeit misst weiß ich auch nicht. Hast Du denn die aktuellste Beta Version installiert? `
                            Ja,neuste FIrmware ist drauf V1.0 Beta 4.
                            Würde mal schätzen, dass das Robonect die Werte misst.
                            Ist auch sinnvoll, da so kann man Wasserschäden frühzeitig erkennen, schade, dass ich die Sensoren offensichtlich nicht habe
                            • braindead
                              @StefSign: Ich habe keine Ahnung, wann Robonect 1.0 veröffentlicht wird. Soweit ich das im Robonect Forum verfolgt habe, wurde bisher auch noch kein Datum von Fabian genannt.
                              @ManinBlack: Wenn die neueste Version installiert ist, dann scheint es tatsächlich einen Unterschied zwischen den Modulen zu geben. Ich werde den Code so anpassen, dass sowas abgefangen wird.
                              • braindead
                                Dieses Wochenende wurde die neue Robonect 1.0 Beta5 Firmware veröffentlicht. Ich habe den Adapter so angepasst, dass er mit der neuen Firmware funktioniert.
                                @ManinBlack: Dein Problem sollte auch gelöst sein.
                                Hier der Link zum Adapter: https://github.com/braindead1/ioBroker.robonect
                                  Hey,
                                  ja vielen Dank. Das haut nun hin!
                                  Wobei ich das hier noch immer im Log habe:
                                  robonect.0	2018-06-12 11:01:34.175	error	TypeError: Cannot read property 'enable' of undefined at Request._callback (/opt/iobroker/node_modules/iobroker.robonect/lib/robonect.js:4182:86) at Request.self.callback (/opt/iobroker/node_m
                                  robonect.0	2018-06-12 11:01:34.174	error	uncaught exception: Cannot read property 'enable' of undefined
                                  Außerdem wird die Akkutemperatur nicht übernommen. Das liegt wohl hieran:
                                  https://github.com/braindead1/ioBroker. … t.js#L3878
                                  • HAL
                                    HAL last edited by
                                    @ManinBlack:
                                    https://github.com/braindead1/ioBroker. … t.js#L3878 `
                                    Die Akkutemperatur wir bei mir angezeigt:
                                    Allerdings habe ich auch Fehler im Log. ( In der Web-UI ist der Mower erreichbar und "schläft" )
                                    VG Uwe
                                    • HAL
                                      HAL last edited by
                                      Ich habe jetzt meinen WLAN Kanal optimiert ( nach dem Standort des Mower ) damit sind die Connection lost weg aber ich bekomme neue Fehler, anscheinden immer wenn der Mower "schläft"
                                      • braindead
                                        Bei mir meldet der Mähroboter seit gestern, dass der Begrenzungsdraht defekt ist. Dummerweise ist der Akku komplett leer und er lädt nicht ohne Begrenzungsdraht. Den Kabel Tester habe ich bestellt und ich hoffe, dass am Wochenende wieder alles läuft. Bis dahin kann ich auf jeden Fall nicht Testen.
                                        @HAL: Versuch es mal mit der IP Adresse des Mähroboters und auch ohne Port. Evtl. ist das Dein Problem.
                                        @ManinBlack: Danke für den konkreten Hinweis auf den Fehler. Wenn ich wieder testen kann, dann werde ich ihn beheben.
                                          Hätte auch was beizutragen: Mäher geupdatet auf 1.0B5, Adapter ebenfalls aktualisiert. Mäher ist problemlos über WLAN erreichbar und steuerbar. Sieht der Adapter aber anders:
                                          robonect.0	2018-06-13 23:30:26.567	error	Error: connect ECONNRESET 192.168.1.107:80
                                          robonect.0	2018-06-13 23:27:56.774	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:27:26.414	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:25:56.946	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:25:26.386	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:24:56.497	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:24:26.380	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:23:56.220	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:23:26.325	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:21:56.522	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:21:26.306	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:20:26.279	error	Error: read ECONNRESET
                                          robonect.0	2018-06-13 23:20:26.273	error	Error: read ECONNRESET
                                          robonect.0	2018-06-13 23:20:26.270	error	Error: socket hang up
                                          robonect.0	2018-06-13 23:19:28.208	error	No connection to lawn mower. Check network connection.
                                          robonect.0	2018-06-13 23:15:26.189	error	Error: read ECONNRESET
                                          robonect.0	2018-06-13 23:15:26.188	error	Error: read ECONNRESET
                                          robonect.0	2018-06-13 23:15:26.183	error	Error: read ECONNRESET
                                          robonect.0	2018-06-13 23:15:26.174	error	Error: read ECONNRESET
                                          Im Adapter habe ich nur die 192.168.1.107 eingetragen, ein Port steht dort nicht. Unter der IP ist der Mäher auch wie gesagt problemlos erreichbar, die Ping Zeiten sind bei 2ms. Das WLAN Signal ist jetzt nicht Weltklasse, aber ok, die Browserverbindung läuft problemlos und ohne Aussetzer.
                                          Viele Grüße
                                          Christian
                                          • HAL
                                            HAL last edited by
                                            @braindead:
                                            @HAL: Versuch es mal mit der IP Adresse des Mähroboters und auch ohne Port. Evtl. ist das Dein Problem. `
                                            Vermutlich wurde der Fehler ausgelöst von einem "#" Zeichen in meinem Passwort. Ich habe das jetzt gelöscht und bisher taucht der Fehler im Log nicht mehr auf.
                                            gardena garten husqvarna mähroboter robonect
                                            58
                                            467
                                            101976
