    4. [HILFE] - iobroker startet nicht js-controller zickt
      chaser last edited by
      Ja habe ich, sollte eigentlich auch funktionieren:
      http://www.iobroker.net/docu/?page_id=5 … ion_Nodejs
      • wendy2702
        wendy2702 last edited by
        Bitte nicht Node mit NPM verwechseln.
        Mach mal bitte
        node -v
        npm -v
          node -v
          v6.14.2
          npm -v
          6.1.0
          • wendy2702
            Hm,
            Node Version ist OK.
            NPM denke ich zu hoch.
            Von dem was ich mitbekommen habe ist 5.7.1 die letzte als funktionierende getestete Version
              ok NPM gedowngraded
              sudo npm install -g npm@5.7.1
              npm -v
              5.7.1
              reboot gemacht
              sudo iobroker start
              Leider gleiches Fehlerbild:
              module.js:478
                  throw err;
              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob         roker.js'
                  at Function.Module._resolveFilename (module.js:476:15)
                  at Function.Module._load (module.js:424:25)
                  at Module.runMain (module.js:611:10)
                  at run (bootstrap_node.js:394:7)
                  at startup (bootstrap_node.js:160:9)
                  at bootstrap_node.js:507:3
              sudo npm i iobroker.js-controller@1.0.3
              npm WARN deprecated tar.gz@1.0.7: ⚠️  WARNING ⚠️ tar.gz module has been deprecated          and your application is vulnerable. Please use tar module instead: https://npmj         s.com/tar
              npm WARN notice [SECURITY] debug has 1 low vulnerability. Go here for more details: https://nodesecurity.io/advisories?search=debug&version=2.3.3 - Run `npm i npm@latest -g` to upgrade your npm version, and then `npm audit` to get more info.
              npm WARN notice [SECURITY] debug has 1 low vulnerability. Go here for more details: https://nodesecurity.io/advisories?search=debug&version=2.2.0 - Run `npm i npm@latest -g` to upgrade your npm version, and then `npm audit` to get more info.
              npm WARN notice [SECURITY] parsejson has 1 high vulnerability. Go here for more details: https://nodesecurity.io/advisories?search=parsejson&version=0.0.3 - Run `npm i npm@latest -g` to upgrade your npm version, and then `npm audit` to get more info.
              > unix-dgram@0.2.3 install /home/pi/node_modules/unix-dgram
              > node-gyp rebuild
              gyp ERR! configure error
              gyp ERR! stack Error: Command failed: /usr/bin/python2 -c import platform; print(platform.python_version());
              gyp ERR! stack Traceback (most recent call last):
              gyp ERR! stack   File "/usr/lib/python2.7/site.py", line 68, in <module>gyp ERR! stack     import os
              gyp ERR! stack ValueError: bad marshal data (unknown type code)
              gyp ERR! stack
              gyp ERR! stack     at ChildProcess.exithandler (child_process.js:199:12)
              gyp ERR! stack     at emitTwo (events.js:106:13)
              gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
              gyp ERR! stack     at maybeClose (internal/child_process.js:920:16)
              gyp ERR! stack     at Socket. <anonymous>(internal/child_process.js:351:11)
              gyp ERR! stack     at emitOne (events.js:96:13)
              gyp ERR! stack     at Socket.emit (events.js:188:7)
              gyp ERR! stack     at Pipe._handle.close [as _onclose] (net.js:509:12)
              gyp ERR! System Linux 4.9.59-v7+
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /home/pi/node_modules/unix-dgram
              gyp ERR! node -v v6.14.2
              gyp ERR! node-gyp -v v3.6.2
              gyp ERR! not ok
              > ursa@0.9.4 install /home/pi/node_modules/ursa
              > node-gyp rebuild
              gyp ERR! stack
              gyp ERR! cwd /home/pi/node_modules/ursa
              gyp ERR! not ok
              > iobroker.js-controller@1.0.3 install /home/pi/node_modules/iobroker.js-controller
              > node iobroker.js setup first
              Cannot write file. Not critical: Error: EACCES: permission denied, open '/home/pi/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
              fs.js:1112
                return binding.unlink(pathModule._makeLong(path));
              Error: EACCES: permission denied, unlink '/home/pi/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                  at Error (native)
                  at Object.fs.unlinkSync (fs.js:1112:18)
                  at Setup.setup (/home/pi/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:126:24)
                  at /home/pi/node_modules/iobroker.js-controller/lib/setup.js:590:27
                  at processCommand (/home/pi/node_modules/iobroker.js-controller/lib/setup.js:622:15)
                  at Object.module.exports.execute (/home/pi/node_modules/iobroker.js-controller/lib/setup.js:2903:5)
                  at Object. <anonymous>(/home/pi/node_modules/iobroker.js-controller/iobroker.js:1:100)
                  at Module._compile (module.js:577:32)
                  at Object.Module._extensions..js (module.js:586:10)
                  at Module.load (module.js:494:32)
              npm WARN npm@2.15.12 had bundled packages that do not match the required version(s). They have been replaced with non-bundled versions.
              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
              npm WARN pi No description
              npm WARN pi No repository field.
              npm WARN pi No README data
              npm WARN pi No license field.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 (node_modules/ursa):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa@0.9.4 install: `node-gyp rebuild`
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! iobroker.js-controller@1.0.3 install: `node iobroker.js setup first`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the iobroker.js-controller@1.0.3 install script.
              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              npm ERR!     /root/.npm/_logs/2018-05-25T16_07_47_464Z-debug.log</anonymous></anonymous></module></anonymous></module>
              sudo npm install iobroker.js-controller –production --unsafe-perm
              > iobroker.js-controller@1.4.2 preinstall /home/pi/node_modules/iobroker.js-controller
              > node lib/preinstall_check.js
              NPM version: 5.7.1
              npm version >= 5: disabling package-lock
              > node-gyp rebuild
              gyp ERR! stack
              gyp ERR! not ok
              > node-gyp rebuild
              gyp ERR! stack
              gyp ERR! not ok
              > iobroker.js-controller@1.4.2 install /home/pi/node_modules/iobroker.js-controller
              npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
              + iobroker.js-controller@1.4.2
              added 1 package from 2 contributors in 37.016s</anonymous></module></anonymous></module>
              Keiner eine Idee woran das liegen kann?
                stephan61 last edited by
                Hallo chaser du bist im falschen Ordner
                du musst in /opt/iobroker installieren
                Gruß Stephan
                • AlCalzone
                  @wendy2702:
                  Von dem was ich mitbekommen habe ist 5.7.1 die letzte als funktionierende getestete Version `
                  Nee, das hast du falsch verstanden. 5.7.1 ist das Minimum, wenn npm5+ verwendet wird. <= 4.x ist ok, >= 5.7.1 ist ok (aber hat so seine Probleme)
                  • wendy2702
                    @AlCalzone:
                    @wendy2702:
                    Nee, das hast du falsch verstanden. 5.7.1 ist das Minimum, wenn npm5+ verwendet wird. <= 4.x ist ok, >= 5.7.1 ist ok (aber hat so seine Probleme) `
                    Ah, ok.
                    Und wie sieht es dann mit NPM 6 aus?
                      Bringt leider auch keine Abhilfe:
                      pi@raspberrypi:~ $ cd /opt/iobroker
                      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.js-controller --product            ion --unsafe-perm
                      > iobroker.js-controller@1.4.2 preinstall /opt/iobroker/node_modules/iobroker.js            -controller
                      NPM version: 5.7.1
                      > iobroker.js-controller@1.4.2 install /opt/iobroker/node_modules/iobroker.js-co            ntroller
                      npm notice created a lockfile as package-lock.json. You should commit this file.
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/har-validator'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/mime'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/mkdirp'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/node-pre-gyp'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/nopt'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/rc'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/rimraf'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/semver~0'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/serialport-list'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/serialport-term'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/sshpk-conv'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/sshpk-conv~1'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/sshpk-sign'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/sshpk-sign~1'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/sshpk-verify'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/sshpk-veri~1'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/strip-json-comments'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/supports-color'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/uuid'
                      npm WARN enoent ENOENT: no such file or directory, stat '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/uu~1'
                      npm WARN Failed to parse json
                      npm WARN Unexpected token v in JSON at position 0 while parsing near 'var SSDP =             require('...'
                      npm WARN File: /opt/iobroker/node_modules/iobroker.discovery/node_modules/ip/pac            kage.json
                      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modu            les/iobroker.discovery/node_modules/ms/package.json'
                      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/lib/package.json'
                      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modu            les/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/http-            signature/node_modules/test/package.json'
                      added 28 packages from 34 contributors, updated 2 packages and moved 5 packages             in 174.159s
                         │   Update available 5.7.1 → 6.1.0    │
                         │     Run npm i -g npm to update      │
                      • wendy2702
                        Installiere doch mal vorher das Paket````
                        serialport
                        Das meckert er doch an
                        • AlCalzone
                          @wendy2702:
                          Und wie sieht es dann mit NPM 6 aus? `
                          Läuft bei mir, hat aber die selben Fallstricke wie NPM5, was root-Rechte angeht.
                          2614
