    4. [Vorlage] todoist.com To-Do-Listen Script für VIS
    • ruhr70
      ruhr70 last edited by
      so…
      zusätzlich zur todoist -> ical Synchronisation habe ich das Skript jetzt auch im Produktivbetrieb.
      Danke für das Skript!
        tempestas last edited by
        @PrinzEisenherz1:
        Hi zusammen.
        Ich nutze jetzt auch schon seit ner weile dieses tolle Script.
        Bloß ist mir seit gestern im Log folgendes aufgefallen
        ! host.orangepiplus2e 2018-04-03 11:35:01.895 info Restart adapter system.adapter.javascript.2 because enabled host.orangepiplus2e 2018-04-03 11:35:01.894 error instance system.adapter.javascript.2 terminated with code 0 (OK) Caught 2018-04-03 11:35:01.893 error by controller[0]: at IncomingMessage.g (events.js:292:16) Caught 2018-04-03 11:35:01.892 error by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12) Caught 2018-04-03 11:35:01.892 error by controller[0]: at Request.emit (events.js:188:7) Caught 2018-04-03 11:35:01.891 error by controller[0]: at emitOne (events.js:96:13) Caught 2018-04-03 11:35:01.891 error by controller[0]: at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10) Caught 2018-04-03 11:35:01.890 error by controller[0]: at Request.emit (events.js:191:7) Caught 2018-04-03 11:35:01.889 error by controller[0]: at emitTwo (events.js:106:13) Caught 2018-04-03 11:35:01.889 error by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22) Caught 2018-04-03 11:35:01.888 error by controller[0]: at Request._callback (script.js.Alexa.Einkaufsliste:127:29) Caught 2018-04-03 11:35:01.887 error by controller[0]: at Object.parse (native) Caught 2018-04-03 11:35:01.883 error by controller[0]: SyntaxError: Unexpected token I in JSON at position 0 javascript.2 2018-04-03 11:35:01.770 info terminating javascript.2 2018-04-03 11:35:01.757 error at IncomingMessage.g (events.js:292:16) javascript.2 2018-04-03 11:35:01.757 error at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12) javascript.2 2018-04-03 11:35:01.757 error at Request.emit (events.js:188:7) javascript.2 2018-04-03 11:35:01.757 error at emitOne (events.js:96:13) javascript.2 2018-04-03 11:35:01.757 error at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10) javascript.2 2018-04-03 11:35:01.757 error at Request.emit (events.js:191:7) javascript.2 2018-04-03 11:35:01.757 error at emitTwo (events.js:106:13) javascript.2 2018-04-03 11:35:01.757 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22) javascript.2 2018-04-03 11:35:01.757 error at Request._callback (script.js.Alexa.Einkaufsliste:127:29) javascript.2 2018-04-03 11:35:01.757 error at Object.parse (native) javascript.2 2018-04-03 11:35:01.757 error SyntaxError: Unexpected token I in JSON at position 0 javascript.2 2018-04-03 11:35:01.755 error uncaught exception: Unexpected token I in JSON at position 0 !
        Mein Script sieht wie folgt aus:
        `// Todoist Script zur Erstellung eines HTML Codes zur Einbindung in VIS mittels "basic - String (unescaped)" Widget
        // Scriptversion: v0.2
        // Ergänzungen tempestas, Stand 17.3.2018
        // https://forum.iobroker.net/viewtopic.php?f=21&t=12563
        // https://forum.iobroker.net/viewtopic.php?f=21&p=133205#p133205
        ! //Erforderliche Angaben:
        var APItoken = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"; // API Token kann in den Todoist Settings auf der Webseite ausgelesen werden
        var debug = false;
        var idEinkaufsliste= "javascript.2.Todoist.Alexa-Einkaufsliste";
        var force = false;
        ! //Weitere Parameter ggf. anpassen:
        var instanz = 'javascript.2'; instanz = instanz + '.'; // Instanz fuer die Datenpunkte definieren
        var pfad = 'Todoist.'; // Pfad definieren
        // var regexTrigger = /^javascript.0.Einkaufsliste.Items..$/; // Trigger analog der manuellen Einkaufsliste, brauchst du nicht, deaktiviert
        ! schedule("
        /1 * * * ", checkTODOIST); // Abfragezeit: jede Minute
        // Scriptbeginn - Ab hier nichts mehr ändern!
        ! createState(instanz + pfad +'telegramBtn', false, force, { // sendet die Liste via Telegram
        name: 'Send Telegram',
        desc: 'Sendet Telegram Einkaufsliste',
        type: 'boolean',
        role: 'state',
        unit: ''
        ! var idTelegram = instanz + pfad +"telegramBtn";
        ! function sendTelegram() {
        Modifizierung durch mich /
        var Einkaufsliste1 = getState(idEinkaufsliste).val;
        einkaufsliste = entferneDatenpunkt(Einkaufsliste1);
        var telegramtext = einkaufsliste;
        // var telegramtext = getState(idEinkaufsliste).val.replace(/
        /g , "\n"); // telegram Liste formatieren, entfernt den Zeilenumbruch für vis und ersettz mit Zeilenumbruch Telegram
        sendTo('telegram.0', { // Nachricht per Telegram senden
        text: "Bitte mitbringen:\n\n" + telegramtext
                setStateDelayed(idTelegram, false, 2000);
        ! // Trigger Telegram
        ! on(idTelegram, function(obj){ // trigger für Telegram
        if(obj.state.val === true){
        sendTelegram();
        ! function checkTODOIST() {
        var APIprojectsURL = "https://beta.todoist.com/API/v8/projects?token="+APItoken;
        var APItaskURL = "https://beta.todoist.com/API/v8/tasks?token="+APItoken;
        var request = require("request");
        var ToDoListen = []; // wird mit IDs der TO-DO Listen befuellt
        var ToDoListen_names = []; // wird mit Namen der TO-DO Listen befuellt
        request(APIprojectsURL, function (error, response, body) {
            try{
                var projects_json = JSON.parse(body);
                for (k = 0; k < projects_json.length; k++) {
                    var projects = parseInt(projects_json[k].id);
                    var projects_name = JSON.stringify(projects_json[k].name);
                    projects_name = projects_name.replace(/\"/g, ""); //entfernt die Anfuehrungszeichen aus dem quellstring
                    ToDoListen[ToDoListen.length] = projects;
                    ToDoListen_names[ToDoListen_names.length] = projects_name;
                    createState(instanz + pfad + ToDoListen_names[k], {def: 'false',type: 'string',role: 'html', name: ToDoListen_names[k]+' HTML String'});
                    if(debug) log("Datenpunkt "+ToDoListen_names[k]+" erstellt.", "info");
                    createState(instanz + pfad + ToDoListen_names[k]+'.TaskID', {def: 'false',type: 'string',role: 'string', name: ToDoListen_names[k]+' Task IDs'});
                    if(debug) log("Datenpunkt "+ToDoListen_names[k]+'.TaskID'+" erstellt.", "info");
            catch(err) {log (err.message)}
        setTimeout(function() {
            try{
                request(APItaskURL, function (error, response, body) {
                    var json = JSON.parse(body);
                    for (j = 0; j < ToDoListen.length; j++) {
                        var HTMLstring = "";
                        setState(instanz + pfad + ToDoListen_names[j],"");
                        for (i = 0; i < json.length; i++) {
                            var Liste = parseInt(json[i].project_id);
                            var content = JSON.stringify(json[i].content);
                            content = content.replace(/\"/g, ""); //entfernt die Anfuehrungszeichen aus dem quellstring
                            content = content[0].toUpperCase() + content.substring(1); // Macht den ersten Buchstaben des strings zu einem Grossbuchstaben
                            var taskurl = JSON.stringify(json[i].url);
                            taskurl = taskurl.replace(/\"/g, "");
                            if (Liste == ToDoListen[j])
                                if(debug) log ("["+content+"] in "+ToDoListen_names[j]+" gefunden", "info");
        ! /* Modifizierung durch mich /
        // HTMLstring = HTMLstring+content+"
        "; // mit Link: HTMLstring = HTMLstring+"
        "+content+"";
        ! HTMLstring = HTMLstring+"  •  "+content+"
        "; // mit Link: HTMLstring = HTMLstring+"* "+content+"";
        ! setState(instanz + pfad + ToDoListen_names[j], HTMLstring); // "<>"+HTMLstring+"
        catch(err) {log(err.message)}
        }, 1000);
            setTimeout(function() {                                                 // legt IDs der einzelnen Tasks in Unterordnern an
                    setState(instanz + pfad + ToDoListen_names[j] +'.TaskID', "");
                        var taskid = JSON.stringify(json[i].id);
                            if(debug) log ("["+taskid+"] in "+ToDoListen_names[j]+" gefunden", "info");
                            HTMLstring = HTMLstring+taskid+"
        setState(instanz + pfad + ToDoListen_names[j]+'.TaskID', HTMLstring); // "<>"+HTMLstring+"
        }, 1000);
        /* Modifiziert durch mich /
        Entferne Sonderzeichen für Telegramübertragung aus Datenpunkt */
        function entferneDatenpunkt(beschreibung) {
        var rueckgabe;
        rueckgabe = beschreibung;
        try {
        rueckgabe = rueckgabe.replace(/  •  /g, "");
        /g , "\n");
        catch(e) {}
        return rueckgabe;
        ! Ich habe leichte Veränderungen am Originalscript. Kann man erkennen anhand der Bemerkung "Modifiziert durch mich"
        ! Dienen rein der Kosmetik zur Anzeige auf VIS bzw. der Übertragung durch Telegram.
        ! Dürften eigentlich nicht den Error verursachen. Vorallem weil es ja jetzt über Tage ohne Probleme funktioniert hat.
        ! Hat jemand n ähnliches Problem bei dem Script?
        ! Gruß
        ! Johnny
        ! Hallo Johnny,
        ! genau das gleiche Problem habe ich auch. Tritt unregelmäßig auf, ich kann nicht feststellen, wann und warum. Siehe mein Posting weiter vorne, da habe ich zunächst vermutet, dass es mit leeren Listen zu tun hat, dem ist aber nicht so.[/i][/i][/i][/i][/i]
          Fatmax last edited by
          @dali3:
          Bilder sagen mehr als 1000 Worte.
          Jedoch habe ich glaubs auch ein anderes Problem 🙂
          siehe /start hmm `
          Ich habe plötzlich das gleiche Problem -> Einkauf wird nicht verstanden, Liste wird aber trotzdem angefordert und übertragen.
          ->gibt es hier dazu eine Lösung?
            Hallo fatmax,
            leider habe ich keine Lösung dazu. Hilft dir zwar nicht, aber ich wollte dich wissen lassen, dass deine Frage nicht ignoriert wird.
              @tempestas:
              Hallo fatmax,
              leider habe ich keine Lösung dazu. Hilft dir zwar nicht, aber ich wollte dich wissen lassen, dass deine Frage nicht ignoriert wird. `
              Danke für die Rückmeldung, die Liste wird ja abgerufen, damit kann ich leben.
              Noch eine andere Frage:
              Die Liste wird in VIS in einem "String unescaped" angezeigt.
              ->Kann man hier irgendwie Scrollbalken einschalten, falls die Liste einmal länger wird?
              Im Moment schneidet es den Rest ab.
                Kannst du im Widget tun.
                In den Einstellungen "overflow y" auf scroll oder auto stellen. Am PC wirst du einen Scrollbalken sehen, auf dem Tablet kannst du einfach mit dem Finger schieben, kein scroll balken da
                  @tempestas: Danke für die Hilfe, funktioniert einwandfrei.
                    Goldblaster last edited by
                    Hallo Leute,
                    ich habe heute die Step by Step Anleitung von "tempestas" ausprobiert.
                    Liste wird angezeigt und auch Einträge von Alexa werden übernommen.
                    Nur habe ich Probleme mit der Erstellung des Löschen und Telegramm Button.
                    Wenn ich diese als Widget im Vis Editor Importiere dann wird mir der Button nicht Angezeigt, rechts in den Einstellungen steht allerdings bei Name: Löschen. Wo ist der Button, bzw. weshalb wird mir dieser nicht angezeigt?
                    Bin Anfänger im Bereich der Vis Editor, irgendwie alles Neuland?
                    Besten Dank und gute Nacht. WJ
                      andyb last edited by
                      Hast du die Metro Widgets in Vis installiert?
                      • haselchen
                        haselchen Most Active last edited by
                        Ich habe aus dem Nichts nun das Problem , dass die Einkaufsliste zwischen Alexa und Todoist nicht mehr abgeglichen wird. Damit holt das Skript nun immer den letzten Stand, es sei denn ich logge ich bei Todoist ein und gebe was manuell ein.
                        Cookie ist valide, Iobroker Log weist auch keine Fehler auf und Todoist ist mit dem Alexa Konto gekoppelt.
                        Wo liegt nun der Fehler aus dem Nichts?
                          rainman1979 last edited by
                          Ich hatte bei mir auch das Problem mit "Ich verstehe einkauf nicht",
                          bei mir lag es daran, das ich text2command installiert habe und logischerweise verstehet t2c "einkauf" nicht.
                          Ich habe einfach Quick and Dirty eine Zeile in t2c erstellt mit:
                          Schalte irgendwas an oder aus | Einkaufsliste | Haken setzen | verweis auf irgend ein Script (ich habe das Todoist Telegram Script)| leer lassen | leer lassen
                          Dadurch erscheint der Fehler nicht mehr 🙂
                          Gibt sicher einen eleganteren Weg, aber soweit bin ich noch nicht drin in der Materie.
                          Gruß Holger
                          • haselchen
                            Bei Todoist gibt es die Inbox und in der habe ich Termine weit in der Zukunft, wie kann ich in VIS diese Termine mit Datum anzeigen lassen?
                            Wenn möglich bitte als Skript , ich habe davon leider keine Ahnung :roll:
                            • haselchen
                              Hab noch eine andere Frage , ist tempestas hier noch aktiv?
                              Habe weiter vorne gelesen , dass du diesen unexpected token Fehler hattest.
                              Den habe ich genauso, immer irgendwann mal zwischendurch.
                              Hast du den wegbekommen?
                                mk120 last edited by
                                Habt ihr eventuell eine Idee wie man per Telegram Dinge auf die Einkaufliste setzen kann? Derzeit funktioniert es nur per Alexa oder halt per App.
                                Ich habe schon an Text2Command gedacht aber der überschreibt den Inhalt kurz und nach der Synctime wird die eigentliche Einkaufliste wieder geladen.. Stehe nun etwas auf dem Schlauch.. Anonsten wie immer geiles Script und Umsetzung.
                                  Golf GTI last edited by
                                  Hallo bin neu Hier könnte mir jemand helf bitte
                                  hab das Script genommen leider bekomme ich immer Felermeldung
                                  var debug = false;
                                  var force = false;
                                  ! schedule("/1 * * * ", checkTODOIST); // Abfragezeit: jede Minute
                                  type: 'boolean',
                                  role: 'state',
                                  unit: ''
                                  ! / Modifizierung durch mich /
                                  sendTelegram();
                                  try{
                                  try{
                                  "; // mit Link: HTMLstring = HTMLstring+" "+content+"";
                                  }, 1000);
                                  }, 1000);
                                  / Entferne Sonderzeichen für Telegramübertragung aus Datenpunkt */
                                  var rueckgabe;
                                  try {
                                  /g , "\n");
                                  catch(e) {}
                                  return rueckgabe;
                                  ! Gruß
                                  ! Johnny
                                  ! Hallo Johnny,
                                    backons last edited by
                                    Könnte mir jemand den Javascript Code nochmal schicken oder hier posten das er zusammenhängend ist. Wenn ich versuche die Code Schnipsel von oben zusammen zu fügen bekomme ich das Script leider nicht zu laufen....
                                      Skript 1:
                                      var APItoken = ""; // API Token kann in den Todoist Settings auf der Webseite ausgelesen werden
                                      var debug = false;
                                      var instanz = 'javascript.0';  instanz = instanz + '.';     // Instanz fuer die Datenpunkte definieren
                                      var regexTrigger = /^javascript\.0\.Einkaufsliste\.Items\..*$/;   // Trigger analog der manuellen Einkaufsliste
                                      schedule("*/1 * * * *", checkTODOIST);  // Abfragezeit: jede Minute
                                              try{
                                              try{
                                                          setState(instanz + pfad + ToDoListen_names[j], "leer");
        HTMLstring = HTMLstring+content+"<br>";  // mit Link: HTMLstring = HTMLstring+"<tr><td><li><a href=\""+taskurl+"\" target=\"_blank\">"+content+"</a></li></td></tr>";
        setState(instanz + pfad + ToDoListen_names[j], HTMLstring);   // "<table><>"+HTMLstring+"</ul></table>");
                                          }, 1000);
                                                      setState(instanz + pfad + ToDoListen_names[j] +'.TaskID', "leer");
                                                              HTMLstring = HTMLstring+taskid+"<br>";  // mit Link: HTMLstring = HTMLstring+"<tr><td><li><a href=\""+taskurl+"\" target=\"_blank\">"+content+"</a></li></td></tr>";
                                                              setState(instanz + pfad + ToDoListen_names[j]+'.TaskID', HTMLstring);   // "<table><>"+HTMLstring+"</ul></table>");
                                          }, 1000);
                                      // TRIGGER
                                      on({    id:regexTrigger,
                                              change: 'ne'},
                                              function() {                          // regex trigger, löst immer aus sobald etwas in der manuellen Liste an- oder abgewählt wird
                                                  checkTODOIST();
                                      Skript2 zum löschen:
                                      //Todoist Script zur Erstellung eines HTML Codes zur Einbindung in VIS mittels "basic - String (unescaped)" Widget:
                                      // LÖSCHEN FUNKTION
                                      //Scriptversion: v0.1
                                      //https://forum.iobroker.net/viewtopic.php?f=21&t=12563
                                      var idEinkaufsliste = "javascript.0.Todoist.Alexa-Einkaufsliste.TaskID"/*Alexa-Einkaufsliste HTML String*/;
                                      var debug = false;
                                      createState(instanz + pfad +'clearBtn', false, force, {               // löschen Button, damit man nicht alles manuell abwählen muss
                                                  desc: 'Löscht die Liste',
                                                  type: 'boolean',
                                                  role: 'state',
                                                  unit: ''
                                      var idClear = instanz + pfad + 'clearBtn';
                                      function deleteTask(){
                                          var idListArray =[];
                                          var idList;
                                          idList = getState(idEinkaufsliste).val;
                                          if(debug)log(idList);
                                          idListArray = idList.split("<br>");
                                          idListArray.pop();                                      // aufgrund meiner uneleganten Änderungen steht als letztes immer "<br>" in der Liste. Damit würde ein Element zuviel ausgegeben werden (leer). Pop kürzt den array ums letzte Element
                                          if(debug)log("idList Array ist " +idListArray);
                                          if(debug)log("idList Array Länge ist "+idListArray.length);
                                          for (i = 0; i< idListArray.length; i++){
                                              if(debug) log("Durchgang "+i);
                                              var deleteURL = "https://beta.todoist.com/API/v8/tasks/"+idListArray[i]+"?token="+APItoken;
                                              if(debug) log("Delete URL ist "+deleteURL);
                                              request({
                                                  uri: deleteURL,
                                                  method: "DELETE",
                                                  timeout: 5000,
                                                      function(error, response, body) {
                                                      if(debug) console.log(body);
                                      // Löschen der Liste
                                      on(idClear, function(obj){                      // trigger fürs Löschen
                                              deleteTask();
                                      Skript 3:
                                      // SKRIPT FÜGT DER ALEXA EINKAUFSLISTE BEI TODOIST EINEN GEGENSTAND HINZU; WENN DIESER IN DER MANUELLEN EINKAUFSLISTE HINZUGEFÜGT WIRD
                                      var debug = true;
                                      var idProject = 123; // Projekt-ID der Alexa-Einkaufsliste aus todoist
                                      var idEinkaufsIDS = "javascript.0.Todoist.Alexa-Einkaufsliste.TaskID";        // hier stehen die Task IDs
                                      var idEinkaufsItems = "javascript.0.Todoist.Alexa-Einkaufsliste"/*Alexa-Einkaufsliste HTML String*/;
                                      var uuid;
                                      var purchItem;
                                      // uuid erstellen
                                      function createUUID(){
                                          var dt = new Date().getTime();
                                          uuid = 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function(c) {
                                              var r = (dt + Math.random()*16)%16 | 0;
                                              dt = Math.floor(dt/16);
                                              return (c=='x' ? r :(r&0x3|0x8)).toString(16);
                                          return uuid;
                                      // "Aufgabe" bzw Einkaufsgegenstand zur todoist Alexa Liste hinzufügen
                                      function addTask(){
                                              createUUID();
                                              log(uuid);
                                              var options = { method: 'POST',
                                                url: 'https://beta.todoist.com/API/v8/tasks',
                                                headers:
                                                 { 'Cache-Control': 'no-cache',
                                                   Authorization: 'Bearer ' +APItoken,
                                                   'X-Request-Id': uuid,
                                                   'Content-Type': 'application/json' },
                                                body:
                                                 { content: purchItem,
                                                   project_id: +idProject,
                                                json: true };
                                              request(options, function (error, response, body) {
                                                if (error) throw new Error(error);
                                                if(debug) console.log(JSON.stringify(body));
                                      // "Aufgabe" bzw Einkaufsgegenstand von todoist entfernen
                                          // Array der IDs aufbereiten
                                          var idListIDsArray =[];
                                          var idListIDs;
                                          idListIDs = getState(idEinkaufsIDS).val;
                                          if(debug)log(idListIDs);
                                          idListIDsArray = idListIDs.split("<br>");
                                          idListIDsArray.pop();                                      // aufgrund meiner uneleganten Änderungen steht als letztes immer "<br>" in der Liste. Damit würde ein Element zuviel ausgegeben werden (leer). Pop kürzt den array ums letzte Element
                                          // Array der Items aufbereiten
                                          var idList;
                                          idList = getState(idEinkaufsItems).val;
                                          idListArray.pop();
                                          // Bestimmen der ID Position im Array
                                          var arrayPosition = idListArray.indexOf(purchItem);
                                          // Den Gegenstand über die gefundene ID löschen
                                              var deleteURL = "https://beta.todoist.com/API/v8/tasks/"+idListIDsArray[arrayPosition]+"?token="+APItoken;
                                              request({
                                                  uri: deleteURL,
                                                  method: "DELETE",
                                                  timeout: 5000,
                                      // Trigger und Wertübergabe
                                      on({    id:regexTrigger,   change: 'ne'},                           // regex trigger, löst immer aus sobald etwas an- oder abgewählt wird
                                                  function(data) {
                                                      var temporary;
                                                      temporary = data.id;
                                                      purchItem = temporary.substring(33);                // Pfad bis zum Item ist 33 Stellen lang
                                                      if(data.state.val) {                                // wenn das item auf der manuellen Liste hinzugefügt wurde (state ist true) dann...
                                                          if (debug) log("Es wird hinzugefügt: "+purchItem);
                                                          setTimeout(addTask, 500); }
                                                      else {                                              // sonst wenn wenn das item auf der manuellen Liste entfernt wurde dann...
                                                          if (debug) log("Es wird entfernt: "+purchItem);
                                                          setTimeout(deleteTask, 500);
                                      Ob das alles noch funktioniert weiß ich nicht, ich nutze es nicht. Habs damals nur von exTreme mal zum rumspielen genutzt.
                                      B tobetobe 2 Replies Last reply Reply Quote 0
                                        bdasch @tempestas last edited by
                                        @tempestas leider habe ich bei dem Script immer wieder eine Fehlermeldung:
                                        Kann mir jemand helfen?
                                          Golf GTI @bdasch last edited by
                                          Script 1
                                          var APItoken = "API Eintragen"; // API Token kann in den Todoist Settings auf der Webseite ausgelesen werden
                                          var debug = false;
                                          var regexTrigger = /^javascript.0.Einkaufsliste.Items..*$/; // Trigger analog der manuellen Einkaufsliste
                                          schedule("* * * * *", checkTODOIST); // Abfragezeit: jede Minute
                                              try{
                                              try{
                                          }, 1000);
                                          }, 1000);
                                          // TRIGGER
                                              change: 'ne'},
                                                  checkTODOIST();
                                            Bei mir bekomme ich immer Im Log eine fehlermeldung woran diese liegt weiß ich nicht
                                            • javascript.0 warn State "[object Object]" not found**
                                              kenne mich nicht mit javascript aus
                                              ansonsten leuft es
                                            130
                                            23143
