    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер Telegram Adapter
    • goofyk
      goofyk last edited by
      копать сюда https://github.com/kirovilya/ioBroker.telegram
      сделал PR в основной репозиторий, ждем обновления драйвера
        smoker_vvo last edited by
        Обновил драйвер, да же настроил прокси…...
        Но вы итоге......
        ! host.GoldFish2 2018-05-01 19:57:28.888 info instance system.adapter.telegram.0 started with pid 7164
        ! host.GoldFish2 2018-05-01 19:57:27.868 info Restart adapter system.adapter.telegram.0 because enabled
        ! host.GoldFish2 2018-05-01 19:57:27.868 error instance system.adapter.telegram.0 terminated with code 0 (OK)
        ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: port: 443 }
        ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: address: '88.212.233.100',
        ! host.GoldFish2 2018-05-01 19:57:27.868 error Caught by controller[1]: syscall: 'connect',
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: errno: 'ETIMEDOUT',
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: code: 'ETIMEDOUT',
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1087:14)
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at exports._exceptionWithHostPort (util.js:1045:20)
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: at Object.exports._errnoException (util.js:1022:11)
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: { Error: connect ETIMEDOUT 88.212.233.100:443
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: port: 443 }
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: address: '88.212.233.100',
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[1]: syscall: 'connect',
        ! host.GoldFish2 2018-05-01 19:57:27.867 error Caught by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:570:32
        ! host.GoldFish2 2018-05-01 19:57:27.866 error Caught by controller[0]: In the future, you will have to enable it yourself.
        ! host.GoldFish2 2018-05-01 19:57:27.866 error Caught by controller[0]: Tue, 01 May 2018 09:57:05 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
        ! telegram.0 2018-05-01 19:57:27.354 error Error: connect ETIMEDOUT 88.212.233.100:443 at Object.exports._errnoException (util.js:1022:11) at exports._exceptionWithHostPort (util.js:1045:20) at TCPConnectWrap.afterConnect [as oncom
        ! telegram.0 2018-05-01 19:57:27.354 error uncaught exception: connect ETIMEDOUT 88.212.233.100:443
        ! telegram.0 2018-05-01 19:57:27.353 error uncaught exception: connect ETIMEDOUT 88.212.233.100:443
        ! telegram.0 2018-05-01 19:57:06.323 info starting. Version 1.2.3 in C:/ioBroker/node_modules/iobroker.telegram, node: v6.9.5
        ! host.GoldFish2 2018-05-01 19:56:56.386 info instance system.adapter.telegram.0 started with pid 7240
        ! host.GoldFish2 2018-05-01 19:56:55.357 info Restart adapter system.adapter.telegram.0 because enabled
        Куда рыть дальше??? Или какой прокси использовать??
        • ViR
          ViR last edited by
          Добрый день тоже сыпятся ошибки при настройки прокси:
          ! host.orangepipcplus 2018-05-09 12:22:13.425 error instance system.adapter.telegram.0 terminated with code 0 (OK)
          ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
          ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at Socket.Readable.push (_stream_readable.js:208:10)
          ! Caught 2018-05-09 12:22:13.425 error by controller[3]: at readableAddChunk (_stream_readable.js:250:11)
          ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at addChunk (_stream_readable.js:263:12)
          ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at Socket.emit (events.js:211:7)
          ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at emitOne (events.js:116:13)
          ! Caught 2018-05-09 12:22:13.424 error by controller[3]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
          ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
          ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser.emit (events.js:211:7)
          ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at emitOne (events.js:116:13)
          ! Caught 2018-05-09 12:22:13.423 error by controller[3]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
          ! Caught 2018-05-09 12:22:13.422 error by controller[3]: { Error: Authentication method mismatch
          ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
          ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at Socket.Readable.push (_stream_readable.js:208:10)
          ! Caught 2018-05-09 12:22:13.422 error by controller[2]: at readableAddChunk (_stream_readable.js:250:11)
          ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at addChunk (_stream_readable.js:263:12)
          ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at Socket.emit (events.js:211:7)
          ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at emitOne (events.js:116:13)
          ! Caught 2018-05-09 12:22:13.421 error by controller[2]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
          ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
          ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser.emit (events.js:211:7)
          ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at emitOne (events.js:116:13)
          ! Caught 2018-05-09 12:22:13.420 error by controller[2]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
          ! Caught 2018-05-09 12:22:13.420 error by controller[2]: { Error: Authentication method mismatch
          ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at TCP.onread (net.js:607:20) code: 'EAUTHNOTSUPPORT' }
          ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at Socket.Readable.push (_stream_readable.js:208:10)
          ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at readableAddChunk (_stream_readable.js:250:11)
          ! Caught 2018-05-09 12:22:13.419 error by controller[1]: at addChunk (_stream_readable.js:263:12)
          ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Socket.emit (events.js:211:7)
          ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at emitOne (events.js:116:13)
          ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
          ! Caught 2018-05-09 12:22:13.418 error by controller[1]: at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
          ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at Parser.emit (events.js:211:7)
          ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at emitOne (events.js:116:13)
          ! Caught 2018-05-09 12:22:13.417 error by controller[1]: at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
          ! Caught 2018-05-09 12:22:13.417 error by controller[1]: { Error: Authentication method mismatch
          ! Caught 2018-05-09 12:22:13.416 error by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:652:30
          ! Caught 2018-05-09 12:22:13.416 error by controller[0]: In the future, you will have to enable it yourself.
          ! Caught 2018-05-09 12:22:13.415 error by controller[0]: Wed, 09 May 2018 02:22:11 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
          ! telegram.0 2018-05-09 12:22:13.324 info terminating
          ! telegram.0 2018-05-09 12:22:12.816 error at TCP.onread (net.js:607:20)
          ! telegram.0 2018-05-09 12:22:12.816 error at Socket.Readable.push (_stream_readable.js:208:10)
          ! telegram.0 2018-05-09 12:22:12.816 error at readableAddChunk (_stream_readable.js:250:11)
          ! telegram.0 2018-05-09 12:22:12.816 error at addChunk (_stream_readable.js:263:12)
          ! telegram.0 2018-05-09 12:22:12.816 error at Socket.emit (events.js:211:7)
          ! telegram.0 2018-05-09 12:22:12.816 error at emitOne (events.js:116:13)
          ! telegram.0 2018-05-09 12:22:12.816 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
          ! telegram.0 2018-05-09 12:22:12.816 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
          ! telegram.0 2018-05-09 12:22:12.816 error at Parser.emit (events.js:211:7)
          ! telegram.0 2018-05-09 12:22:12.816 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
          ! telegram.0 2018-05-09 12:22:12.816 error Error: Authentication method mismatch
          ! telegram.0 2018-05-09 12:22:12.815 error uncaught exception: Authentication method mismatch
          ! telegram.0 2018-05-09 12:22:12.809 error at TCP.onread (net.js:607:20)
          ! telegram.0 2018-05-09 12:22:12.809 error at Socket.Readable.push (_stream_readable.js:208:10)
          ! telegram.0 2018-05-09 12:22:12.809 error at readableAddChunk (_stream_readable.js:250:11)
          ! telegram.0 2018-05-09 12:22:12.809 error at addChunk (_stream_readable.js:263:12)
          ! telegram.0 2018-05-09 12:22:12.809 error at Socket.emit (events.js:211:7)
          ! telegram.0 2018-05-09 12:22:12.809 error at emitOne (events.js:116:13)
          ! telegram.0 2018-05-09 12:22:12.809 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
          ! telegram.0 2018-05-09 12:22:12.809 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
          ! telegram.0 2018-05-09 12:22:12.809 error at Parser.emit (events.js:211:7)
          ! telegram.0 2018-05-09 12:22:12.809 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
          ! telegram.0 2018-05-09 12:22:12.809 error Error: Authentication method mismatch
          ! telegram.0 2018-05-09 12:22:12.808 error uncaught exception: Authentication method mismatch
          ! telegram.0 2018-05-09 12:22:12.798 error at TCP.onread (net.js:607:20)
          ! telegram.0 2018-05-09 12:22:12.798 error at Socket.Readable.push (_stream_readable.js:208:10)
          ! telegram.0 2018-05-09 12:22:12.798 error at readableAddChunk (_stream_readable.js:250:11)
          ! telegram.0 2018-05-09 12:22:12.798 error at addChunk (_stream_readable.js:263:12)
          ! telegram.0 2018-05-09 12:22:12.798 error at Socket.emit (events.js:211:7)
          ! telegram.0 2018-05-09 12:22:12.798 error at emitOne (events.js:116:13)
          ! telegram.0 2018-05-09 12:22:12.798 error at Socket.Parser.__onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:33:10)
          ! telegram.0 2018-05-09 12:22:12.798 error at Parser._onData (/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.parser.js:85:14)
          ! telegram.0 2018-05-09 12:22:12.798 error at Parser.emit (events.js:211:7)
          ! telegram.0 2018-05-09 12:22:12.798 error at Parser. <anonymous>(/opt/iobroker/node_modules/iobroker.telegram/node_modules/socksv5/lib/client.js:102:15)
          ! telegram.0 2018-05-09 12:22:12.798 error Error: Authentication method mismatch
          ! telegram.0 2018-05-09 12:22:12.796 error uncaught exception: Authentication method mismatch</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
          Кто подскажет где копать?
          • goofyk
            Похоже, что-то не так с прокси.
            Попробуй такой прокси:
            Server: socks.kuzmitch.ru
            Port: 1080
            User: socksuser
            Pass: heropass2
            • ViR
              ViR last edited by
              @goofyk:
              Port: 1080
              User: socksuser
              Pass: heropass2 `
              И с этим не хотит но ошибка уже другая, такая же как и без прокси
              ! telegram.0 2018-05-11 04:33:59.911 error polling_error:EFATAL, EFATAL: Error: self signed certificate
              ! telegram.0 2018-05-11 04:33:58.560 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.11.1
              причем когда останавливаешь бота Telegramm сыпятся ошибки
              ! host.orangepipcplus 2018-05-11 04:54:45.766 info instance system.adapter.telegram.0 terminated with code 0 (OK)
              ! Caught 2018-05-11 04:54:45.766 error by controller[1]: at process._tickCallback (internal/process/next_tick.js:180:9)
              ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
              ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at emitErrorNT (internal/streams/destroy.js:64:8)
              ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at TLSSocket.emit (events.js:211:7)
              ! Caught 2018-05-11 04:54:45.765 error by controller[1]: at emitOne (events.js:116:13)
              ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
              ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at ClientRequest.emit (events.js:211:7)
              ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at emitOne (events.js:116:13)
              ! Caught 2018-05-11 04:54:45.764 error by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:878:8)
              ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.emit (events.js:211:7)
              ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at emitOne (events.js:116:13)
              ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at self.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:186:22)
              ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-
              ! Caught 2018-05-11 04:54:45.763 error by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/
              ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at new RequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js
              ! Caught 2018-05-11 04:54:45.762 error by controller[1]: Unhandled rejection RequestError: Error: self signed certificate
              ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at process._tickCallback (internal/process/next_tick.js:180:9)
              ! Caught 2018-05-11 04:54:45.762 error by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
              ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at emitErrorNT (internal/streams/destroy.js:64:8)
              ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at TLSSocket.emit (events.js:211:7)
              ! Caught 2018-05-11 04:54:45.761 error by controller[1]: at emitOne (events.js:116:13)
              ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
              ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at ClientRequest.emit (events.js:211:7)
              ! Caught 2018-05-11 04:54:45.760 error by controller[1]: at emitOne (events.js:116:13)
              ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:878:8)
              ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at Request.emit (events.js:211:7)
              ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at emitOne (events.js:116:13)
              ! Caught 2018-05-11 04:54:45.759 error by controller[1]: at self.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request/request.js:186:22)
              ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-
              ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at Request.plumbing.callback (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/
              ! Caught 2018-05-11 04:54:45.758 error by controller[1]: at new RequestError (/opt/iobroker/node_modules/iobroker.telegram/node_modules/node-telegram-bot-api/node_modules/request-promise/node_modules/request-promise-core/lib/errors.js
              ! Caught 2018-05-11 04:54:45.758 error by controller[1]: Unhandled rejection RequestError: Error: self signed certificate
              ! Caught 2018-05-11 04:54:45.757 error by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at module.js:652:30
              ! Caught 2018-05-11 04:54:45.757 error by controller[0]: In the future, you will have to enable it yourself.
              ! Caught 2018-05-11 04:54:45.756 error by controller[0]: Thu, 10 May 2018 18:54:28 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
              • goofyk
                как будто кто-то сертификат подменяет… уж не провайдер ли...
                даже не знаю почему так.
                • aurodionov
                  aurodionov last edited by
                  у меня драйвер даже через впн не пошел, горит жёлтый и нихрена не работает
                  • goofyk
                    видать провайдер-провайдеру рознь.
                    у меня на Мегафоне и РТ через прокси нормально работают боты
                    • aurodionov
                      у меня один из пров РТ. не работает и всё
                      • ViR
                        ViR last edited by
                        Так и не появилось решение, пробовал через Tor тоже не получилось?
                          andrey1509 last edited by
                          Здравствуйте все.
                          Пытаюсь подключить Telegram.
                          Что сделал. Установил драйвер. Зашел в https://web.telegram.org получил API ключ , дальше
                          попытался получить пароль , не пойму как.
                          На системе ( У меня Кубик) установил SOCKS5 (dante-server). Запустился вроде работает.
                          Выхожу в мир через Keenetic ADSL, порт TCP пробросил
                          Как это все увязать до кучи мозгов не хватает. Помогите пожалуйста.
                          При запуске telegram.0 в логе получаю ошибки:
                          ! Caught by controller[0]: Sat, 01 Sep 2018 13:14:39 GMT node-telegram-bot-api deprecated Automatic enabling of cancellation of promises is deprecated.
                          ! 2018-09-01 16:14:41.959 - [31merror[39m: Caught by controller[0]: In the future, you will have to enable it yourself.
                          ! 2018-09-01 16:14:41.959 - [31merror[39m: Caught by controller[0]: See https://github.com/yagop/node-telegram- … issues/319. at internal/modules/cjs/loader.js:689:30
                          ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: { Error: connection not allowed by ruleset
                          ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                          ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                          ! 2018-09-01 16:14:41.960 - [31merror[39m: Caught by controller[1]: at Socket.emit (events.js:182:13)
                          ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at addChunk (_stream_readable.js:283:12)
                          ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at readableAddChunk (_stream_readable.js:264:11)
                          ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at Socket.Readable.push (_stream_readable.js:219:10)
                          ! 2018-09-01 16:14:41.961 - [31merror[39m: Caught by controller[1]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                          ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: { Error: connection not allowed by ruleset
                          ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                          ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                          ! 2018-09-01 16:14:41.962 - [31merror[39m: Caught by controller[2]: at Socket.emit (events.js:182:13)
                          ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at addChunk (_stream_readable.js:283:12)
                          ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at readableAddChunk (_stream_readable.js:264:11)
                          ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at Socket.Readable.push (_stream_readable.js:219:10)
                          ! 2018-09-01 16:14:41.963 - [31merror[39m: Caught by controller[2]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                          ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: { Error: connection not allowed by ruleset
                          ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                          ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                          ! 2018-09-01 16:14:41.964 - [31merror[39m: Caught by controller[3]: at Socket.emit (events.js:182:13)
                          ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at addChunk (_stream_readable.js:283:12)
                          ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at readableAddChunk (_stream_readable.js:264:11)
                          ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at Socket.Readable.push (_stream_readable.js:219:10)
                          ! 2018-09-01 16:14:41.965 - [31merror[39m: Caught by controller[3]: at TCP.onread (net.js:639:20) code: 'EACCES' }
                          ! 2018-09-01 16:14:41.966 - [31merror[39m: host.cubie instance system.adapter.telegram.0 terminated with code 0 (OK)
                          ! 2018-09-01 16:14:41.966 - [32minfo[39m: host.cubie Restart adapter system.adapter.telegram.0 because enabled
                          ! 2018-09-01 16:14:43.011 - [32minfo[39m: host.cubie instance system.adapter.telegram.0 started with pid 14390
                          ! 2018-09-01 16:14:49.076 - [32minfo[39m: telegram.0 starting. Version 1.2.7 in /opt/iobroker/node_modules/iobroker.telegram, node: v10.9.0
                          ! 2018-09-01 16:14:50.097 - [31merror[39m: telegram.0 uncaught exception: connection not allowed by ruleset
                          ! 2018-09-01 16:14:50.103 - [31merror[39m: telegram.0 Error: connection not allowed by ruleset
                          ! at Parser._onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:122:21)
                          ! at Socket.Parser.__onData (/opt/iobroker/node_modules/socksv5/lib/client.parser.js:33:10)
                          ! at Socket.emit (events.js:182:13)
                          ! at addChunk (_stream_readable.js:283:12)
                          ! at readableAddChunk (_stream_readable.js:264:11)
                          ! at Socket.Readable.push (_stream_readable.js:219:10)
                          ! at TCP.onread (net.js:639:20)
                          Ходил по адресу https://github.com/yagop/node-telegram- … issues/319 , но ни чего так и не понял.
                          • aurodionov
                            @andrey1509:
                            дальше
                            Ходил по адресу https://github.com/yagop/node-telegram- … issues/319 , но ни чего так и не понял. `
                            пароль задаешь свой, при конекте бот его спросит
                              @aurodionov:
                              @andrey1509:
                              дальше
                              пароль задаешь свой, при конекте бот его спросит `
                              Бот ни чего не просит.
                              В proxy пароль даю свой который в danted прописал.
                              • aurodionov
                                все настройки
                                  Эти настройки я делаю , но значок горит желтым.
                                  В логе " telegram.0 polling_error:EFATAL, EFATAL: Error: connect ETIMEDOUT 149.154.167.220:443"
                                  • aurodionov
                                    @andrey1509:
                                    В логе " telegram.0 polling_error:EFATAL, EFATAL: Error: connect ETIMEDOUT 149.154.167.220:443" `
                                    провайдер блокирует, в России у многих так
                                    приходится телеграмм трафик заворачивать в впн канал, еще есть место с подменой днс
                                      @aurodionov:
                                      @andrey1509:
                                      приходится телеграмм трафик заворачивать в впн канал, еще есть место с подменой днс `
                                      Я это из лога понял.
                                      Как это обойти?
                                      Пробую danted не получается, в логе отправляют https://github.com/yagop/node-telegram- … issues/319.
                                      А там чего делать не понятно (англицкий на уровне - ниже плинтуса 😄 )
                                      • aurodionov
                                        @andrey1509:
                                        @aurodionov:
                                        @andrey1509:
                                        Как это обойти?
                                        А там чего делать не понятно (англицкий на уровне - ниже плинтуса 😄 ) `
                                        я же написал, завернуть трафик до серверов телеги в впн и проверить что пров не подменяет днс
                                        как завернуть ….каждому свое, у меня микрот и выделенный сервер на арубе
                                          Bosya last edited by
                                          Писал ранее. Ответ не получил. Через клиент отправляю команду боту и тут он попадает в цикл.
                                          В драйвере это видно как одинаковые комманды одна за другой. Если послать другую комманду - может остановится, а может снова уйти в цикл...
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:24.526	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:24.512	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:17.123	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:17.109	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:09.541	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:09.531	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:12:01.159	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:12:01.148	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:53.498	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:53.487	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:45.920	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:45.900	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:38.172	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:38.143	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:30.547	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:30.529	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:23.653	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:23.649	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:16.572	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:16.549	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:09.178	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:09.165	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:11:01.639	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:11:01.630	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:54.357	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:54.351	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:45.658	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:45.646	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:38.446	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:38.437	2019-05-16 09:43:37.614
                                          stateChange	telegram.0.communicate.request	"[Sergii]/ip"	false	telegram.0	2019-05-16 16:10:31.055	2019-05-16 09:54:33.176
                                          stateChange	telegram.0.communicate.requestMessageId	110915	false	telegram.0	2019-05-16 16:10:31.036	2019-05-16 09:43:37.614
                                          Не совсем понятно что с этим делать и как остановить...
                                          55
                                          17685
