    4. SMA Wechselrichter
    SMA Wechselrichter
    • Röstkartoffel
      Röstkartoffel last edited by
      @wendy2702:
      Hier für meine Leistung. Kann natürlich sein das es auch einfacher/anders geht aber so funktioniert es für mich.
      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="controls_if" id="pEdg8L|_2wfYKM;Rj1F[" x="13" y="-138"><value name="IF0"><block type="logic_compare" id="ve_IO@?a.NH#!K6lN})H"><field name="OP">LT</field>
      <value name="A"><block type="get_value" id="TT2|XzE?cX=Yjx3I~Ow0"><field name="ATTR">val</field>
      <field name="OID">modbus.0.inputRegisters.30775_PVLeistung</field></block></value>
      <value name="B"><block type="math_number" id="t^z^92g=Pn8B[=x,VmPb"><field name="NUM">0</field></block></value></block></value>
      <statement name="DO0"><block type="update" id="Wq4l-jClESAENIfLeu0A"><mutation delay_input="false"></mutation>
      <field name="OID">javascript.0.PV_Anlage.PVLeistung</field>
      <value name="VALUE"><block type="math_number" id="Qn]36t+jv%=@C]y|^Qvu"><field name="NUM">0</field></block></value></block></statement>
      <next><block type="on_ext" id="T;-)_93^_CNk]zc+*i?l"><mutation items="1"></mutation>
          <value name="OID0"><shadow type="field_oid" id="*!^cdo:#]/##i8spF)b="><field name="oid">modbus.0.inputRegisters.30775_PVLeistung</field></shadow></value>
          <statement name="STATEMENT"><block type="controls_if" id=".}+H/b5qr#e}V#j_X=}4"><mutation elseif="1"></mutation>
              <value name="IF0"><block type="logic_compare" id="6:l9GI-Hw9;yihdsPUyC"><field name="OP">GTE</field>
                  <value name="A"><block type="get_value" id="M)@JQTnKz8Ho%dEp,7Q~"><field name="ATTR">val</field>
                  <value name="B"><block type="math_number" id="wcpgAmpQ5uZ_l5(?mNOq"><field name="NUM">0</field></block></value></block></value>
              <statement name="DO0"><block type="update" id="?.Ww%r(xZs+o%/T3ycEZ"><mutation delay_input="false"></mutation>
                  <value name="VALUE"><block type="get_value" id="pgY3;iduTqZgSldqSi]|"><field name="ATTR">val</field>
                      <field name="OID">modbus.0.inputRegisters.30775_PVLeistung</field></block></value></block></statement>
              <value name="IF1"><block type="logic_compare" id="6/fvm-#3-/,r/~Lmdu)-"><field name="OP">LT</field>
                  <value name="A"><block type="get_value" id="FFgd*E==nz0L{D~::s:k"><field name="ATTR">val</field>
                  <value name="B"><block type="math_number" id="78_UF%EsZ.YM6c5HP9%v"><field name="NUM">0</field></block></value></block></value>
              <statement name="DO1"><block type="update" id="gFDt@;i.`fV[r+v/Cei6"><mutation delay_input="false"></mutation>
                  <value name="VALUE"><block type="math_number" id="W@dellLrOQAqxuiM}Ple"><field name="NUM">0</field></block></value></block></statement></block></statement></block></next></block></xml>
      Ich benutze dieses Script, welches auch sehr gut funktioniert:
      on({id: "modbus.0.inputRegisters.30777_Power_L1", change: "ne"}, function (obj) {
        var value = obj.state.val;
        setState("javascript.0.PV_Anlage.Werte.PVLeistung", (getState("modbus.0.inputRegisters.30777_Power_L1").val), true);
      Damit greife ich natürlich in VIS oder Flot nicht mehr auf das Modbusregister zu, sondern auf die Javascript Variable.
      Volker
        martin last edited by
        Ich habe 2 Wechselrichter die mit dem Sunny-Beam (nicht die Bluetooth, sondern die alte Funkversion) verbunden sind.
        Könnte man den Sunny-Beam auslesen und die Daten im ioBroker verwenden? Evtl. auch über USB?
        • wendy2702
          wendy2702 last edited by
          kannst du mal sagen welche WR genau das sind?
          Dann kann man mal schauen was die für ein Protokoll sprechen.
          Aber verstehe ich das richtig das die per Funk mit dem Sunny Beam kommunizieren? Sorry das ich nachfrage aber ich kenne das Teil nicht.
          EDIT: gerade mal die Anleitung Sunny Beam Funk überflogen. Etwas fertiges um den Sunny Beam auszulesen habe ich hier noch nicht gesehen.
          EDIT1: hat der WR einen Seriellen Anschluß? dann vielleicht so –> viewtopic.php?f=20&t=5911&hilit=sunny&start=20
          Kannst auch mal fragen ob er weitergekommen ist: viewtopic.php?f=8&t=11033&hilit=sunny
          • O
            Orbitson last edited by
            Echt super eure Erläuterungen. Bin absoluter neuling in Sachen Raspberry, JavaScript und iobroker und habe dank eurer vielen Posts schnell zurecht gefunden.
            Habe fast alles eingebunden STP9000 / SB1.5 / SI6.0 / SHM2.0
            Aber zu meinen vielen Edimax SP-2101w funksteckdosen habe ich nicht wirklich etwas gefunden wie ich sie visualisiert bekomme.
            Hat da jemand Erfahrung oder vielleicht schon eine Lösung mit passendem Skript?
            @Marcolotti echt super Visualisierung würdest du sie mir eventuell bereit stellen, lerne an Beispielen schneller
            Mit freundlichen Grüßen
              kevinaus last edited by
              ersteinmal vorweg eine tolle Arbeit, die ihr hier geleistet habt. Sehr schönes Projekt.
              Bin derzeit noch in er Einarbeitsungsphase des ioBrokers. Es macht sher viel spaß, ist aber alles auch nicht Out of the Box 🙂
              EInen Anfang habe ich schonmal gemacht, aber ein paar Werte bekomme ich noch nicht so wirklich raus. Vielleicht könnt ihr mit dabei helfen.
              vorhandenes Equipment:
              Sunny Home Manager 2.0
              zwangsläufig Sunny Portal
              SMA SunnyBoy 3.0
              SMA SunnyBoy 5.0
              Ich möchte im ersten Schritt in meinem ioBroker eigentlich nur dieselben Werte haben wie im Sunny Portal:
              Mein aktueller Stand:
              ioBroker samt Adapter Läuft. Durch die Bezeichnungen bin ich noch nicht wirklich durchgestiegen, aber zwei habe ich schonmal gefunden:
              Netzeinspeisung
              Netzbezug
              Nun fehlt mir noch als Livewert die PV Erzeugung (von meinen zwei Wechselrichter zusammen) und der aktuelle Gesamtverbrauch.
              Diesen finde ich in meiner Übersicht leider nicht:
              Könnt ihr mir helfen wie ich an diese Werte komme?
              Besten Dank und schöne Grüße
              Kevin
              • wendy2702
                also die PV Erzeugung erhalten die meisten per Modbus aus den WRs und der Gesamtverbrauch wird errechnet.
                Ob der Homemanager 2.0 die Daten liefert kann ich nicht sagen da ich das Teil nicht habe.
                  Sneak-L8 last edited by
                  Ja, PV-Erzeugung kommt aus dem/den WR, Einspeisung Überschuss bzw. Netzbezug vom SHM. Die Differenz ist Dein Verbrauch.
                  Musst also rechnen: Verbrauch = Netzbezug - Einspeisung + Erzeugung WR1 + Erzeugung WR2
                    Vielen Dank für die schnellen Antworten.
                    Also der Reihe nach muss ich demnach jetzt folgendes machen?
                    1. ModBus Adapter im ioBroker installieren und mit meinem Wechselrichter verbinden? Mein Wechselrichter hat Netzwerk und demnach brauche ich dort nur die IP Adresse eintragen um die zu Verbinden?
                    2. Wenn ich die Werte dann über den ModBus von den Wechselrichter habe, muss ich mir mittels Blocky eine Rechnung schreiben, der die Werte errechnet?
                    Danke Euch und Grüße
                    Kevin
                      Hallo Kevin,
                      fast. Modbus ja, aber dann musst Du noch die notwendigen Register hinterlegen, aus denen die Daten entnommen und als States im ioBroker abgelegt werden. Die Werte findest Du hier im Forum.
                      Die Berechnung kannst Du mit Blockly oder einem Skript machen (gute Einführung auf der ioBroker-Seite verlinkt), das den Wert in einem neuen State ablegt.
                      • wendy2702
                        @kevinaus:
                        1. ModBus Adapter im ioBroker installieren und mit meinem Wechselrichter verbinden? Mein Wechselrichter hat Netzwerk und demnach brauche ich dort nur die IP Adresse eintragen um die zu Verbinden? `
                        Modbus am WR aktivieren wenn er es denn Unterstützt. Adapter und Instanz installieren und Konfigurieren mit Registern die gelesen werden sollen.
                        Einige Beispiele stehen in diesem Thread auf den ersten Seiten.
                        @kevinaus:
                        2. Wenn ich die Werte dann über den ModBus von den Wechselrichter habe, muss ich mir mittels Blocky eine Rechnung schreiben, der die Werte errechnet? `
                        Yep. Oder im Forum suchen, gibt hier schon "fertige" Lösungen.
                          Dank Euren Tipps bin ich nun auch schon einen Schritt weiter.
                          Ich habe einen modbus.0 Adapter installiert und die erste passende Adresse im Eingangsregister hinterlegt.
                          Jetzte habe ich gerade noch ein kleines andere Problem, wo ich im Forum nichts zu gefunden habe.
                          Wenn ich einen weitere modbus.1 Adapter anlege und diesem mit meinem ZWEITEN Wechselrichter verbinde klappt das auch.
                          Wenn ich aber dann dieselbe Adresse in das Eingangsregister eintrage wie für den ersten Wechselrichter erscheint folgende Meldung und die Instanz startet gar nicht mehr:
                          modbus.1 warn	Poll error count: 1 code: {"errorCode":132,"exceptionCode":2,"message":"ILLEGAL DATA ADDRESS"}
                          Es scheint als wenn ich die Adresse für den PV Ertrag 30775 nur einem Modbus Adapter hinterlegen kann.
                          Habt ihr da eine Idee?
                          Danke unn Grüße
                          Kevin
                            Hmm, da fällt mir auch nicht viel ein. Nur zur Sicherheit: Du hast im zweiten Adapter auch die IP-Adresse des 2. WR angegeben und nicht versehentlich nochmal die des ersten?
                            Da wäre für mich die einzige Erklärung.
                            • wendy2702
                              Du hast aber in beiden Instanzen unterschiedliche IP's für die einzelnen WRs eingetragen?
                              Desweiteren ist es auch möglich das dieser WR entweder kein Modbus kann, die Register anders sind, Modbus noch nicht aktiv ist, etc.
                              Was passiert wenn du Modbus.0 stoppst und nur 1 startest? Geht es dann?
                              Was passiert wenn du in Instanz 0 mal die IP von dem WR einträgst der nicht funktioniert?
                                ihr seit ja fix…
                                während ich Eure Sachen testen wollte habe ich den Fehler gefunden.
                                Es war nicht die doppelte Adresse, die das Problem war, sondern der Name.
                                so ging es nicht
                                modbus.0 30775 Name: PV Erzeugung
                                modbus.1 30775 Name: PV Erzeugung
                                so geht es
                                modbus.1 30775 Name: PV Erzeugung 1
                                Jetzt geht es weiter, daraus einen neuen State zu machen der beides Addiert...
                                Danke Euch für die Mühe .....
                                  Surfer2010 last edited by
                                  @Solear:
                                  Gibt es eine Empfehlung für einen Wechselrichter mit der Möglichkeit, die Daten auszulesen?
                                  Ich will 2-3 Solarplatten aufs Dach hinten packen um meine Grundlast tagsüber etwas zu senken. Mehr als aus "weil es geht" als aus Geldspargründen.
                                  Interessant sind die Letrika SMI260 Wechselrichter, da kann man mittels SunGate Gateway oder einen SunStickSMI die Daten auslesen, aber die sind propritär und offenbar ohne Datenausgang. Und der SunStick wäre preislich OK (unter 100 €), aber läuft offenbar nur an Windows. Und das geht gar nicht. `
                                  Hi
                                  ich hab jetzt so ein SMI260 Wechselrichter von Letrika und wüsste gern wie ich die Daten daraus in meinen ioBroker bekomme. Wer kann mir da helfen? Welche Optionen habe ich da?
                                  VIELEN DANK schon mal
                                    Solear last edited by
                                    @Surfer2010:
                                    @Solear:
                                    Hi
                                    VIELEN DANK schon mal `
                                    Ich habe das Problem jetzt lösen können und kann die Werte vom SMI260 über CuxD in Homematic anzeigen lassen und hole sie von da in iobroker ab um die Daten zu verarbeiten.
                                    Mit dem Carpediem Sunstick oder einen anderen iM871A Stick (zB von Piotek) als Hardware. Den habe ich in meinen Raspberry 3 gesteckt, worauf RaspberryMatic mit CuxD läuft.
                                    Von piotek gibt es eine Lizenz für M-Bus zu kaufen, auch ein Bundle mit dem Stick zusammen:
                                    https://www.piotek.de/CUxD-Wireless-M-B … -USB-Stick
                                    Wenn man den Carpediem Sunstick schon hat, benötigt man nur die M-Bus Lizenz:
                                    https://www.piotek.de/CUxD-Wireless-M-B … 1-und-CCU2
                                    Nun den Lizenzschlüssel in CuxD unterm Reiter "Setup" als neue Zeile einfügen ("KEY=xxxxxxxxxxxxxx").
                                    Jetzt unterm Reiter Geräte ein oder mehrere neue Geräte anlegen (für jeden SMI260 eins: wM-Bus-Sensor auswählen, SMI260 und ein Icon aussuchen und auf Gerät erzeugen klicken).
                                    Jetzt ist in Homematic ein neues Gerät im Posteingang zu finden. Dieses dann entsprechend konfigurieren, bei CODE kommen die letzten 5 Ziffern der Seriennummer des SMI260 rein.
                                    Jetzt hat man den oder die SMI260 als Geräte in Homematic 🙂
                                    Dieses homematic / CuxD Gerät kann man dann wie üblich in iobroker über den rpc-Adapter/cuxd einbinden.
                                    Das war es.
                                    • Stabilostick
                                      Stabilostick last edited by
                                      @Solear Tolle Kurzanleitung! Super! [emoji1303]
                                      Nur es ist kein SMA-Wechselrichter. Fast was für einen eigenen Thread….
                                        Gibt es denn noch eine "einfachere" Möglichkeit weil ich hab nur den ioBroker laufen und würde das gerne auch simpel halten … also dafür extra nich nen Pi usw. aufsetzen?
                                        Wäre klasse wenn es auch direkter ginge?
                                        P.S. neuer Thread wegen mir gerne ... hier oder im Hardware Forum oder bei Adaptern?
                                        • Stabilostick
                                          Siehe z.B. https://www.photovoltaikforum.com/letri … l#p1541373
                                            klausiy123 last edited by
                                            ich komm schon mit dem Modbus nicht weiter. Der Reihe nach:
                                            im SMA Explorer mit Installateur den TCP und UDP aktiviert (ja)
                                            Die IP Adresse aus der Fritzbox ausgelesen, ist einen andere als die im SMA Explorer angezeigte.
                                            die IP Adresse aus der Fritzbox im MODBUS adapter eingetragen, aliase ausgehakt
                                            Nun zeigt mir der Modbus aber immer noch "verbunden mit Modbus: falsch" an
                                            Irgendwo hab ich wohl nachenen Fehler drin. Hat jemand einen Tip für mich. Danke
                                            586
                                            162199
