    4. [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testen
      apollon77 last edited by
      @sigi234:
      Ja, habe ich nachgemacht, der Adapter bleibt ROT.
      Caught	2018-06-18 09:54:06.849	error	by controller[0]: { Error: Cannot find module 'debug'
      Bitte Update Adapter vom Github 0.2.4. Sollte das fixen
      • Alex1808
        Alex1808 last edited by
        @apollon77:
        Bitte Update Adapter vom Github 0.2.4. Sollte das fixen `
        Habe auch ausprobiert ein par Beispiele aus diesem Forum, bekomme aber gleiche Fehler zusehen
        ! host.buanet 2018-06-18 11:44:00.332 error instance system.adapter.ham.0 terminated with code 0 (OK)
        ! Caught 2018-06-18 11:44:00.331 error by controller[2]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:241:12)
        ! Caught 2018-06-18 11:44:00.331 error by controller[2]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:316:9)
        ! Caught 2018-06-18 11:44:00.331 error by controller[2]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
        ! Caught 2018-06-18 11:44:00.331 error by controller[2]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:23)
        ! Caught 2018-06-18 11:44:00.331 error by controller[2]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:211:57)
        ! Caught 2018-06-18 11:44:00.331 error by controller[2]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:90:23)
        ! Caught 2018-06-18 11:44:00.331 error by controller[2]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:176:17)
        ! Caught 2018-06-18 11:44:00.331 error by controller[2]: at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:87:8)
        ! Caught 2018-06-18 11:44:00.330 error by controller[2]: at Server._loadDynamicPlatforms (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:345:30)
        ! Caught 2018-06-18 11:44:00.330 error by controller[2]: at new iobroker (/opt/iobroker/node_modules/homebridge-iobroker/index.js:29:21)
        ! Caught 2018-06-18 11:44:00.330 error by controller[2]: TypeError: Cannot read property 'host' of null
        ! Caught 2018-06-18 11:44:00.330 error by controller[1]: [2018-6-18 09:43:59] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
        ! Caught 2018-06-18 11:44:00.330 error by controller[0]: [2018-6-18 09:43:58] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
        ! ham.0 2018-06-18 11:44:00.306 info terminating
        ! ham.0 2018-06-18 11:44:00.298 warn Exception: TypeError: Cannot read property 'host' of null
        ! ham.0 2018-06-18 11:44:00.292 info cleaned everything up…
        ! ham.0 2018-06-18 11:44:00.290 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:241:12)
        ! ham.0 2018-06-18 11:44:00.290 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:316:9)
        ! ham.0 2018-06-18 11:44:00.290 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
        ! ham.0 2018-06-18 11:44:00.290 error at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:23)
        ! ham.0 2018-06-18 11:44:00.290 error at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:211:57)
        ! ham.0 2018-06-18 11:44:00.290 error at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:90:23)
        ! ham.0 2018-06-18 11:44:00.290 error at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:176:17)
        ! ham.0 2018-06-18 11:44:00.290 error at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:87:8)
        ! ham.0 2018-06-18 11:44:00.290 error at Server._loadDynamicPlatforms (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:345:30)
        ! ham.0 2018-06-18 11:44:00.290 error at new iobroker (/opt/iobroker/node_modules/homebridge-iobroker/index.js:29:21)
        ! ham.0 2018-06-18 11:44:00.290 error TypeError: Cannot read property 'host' of null
        ! ham.0 2018-06-18 11:44:00.289 error uncaught exception: Cannot read property 'host' of null
        ! ham.0 2018-06-18 11:43:57.584 info starting. Version 0.2.4 in /opt/iobroker/node_modules/iobroker.ham, node: v6.14.1
        ! ham.0 2018-06-18 11:43:57.422 info States connected to redis: 127.0.0.1:6379
        ! host.buanet 2018-06-18 11:43:56.486 info instance system.adapter.ham.0 started with pid 4978
        ! host.buanet 2018-06-18 11:43:26.476 info Restart adapter system.adapter.ham.0 because enabled
        ! host.buanet 2018-06-18 11:43:26.476 error instance system.adapter.ham.0 terminated with code 0 (OK)
        ! Caught 2018-06-18 11:43:26.476 error by controller[2]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:241:12)
        ! Caught 2018-06-18 11:43:26.475 error by controller[2]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:316:9)
        ! Caught 2018-06-18 11:43:26.475 error by controller[2]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
        ! Caught 2018-06-18 11:43:26.475 error by controller[2]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:23)
        ! Caught 2018-06-18 11:43:26.475 error by controller[2]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:211:57)
        ! Caught 2018-06-18 11:43:26.475 error by controller[2]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:90:23)
        ! Caught 2018-06-18 11:43:26.475 error by controller[2]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:176:17)
        ! Caught 2018-06-18 11:43:26.475 error by controller[2]: at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:87:8)
        ! Caught 2018-06-18 11:43:26.475 error by controller[2]: at Server._loadDynamicPlatforms (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:345:30)
        ! Caught 2018-06-18 11:43:26.474 error by controller[2]: at new iobroker (/opt/iobroker/node_modules/homebridge-iobroker/index.js:29:21)
        ! Caught 2018-06-18 11:43:26.474 error by controller[2]: TypeError: Cannot read property 'host' of null
        ! Caught 2018-06-18 11:43:26.474 error by controller[1]: [2018-6-18 09:43:25] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
        ! Caught 2018-06-18 11:43:26.473 error by controller[0]: [2018-6-18 09:43:25] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
        ! ham.0 2018-06-18 11:43:26.452 info terminating
        ! ham.0 2018-06-18 11:43:26.445 warn Exception: TypeError: Cannot read property 'host' of null
        ! ham.0 2018-06-18 11:43:26.439 info cleaned everything up…
        ! ham.0 2018-06-18 11:43:26.438 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:241:12)
        ! ham.0 2018-06-18 11:43:26.438 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:316:9)
        ! ham.0 2018-06-18 11:43:26.438 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
        ! ham.0 2018-06-18 11:43:26.438 error at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:23)
        ! ham.0 2018-06-18 11:43:26.438 error at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:211:57)
        ! ham.0 2018-06-18 11:43:26.438 error at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:90:23)
        ! ham.0 2018-06-18 11:43:26.438 error at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:176:17)
        ! ham.0 2018-06-18 11:43:26.438 error at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:87:8)
        ! ham.0 2018-06-18 11:43:26.438 error at Server._loadDynamicPlatforms (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:345:30)
        ! ham.0 2018-06-18 11:43:26.438 error at new iobroker (/opt/iobroker/node_modules/homebridge-iobroker/index.js:29:21)
        ! ham.0 2018-06-18 11:43:26.438 error TypeError: Cannot read property 'host' of null
        ! ham.0 2018-06-18 11:43:26.437 error uncaught exception: Cannot read property 'host' of null</anonymous></anonymous></anonymous></anonymous>
        Version ist 0.2.4
          Der Fehler kommt aus "homebridge-iobroker" Ist das das Modul was Du installieren willst?
          Was ist denn das?
          Wie siehst sonst die Konfig von deinem iobroker.ham aus? Welche Module werden installiert? Wie ist die Konfig?
          • Alex1808
            @apollon77:
            Was ist denn das?
            Wie siehst sonst die Konfig von deinem iobroker.ham aus? Welche Module werden installiert? Wie ist die Konfig? `
            Nein, habe ausprobiert homebridge-camera-ffmpeg und homebridge-airrohr (aber nicht gleichzeitig, zuerst eins, dan komplett gelöscht und dan erst die zweite).
            Konfig-1
            "platform": "Camera-ffmpeg",
            "cameras": [
            "name": "Camera Name",
            "videoConfig": {
            "source": "-re -i rtsp://myfancy_rtsp_stream",
            "stillImageSource": "-i http://faster_still_image_grab_url/this_is_optional.jpg",
            "maxStreams": 2,
            "maxWidth": 1280,
            "maxHeight": 720,
            "maxFPS": 30,
            "maxBitrate": 200,
            "vcodec": "h264_omx",
            "audio": true,
            "packetSize": 188,
            "debug": true
            Konfig-2
              "description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
              "accessories": [
                  "name": "AirRohr",
                  "accessory": "airrohr",
                  "public_temperature_json_data": "http://api.luftdaten.info/v1/sensor/5032/",
                  "public_airquality_json_data": "http://api.luftdaten.info/v1/sensor/5032/",
                  "sensor_id": "2342523",
                  "update_interval_seconds": 60
              "platforms": []
            Module eingetragen und die wurden auch installiert
            Komplette log Datei
            513_iobroker.2018-06-18.log
              Also erst einmal ist irgendwas an deinem NPM oder NPM cache kaputt.
              Du hast bei allen installationsversuchen den Fehler
              2018-06-18 10:59:08.633 - error: ham.0 npm ERR! Object.entries is not a function
              drin. Ist ein anderes Thema, aber das solltest du beheben. Bitte aber falls Du support brauchst eigener Thread!
              Und am Ende hat Airrohr auch gut geklappt und dann kommt:
              2018-06-18 10:59:09.237 - error: ham.0 uncaught exception: Cannot read property 'host' of null
              2018-06-18 10:59:09.237 - error: ham.0 TypeError: Cannot read property 'host' of null
              Das bedeutet: Homebridge findet dieses "homebridge-iobrker" paket in deinen node_modules und versuch es zu initialisieren und das fliegt auf die nase.
              Finde raus was das ist und ggf lösche es. Ich finde auf NPM keinerlei "homebridge-iobroker" … also wenn kann es nur was inoffizielles sein.
              Wenn das weg ist sollte alles tun.
              EDIT:
              Kannes sein das du mal das hier installiert hast: https://github.com/Haba1234/homebridge-iobroker ?!
              Dann bitte da ein Bug auf machen oder wie gesagt (wenn du es nicht verwendest) deinstallieren ... Oder eine Konfiguration mit hinterlegen das er ein "host" property findet ... auch wenn es ne falsche URL sein sollte denke ich
                @All: Version 0.2.5 ist auf Github verfügbar. Hier wird jetzt alles was Homebridge im Standard an die Konsole loggt als iobroker log durchgeschleift wenn Loglevel auf Debug steht für den Adapter.
                Damit sollte man im Debug fall mehr sehen können!
                  JackWolfskind last edited by
                  Bin schon mal nen Schritt weiter und der HAM Adapter läuft. Jetzt versuche ich eines der 2 verfügbaren Homebridge Plugins für Wemo zum laufen zu bringen.
                  Anscheinend muss man da erst irgendwelche obskuren JSON COnfig Files anlegen damit das funktioniert?
                  Leider schmiert mir der Adapter aber gleich ab:
                  ` > host.iobroker 2018-06-18 13:24:24.290 info Restart adapter system.adapter.ham.0 because enabled
                  host.iobroker 2018-06-18 13:24:24.290 error instance system.adapter.ham.0 terminated with code 0 (OK)
                  host.iobroker 2018-06-18 13:24:24.290 error Caught by controller[2]: at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:86:38)
                  host.iobroker 2018-06-18 13:24:24.289 error Caught by controller[2]: at Server._loadAccessories (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:295:29)
                  host.iobroker 2018-06-18 13:24:24.289 error Caught by controller[2]: at new WeMoAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-wemo/index.js:17:8)
                  host.iobroker 2018-06-18 13:24:24.289 error Caught by controller[2]: at WeMoAccessory.search (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-wemo/index.js:21:8)
                  host.iobroker 2018-06-18 13:24:24.289 error Caught by controller[2]: at Function.WeMo.Search (/opt/iobroker/node_modules/iobroker.ham/node_modules/wemo/wemo.js:18:15)
                  host.iobroker 2018-06-18 13:24:24.289 error Caught by controller[2]: at Function.WeMo.SearchByFriendlyName (/opt/iobroker/node_modules/iobroker.ham/node_modules/wemo/wemo.js:41:20)
                  host.iobroker 2018-06-18 13:24:24.288 error Caught by controller[2]: at Function.WeMo.Search (/opt/iobroker/node_modules/iobroker.ham/node_modules/wemo/wemo.js:21:15)
                  host.iobroker 2018-06-18 13:24:24.288 error Caught by controller[2]: at new SsdpClient (/opt/iobroker/node_modules/iobroker.ham/node_modules/node-ssdp/lib/client.js:13:8)
                  host.iobroker 2018-06-18 13:24:24.288 error Caught by controller[2]: at SsdpClient.SSDP (/opt/iobroker/node_modules/iobroker.ham/node_modules/node-ssdp/lib/index.js:62:8)
                  host.iobroker 2018-06-18 13:24:24.288 error Caught by controller[2]: at SsdpClient.SSDP._init (/opt/iobroker/node_modules/iobroker.ham/node_modules/node-ssdp/lib/index.js:95:54)
                  host.iobroker 2018-06-18 13:24:24.288 error Caught by controller[2]: TypeError: ip.address is not a function
                  host.iobroker 2018-06-18 13:24:24.287 error Caught by controller[1]: [2018-6-18 13:24:22] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                  host.iobroker 2018-06-18 13:24:24.286 error Caught by controller[0]: [2018-6-18 13:24:22] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                  host.iobroker 2018-06-18 13:24:18.614 info instance system.adapter.ham.0 started with pid 17535 `
                  Der Versuch ein Homebridge Plugin wieder aus dem Adapter zu entfernen führt leider dazu das der Adapter weiter darüber meckert, obwohl es in den Adaptereinstellungen verschwunden ist 😞
                  • Alex1808
                    @apollon77:
                    Dann bitte da ein Bug auf machen oder wie gesagt (wenn du es nicht verwendest) deinstallieren … Oder eine Konfiguration mit hinterlegen das er ein "host" property findet ... auch wenn es ne falsche URL sein sollte denke ich `
                    Das konnte sein, ist eine für tests vorgesehene Maschine und hat schon einiges erlebt.. 🙂 Ich glaube erste version Homeridge vom Ilya war auch schon mahl darauf))
                    Habe jetzt ein neue Container erstellt und da hat sofort funktioniert.
                    Danke! Werde weiter test.
                    • Dutchman
                      So dan ich auch mal 🙂
                      System : Docker image von Burnet
                      Installation = OK, version 0.2.5 per github installer
                      Nach einigen rumspielen habe ich dan auch endlich die JSON kapiert, der erste adapter start schlug fehl da ich die module hue usw nicht installiert habe.
                      Habe jetzt 2 plugins im einsatz, synology und domoticz.
                      Sinology klappt nicht, hat aber mit dem plugin zu tun holt sich irgendwie keine Daten 😕
                      Domoticz = Klappt sowohl das empfangen als schalten 🙂
                      Werde mal schauen ob es noch andere interessante plugins gibt, zum beispiel für andere mal meine konfigurationsdatei:
                        "accessories": [
                            "accessory": "SynologyDiskstation",
                            "name": "Home_Master",
                            "host": "xxx",
                            "mac": "xxx",
                            "port": "5001",
                            "secure": true,
                            "account": "xxx",
                            "password": "xxx",
                            "version": 6.1
                        "platforms": [
                            "platform": "eDomoticz",
                            "name": "eDomoticz",
                            "server": "xxx",
                            "port": "8080",
                            "ssl": 0,
                            "roomid": 0,
                            "mqtt": 1,
                            "excludedDevices": []
                        Ok, die Wemo Plugins bekomme ich leider gar nicht zum laufen aber 2 Plugins für domoticz und Jahreszeit scheinen zu gehen 🙂
                        Allerdings sind die auch arg geschwätzig, d.h. sie legen für alles wie wild Objekte an. Das wird selbst bei meiner mittelgroßen IOBroker Instanz langsam zu seinem Problem für die Oberfläche. Da bräuchte ich langsam einen ausgewachsenen PC und ein GUI was diese Tausende Objekte komfortabler verwaltbar macht :shock:
                          pix last edited by
                          Hallo JackWolfskind,@JackWolfskind:
                          @pix:
                          ist die Rademacher Anbindung über den Homebridge Adapter jetzt irgendwie besser als direkt über den Homepilot Adapter ? `
                          du musst "irgendwie" genauer definieren. Es ist anders. Ich kann nur über die Einbindung der Gutwickleraktoren sprechen, denn andere Geräte habe ich nicht. Meiner Meinung nach werden die mit homebridge nicht so gut eingebunden.
                          Die Struktur ist unübersichtlicher (siehe hier: viewtopic.php?f=36&t=14972&p=156440#p156472) und es gibt zwei verschiedene Datenpunkte für Soll und Ist Zustand. Da weiß ich nicht, wie man das zB einem Metro-Bar-Widget o.ä. beibringen will. Für die Ansteuerung und Beobachtung aus einem Skript heraus ist dieses Design allerdings gut.
                          Es werden (selbst bei meinen Gurtwickler Aktoren) auch die Winkel der Jalousie-Lamellen angezeigt. Damit ist eine Raffstore Steuerung möglich. Auch hier wieder: getrennte Soll- und Ist-Datenpunkte.
                          Und wie es apollon77 schon sagt, sind keine Rollen/Gewerkezugeteilt. Das mag bei manueller Auswertung der Datenpunkte mit direkter Abfrage der ID ok sein. Aber wenn man dynamisch, zB alle Rollläden abfragen oder steuern will, wird das schwieriger.
                          Der homepilot-Adapter wurde entwickelt, um Gurtwickler Motoren von Rademacher anzubinden. Weitere Duofern Geräte kamen nachträglich dazu. Da ich aber keine weiteren Geräte besitze, kann ich auch nicht testen. Wenn du einen gut ausgebauten Homepilot Kosmos mit Aktoren, Sensoren, vielleicht Kameras anbinden willst, kann der Weg über ham besser sein.
                          Pix
                          • lobomau
                            lobomau last edited by
                            @Dutchman:
                              "accessories": [
                                  "host": "xxx",
                                  "mac": "xxx",
                                  "port": "5001",
                                  "secure": true,
                                  "account": "xxx",
                                  "password": "xxx",
                                  "version": 6.1
                              "platforms": [
                                  "server": "xxx",
                                  "port": "8080",
                                  "ssl": 0,
                                  "roomid": 0,
                                  "mqtt": 1,
                            Die Konfig-Datei scheint das "Geheimnis" hier zu sein. Airrohr plugin ist bei mir gelaufen. Habe dann versucht den camera-ffmeg hinzuzufügen. Da ist aber noch ein Fehler, den ich nicht wegbekomme:
                              @JackWolfskind:
                              Der Versuch ein Homebridge Plugin wieder aus dem Adapter zu entfernen führt leider dazu das der Adapter weiter darüber meckert, obwohl es in den Adaptereinstellungen verschwunden ist 😞 `
                              Was hast Du denn im JSON-Editor für eine Konfiguration hinterlegt? Ich tippe das die falsch ist. Wenn DU das Plugin wieder aus der liste entfernst bleibt es erstmal installiert (wird nur nicht mehr aktuell gehalten). Wenn also die Konfig immer noch falsch ist dann kommt der Fehler. Also bitte auch die Konfig checken ob Sie angegeben ist wie es vom Pluging braucht wird!
                              • Dutchman
                                @imobau
                                Deine konfig ist falsch das erste Platform muss raus.
                                Schade das du einen Screenshot gepostet hast und nicht die Configuration in Code Tags 🙂
                                  @Alex1808:
                                  @apollon77:
                                  Danke! Werde weiter test. `
                                  oder einfach
                                  npm uninstall homebridge-iobroker
                                    pix last edited by
                                    Hallo lobomau,
                                    ich sehe die Ursache für den Fehler im Editor für die fehlende schließende eckige Klammer zu "platforms"
                                    "platforms": [
                                          "cameras": [
                                          ] <---- schließt cameras
                                      ] <---- schließt platforms
                                    eine der beiden ] fehlt bei dir.
                                    Pix
                                    • lobomau
                                      Hab bischen rumprobiert. Fehler in Zeile 26: Expected ',` instead of ']':
                                        "accessories": [
                                            "name": "AirRohr",
                                            "public_temperature_json_data": "http://api.luftdaten.info/v1/sensor/7893/",
                                            "public_airquality_json_data": "http://api.luftdaten.info/v1/sensor/7893/",
                                        "cameras": [
                                            "videoConfig": {
                                            	"maxStreams": 2,
                                            	"maxWidth": 1280,
                                            	"maxHeight": 720,
                                            	"maxFPS": 30
                                        Ersetzte am Ende:
                                        durch
                                          Dieses händische Konfigurieren der JSON Config ist ja mal so 90er , da komm ich mir ja fast wie bei FHEM vor :?
                                          Da muss man mal bissl mehr als bei IObroker nachlesen oder es erbarmt sich jemand und erklärt diese seltsame Config mit accessories und platfforms etc. oder schreibt gleich noch ne Oberfläche wie es für Homebridge ja auch schon gibt 8-)
                                          Bisher sieht es so aus als bekomme ich nur für mich nur völlig sinnfreie Plugins zum laufen aber der Spaß war es bisher trotzdem wert :lol:
                                          Und der Bug mit WeMo wird ja vielleicht irgendwann jemand fixen der mehr Ahnung davon hat als ich 😉
                                          • Dutchman
                                            erstes plugin gefunden was nicht läuft, https://github.com/oznu/homebridge-config-ui-x
                                            (damit hat man ein webinterface für die homebridge selber)
                                            auf einer native installation kommt hat man dan ein webinterface, bei iObroker kommt aber nichts und ich erkenne auch nicht wirklich was im debug log.
                                            JSON file ist richtig konvertiert, habe ich mit der native installation überprüft.
                                            343
                                            85741
