    4. Unwetterwarnung für Österreich bzw. Europa ?
      dwm last edited by Negalein
      Hm …
      Es findet sich leider sehr wenig Information über die API. Trotzdem, so ganz auf die Schnelle mit einer Abwandlung meines DWD Proof of Concepts:
      var AdapterId = "javascript.0";
      var ChannelId = "UWZ";
      var forceInitStates = false;
      var numOfWarnings = 3;
      var warncellid = 'UWZDE92540'; // HIER DIE EIGENE AREA ID eintragen!
      var url='http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=XXXAREAXXX';
      url=url.replace("XXXAREAXXX",warncellid);
      function createStates(n){
          for (var i=0; i<n; i++)/{/createstate(channelid+".warning."+i+".name","",forceinitstates,{type:/'string'});/createstate(channelid+".warning."+i+".text","",forceinitstates,{type:/createstate(channelid+".warning."+i+".shorttext","",forceinitstates,{type:/createstate(channelid+".warning."+i+".longtext","",forceinitstates,{type:/createstate(channelid+".warning."+i+".object","",forceinitstates,{type:/createstate(channelid+".warning."+i+".begin",0,forceinitstates,{type:/'number'});/createstate(channelid+".warning."+i+".end",0,forceinitstates,{type:/createstate(channelid+".warning."+i+".severity",0,forceinitstates,{type:/createstate(channelid+".warning."+i+".type",0,forceinitstates,{type:/}/function/processresultentry(w)/this.object="JSON.stringify(w);" this.begin="new" date(w.dtgstart).gettime();/this.end="new" date(w.dtgend).gettime();/this.longtext="w.payload.translationsLongText.DE;" this.shorttext="w.payload.translationsShortText.DE;" this.severity="w.severity;" this.type="w.type;" processdata(data)/if/(!data)/return;/var/thedata="JSON.parse(data);" warnings="[];" (thedata.results.length="">0) {
              for (i=0; i<thedata.results.length; 3/10/i++)/{/warnings.push(new/processresultentry(thedata.results[i]));/}/*/warnings.sort(function(a,b){/var/asort="a.urgency*1000+a.category*100+a.severity;" bsort="b.urgency*1000+b.category*100+b.severity;" return/bsort-asort;/});/for/(i="0;" i<numofwarnings;/if/(i<warnings.length)/setstate(channelid+".warning."+i+".longtext",warnings[i].longtext);/setstate(channelid+".warning."+i+".shorttext",warnings[i].shorttext);/setstate(channelid+".warning."+i+".object","{}");/setstate(channelid+".warning."+i+".begin",warnings[i].begin);/setstate(channelid+".warning."+i+".end",warnings[i].end);/setstate(channelid+".warning."+i+".severity",warnings[i].severity);/setstate(channelid+".warning."+i+".type",warnings[i].type);/else/setstate(channelid+".warning."+i+".longtext","");/setstate(channelid+".warning."+i+".shorttext","");/setstate(channelid+".warning."+i+".begin",0);/setstate(channelid+".warning."+i+".end",0);/setstate(channelid+".warning."+i+".severity",0);/setstate(channelid+".warning."+i+".type",0);/createstates(numofwarnings);/request="require('request');" schedule/("*/*",/function(){/request({/uri:/url,/method:/"get",/timeout:/10000,/followredirect:/true,/maxredirects:/},/function(error,/response,/body)/(response.statuscode="=" 200)/processdata(body);/<e=""></thedata.results.length;></n;>`
      Im Script die eigene AREA Id eintragen, dann wird alle drei Minuten die UWZ API aufgerufen und in javascript.0.UWZ.warnung.... geschrieben.
      Wie man die Area ID rausfindet, stand irgendwo bei dem FHEM beschrieben.
      Ich konnte auf die Schnelle nicht rausfinden, was severity und type jetzt bedeuten, hab allerdings auch nicht lange danach gesucht.
      Deswegen ist auch eine Sortierung der Warnungen abgeschaltet ... und Farbcode gibts auch keinen.
      Aber schon mal ein Anfang 🙂
      CU
      Werner
        @dwm:
        Ich konnte auf die Schnelle nicht rausfinden, was severity und type jetzt bedeuten `
        Beim DWD ist die severity die Warnstufe 0=keine 1= leicht=gelb 2= rot und 4 = lila, da wären dann auch schon die Farben. Außerdem gibt es noch Hitze und Ozon.
        Type müsste ich auch noch suchen.
        Rainer
        • Q
          Qlink last edited by
          Hi Werner,
          vielen Dank für deine Hilfe.
          Skript läuft soweit:
          Wie kann ich die Zahlen bei begin und end deuten ?
          Der Severity Wert dürfte dann bei UWZ wohl bis 10 gehen oder ?
          so in der art
          1= kein unwetter in sicht
          5= starkes unwetter
          10= weltuntergang
          oder ?
            dwm last edited by
            Die Zahlen bei begin und end sind der Anfangs- und Endzeitpunkt in ms seit dem 1.1.1970.
            Hm, ja. Könnte man noch "human readable" gestalten :D.
            Was severity und type bei der Unwetterzentrale jetzt heissen … keine Ahnung. Wie Hormoran schrieb, beim DWD ist das gut dokumentiert.
            type=7 ist wohl "Gewitter"... aber das ist mit der Stange im Nebel stochern. Mal sehen, ob sich da nicht im Netz eine Doku findet...
            Ein Bug ist auch noch drin ... das "object" sollte eigentlich das JSON der Warnung zeigen.
            var AdapterId = "javascript.0"; var ChannelId = "UWZ"; ! var forceInitStates = true; var numOfWarnings = 3; ! var warncellid = 'UWZDE92540'; // HIER DIE EIGENE AREA ID eintragen! ! //============================================================== var url='http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=XXXAREAXXX'; ! url=url.replace("XXXAREAXXX",warncellid); ! function createStates(n){ for (var i=0; i<n; i++)/{/createstate(channelid+".warning."+i+".name","",forceinitstates,{type:/'string'});/createstate(channelid+".warning."+i+".text","",forceinitstates,{type:/createstate(channelid+".warning."+i+".shorttext","",forceinitstates,{type:/createstate(channelid+".warning."+i+".longtext","",forceinitstates,{type:/createstate(channelid+".warning."+i+".object","",forceinitstates,{type:/createstate(channelid+".warning."+i+".begin",0,forceinitstates,{type:/createstate(channelid+".warning."+i+".end",0,forceinitstates,{type:/createstate(channelid+".warning."+i+".severity",0,forceinitstates,{type:/'number'});/createstate(channelid+".warning."+i+".type",0,forceinitstates,{type:/}/function/processresultentry(w)/this.object="JSON.stringify(w);" this.begin="formatDate(new" date(w.dtgstart),"dd.mm.yyyy/hh:mm");/this.end="formatDate(new" date(w.dtgend),"dd.mm.yyyy/this.longtext="w.payload.translationsLongText.DE;" this.shorttext="w.payload.translationsShortText.DE;" this.severity="w.severity;" this.type="w.type;" processdata(data)/if/(!data)/return;/var/thedata="JSON.parse(data);" warnings="[];" (thedata.results.length="">0) { for (i=0; i<thedata.results.length; 3/10/i++)/{/warnings.push(new/processresultentry(thedata.results[i]));/}/*/warnings.sort(function(a,b){/var/asort="a.urgency*1000+a.category*100+a.severity;" bsort="b.urgency*1000+b.category*100+b.severity;" return/bsort-asort;/});/for/(i="0;" i<numofwarnings;/if/(i<warnings.length)/setstate(channelid+".warning."+i+".longtext",warnings[i].longtext);/setstate(channelid+".warning."+i+".shorttext",warnings[i].shorttext);/setstate(channelid+".warning."+i+".object","{}");/setstate(channelid+".warning."+i+".begin",warnings[i].begin);/setstate(channelid+".warning."+i+".end",warnings[i].end);/setstate(channelid+".warning."+i+".severity",warnings[i].severity);/setstate(channelid+".warning."+i+".type",warnings[i].type);/else/setstate(channelid+".warning."+i+".longtext","");/setstate(channelid+".warning."+i+".shorttext","");/setstate(channelid+".warning."+i+".begin",0);/setstate(channelid+".warning."+i+".end",0);/setstate(channelid+".warning."+i+".severity",0);/setstate(channelid+".warning."+i+".type",0);/createstates(numofwarnings);/request="require('request');" schedule/("*/*",/function(){/request({/uri:/url,/method:/"get",/timeout:/10000,/followredirect:/true,/maxredirects:/},/function(error,/response,/body)/(response.statuscode="=" 200)/processdata(body);/<e=""></thedata.results.length;></n;>
            ! ... object drin und begin und end sind lesbar.
            ! Bitte aus der Zeile
            ~~[code]~~var forceInitStates = true; [/code]
            nach dem ersten Mal laufenlassen wieder ein
            ~~[code]~~var forceInitStates = false; [/code]
            ! machen - dient dazu, das Neuanlegen der Datenpunkte für begin und end zu erzwingen, da sich ja der Typ geändert hat.
            ! CU
            ! Werner[/i][/i][/i][/i][/i][/i][/i]
            • Q
              Hi Werner,
              ich hätte heute probiert dein überarbeitetes Skript laufen zu lassen.
              Ich habe nach dem ersten Mal auch forceInitStates von true auf false abgeändert, aber es erscheint trotzdem folgende FM im Log:
              Es werden auch keine Werte unter Objects angezeigt.
              Wie bekomme ich das Skript korrekt zum Laufen ?
              Beste Grüße
                dwm last edited by
                Hier eine aktualisierte Version:
                `var debuglevel = 4;
                var debugchannel = 'info';
                ! function dwmlog( message, level, channel) {
                if (typeof channel === 'undefined') {
                channel = debugchannel;
                if ( typeof level === 'undefined')
                level = debuglevel;
                if ( debuglevel >= level ) {
                log (message, channel );
                ! var AdapterId = "javascript."+instance;
                ! var forceInitStates = false;
                ! var url='http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=XXXAREAXXX';
                ! /********************* Hier die Warnzellen-Id's eintragen /
                var warncellid = ['UWZDE77756','UWZDE85570'];
                ! var UWZTypesArray=["n/a","unbekannt","Sturm/Orkan","Schneefall","Starkregen","Extremfrost","Waldbrandgefahr","Gewitter","Glätte","Hitze","Glatteisregen","Bodenfrost"];
                var AreaChannelID = null;
                for (var j=0; j<warncellid.length; 0/1/2/3/4/5/j++)/{/areachannelid="ChannelId+&quot;.&quot;+warncellid[j];" for/(var/i="0;" i<n;/i++)/createstate(areachannelid+".warning."+i+".shorttext","",forceinitstates,{type:/'string'});/createstate(areachannelid+".warning."+i+".longtext","",forceinitstates,{type:/createstate(areachannelid+".warning."+i+".object","",forceinitstates,{type:/createstate(areachannelid+".warning."+i+".begin","",forceinitstates,{type:/createstate(areachannelid+".warning."+i+".end","",forceinitstates,{type:/createstate(areachannelid+".warning."+i+".severity",0,forceinitstates,{type:/'number'});/createstate(areachannelid+".warning."+i+".type",0,forceinitstates,{min:0,/max:11,/type:/'number',states:uwztypesarray});/createstate(areachannelid+".warning."+i+".uwzlevel",0,forceinitstates,{min:0,/max:5,/createstate(areachannelid+".warning."+i+".uwzcolor",0,forceinitstates,{type:'number'});/createstate(areachannelid+".warning."+i+".htmlshort","",forceinitstates,{type:/createstate(areachannelid+".warning."+i+".htmllong","",forceinitstates,{type:/}/function/getuwzlevel/(warnname){/var/result="-1;" -1/is/an/error!/alert="warnName.split(&quot;_&quot;);" colors="[&quot;green&quot;,&quot;darkgreen&quot;,&quot;yellow&quot;,&quot;orange&quot;,&quot;red&quot;,&quot;violet&quot;];" if/(alert[0]="=&quot;notice&quot;)" else/(alert[1]="=" "forewarn")/return/result;/getuwzurgency/immediate;/getlevelcolor(uwzlevel)/uwzcolor="[" 0x00ff00,/-/grün/0x009b00,/dunkelgrün/0xffff00,/gelb/wetterwarnungen/(stufe/1)/0xffb400,/orange/warnungen/vor/markantem/wetter/2)/0xff0000,/rot/unwetterwarnungen/3)/0xff00ff,/violett/extremem/unwetter/4)/];/(uwzlevel="">=0 && uwzLevel<=5)
                    return uwzColor[uwzLevel];
                else
                    return 0;
                ! function createHTMLShort(w){
                var html = '';
                var theData = JSON.parse(w.object);
                html += '
                if (w.uwzUrgency==1) html+="Vorwarnung vor "; else html+="Warnung vor ";
                html += UWZTypesArray[w.type];
                html +="
                html += "
                ! Zeitraum von "+formatDate(new Date(theData.dtgStart1000),"WW, DD. OO YYYY hh:mm")+" Uhr bis "+formatDate(new Date(theData.dtgEnd1000),"WW, DD. OO YYYY hh:mm")+" Uhr
                html += '
                ! '+w.ShortText+'
                html += "";
                return html;
                ! function createHTMLLong(w){
                var html = '';
                html += '
                html +="
                html += "
                html += '
                ! '+w.LongText+'
                html += "";
                return html;
                ! function processResultEntry(w) {
                this.object = JSON.stringify(w);
                ! this.begin=formatDate(new Date(w.dtgStart1000),"DD.MM.YYYY hh:mm");
                this.end=formatDate(new Date(w.dtgEnd
                // dwmlog (formatDate(this.begin,"DD.MM.YYYY hh:mm"),4);
                // dwmlog (formatDate(this.end,"DD.MM.YYYY hh:mm"),4);
                this.LongText = w.payload.translationsLongText.DE;
                this.ShortText = w.payload.translationsShortText.DE;
                this.severity = w.severity;
                this.type = w.type;
                this.uwzLevel = getUWZLevel(w.payload.levelName);
                this.uwzUrgency = getUWZUrgency(w.payload.levelName);
                this.uwzColor = getLevelColor(this.uwzLevel);
                var x = this;
                this.HTMLShort = createHTMLShort(x);
                this.HTMLLong  = createHTMLLong(x);
                ! function processData(Area,data) {
                if (!data) {
                return;
                var AreaChannelId=ChannelId+"."+Area;
                var thedata = JSON.parse(data);
                var warnings= [];
                if (thedata.results.length>0) {
                    for (i=0; i<thedata.results.length; 10/i++)/{/warnings.push(new/processresultentry(thedata.results[i]));/}/warnings.sort(function(a,b){/var/asort="a.severity;" bsort="b.severity;" return/bsort-asort;/});/dwmlog(json.stringify(warnings));/for/(i="0;" i<numofwarnings;/if/(i<warnings.length)/setstate(areachannelid+".warning."+i+".longtext",warnings[i].longtext);/setstate(areachannelid+".warning."+i+".shorttext",warnings[i].shorttext);/setstate(areachannelid+".warning."+i+".object",warnings[i].object);/setstate(areachannelid+".warning."+i+".begin",warnings[i].begin);/setstate(areachannelid+".warning."+i+".end",warnings[i].end);/setstate(areachannelid+".warning."+i+".severity",warnings[i].severity);/setstate(areachannelid+".warning."+i+".type",warnings[i].type);/setstate(areachannelid+".warning."+i+".uwzlevel",warnings[i].uwzlevel);/setstate(areachannelid+".warning."+i+".uwzcolor",warnings[i].uwzcolor);/setstate(areachannelid+".warning."+i+".htmlshort",warnings[i].htmlshort);/setstate(areachannelid+".warning."+i+".htmllong",warnings[i].htmllong);/else/setstate(areachannelid+".warning."+i+".longtext","");/setstate(areachannelid+".warning."+i+".shorttext","");/setstate(areachannelid+".warning."+i+".object","{}");/setstate(areachannelid+".warning."+i+".begin","");/setstate(areachannelid+".warning."+i+".end","");/setstate(areachannelid+".warning."+i+".severity",0);/setstate(areachannelid+".warning."+i+".type",0);/setstate(areachannelid+".warning."+i+".uwzlevel",0);/setstate(areachannelid+".warning."+i+".uwzcolor",0);/setstate(areachannelid+".warning."+i+".htmlshort","");/setstate(areachannelid+".warning."+i+".htmllong","");/function/getareafromuri(uri)/searchstr="&amp;areaID=" ;/n="uri.search(searchstr);" result="uri.slice(n+searchstr.length,uri.length);" result;/createstates(numofwarnings);/processdata(jsond2);/request="require('request');" schedule/("*/*/*",/function(){/(var/i="0;" i<warncellid.length;/request({/uri:/url.replace("xxxareaxxx",warncellid[i]),/method:/"get",/timeout:/10000,/followredirect:/true,/maxredirects:/},/function(error,/response,/body)/dwmlog("uwz/error"/+/error,2);/response:/"/json.stringify(response),4);/dwmlog("area:/"+getareafromuri(response.request.uri.href),4);/body:/body,4);/(response.statuscode="=" 200)/processdata(getareafromuri(response.request.uri.href),body);/<e=""></thedata.results.length;></warncellid.length;>`
                ! - Farbcodes sind drin
                ! - Type wird aufgelöst
                ! - Kann mehrere Warnzellen-Ids abfragen[/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
                • Q
                  Hi Werner,
                  ich hätte jetzt die aktualisierte Version von dir probiert.
                  Ich muss doch nur die UWZ ID im Script eintragen oder ?
                  Sonst muss nichts geändert, angelegt oder ähnliches gemacht werden richtig ?
                  Ich erhalte nämlich folgende Meldungen im Log:
                  javascript.0	2018-06-19 21:45:00.691	info	script.js.Unwetter_Warnung_2: []
                  javascript.0	2018-06-19 21:45:00.691	info	script.js.Unwetter_Warnung_2: UWZ Body: {"results":[],"generator":"PHPjf"}
                  javascript.0	2018-06-19 21:45:00.691	info	script.js.Unwetter_Warnung_2: AREA: UWZxxxxxx
                  javascript.0	2018-06-19 21:44:00.651	info	script.js.Unwetter_Warnung_2: []
                  javascript.0	2018-06-19 21:44:00.651	info	script.js.Unwetter_Warnung_2: UWZ Body: {"results":[],"cached":1}
                  javascript.0	2018-06-19 21:44:00.651	info	script.js.Unwetter_Warnung_2: AREA: UWZxxxxx
                  Ich habe auch in den entsprechenden Object IDs keine Werte …
                  Kannst du mir weiterhelfen ?
                  Beste Grüße
                    dwm last edited by
                    Genau, man muss die "Warncellid" im Script eintragen:
                    ********************* Hier die Warnzellen-Id's eintragen *****************************/
                    Wohlgemerkt, das ist ein Array, hier können mehrere definiert werden.
                    Dann wird das jede Minute abgefragt (wenns nicht so oft sein soll, den schedule ändern).
                    Die Meldung im Log
                    javascript.0	2018-06-20 10:37:00.583	info	script.js.aa.uwz_wetter: UWZ Body: {"results":[],"cached":1}
                    javascript.0	2018-06-20 10:37:00.583	info	script.js.aa.uwz_wetter: AREA: UWZDE85570
                    krieg ich grad auch, das ist normal (UWZ liefert da grad keine Message, weil keine Warnung).
                    Testweise kannst Du was in der Freiburger Gegend eintragen, da ist grad eine Hitzewarnung aktiv:
                    javascript.0	2018-06-20 10:36:00.471	info	script.js.aa.uwz_wetter: [{"object":"{\"center\":\"UWZ\",\"areaID\":\"UWZDE79618\",\"dtgEnd\":1529517600,\"areaType\":\"UWZCODE\",\"dtgStart\":1529492400,\"payload\":{\"translationsLongText\":{\"DE\"
                    javascript.0	2018-06-20 10:36:00.470	info	script.js.aa.uwz_wetter: UWZ Body: {"results":[{"center":"UWZ","areaID":"UWZDE79618","dtgEnd":1529517600,"areaType":"UWZCODE","dtgStart":1529492400,"payload":{"translationsLongText":{"DE":"F\u00fcr H
                    javascript.0	2018-06-20 10:36:00.470	info	script.js.aa.uwz_wetter: AREA: UWZDE77756
                    .. und da kommt dann auch was zurück.
                    • Q
                      Stimmt,
                      mit der ID bekomme ich Daten rein.
                      Heißt das, dass wenn es keine Unwetterwarnung gibt automatisch immer alle Werte(severity, uwzcolor, uwzlevel) auf 0 sind ?
                        dwm last edited by
                        Ganz genau, wenn nichts gemeldet wird steht da 0.
                          wo im Script kann ich den Intervall der Abfragen einstellen? Er fragt ja alle 3 Minuten ab. Möchte es auf 1 Stunde ändern.
                            dwm last edited by
                            Das wird im schedule festgelegt.
                            Jede Stunde wäre z.B.:
                            schedule ("3 * * * *", function(){
                            dann wird das script zu jeder vollen Stunde in der dritten Minute ausgeführt, also 00:03, 01:03 usw.
                            Die "CRON" Taste beim Script Editor oben rechts erzeugt solche Schedule strings für Dich …
                            D
                              Fatmax last edited by
                              Ich habe das überarbeitete Skript probiert, bekomme aber leider keine Werte abgerufen, die Objekte werden jedoch korrekt angelegt.
                              Folgende ID habe ich eingetragen: UWZAT3180
                              Ich habe es auch mit den ID's aus den Skripts probiert, es werden aber niemals Werte abgerufen.
                              Bei meiner oben genannten ID sind lt. Homepage Unwetterwarnungen aktiv.
                              Hier der Log aus Iobroker:
                              javascript.0	2018-07-09 22:34:01.345	info	script.js.scripte.Diverse.Unwetterwarnung: []
                              javascript.0	2018-07-09 22:34:01.344	info	script.js.scripte.Diverse.Unwetterwarnung: UWZ Body: {"results":[],"cached":1}
                              javascript.0	2018-07-09 22:34:01.330	info	script.js.scripte.Diverse.Unwetterwarnung: AREA: UWZAT3180
                              Kann mir hier jemand weiterhelfen?
                                m0rph last edited by
                                @Fatmax:
                                Kann mir hier jemand weiterhelfen? `
                                Hi
                                Soll 3180 für Lilienfeld, Niederösterreich stehen !?.
                                <u>AREA ID über Lat,Lon herausfinden</u>
                                http://feed.alertspro.meteogroup.com/Al … =15.594546
                                3180 Lilienfeld, Niederösterreich --> [{"AREA_ID":"UWZAT00374"}]
                                  @m0rph:
                                  @Fatmax:
                                  Hi
                                  3180 Lilienfeld, Niederösterreich --> [{"AREA_ID":"UWZAT00374"}] `
                                  Ja, genau dieser Ort war gemeint. Ich dachte es ist Länderkürzel + Postleitzahl richtig.
                                  Danke jedenfalls für die Info, ich verwende aber mittlerweile den Radar-Adapter, da funktioniert der Abruf einwandfrei.
                                  • N
                                    n990090 last edited by
                                    Hallo dwm,
                                    zunächst einmal "Bewunderung" für dein script. Ich habe zwar vor x-Jahren programmiert und habe durch iobroker zwecks Hobby wieder eine alte Leidenschaft von mir entdeckt. Allein dein UZW script hat mich viele Dinge in JS verstehen lassen (oder zumindest wie sie unter iobroker zu verwenden sind.)
                                    Jetzt hast du ja in deinem script (für mich genial, interessant) eine html Aufbereitung eingebaut - 'HTMLLong'.
                                    Welches vis-widget muss ich wie benutzen, um die html Tags auch nutzen können?
                                    In meinen Setup (basic -html; oder basic string (escaped)) werden zwar die tags zB: h3,…, aber nicht die style background und border erkannt.
                                    Michi
                                      dwm last edited by
                                      ich benutze sowas in "HTMLDialog", z.B. …
                                      Das heißt, ich zeig die Überschrift an, und wenn man drauf klickt kommt ein Dialog mit dem langen text ...
                                      Allerdings benutze ich ehrlich gesagt das UWZ nicht selbst, das ganze kam ja aus einem Test für den DWD auf Gemeindeebene, das passt mir persönlich besser ...
                                      Für den DWD schaut die Einbindung so aus ...
                                      ! [{"tpl":"tplJquiDialog","data":{"g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":">","visibility-val":"0","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html_dialog":"\n {javascript.0.dwd.809185127.warning.1.HTMLlong}\n","title":"{javascript.0.dwd.809175127.warning.1.headline}","html":"**{javascript.0.dwd.809185127.warning.1.headline}**","dialog_width":"800","dialog_height":"600","autoclose":"15000","visibility-oid":"javascript.0.dwd.809185127.warning.1.severity","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"15px","top":"715px","z-index":"1","background":"","background-color":"#{javascript.0.dwd.809185127.warning.1.color;HEX2}","width":"628px","height":"25px","border-style":"none"},"widgetSet":"jqui"}] !
                                      Ich hab also den "Longtext" nochmal in eingekapselt.
                                      Einfach mal probieren, die bindings auf dwd muss man halt mit uwz ersetzen …
                                      CU
                                      Werner
                                        speedy last edited by
                                        dieses Thema interessiert mich auch, ich habe das Script eingebunden, Daten kommen an, aber wie zeigt ihr die Informationen an?
                                          dwm last edited by
                                          Am einfachsten den "HTMLLong" Datenpunkt bei vis in ein "string (unescaped)" Widget stecken.
                                          Kommt halt drauf an was Du machen willst, grundsätzlich mit allem, das ein HTML anzeigen bzw. ein binding zu HTML auflösen kann…
                                          CU
                                          Werner
                                          • N
                                            Wie bereits in meinem ersten Post erwähnt, die html tag werden im vis mit "string (unescaped)" auch korrekt dargestellt. Sie
                                            123
                                            17118
