    4. [Aufruf] Smartmeter 1.2.0 testen
    • bahnuhr
      log:
      `2018-06-21 18:11:46.248  - [32minfo[39m: iobroker url "https://github.com/Apollon77/ioBroker.smartmeter/tarball/master" smartmeter
      2018-06-21 18:11:47.137  - [32minfo[39m: iobroker install https://github.com/Apollon77/ioBroker.smartmeter/tarball/master
      2018-06-21 18:11:49.025  - [32minfo[39m: iobroker npm install https://github.com/Apollon77/ioBroker.smartmeter/tarball/master --production --save --prefix "C:/ioBroker" (System call)
      2018-06-21 18:11:57.975  - [32minfo[39m: iobroker npm
      2018-06-21 18:11:57.975  - [32minfo[39m: iobroker  WARN deprecated parser-cctalk@1.0.2: reanmed to @serialport/parser-cctalk
      2018-06-21 18:11:57.991  - [32minfo[39m: iobroker npm
      2018-06-21 18:11:57.992  - [32minfo[39m: iobroker  WARN deprecated parser-byte-length@1.0.2: renamed to @serialport/parser-byte-length
      2018-06-21 18:11:57.998  - [32minfo[39m: iobroker npm
      2018-06-21 18:11:57.999  - [32minfo[39m: iobroker  WARN deprecated parser-readline@1.0.2: reanmed to @serialport/parser-readline
      2018-06-21 18:11:58.001  - [32minfo[39m: iobroker npm WARN deprecated parser-regex@1.0.2: reanmed to @serialport/parser-regex
      2018-06-21 18:11:58.006  - [32minfo[39m: iobroker npm WARN deprecated parser-delimiter@1.0.2: reanmed to @serialport/parser-delimiter
      2018-06-21 18:11:58.034  - [32minfo[39m: iobroker npm
      2018-06-21 18:11:58.035  - [32minfo[39m: iobroker  WARN deprecated parser-ready@1.0.2: reanmed to @serialport/parser-ready
      2018-06-21 18:12:00.708  - [32minfo[39m: javascript.0 script.js.Scripte.Sonstige.Mähroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "stopped": false, "duration": 72907, "mode": 0, "battery": 100, "hours": 356}, "timer": {"status": 2, "next": {"date": "2018-06-23", "time": "12:00:00", "unix": 1529755200}}, "blades": {"quality": 77, "hours": 47, "days": 31}, "wlan": {"signal": -59}, "health": {"temperature": 35, "humidity": 25}, "clock": {"date": "2018-06-21", "time": "18:11:59", "unix": 1529604719}, "successful": true}
      2018-06-21 18:12:00.792  - [32minfo[39m: javascript.0 script.js.Scripte.Sonstige.Photovoltaik: Auslöser: Schedule
      2018-06-21 18:12:00.996  - [32minfo[39m: javascript.0 script.js.Scripte.System.Servicemeldungen: Auslöser Servicemeldungen Schedule
      2018-06-21 18:12:11.799  - [32minfo[39m: iobroker got C:/ioBroker/node_modules/iobroker.smartmeter/admin
      2018-06-21 18:12:11.824  - [32minfo[39m: iobroker upload [5] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/words.js words.js application/javascript
      2018-06-21 18:12:11.911  - [32minfo[39m: iobroker upload [4] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
      2018-06-21 18:12:11.966  - [32minfo[39m: iobroker upload [3] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
      2018-06-21 18:12:12.038  - [32minfo[39m: iobroker upload [2] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
      2018-06-21 18:12:12.129  - [32minfo[39m: iobroker upload [1] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
      2018-06-21 18:12:12.185  - [32minfo[39m: iobroker upload [0] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
      2018-06-21 18:12:12.265  - [32minfo[39m: iobroker exit 0
      2018-06-21 18:12:12.427  - [32minfo[39m: host.Asus-Buero Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2018-06-21 18:12:23.401  - [32minfo[39m: javascript.0 script.js.Scripte.Licht.Flur2_EG: Licht Flur 2 EG nicht ausgeschaltet. Erneute Prüfung nach 2 min.
      2018-06-21 18:12:33.766  - [32minfo[39m: host.Asus-Buero object change system.adapter.smartmeter.0
      2018-06-21 18:12:36.056  - [32minfo[39m: host.Asus-Buero object change system.adapter.smartmeter.1[/code]`
      exit mit 0 -> müsste ok sein.
      Und eine Hardcopy von den Objekten.
       ![1540_bild1.jpg](/assets/uploads/files/1540_bild1.jpg)
        apollon77 last edited by
        Der Log vom Start ist interessanter 🙂
        • bahnuhr
          habe Instanz aus geschaltet.
          Und dann wieder ein.
          mehr kommt da nicht:
            Setze bitte mal Loglevel auf Debug (Instanzen - Expertenmodus - Spalte Loglevel)
            • bahnuhr
              hab ich.
              anbei:
              smartmeter.0	2018-06-22 11:02:18.328	debug	SERIALPORT CLOSE
              smartmeter.0	2018-06-22 11:02:18.327	debug	SCHEDULE NEXT RUN IN 300s
              smartmeter.0	2018-06-22 11:02:18.327	debug	RESUME READING SERIALPORT
              smartmeter.0	2018-06-22 11:02:18.327	debug	SET MESSAGE TIMEOUT TIMER: 120000
              smartmeter.0	2018-06-22 11:02:18.327	info	Received 7 values, 7 updated
              smartmeter.0	2018-06-22 11:02:18.327	debug	Set State 129-129:199_130_5*255.value = 93292772e43fde6481665b70152078535915a6280c7c672f6aa6b0bfd269c0465581d202d4aefe59beb54ea6527100f8
              smartmeter.0	2018-06-22 11:02:18.327	debug	Set State 129-129:199_130_5*255.rawvalue = undefined
              smartmeter.0	2018-06-22 11:02:18.326	debug	Create State 129-129:199_130_5*255.value
              smartmeter.0	2018-06-22 11:02:18.326	debug	Create Channel 129-129:199_130_5*255 with name Forename/Public Key
              smartmeter.0	2018-06-22 11:02:18.326	debug	129-129:199.130.5*255: Forename/Public Key = 93292772e43fde6481665b70152078535915a6280c7c672f6aa6b0bfd269c0465581d202d4aefe59beb54ea6527100f8
              smartmeter.0	2018-06-22 11:02:18.326	debug	Set State 1-0:16_7_0*255.value = -769.2
              smartmeter.0	2018-06-22 11:02:18.326	debug	Set State 1-0:16_7_0*255.rawvalue = undefined
              smartmeter.0	2018-06-22 11:02:18.326	debug	Create State 1-0:16_7_0*255.value
              smartmeter.0	2018-06-22 11:02:18.326	debug	Create Channel 1-0:16_7_0*255 with name Momentanwert Gesamtwirkleistung (Total)
              smartmeter.0	2018-06-22 11:02:18.326	debug	1-0:16.7.0*255: Momentanwert Gesamtwirkleistung (Total) = -769.2 W
              smartmeter.0	2018-06-22 11:02:18.326	debug	Set State 1-0:2_8_2*255.value = 28496.3828
              smartmeter.0	2018-06-22 11:02:18.325	debug	Set State 1-0:2_8_2*255.rawvalue = undefined
              smartmeter.0	2018-06-22 11:02:18.325	debug	Create State 1-0:2_8_2*255.value
              smartmeter.0	2018-06-22 11:02:18.325	debug	Create Channel 1-0:2_8_2*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (T2)
              smartmeter.0	2018-06-22 11:02:18.325	debug	1-0:2.8.2*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T2) = 28496.3828 kWh
              smartmeter.0	2018-06-22 11:02:18.325	debug	Set State 1-0:2_8_1*255.value = 0
              smartmeter.0	2018-06-22 11:02:18.325	debug	Set State 1-0:2_8_1*255.rawvalue = undefined
              smartmeter.0	2018-06-22 11:02:18.325	debug	Create State 1-0:2_8_1*255.value
              smartmeter.0	2018-06-22 11:02:18.325	debug	Create Channel 1-0:2_8_1*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (T1)
              smartmeter.0	2018-06-22 11:02:18.324	debug	1-0:2.8.1*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T1) = 0 kWh
              smartmeter.0	2018-06-22 11:02:18.324	debug	Set State 1-0:2_8_0*255.value = 28496.3828
              smartmeter.0	2018-06-22 11:02:18.324	debug	Set State 1-0:2_8_0*255.rawvalue = undefined
              smartmeter.0	2018-06-22 11:02:18.324	debug	Create State 1-0:2_8_0*255.value
              smartmeter.0	2018-06-22 11:02:18.324	debug	Create Channel 1-0:2_8_0*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (Total)
              smartmeter.0	2018-06-22 11:02:18.324	debug	1-0:2.8.0*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 28496.3828 kWh
              smartmeter.0	2018-06-22 11:02:18.324	debug	Set State 1-0:0_0_9*255.value = 06454d480104c56ee7c1
              smartmeter.0	2018-06-22 11:02:18.324	debug	Set State 1-0:0_0_9*255.rawvalue = undefined
              smartmeter.0	2018-06-22 11:02:18.324	debug	Create State 1-0:0_0_9*255.value
              smartmeter.0	2018-06-22 11:02:18.323	debug	Create Channel 1-0:0_0_9*255 with name Device ID
              smartmeter.0	2018-06-22 11:02:18.323	debug	1-0:0.0.9*255: Device ID = 06454d480104c56ee7c1
              smartmeter.0	2018-06-22 11:02:18.323	debug	Set State 129-129:199_130_3*255.value = EMH
              smartmeter.0	2018-06-22 11:02:18.323	debug	Set State 129-129:199_130_3*255.rawvalue = undefined
              smartmeter.0	2018-06-22 11:02:18.323	debug	Create State 129-129:199_130_3*255.value
              smartmeter.0	2018-06-22 11:02:18.323	debug	Create Channel 129-129:199_130_3*255 with name Manufacturer ID
              smartmeter.0	2018-06-22 11:02:18.323	debug	129-129:199.130.3*255: Manufacturer ID = EMH
              smartmeter.0	2018-06-22 11:02:18.323	debug	STORE DATA
              smartmeter.0	2018-06-22 11:02:18.322	debug	SML MESSAGE: START SML-File START SmlMessage Transaction-ID: H�� (00160248f6c4) Group-No: 0 Abort On Error: 0 Message-Body: SmlPublicOpenResponse Codepage: undefined Client-ID: und
              smartmeter.0	2018-06-22 11:02:18.322	debug	MSG IDX 350
              smartmeter.0	2018-06-22 11:02:18.322	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
              smartmeter.0	2018-06-22 11:02:18.322	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.321	debug	ADD NEW DATA (498 + NEW 9)
              smartmeter.0	2018-06-22 11:02:18.204	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.203	debug	ADD NEW DATA (483 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.191	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.190	debug	ADD NEW DATA (467 + NEW 16)
              smartmeter.0	2018-06-22 11:02:18.171	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.170	debug	ADD NEW DATA (452 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.156	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.155	debug	ADD NEW DATA (437 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.140	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.139	debug	ADD NEW DATA (421 + NEW 16)
              smartmeter.0	2018-06-22 11:02:18.126	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.125	debug	ADD NEW DATA (406 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.110	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.109	debug	ADD NEW DATA (391 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.103	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.099	debug	ADD NEW DATA (375 + NEW 16)
              smartmeter.0	2018-06-22 11:02:18.076	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.075	debug	ADD NEW DATA (360 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.060	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.059	debug	ADD NEW DATA (345 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.044	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.043	debug	ADD NEW DATA (329 + NEW 16)
              smartmeter.0	2018-06-22 11:02:18.031	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.029	debug	ADD NEW DATA (314 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.018	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.016	debug	ADD NEW DATA (299 + NEW 15)
              smartmeter.0	2018-06-22 11:02:18.005	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:18.002	debug	ADD NEW DATA (283 + NEW 16)
              smartmeter.0	2018-06-22 11:02:17.982	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:17.980	debug	ADD NEW DATA (268 + NEW 15)
              smartmeter.0	2018-06-22 11:02:17.969	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:17.968	debug	ADD NEW DATA (253 + NEW 15)
              smartmeter.0	2018-06-22 11:02:17.968	debug	MATCH-RESULT MESSAGE: "fc33f10177070100020801ff0101621e52ff5600000000000177070100020802ff0101621e52ff560010fc33f10177070100100700ff0101621b52ff55ffffe1fb0177078181c78205ff01726201650aacb04b01018302932
              smartmeter.0	2018-06-22 11:02:17.968	debug	ADD NEW DATA (237 + NEW 16)
              smartmeter.0	2018-06-22 11:02:17.965	debug	system.adapter.admin.0: logging true
                Und du hast wirklich die 1.2.0 installiert? Im Log fehlte leider die Zeile vom Start des Adapters …
                • bahnuhr
                  wird zumindest so angezeigt.
                  • bahnuhr
                    @apollon77:
                    Im Log fehlte leider die Zeile vom Start des Adapters … `
                    Es kommt da sonst nix.
                    javascript.0	2018-06-22 11:33:52.085	info	script.js.Scripte.Sonstige.Kombisensor_-_Windrose: Auslöser Windrichtung
                    smartmeter.0	2018-06-22 11:33:32.387	debug	SERIALPORT CLOSE
                    smartmeter.0	2018-06-22 11:33:32.387	debug	SCHEDULE NEXT RUN IN 300s
                    smartmeter.0	2018-06-22 11:33:32.386	debug	RESUME READING SERIALPORT
                    smartmeter.0	2018-06-22 11:33:32.386	debug	SET MESSAGE TIMEOUT TIMER: 120000
                    smartmeter.0	2018-06-22 11:33:32.386	info	Received 7 values, 7 updated
                    smartmeter.0	2018-06-22 11:33:32.386	debug	Set State 129-129:199_130_5*255.value = 93292772e43fde6481665b70152078535915a6280c7c672f6aa6b0bfd269c0465581d202d4aefe59beb54ea6527100f8
                    smartmeter.0	2018-06-22 11:33:32.386	debug	Set State 129-129:199_130_5*255.rawvalue = undefined
                    smartmeter.0	2018-06-22 11:33:32.386	debug	Create State 129-129:199_130_5*255.value
                    smartmeter.0	2018-06-22 11:33:32.385	debug	Create Channel 129-129:199_130_5*255 with name Forename/Public Key
                    smartmeter.0	2018-06-22 11:33:32.385	debug	129-129:199.130.5*255: Forename/Public Key = 93292772e43fde6481665b70152078535915a6280c7c672f6aa6b0bfd269c0465581d202d4aefe59beb54ea6527100f8
                    smartmeter.0	2018-06-22 11:33:32.385	debug	Set State 1-0:16_7_0*255.value = -941.3
                    smartmeter.0	2018-06-22 11:33:32.385	debug	Set State 1-0:16_7_0*255.rawvalue = undefined
                    smartmeter.0	2018-06-22 11:33:32.385	debug	Create State 1-0:16_7_0*255.value
                    smartmeter.0	2018-06-22 11:33:32.385	debug	Create Channel 1-0:16_7_0*255 with name Momentanwert Gesamtwirkleistung (Total)
                    smartmeter.0	2018-06-22 11:33:32.385	debug	1-0:16.7.0*255: Momentanwert Gesamtwirkleistung (Total) = -941.3 W
                    smartmeter.0	2018-06-22 11:33:32.385	debug	Set State 1-0:2_8_2*255.value = 28496.8207
                    smartmeter.0	2018-06-22 11:33:32.385	debug	Set State 1-0:2_8_2*255.rawvalue = undefined
                    smartmeter.0	2018-06-22 11:33:32.384	debug	Create State 1-0:2_8_2*255.value
                    smartmeter.0	2018-06-22 11:33:32.384	debug	Create Channel 1-0:2_8_2*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (T2)
                    smartmeter.0	2018-06-22 11:33:32.384	debug	1-0:2.8.2*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T2) = 28496.8207 kWh
                    smartmeter.0	2018-06-22 11:33:32.384	debug	Set State 1-0:2_8_1*255.value = 0
                    smartmeter.0	2018-06-22 11:33:32.384	debug	Set State 1-0:2_8_1*255.rawvalue = undefined
                    smartmeter.0	2018-06-22 11:33:32.384	debug	Create State 1-0:2_8_1*255.value
                    smartmeter.0	2018-06-22 11:33:32.384	debug	Create Channel 1-0:2_8_1*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (T1)
                    smartmeter.0	2018-06-22 11:33:32.384	debug	1-0:2.8.1*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T1) = 0 kWh
                    smartmeter.0	2018-06-22 11:33:32.384	debug	Set State 1-0:2_8_0*255.value = 28496.8207
                    smartmeter.0	2018-06-22 11:33:32.383	debug	Set State 1-0:2_8_0*255.rawvalue = undefined
                    smartmeter.0	2018-06-22 11:33:32.383	debug	Create State 1-0:2_8_0*255.value
                    smartmeter.0	2018-06-22 11:33:32.383	debug	Create Channel 1-0:2_8_0*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (Total)
                    smartmeter.0	2018-06-22 11:33:32.383	debug	1-0:2.8.0*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 28496.8207 kWh
                    smartmeter.0	2018-06-22 11:33:32.383	debug	Set State 1-0:0_0_9*255.value = 06454d480104c56ee7c1
                    smartmeter.0	2018-06-22 11:33:32.383	debug	Set State 1-0:0_0_9*255.rawvalue = undefined
                    smartmeter.0	2018-06-22 11:33:32.383	debug	Create State 1-0:0_0_9*255.value
                    smartmeter.0	2018-06-22 11:33:32.383	debug	Create Channel 1-0:0_0_9*255 with name Device ID
                    smartmeter.0	2018-06-22 11:33:32.383	debug	1-0:0.0.9*255: Device ID = 06454d480104c56ee7c1
                    smartmeter.0	2018-06-22 11:33:32.382	debug	Set State 129-129:199_130_3*255.value = EMH
                    smartmeter.0	2018-06-22 11:33:32.382	debug	Set State 129-129:199_130_3*255.rawvalue = undefined
                    smartmeter.0	2018-06-22 11:33:32.382	debug	Create State 129-129:199_130_3*255.value
                    smartmeter.0	2018-06-22 11:33:32.382	debug	Create Channel 129-129:199_130_3*255 with name Manufacturer ID
                    smartmeter.0	2018-06-22 11:33:32.382	debug	129-129:199.130.3*255: Manufacturer ID = EMH
                    smartmeter.0	2018-06-22 11:33:32.382	debug	STORE DATA
                    smartmeter.0	2018-06-22 11:33:32.382	debug	SML MESSAGE: START SML-File START SmlMessage Transaction-ID: I< (00160249123c) Group-No: 0 Abort On Error: 0 Message-Body: SmlPublicOpenResponse Codepage: undefined Client-ID: und
                    smartmeter.0	2018-06-22 11:33:32.382	debug	MSG IDX 530
                    smartmeter.0	2018-06-22 11:33:32.381	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
                    smartmeter.0	2018-06-22 11:33:32.381	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.380	debug	ADD NEW DATA (584 + NEW 13)
                    smartmeter.0	2018-06-22 11:33:32.257	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.256	debug	ADD NEW DATA (568 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:32.241	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.240	debug	ADD NEW DATA (554 + NEW 14)
                    smartmeter.0	2018-06-22 11:33:32.232	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.225	debug	ADD NEW DATA (538 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:32.211	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.210	debug	ADD NEW DATA (522 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:32.201	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.199	debug	ADD NEW DATA (508 + NEW 14)
                    smartmeter.0	2018-06-22 11:33:32.178	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.177	debug	ADD NEW DATA (492 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:32.161	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.161	debug	ADD NEW DATA (476 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:32.145	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.144	debug	ADD NEW DATA (462 + NEW 14)
                    smartmeter.0	2018-06-22 11:33:32.130	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.129	debug	ADD NEW DATA (446 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:32.114	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.113	debug	ADD NEW DATA (430 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:32.097	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.096	debug	ADD NEW DATA (416 + NEW 14)
                    smartmeter.0	2018-06-22 11:33:32.084	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.083	debug	ADD NEW DATA (400 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:32.067	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.066	debug	ADD NEW DATA (385 + NEW 15)
                    smartmeter.0	2018-06-22 11:33:32.053	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.053	debug	ADD NEW DATA (354 + NEW 31)
                    smartmeter.0	2018-06-22 11:33:32.052	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.051	debug	ADD NEW DATA (323 + NEW 31)
                    smartmeter.0	2018-06-22 11:33:32.028	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.028	debug	ADD NEW DATA (293 + NEW 30)
                    smartmeter.0	2018-06-22 11:33:32.020	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:32.014	debug	ADD NEW DATA (277 + NEW 16)
                    smartmeter.0	2018-06-22 11:33:31.939	debug	MATCH-RESULT MESSAGE: "77010b06454d480104c56ee7c1070100620affff726201650aacb79d7777078181c78203ff0101010104454d480177070100000009ff010101010b06454d480104c56ee7c10177070100020800ff640200a201621e52ff560
                    smartmeter.0	2018-06-22 11:33:31.937	debug	ADD NEW DATA (265 + NEW 12)
                    smartmeter.0	2018-06-22 11:33:31.483	debug	system.adapter.admin.0: logging true
                    host.Asus-Buero	2018-06-22 11:33:28.676	info	object change system.adapter.smartmeter.0
                    host.Asus-Buero	2018-06-22 11:33:21.695	info	object change system.adapter.smartmeter.0
                    javascript.0	2018-06-22 11:33:11.067	info	script.js.Scripte.Sonstige.Wohnzimmer: Auslöser Bewegung Wohnzimmer
                      Häää??
                      Ok Im File /opt/iobroker/node_modules/iobroker.smartmeter/smartmeter.js Zeile 190 was steht da bei Dir?
                      Es sollte
                              var ioChannelId = obisResult[obisId].idToString().replace(/[.*]/g, "_");
                      sein
                      • bahnuhr
                        ja, richtig.
                        Genau das steht da.
                        Bei aber Win7 Rechner.
                        Also:
                        C:\iobroker\….
                        1540_smartmeter.js
                          strange … Ich habe jetzt nochmal die regex geändert. 1.2.1 auf GitHub.
                          Bitte nochmal checken. Danke
                          • bahnuhr
                            1.2.1 installiert
                            log:
                            smartmeter.0	2018-06-23 08:26:15.663	debug	SERIALPORT CLOSE
                            smartmeter.0	2018-06-23 08:26:15.663	debug	SCHEDULE NEXT RUN IN 300s
                            smartmeter.0	2018-06-23 08:26:15.663	debug	RESUME READING SERIALPORT
                            smartmeter.0	2018-06-23 08:26:15.663	debug	SET MESSAGE TIMEOUT TIMER: 120000
                            smartmeter.0	2018-06-23 08:26:15.663	info	Received 7 values, 7 updated
                            smartmeter.0	2018-06-23 08:26:15.662	debug	Set State 129-129:199_130_5*255.value = 93292772e43fde6481665b70152078535915a6280c7c672f6aa6b0bfd269c0465581d202d4aefe59beb54ea6527100f8
                            smartmeter.0	2018-06-23 08:26:15.654	debug	Set State 129-129:199_130_5*255.rawvalue = undefined
                            smartmeter.0	2018-06-23 08:26:15.654	debug	Create State 129-129:199_130_5*255.value
                            smartmeter.0	2018-06-23 08:26:15.654	debug	Create Channel 129-129:199_130_5*255 with name Forename/Public Key
                            smartmeter.0	2018-06-23 08:26:15.654	debug	129-129:199.130.5*255: Forename/Public Key = 93292772e43fde6481665b70152078535915a6280c7c672f6aa6b0bfd269c0465581d202d4aefe59beb54ea6527100f8
                            smartmeter.0	2018-06-23 08:26:15.654	debug	Set State 1-0:16_7_0*255.value = -1118.5
                            smartmeter.0	2018-06-23 08:26:15.653	debug	Set State 1-0:16_7_0*255.rawvalue = undefined
                            smartmeter.0	2018-06-23 08:26:15.653	debug	Create State 1-0:16_7_0*255.value
                            smartmeter.0	2018-06-23 08:26:15.653	debug	Create Channel 1-0:16_7_0*255 with name Momentanwert Gesamtwirkleistung (Total)
                            smartmeter.0	2018-06-23 08:26:15.653	debug	1-0:16.7.0*255: Momentanwert Gesamtwirkleistung (Total) = -1118.5 W
                            smartmeter.0	2018-06-23 08:26:15.653	debug	Set State 1-0:2_8_2*255.value = 28508.3225
                            smartmeter.0	2018-06-23 08:26:15.653	debug	Set State 1-0:2_8_2*255.rawvalue = undefined
                            smartmeter.0	2018-06-23 08:26:15.653	debug	Create State 1-0:2_8_2*255.value
                            smartmeter.0	2018-06-23 08:26:15.653	debug	Create Channel 1-0:2_8_2*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (T2)
                            smartmeter.0	2018-06-23 08:26:15.653	debug	1-0:2.8.2*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T2) = 28508.3225 kWh
                            smartmeter.0	2018-06-23 08:26:15.652	debug	Set State 1-0:2_8_1*255.value = 0
                            smartmeter.0	2018-06-23 08:26:15.652	debug	Set State 1-0:2_8_1*255.rawvalue = undefined
                            smartmeter.0	2018-06-23 08:26:15.652	debug	Create State 1-0:2_8_1*255.value
                            smartmeter.0	2018-06-23 08:26:15.652	debug	Create Channel 1-0:2_8_1*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (T1)
                            smartmeter.0	2018-06-23 08:26:15.652	debug	1-0:2.8.1*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T1) = 0 kWh
                            smartmeter.0	2018-06-23 08:26:15.652	debug	Set State 1-0:2_8_0*255.value = 28508.3225
                            smartmeter.0	2018-06-23 08:26:15.652	debug	Set State 1-0:2_8_0*255.rawvalue = undefined
                            smartmeter.0	2018-06-23 08:26:15.652	debug	Create State 1-0:2_8_0*255.value
                            smartmeter.0	2018-06-23 08:26:15.652	debug	Create Channel 1-0:2_8_0*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (Total)
                            smartmeter.0	2018-06-23 08:26:15.651	debug	1-0:2.8.0*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 28508.3225 kWh
                            smartmeter.0	2018-06-23 08:26:15.651	debug	Set State 1-0:0_0_9*255.value = 06454d480104c56ee7c1
                            smartmeter.0	2018-06-23 08:26:15.651	debug	Set State 1-0:0_0_9*255.rawvalue = undefined
                            smartmeter.0	2018-06-23 08:26:15.651	debug	Create State 1-0:0_0_9*255.value
                            smartmeter.0	2018-06-23 08:26:15.651	debug	Create Channel 1-0:0_0_9*255 with name Device ID
                            smartmeter.0	2018-06-23 08:26:15.651	debug	1-0:0.0.9*255: Device ID = 06454d480104c56ee7c1
                            smartmeter.0	2018-06-23 08:26:15.651	debug	Set State 129-129:199_130_3*255.value = EMH
                            smartmeter.0	2018-06-23 08:26:15.651	debug	Set State 129-129:199_130_3*255.rawvalue = undefined
                            smartmeter.0	2018-06-23 08:26:15.650	debug	Create State 129-129:199_130_3*255.value
                            smartmeter.0	2018-06-23 08:26:15.650	debug	Create Channel 129-129:199_130_3*255 with name Manufacturer ID
                            smartmeter.0	2018-06-23 08:26:15.650	debug	129-129:199.130.3*255: Manufacturer ID = EMH
                            smartmeter.0	2018-06-23 08:26:15.650	debug	STORE DATA
                            smartmeter.0	2018-06-23 08:26:15.650	debug	SML MESSAGE: START SML-File START SmlMessage Transaction-ID: M~� (0016024d7eb6) Group-No: 0 Abort On Error: 0 Message-Body: SmlPublicOpenResponse Codepage: undefined Client-ID: und
                            smartmeter.0	2018-06-23 08:26:15.650	debug	MSG IDX 4
                            smartmeter.0	2018-06-23 08:26:15.650	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
                            smartmeter.0	2018-06-23 08:26:15.649	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.648	debug	ADD NEW DATA (331 + NEW 3)
                            smartmeter.0	2018-06-23 08:26:15.539	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.537	debug	ADD NEW DATA (316 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.525	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.524	debug	ADD NEW DATA (301 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.509	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.509	debug	ADD NEW DATA (285 + NEW 16)
                            smartmeter.0	2018-06-23 08:26:15.489	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.488	debug	ADD NEW DATA (270 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.473	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.472	debug	ADD NEW DATA (255 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.459	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.458	debug	ADD NEW DATA (239 + NEW 16)
                            smartmeter.0	2018-06-23 08:26:15.442	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.441	debug	ADD NEW DATA (224 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.430	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.429	debug	ADD NEW DATA (209 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.415	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.414	debug	ADD NEW DATA (193 + NEW 16)
                            smartmeter.0	2018-06-23 08:26:15.397	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.396	debug	ADD NEW DATA (178 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.378	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.377	debug	ADD NEW DATA (163 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.363	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.362	debug	ADD NEW DATA (147 + NEW 16)
                            smartmeter.0	2018-06-23 08:26:15.346	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.345	debug	ADD NEW DATA (132 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.329	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.328	debug	ADD NEW DATA (117 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.314	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.313	debug	ADD NEW DATA (101 + NEW 16)
                            smartmeter.0	2018-06-23 08:26:15.301	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c1070100620afff
                            smartmeter.0	2018-06-23 08:26:15.300	debug	ADD NEW DATA (86 + NEW 15)
                            smartmeter.0	2018-06-23 08:26:15.288	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177010b06454d480104c56ee7c107010062" ->
                            smartmeter.0	2018-06-23 08:26:15.285	debug	ADD NEW DATA (70 + NEW 16)
                            smartmeter.0	2018-06-23 08:26:15.267	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae60076070016024d7eb7620062007263070177" -> null
                            smartmeter.0	2018-06-23 08:26:15.265	debug	ADD NEW DATA (56 + NEW 14)
                            smartmeter.0	2018-06-23 08:26:15.252	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb662006200726301017601010700160aad7f920b06454d480104c56ee7c10101636ae600760700" -> null
                            smartmeter.0	2018-06-23 08:26:15.252	debug	ADD NEW DATA (24 + NEW 32)
                            smartmeter.0	2018-06-23 08:26:15.252	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b0101010176070016024d7eb6620062007263" -> null
                            smartmeter.0	2018-06-23 08:26:15.250	debug	ADD NEW DATA (10 + NEW 14)
                            smartmeter.0	2018-06-23 08:26:15.206	debug	MATCH-RESULT MESSAGE: "006b1b1b1b1b01010101" -> null
                            smartmeter.0	2018-06-23 08:26:15.204	debug	ADD NEW DATA (2 + NEW 8)
                            smartmeter.0	2018-06-23 08:26:14.807	debug	SET MESSAGE TIMEOUT TIMER: 120000
                            smartmeter.0	2018-06-23 08:26:14.807	debug	MATCH-RESULT MESSAGE: "006b" -> null
                            smartmeter.0	2018-06-23 08:26:14.807	debug	ADD NEW DATA (0 + NEW 2)
                            smartmeter.0	2018-06-23 08:26:14.807	debug	SERIALPORT OPEN
                            smartmeter.0	2018-06-23 08:26:14.807	debug	CREATE SERIALPORT: 9600 8 1 none
                            smartmeter.0	2018-06-23 08:26:14.806	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"300","anotherQueryDelay":"1000","transportSerialPort":"/dev/lesevoltaik","transport
                            smartmeter.0	2018-06-23 08:26:14.804	info	starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v6.13.0
                            host.Asus-Buero	2018-06-23 08:26:12.654	info	object change system.adapter.smartmeter.0
                            javascript.0	2018-06-23 08:26:09.705	info	script.js.Scripte.Sonstige.Kombisensor: Auslöser Duration geändert
                            javascript.0	2018-06-23 08:26:09.704	info	script.js.Scripte.Sonstige.Kombisensor_-_Windrose: Auslöser Windrichtung
                            host.Asus-Buero	2018-06-23 08:26:08.101	info	object change system.adapter.smartmeter.0
                            javascript.0	2018-06-23 08:26:01.227	info	script.js.Scripte.Sonstige.Mähroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "stopped": false, "duration": 210551, "mode": 0, "battery": 100, "hours": 356}, "timer": {
                            javascript.0	2018-06-23 08:25:52.860	info	script.js.Scripte.Sonstige.Waschmaschine: Auslöser Waschmaschine
                            javascript.0	2018-06-23 08:24:48.471	info	script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
                            host.Asus-Buero	2018-06-23 08:24:11.170	info	object change system.adapter.smartmeter.0
                            host.Asus-Buero	2018-06-23 08:24:07.404	info	object change system.adapter.smartmeter.0
                            host.Asus-Buero	2018-06-23 08:24:06.401	info	object change system.adapter.smartmeter.1
                            javascript.0	2018-06-23 08:24:01.241	info	script.js.Scripte.Sonstige.Mähroboter: json = {"name": "Robo-Maeh", "id": "081603", "status": {"status": 17, "stopped": false, "duration": 210431, "mode": 0, "battery": 100, "hours": 356}, "timer": {
                            javascript.0	2018-06-23 08:23:51.333	info	script.js.Scripte.Sonstige.Waschmaschine: Auslöser Waschmaschine
                            host.Asus-Buero	2018-06-23 08:23:47.919	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                            iobroker	2018-06-23 08:23:47.736	info	exit 0
                            iobroker	2018-06-23 08:23:47.658	info	upload [0] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
                            iobroker	2018-06-23 08:23:47.601	info	upload [1] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
                            iobroker	2018-06-23 08:23:47.527	info	upload [2] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
                            iobroker	2018-06-23 08:23:47.461	info	upload [3] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
                            iobroker	2018-06-23 08:23:47.391	info	upload [4] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
                            iobroker	2018-06-23 08:23:47.316	info	upload [5] smartmeter.admin C:/ioBroker/node_modules/iobroker.smartmeter/admin/words.js words.js application/javascript
                            iobroker	2018-06-23 08:23:47.286	info	got C:/ioBroker/node_modules/iobroker.smartmeter/admin
                            iobroker	2018-06-23 08:23:39.359	info	WARN deprecated parser-readline@1.0.2: reanmed to @serialport/parser-readline
                            iobroker	2018-06-23 08:23:39.358	info	npm
                            iobroker	2018-06-23 08:23:39.356	info	WARN deprecated parser-cctalk@1.0.2: reanmed to @serialport/parser-cctalk
                            iobroker	2018-06-23 08:23:39.356	info	npm
                            iobroker	2018-06-23 08:23:39.345	info	WARN deprecated parser-regex@1.0.2: reanmed to @serialport/parser-regex
                            iobroker	2018-06-23 08:23:39.344	info	npm
                            iobroker	2018-06-23 08:23:39.333	info	WARN deprecated parser-ready@1.0.2: reanmed to @serialport/parser-ready
                            iobroker	2018-06-23 08:23:39.333	info	npm
                            iobroker	2018-06-23 08:23:39.319	info	npm WARN deprecated parser-delimiter@1.0.2: reanmed to @serialport/parser-delimiter
                            iobroker	2018-06-23 08:23:39.313	info	npm WARN deprecated parser-byte-length@1.0.2: renamed to @serialport/parser-byte-length
                            iobroker	2018-06-23 08:23:28.538	info	npm install https://github.com/Apollon77/ioBroker.smartmeter/tarball/master --production --save --prefix "C:/ioBroker" (System call)
                            iobroker	2018-06-23 08:23:25.744	info	install https://github.com/Apollon77/ioBroker.smartmeter/tarball/master
                            iobroker	2018-06-23 08:23:24.817	info	url "https://github.com/Apollon77/ioBroker.smartmeter/tarball/master" smartmeter
                            Bei Objekten keine Veränderung.
                            Keine Neuanlage von _
                            mfg
                              Bei dir steht er startet die 1.1.3 neu … nichts von der 1.2.1
                              Haben wir jetzt dich als zweiten mit dem Problem. Ich kapiers nicht.
                              Adapter stoppen. Und iobroker Upload smartmeter.
                              Steht dann die korrekte Versionsnummer beim starten drin?
                              • bahnuhr
                                cmd als admin ausgeführt, dann
                                C:\Windows\system32>cd\iobroker
                                C:\ioBroker>iobroker upload smartmeter
                                C:\ioBroker>node node_modules/iobroker.js-controller/iobroker.js upload smartmet
                                er
                                C:\ioBroker>
                                dann instanz wieder gestartet.
                                im log:
                                smartmeter.0	2018-06-23 08:43:57.938	debug	SERIALPORT CLOSE
                                smartmeter.0	2018-06-23 08:43:57.938	debug	SCHEDULE NEXT RUN IN 300s
                                smartmeter.0	2018-06-23 08:43:57.937	debug	RESUME READING SERIALPORT
                                smartmeter.0	2018-06-23 08:43:57.937	debug	SET MESSAGE TIMEOUT TIMER: 120000
                                smartmeter.0	2018-06-23 08:43:57.937	info	Received 7 values, 7 updated
                                smartmeter.0	2018-06-23 08:43:57.937	debug	Set State 129-129:199_130_5*255.value = 93292772e43fde6481665b70152078535915a6280c7c672f6aa6b0bfd269c0465581d202d4aefe59beb54ea6527100f8
                                smartmeter.0	2018-06-23 08:43:57.937	debug	Set State 129-129:199_130_5*255.rawvalue = undefined
                                smartmeter.0	2018-06-23 08:43:57.937	debug	Create State 129-129:199_130_5*255.value
                                smartmeter.0	2018-06-23 08:43:57.937	debug	Create Channel 129-129:199_130_5*255 with name Forename/Public Key
                                smartmeter.0	2018-06-23 08:43:57.937	debug	129-129:199.130.5*255: Forename/Public Key = 93292772e43fde6481665b70152078535915a6280c7c672f6aa6b0bfd269c0465581d202d4aefe59beb54ea6527100f8
                                smartmeter.0	2018-06-23 08:43:57.937	debug	Set State 1-0:16_7_0*255.value = -1952.4
                                smartmeter.0	2018-06-23 08:43:57.936	debug	Set State 1-0:16_7_0*255.rawvalue = undefined
                                smartmeter.0	2018-06-23 08:43:57.936	debug	Create State 1-0:16_7_0*255.value
                                smartmeter.0	2018-06-23 08:43:57.936	debug	Create Channel 1-0:16_7_0*255 with name Momentanwert Gesamtwirkleistung (Total)
                                smartmeter.0	2018-06-23 08:43:57.936	debug	1-0:16.7.0*255: Momentanwert Gesamtwirkleistung (Total) = -1952.4 W
                                smartmeter.0	2018-06-23 08:43:57.936	debug	Set State 1-0:2_8_2*255.value = 28508.6819
                                smartmeter.0	2018-06-23 08:43:57.936	debug	Set State 1-0:2_8_2*255.rawvalue = undefined
                                smartmeter.0	2018-06-23 08:43:57.936	debug	Create State 1-0:2_8_2*255.value
                                smartmeter.0	2018-06-23 08:43:57.936	debug	Create Channel 1-0:2_8_2*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (T2)
                                smartmeter.0	2018-06-23 08:43:57.936	debug	1-0:2.8.2*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T2) = 28508.6819 kWh
                                smartmeter.0	2018-06-23 08:43:57.935	debug	Set State 1-0:2_8_1*255.value = 0
                                smartmeter.0	2018-06-23 08:43:57.935	debug	Set State 1-0:2_8_1*255.rawvalue = undefined
                                smartmeter.0	2018-06-23 08:43:57.935	debug	Create State 1-0:2_8_1*255.value
                                smartmeter.0	2018-06-23 08:43:57.935	debug	Create Channel 1-0:2_8_1*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (T1)
                                smartmeter.0	2018-06-23 08:43:57.935	debug	1-0:2.8.1*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (T1) = 0 kWh
                                smartmeter.0	2018-06-23 08:43:57.935	debug	Set State 1-0:2_8_0*255.value = 28508.6819
                                smartmeter.0	2018-06-23 08:43:57.935	debug	Set State 1-0:2_8_0*255.rawvalue = undefined
                                smartmeter.0	2018-06-23 08:43:57.935	debug	Create State 1-0:2_8_0*255.value
                                smartmeter.0	2018-06-23 08:43:57.934	debug	Create Channel 1-0:2_8_0*255 with name Zählerstand 1 Summe Wirkarbeit Abgabe - (Total)
                                smartmeter.0	2018-06-23 08:43:57.934	debug	1-0:2.8.0*255: Zählerstand 1 Summe Wirkarbeit Abgabe - (Total) = 28508.6819 kWh
                                smartmeter.0	2018-06-23 08:43:57.934	debug	Set State 1-0:0_0_9*255.value = 06454d480104c56ee7c1
                                smartmeter.0	2018-06-23 08:43:57.934	debug	Set State 1-0:0_0_9*255.rawvalue = undefined
                                smartmeter.0	2018-06-23 08:43:57.934	debug	Create State 1-0:0_0_9*255.value
                                smartmeter.0	2018-06-23 08:43:57.934	debug	Create Channel 1-0:0_0_9*255 with name Device ID
                                smartmeter.0	2018-06-23 08:43:57.934	debug	1-0:0.0.9*255: Device ID = 06454d480104c56ee7c1
                                smartmeter.0	2018-06-23 08:43:57.934	debug	Set State 129-129:199_130_3*255.value = EMH
                                smartmeter.0	2018-06-23 08:43:57.934	debug	Set State 129-129:199_130_3*255.rawvalue = undefined
                                smartmeter.0	2018-06-23 08:43:57.933	debug	Create State 129-129:199_130_3*255.value
                                smartmeter.0	2018-06-23 08:43:57.933	debug	Create Channel 129-129:199_130_3*255 with name Manufacturer ID
                                smartmeter.0	2018-06-23 08:43:57.933	debug	129-129:199.130.3*255: Manufacturer ID = EMH
                                smartmeter.0	2018-06-23 08:43:57.933	debug	STORE DATA
                                smartmeter.0	2018-06-23 08:43:57.933	debug	SML MESSAGE: START SML-File START SmlMessage Transaction-ID: M�� (0016024d8e8e) Group-No: 0 Abort On Error: 0 Message-Body: SmlPublicOpenResponse Codepage: undefined Client-ID: und
                                smartmeter.0	2018-06-23 08:43:57.933	debug	MSG IDX 4
                                smartmeter.0	2018-06-23 08:43:57.933	debug	PAUSE READING SERIALPORT TO HANDLE MESSAGE
                                smartmeter.0	2018-06-23 08:43:57.932	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.931	debug	ADD NEW DATA (319 + NEW 15)
                                smartmeter.0	2018-06-23 08:43:57.815	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.814	debug	ADD NEW DATA (303 + NEW 16)
                                smartmeter.0	2018-06-23 08:43:57.799	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.798	debug	ADD NEW DATA (289 + NEW 14)
                                smartmeter.0	2018-06-23 08:43:57.784	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.783	debug	ADD NEW DATA (273 + NEW 16)
                                smartmeter.0	2018-06-23 08:43:57.766	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.765	debug	ADD NEW DATA (257 + NEW 16)
                                smartmeter.0	2018-06-23 08:43:57.749	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.748	debug	ADD NEW DATA (242 + NEW 15)
                                smartmeter.0	2018-06-23 08:43:57.733	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.732	debug	ADD NEW DATA (227 + NEW 15)
                                smartmeter.0	2018-06-23 08:43:57.721	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.720	debug	ADD NEW DATA (211 + NEW 16)
                                smartmeter.0	2018-06-23 08:43:57.702	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.700	debug	ADD NEW DATA (196 + NEW 15)
                                smartmeter.0	2018-06-23 08:43:57.687	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.686	debug	ADD NEW DATA (181 + NEW 15)
                                smartmeter.0	2018-06-23 08:43:57.670	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.669	debug	ADD NEW DATA (165 + NEW 16)
                                smartmeter.0	2018-06-23 08:43:57.657	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.656	debug	ADD NEW DATA (150 + NEW 15)
                                smartmeter.0	2018-06-23 08:43:57.652	debug	system.adapter.admin.0: logging true
                                smartmeter.0	2018-06-23 08:43:57.652	debug	MATCH-RESULT MESSAGE: "00e41b1b1b1b0101010176070016024d8e8e62006200726301017601010700160aad84da0b06454d480104c56ee7c1010163b7310076070016024d8e8f620062007263070177010b06454d480104c56ee7c1070100620afff
                                smartmeter.0	2018-06-23 08:43:57.649	debug	ADD NEW DATA (135 + NEW 15)
                                host.Asus-Buero	2018-06-23 08:43:51.968	info	object change system.adapter.smartmeter.0
                                das steht nix mehr von start !
                                • bahnuhr
                                  @bahnuhr:
                                  1.2.1 installiert
                                  log:
                                  mfg `
                                  was mir hier aufgefallen ist; dort steht:
                                  Das Verzeichnis stimmt dort auch nicht !
                                  Bin ja auf C:\….
                                  mfg
                                    Stimmt bei anderen Adapter. Beim Start die pfadangabe?
                                    Also irgendwie scheint er ne andere Version zu laden. Such mal wo bei dir alles eine smartmeter.js liegt.
                                    • bahnuhr
                                      Nur an einem Ort:
                                        Sich mal Rechnerweit nicht im ioBroker Verzeichnis.
                                        Gesendet vom Handy …
                                        • bahnuhr
                                          So ich hab die Lösung.
                                          Folgende Hardware hab ich:
                                          win7 Rechner mit iobroker
                                          Dies ist der Hauptrechner wo alles läuft.
                                          Daneben Raspi als slave
                                          Hier läuft smartmeter und 2 Leseköpfe
                                          Auf dem win7 Rechner hab ich smartmeter upgedatet
                                          Dann hab ich Extra eine admin Instanz installiert, also
                                          admin.1 und server der raspi
                                          Somit konnte ich den raspi mit seiner eigenen ip aufrufen.
                                          Und hier war noch die alte vers. installiert.
                                          Also hier den adapter upgedatet und siehe da:
                                          Die anderen (neuen) Objekte werden angezeigt.
                                          Fazit:
                                          Objekte (neue) sind nun da.
                                          Dachte aber eigentlich, dass ich den Umweg mit einem extra admin nicht notwendig wäre.
                                          mfg
                                            @bahnuhr:
                                            Somit konnte ich den raspi mit seiner eigenen ip aufrufen. `
                                            Das ist ein absolutes nogo!
                                            Die Verwaltung eines Slaves erfolgt immer über den Admin des Masters.
                                            Allerdings darf auf dem Slave NICHTS außer dem admin installiert sein, wenn er zum Slave gemacht wird.
                                            Alle Instanzen sind erst anschließend vom Admin des MAsters auf dem Slave zu installieren.
                                            Rainer
                                            2032
