    4. [Aufruf] G-Homa Adapter testen
      Rotzbubi last edited by
      Hallo AlCalzone,
      mache ich heute Abend, wenn ich wieder daheim bin.
      Liebe Grüße!
      Rainer
        Hallo AlCalzone,
        anbei die Logs. Vielleicht ist da ja etwas dabei.
        LG Rainer
        ! undefined2018-06-20 18:19:03.843 - info: host.raspberrypi object change system.adapter.g-homa.0
        ! 2018-06-20 18:19:03.850 - info: host.raspberrypi stopInstance system.adapter.g-homa.0
        ! 2018-06-20 18:19:03.851 - info: host.raspberrypi stopInstance system.adapter.g-homa.0 killing pid 6635
        ! 2018-06-20 18:19:03.873 - info: g-homa.0 terminating
        ! 2018-06-20 18:19:03.912 - info: host.raspberrypi instance system.adapter.g-homa.0 terminated with code 0 (OK)
        ! 2018-06-20 18:19:06.960 - info: host.raspberrypi object change system.adapter.g-homa.0
        ! 2018-06-20 18:19:06.992 - info: host.raspberrypi instance system.adapter.g-homa.0 started with pid 6691
        ! 2018-06-20 18:19:08.378 - debug: g-homa.0 objectDB connected
        ! 2018-06-20 18:19:08.450 - debug: g-homa.0 statesDB connected
        ! 2018-06-20 18:19:08.506 - info: g-homa.0 starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.g-homa, node: v6.14.2
        ! 2018-06-20 18:19:08.577 - info: g-homa.0 enumerating known plugs…
        ! 2018-06-20 18:19:08.647 - info: g-homa.0 found plug with id 4fb956 (online)
        ! 2018-06-20 18:19:08.649 - info: g-homa.0 starting server...
        ! 2018-06-20 18:19:08.672 - info: g-homa.0 server started on port 50000
        ! 2018-06-20 18:19:08.683 - info: g-homa.0 searching plugs
        ! 2018-06-20 18:19:43.100 - info: host.raspberrypi object change system.adapter.g-homa.0
        ! 2018-06-20 18:19:43.102 - info: host.raspberrypi stopInstance system.adapter.g-homa.0
        ! 2018-06-20 18:19:43.103 - info: host.raspberrypi stopInstance system.adapter.g-homa.0 killing pid 6691
        ! 2018-06-20 18:19:43.124 - info: g-homa.0 terminating
        ! 2018-06-20 18:19:43.171 - info: host.raspberrypi instance system.adapter.g-homa.0 terminated with code 0 (OK)
        ! 2018-06-20 18:19:45.642 - info: host.raspberrypi instance system.adapter.g-homa.0 started with pid 6718
        ! 2018-06-20 18:19:46.968 - debug: g-homa.0 objectDB connected
        ! 2018-06-20 18:19:47.032 - debug: g-homa.0 statesDB connected
        ! 2018-06-20 18:19:47.150 - info: g-homa.0 starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.g-homa, node: v6.14.2
        ! 2018-06-20 18:19:47.255 - info: g-homa.0 enumerating known plugs...
        ! 2018-06-20 18:19:47.336 - info: g-homa.0 found plug with id 4fb956 (online)
        ! 2018-06-20 18:19:47.338 - info: g-homa.0 starting server...
        ! 2018-06-20 18:19:47.360 - info: g-homa.0 server started on port 50000
        ! 2018-06-20 18:19:47.372 - info: g-homa.0 searching plugs
        • AlCalzone
          Hmm ich dachte, ich hätte mehr Logs eingebaut. Da muss ich nochmal ran. Melde mich, wenn du nochmal testen darfst.
          • AlCalzone
            @Rotzbubi:
            anbei die Logs. Vielleicht ist da ja etwas dabei. `
            Kannst du bitte die Version von Github installieren und mir damit nochmal einen Logauszug erstellen?
              Guten Abend!
              Habe jetzt die Objekte gelöscht und den Adapter gelöscht. Die erneute Instalation über GitHub wird zwar bei meinen Adaptern angezeigt, taucht jedoch nicht mehr bei den Instanzen und Objekten auf…
              Jemand einen Tipp?
              LG Rainer
              • Dutchman
                Bei Installationen per github danach manuell die Instanz erstellen (bzw updaten).
                ( + Zeichen )
                  Hallo Dutchman,
                  das hat geholfen. Adapter taucht jetzt auch wieder bei den Instanzen auf. Vielen Dank!
                  @ALCalzone
                  Jetzt zeigen die Logs auch den Verbrauch an.
                  ! g-homa.0 2018-06-23 09:06:32.035 error already running
                  ! g-homa.0 2018-06-23 09:06:32.018 debug statesDB connected
                  ! g-homa.0 2018-06-23 09:06:31.951 debug objectDB connected
                  ! g-homa.0 2018-06-23 09:06:03.621 info Added plug with ID 4fb956
                  ! g-homa.0 2018-06-23 09:06:01.937 debug Power factor: 0.95
                  ! g-homa.0 2018-06-23 09:06:01.937 debug Power: 26.6 W
                  ! g-homa.0 2018-06-23 09:06:01.936 debug Current: 0.12 A
                  ! g-homa.0 2018-06-23 09:06:01.935 debug voltage: 232.16 V
                  ! g-homa.0 2018-06-23 09:06:01.934 debug switched from: local
                  ! g-homa.0 2018-06-23 09:06:01.934 debug state: on
                  ! g-homa.0 2018-06-23 09:06:01.934 debug Got updated info for Plug 4fb956:
                  ! g-homa.0 2018-06-23 09:06:01.730 debug Power factor: 0.95
                  ! g-homa.0 2018-06-23 09:06:01.729 debug Power: 26.6 W
                  ! g-homa.0 2018-06-23 09:06:01.729 debug Current: 0.12 A
                  ! g-homa.0 2018-06-23 09:06:01.728 debug voltage: 232.16 V
                  ! g-homa.0 2018-06-23 09:06:01.728 debug switched from: local
                  ! g-homa.0 2018-06-23 09:06:01.728 debug state: on
                  ! g-homa.0 2018-06-23 09:06:01.728 debug Got updated info for Plug 4fb956:
                  ! g-homa.0 2018-06-23 09:06:01.323 debug Power factor: 0.95
                  ! g-homa.0 2018-06-23 09:06:01.323 debug Power: 26.6 W
                  ! g-homa.0 2018-06-23 09:06:01.323 debug Current: 0.12 A
                  ! g-homa.0 2018-06-23 09:06:01.322 debug voltage: 232.16 V
                  ! g-homa.0 2018-06-23 09:06:01.321 debug switched from: local
                  ! g-homa.0 2018-06-23 09:06:01.321 debug state: on
                  ! g-homa.0 2018-06-23 09:06:01.321 debug Got updated info for Plug 4fb956:
                  ! g-homa.0 2018-06-23 09:06:01.017 debug Power: 26.6 W
                  ! g-homa.0 2018-06-23 09:06:01.017 debug Current: 0.12 A
                  ! g-homa.0 2018-06-23 09:06:01.016 debug voltage: 232.16 V
                  ! g-homa.0 2018-06-23 09:06:01.016 debug switched from: local
                  ! g-homa.0 2018-06-23 09:06:01.016 debug state: on
                  ! g-homa.0 2018-06-23 09:06:01.016 debug Got updated info for Plug 4fb956:
                  ! g-homa.0 2018-06-23 09:06:00.807 debug Power: 26.6 W
                  ! g-homa.0 2018-06-23 09:06:00.806 debug Current: 0.12 A
                  ! g-homa.0 2018-06-23 09:06:00.805 debug voltage: 232.16 V
                  ! g-homa.0 2018-06-23 09:06:00.803 debug switched from: local
                  ! g-homa.0 2018-06-23 09:06:00.803 debug state: on
                  ! g-homa.0 2018-06-23 09:06:00.803 debug Got updated info for Plug 4fb956:
                  ! g-homa.0 2018-06-23 09:06:00.512 debug Current: 0.12 A
                  ! g-homa.0 2018-06-23 09:06:00.511 debug voltage: 232.16 V
                  ! g-homa.0 2018-06-23 09:06:00.510 debug switched from: local
                  ! g-homa.0 2018-06-23 09:06:00.510 debug state: on
                  ! g-homa.0 2018-06-23 09:06:00.510 debug Got updated info for Plug 4fb956:
                  ! g-homa.0 2018-06-23 09:06:00.214 debug voltage: 232.16 V
                  ! g-homa.0 2018-06-23 09:06:00.213 debug switched from: local
                  ! g-homa.0 2018-06-23 09:06:00.213 debug state: on
                  ! g-homa.0 2018-06-23 09:06:00.213 debug Got updated info for Plug 4fb956:
                  Muss ich jetzt die Datenpunkte dazu manuell erstellen?
                  LG und ein schönes Wochenende!
                  Rainer
                  • AlCalzone
                    @Rotzbubi:
                    Muss ich jetzt die Datenpunkte dazu manuell erstellen? `
                    Werden die jetzt nicht mehr erstellt? Siehst du sie auch nicht wenn du die Objekte Liste aktualisierst? Dann hab ich vermutlich mit dem letzten fix was kaputt gemacht.
                    Gesendet von unterwegs
                      Hallo Alcalzone,
                      Datenpunke wurden nicht erstellt. Sie tauchen zwar im Log auf - Aber auch nach mehrmaliger Aktualisierung sind keine Datenpunkte zu finden.
                      LG Rainer
                      • AlCalzone
                        Mit meiner Steckdose kann ich das nicht nachvollziehen. Gerade mal alle Objekte gelöscht und sie werden bei Aktualisierung sofort wieder angelegt.
                        Das ist allerdings auch keine mit Energiemessung. Betrifft das bei dir alle Objekte oder nur die für Energiemessung?
                          es betrifft tatsachlich nur die Datenpunkte für die Energiemessung, welche nicht da sind.
                          LG Rainer
                          • AlCalzone
                            Dann muss ich dich leider bitten, nochmal von Github zu aktualisieren, Instanz neustarten und nochmal einen Debug-Log erzeugen.
                              Hallo Alcazone,
                              anbei der neue Log.
                              ! g-homa.0 2018-06-27 20:57:27.117 info Added plug with ID 4fb956
                              ! g-homa.0 2018-06-27 20:57:25.524 debug powerFactor in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:25.523 debug power in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:25.522 debug current in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:25.521 debug voltage in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:25.486 debug extendPlug: type = undefined, energyMeasurement != null: true
                              ! g-homa.0 2018-06-27 20:57:25.482 debug Power factor: 0.95
                              ! g-homa.0 2018-06-27 20:57:25.482 debug Power: 26.53 W
                              ! g-homa.0 2018-06-27 20:57:25.481 debug Current: 0.12 A
                              ! g-homa.0 2018-06-27 20:57:25.480 debug Voltage: 232.32 V
                              ! g-homa.0 2018-06-27 20:57:25.478 debug type: undefined
                              ! g-homa.0 2018-06-27 20:57:25.478 debug switched from: local
                              ! g-homa.0 2018-06-27 20:57:25.478 debug state: on
                              ! g-homa.0 2018-06-27 20:57:25.478 debug Got updated info for Plug 4fb956:
                              ! g-homa.0 2018-06-27 20:57:25.301 debug powerFactor in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:25.300 debug power in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:25.299 debug current in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:25.297 debug voltage in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:25.281 debug extendPlug: type = undefined, energyMeasurement != null: true
                              ! g-homa.0 2018-06-27 20:57:25.273 debug Power factor: 0.95
                              ! g-homa.0 2018-06-27 20:57:25.272 debug Power: 26.53 W
                              ! g-homa.0 2018-06-27 20:57:25.272 debug Current: 0.12 A
                              ! g-homa.0 2018-06-27 20:57:25.271 debug Voltage: 232.32 V
                              ! g-homa.0 2018-06-27 20:57:25.271 debug type: undefined
                              ! g-homa.0 2018-06-27 20:57:25.271 debug switched from: local
                              ! g-homa.0 2018-06-27 20:57:25.271 debug state: on
                              ! g-homa.0 2018-06-27 20:57:25.271 debug Got updated info for Plug 4fb956:
                              ! g-homa.0 2018-06-27 20:57:24.899 debug powerFactor in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.896 debug power in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.895 debug current in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.892 debug voltage in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.876 debug extendPlug: type = undefined, energyMeasurement != null: true
                              ! g-homa.0 2018-06-27 20:57:24.874 debug Power factor: 0.95
                              ! g-homa.0 2018-06-27 20:57:24.874 debug Power: 26.53 W
                              ! g-homa.0 2018-06-27 20:57:24.874 debug Current: 0.12 A
                              ! g-homa.0 2018-06-27 20:57:24.873 debug Voltage: 232.32 V
                              ! g-homa.0 2018-06-27 20:57:24.872 debug type: undefined
                              ! g-homa.0 2018-06-27 20:57:24.872 debug switched from: local
                              ! g-homa.0 2018-06-27 20:57:24.872 debug state: on
                              ! g-homa.0 2018-06-27 20:57:24.872 debug Got updated info for Plug 4fb956:
                              ! g-homa.0 2018-06-27 20:57:24.627 debug powerFactor in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:24.627 debug power in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.626 debug current in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.623 debug voltage in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.597 debug extendPlug: type = undefined, energyMeasurement != null: true
                              ! g-homa.0 2018-06-27 20:57:24.591 debug Power: 26.53 W
                              ! g-homa.0 2018-06-27 20:57:24.591 debug Current: 0.12 A
                              ! g-homa.0 2018-06-27 20:57:24.590 debug Voltage: 232.32 V
                              ! g-homa.0 2018-06-27 20:57:24.589 debug type: undefined
                              ! g-homa.0 2018-06-27 20:57:24.589 debug switched from: local
                              ! g-homa.0 2018-06-27 20:57:24.589 debug state: on
                              ! g-homa.0 2018-06-27 20:57:24.589 debug Got updated info for Plug 4fb956:
                              ! g-homa.0 2018-06-27 20:57:24.408 debug powerFactor in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:24.407 debug power in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.406 debug current in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.404 debug voltage in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.382 debug extendPlug: type = undefined, energyMeasurement != null: true
                              ! g-homa.0 2018-06-27 20:57:24.379 debug Power: 26.53 W
                              ! g-homa.0 2018-06-27 20:57:24.378 debug Current: 0.12 A
                              ! g-homa.0 2018-06-27 20:57:24.378 debug Voltage: 232.32 V
                              ! g-homa.0 2018-06-27 20:57:24.377 debug type: undefined
                              ! g-homa.0 2018-06-27 20:57:24.377 debug switched from: local
                              ! g-homa.0 2018-06-27 20:57:24.377 debug state: on
                              ! g-homa.0 2018-06-27 20:57:24.377 debug Got updated info for Plug 4fb956:
                              ! g-homa.0 2018-06-27 20:57:24.096 debug powerFactor in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:24.095 debug power in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:24.095 debug current in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.094 debug voltage in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:24.080 debug extendPlug: type = undefined, energyMeasurement != null: true
                              ! g-homa.0 2018-06-27 20:57:24.077 debug Current: 0.12 A
                              ! g-homa.0 2018-06-27 20:57:24.077 debug Voltage: 232.32 V
                              ! g-homa.0 2018-06-27 20:57:24.076 debug type: undefined
                              ! g-homa.0 2018-06-27 20:57:24.076 debug switched from: local
                              ! g-homa.0 2018-06-27 20:57:24.076 debug state: on
                              ! g-homa.0 2018-06-27 20:57:24.076 debug Got updated info for Plug 4fb956:
                              ! g-homa.0 2018-06-27 20:57:23.843 debug powerFactor in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:23.842 debug power in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:23.842 debug current in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:23.838 debug voltage in plug.energyMeasurement => true
                              ! g-homa.0 2018-06-27 20:57:23.800 debug extendPlug: type = undefined, energyMeasurement != null: true
                              ! g-homa.0 2018-06-27 20:57:23.793 debug Voltage: 232.32 V
                              ! g-homa.0 2018-06-27 20:57:23.791 debug type: undefined
                              ! g-homa.0 2018-06-27 20:57:23.791 debug switched from: local
                              ! g-homa.0 2018-06-27 20:57:23.791 debug state: on
                              ! g-homa.0 2018-06-27 20:57:23.791 debug Got updated info for Plug 4fb956:
                              ! g-homa.0 2018-06-27 20:57:19.797 debug powerFactor in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:19.797 debug power in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:19.796 debug current in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:19.795 debug voltage in plug.energyMeasurement => false
                              ! g-homa.0 2018-06-27 20:57:19.502 debug extendPlug: type = undefined, energyMeasurement != null: true
                              ! g-homa.0 2018-06-27 20:57:19.476 debug type: undefined
                              ! g-homa.0 2018-06-27 20:57:19.476 debug switched from: local
                              ! g-homa.0 2018-06-27 20:57:19.476 debug state: on
                              ! g-homa.0 2018-06-27 20:57:19.476 debug Got updated info for Plug 4fb956:
                              ! g-homa.0 2018-06-27 20:57:19.473 info Added plug with ID 4fb956
                              ! g-homa.0 2018-06-27 20:57:18.619 debug sendTo "getIPAddresses" to system.adapter.admin.0 from system.adapter.g-homa.0
                              ! g-homa.0 2018-06-27 20:57:16.359 info searching plugs
                              ! g-homa.0 2018-06-27 20:57:16.346 info server started on port 50000
                              ! g-homa.0 2018-06-27 20:57:16.323 info starting server…
                              ! g-homa.0 2018-06-27 20:57:16.319 info found plug with id 4fb956 (offline)
                              ! g-homa.0 2018-06-27 20:57:16.209 info enumerating known plugs...
                              ! g-homa.0 2018-06-27 20:57:16.127 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.g-homa, node: v6.14.2
                              ! g-homa.0 2018-06-27 20:57:16.057 debug statesDB connected
                              ! g-homa.0 2018-06-27 20:57:15.982 debug objectDB connected
                              ! g-homa.0 2018-06-27 20:56:29.132 info terminating
                              ! g-homa.0 2018-06-27 20:53:20.643 info Added plug with ID 4fb956
                              Danke für Deinen Einsatz 🙂
                              Rainer
                              • AlCalzone
                                Danke, das war der entscheidende Log. Anscheinend wird von der g-homa Library nicht der korrekte Stecker-Typ übergeben.
                                Ich kann einen einfachen Workaround in den Adapter einbauen, würde aber bevorzugt die Library selbst fixen. Wie dringend ist es bei dir, bzw. wie groß ist deine weitere Testbereitschaft? Im Optimalfall reicht ein weiterer kurzer Test.
                                • AlCalzone
                                  Ok kleines Update:
                                  Ich release später die v0.3.2. Die dann bitte installieren und schauen, ob alles funktioniert.
                                  Außerdem bitte nochmal einen kleinen Testlauf per Konsole:
                                  - Adapter stoppen
                                  cd /opt/iobroker/node_modules/iobroker.g-homa
                                  DEBUG=g-homa node main.js --force --logs
                                  und die Ausgabe hier posten. Da sollte dann irgendwas stehen mit
                                  unknown plug type detected. triggercode is ...
                                  the full payload was: ...
                                    ich habe keine Zeitnot und freue mich, wenn du das Projekt weiterbringst.
                                    LG Rainer
                                      schittl last edited by
                                      Hallo AlCalzone,
                                      ich habe jetzt für 4 Steckdosen folgendes Skript zum Energieverbrauch am laufen. Dadurch wird iobroker dermassen belastet, dass ich es wieder deaktivieren muss. Kann das eventuell am Adapter liegen oder ist das normal und sollte so nicht gemacht werden?
                                      var logging = false;
                                      var instanz = 'javascript.0' + '.';
                                      var pfad = 'Strom.';
                                      ! var idGHomaPower1 = 'g-homa.0.XXXXXX.power',
                                      idGHomaEnergie1 = pfad + 'XXXXXX.ENERGY_COUNTER',
                                      idGHomaPower2 = 'g-homa.0.YYYYYY.power',
                                      idGHomaEnergie2 = pfad + 'YYYYYY.ENERGY_COUNTER',
                                      idGHomaPower3 = 'g-homa.0.ZZZZZZ.power',
                                      idGHomaEnergie3 = pfad + 'ZZZZZZ.ENERGY_COUNTER',
                                      idGHomaPower4 = 'g-homa.0.WWWWWW.power',
                                      idGHomaEnergie4 = pfad + 'WWWWWW.ENERGY_COUNTER';
                                      ! createState(idGHomaEnergie1, 0, {name: 'Energie Counter XXXXXX', type: 'number', unit:'Wh'});
                                      createState(idGHomaEnergie2, 0, {name: 'Energie Counter YYYYYY', type: 'number', unit:'Wh'});
                                      createState(idGHomaEnergie3, 0, {name: 'Energie Counter ZZZZZZ', type: 'number', unit:'Wh'});
                                      createState(idGHomaEnergie4, 0, {name: 'Energie Counter WWWWWW', type: 'number', unit:'Wh'});
                                      ! on({id:idGHomaPower1, change:'any'}, function(obj) {
                                      var Verbrauch = getState(idGHomaEnergie1).val;
                                      Verbrauch += (0.5 * (obj.state.val + obj.oldState.val) * (obj.state.ts - obj.oldState.ts)) / 3600000;
                                      setState(idGHomaEnergie1, Verbrauch);
                                      ! on({id:idGHomaPower2, change:'any'}, function(obj) {
                                      var Verbrauch = getState(idGHomaEnergie2).val;
                                      setState(idGHomaEnergie2, Verbrauch);
                                      ! on({id:idGHomaPower3, change:'any'}, function(obj) {
                                      var Verbrauch = getState(idGHomaEnergie3).val;
                                      setState(idGHomaEnergie3, Verbrauch);
                                      ! on({id:idGHomaPower4, change:'any'}, function(obj) {
                                      var Verbrauch = getState(idGHomaPower4).val;
                                      setState(idGHomaPower4, Verbrauch);
                                      Zusatzinfo:
                                      An 2 solcher Steckdosen hängt kein Verbraucher also sollten diese ja nicht weiter belastet werden…
                                      Danke und vg
                                      Falk
                                      • AlCalzone
                                        @schittl:
                                        Dadurch wird iobroker dermassen belastet, dass ich es wieder deaktivieren muss. `
                                        Das Skript sieht auf den ersten Blick nicht weiter wild aus. Kannst du versuchen, herauszufinden, wie oft die Trigger aufgerufen werden? Oder triggerst du an anderer Stelle auf die berechnete Energie und erzeugst dir damit möglicherweise die Last?
                                          Wo finde ich heraus wie oft die Trigger aufgerufen wurden?
                                          Ich mache vorerst nix mit den Werten. Was noch ist das die 4 Werte POWER noch protokolliert werden per SQL.
                                          Es ist sehr schwierig zu analysieren, da nach einer gewissen Zeit iobroker nicht mehr reagiert. Habe daher das Skript erstmal deaktiviert. Kann man das im Nachhinein noch herausfinden wie oft es getriggert wurde?
                                          • AlCalzone
                                            Ich fürchte nachträglich geht das nicht. Mein Vorschlag wäre in den Trigger je eine Logausgabe zu integrieren und das Skript kurz laufen zu lassen.
                                            31.7k
                                            79.8k
                                            177
                                            29830
