    4. [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testen
    • Dutchman
      @Alex1808:
      P.S. Habe mit Dev. vom homebridge-iobroker gesprochen wird eventuell ein Fortsetzung geben 🙂 `
      Interesting! Was genau?
      • Alex1808
        Alex1808 last edited by
        @Dutchman:
        Interesting! Was genau? `
        Native Verbindung zwischen iobroker und Homebridge (ohne yahka adapter)
        "platforms": [
                    "platform" : "homebridge-iobroker.iobroker",
                    "name" : "iobroker",
                    "host": "http://localhost:8084",
                    "filter": "*",
                    "switches": [
                        "adapter.0.object_1",
                        "adapter.0.object_2",
                        "adapter.0.object_3",
        https://github.com/Haba1234/homebridge-iobroker
          rudiraz last edited by
          mich interessiert der Adapter sehr.
          Leider bekomme ich beim Start folgende Meldung:
          ` > ham.0 2018-06-26 10:48:38.034 info terminating
          ham.0 2018-06-26 10:48:37.946 warn Exception: TypeError: Cannot read property 'indexOf' of undefined
          ham.0 2018-06-26 10:48:37.938 info cleaned everything up…
          ham.0 2018-06-26 10:48:37.936 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          ham.0 2018-06-26 10:48:37.936 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          ham.0 2018-06-26 10:48:37.936 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2249:25)
          ham.0 2018-06-26 10:48:37.936 error at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:27)
          ham.0 2018-06-26 10:48:37.936 error at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:229:35)
          ham.0 2018-06-26 10:48:37.936 error at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
          ham.0 2018-06-26 10:48:37.936 error at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:190:17)
          ham.0 2018-06-26 10:48:37.936 error at Server.run (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:85:36)
          ham.0 2018-06-26 10:48:37.936 error at Server._loadPlatforms (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:314:45)
          ham.0 2018-06-26 10:48:37.936 error at API.platform (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/api.js:108:11)
          ham.0 2018-06-26 10:48:37.936 error TypeError: Cannot read property 'indexOf' of undefined
          ham.0 2018-06-26 10:48:37.936 error uncaught exception: Cannot read property 'indexOf' of undefined</anonymous> `
          Nodejs 6 ist installiert
          Woran kann das liegen?
          • Dutchman
            Zeig Mal deine config
              Plugin erstmal nur zum Test drin:
              • Dutchman
                Nimm Mal {} bij Platforms Weck wenn nichts eingefüllt reicht []
                  Ahh ok, das war der Fehler.
                  Dann kann ich mal testen jetzt 🙂
                  Danke und Grüße
                  • Meistertr
                    wollte es auch gerade testen leider ohne erfolg, er kann die config.json nicht finden.
                    host.devbroker	2018-06-26 21:59:40.320	info	Restart adapter system.adapter.ham.0 because enabled
                    host.devbroker	2018-06-26 21:59:40.320	error	instance system.adapter.ham.0 terminated with code 0 (OK)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: path: '/opt/iobroker/iobroker-data/ham_0/config.json' }
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: syscall: 'open',
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: code: 'ENOENT',
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: errno: -2,
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:188:19)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at new Server (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:57:24)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Server._loadPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:139:22)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Array.forEach (<anonymous>)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Server. <anonymous>(/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:165:14)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Plugin.module.exports [as initializer] (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:10:9)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at isConfig (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:24:32)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.fs.readFileSync (fs.js:551:33)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.fs.openSync (fs.js:646:18)
                    Caught	2018-06-26 21:59:40.320	error	by controller[1]: { Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
                    Caught	2018-06-26 21:59:40.319	error	by controller[0]: [2018-6-26 21:59:40] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                    ham.0	2018-06-26 21:59:40.314	warn	Exception: Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
                    ham.0	2018-06-26 21:59:40.314	info	cleaned everything up...
                    ham.0	2018-06-26 21:59:40.314	error	at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
                    ham.0	2018-06-26 21:59:40.314	error	at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:188:19)
                    ham.0	2018-06-26 21:59:40.314	error	at new Server (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:57:24)
                    ham.0	2018-06-26 21:59:40.314	error	at Server._loadPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:139:22)
                    ham.0	2018-06-26 21:59:40.314	error	at Array.forEach (<anonymous>)
                    ham.0	2018-06-26 21:59:40.314	error	at Server. <anonymous>(/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:165:14)
                    ham.0	2018-06-26 21:59:40.314	error	at Plugin.module.exports [as initializer] (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:10:9)
                    ham.0	2018-06-26 21:59:40.314	error	at isConfig (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:24:32)
                    ham.0	2018-06-26 21:59:40.314	error	at Object.fs.readFileSync (fs.js:551:33)
                    ham.0	2018-06-26 21:59:40.314	error	at Object.fs.openSync (fs.js:646:18)
                    ham.0	2018-06-26 21:59:40.314	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
                    ham.0	2018-06-26 21:59:40.314	error	uncaught exception: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
                    ham.0	2018-06-26 21:59:40.311	debug	[2018-6-26 21:59:40] Loaded plugin: homebridge-mi-philips-light</anonymous></anonymous></anonymous></anonymous>
                    das modul habe ich eigentlich schon gelöscht.. screenshot der Config im Anhang
                      apollon77 last edited by
                      Oooohje diese Plugin-Entwickler … warum auch immer die das Configfile lesen ...
                      Bitte 0.4.3 vom GitHub versuchen. geht es damit? Er schreibt jetzt die Konfig ins Konfigverzeichnis zusätzlich.
                      Du solltest aber das JSON checken. ein doppeltes "accessories" ist blöd. Wirf das Wemos raus wenn Du es nicht brauchst.
                      • Alex1808
                        @apollon77:
                        Du solltest aber das JSON checken. ein doppeltes "accessories" ist blöd. Wirf das Wemos raus wenn Du es nicht brauchst. `
                        Am besten aus dem Grund-config diese Beispiele löschen, es verwirrt nur.
                          0.4.3 macht genau das 😉
                          Gesendet vom Handy …
                          • Z
                            zahnheinrich last edited by
                            Hallo in die Runde,
                            Mein System:
                            ioBroker auf Synology buanet-Docker
                            node v6.14.3
                            npm 4.6.1
                            Installation des Adpters ohne Besonderheiten.
                            Habe das homebridge-ikea-tradfri-gateway installiert, die config, wie von Alex1808 für ein funktionierendes Plugin beschrieben, eingestellt.
                            Gateway ist online.
                            Der Adapter zeigt kurz grün, dann bleibt er rot, das log zeigt folgende Fehler:
                            ! host.iobrokerBosaca 2018-06-27 15:02:53.792 error instance system.adapter.ham.0 terminated with code 0 (OK)
                            ! host.iobrokerBosaca 2018-06-27 15:02:53.792 error Caught by controller[2]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/node-aead-crypto/index.js:4:15)
                            ! host.iobrokerBosaca 2018-06-27 15:02:53.791 error Caught by controller[2]: at Function.Module._load (/opt/iobroker/node_modules/iobroker.ham/node_modules/mock-require/index.js:29:22)
                            ! host.iobrokerBosaca 2018-06-27 15:02:53.791 error Caught by controller[2]: { Error: Cannot find module '/opt/iobroker/node_modules/iobroker.ham/node_modules/node-aead-crypto/build/Release/node-v48-linux-x64/node_aead_crypto.node'
                            ! host.iobrokerBosaca 2018-06-27 15:02:53.790 error Caught by controller[0]: [2018-6-27 13:02:52] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                            ! host.iobrokerBosaca 2018-06-27 15:02:50.474 info instance system.adapter.ham.0 started with pid 7291
                            ! host.iobrokerBosaca 2018-06-27 15:02:20.449 info Restart adapter system.adapter.ham.0 because enabled</anonymous>
                            die config:
                            ! "description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
                            ! "accessories": [],
                            ! "platforms": [
                            ! "platform": "Ikea Trådfri Gateway",
                            ! "name": "Ikea Trådfri Gateway",
                            ! "host": "192.168.7.106", // IP des Tradfry Gateways
                            ! "securityCode": "XXXXXXXXXX" // hier unkenntlich gemacht
                              Zeig mal den Log-Teil von der Installation des gewählten Plugins … In meinen Augen passt da was nicht:
                              • Dutchman
                                Warum Bindest du Ikea per Homebridge ein anstatt des tradifi Adapters ?
                                Der Adapter kan mehr als Homebridge!
                                Beides gleichzeitig geht nicht wegen besetzten ports
                                • Z
                                  @apollon77
                                  Ähh, welchen log meinst Du? Stehe da gerade auf dem Schlauch… :roll:
                                  @Dutchman
                                  ...weil ich das Ding nicht mehr zum Laufen kriege... :oops:
                                  Es ging schon mal einwandfrei, nach Docker update, Adapter update auf 2.0 auf einmal nicht mehr, trotz stundenlangen Suchens.
                                  Auch zurück auf v1.4.1 beim Tradfri ging nicht mehr.
                                  Dacht nun, wenn mit dem homebridge plugin einfach ginge....
                                    @zahnheinrich:
                                    @apollon77
                                    Ähh, welchen log meinst Du? Stehe da gerade auf dem Schlauch… :roll: `
                                    Also du den Namen des Plugins in die Konfig eingetragen und gespeichert hast. Da würde das NPM paket installiert. Den Teil aus dem ioBroker-Log meine ich.
                                    @zahnheinrich:
                                    @Dutchman
                                    …weil ich das Ding nicht mehr zum Laufen kriege... :oops:
                                    Dacht nun, wenn mit dem homebridge plugin einfach ginge.... `
                                    Dann mache lieber einen Thread auf wo es darum geht den Adapter wieder zum laufen zu bekommen! 🙂
                                    • Dutchman
                                      Nö lieber troubleshooten warum tradifi nicht mehr läuft Homebridge wird dir weniger Möglichkeiten geben als der Adapter.
                                      Mja, jedenfalls würde ich es so machen gut gemeinter tip
                                        schroedinger last edited by
                                        ich finde diesen adapter absolut toll , allerdings habe ich ein Problem, das ich einfach nicht selber lösen kann:
                                        Ich schaffe es nicht zwei "platforms" in die Konfigurationsdatei zu geben – denn ich erhalte immer eine Fehlermeldung und kann die Konfirguration nicht abspeichern.
                                        Hier die Konfirgurationsdatei - mit 2 "platforms", für dich ich die Fehlermeldung "expected ',' instead od '{' ferhalte -> und nicht abspeichern kann.
                                        (die Fehlermeldung steht übrigens über der Zeile mit "platform": "Info",
                                        ! "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                                        ! "accessories": [
                                        ! "accessory": "RaspberryPiTemperature",
                                        ! "name": "RaspberryPi CPU Temperature",
                                        ! "updateInterval": 1000
                                        ! "platforms": [
                                        ! "platform": "Seasons",
                                        ! "name": "Seasons",
                                        ! "calendar": "meteorologic",
                                        ! "hemisphere": "north",
                                        ! "display": "both"
                                        ! "platform": "Info",
                                        ! "port": 9876,
                                        ! "name": "Homebridge Info Server",
                                        ! "updateFrequency": 10000,
                                        ! "updateCheckFrequency": 86400
                                        Was an meiner Konfiguration ist falsch bzw. wie kann man mehrere "platforms" in der Konfigurationsdatei eintragen.
                                        Danke bereits jetzt für eure Tipps.
                                        schroedinger
                                        • Alex1808
                                          @schroedinger:
                                          "platforms": [ `
                                          es fehlt eine Komma
                                          "name": "Seasons",
                                          "display": "both"
                                          "platform": "Info",
                                          "port": 9876,
                                            Nach der ersten Plattform und der schliessenden geschweiften Klammer ein Komma bitte weil Du ja noch einen Eintrag angibst.
                                            Die Fehlermeldung sagt das doch … "erwarte ein Komma anstelle der nächsten öffnenden Klammer ...
                                            Edit: Alex war schneller 😉
                                            1.0k
                                            343
                                            85818
