    4. [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testen
    • Meistertr
      wollte es auch gerade testen leider ohne erfolg, er kann die config.json nicht finden.
      host.devbroker	2018-06-26 21:59:40.320	info	Restart adapter system.adapter.ham.0 because enabled
      host.devbroker	2018-06-26 21:59:40.320	error	instance system.adapter.ham.0 terminated with code 0 (OK)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: path: '/opt/iobroker/iobroker-data/ham_0/config.json' }
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: syscall: 'open',
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: code: 'ENOENT',
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: errno: -2,
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:188:19)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at new Server (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:57:24)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Server._loadPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:139:22)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Array.forEach (<anonymous>)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Server. <anonymous>(/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:165:14)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Plugin.module.exports [as initializer] (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:10:9)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at isConfig (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:24:32)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.fs.readFileSync (fs.js:551:33)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: at Object.fs.openSync (fs.js:646:18)
      Caught	2018-06-26 21:59:40.320	error	by controller[1]: { Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
      Caught	2018-06-26 21:59:40.319	error	by controller[0]: [2018-6-26 21:59:40] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
      ham.0	2018-06-26 21:59:40.314	warn	Exception: Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
      ham.0	2018-06-26 21:59:40.314	info	cleaned everything up...
      ham.0	2018-06-26 21:59:40.314	error	at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:96:23)
      ham.0	2018-06-26 21:59:40.314	error	at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:188:19)
      ham.0	2018-06-26 21:59:40.314	error	at new Server (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:57:24)
      ham.0	2018-06-26 21:59:40.314	error	at Server._loadPlugins (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:139:22)
      ham.0	2018-06-26 21:59:40.314	error	at Array.forEach (<anonymous>)
      ham.0	2018-06-26 21:59:40.314	error	at Server. <anonymous>(/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:165:14)
      ham.0	2018-06-26 21:59:40.314	error	at Plugin.module.exports [as initializer] (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:10:9)
      ham.0	2018-06-26 21:59:40.314	error	at isConfig (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-mi-philips-light/index.js:24:32)
      ham.0	2018-06-26 21:59:40.314	error	at Object.fs.readFileSync (fs.js:551:33)
      ham.0	2018-06-26 21:59:40.314	error	at Object.fs.openSync (fs.js:646:18)
      ham.0	2018-06-26 21:59:40.314	error	Error: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
      ham.0	2018-06-26 21:59:40.314	error	uncaught exception: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/ham_0/config.json'
      ham.0	2018-06-26 21:59:40.311	debug	[2018-6-26 21:59:40] Loaded plugin: homebridge-mi-philips-light</anonymous></anonymous></anonymous></anonymous>
      das modul habe ich eigentlich schon gelöscht.. screenshot der Config im Anhang
        apollon77 last edited by
        Oooohje diese Plugin-Entwickler … warum auch immer die das Configfile lesen ...
        Bitte 0.4.3 vom GitHub versuchen. geht es damit? Er schreibt jetzt die Konfig ins Konfigverzeichnis zusätzlich.
        Du solltest aber das JSON checken. ein doppeltes "accessories" ist blöd. Wirf das Wemos raus wenn Du es nicht brauchst.
        • Alex1808
          Alex1808 last edited by
          @apollon77:
          Du solltest aber das JSON checken. ein doppeltes "accessories" ist blöd. Wirf das Wemos raus wenn Du es nicht brauchst. `
          Am besten aus dem Grund-config diese Beispiele löschen, es verwirrt nur.
            0.4.3 macht genau das 😉
            Gesendet vom Handy …
            • Z
              zahnheinrich last edited by
              Hallo in die Runde,
              Mein System:
              ioBroker auf Synology buanet-Docker
              node v6.14.3
              npm 4.6.1
              Installation des Adpters ohne Besonderheiten.
              Habe das homebridge-ikea-tradfri-gateway installiert, die config, wie von Alex1808 für ein funktionierendes Plugin beschrieben, eingestellt.
              Gateway ist online.
              Der Adapter zeigt kurz grün, dann bleibt er rot, das log zeigt folgende Fehler:
              ! host.iobrokerBosaca 2018-06-27 15:02:53.792 error instance system.adapter.ham.0 terminated with code 0 (OK)
              ! host.iobrokerBosaca 2018-06-27 15:02:53.792 error Caught by controller[2]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.ham/node_modules/node-aead-crypto/index.js:4:15)
              ! host.iobrokerBosaca 2018-06-27 15:02:53.791 error Caught by controller[2]: at Function.Module._load (/opt/iobroker/node_modules/iobroker.ham/node_modules/mock-require/index.js:29:22)
              ! host.iobrokerBosaca 2018-06-27 15:02:53.791 error Caught by controller[2]: { Error: Cannot find module '/opt/iobroker/node_modules/iobroker.ham/node_modules/node-aead-crypto/build/Release/node-v48-linux-x64/node_aead_crypto.node'
              ! host.iobrokerBosaca 2018-06-27 15:02:53.790 error Caught by controller[0]: [2018-6-27 13:02:52] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
              ! host.iobrokerBosaca 2018-06-27 15:02:50.474 info instance system.adapter.ham.0 started with pid 7291
              ! host.iobrokerBosaca 2018-06-27 15:02:20.449 info Restart adapter system.adapter.ham.0 because enabled</anonymous>
              die config:
              ! "description": "This is an example configuration file with one fake accessory and one fake platform. You can use this as a template for creating your own configuration file containing devices you actually own.",
              ! "accessories": [],
              ! "platforms": [
              ! "platform": "Ikea Trådfri Gateway",
              ! "name": "Ikea Trådfri Gateway",
              ! "host": "192.168.7.106", // IP des Tradfry Gateways
              ! "securityCode": "XXXXXXXXXX" // hier unkenntlich gemacht
                Zeig mal den Log-Teil von der Installation des gewählten Plugins … In meinen Augen passt da was nicht:
                • Dutchman
                  Warum Bindest du Ikea per Homebridge ein anstatt des tradifi Adapters ?
                  Der Adapter kan mehr als Homebridge!
                  Beides gleichzeitig geht nicht wegen besetzten ports
                  • Z
                    @apollon77
                    Ähh, welchen log meinst Du? Stehe da gerade auf dem Schlauch… :roll:
                    @Dutchman
                    ...weil ich das Ding nicht mehr zum Laufen kriege... :oops:
                    Es ging schon mal einwandfrei, nach Docker update, Adapter update auf 2.0 auf einmal nicht mehr, trotz stundenlangen Suchens.
                    Auch zurück auf v1.4.1 beim Tradfri ging nicht mehr.
                    Dacht nun, wenn mit dem homebridge plugin einfach ginge....
                      @zahnheinrich:
                      @apollon77
                      Ähh, welchen log meinst Du? Stehe da gerade auf dem Schlauch… :roll: `
                      Also du den Namen des Plugins in die Konfig eingetragen und gespeichert hast. Da würde das NPM paket installiert. Den Teil aus dem ioBroker-Log meine ich.
                      @zahnheinrich:
                      @Dutchman
                      …weil ich das Ding nicht mehr zum Laufen kriege... :oops:
                      Dacht nun, wenn mit dem homebridge plugin einfach ginge.... `
                      Dann mache lieber einen Thread auf wo es darum geht den Adapter wieder zum laufen zu bekommen! 🙂
                      • Dutchman
                        Nö lieber troubleshooten warum tradifi nicht mehr läuft Homebridge wird dir weniger Möglichkeiten geben als der Adapter.
                        Mja, jedenfalls würde ich es so machen gut gemeinter tip
                          schroedinger last edited by
                          ich finde diesen adapter absolut toll , allerdings habe ich ein Problem, das ich einfach nicht selber lösen kann:
                          Ich schaffe es nicht zwei "platforms" in die Konfigurationsdatei zu geben – denn ich erhalte immer eine Fehlermeldung und kann die Konfirguration nicht abspeichern.
                          Hier die Konfirgurationsdatei - mit 2 "platforms", für dich ich die Fehlermeldung "expected ',' instead od '{' ferhalte -> und nicht abspeichern kann.
                          (die Fehlermeldung steht übrigens über der Zeile mit "platform": "Info",
                          ! "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                          ! "accessories": [
                          ! "accessory": "RaspberryPiTemperature",
                          ! "name": "RaspberryPi CPU Temperature",
                          ! "updateInterval": 1000
                          ! "platforms": [
                          ! "platform": "Seasons",
                          ! "name": "Seasons",
                          ! "calendar": "meteorologic",
                          ! "hemisphere": "north",
                          ! "display": "both"
                          ! "platform": "Info",
                          ! "port": 9876,
                          ! "name": "Homebridge Info Server",
                          ! "updateFrequency": 10000,
                          ! "updateCheckFrequency": 86400
                          Was an meiner Konfiguration ist falsch bzw. wie kann man mehrere "platforms" in der Konfigurationsdatei eintragen.
                          Danke bereits jetzt für eure Tipps.
                          schroedinger
                          • Alex1808
                            @schroedinger:
                            "platforms": [ `
                            es fehlt eine Komma
                            "name": "Seasons",
                            "display": "both"
                            "platform": "Info",
                            "port": 9876,
                              Nach der ersten Plattform und der schliessenden geschweiften Klammer ein Komma bitte weil Du ja noch einen Eintrag angibst.
                              Die Fehlermeldung sagt das doch … "erwarte ein Komma anstelle der nächsten öffnenden Klammer ...
                              Edit: Alex war schneller 😉
                                danke euch beiden.
                                Ich habe immer noch Probleme mit der Syntax von Konfigurationsdateien - aber auch wieder was gelernt.
                                Falls ich noch ein paar interessante hmebridge-adapter zum Laufen bringen, poste ich das hier. Mein Favorit wäre fakegato-history
                                Wenn das funktioniert, könnte man in der Elgato Eve app Graphen anzeigen lassen.
                                Sollte ich es hinbekommen, poste ich es hier.
                                danke
                                schroedinger
                                  Dann sag doch welche Probleme du hast, dann finden wir eine Lösung.
                                    Ps: dir ist aber schon klar das fakegato-History kein homebridge Plugin ist. Das ist eine Library die andere Plugin Provider einbauen können um für ihre Plugins in eve histories anzuzeigen.
                                    Also du kannst da gar nichts tun. Das müssen die Plugin devs machen. Also wenn du es willst musst du bei denen isues aufmachen.
                                    Auch dann wäre das hier nur für den globalen Modus interessant!! Für den wrapper Modus nimm History in iobroker oder so.
                                      hi @appolon77
                                      Ich hatte mich schlecht ausgedrückt , als ich sagte, die Syntax macht mir immer noch Probleme. Ich meinte dies generell.
                                      Aber mein oben erwähntes Problem hast du doch deine Post gelöst. Ich werde dies als "gelöst" markieren.
                                      Bezüglich > fakegato-History kein homebridge Plugin
                                      Zumindest hier steht, dass es ein homebridge-plugin wäre.
                                      https://www.npmjs.com/search?q=homebrid … popularity
                                      cu
                                        Dann lies mal was auf der readme von dem Projekt steht.
                                          Ps: das wäre eher ein issue für yahka in meinen Augen sowas mit einzubauen auch wenn nicht diese lib genutzt werden kann
                                            Kueppert last edited by
                                            Hi Gemeinde,
                                            hab mal wieder versucht, das plugin````
                                            [b]homebridge-mi-aqara[/b]
                                            (bedeutet: Daten eingetragen, gem. log wurde das plugin gestartet, die Mac-Adresse vom Gateway aufgerufen…und das wars. Keine Objekte erstellt. Testweise habe ich das Luftdaten-plugin ausprobiert - funktioniert. An einer Verbindung sollte es also nicht liegen)
                                            Ich würde gern den Aquara-Würfel nutzen können, der derzeit vom MiHome-Adapter (noch) nicht unterstützt wird.
                                            Frage: hat den Adapter schon jemand ausprobiert? Und ans Laufen bekommen?
                                            Link: [https://github.com/YinHangCode/homebridge-mi-aqara](https://github.com/YinHangCode/homebridge-mi-aqara)
                                            Danke und viele Grüße, Thorsten
                                            343
                                            85796
