    4. [Projekt] ioGo # Smarthome to go
      A Former User last edited by
      @Bluefox:
      Welche Module hast du? `
      Ich hab aktuell folgende dependencies:
      dependencies {
          implementation fileTree(include: ['*.jar'], dir: 'libs')
          // android support libraries
          implementation 'com.android.support:appcompat-v7:27.1.1'
          implementation 'com.android.support.constraint:constraint-layout:1.1.2'
          implementation 'com.android.support:design:27.1.1'
          implementation 'com.android.support:support-v4:27.1.1'
          implementation 'com.android.support:recyclerview-v7:27.1.1'
          implementation 'com.android.support:preference-v7:27.1.1'
          implementation 'com.android.support:preference-v14:27.1.1'
          implementation 'com.android.support:cardview-v7:27.1.1'
          // view model
          implementation 'android.arch.lifecycle:extensions:1.1.1'
          annotationProcessor 'android.arch.lifecycle:compiler:1.1.1'
          // ROOM
          implementation 'android.arch.persistence.room:runtime:1.1.1'
          annotationProcessor 'android.arch.persistence.room:compiler:1.1.1'
          // GSON
          implementation 'com.google.code.gson:gson:2.8.2'
          // SOCKET IO
          implementation('io.socket:socket.io-client:0.8.3') {
              exclude group: 'org.json', module: 'json'
          // OTTO BUS
          implementation 'com.squareup:otto:1.3.8'
          // DAGGER
          annotationProcessor 'com.google.dagger:dagger-compiler:2.14.1'
          implementation 'com.google.dagger:dagger:2.14.1'
          annotationProcessor 'com.google.dagger:dagger-android-processor:2.14.1'
          implementation 'com.google.dagger:dagger-android-support:2.14.1'
          implementation 'com.google.dagger:dagger-android:2.14.1'
          // BUTTERKNIFE
          implementation 'com.jakewharton:butterknife:8.5.1'
          annotationProcessor 'com.jakewharton:butterknife-compiler:8.5.1'
          // FIREBASE
          implementation 'com.google.firebase:firebase-core:16.0.1'
          implementation 'com.google.firebase:firebase-crash:16.0.1'
          // CRASHLYTICS
          implementation 'com.crashlytics.sdk.android:crashlytics:2.9.4'
          // testing
          testImplementation 'junit:junit:4.12'
          androidTestImplementation 'com.android.support.test:runner:1.0.2'
          androidTestImplementation 'com.android.support.test.espresso:espresso-core:3.0.2'
        Hat jemand eine gute Idee für einen App-Namen, mit der die App im Playstore gut zu finden ist?
        Auch sollte der Name nicht für Verwirrung sorgen neben der bestehenden App ioBroker.vis?!?
        Danke für Vorschläge
          Kueppert last edited by
          Hmmm… Namen... Bin da eher pragmatisch. ioBroker.native oder ioBroker.easy? Sehr, da hat ggf noch jemand eine bessere Idee? 🙂 Finde meine aber garnicht so schlecht...
          VG Thorsten
            KevinK last edited by
            Moin moin,
            Ich finde die App super. Vielen Dank für die Veröffentlichung! Ich kann sie sehr gut für meine Zwecke nutzen.
            Mir sind bei der Nutzung noch ein paar Optimierungsmöglichkeiten aufgefallen (v: 0.9.8).
            Kannst du bitte mal schauen, ob du den ein oder anderen Vorschlag einarbeiten kannst, nisio?
            • Beim Edit von ( z.B. Number) Values könnte das Input Feld direkt fokussiert werden, damit die Tastatur direkt eingeblendet wird.
            • Ein "Ok" auf ebendieser Tastatur könnte das Popup "New Value" auch direkt schließen.
            • der Stern zur Markierung eines Favoriten ist gut in den Räumen/Funktionen Menüs. Auf dem Startbildschirm benötige ich ihn persönlich nicht.
            • Eine Ausblend-Möglichkeit für die Rolle wäre super, um einen Zeilenumbruch für den Titel zu ermöglichen.
            Damit könnte u.U. die Text Überlagerung von Key und Value unterbunden werden.
            Besten Dank! 🙂
              MKaiser96 last edited by
              so langsam entwickelt sich die App. Sie wird immer besser.
              Drei Dinge sind mir aufgefallen.
              • Ich habe einen Schalter, bei dem nur lesen erlaubt ist. In der App ist der Schalter visuell schaltbar. Im Admin wird aber nichts geschaltet. So soll es auch sein. Wenn ich einmal zurück gehe und wieder in meinen Raum, dann ist er im Ausgangszustand. Empfehlenswert wäre, dass er visuell erst gar nicht schaltet bzw. wieder sofort zurückschaltet.
              • Ich habe einen State, der einen Status in Wortform ausgibt. Aus Platzgründen gibt es hier einen Zeilenumbruch. Dieser ist allerdings willkürlich im Wort. Hier wäre ein Zeilenumbruch bei einem Leerzeichen sinnvoll. Allerdings weiß ich nicht, wie man das bei einem sehr langen Wort lösen könnte.
              • Wie kann ich meine States sortieren? Es scheint so, als wären sie in der Reihenfolge, wie sie im admin als Objekte angelegt worden. Schöner wäre eine individuelle Sortierung. Dies müsste allerdings irgendwie synchronisiert werden, um es parallel auf mehreren Geräten identisch zu haben.
                @MKaiser96:
                Ich habe einen Schalter, bei dem nur lesen erlaubt ist. In der App ist der Schalter visuell schaltbar. Im Admin wird aber nichts geschaltet. So soll es auch sein. Wenn ich einmal zurück gehe und wieder in meinen Raum, dann ist er im Ausgangszustand. Empfehlenswert wäre, dass er visuell erst gar nicht schaltet bzw. wieder sofort zurückschaltet. `
                Welche Role hat der State?
                @MKaiser96:
                Ich habe einen State, der einen Status in Wortform ausgibt. Aus Platzgründen gibt es hier einen Zeilenumbruch. Dieser ist allerdings willkürlich im Wort. Hier wäre ein Zeilenumbruch bei einem Leerzeichen sinnvoll. Allerdings weiß ich nicht, wie man das bei einem sehr langen Wort lösen könnte. `
                Bitte einen Screenshot machen, sonst wird es schwer das nachzuvollziehen.
                @MKaiser96:
                Wie kann ich meine States sortieren? Es scheint so, als wären sie in der Reihenfolge, wie sie im admin als Objekte angelegt worden. Schöner wäre eine individuelle Sortierung. Dies müsste allerdings irgendwie synchronisiert werden, um es parallel auf mehreren Geräten identisch zu haben. `
                Das nehm ich gerne auf die Wunschliste auf… klingt sehr hilfreich.
                Ganz vielen Dank für das Feedback und die Ideen
                  Der State ist als switch deklariert.
                  Ich habe gerade gesehen, dass der Zeilenumbruch in der neuen App so angepasst wurde, wie ich es mir gewünscht habe. Ein Zeilenumbruch ist bei Platzmangel bei einem Leerzeichen. Ansonsten, wenn das Wort zu lang ist zwischendurch.
                  Allerdings ist mir eben aufgefallen, dass nur zwei Zeilen geschrieben werden. Beim Status: Zeilenumbruch fehlt das "h".
                  Eine weitere Sache. Ein Aktualisieren-Button wäre hilfreich. Oder wie beim Chromebrowser: Nach unten wischen zum aktualisieren. Werte werden zwar live angepasst, aber wenn ich ein neues Objekt anlege oder dessen Eigenschaften ändere, geschieht das erst nach aktualisieren in den Optionen.
                  EDIT:
                  Ich habe mir die neue Version 0.9.9 geladen. Hier ist jetzt mehr Platz für den Status. Auch die Icons für die Rollen sind schön gelöst.
                    Switch sollte immer read und write sein.
                    Ich orientiere mich dabei an folgender Liste: https://github.com/ioBroker/ioBroker/bl … E_ROLES.md
                    Aktualisieren ala Chrome nehm ich auch gerne mit auf
                    Gesendet von meinem Pixel 2 mit Tapatalk
                      Ich habe verschiedene Rollen durchprobiert, aber nicht das richtige gefunden. Was könnte man hier nehmen, um ein wahr/falsch oder ein/aus anzuzeigen?
                      Wäre es möglich, dass der Schalter bei nur Lesezugriff wieder sofort zurückschaltet oder erst gar nicht reagiert?
                        Boolean read-only sind Sensor und Indicator. Es geht alles, aber macht es macht nicht immer Sinn. So lange es bestehende Lösungen gibt, werde ich versuchen keine Workarounds umzusetzen. Das artet ansonsten ganz schnell aus…
                          Hi, ich habe 0.9.9 gerade ausprobiert. Bei mir werden keine functions mehr angezeigt und wenn ich auf einen bestimmten Raum klicke springt die App wieder auf den Start Bildschirm und schreit"Service started". Das hatte ich bei der älteren Version nicht…
                            @Kueppert:
                            Hi, ich habe 0.9.9 gerade ausprobiert. Bei mir werden keine functions mehr angezeigt und wenn ich auf einen bestimmten Raum klicke springt die App wieder auf den Start Bildschirm und schreit"Service started". Das hatte ich bei der älteren Version nicht… `
                            Funktionen werden mit 0.9.10 wieder angezeigt.
                            Das Verhalten mit dem Raum kann ich noch nicht nachvollziehen.
                              steckenpferd last edited by
                              Auch eine Chance später das ganze als iOS App?
                                iOS App ist nicht geplant von mir
                                  @nisio:
                                  Das Verhalten mit dem Raum kann ich noch nicht nachvollziehen. `
                                  Hi nisio, der Raum lässt sich wieder öffnen ohne dass die App dieses komische Verhalten zeigt. Mit der neuen Version wieder alles gut 🙂
                                    Die Version 0.9.11 lässt sich bei mir nicht installieren… Er tut so und sagt dann, wurde nicht installiert. Muss ich für die 11er Version die Akte vorher löschen? Musste ich bisher nicht...
                                      @Kueppert:
                                      Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk ` Ich habe ein paar elementare Anpassungen an den Package Namen gemacht zur Vorbereitung für den Play Store. Version 0.9.11 gibt's nicht mehr. Version 0.10.x muss vermutlich neu installiert werden (alte Version vorher deinstallieren)
                                        In der neuen Version 0.10.0 sind vor den States die Symbole verschwunden, vor den Schaltern sind sie dagegen vorhanden.
                                        Zudem habe ich immer mal Probleme, dass die Objekte beim Öffnen nicht automatisch aktualisiert werden. Ich muss dann in den Infobereich gehen und die Objekte manuell synchronisieren.
                                          Hi, ich habe jetzt auch v0.10.0 drauf. IP bei eingetragen und bei gesynct. Objekte werden gefunden, aber keine states mehr.
                                            mich wundert zur Zeit, dass ein State (Werteliste (number)) nicht als State in der App erkannt wird. Kann jemand sagen, woran es liegen mag? Hier einmal die Details zum dem State:
                                            81.1k
                                            android app iogo
                                            61
                                            1140
                                            358180
