    4. [Frage] Xiaomi Vacuum cleaner
    • bahnuhr
      und das ist die Error Liste:
          var v_Error = getState('mihome-vacuum.0.info.error').val;
          var v_Text = "";
          if (v_Error === 0) v_Text = "no Error";
          if (v_Error === 1) v_Text = "Laser distance sensor error";
          if (v_Error === 2) v_Text = "Collision sensor error";
          if (v_Error === 3) v_Text = "Wheels on top of void, move robot";
          if (v_Error === 4) v_Text = "Clean hovering sensors, move robot";
          if (v_Error === 5) v_Text = "Clean main brush";
          if (v_Error === 6) v_Text = "Clean side brush";
          if (v_Error === 7) v_Text = "Main wheel stuck?";
          if (v_Error === 8) v_Text = "Device stuck, clean area";
          if (v_Error === 9) v_Text = "Dust collector missing";
          if (v_Error === 10) v_Text = "Clean filter";
          if (v_Error === 11) v_Text = "Stuck in magnetic barrier";
          if (v_Error === 12) v_Text = "Low battery";
          if (v_Error === 13) v_Text = "Charging fault";
          if (v_Error === 14) v_Text = "Battery fault";
          if (v_Error === 15) v_Text = "Wall sensors dirty, wipe them";
          if (v_Error === 16) v_Text = "Place me on flat surface";
          if (v_Error === 17) v_Text = "Side brushes problem, reboot me";
          if (v_Error === 18) v_Text = "Suction fan problem";
          if (v_Error === 19) v_Text = "Unpowered charging station";
          setState("javascript.0.Status.Geräte.Mihome_Text_Error", v_Text);
      • bahnuhr
        und hier das ganze Script inkl. telegram und Sound-Ansage:
        // Error, Text in Variable schreiben ----------------------------------------------------------------------------------------------
        on({id: "mihome-vacuum.0.info.error", change: "ne"}, function(obj){
            var v_Text = "";
            if (v_Error > 0) {
                log("Auslöser: Mihome Staubsauger hat Error !");
                sendTo('telegram', "Achtung, Achtung! \nDer Mihome Staubsauger hat folgenden Error:\n" + v_Text);
                View_change ('Geraete', 0);
                //Sound
                    var request = require ('request');
                    request('http://192.168.243.76:50000/track=tng_red_alert2.wav');
                    setTimeout(setState('sayit.0.tts.text', "Achtung, Achtung! Der Robo Staubsauger hat Error"), 5000);
                View_change ('Titel', 30000);
          trollmar last edited by
          @klassisch:
          /*   List of states
          			1 unknown state
          			2 sleep no Charge
          			3 sleep
          			5 cleaning
          			6 returning home
          			7 manual mode
          			8 charging
          			10 paused
          			11 spot cleaning
          			12 Error
          Wenn sich meiner verhakt, gibts die 12 und dann sende ich eine email mit "Help" `
          Danke!!!!
            Brati last edited by
            Mit PushOver und verschiedenen Prioritäten so gelöst (den Error gleich auslesen hatte nicht funktioniert, weil der State nicht schnell genug wechselte, somit kommt erst "Fehler" und danach der eigentliche Fehler):
            /* Status Pushen */
            on({id: "mihome-vacuum.0.info.state"/*Vacuum state*/, change: "ne"}, function (obj) {
                nachricht = obj.state.val;
                prio    = -1;
                betreff = "Roborock";
                instance = 0;
                switch (nachricht) {
                    case 2:
                        nachricht = "gehe Schlafen ohne Laden!";
                        break;
                    case 3:
                        nachricht = "gehe Schlafen!";
                        break;
                    case 6:
                        nachricht = "Weg zur Ladestation!";
                        prio = -2;
                        break;
                    case 8:
                        nachricht = getState("mihome-vacuum.0.info.cleanedarea"/*Cleaned area*/).val +
                                    "m² in " +
                                    getState("mihome-vacuum.0.info.cleanedtime"/*Cleaning time*/).val +
                                    "min. Ladestation erreicht!";
                        break;
                    case 12:
                        betreff = "Roborock - Error!";
                        prio = -2;
                        nachricht   = "wird ausgelesen!";
                        break;
                    case 16:
                        nachricht = "GoTo Point!";
                        prio = -2;
                        break;
                    case 17:
                        nachricht = "In Zonen Reinigung!";
                        prio = -2;
                        break;
                    default:
                        nachricht = "Status -"  + nachricht + "- unbekannt!";
                sendTo("pushover." + instance, {
                    message:  nachricht, // mandatory - your text message
                    title:    betreff, // optional  - your message's title, otherwise your app's name is used
                    priority: prio,});
            on({id: "mihome-vacuum.0.info.error"/*Error*/, change: "ne"}, function (obj) {
                prio = 0;
                instance = 2;
                switch (getState("mihome-vacuum.0.info.error"/*Error*/).val) {
                                case 0:
                                nachricht = "No Error";
                                break;
                            case 1:
                                nachricht = "Laser distance sensor error";
                                break;
                            case 2:
                                nachricht = "Collision sensor error";
                                break;
                            case 3:
                                nachricht = "Wheels on top of void, move robot";
                                break;
                            case 4:
                                nachricht = "Clean hovering sensors, move robot";
                                break;
                            case 5:
                                nachricht = "Clean main brush";
                                break;
                            case 6:
                                nachricht = "Clean side brush";
                                break;
                            case 7:
                                nachricht = "Main wheel stuck?";
                                break;
                            case 8:
                                nachricht = "Device stuck, clean area";
                                break;
                            case 9:
                                nachricht = "Dust collector missing";
                                break;
                            case 10:
                                nachricht = "Clean filter";
                                break;
                            case 11:
                                nachricht = "Stuck in magnetic barrier";
                                break;
                            case 12:
                                nachricht = "Low battery";
                                break;
                            case 13:
                                nachricht = "Charging fault";
                                break;
                            case 14:
                                nachricht = "Battery fault";
                                break;
                            case 15:
                                nachricht = "Wall sensors dirty, wipe them";
                                break;
                            case 1:
                                nachricht = "Place me on flat surface";
                                break;
                            case 1:
                                nachricht = "Side brushes problem, reboot me";
                                break;
                            case 1:
                                nachricht = "Suction fan problem";
                                break;
                            case 1:
                                nachricht = "Unpowered charging station";
                                break;
                            case 1:
                                break;
                            default:
                                nachricht = "Error - Status unbekannt!";
                    priority: prio,});
              root_ last edited by
              Ich gebe über vis und telegram aus das der Staubbehälter geleert werden soll. Das funktioniert sowert sehr gut aber die Methode gefällt mir noch nicht. Momentan gibt er alle 5x "Vacuum state=5" die Meldung aus. Da er aber auch, wenn er sich festgefahren hat und man ihn weiterschickt, wieder auf state5 geht kann es sein das man schon nach 2-3 Tagen die Meldung bekommt. Sinniger wär es zb alle 200-250qm Reinigungsfläche die Meldung auszugeben. Das bekomme ich aber nicht hin. Man müsste "mihome-vacuum.0.history.total_area" und "mihome-vacuum.0.info.cleanedarea" dazu berechnen. Irgendwie bin ich aber zu doof das umzusetzen. Hat jemand eine Idee?
                ungetestet:
                createState('Roborock.DustHour', 0,{type: "number",name:"Nutzung Saugbehaelter in h",  role: "Nutzung Saugbehaelter in h"});
                on({id: "mihome-vacuum.0.info.cleanedarea", change: "ne"}, function (obj) {
                    gesamt = getState("mihome-vacuum.0.info.cleanedarea"/*Cleaned area*/).val + getState("javascript.0.Roborock.DustHour").val;
                    setState("javascript.0.Roborock.DustHour", gesamt);
                    if (gesamt > 225) {
                        setState("javascript.0.Roborock.DustHour",0);
                        // und hier noch Push ergänzen
                Das sollte bei jeder Änderung des State "cleanedarea" den State "DustHour" nach oben zählen. Bis der Wert 225 erreicht ist, dann wird im if Bereich alles abgearbeitet und wieder auf 0 gesetzt.
                Brati
                  ltsalvatore last edited by
                  @trollmar:
                  @klassisch:
                  /*   List of states
                  			1 unknown state
                  			2 sleep no Charge
                  			3 sleep
                  			5 cleaning
                  			6 returning home
                  			7 manual mode
                  			8 charging
                  			10 paused
                  			11 spot cleaning
                  			12 Error
                  Danke!!!! `
                  wie bekomme ich diese states im vis dargestellt..
                  das hier, scheint nicht so ganz zu funktionieren.
                  aktuell müsste der wert charging angezeigt weren, es wird jedoch unknown state angezeigt.
                    @Brati:
                    ungetestet:
                        if (gesamt > 225) {
                    Brati `
                    Vielen Dank. Ich werde es gleich testen. 🙂
                      Funktioniert leider nicht. Er addiert so bei jeder state Änderung den Wert zu dusthour. So kommt man dann bei 17qm real auf einen Wert von über 600. Man muss den cleanedaera wert quasi auslesen (qm) und so lange addieren bis 250 erreicht ist. Eine Reinigung ergibt bei uns ca 50qm. Danach wird der Wert cleanedarea wieder auf 0 gesetzt aber der Wert von dusthour muss bei 50 bleiben und dann bei der nächsten Reinigung weiterzählen. Ist doch nicht ganz so trivial. Andere Möglichkeit wäre bei der state Änderung „Returning home“ den cleandeaera Wert zu dusthour zu addieren.
                        Ahh, stimmt er zählt ja den Wert bei der Reinigung nach oben, also wird alle 6s addiert. Das Problem ist aber, dass er Returning to Home auch annimmt, wenn er nur zu einem Punkt gefahren ist.
                        Dann müsste man addieren, wenn er in der Basis ist und der Wert sich geändert hat.
                        Ich mache mir mal Gedanken… Brauchen wir nur ein, zwei States mehr.
                        Soll der Stunden Zähler automatisch auf 0 gesetzt werden oder per vis? Ich glaube den Status "Staubbehälter entnommen" gibt es so nicht...
                        Grüße Brati
                        Von unterwegs gesendet...
                          Hab jetzt mit Blocky hinbekommen 🙂
                          Nun hab ich nur noch eine Sache, wie bekomm ich in einem Objekt (Zahl) die Kommenstellen 2 stellig? Momentan sind da irgendwie 10 Stellen nach dem Komma.
                          • AlCalzone
                            Kenne den exakten Blockly-Aufbau nicht, aber so gehts:
                            Zahl = Runden(Zahl * 100) / 100
                              Hab es hinbekommen. Mit dem Block "runden" .
                                Altersrentner last edited by
                                Ich bin mir unsicher ob ich hier meine Frage beantwortet bekomme,
                                oder ob ich einen neuen Betreff aufmachen soll.
                                Es geht um das auslesen des Token für den Staubsauger S5 Roborock.
                                Im ioBroker habe ich den mihome-vacuum.0 Adapter geladen.
                                Zur Konfiguration benötige ich neben der IP den Token.
                                Dazu habe ich das Mi Toolkit 1.6 auf meinen Win10 PC installiert.
                                Java ist auf dem aktuellen Stand.
                                Nach dem starten der Mi exe wird ein Backup erstell was auch entpackt wird.
                                Leider wird nur die IP angezeigt und der Token nicht.
                                im Netz habe ich die unterschiedlichsten Vorgehensweisen gefunden,
                                aber keine brachte das gewünschte Ergebnis.
                                In einem Beitrag habe ich gelesen, das sich der Token in der Datei
                                miio2.db-journal befinden soll.
                                Diese Datei habe ich gefunden nur wie wird diese geöffnet.
                                Gruß Michael
                                • umbm
                                  umbm last edited by
                                  Ich habe das gleiche Problem letzte Woche lösen müssen, und es nur auf einem Weg geschafft:
                                  Die aktuelle Mi-App vom Android deinstalliert, und eine alte Version (bei mir war es 5.0.19) vom apk-Mirror installiert.
                                  Davon dann das Backup nochmal erstellt nachdem der roborock eingebunden war und mit dem Tool den Token auslesen lassen. Nur so hat es funktioniert.
                                  Danach have ich dann wieder die aktuelle Version der Mi-App aus dem Playstore installiert.
                                  Viel Erfolg…
                                  Nachtrag:
                                  Die mui2.db lässt sich mit einem Mysql-Viewer öffnen, allerdings ist der Token dort leer und wird nicht angezeigt, wenn das Backup aus der aktuellen Mi-App erstellt wurde.
                                  • Meistertr
                                    @umbm:
                                    Viel Erfolg…
                                    Nachtrag:
                                    Die mui2.db lässt sich mit einem Mysql-Viewer öffnen, allerdings ist der Token dort leer und wird nicht angezeigt, wenn das Backup aus der aktuellen Mi-App erstellt wurde. ` Das 3infaxhste ist es die russische Version aus der readme zu installieren, so hast du immer den token..
                                    Gesendet von meinem Handy
                                      Danke für Eure Antworten.
                                      Meistertr,
                                      Könntest Du mir bitte die russisch Version zukommen lassen.
                                      Ich war gestern schon auf der russischen Seite, habe aber nichts gefunden.
                                      Danke, Gruß Michael
                                      • umbm
                                        umbm last edited by
                                        Die russische Version hatte ich auch versucht, dort ließ sich der roborock nichtmal einrichten, weil immer der Server (CN Mainland) abgelehnt wurde, und so kam ich nicht in Einstellungen des vacuum, um den Token anzeigen zu lassen.
                                        Aber ohne den China-Server bekomme ich meine Aktoren nicht eingerichtet…
                                        Ziemliches Chaos irgendwie, seit die neuerdings scheinbar beim roborock auf den EU-Server bestehen und sonst den Zugriff verweigern...
                                        Noch ein Hinweis:
                                        wenn du irgendwann den Token hast, auf keinen Fall am Sauger das wifi zurücksetzen und neu verbinden, dann givt es einen neuen token....
                                          Hallo umbm,
                                          Danke für den Hinweis,
                                          aber es muss doch eine Möglichkeit geben.
                                          Es gibt doch hier einige, denen es gelungen ist den Token zu ermitteln.
                                          Wer hat noch eine Idee.
                                          Gruß Michael
                                            Kueppert last edited by
                                            Hi, ich mache das mit der App Version 5.0.6 und dem Backup. Danke hat es letztes Mal wunderbar geklappt. Server hab ich China genommen…
                                            2196
                                            959280
