    4. Das Ultimative Markisen / Rolladen Blockly - Script
      muckel last edited by
      Hallo Smile!
      Könntest du bitte dein "Klimadatenaußenerfassen.txt" nochmals hochladen.
      Ich bekomme einen Import Error.
      Danke im Voraus
      Liebe Grüße
      • smile
        smile last edited by Negalein
        Na klar, hier kommt es nochmal neu, als TXT und hier als Code.
         <xml xmlns="http://www.w3.org/1999/xhtml"><block type="schedule" id="!LT)#j}MPt[UXkpKSgaH" x="-938" y="-3312"><field name="SCHEDULE">*/2 * * * *</field>
            <statement name="STATEMENT"><block type="comment" id="14}z2@Y0`tb8dLOwV4_#"><field name="COMMENT">Abfrage Sonne Vormittag</field>
                <next><block type="controls_if" id="t7yCKxf:b#O:O#.mTcm0"><value name="IF0"><block type="logic_compare" id="E9e]QBwXCT`1y|{v?=zU"><field name="OP">GT</field>
                        <value name="A"><block type="get_value" id="}l*BsjV(Ly;R`TLR#ygG"><field name="ATTR">val</field>
                            <field name="OID">hm-rpc.0.NEQ1100463.1.BRIGHTNESS</field></block></value>
                        <value name="B"><block type="math_number" id="T1]py,8=Mr}?*wc;deL["><field name="NUM">201</field></block></value></block></value>
                    <statement name="DO0"><block type="controls_if" id=",X,[,Ro9G0)12.^Yeq:A"><value name="IF0"><block type="logic_compare" id=")k5uB?0~qs-.DY}l?M;R"><field name="OP">LT</field>
                            <value name="A"><block type="get_value" id="d?r7,5KPl4Qr~nqK!wEt"><field name="ATTR">val</field>
                                <field name="OID">javascript.0.Count_Sonne</field></block></value>
                            <value name="B"><block type="math_number" id="SZs8Ov!bkM1]G,smqrlm"><field name="NUM">5</field></block></value></block></value>
                        <statement name="DO0"><block type="control" id="bQ={G~at|PPqm1zl;v0Q"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="math_arithmetic" id=",g5B[~3az!AUK-_u62U?"><field name="OP">ADD</field>
                                <value name="A"><shadow type="math_number" id="nMRH}I.JPiB^vn+{ztFe"><field name="NUM">1</field></shadow>
                                  <block type="get_value" id="1%}X`^lx8/5G-w|~G5.N"><field name="ATTR">val</field>
                                <value name="B"><shadow type="math_number" id="H0[*xZdkWMmLt;QlM4TC"><field name="NUM">2.5</field></shadow></value></block></value></block></statement></block></statement>
                    <next><block type="controls_if" id="T2nEKl1l~:gpzIn[cw[v"><value name="IF0"><block type="logic_compare" id="|(zjR2;f.0+Y0yq#Vu1n"><field name="OP">LT</field>
                            <value name="A"><block type="get_value" id="H~nQMQ|b{.QVj,_KO{J0"><field name="ATTR">val</field>
                            <value name="B"><block type="math_number" id="aVcOp`H|]2Gs}WWoG_Ee"><field name="NUM">200</field></block></value></block></value>
                        <statement name="DO0"><block type="controls_if" id=")vIke:QSu)U1=r|a=F%s"><value name="IF0"><block type="logic_compare" id="U|zezrE^_Dz{i6nHr2~d"><field name="OP">GT</field>
                                <value name="A"><block type="get_value" id="BQV.=S!0wA};O_tq0CW?"><field name="ATTR">val</field>
                                <value name="B"><block type="math_number" id="ppO!s_(~|oC1srIenB=o"><field name="NUM">0</field></block></value></block></value>
                            <statement name="DO0"><block type="control" id="94#BMt`V1=p,y0BjWeI("><mutation delay_input="false"></mutation>
                                <value name="VALUE"><block type="math_arithmetic" id="uM)sV9;Cl-MTQpXSciKY"><field name="OP">MINUS</field>
                                      <block type="get_value" id="Fj,a#Sbc|JLHamxdvjI]"><field name="ATTR">val</field>
                                    <value name="B"><shadow type="math_number" id="@LXQipW3MJ`k!7@cBJ)!"><field name="NUM">1</field></shadow></value></block></value></block></statement></block></statement>
                        <next><block type="controls_if" id="U;DVO:.?Qb5i:xucQN4,"><value name="IF0"><block type="logic_operation" id="6^}f7@j6oR5;Z=m5qo7e" inline="false"><field name="OP">AND</field>
                                <value name="A"><block type="logic_compare" id=";yu9X~U@gCG7]hu|N+CC"><field name="OP">GTE</field>
                                    <value name="A"><block type="get_value" id="HCT!-SFF#?V4C}hZ6vw["><field name="ATTR">val</field>
                                    <value name="B"><block type="math_number" id=";9[S+4G!!ZGP.yn}dGBQ"><field name="NUM">5</field></block></value></block></value>
                                <value name="B"><block type="logic_compare" id="a}qpvtwrGWZ{mq@RwZu:"><field name="OP">EQ</field>
                                    <value name="A"><block type="get_value" id="sJz4!qJ~2ymGA`+0jhI~"><field name="ATTR">val</field>
                                        <field name="OID">javascript.0.Sonne vormittag</field></block></value>
                                    <value name="B"><block type="logic_boolean" id="qGsul^y.sa|pxCU4`ftF"><field name="BOOL">FALSE</field></block></value></block></value></block></value>
                            <statement name="DO0"><block type="control" id="LzY2y7N|];DFJhpsr*GF"><mutation delay_input="false"></mutation>
                                <value name="VALUE"><block type="logic_boolean" id="X6}CStLs/,agz1r*)Qg4"><field name="BOOL">TRUE</field></block></value>
                                <next><block type="debug" id="aNXkXdXVkN)/q6~g?iuw"><field name="Severity">log</field>
                                    <value name="TEXT"><shadow type="text" id="]E;|kP1P~%KjOa|~1_.G"><field name="TEXT">***Sonne vormittag da</field></shadow></value></block></next></block></statement>
                            <next><block type="controls_if" id="Nld)#@oM(7bQXsl!ka:R"><value name="IF0"><block type="logic_operation" id="%JN-]kpYmfVO/+K:bNvA" inline="false"><field name="OP">AND</field>
                                    <value name="A"><block type="logic_compare" id="|}I14xq7E0k!Iu`.pIdL"><field name="OP">LTE</field>
                                        <value name="A"><block type="get_value" id=":H):wT:?1qh_g#m}qiqr"><field name="ATTR">val</field>
                                        <value name="B"><block type="math_number" id="UdE!|W5[=RsEw@hYdQ]Q"><field name="NUM">0</field></block></value></block></value>
                                    <value name="B"><block type="logic_compare" id="1-G~.wFPh1:/T(..%h!D"><field name="OP">EQ</field>
                                        <value name="A"><block type="get_value" id="QD.,}wQQC[3yb!X]TWbR"><field name="ATTR">val</field>
                                        <value name="B"><block type="logic_boolean" id="2uioy}D_@l(5VPPD8SRu"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                                <statement name="DO0"><block type="control" id="oLwRwTiMa_VHDTJ?Wuwc"><mutation delay_input="false"></mutation>
                                    <value name="VALUE"><block type="logic_boolean" id="j)8?TDqL#ob(}3%?AU*%"><field name="BOOL">FALSE</field></block></value>
                                    <next><block type="debug" id="CBvLn^xu0jpzRT0PSG|k"><field name="Severity">log</field>
                                        <value name="TEXT"><shadow type="text" id="vnYEqh.!ihiX`PcU@,Y-"><field name="TEXT">***Sonne vormittag weg</field></shadow></value></block></next></block></statement>
                                <next><block type="comment" id="fb!tZTKi(lMo~rlxd[IR"><field name="COMMENT">Abfrage Sonne Nachmittag</field>
                                    <next><block type="controls_if" id="9,jPH9@.DKY16K3zQoNE"><value name="IF0"><block type="logic_compare" id="v;=}p)8kn2@)O~M/]A={"><field name="OP">GT</field>
                                            <value name="A"><block type="get_value" id="alF%|DBVoLMpo~rf?EvA"><field name="ATTR">val</field>
                                            <value name="B"><block type="math_number" id="=Z+hc=SJZH/N1H;aPIe{"><field name="NUM">195</field></block></value></block></value>
                                        <statement name="DO0"><block type="controls_if" id="Rn]IyQC/]bnFt9:-C8U;"><value name="IF0"><block type="logic_compare" id="Xz_~.8YsCRExFR;U9KRT"><field name="OP">LT</field>
                                                <value name="A"><block type="get_value" id="8[3;*d31D4%_h%`*;@nh"><field name="ATTR">val</field>
                                                    <field name="OID">javascript.0.Count_Sonne_Nachmittag</field></block></value>
                                                <value name="B"><block type="math_number" id="_CL:TdIFx{!yFZaJ;uo;"><field name="NUM">5</field></block></value></block></value>
                                            <statement name="DO0"><block type="control" id="9v;:)+2ug~n_3vW6Z);("><mutation delay_input="false"></mutation>
                                                <value name="VALUE"><block type="math_arithmetic" id="GHlZ:1_aW6U0LFp)Bz`5"><field name="OP">ADD</field>
                                                      <block type="get_value" id="@%uiNy0n?7_jGQAX+(aG"><field name="ATTR">val</field>
                                                    <value name="B"><shadow type="math_number" id="1MiEb2r6ERxq{;`H+_m)"><field name="NUM">2.5</field></shadow></value></block></value></block></statement></block></statement>
                                        <next><block type="controls_if" id="FY*_Ui+K?Wk)0L31xLTm"><value name="IF0"><block type="logic_compare" id="m5O5n}DG6r*)^MbgH8b:"><field name="OP">LT</field>
                                                <value name="A"><block type="get_value" id="z4NGJ8pn(bXFs0^#UX78"><field name="ATTR">val</field>
                                                <value name="B"><block type="math_number" id=")[.{^lnfj.l]5rXSO%-U"><field name="NUM">195</field></block></value></block></value>
                                            <statement name="DO0"><block type="controls_if" id="?+_/[{bJo#j_%kd{v~sK"><value name="IF0"><block type="logic_compare" id="bScqjjgFCl9bqPD2MUU("><field name="OP">GT</field>
                                                    <value name="A"><block type="get_value" id="5;Oy]TqxrrJJoDm=;Cce"><field name="ATTR">val</field>
                                                    <value name="B"><block type="math_number" id="@5Y8?|+lE;[*42]tvDHq"><field name="NUM">0</field></block></value></block></value>
                                                <statement name="DO0"><block type="control" id="xnJb|G8@Sz6*PBqLLnk["><mutation delay_input="false"></mutation>
                                                    <value name="VALUE"><block type="math_arithmetic" id="I8YR}H|i|7!;g!#]vjeH"><field name="OP">MINUS</field>
                                                          <block type="get_value" id="a=YMs9gocb/9RnNyP*Xv"><field name="ATTR">val</field>
                                                        <value name="B"><shadow type="math_number" id="tleKjpnRNcQjOlSG)WbU"><field name="NUM">1</field></shadow></value></block></value></block></statement></block></statement>
                                            <next><block type="controls_if" id="Q)r2Sx5Gw:`c^ra8S)[C"><value name="IF0"><block type="logic_operation" id="%j?sZi`vo.U_DKQ;.zl_" inline="false"><field name="OP">AND</field>
                                                    <value name="A"><block type="logic_compare" id="rd4m7{aGCDkarRn!;k+~"><field name="OP">GTE</field>
                                                        <value name="A"><block type="get_value" id="PA5L-w89e%?[z2CNS]*:"><field name="ATTR">val</field>
                                                        <value name="B"><block type="math_number" id="QsfD{cOVBrbZS)dq!@KJ"><field name="NUM">5</field></block></value></block></value>
                                                    <value name="B"><block type="logic_compare" id="-U;C[0TCY:JSci:1EO|%"><field name="OP">EQ</field>
                                                        <value name="A"><block type="get_value" id="6jKsQx:SCO2PjK1B,)QN"><field name="ATTR">val</field>
                                                            <field name="OID">javascript.0.Sonne nachmittag</field></block></value>
                                                        <value name="B"><block type="logic_boolean" id="QP([z.q=LYDX?;%5?Zl("><field name="BOOL">FALSE</field></block></value></block></value></block></value>
                                                <statement name="DO0"><block type="control" id="7*RMi=_35%+8X(vJ,i)P"><mutation delay_input="false"></mutation>
                                                    <value name="VALUE"><block type="logic_boolean" id="k:G~C8G86vQ%a[gG4bSL"><field name="BOOL">TRUE</field></block></value>
                                                    <next><block type="debug" id="v]?)h87yvRgZd+?nxF!4"><field name="Severity">log</field>
                                                        <value name="TEXT"><shadow type="text" id="?k{[GWyML4z0xL{xS1z."><field name="TEXT">***Sonne nachmittag da</field></shadow></value></block></next></block></statement>
                                                <next><block type="controls_if" id="oEQ^2Vo.^6hSN:ugnkOK"><value name="IF0"><block type="logic_operation" id="vkqAJ]a=6vy+~Sov|m*i" inline="false"><field name="OP">AND</field>
                                                        <value name="A"><block type="logic_compare" id="`*!:.d30}Z-nP6pnAiY1"><field name="OP">LTE</field>
                                                            <value name="A"><block type="get_value" id="0@Gp*m|lpiL(*v5+4R#p"><field name="ATTR">val</field>
                                                            <value name="B"><block type="math_number" id=";[@MC;+RFJk-Oj0;V8;6"><field name="NUM">0</field></block></value></block></value>
                                                        <value name="B"><block type="logic_compare" id="O72bla=|L8Lz47WRf3:e"><field name="OP">EQ</field>
                                                            <value name="A"><block type="get_value" id="y^!LL.nCFF,9br.)Rcm/"><field name="ATTR">val</field>
                                                            <value name="B"><block type="logic_boolean" id="tb~+vPby]Xz2tHuq1tT8"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                                                    <statement name="DO0"><block type="control" id="[dwzHn.nlns=7ZygD`P@"><mutation delay_input="false"></mutation>
                                                        <value name="VALUE"><block type="logic_boolean" id="VM}`(BgB%}0MmBCvRqgK"><field name="BOOL">FALSE</field></block></value>
                                                        <next><block type="debug" id="v1Y1=vjkx2#J^!NQ=ehf"><field name="Severity">log</field>
                                                            <value name="TEXT"><shadow type="text" id="=w9fhs[n;A41m}lAy@d%"><field name="TEXT">***Sonne nachmittag weg</field></shadow></value></block></next></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></statement>
            <next><block type="comment" id="aZ2ev/eW/hh(ON|#6QN^"><field name="COMMENT">Abfrage Temperatur Außen</field>
                <next><block type="on_ext" id="7,z@].TfiSVhfV-NYgAZ"><mutation items="1"></mutation>
                    <value name="OID0"><shadow type="field_oid" id="rEjxbS*^`GP{J:6Zk553"><field name="oid">hm-rpc.0.NEQ1100463.1.TEMPERATURE</field></shadow></value>
                    <statement name="STATEMENT"><block type="comment" id="R1b?TU=gt%1lDFGUTRn)"><field name="COMMENT">Aktuelle Temperatur</field>
                        <next><block type="controls_if" id="`5RefTXs(B)i#R%%E1+r"><mutation elseif="1"></mutation>
                            <value name="IF0"><block type="logic_compare" id="^!Fi,bdwG.XTSg#mm)yH"><field name="OP">GT</field>
                                <value name="A"><block type="get_value" id="ja+8D%Wlq0Z?dzqP7r7l"><field name="ATTR">val</field>
                                    <field name="OID">hm-rpc.0.NEQ1100463.1.TEMPERATURE</field></block></value>
                                <value name="B"><block type="text" id="AxH|zsgkq.|Nw%6OK4Xg"><field name="TEXT">16.1</field></block></value></block></value>
                            <statement name="DO0"><block type="control" id="nLH?R~{YL,5M3/;=^w7@"><mutation delay_input="false"></mutation>
                                <field name="OID">javascript.0.Temperatur</field>
                                <value name="VALUE"><block type="logic_boolean" id="~frbMi?G%~[KjVCQ-#:i"><field name="BOOL">TRUE</field></block></value>
                                <next><block type="debug" id="J_c-+Z^^+ssKe[2HTa-:"><field name="Severity">log</field>
                                    <value name="TEXT"><shadow type="text" id="{!1DpB7lf1/u1z)X3tz!"><field name="TEXT">*** Außentemperatur warm</field></shadow></value></block></next></block></statement>
                            <value name="IF1"><block type="logic_compare" id=")%4/VNgmmVHZ@flcpDFh"><field name="OP">LT</field>
                                <value name="A"><block type="get_value" id="t}E`rI8k_N?,ouFpYa1w"><field name="ATTR">val</field>
                                <value name="B"><block type="text" id="hD_oO]FIIY_v,w*8eMI0"><field name="TEXT">16</field></block></value></block></value>
                            <statement name="DO1"><block type="control" id="2pVT?[TWw4Su!%e^w3YH"><mutation delay_input="false"></mutation>
                                <value name="VALUE"><block type="logic_boolean" id="/C]Z54G(2bU.gKYeq:cn"><field name="BOOL">FALSE</field></block></value>
                                <next><block type="debug" id="*;ZY?GX1tOMSzB,qwXd%"><field name="Severity">log</field>
                                    <value name="TEXT"><shadow type="text" id="4N*fA3R=|9|YxDtLb!NI"><field name="TEXT">***Außentemperatur kühl</field></shadow></value></block></next></block></statement>
                            <next><block type="comment" id="#:oxk@|p.dfdIqcqqtMY"><field name="COMMENT">Tiefsttemperatur Nachts</field>
                                <next><block type="controls_if" id="UGkup1I3v^B1v31,]u-s"><value name="IF0"><block type="logic_operation" id="NA*SvxUv%,u]HPut*AR9"><field name="OP">AND</field>
                                        <value name="A"><block type="time_compare" id="Er]#dZmiT096wW?Bf;@p"><mutation end_time="false"></mutation>
                                            <field name="OPTION">==</field>
                                            <field name="START_TIME">03:00</field></block></value>
                                        <value name="B"><block type="logic_compare" id="i[.mk2^Nv2w-:]NuGFZ7"><field name="OP">LT</field>
                                            <value name="A"><block type="get_value" id="U1;IyB`U_;])xa|fF?81"><field name="ATTR">val</field>
                                            <value name="B"><block type="text" id=":sj!dItIB+HdPFfWezp8"><field name="TEXT">12</field></block></value></block></value></block></value>
                                    <statement name="DO0"><block type="control" id="#d)Ys!x]f?=}=)1wG)0n"><mutation delay_input="false"></mutation>
                                        <field name="OID">javascript.0.AußenTemperaturNachts</field>
                                        <value name="VALUE"><block type="text" id="=q%:YM9^ft3S7M6`Ch?o"><field name="TEXT">kühl</field></block></value></block></statement>
                                    <next><block type="controls_if" id="o2{Hec:.f-S[BCZH|~gL"><value name="IF0"><block type="logic_operation" id="qI%IjyS81C;gISX_2!hM"><field name="OP">AND</field>
                                            <value name="A"><block type="time_compare" id="A/7B+hk,Dfax:wPmP4g#"><mutation end_time="false"></mutation>
                                            <value name="B"><block type="logic_compare" id="/{zLh5VazNRP:o~!`xnc"><field name="OP">GT</field>
                                                <value name="A"><block type="get_value" id="XMvp9MuKmmF*;bls@`~v"><field name="ATTR">val</field>
                                                <value name="B"><block type="text" id="|oZH`]kqc`P@+HG7kHTb"><field name="TEXT">12.1</field></block></value></block></value></block></value>
                                        <statement name="DO0"><block type="control" id="B-wJtoVvzcQ{xt}G}tkq"><mutation delay_input="false"></mutation>
                                            <value name="VALUE"><block type="text" id="=]jp5{l=];4+`A~b_=PO"><field name="TEXT">warm</field></block></value></block></statement></block></next></block></next></block></next></block></next></block></statement>
                    <next><block type="comment" id="X*Ef!;L5GF/7suxDtmHD"><field name="COMMENT">Abfrage Wind</field>
                        <next><block type="on_ext" id="K(de=mCR#,!P*c6Y:F]S"><mutation items="1"></mutation>
                            <value name="OID0"><shadow type="field_oid" id="s3s()7EHK)ufjxJhKrTK"><field name="oid">hm-rpc.0.NEQ1100463.1.WIND_SPEED</field></shadow></value>
                            <statement name="STATEMENT"><block type="controls_if" id="?~q|Q[OA!ba,KzH-=jeY"><value name="IF0"><block type="logic_compare" id=".z?EAXF3F-d-CSxY2oic"><field name="OP">GT</field>
                                    <value name="A"><block type="get_value" id="mVio*BnNs7bz[y*hr52W"><field name="ATTR">val</field>
                                        <field name="OID">hm-rpc.0.NEQ1100463.1.WIND_SPEED</field></block></value>
                                    <value name="B"><block type="text" id="~F*TEA=B%;v?o`Glzmmn"><field name="TEXT">35,1</field></block></value></block></value>
                                <statement name="DO0"><block type="control" id="m1ose1GTtgx5,xbhYE`E"><mutation delay_input="false"></mutation>
                                    <field name="OID">javascript.0.Wind</field>
                                    <value name="VALUE"><block type="text" id="M[5|Az1s9ir+Ri[6u0~I"><field name="TEXT">Wind Stufe 1</field></block></value>
                                    <next><block type="debug" id="xGS%P79ci%opn=P~W*{D"><field name="Severity">log</field>
                                        <value name="TEXT"><shadow type="text" id="5Fal!NoLDxP/kzteCYE["><field name="TEXT">***Wind Stufe 1</field></shadow></value></block></next></block></statement>
                                <next><block type="controls_if" id="!~;z[}n=~=33BH3MY..g"><value name="IF0"><block type="logic_compare" id="H}u1|Anm5-qyjjAczuiT"><field name="OP">GT</field>
                                        <value name="A"><block type="get_value" id="Cg0tip=_t/4@IVRl,9|g"><field name="ATTR">val</field>
                                        <value name="B"><block type="text" id="Y~dX9#A58W1!=CZ7WeoC"><field name="TEXT">43</field></block></value></block></value>
                                    <statement name="DO0"><block type="control" id="X^5Z^z?Jpk(Z_[v8Ga8*"><mutation delay_input="false"></mutation>
                                        <value name="VALUE"><block type="text" id="CmQA[F6/JfzL[f|U3YV("><field name="TEXT">Wind Stufe 2</field></block></value>
                                        <next><block type="debug" id="5pK)Oi2{;w2yS6FS6l6["><field name="Severity">log</field>
                                            <value name="TEXT"><shadow type="text" id="^m9zf|8FHVGByI?;qxST"><field name="TEXT">***Wind Stufe 2</field></shadow></value></block></next></block></statement>
                                    <next><block type="controls_if" id="w6|7v=Sdw-1,z{,Qhmzp"><value name="IF0"><block type="logic_compare" id="D]lT,xb:gj0V!n=VDAhw"><field name="OP">LT</field>
                                            <value name="A"><block type="get_value" id="]3W[C5iQ4,:~eRhBm^r)"><field name="ATTR">val</field>
                                            <value name="B"><block type="text" id="UtpR5EoQ8rtjV]c{K(9|"><field name="TEXT">35</field></block></value></block></value>
                                        <statement name="DO0"><block type="control" id=".jyso.,CdgX#u7~P)2uL"><mutation delay_input="false"></mutation>
                                            <value name="VALUE"><block type="text" id="/{Z3me![Hs@YMz,EgEbn"><field name="TEXT">Kein Wind</field></block></value>
                                            <next><block type="debug" id="zG}V({]JlgY*kwxkul%b"><field name="Severity">log</field>
                                                <value name="TEXT"><shadow type="text" id="F{;!)tNl,dDm0m6.-nOv"><field name="TEXT">***Kein Wind</field></shadow></value></block></next></block></statement></block></next></block></next></block></statement>
                            <next><block type="comment" id="v~MV?RP]n#U5m]8^_Ho)"><field name="COMMENT">Abfrage Regen</field>
                                <next><block type="on_ext" id="FE`/TImiZzeZ~5P4+-OY"><mutation items="1"></mutation>
                                    <value name="OID0"><shadow type="field_oid" id="rjL*~9[Rku7Pzi%ywqS]"><field name="oid">hm-rpc.0.LEQ1288980.1.STATE</field></shadow></value>
                                    <statement name="STATEMENT"><block type="controls_if" id="%ts,q}!3,M-u3k^Wv3,w"><mutation elseif="1"></mutation>
                                        <value name="IF0"><block type="logic_compare" id="3bPUL*Hr,6(cM{.Ul2+b"><field name="OP">EQ</field>
                                            <value name="A"><block type="get_value" id="L{)XNNtIlztZlRhFprXO"><field name="ATTR">val</field>
                                                <field name="OID">hm-rpc.0.LEQ1288980.1.STATE</field></block></value>
                                            <value name="B"><block type="logic_boolean" id="_dPsLwjD?dvf79m}O4@1"><field name="BOOL">TRUE</field></block></value></block></value>
                                        <statement name="DO0"><block type="timeouts_cleartimeout" id="{OwF~K}!PB|C3pWI^zp;"><field name="NAME">timeout_Regen</field>
                                            <next><block type="control" id="_B6ii=u^#FOQMKM0~ck)"><mutation delay_input="false"></mutation>
                                                <field name="OID">javascript.0.Regen</field>
                                                <value name="VALUE"><block type="logic_boolean" id="9h%14idCSJ)Zww-~VoJ2"><field name="BOOL">TRUE</field></block></value>
                                                <next><block type="debug" id="w0=BI[3GhX|IVGuCu?s2"><field name="Severity">log</field>
                                                    <value name="TEXT"><shadow type="text" id=";6k6%@4D%_Fl`Dys81cD"><field name="TEXT">***Regen</field></shadow></value>
                                                    <next><block type="controls_if" id="?u/jDEjfj7Jz.Nffr|Ko" disabled="true"><value name="IF0"><block type="logic_compare" id="j?2(k.k].sH,:^;%bDb^"><field name="OP">EQ</field>
                                                            <value name="A"><block type="variables_get" id="kWrmCdA4:oL`|zk|-=r}"><field name="VAR">Regen_push</field></block></value>
                                                            <value name="B"><block type="logic_boolean" id="d3xBP}2*L.B(Q@at_OEm"><field name="BOOL">FALSE</field></block></value></block></value>
                                                        <statement name="DO0"><block type="pushover" id="ei(z_l.-T34cdCAO7P=a"><field name="INSTANCE">.0</field>
                                                            <field name="PRIORITY">0</field>
                                                            <field name="LOG">debug</field>
                                                            <value name="MESSAGE"><shadow type="text" id="[N{KFm+TArs_OPQ`pTGE"><field name="TEXT">Es regnet in Braak</field></shadow></value>
                                                            <next><block type="variables_set" id="T^[+6)ppO/AMk6q_+mI~"><field name="VAR">Regen_push</field>
        <value name="VALUE"><block type="logic_boolean" id="17O.3-Yj=2|--omd;vfZ"><field name="BOOL">TRUE</field></block></value></block></next></block></statement></block></next></block></next></block></next></block></statement>
                                        <value name="IF1"><block type="logic_compare" id="`Pz^)jiw,=aT:2*;=j1S"><field name="OP">EQ</field>
                                            <value name="A"><block type="get_value" id="@GTwWN{#a;X%^tKd0o^x"><field name="ATTR">val</field>
                                            <value name="B"><block type="logic_boolean" id="oUHbso]%wb,5_31.)eKO"><field name="BOOL">FALSE</field></block></value></block></value>
                                        <statement name="DO1"><block type="timeouts_settimeout" id="b_MyrWSc%gTiH|Oa1eNc"><field name="NAME">timeout_Regen</field>
                                            <field name="DELAY">7</field>
                                            <statement name="STATEMENT"><block type="control" id="-!3H62_/4}:7WB,a8~A("><mutation delay_input="false"></mutation>
                                                <value name="VALUE"><block type="logic_boolean" id="l(KF5-BVSs)G+CuMx6I_"><field name="BOOL">FALSE</field></block></value>
                                                <next><block type="variables_set" id="-L2Ka4fIJAE^v+XVwn1+" disabled="true"><field name="VAR">Regen_push</field>
                                                    <value name="VALUE"><block type="logic_boolean" id="MH6_{#OOip0Zg3*o^YR_"><field name="BOOL">FALSE</field></block></value>
                                                    <next><block type="debug" id="Y~M4~W8vo7O{HKJ,u*,u"><field name="Severity">log</field>
                                                        <value name="TEXT"><shadow type="text" id="6Y5_mH6_ar=m!SXSs];+"><field name="TEXT">***Kein Regen</field></shadow></value></block></next></block></next></block></statement></block></statement></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block>
          <block type="create" id="}=Y-O-vl`*2YuCcv_F^*" x="-2788" y="4237"><field name="NAME">Sonne vormittag</field>
            <statement name="STATEMENT"><block type="create" id="4434IyAnZn93df[8IL)B"><field name="NAME">Sonne nachmittag</field>
                <statement name="STATEMENT"><block type="create" id="08D_xiK+@q-Cwp#{9j|4"><field name="NAME">Temperatur</field>
                    <statement name="STATEMENT"><block type="create" id="c6,QVVu?U2CJiT*E=Pp*"><field name="NAME">Wind</field>
                        <statement name="STATEMENT"><block type="create" id="1At9e*9_D.Nm?V/plCkh"><field name="NAME">Regen</field></block></statement></block></statement></block></statement></block></statement></block>
          <block type="create" id="q.YGV]LYAqg[6=A)Pv/+" x="-2748" y="4317"><field name="NAME">Sonne vormittag</field>
            <statement name="STATEMENT"><block type="create" id="DWxso}y[DrtacF4Q]@Up"><field name="NAME">Sonne nachmittag</field>
                <statement name="STATEMENT"><block type="create" id="mEc#HPl1?xXK5XpS:5ax"><field name="NAME">Temperatur</field>
                    <statement name="STATEMENT"><block type="create" id="=|8=g*dM0k3or(4cOe%m"><field name="NAME">Wind</field>
                        <statement name="STATEMENT"><block type="create" id="d[6|S2QCtL}S8NG9a8;a"><field name="NAME">Regen</field></block></statement></block></statement></block></statement></block></statement></block></xml>
        3472_abfrage_klimadaten_au_en.txt
          MartinBr last edited by
          Hallo smile,
          ich finde dein Script klasse. Ich bin gerade dabei, die Scripte zu installieren. Dabei ist mir aufgefallen, dass eine Menge an Variablen nicht gesetzt werden. Dein Init-Script setzt nur einige (z.B. Sonne nachmittag). Die Wetter Temperatur, Wind, Regen und Sonneneinstahlung habe ich zugeordnet.
          Andere werden leider nicht initial gesetzt, z.B. Energiegewinnungs-Modus …
          Kannst du mir da weiter helfen?
          Martin
          • smile
            Was meinst du damit dass einige Variablen nicht gesetzt werden?
            Die Init Blöcke habe ich mittlerweile komplett deaktiviert. Das ganze läuft dadurch für mich besser, weil z.B. die Beschattungen nicht hochfahren wenn ich diese Manuell runtergefahren hatte, das Script dabei deaktiviert hatte und es dann wieder neu aktiviere.
            Vielleicht kannst du erklären was genau bei dir nicht klappt?
              MartyBr last edited by Negalein
              Hallo smile,
              ich habe mir jetzt ein Script geschrieben, um einige Variablen initial zu setzen.
              // https://forum.iobroker.net/viewtopic.php?f=21&t=7951&start=40
              //Input
              createState('Rolladen.Wind', {
                  read: true,
                  write: true,
                  type: "string"
              createState('Rolladen.Temperatur', {
                  read: true,
                  write: true,
                  type: "string"
              createState('Rolladen.Regen', {
                  read: true,
                  write: true,
                  type: "string"
              createState('Rolladen.Sonne nachmittag', {
                  read: true,
                  write: true,
                  type: "string"
              createState('Rolladen.Sonne vormittag', {
                  read: true,
                  write: true,
                  type: "string"
              createState('Rolladen.Solltemperatur_WHZ', {
                  read: true,
                  write: true,
                  type: "number"
              createState('Rolladen.Solltemperatur_Bad', {
                  read: true,
                  write: true,
                  type: "number"
              createState('Rolladen.Solltemperatur_Schlaf', {
                  read: true,
                  write: true,
                  type: "number"
              createState('Rolladen.InnenTemperatur', {
                  read: true,
                  write: true,
                  type: "number"
              createState('Rolladen.InnenTemperatur_Bad', {
                  read: true,
                  write: true,
                  type: "number"
              createState('Rolladen.InnenTemperatur_Schlaf', {
                  read: true,
                  write: true,
                  type: "number"
              createState('Rolladen.Energiegewinnungs-Modus', {
                  read: true,
                  write: true,
                  type: "boolean"
              createState('Rolladen.Energiegewinnungs-Modus_Schlafzimmer', {
                  read: true,
                  write: true,
                  type: "boolean"
              createState('Rolladen.AussenTemperaturNachts', {
                  read: true,
                  write: true,
                  type: "string"
              createState('Rolladen.Count_Sonne_Nachmittag', {
                  read: true,
                  write: true,
                  type: "number"
              createState('Rolladen.Count_Sonne_Vormittag', {
                  read: true,
                  write: true,
                  type: "number"
              createState('Rolladen.Count_Sonne', {
                  read: true,
                  write: true,
                  type: "number"
              Bei einigen Variablen bin ich mir nicht sicher, welchen Wert du abfragst.
              Z.B.
              • smile
                @MartyBr:
                Z.B.
                ![](</s>/Users/martin/Documents/iobriker.png) ` ~~In dem Beispiel prüfe ich erst, ob die jeweilige Beschattung / Rollo gerade ein oder -ausgefahren ist. Wenn der "Level" 100 ist, dann ist sie bei mir eingefahren. Der Homematic Schalter darunter "Press_Short" ist lediglich ein interner Homematic Schalter und gleichzusetzen mit "Steuere Rollo auf Level 0", mit anderen Worten das ausfahren des Rollos.
                Die Abfrage is also nur dafür da, damit der Rolladenaktor nicht immer wieder schaltet, wenn die Beschattung bereits in der gewünschten Stellung ist.~~
                  Fox1985 last edited by Negalein
                  ich habe ein Problem mit meiner gebauten Steuerung und Denke für etwas mehr Ordnung schreibe ich es hier hin.
                  Ich habe folgende Hardware verbaut.
                  Raspberrymatic mit dem CUL Stick –> steuert die Somfy Markise
                  einen Temperatur Differenz Sensor (ein Fühler weiß, einer schwarz) auf Kanal 3 rufe ich die Differenz ab
                  Einen Homematic Fensterkontakt habe ich zum Regensensor umgebaut.
                  Ich möchte dies nun mit einem Blockly Skript steuern,
                  aber leider funktioniert es nicht wirklich.
                  Meine Vorstellung ist folgende:
                  Wenn der Differenz Sensor auf Kanal 3 einen Wert von 5°C misst, soll gerpüft werden ob es regnet.
                  Wenn es nicht regnet, soll die Markise raus fahren.
                  Einfahren dachte ich, mache ich selbst.
                  Wenn es zu regnen beginnt, soll die Markise sofort rein fahren.
                  Problem ist nun, die Markise fährt ständig raus, auch wenn der Sensor keine Differenz von 5 hat.
                  ich hoffe Ihr könnt mir helfen.
                  Stefan
                  • rantanplan
                    rantanplan last edited by
                    In Deinem ersten Trigger fehlt eine UND Abfrage.
                    Falls "wert vom …. >5" UND "Wert vom …. = unwahr"
                    Zudem eventuell beide Trigger auf "wurde geändert" setzen.
                      @rantanplan:
                      Grüße ` Hallo rantanplan,
                      Danke für deine Antwort.
                      Ich verstehe nicht genau was du meinst,
                      Ich habe doch die UND Abfrage eingebaut.
                      (externer Eingang)
                      Oder was meinst du?
                      Viele Grüße
                      Gesendet von meinem ONEPLUS A3003 mit Tapatalk
                      • rantanplan
                        @Fox1985:
                        (externer Eingang)
                        Oder was meinst du? `
                        Ne, hast Du nicht.
                        Bei steht "Falls Wert >5" = "Wert = unwahr"
                        Das kann nicht funktionieren.
                        Du solltest den "UND" Block nehmen nicht den "=" Block.
                          :oops: Peinlich,
                          Rantanplandu hattest natürlich vollkommen Recht.
                          Habe es geändert und es funktioniert jetzt wunderbar.
                          Vielen Dank
                          • smile
                            @Fox1985
                            sehr cool, das mit dem umgebauten Fensterkontakt in Kombination mit einem normalen, drahtgebundenen Regensensor mache ich auch so 😄
                            Eine Frage: Die Somfy Markisen die du steuerst, haben die RTS oder IO Funkmotoren? Woher hast du die Infos bezüglich der Ansteuerung bezogen?
                            Danke und viele Grüße
                              @smile:
                              @Fox1985
                              Danke und viele Grüße ` Habe einen RTS Motor und steuer den per CUL an. Der bangt noch an meiner CCU2.
                              Im homematic forum gibt es dazu eine Anleitung.
                              Die Idee mit dem Fensterkontakt habe ich mal in einem Youtube Video gesehen.
                              EDIT:
                              aus diesem Video habe ich die Idee gehabt:
                              https://www.youtube.com/watch?v=y4xGgx2yNXE
                              und so hält auch die Batterie länger:
                              https://www.youtube.com/watch?v=98BFtiwxjzE
                                Hallo nochmal,
                                habe nun nach zwei Monaten endlich meine Xiaomi Fensterkontakte aus China geliefert bekommen :roll:
                                Nun sitze ich am Script für die Terrassentüre.
                                Ich will den Rolladen so steuern, dass wenn die Türe offen ist (sich noch einer auf der Terrasse befindet) der Rolladen als einziger noch oben bleibt.
                                Wird die Türe dann geschlossen, soll der Rolladen sich automatisch schließen.
                                ich habe schon einmal angefangen,komme aber nicht so recht weiter.
                                Könnt ihr mir bitte helfen?
                                Viele Grüße
                                  bishop last edited by
                                  ich bekomme auch ein texttype error wie muckel!
                                  was fehlt mir da?
                                  Ich würde gerne die Sonne ermittlen den rest brauche ich erst einmal noch nicht.
                                  @muckel:
                                  Hallo Smile!
                                  Danke im Voraus
                                  Liebe Grüße `
                                  Ist der Helligkeitswert in Lux?
                                  • smile
                                    Hi, das ist ja seltsam.
                                    Hier kommt nochmal das Skript zum Erfassen der Wetterdaten:
                                    3472_klimadaten_au_en_erfassen.txt
                                    Der Helligkeitswert der Homematic Wetterstation ist meiner Ansicht nache ein willkürlicher Wert, da der denke ich nicht mit tatsächlichen Lux Werten übereinstimmt.
                                    Letztendlich ist das aber auch egal, da die Hauptsache ja ist dass ein Helligkeitswert abgefragt wird und man diesen entsprechend verarbeiten kann.
                                    • smile
                                      smile last edited by smile
                                      Update 21.04.2019:
                                      • Verzögerung für das Ein / Ausfahren der Beschattung bei Überschreitung der Höchsttemperatur hinzugefügt
                                      • Wind Stufen Variable als reine Ziffer (0, 1, 2) gesetzt, dadurch ist die Variable in Datenbanken (z.B. InfluxDB) besser lesbar
                                      • Energiegewinnung im April angepasst: Zusätzliche Außentemperaturvariable hinzugefügt, damit bei sehr kalter Außentemperatur der Innenraum noch mehr Wärme puffert, bevor die Rolläden wieder runterfahren.
                                      • Kleinere Korrekturen
                                      Blockly-Exporte:
                                      https://forum.iobroker.net/post/101260
                                        MartyBr @smile last edited by
                                        @smile
                                        Hallo smile,
                                        die beiden Beschattungsscripte werfen beim Import immer einen Fehler aus. Den Kopf hatte ich gelöscht, dass hilft leider nicht.
                                        Kannst du die Scripte nochmal einstellen?
                                        Martin
                                          muckel @smile last edited by
                                          @smile
                                          Hallo Smile,
                                          ich wollte mir mal ansehen wie du deine Rollladen Steuerst.
                                          Leider kann ich deine beiden "Beschattung" Exports nicht importieren.
                                          Kannst du diese bitte nochmals hochladen.
                                          Danke im Voraus
                                          liebe Grüße
                                          • smile
                                            habe ich soeben neu exportiert und hochgeladen. Könnt ihr bitte mal überprüfen ob es jetzt funktioniert?
                                            Hier nochmal die Exporte direkt:
                                            Beschattung Auto Regen / Wind
                                              <block type="comment" id="IR94DiuG7v6~=Zg2dVp6" x="-862" y="4413">
                                                <field name="COMMENT">Variablen initialisieren</field>
                                                  <block type="procedures_callnoreturn" id="iW:+%8blE]XvSDS~rIw5">
                                                    <mutation name="InitVariablen"></mutation>
                                                      <block type="comment" id="_:tJ@Ut#F5ws5(QdD#18">
                                                        <field name="COMMENT">Variablen überwachen</field>
                                                          <block type="comment" id="Mlyo7L0-(5%m9dgr4!hg">
                                                            <field name="COMMENT">Wenn sich eine ändert, startet Trigger</field>
                                                              <block type="on" id="y@5W3=xOld/#5OvGuT#C">
        <field name="OID">javascript.0.Klima.wind_stufe</field>
        <block type="comment" id="nV@fJn+(nfLo:a.DqSPZ">
        <field name="COMMENT">Beschattung einfahren Wind</field>
        <block type="controls_if" id="j*450vq]+6x`;5`RpE3W">
        <block type="logic_compare" id="T.iWvUC3YT,_qkwZRI~z">
        <block type="get_value" id="orO,yL!f7A;MnSWeI.{h">
        <block type="math_number" id="OuKRKY`f50YNI;t~}Haf">
        <block type="controls_if" id="RC.KplK!tWqDx(Ktf7%:">
        <block type="logic_compare" id="NKPEgVSX:aAu5#eFxQU_">
        <block type="get_value" id="Y6lJQhjx_-|BzhMdc)3Z">
        <field name="OID">hm-rpc.2.LEQ0170301.3.LEVEL</field>
        <block type="text" id="wy4`]h,[K]M~|0A,~y}:">
        <field name="TEXT">99</field>
        <block type="control" id="^}Ar,2GR{NE=mf)}b79#">
        <field name="OID">hm-rpc.2.BidCoS-Wir.9.PRESS_SHORT</field>
        <block type="logic_boolean" id="Q0=nDX@WJ3jK(z:J/57n">
        <block type="debug" id="D~*Q!irXwb3Yd2{TixJ/">
        <value name="TEXT">
        <shadow type="text" id="~^+nNp!mfk*)MP-;}VH1">
        <field name="TEXT">***Beschattung Wind hoch</field>
        <block type="controls_if" id="--(`Xxj:!+nr8IA6@TUd">
        <block type="logic_compare" id="2:CXtVM`:-ws{E?{J%J0">
        <block type="get_value" id=",5IWlhV5Wn_)MaFECLYi">
        <field name="OID">hm-rpc.2.LEQ0170348.3.LEVEL</field>
        <block type="text" id="~8}Mu`^G]%=awkrB{9Hv">
        <block type="control" id="/jT[fmN;+8yFxt(~toyB">
        <field name="OID">hm-rpc.2.BidCoS-Wir.7.PRESS_SHORT</field>
        <block type="logic_boolean" id="R0TCv3yy=Kw#iIh,Bzzq">
        <block type="comment" id="0g*Rze/X.nfp[Y6v*?_s">
        <field name="COMMENT">Raffstore einfahren Wind</field>
        <block type="controls_if" id="pS8P;CPTP7S9q3YMWE,B">
        <block type="logic_compare" id="*ngIY~p[N=O[-MVPghdj">
        <block type="get_value" id="8k2)AQwoTs!P?X6Pb!_h">
        <block type="text" id="0aC_-BYzC[#*^SEv)b9~">
        <field name="TEXT">1</field>
        <block type="controls_if" id="i?CB2}QCY3F~@wUj[CCe">
        <block type="logic_compare" id="8bqKiPG`}!ZY+K2k,+hF">
        <block type="get_value" id="^]#k3E?/4ug%H.Er3o6C">
        <field name="OID">hm-rpc.0.LEQ0904694.1.LEVEL</field>
        <block type="text" id=",rI3ve}Zz62EA4]*cRf#">
        <block type="control" id="KX[P)di[Ku}aWK[WrRaR">
        <field name="OID">hm-rpc.0.BidCoS-RF.29.PRESS_SHORT</field>
        <block type="logic_boolean" id="X;PIq}rO!47ek9xN-CE!">
        <block type="debug" id="pgQYRUIt4|2s/C{lD*]P">
        <value name="TEXT">
        <shadow type="text" id="Kp;,#xJP!AiIahG2MVem">
        <block type="controls_if" id="Sh6-H?=2dcmrZs9nVAZ`">
        <block type="logic_compare" id="2j~-M6V2W-*q2@j-FzFQ">
        <block type="get_value" id="T?|QvwR]9E8owUFJin.Q">
        <field name="OID">hm-rpc.0.JEQ0300111.1.LEVEL</field>
        <block type="text" id="YvhYmdjDUM*C}V/*B}D[">
        <block type="control" id="{L@|)LA6xMYnoJ*_hH{M">
        <field name="OID">hm-rpc.0.BidCoS-RF.31.PRESS_SHORT</field>
        <block type="logic_boolean" id="kg2By/m],xH+KbZ_sL*:">
        <block type="comment" id="T)B*3eml#*`fvrb(,`r,">
        <field name="COMMENT">Rollo einfahren Wind</field>
        <block type="controls_if" id="ZQVeHI6`tw-16{sPs,PH">
        <block type="logic_compare" id="Rbo~%5aF#t!NDha|=)OB">
        <block type="get_value" id="B6Kcvv}T5/z=,=hke!DY">
        <block type="text" id="R2j/ov@w2sVqtj_#5q{;">
        <field name="TEXT">2</field>
        <block type="controls_if" id="_89.*[X!)P-(sh_~}b[f">
        <block type="logic_compare" id="/J#Esk-FCxOf.uV_V,8F">
        <block type="get_value" id="E|j8P4qocc72Ut[2w{So">
        <field name="OID">hm-rpc.0.JEQ0299861.1.LEVEL</field>
        <block type="text" id="vawKr8aw-)/E,3r-yJwD">
        <block type="control" id="u^IQ/tb!]nqifIm=%u3e">
        <field name="OID">hm-rpc.0.BidCoS-RF.14.PRESS_SHORT</field>
        <block type="logic_boolean" id=":_Fui~]f%i)4!u|vIl)N">
        <block type="debug" id="qO.v*_T%-Ybquu]XMBok">
        <value name="TEXT">
        <shadow type="text" id="!27r.U={ZGs[0=-l^zUB">
        <field name="TEXT">***Rollo Einfahren Wind</field>
        <block type="controls_if" id="o;BlSq()74UA3#,?N;%+">
        <block type="logic_compare" id="f.p;j0)B)7Ws~)99?8,9">
        <block type="get_value" id="ZI-;y?7KR]Lgh?U?Brs6">
        <field name="OID">hm-rpc.0.JEQ0299851.1.LEVEL</field>
        <block type="text" id="YA~dTN@H8y5lnu(zFjQ5">
        <block type="control" id="FN8sn|ps*/U}n|cFb%2!">
        <field name="OID">hm-rpc.0.BidCoS-RF.16.PRESS_SHORT</field>
        <block type="logic_boolean" id="M7l8Q+qof)_2eDhkw([8">
        <block type="controls_if" id="W1Kctj2#XVS)TNVJ:%=G">
        <block type="logic_compare" id="*}jBtnO.Yh5JlU5oM~;;">
        <block type="get_value" id="#ZBmxEnoTTvGb_rSmt{h">
        <block type="text" id="@{pL#Y6g.fOPk/z.(GAh">
        <block type="controls_if" id="/XfXK_@R}pvGYSJ^I*nn">
        <block type="logic_compare" id="Vkv;-Z#(6=PO:x6BXRr5">
        <block type="get_value" id=";0_F{D.ngpcdp%x5e7pb">
        <field name="OID">hm-rpc.0.LEQ0904951.1.LEVEL</field>
        <block type="text" id="t,@FP,Zlh=zR=JC?l+=+">
        <block type="control" id="5]T9.pHFS!v.{b:y25Jm">
        <field name="OID">hm-rpc.0.BidCoS-RF.25.PRESS_SHORT</field>
        <block type="logic_boolean" id="1c,n=1mDGq(?1JDF}G07">
        <block type="debug" id="%*GGYD7UeWQN-~`.h6Ng">
        <value name="TEXT">
        <shadow type="text" id="Ld1Dea?Coc.[-HJn3hg7">
        <block type="controls_if" id="mvq.anzvxMp@,yt@otQO">
        <block type="logic_compare" id="xi.A(Ezol-=:`oxV|nvW">
        <block type="get_value" id=")-eA`9r.A!O}yvpPar[E">
        <field name="OID">hm-rpc.0.JEQ0299881.1.LEVEL</field>
        <block type="text" id=";=`NBe~}20{1?o7IW1s{">
        <block type="control" id="}+}.*K_kZfkiEtA_S)x*">
        <field name="OID">hm-rpc.0.BidCoS-RF.27.PRESS_SHORT</field>
        <block type="logic_boolean" id="lkxjpqRd@-,DFa=6Y^fJ">
        <block type="on" id="iR~z89N=QTy2HXjmtbs9">
        <field name="OID">javascript.0.Klima.regen</field>
        <block type="comment" id="|rGMiBg8C^PJsN#Z,vhE">
        <field name="COMMENT">Beschattung / Rollo einfahren Regen</field>
        <block type="controls_if" id="P1^IBjxiuHr~7J{)7t5Z">
        <block type="logic_compare" id="(GvP7StBSOY#cWn#?G(k">
        <block type="get_value" id="T:n1;WGsH@P3kqD)K.?I">
        <block type="logic_boolean" id="eH[`y9s0qL-e]ra4Vx))">
        <block type="controls_if" id="~l%{.TC|kLE5x`7at[b~">
        <block type="logic_compare" id="3qWo*3@^lc`.m|Ck2fJ~">
        <block type="get_value" id="yZE+N8Q=7y]-Xzd:+9%P">
        <block type="math_number" id="@r{^W;!9EJ^oIQkZ;+|9">
        <field name="NUM">98</field>
        <block type="control" id="^t{Nu27U7K^dwOU#1]D*">
        <block type="logic_boolean" id=".JA{8rL4lMLgZC^Qq+~q">
        <block type="debug" id="`iUbc{K6Ejf?,`[TCL!d">
        <value name="TEXT">
        <shadow type="text" id="MIkXiVth+#Xf}KtobT3e">
        <field name="TEXT">***Beschattung Regen hoch</field>
        <block type="pushover" id="#5ms{;QZa(.}VT1UJ0:B">
        <field name="SOUND"></field>
        <field name="LOG"></field>
        <shadow type="text" id="=Z`^JO85E:VB}i~Yu(Fc">
        <field name="TEXT">Beschattung fährt hoch wegen Regen</field>
        <block type="controls_if" id="qVNwND{O]OhvIZ!j!5lN">
        <block type="logic_compare" id="eON!u_|zL]YvE7CF^TW/">
        <block type="get_value" id="/_]J?6g|p5#bsh#tw3]X">
        <block type="math_number" id="vzNLi-iveVhUE-V:Dy(#">
        <field name="NUM">99</field>
        <block type="control" id="2Yd^=#WM9A/Rx%0~r.nB">
        <block type="logic_boolean" id="r-CS}lco!%rhJZ(phuJh">
        <block type="controls_if" id="v]Z?H3gQqO/mXJ,@)Gi:">
        <block type="logic_compare" id="~ec+io`8;+u?^V|MBm*{">
        <block type="get_value" id="CO*T5oh:s3TEgv=a:Wbo">
        <block type="math_number" id="X/}d.d~A##kuIl,_/aLl">
        <block type="control" id="gd^Hj3l_%m]CQF:fiD?M">
        <block type="logic_boolean" id="!Yn|HE[Op}f52S?vXnNh">
        <block type="debug" id="v3Rty4%his,Rb2IOGK9:">
        <value name="TEXT">
        <shadow type="text" id="oVs~3d`?aearKsb?@h7H">
        <field name="TEXT">***Rollo Regen hoch</field>
        <block type="controls_if" id="z6h!y1MjQr]swF%X69(D">
        <block type="logic_compare" id="LM7pp|O_%Vh2FtM6fpss">
        <block type="get_value" id="o3]7u/KI2VHyp?oo1~Fz">
        <block type="math_number" id="ux;9!|36Moj+%J=CfZyz">
        <block type="control" id="CBu;E{DZqeHPEGoG=A~}">
        <block type="logic_boolean" id="M[}q[F+Qf_O5w8eO4FN9">
        <block type="controls_if" id="b+xxr^Gbc4]uT5/#[|kA">
        <block type="logic_compare" id="|yE]Y#6sgFa(XKL~r{CQ">
        <block type="get_value" id="[pHmUEhYxJSOk,Jrqc5;">
        <block type="math_number" id="Uhnz7GCx@O[dds=A]E4-">
        <block type="control" id="t)97)nK76NhZUbuSTL)*">
        <block type="logic_boolean" id="?[2h;I9-3Q1}IY^~/RJp">
                                              <block type="procedures_defnoreturn" id="(+6Mz{Je,L}7n^5*t*wO" x="-362" y="4463">
                                                <field name="NAME">InitVariablen</field>
                                                <statement name="STACK">
                                                  <block type="control" id="p?`r0r!rP+l-DL?HVpBE">
                                                      <block type="text" id="=23O/zB:VZ!/%Yx%uWR!">
                                                        <field name="TEXT">0</field>
                                              <block type="control" id="d:8g!N[q^)G{PlAhNaz-" disabled="true" x="-337" y="4563">
                                                  <block type="text" id="O0b3a)p_H.ZWmX)incoT">
                                                    <field name="TEXT"></field>
                                            Das Sonnen Automatik Blockly ist zu groß, das kann ich nut als .txt Datei hochladen.
                                            Wurde wie gesagt gerade frisch gemacht. Müsste gehen.
                                            blockly climate
                                            18
                                            80
                                            31822
