    4. Adapter: iobroker.backitup (stable Release)
      JackWolfskind last edited by
      Auf sowas hab ich auch gewartet 😄
      Auf meinem Raspberry lässt sich der Adapter aktuell allerdings noch nicht installieren:
      iobroker	2018-07-05 08:37:44.798	info	exit 0
      iobroker	2018-07-05 08:37:44.665	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      iobroker	2018-07-05 08:37:44.665	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuil
      iobroker	2018-07-05 08:37:44.663	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      iobroker	2018-07-05 08:37:44.659	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      iobroker	2018-07-05 08:37:44.658	info	npm
      iobroker	2018-07-05 08:37:44.653	info	ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.node-red/package.json'
      iobroker	2018-07-05 08:37:44.651	info	enoent
      iobroker	2018-07-05 08:37:44.648	info	WARN
      iobroker	2018-07-05 08:37:44.646	info	npm
      Cannot	2018-07-05 08:37:37.063	error	read /proc/meminfo: TypeError: text.match is not a function
      iobroker	2018-07-05 08:37:36.295	info	node-gyp -v v3.6.2gyp ERR! not ok
      iobroker	2018-07-05 08:37:36.291	info	gyp ERR!
      iobroker	2018-07-05 08:37:36.291	info	gyp ERR! node -v v6.13.1
      iobroker	2018-07-05 08:37:36.291	info	gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      iobroker	2018-07-05 08:37:36.291	info	ERR! System Linux 4.9.80-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      iobroker	2018-07-05 08:37:36.289	info	gyp
      iobroker	2018-07-05 08:37:36.289	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
      iobroker	2018-07-05 08:37:36.289	info	gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      iobroker	2018-07-05 08:37:36.289	info	gyp ERR! stack at emitTwo (events.js:106:13)
      iobroker	2018-07-05 08:37:36.289	info	ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:258:23)
      iobroker	2018-07-05 08:37:36.286	info	gyp
      iobroker	2018-07-05 08:37:36.278	info	ERR! build error
      iobroker	2018-07-05 08:37:36.277	info
      iobroker	2018-07-05 08:37:36.272	info	gyp
      iobroker	2018-07-05 08:37:36.259	info	make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
      iobroker	2018-07-05 08:37:36.244	info	compilation terminated.
      iobroker	2018-07-05 08:37:36.244	info	^
      iobroker	2018-07-05 08:37:36.244	info	../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
      • simatec
        Was hast du für eine node Version laufen?
        Schaue mal bitte in der Konsole mit „node -v“
          apollon77 last edited by
          Laut ausgaben dort sollte es node 6 sein.
          Bitte mal ein vollständiges Log posten! Da fehlt der Befehl für die Installastion und so.
          Das Exit 0" am Ende sagt an sich das alles ok gelaufen ist - trotz der Warnungen zu optionalen Paketen.
          Was genau geht denn nicht?
          Falls Du "Nur" keine Instanz hast dann ist das bei GitHub installs normal. Musst Du manuell anlegen
          • simatec
            Was mich verwundert ist die Zeile.
            Stimmt die node Version steht im Log.
            Hatte ich auf dem Handy überlesen :oops:
              Stimmt, Instanz läst sich ja doch anlegen - und läuft dann auch 🙂
              War von den vielen Fehlern im log zunächst doch überrrascht, aber ist doch alles gut …
              • simatec
                Poste bitte trotzdem mal den kompletten Log.
                Würde gerne den Fehler suchen [emoji51]
                • enzo
                  enzo last edited by
                  Und was ist mit Multihost Modus ?
                  • simatec
                    @enzo:
                    Und was ist mit Multihost Modus ? `
                    Ist auf unserer Todo
                      @simatec:
                      Würde gerne den Fehler suchen [emoji51] `
                      Denke nicht das Du da was findest weil hat nichts mit dem Adapter zu tun!!
                      Die "authenticvate_pam" Fehler (und damit das ganze node-gyp zeug) kommt vom js-controller und liegt daran das er ein bestimmtes Debian-Paket nicht installiert hat. Den Fehler müste er bei jeder Adapterinstallation/Update bekommen.
                      Andere Fehler kommen auch von js-controller und sollten da auch schon gefixt sein.
                      Diese Verison 3.x ist die bon node-gyp (dem Bei Bedarf kompilieren tool) und auch Ok.
                      Also: tiefer rein blicken bringt hier nichts weil es nichts mit dem Adapter zu tun hat!
                      • simatec
                        Ahh ok … danke für den Tipp.
                        Wollte nur sicher gehen 😉
                          Dann hier mal noch Dev-Feedback:
                          • Verzeichnisse widget und www weg wenn Du Sie nicht brauchst/anbietest.
                          • Wenn der Adater nodejs 4 nicht supportet dann bitte in die package.json eine entsprechende "engine "minimumversion rein und Testing für node 4 rausnehmen. Dann sollte Testing auch grün werden.
                          • Bitte "Changelog" in der Readme nur "Changelog" nennen damit es in Admin 3 korrekt angezeigt wird und auch License Abschnitt ans Ende hängen
                          • In der io-package sind einige Zeichen kaputt. AM besten kodiereung des Files auf UTF-8 und so 🙂
                          • io-package: ohne Widget brauchst Du kein "restartAdapters".
                          • io-package: Bitte nur die "die sprachen in "docs" listen die auch da sind.
                          • immer angelegte gleiche Datenpunkte könntest Du auch in der io-package definieren, dann werden die automatisch angelegt und du brauchst keinen Code dafür …
                          Sonst wenig Kommentare. Cooes Teil!
                          Wenn es getestet ist meldet es bitte fürs Repo an.
                            @apollon77:
                            @simatec:
                            Also: tiefer rein blicken bringt hier nichts weil es nichts mit dem Adapter zu tun hat! `
                            Eine Idee welches Debian Package da fehlen könnte?
                            Der Fix für den Fehler im js-controller ist aber noch nicht verfügbar, oder ?
                            • simatec
                              Hallo apollon77,
                              danke für das super Feedback.
                              Hier gleich mal die Antworten und Fragen dazu. 😄
                              @apollon77:
                              • io-package: Bitte nur die "die sprachen in "docs" listen die auch da sind. `
                              Die Punkte habe ich gerade alle erledigt …
                              @apollon77:
                              • Wenn der Adater nodejs 4 nicht supportet dann bitte in die package.json eine entsprechende "engine "minimumversion rein und Testing für node 4 rausnehmen. Dann sollte Testing auch grün werden. `
                              Macht es Sinn nodejs 4 nicht zu supporten? Aktuell habe ich das Gefühl, dass der Fehler beim testing am "child_process" Paket liegt.
                              npm WARN optional dep failed, continuing fsevents@1.2.4
                              child_process@1.0.2 node_modules/child_process
                              gyp WARN download NVM_NODEJS_ORG_MIRROR is deprecated and will be removed in node-gyp v4, please use NODEJS_ORG_MIRROR
                                CXX(target) Release/obj.target/diskusage/src/main.o
                              make: g++-4.8: No such file or directory
                              make: *** [Release/obj.target/diskusage/src/main.o] Error 1
                              gyp ERR! build error
                              gyp ERR! stack Error: `make` failed with exit code: 2
                              gyp ERR! stack     at ChildProcess.onExit (/Users/travis/.nvm/versions/node/v4.9.1/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                              gyp ERR! stack     at emitTwo (events.js:87:13)
                              gyp ERR! stack     at ChildProcess.emit (events.js:172:7)
                              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
                              gyp ERR! System Darwin 16.7.0
                              gyp ERR! command "/Users/travis/.nvm/versions/node/v4.9.1/bin/node" "/Users/travis/.nvm/versions/node/v4.9.1/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                              gyp ERR! cwd /Users/travis/build/simatec/ioBroker.backitup/node_modules/iobroker.js-controller/node_modules/diskusage
                              gyp ERR! node -v v4.9.1
                              gyp ERR! node-gyp -v v3.4.0
                              gyp ERR! not ok
                              > unix-dgram@0.2.3 install /Users/travis/build/simatec/ioBroker.backitup/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
                              > node-gyp rebuild
                                CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                              make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
                              gyp ERR! cwd /Users/travis/build/simatec/ioBroker.backitup/node_modules/iobroker.js-controller/node_modules/winston-syslog/node_modules/unix-dgram
                              gyp ERR! not ok
                              npm WARN optional dep failed, continuing diskusage@0.2.4
                              npm WARN optional dep failed, continuing unix-dgram@0.2.3
                              @apollon77:
                              • immer angelegte gleiche Datenpunkte könntest Du auch in der io-package definieren, dann werden die automatisch angelegt und du brauchst keinen Code dafür … `
                              Das schauen wir uns auf jeden Fall an und probieren das zu ändern.
                              @apollon77:
                              Wenn es getestet ist meldet es bitte fürs Repo an. `
                              Dankeschön :mrgreen: :mrgreen:
                                darkiop Most Active last edited by
                                Super! Werde heut Abend auch mal für euch den Tester spielen!!
                                  @JackWolfskind:
                                  Der Fix für den Fehler im js-controller ist aber noch nicht verfügbar, oder ? `
                                  Google is your friend: https://packages.debian.org/cgi-bin/sea … &arch=i386
                                  Welche js-controller hast Du?
                                    @simatec:
                                    @apollon77:
                                    Macht es Sinn nodejs 4 nicht zu supporten? Aktuell habe ich das Gefühl, dass der Fehler beim testing am "child_process" Paket liegt. `
                                    Ne der liegt am der ES6 Code-Style und verwendung wie
                                    https://travis-ci.org/simatec/ioBroker. … 28514#L794 (hat eher mit dem const { ... } zu tun!).
                                    Node 4 ist EOL also würde ich da bei neuen Adaptern akzeptieren das es nicht tut.
                                    • simatec
                                      Gut habe ich dann auch gleich erledigt und den Support für node 4 rausgenommen.
                                      "engines": {
                                          "node": ">=6.0.0"
                                      Jetzt wird es beim Testing mit Travis und Appveyor auch alles grün … 😉
                                      • Peoples
                                        Peoples last edited by
                                        @apollon77:
                                        Das heißt man kann die 6 Datenpunkte für die History und das oneclick außerhalb des Javascripts erstellen?
                                          Ich glaube es ist 1.50, zumindest ist das was iobroker -v ausgibt, und sonst weiss ich nicht wo man das in IOBroker erkennen könnte?
                                            @peoples:
                                            @apollon77:
                                            Das heißt man kann die 6 Datenpunkte für die History und das oneclick außerhalb des Javascripts erstellen? `
                                            Korrekt.
                                            Beispiel: https://github.com/ioBroker/ioBroker.sq … .json#L218
                                            1.2k
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1172026
