    4. Adapter: iobroker.backitup (stable Release)
    • Chaot
      Chaot last edited by
      Ich habe keine Ahnung was das mit meinen Buttons war. Ich habe deine importiert und es funktioniert.
      DANKE dafür.
        @peoples:
        @Chaot:
        Ich denke das ich die Bindings richtig habe: `
        Schaut zumindest so aus, hab mal schnell von einem meiner Buttons einen Widgetexport gemacht dass du Ihn versuchen kannst:
        [{"tpl":"tplJquiButtonState","data":{"oid":"backitup.0.OneClick.start_minimal_Backup","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","buttontext":"{wert:backitup.0.OneClick.start_minimal_Backup; wert === \"true\" ? \"Minimal Backup
         wird erstellt\" : \"Minimal Backup
         starten\"}","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"no_style":false,"value":"true"},"style":{"left":"378px","top":"750px","border-width":"","border-style":"","border-color":"","width":"220px","height":"100px","z-index":"3"},"widgetSet":"jqui"}]
        Geht bei mir auch!
        • Peoples
          Peoples last edited by
          @Jey Cee:
          Hab gerade festgestellt das die OneClick states alle Schreibgeschützt (write: false) sind. `
          Das hab ich tatsächlich vergessen zu ändern, hab ich gerade gefixt.
          Dank dir für den Hinweis
          • simatec
            @sigi234:
            Ich greife via Windows Pc auf meinen PI zu…..
            Die NAS ist eine WD MY CLOUD der Pfad zu dieser ist:
            http://wdmycloud.local/UI/shares/iobroker
            Eventuell gibt es Probleme mit dem Hostnamen.
            Setze an der Stelle mal die IP von deinem NAS ein.
            • simatec
              @Jey Cee:
              Appollon77 hat ja schon das meiste genannt was ich heute Vormittag schon gesehen hatte, aber ein paar sachen hab ich noch.
              • die Zeilen 15 bis 18 in der main.js können gelöscht werden, außer ihr verwendet "variable" im code
              • Doku: ihr habt ja im docs Ordner die Doku in de und en angelegt, hier wäre zu Überlegen in der Readme darauf zu verlinken und nur die Beschreibung in der Readme zu belassen und um die Englische zu erweitern
              • falls sinnvoll/möglich könnte man den Adapter noch von daemon auf schedule umbauen. Ihr schreibt ja das er Zyklisch Backups erstellt, somit könnte man die Systemlast etwas reduzieren wenn der Adapter nicht ständig läuft.
              Außerdem könntet ihr auf node-schedule verzichten.
              Für das One-Click Backup könnte man in diesem Fall ein Skript im JS Adapter verwenden das den Adapter Startet.
              • die Datei "initial" scheint unnötig zu sein
              Dickes Danke an euch das ihr eine einfache Lösung für Backups gebaut habt. `
              Danke für das super Feedback und die Tips …
              Wir schauen uns das mal an und werden da noch einiges anpassen.
              Mit dem umbauen auf schedule bin ich mir nicht so sicher.
              Wir haben ja 3 unterschiedliche Backupzeiten zur Auswahl.
              Geht das denn, wenn der Adapter als schedule läuft?
              Bisher ist mir immer nur eine Zeit bekannt, die man parametrieren kann
                @simatec:
                @sigi234:
                Gesendet von iPhone mit Tapatalk `
                JAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                ` > backitup.0 2018-07-06 01:07:22.315 info success –- Backup-File wurde erfolgreich auf ein anderes Verzeichnis kopiert ---
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_06-01_07_02.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_06-01_03_56.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_05-23_56_53.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_05-23_46_57.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_05-23_43_56.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_05-23_32_31.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_05-23_29_09.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_05-23_20_10.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info backupiobroker_minimal-2018_07_05-22_15_10.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info --- Backup-File FTP-Upload wird gestartet ---
                backitup.0 2018-07-06 01:07:22.315 info success --- Ueberpruefung auf alte Dateien und loeschen erfolgreich ---
                backitup.0 2018-07-06 01:07:22.315 info --- Alte Backups entfernen ---
                backitup.0 2018-07-06 01:07:22.315 info success --- Ein normales Backup wurde erstellt ---
                backitup.0 2018-07-06 01:07:22.315 info Backup created: /opt/iobroker/backups/2018_07_06-01_07_03_backupiobroker.tar.gz
                backitup.0 2018-07-06 01:07:22.315 info --- Es wurde ein Normales Backup gestartet ---
                backitup.0 2018-07-06 01:07:22.315 info exec: minimal||2|192.168.178.23|/iobroker/Backup|admin|xxx||||FTP||||||5
                backitup.0 2018-07-06 01:07:22.129 debug redis pmessage io.backitup.0.OneClick* io.backitup.0.OneClick.start_minimal_Backup {"val":false,"ack":true,"ts":1530832042127,"q":0,"from":"system.adapter.backitup.0","lc":1530832042127}
                backitup.0 2018-07-06 01:07:02.125 info backup_erstellen(minimal,,2,192.168.178.23,/iobroker/Backup,admin,xxx,,,,FTP,,,,,,5)
                backitup.0 2018-07-06 01:07:02.088 info bash /opt/iobroker/node_modules/iobroker.backitup/backitup.sh "minimal||2|192.168.178.23|/iobroker/Backup|admin|xxx||||FTP||||||5"
                backitup.0 2018-07-06 01:07:02.086 info OneClick Minimal Backup gestartet `
                • simatec
                  Es ist eine neue Version verfügbar …
                  Der Adapter ist einfach über Github in IoBroker zu aktualisieren.
                  Im IoBroker einfach unter Adapter auf den Button „Installieren aus eigener URL“ gehen und unter dem Tab „Beliebig“ den folgenden Github Link einfügen …
                  https://github.com/simatec/ioBroker.backitup.git
                  Danach sollte die neue Version 0.1.7 verfügbar sein.
                  oder über npm:
                  https://www.npmjs.com/package/iobroker.backitup
                  • 0
                    0018 last edited by
                    erstmal vielen Dank für die Super Arbeit und die Erstellung des Adapters!
                    Leider schaffe ich es nicht die CIFS Verbindung zu erstellen. Habe schon sämtliche Ausführungen der Schreibweise versucht.
                    Vielleicht habt ihr noch eine Idee?
                    Hier die Adpatereinstellung:
                    und der Log:
                    backitup.0	2018-07-06 12:49:45.134	info	error --- Backup-Pfad wurde nicht vom CIFS-Server getrennt ---
                    backitup.0	2018-07-06 12:49:45.134	info	success --- Ueberpruefung auf alte Dateien und loeschen erfolgreich ---
                    backitup.0	2018-07-06 12:49:45.134	info	--- Alte Backups entfernen ---
                    backitup.0	2018-07-06 12:49:45.134	info	success --- Ein normales Backup wurde erstellt ---
                    backitup.0	2018-07-06 12:49:45.134	info	Backup created: /opt/iobroker/backups/2018_07_06-12_49_19_backupiobroker.tar.gz
                    backitup.0	2018-07-06 12:49:45.134	info	--- Es wurde ein Normales Backup gestartet ---
                    backitup.0	2018-07-06 12:49:45.134	info	error --- Backup-Pfad wurde nicht auf CIFS-Server verbunden ---
                    backitup.0	2018-07-06 12:49:45.134	info	--- Backup-Pfad auf CIFS mounten ---
                    backitup.0	2018-07-06 12:49:45.134	info	exec: minimal||5|192.168.0.100|/Software/ioBroker/Backup/|ioBroker|passwort||||CIFS||||||5
                    backitup.0	2018-07-06 12:49:16.830	info	backup_erstellen(minimal,,5,192.168.0.100,/Software/ioBroker/Backup/,ioBroker,passwort,,,,CIFS,,,,,,5)
                    backitup.0	2018-07-06 12:49:16.802	info	Telegram Message ist aktiv
                    backitup.0	2018-07-06 12:49:16.800	info	bash /opt/iobroker/node_modules/iobroker.backitup/backitup.sh "minimal||5|192.168.0.100|/Software/ioBroker/Backup/|ioBroker|iobroker||||CIFS||||||5"
                    • simatec
                      Bei der CIFS Variante bitte den / in der Pfadangabe weglassen.
                      Beispiel:
                      NAS-Freigabename/Pfadangabe
                      Siehe Readme…
                        Superdad last edited by
                        Funktioniert super!
                        Vielen Dank!
                        • 0
                          0018 last edited by
                          @simatec:
                          Bei der CIFS Variante bitte den / in der Pfadangabe weglassen. `
                          Wunderbar, funktioniert!
                          Danke…
                          Eine Frage hab ich noch:
                          Was bedeutet die Auswahl "Löschen nach x Tagen" bei jeder Variante genau?
                          Löschen nach x Tagen im Ordner iobroker/backup oder auf dem NAS? oder beides?
                          Einen kleiner Verbesserungsvorschlag:
                          Bei der Telegram Benachrichtigung wäre es schön nur eine Instanz auswählen zu können.
                          Habe aktuell 2 Instanzen am laufen und diese senden beide die Nachricht nach erfolgreichem Backup.
                          Schöner für mich wäre es wenn nur eine sendet.
                          • Peoples
                            @0018:
                            @simatec:
                            Danke…
                            Schöner für mich wäre es wenn nur eine sendet. `
                            "Löschen nach x Tagen" das ist Abhängig von der Variante die du verwendest. Bei Cifs an beiden Orten bei FTP nur auf dem iobroker. Seht auch und der Doku 😉
                            Wofür verwendest du denn zwei Instanzen? Das könnte ich ändern, vielleicht ginge auch ne Auswahl hmm.
                            • Boris73
                              Boris73 last edited by
                              hi Steffen, hi Pix,
                              habe den adapter installiert und instantiiert,, bekomme aber in der Maske Parameter-Konfiguration nur zwei leere Text-Felder Testen1 und Testen2 angezeigt. Was tun?
                              Grüße, Boris
                              • Chaot
                                Bei mir werden die Backups korrekt ausgeführt.
                                Allerdings versagt dann der Adapter beim FTP Upload.
                                zunächst wurden normale Dateien geschrieben, aber die letzten beiden Tage sind dort nur Dateien mit 0 Byte aufgeführt. Im Ordner "Backups" auf dem Raspi sind die Dateien richtig vorhanden.
                                • simatec
                                  @Boris73:
                                  hi Steffen, hi Pix,
                                  Grüße, Boris `
                                  Mache mal ein Update auf Admin 3
                                  Die alte Admin Oberfläche wird von diesem Adapter nicht mehr unterstützt
                                  • simatec
                                    @Chaot:
                                    zunächst wurden normale Dateien geschrieben, aber die letzten beiden Tage sind dort nur Dateien mit 0 Byte aufgeführt. Im Ordner "Backups" auf dem Raspi sind die Dateien richtig vorhanden. `
                                    Kannst du uns hier mal ein Log posten?
                                    • Chaot
                                      :oops: :oops: Fehler gefunden.
                                      Angeblich Platte voll.
                                      Vom Verhalten her würde ich sagen die Platte ist dahin. Ok, nach 9 Jahren Laufzeit darf sie das dann mal….. 😞
                                      • simatec
                                        Ja nach 9 Jahren kann das passieren [emoji51]
                                        • 0
                                          0018 last edited by
                                          @peoples:
                                          "Löschen nach x Tagen" das ist Abhängig von der Variante die du verwendest. Bei Cifs an beiden Orten bei FTP nur auf dem iobroker. Seht auch und der Doku 😉 `
                                          Ok, danke. Das geht für mich nicht so direkt aus der Doku hervor.
                                          Warum wird das Backupfile lokal nicht immer gleich gelöscht wenn es auf das NAS geschoben wird?
                                          Das würde unnötigen Datenmüll auf dem ioroker Server (Raspi bei mir) vermeiden oder?
                                          Zumindest wenn mann häufig Backups laufen lässt.
                                          @peoples:
                                          Wofür verwendest du denn zwei Instanzen? Das könnte ich ändern, vielleicht ginge auch ne Auswahl hmm. `
                                          Wenn du das einbauen kannst wäre es cool 😄
                                          Habe zwei Instanzen weil ich mir üver eine Bilder von der CAM bei Bewegung senden lasse und bei der zweiten habe ich Systemmeldung usw.
                                          Finde ich übersichtlicher in meinem Fall, zumal bei der CAM einiges an Bilder kommen kann.
                                          EDIT: Ist es geplant auch die Backup Einstellungen/Aktivierung auch über VIS zu editieren, wie es im Script möglich war? (Dauer, Tage, Zyklus)
                                          • simatec
                                            Lokal wird es nur noch zusätzlich gespeichert, wenn du FTP nutzt.
                                            Wenn du cifs nutzt, wird es direkt auf dem NAS geschrieben …
                                            Eigentlich ist eine Bedienung über VIS nicht geplant, da du alles im Adapter einstellen kannst und über vis mal schnell ein one click auslösen kannst.
                                            Telegram nehmen wir mit auf die Todo [emoji4]
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1172210
