    3. Cloud Dienste
    4. Alexa Adapter renewed (0.1.0+)
      liv-in-sky last edited by
      hi appollon,
      finde ich sehr gut, dass du dich damit beschäftigst. habe deinen adapter installiert und auch git. das ist die fehlermeldung.
      was mache ich falsch
      Caught	2018-07-10 14:08:21.327	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:180:9)
      Caught	2018-07-10 14:08:21.327	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
      Caught	2018-07-10 14:08:21.327	error	by controller[0]: at emitErrorNT (internal/streams/destroy.js:64:8)
      Caught	2018-07-10 14:08:21.327	error	by controller[0]: at TLSSocket.emit (events.js:211:7)
      Caught	2018-07-10 14:08:21.327	error	by controller[0]: at emitOne (events.js:116:13)
      Caught	2018-07-10 14:08:21.327	error	by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
      Caught	2018-07-10 14:08:21.327	error	by controller[0]: at ClientRequest.emit (events.js:211:7)
      Caught	2018-07-10 14:08:21.327	error	by controller[0]: at ClientRequest. <anonymous>(/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:54:20)
      Caught	2018-07-10 14:08:21.326	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:127:35
      Caught	2018-07-10 14:08:21.326	error	by controller[0]: TypeError: Cannot read property 'req' of null
      alexa.0	2018-07-10 14:08:21.298	info	terminating
      alexa.0	2018-07-10 14:08:21.288	error	at process._tickCallback (internal/process/next_tick.js:180:9)
      alexa.0	2018-07-10 14:08:21.288	error	at _combinedTickCallback (internal/process/next_tick.js:138:11)
      alexa.0	2018-07-10 14:08:21.288	error	at emitErrorNT (internal/streams/destroy.js:64:8)
      alexa.0	2018-07-10 14:08:21.288	error	at TLSSocket.emit (events.js:211:7)
      alexa.0	2018-07-10 14:08:21.288	error	at emitOne (events.js:116:13)
      alexa.0	2018-07-10 14:08:21.288	error	at TLSSocket.socketErrorListener (_http_client.js:387:9)
      alexa.0	2018-07-10 14:08:21.288	error	at ClientRequest.emit (events.js:211:7)
      alexa.0	2018-07-10 14:08:21.288	error	at ClientRequest. <anonymous>(/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:54:20)
      alexa.0	2018-07-10 14:08:21.288	error	at /opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:127:35
      alexa.0	2018-07-10 14:08:21.288	error	TypeError: Cannot read property 'req' of null
      alexa.0	2018-07-10 14:08:21.287	error	uncaught exception: Cannot read property 'req' of null</anonymous></anonymous>
      gruß
        apollon77 last edited by
        Schau bitte nochmal … Hattest Du nach dem Install die Instanz mal neu gestartet? Mach mal Stop und neu starten ... dann andere Fehlermeldung?
        Der Fehler passt nicht zum Code ... Zeile 127 ist was ganz anders 🙂
          hatte ich gemacht - nochmal versucht - kommt absolut identische fehlermeldung - hab sogar iobroker neugestartet - auch selber fehler in zeile 127
            Dann hat er irgendwie das nicht korrekt installiert. Installier bitte nochmal vom GitHub und poste log.
            Gesendet vom Handy …
              knopers1 last edited by
              @Apollon
              kannst Du eine kurze Anleitung geben wie der Adapter zu installieren ist? Ich würde gerne auch testen…
                mikiline last edited by
                Adapter von Github installiert, Mail und Passwort in der Adapterkonfiguration eingetragen und schwups…...läuft 😉
                Vielen Dank!
                  hi mikiline
                  kannst du mir bitte den github link posten
                  ich verstehe das schon richtig? ich muss das im iobroker admin unter den "kopfhörer"-icon eingeben?
                    @mikiline:
                    Vielen Dank! `
                    welche Mail und Passwort? Kann jemand eine grobe Anleitung machen wie zu installieren ist und welche Passwörter und Mails nötig sind?
                      ok - hab das hinbekommen - adapter läuft nach git installation
                      danke
                      • Dutchman
                        @liv-in-sky:
                        hatte ich gemacht - nochmal versucht - kommt absolut identische fehlermeldung - hab sogar iobroker neugestartet - auch selber fehler in zeile 127 `
                        Hast du einen manuellen Upload ausgeführt nachdem du den Adapter per github geupdated hast ?
                        • O
                          ooooli last edited by
                          Super, dass der Token sich nun wieder mittels Adapter auslesen lassen lässt!
                          Soweit war die Installation auch kein Thema. Was jedoch nicht funktioniert, ist das Starten von Tunein. Habe die Tunein ID ins Tunein Feld eingetragen. Bei Start auf True setzen passiert jedoch nichts. Das Log lässt auch keine Rückschlüsse zu.
                          Ich nutze das derzeit noch mit dem Script. Würde das gern durch den Adapter ersetzen. Ist das bekannt / noch offen?
                            kurzer bericht - klingt strange ist aber passiert.
                            habe alle echos getestet mit tunein - ok
                            lautstärke ändern - ok
                            multiroom device - ok - alle spielten tunein
                            jetzt kommts
                            • danach konnte ich keine einzelnen echo mehr steuern (über adapter)
                            • echo's reagierten nicht mehr auf sprache - roter ring
                            • mein wlan ist zusammengebrochen
                            • massig fehler in iobroker- log - alle sonoffs spielten verückt und viele andere adapter machten fehler
                            • in der alexa app wurde ein echo unbenannt in "state" !!!!! - musste alle echos neustarten und iobroker neustarten - die alexa app konnte teilweise keine geräte anzeigen
                            • musste iobroker-maschine neustarten
                            kann das alles mit dem adapter zu tun haben - irgendwelche ideen?
                              He,
                              also ich habe aktuell nichts wirklich angefasst ausser die ganze Cookie Nummer und das vor Benutzung des Cookies geprüft wird ob dieser auch noch gültig ist und tut und wenn nein versucht wird zu erneuern.
                              Ansonsten habe ich nur Dinge geändert die mein Editor als Code-Fehler gemeldet hat - also die vorher noch nie funktioniert haben (sollten) oder per Zufall funktioniert haben.
                              Die ganzen anderen Funktionen muss ich jetzt ansehen.
                              Das Log wird sehr gesprächig wenn Du das Loglevel der Instanz auf
                              Strange ist jetzt das ein User sagt Tunein tut und ein anderer das es nicht tut. Der komische Effekt im letzten Post ist auch eher strange.
                              @liv-in-sky: Kannst Du das mal reproduzieren?!
                              Ansonsten kann ich nur sagen (weil ich selbst auch kein Tunein nutze/habe) das ein Log von einem User wo es tut und ein Log von einem User wo es nicht tut als vergleich super wäre. Am besten (wegen dem enthaltenen cookie) aber als PN oder anonymisiert das Cookie in allen Millionen stellen im Log 🙂
                              @knopers1: SInd deine Fragen beantwortet? GitHub Install (Adapter -> Custom-Install Icon -> von Gihtub -> URL zu meinem Fork aus dem ersten Beitrag).
                              E-Mail und Passwort sind die von deinem Amazon-Account wo der Echo/Alexa drin registriert sind.
                                Verbesserung (Feature): ist das möglich?
                                • Bluetooth connection zu gerät "verbinden" und "trennen"
                                • spiele Radiosender "XY"
                                  Bitte Github Issues anlegen.
                                  Wenn es in https://github.com/thorsten-gehrig/alex … te-control drin ist sollte es dann auch gehen wenn ich mal fertig bin
                                    @ appollon
                                    was da genau passiert ist kann ich nicht sagen. tunein funktionierte, wenn ich z.b. rockantenne im object eingab. die s"nummer" ging nicht. im script unter linux gebe ich immer die station-id an ( alexa_remote…. -r 25217) - ich habe alles direkt in den objecten eingegeben und es lief, bis ich von multiroom wieder in den einzelmodus gehen wollte.
                                    im moment bin ich erst mal froh, das wieder alles läuft (habe kein testsystem) - muss mich erst mal erholen vom schock
                                    wirklich unverständlich war, dass der echo selbst unbenannt worden ist. er hieß vorher "Echozimmer" und nach dem disaster hieß er "state" in der alexa app. ich möchte vermeiden, dass mich amazon sperrt. ich lasse erstmal den exec befehl mit dem orginalscript.
                                    vieleicht habe ich etwas bei der git installation verbockt - fehler hatte ich keine. vielleicht hat ein anderer tester irgendwann ähnliche symptome. ich bin kein coder daher kenne ich die zusammenhänge nicht (node version,...) - sorry bin da keine große hilfe
                                    • chucky666
                                      chucky666 last edited by
                                      Das liegt am Adapter, das Problem hatte ich letzten Monat auch .
                                      Danach ist er erstmal runtergeflogen.
                                      Gesendet von iPad mit Tapatalk Pro
                                        dann bin ich froh, dass es noch jemanden gibt, der das nachvollziehen kann
                                        danke chucky
                                          Trotzdem wäre es super ein Log zu bekommen wenn das passiert und auch die Frage ob es nur mit Tunein zu tun hat oder wie oder was … Wir wollen ja schliesslich versuchen den Fehler zu finden und zu fixen 🙂
                                            ich würde dir gerne helfen, weil ich das project mit alexa unterstützen möchte.
                                            aber sind nicht alle logs nach neustart der maschine weg? wenn nicht sag mir bitte wo ich suchen soll !
                                            1.0k
                                            207
                                            31220
