    3. Cloud Dienste
    4. Alexa Adapter renewed (0.1.0+)
      @Pocky:
      Übrigens funktioniert das Skript immer noch genauso.
      Man muss dort nur auch den Cookie manuell schreiben. `
      Nein, geht bei mir nicht, Cookie wurde manuell gesetzt…...
      • lobomau
        lobomau last edited by
        Hab auch Probleme beim Installieren. Git ist bereits installiert.
        Während Installation:
        iobroker	2018-07-10 23:02:27.484	info	exit 0
        iobroker	2018-07-10 23:02:27.378	info	run `npm audit fix` to fix them, or `npm audit` for details
        iobroker	2018-07-10 23:02:27.378	info	found 86 vulnerabilities (46 low, 23 moderate, 17 high)
        iobroker	2018-07-10 23:02:27.378	info	added 4 packages from 3 contributors and audited 7071 packages in 47.374s
        iobroker	2018-07-10 23:02:27.378	info	+ iobroker.alexa@0.1.0
        iobroker	2018-07-10 23:02:27.363	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        iobroker	2018-07-10 23:02:27.363	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIO
        iobroker	2018-07-10 23:02:27.362	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
        iobroker	2018-07-10 23:01:38.445	info	npm install https://github.com/Apollon77/ioBroker.alexa/tarball/master --production --save --prefix "/opt/iobroker" (System call)
        iobroker	2018-07-10 23:01:37.775	info	install https://github.com/Apollon77/ioBroker.alexa/tarball/master
        iobroker	2018-07-10 23:01:37.131	info	url "https://github.com/Apollon77/ioBroker.alexa" --debug
        iobroker	2018-07-10 23:00:34.344	info	exit 0
        iobroker	2018-07-10 22:59:50.047	info	npm uninstall iobroker.alexa --silent --save --prefix "/opt/iobroker" (System call)
        iobroker	2018-07-10 22:59:49.457	info	host.brix-3150 Deleting 1 state(s).
        iobroker	2018-07-10 22:59:49.436	info	host.brix-3150 Deleting 2 object(s).
        iobroker	2018-07-10 22:59:49.422	info	host.brix-3150 Counted 1 states (system.adapter.alexa.*) from states
        iobroker	2018-07-10 22:59:49.193	info	host.brix-3150 Counted 1 states of alexa
        iobroker	2018-07-10 22:59:44.412	info	host.brix-3150 Counted 1 adapters for alexa
        iobroker	2018-07-10 22:59:44.219	info	host.brix-3150 no instances of adapter alexa found
        iobroker	2018-07-10 22:59:44.106	info	Delete adapter "alexa"
        iobroker	2018-07-10 22:59:43.396	info	del alexa
        iobroker	2018-07-10 22:51:51.192	info	exit 0
        Dann füge ich Instanz hinzu mit den Einstellungen. Basis-URL lasse ich frei!?
        Dann kommt immer wieder wie bei liv-in-sky:
        host.brix-3150	2018-07-10 23:10:06.578	info	Restart adapter system.adapter.alexa.0 because enabled
        host.brix-3150	2018-07-10 23:10:06.578	error	instance system.adapter.alexa.0 terminated with code 0 (OK)
        Caught	2018-07-10 23:10:06.578	error	by controller[1]: at TCP.done [as _onclose] (_tls_wrap.js:356:7)
        Caught	2018-07-10 23:10:06.578	error	by controller[1]: at _handle.close (net.js:557:12)
        Caught	2018-07-10 23:10:06.578	error	by controller[1]: at TLSSocket.emit (events.js:211:7)
        Caught	2018-07-10 23:10:06.578	error	by controller[1]: at emitOne (events.js:121:20)
        Caught	2018-07-10 23:10:06.578	error	by controller[1]: at TLSSocket.socketCloseListener (_http_client.js:363:9)
        Caught	2018-07-10 23:10:06.578	error	by controller[1]: at ClientRequest.emit (events.js:211:7)
        Caught	2018-07-10 23:10:06.578	error	by controller[1]: at emitOne (events.js:116:13)
        Caught	2018-07-10 23:10:06.578	error	by controller[1]: at ClientRequest. <anonymous>(/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:76:24)
        Caught	2018-07-10 23:10:06.577	error	by controller[1]: at request (/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:184:46)
        Caught	2018-07-10 23:10:06.577	error	by controller[1]: TypeError: Cannot read property 'startsWith' of null
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:180:9)
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at emitErrorNT (internal/streams/destroy.js:64:8)
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at TLSSocket.emit (events.js:211:7)
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at emitOne (events.js:116:13)
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at ClientRequest.emit (events.js:211:7)
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at ClientRequest. <anonymous>(/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:76:24)
        Caught	2018-07-10 23:10:06.577	error	by controller[0]: at request (/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:184:46)
        Caught	2018-07-10 23:10:06.576	error	by controller[0]: TypeError: Cannot read property 'startsWith' of null
        alexa.0	2018-07-10 23:10:06.494	error	at TCP.done [as _onclose] (_tls_wrap.js:356:7)
        alexa.0	2018-07-10 23:10:06.494	error	at _handle.close (net.js:557:12)
        alexa.0	2018-07-10 23:10:06.494	error	at TLSSocket.emit (events.js:211:7)
        alexa.0	2018-07-10 23:10:06.494	error	at emitOne (events.js:121:20)
        alexa.0	2018-07-10 23:10:06.494	error	at TLSSocket.socketCloseListener (_http_client.js:363:9)
        alexa.0	2018-07-10 23:10:06.494	error	at ClientRequest.emit (events.js:211:7)
        alexa.0	2018-07-10 23:10:06.494	error	at emitOne (events.js:116:13)
        alexa.0	2018-07-10 23:10:06.494	error	at ClientRequest. <anonymous>(/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:76:24)
        alexa.0	2018-07-10 23:10:06.494	error	at request (/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:184:46)
        alexa.0	2018-07-10 23:10:06.494	error	TypeError: Cannot read property 'startsWith' of null
        alexa.0	2018-07-10 23:10:06.494	error	uncaught exception: Cannot read property 'startsWith' of null
        alexa.0	2018-07-10 23:10:06.489	error	at process._tickCallback (internal/process/next_tick.js:180:9)
        alexa.0	2018-07-10 23:10:06.489	error	at _combinedTickCallback (internal/process/next_tick.js:138:11)
        alexa.0	2018-07-10 23:10:06.489	error	at emitErrorNT (internal/streams/destroy.js:64:8)
        alexa.0	2018-07-10 23:10:06.489	error	at TLSSocket.emit (events.js:211:7)
        alexa.0	2018-07-10 23:10:06.489	error	at emitOne (events.js:116:13)
        alexa.0	2018-07-10 23:10:06.489	error	at TLSSocket.socketErrorListener (_http_client.js:387:9)
        alexa.0	2018-07-10 23:10:06.489	error	at ClientRequest.emit (events.js:211:7)
        alexa.0	2018-07-10 23:10:06.489	error	at ClientRequest. <anonymous>(/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:76:24)
        alexa.0	2018-07-10 23:10:06.489	error	at request (/opt/iobroker/node_modules/iobroker.alexa/node_modules/alexa-cookie/alexa-cookie.js:184:46)
        alexa.0	2018-07-10 23:10:06.489	error	TypeError: Cannot read property 'startsWith' of null
        alexa.0	2018-07-10 23:10:06.488	error	uncaught exception: Cannot read property 'startsWith' of null
        alexa.0	2018-07-10 23:10:02.958	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.alexa, node: v8.11.3
        host.brix-3150	2018-07-10 23:10:02.166	info	instance system.adapter.alexa.0 started with pid 32590
        host.brix-3150	2018-07-10 23:09:32.141	info	Restart adapter system.adapter.alexa.0 because enabled</anonymous></anonymous></anonymous></anonymous>
        Upload Alexa macht keinen Unterschied.
        Hab dann ioBroker neugestartet. Bringt auch nichts. Login über alexa.amazon kein Problem.
          @apollon77:
          Ich have erst einmal nur das Logging erweitert und optimiert `
          Logt sich immer ein und aus und der Log( auf Debug gesetzt) verschwindet…..:
          alexa.0 2018-07-10 23:15:34.254 debug system.adapter.admin.0: logging true
          alexa.0 2018-07-10 23:15:29.876 debug system.adapter.admin.0: logging false
          alexa.0 2018-07-10 23:15:01.576 debug system.adapter.admin.0: logging true
          alexa.0 2018-07-10 23:15:01.276 debug system.adapter.admin.0: logging false
            apollon77 last edited by
            @lobomau: Bitte Debug-Log einschalten und schicken. (und vorher auf 0.1.1 updaten!) Ich kann den Fehler anfangen aber irgendwas geht bei Dir bei den Requests zu Alexa schieff.
            @sigi234: Diese Meldung hat mit Logging vom Adapter nix zu tun. Das ist der Admin Adapter der sich für Logs subscribed und wieder unsubscribed wenn DU die UI auf hast oder zu machst.
            Log auf Debug heisst Du hast die Instanz unter dem was in meiner Signatur steht in Debug-Loglevel gesetzt? Dann muss mehr log da sein!
            • lobomau
              @apollon77:
              Log auf Debug heisst Du hast die Instanz unter dem was in meiner Signatur steht in Debug-Loglevel gesetzt? Dann muss mehr log da sein! `
              ok, alles klar hab dir den debug-log zugeschickt mit 0.1.1.
                @lobomau:
                ok, alles klar hab dir den debug-log zugeschickt mit 0.1.1. `
                siehe PN, 0.1.2 testen und dann mal schauen warum Amazon ne Challenge abfragt
                • Mikewolf
                  Mikewolf last edited by
                  bei mir läuft der Alexaadapter 0.1.2 ohne probleme ,keine Fehlermeldungen und alle echos lassen sich steuern !
                  nur zu Info. 🙂
                  mfg
                  mikewolf
                  • O
                    ooooli last edited by
                    Bei mir funktioniert 0.1.2 auch grundsätzlich erstmal. Nur wie starte ich Tunein und wähle den Sender? Bei Button Play spielt er die zuvor eingestellte Quelle (Spotify) und der Tunein State hat keine Funktion bei mir. Ne kleine Hilfe wäre prima, dann kann das Skipt weg und ich kann den zusätzlich Komfort sich nicht mehr ums Cookie kümmern zu müssen nutzen.
                    Danke schonmal an apollon77 für die Weiterentwicklung. Klasse Geschichte!
                    • Webranger
                      Webranger last edited by
                      Ist mit der 0.1.2 das Problem mit dem umbenennen auch gelöst?
                        @oooli: Theoretisch in den "TuneI"NDatenpunkt sden Station Namen rein und der sollte dann gesetzt werden.
                        AM besten Debug einschalten, machen und mit Log schicken 🙂
                        @ringdingringding: An der Stelle habe ich bisher im Code nichts gefunden was einen Echo umbenennen würde. Wenn es dennoch passiert sind wir wieder bei "Logs bitte" 🙂
                        @All:
                        Ich bin aber auch ehrlich. Ich habe den Adapter gerade übernommen, ziehe gerade das Glatt was da ist und mache mir nen Plan wie es weiter geht.
                        Daher: Nachvollziehbare Bugs bitte als Issues im Github anlegen mit Logs (oder Logs per PN senden mit verweis auf das Problem!)
                        WICHTIG: Logs bitte aus der Logdatei (verzeichnis log im ioBroker-verzeichnis) und NICHT aus dem Admin, da dort abgeschnitten wird!
                        Auf Github ist jetzt v0.1.3. Es sind nur Korrekturen. Keine neuen Funktionen dazugekommen. Unter anderem sind alle falschen Rollender Datenpunkte nun korrigiert. Also bitte entweder alle Objekte unter alex.0 löschen oder Instanz löschen und neu anlegen.
                        Weiterhin habe ich auf der Readme alle aktuellen Datenpunkte mit Ihren gedachten aktuellen Funktionen beschrieben. Ich hoffe (auch wenn aktuell englisch) das es hilft zu verstehen was aktuell geht und was nicht.
                        https://github.com/Apollon77/ioBroker.a … rokeralexa
                          m.nestler last edited by
                          Habe auch komischerweise hin und wieder , nach dem löschen das einer ( der letzte in Verwendung ) auf host
                          Umbenannt wird -
                          Ist aber für mich nicht tragisch lässt sich ja leicht ändern
                          Nochmals danke für die Weiterentwicklung !!
                          Mit freundlichen Grüßen
                          Mikewolf
                            @m.nestler:
                            Umbenannt wird - `
                            Nach was für einem löschen? Also am besten log mitlaufen lassen bzw wenn Ihr es reproduzieren könnt … und wenn logs da sind her damit 🙂
                            Aktuell loggt der eh nicht so viel
                              Löschen Erklärung ,
                              Da ich die Objekte vom alexa Adapter immer lösche ,
                              Dh zuerst stoppe ich den Adapter dann lösche ich die alexa Objekte dann wird neue Version des Adapters installiert dannach gestartet
                              Um zu sehen ob die Objekte neu angelegt werden .
                              Ich logge derzeit nur wie immer kommt jetzt der Fehler natürlich nich [emoji848][emoji34]
                                Also wenn der Adapter noch läuft wärend du Objekte löschst dann könnten komische Effekte passieren. Müsste man al schauen, aber nicht wenn Du löschst während der Adapter definitiv aus ist.
                                PS: Die Löscherei sollte unnötig sein 🙂
                                • lobomau
                                  @apollon77:
                                  Auf Github ist jetzt v0.1.3. `
                                  Hab ich installiert. Unter ioBroker wird 0.1.2 als Version angezeigt.
                                  • O
                                    @apollon77:
                                    AM besten Debug einschalten, machen und mit Log schicken 🙂 `
                                    Super, funktioniert. Für's readme: der direkte Name (z.B. SWR3) wird eingegeben und los geht's. Ich hatte die Station ID probiert, das funktioniert nicht.
                                      @lobomau: ääähm yes … jetztbehoben ... musst aber nicht nochmal updaten 🙂
                                      @ooooli: kommt auf die Featureliste ... sollte einfach sein beides zu unterstützen. Wie sieht eine Station-ID aus?
                                      • O
                                        @apollon77:
                                        @ooooli: kommt auf die Featureliste … sollte einfach sein beides zu unterstützen. Wie sieht eine Station-ID aus? `
                                        Ich kann durchaus mit dem Namen leben. Funktioniert ebenso.
                                        Wenn du die Station ID einbauen kannst, hier ist beschrieben wie man rankommt:
                                        https://help.tunein.com/what-is-my-stat … SJbg90quwz
                                        Bei SWR3 ist sie s24896
                                          Dot wurde von Wohnzimmer auf VOLUME geändert.
                                            hast Du debug logs von dem zeitpunkt/zeitraum? Aus dem Logfile auf der Platte?
                                            207
                                            31224
