    3. Cloud Dienste
    4. Alexa Adapter renewed (0.1.0+)
      A Former User last edited by
      /tmp/.alexa.cookie hat aber nichts mit diesem Adapter zu tun.
      Es ist für das Skript von Lötzimmer gedacht.
        apollon77 last edited by
        @ringdingringding:
        Nach update auf 0.1.4 kommt das bei mir.
        Error: Captcha needed
        Hilft das?
        Log Auszug:
        ! alexa.0 2018-07-11 18:24:58.813 error Error: Captcha needed alexa.0 2018-07-11 18:24:56.898 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.alexa, node: v6.13.0 alexa.0 2018-07-11 18:24:56.736 info States connected to redis: 127.0.0.1:6379 host.debian-iobroker 2018-07-11 18:24:55.801 info instance system.adapter.alexa.0 started with pid 23628 host.debian-iobroker 2018-07-11 18:24:53.333 info instance system.adapter.alexa.0 terminated with code 0 (OK) host.debian-iobroker 2018-07-11 18:24:53.256 info stopInstance system.adapter.alexa.0 killing pid 23565 host.debian-iobroker 2018-07-11 18:24:53.255 info stopInstance system.adapter.alexa.0 alexa.0 2018-07-11 18:24:53.262 info terminating host.debian-iobroker 2018-07-11 18:24:53.246 info object change system.adapter.alexa.0 host.debian-iobroker 2018-07-11 18:24:03.348 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK) host.debian-iobroker 2018-07-11 18:24:00.035 info instance system.adapter.tankerkoenig.0 started with pid 23597 javascript.0 2018-07-11 18:23:08.538 warn at Object. <anonymous>(script.js.common.Alexa_cube:3:5) javascript.0 2018-07-11 18:23:08.537 warn State "alexa.0.echo-devices.G090LF107204149Q.Commands.volume" not found javascript.0 2018-07-11 18:23:08.075 warn at Object. <anonymous>(script.js.common.Alexa_cube:3:5) javascript.0 2018-07-11 18:23:08.073 warn State "alexa.0.echo-devices.G090LF107204149Q.Commands.volume" not found javascript.0 2018-07-11 18:23:07.652 warn at Object. <anonymous>(script.js.common.Alexa_cube:3:5) javascript.0 2018-07-11 18:23:07.650 warn State "alexa.0.echo-devices.G090LF107204149Q.Commands.volume" not found javascript.0 2018-07-11 18:23:06.806 warn at Object. <anonymous>(script.js.common.Alexa_cube:3:5) javascript.0 2018-07-11 18:23:06.804 warn State "alexa.0.echo-devices.G090LF107204149Q.Commands.volume" not found javascript.0 2018-07-11 18:23:06.340 warn at Object. <anonymous>(script.js.common.Alexa_cube:3:5) javascript.0 2018-07-11 18:23:06.338 warn State "alexa.0.echo-devices.G090LF107204149Q.Commands.volume" not found javascript.0 2018-07-11 18:23:05.912 warn at Object. <anonymous>(script.js.common.Alexa_cube:3:5) javascript.0 2018-07-11 18:23:05.911 warn State "alexa.0.echo-devices.G090LF107204149Q.Commands.volume" not found javascript.0 2018-07-11 18:23:04.657 warn at Object. <anonymous>(script.js.common.Alexa_cube:3:5) javascript.0 2018-07-11 18:23:04.648 warn State "alexa.0.echo-devices.G090LF107204149Q.Commands.volume" not found alexa.0 2018-07-11 18:22:43.150 error Error: Captcha needed alexa.0 2018-07-11 18:22:41.319 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.alexa, node: v6.13.0 alexa.0 2018-07-11 18:22:41.163 info States connected to redis: 127.0.0.1:6379 host.debian-iobroker 2018-07-11 18:22:40.278 info instance system.adapter.alexa.0 started with pid 23565 host.debian-iobroker 2018-07-11 18:22:37.795 info instance system.adapter.alexa.0 terminated with code 0 (OK) host.debian-iobroker 2018-07-11 18:22:37.752 info stopInstance system.adapter.alexa.0 killing pid 23539 host.debian-iobroker 2018-07-11 18:22:37.752 info stopInstance system.adapter.alexa.0 alexa.0 2018-07-11 18:22:37.759 info terminating host.debian-iobroker 2018-07-11 18:22:37.749 info object change system.adapter.alexa.0 alexa.0 2018-07-11 18:22:19.403 error Error: cookie not provided alexa.0 2018-07-11 18:22:19.236 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.alexa, node: v6.13.0 alexa.0 2018-07-11 18:22:19.082 info States connected to redis: 127.0.0.1:6379 iobroker 2018-07-11 18:22:16.908 info exit 0 iobroker 2018-07-11 18:22:16.865 info host.debian-iobroker object system.adapter.alexa.0 created host.debian-iobroker 2018-07-11 18:22:16.853 info instance system.adapter.alexa.0 started with pid 23539 host.debian-iobroker 2018-07-11 18:22:16.829 info object change system.adapter.alexa.0 iobroker 2018-07-11 18:22:16.797 info host.debian-iobroker object system.adapter.alexa.0.alive created iobroker 2018-07-11 18:22:16.760 info host.debian-iobroker object system.adapter.alexa.0.connected created iobroker 2018-07-11 18:22:16.719 info host.debian-iobroker object system.adapter.alexa.0.memHeapUsed created iobroker 2018-07-11 18:22:16.682 info host.debian-iobroker object system.adapter.alexa.0.memHeapTotal created iobroker 2018-07-11 18:22:16.643 info host.debian-iobroker object system.adapter.alexa.0.memRss created iobroker 2018-07-11 18:22:16.605 info host.debian-iobroker object system.adapter.alexa.0.uptime created iobroker 2018-07-11 18:22:16.569 info host.debian-iobroker object system.adapter.alexa.0.inputCount created iobroker 2018-07-11 18:22:16.531 info host.debian-iobroker object system.adapter.alexa.0.outputCount created iobroker 2018-07-11 18:22:16.513 info host.debian-iobroker create instance alexa iobroker 2018-07-11 18:22:16.482 info host.debian-iobroker object system.adapter.alexa created iobroker 2018-07-11 18:22:16.314 info upload [0] alexa.admin /opt/iobroker/node_modules/iobroker.alexa/admin/alexa.png alexa.png image/png iobroker 2018-07-11 18:22:16.224 info upload [1] alexa.admin /opt/iobroker/node_modules/iobroker.alexa/admin/index.html index.html text/html iobroker 2018-07-11 18:22:16.194 info got /opt/iobroker/node_modules/iobroker.alexa/admin iobroker 2018-07-11 18:22:16.141 info host.debian-iobroker install adapter alexa iobroker 2018-07-11 18:22:15.061 info add alexa</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous> `
        Naja er will ein captcha gelöst haben. Siehe weiter oben im Thread zu den Lösungsmöglichkeiten. 😞
        Gesendet vom Handy …
          m.nestler last edited by
          Also ich glaube hier sollte sich Amazon was Einfallen lassen , kann ja nicht sein das automation bedeutet
          Immer wieder händisch einloggen oder captcha oder …
          Selbst Cookies anlegt kopiert , sollte ja auch in deren Sinne sein nachdem man evt über Risiken informiert wurde ?
          Sollte doch reichen User und Pw einzugeben ..
          Mit freundlichen Grüßen
          Mikewolf
            @Pocky:
            Es ist für das Skript von Lötzimmer gedacht. `
            Korrekt. Eine Anleitung wie man an den coolere kommt ist im Admin des Adapters verlinkt.
            • Webranger
              Webranger last edited by
              @apollon77:
              @ringdingringding:
              Hilft das?
              Log Auszug:
              Gesendet vom Handy … ` Wie soll ich Captcha lösen wenn iobroker in einer vm aufm nuc läuft?
              edit
              Cookie von Hand eintragen geht. Mal die Tage abwarten.
                @liv-in-sky:
                @ appollon
                habe gesehen,du diskutierst auf github mit dem scriptersteller. nachdem sich ein echodot völlig verabschiedet hatte (musste ihn resetten und neu einrichten), läuft bei mir das script nicht mehr. bekomme jetzt die captcha meldung !
                als lösung soll man sich mit chrome einloggen - muss das auf dem rechner sein, der das script aufruft(das ist debian ohne gui!). ich konnte mit chrome von einem anderen rechner ein captcha abfragen und eingeben. der fehler auf dem iobroker rechner bleibt. ich habe auch versucht ein cookie (chrome-entwicklertools) von dort zu kopieren und in /tmp/.alexa.cookie eingesetzt - bringt auch nichts - setzte ich das cookie in das alte hauke script kommt immer falscher raum als fehler.
                hast du irgendeine idee, wie ich das wieder hinbekomme, `
                Hm … keine echt simple.
                Ideen wären irgendwie den netzwerkverkehr über dem Rechner Tunneln oder so.
                Oder schau mal bei den Debian Paketen bzw Google. Es gibt bestimmt „Browser für Konsole“ die per Shell funktionieren ... aber da musst du selbst schauen.
                Alternative: mal paar Tage warten und dann nochmal versuchen?! Sorry.
                Gesendet vom Handy ...
                  liv-in-sky last edited by
                  danke für's überlegen - warten hat schon mal etwas gebracht - ich versuch es dir nächsten tage mal
                  den browser für terminal-session ? muss ich mich mal schlau machen ob es sowas gibt
                    @liv-in-sky:
                    den browser für terminal-session ? muss ich mich mal schlau machen ob es sowas gibt `
                    Mehr als einen 😉
                    https://opensource.com/article/16/12/we … mmand-line
                      genau auf der seite war ich auch gerade 🙂
                      aber nur links hat wohl javascript - sonst öffnet sich alexa.amazon.de eh nicht !
                        Du brauchst kein JavaScript. Muss aus sein. Und keine Cookies und Kram haben.
                        Und ja am Ende wenn alles geklappt hat landest du auf einer Amazon Seite die er ohne JavaScript nicht anzeigen kann aber das ist ok!!! Dann bist du erfolgreich durch.
                          Alexa.amazon.de fällt ohne JavaScript zu einem Login Formular für alte mobile Browser zurück … da kommt ne normale login maske.
                          Dachte du hast es schon ohne JavaScript und ohne Cookies (=inkognito/ privater Modus) versucht gehabt??
                            ja auf meinem desktop - aber die seite (chrome) war nur weiß
                              Die Seite am Ende oder gleich zu Beginn?
                              Also ich bekomme eine Login Maske auch ohne JavaScript.
                                mikiline last edited by
                                bei mir läuft ioBroker auf einem QNAP. Seit Anbeginn dieses Adapters (renewed) funktioniert dieser bei mir. Auch mit der neuesten Version
                                  hab jetzt elinks und w3m probiert - beide haben mit der amazon seite mit den cookies - ich komme immer wieder auf die seite, wo amazon sagt, ich solle cookies aktivieren - hab ich - geht trotzdem nicht - andere seiten kann ich öffnen
                                    @liv-in-sky
                                    Bei mir läuft iobroker auf einem Raspberry.
                                    Wenn ich den Cookie manuell gesetzt habe, dann habe ich den nicht über einen Browser auf dem Raspi ausgelesen.
                                    Das mache ich über mein Laptop ein paar Räume weiter.
                                    Ist Ubuntu drauf und lese mit Chrome oder Firefox aus.
                                    Muss also nicht über den Raspberry ausgelesen werden.
                                    Was läuft denn da überhaupt bei Dir.
                                    Soweit ich das bisher mitbekommen habe:
                                    Hauke Skript ohne gültigen Cookie
                                    Lötzimmer Skript ohne gültigen Cookie
                                    Alexa Adapter ohne gültigen Cookie.
                                    Ich denke Du solltest diesen MischMasch erstmal abschalten und Dich fragen was Du benötigst.
                                    Lass erstmal den Adapter vernünftig laufen und dann kannst Du Dich wieder an die anderen Skripte machen.
                                    Wer weiss was dieses durcheinander so alles bewirkt bei Dir.
                                    Schreib den Cookie auf dem Adapter erstmal manuell damit Du Dich überhaupt verbinden kannst.
                                      pocky - das chaos begann jedoch erst mit dem adapter - ich wollte das testen um das projekt von appollon zu unterstützen - siehe früher im thread - der adapter ist längst wieder gelöscht
                                      • das hauke skript ist wieder abgeschaltet - wollt nur etwas testen (ob cookie wieder geht - es kommen keine fehler im log aber die echos spielen nichts)
                                      • es ist nur das alexa_remote script aktiv - welches jetzt nicht mehr funktioniert
                                      den cookie lese ich auch "händisch" auf dem desktoprechner aus - hilft aber auch nicht - es geht ja nur um den captcha fehler, der bei diesem skript auftaucht (bei manchen) https://github.com/thorsten-gehrig/alex … /issues/10
                                      ich warte mal 2 tage ab - bemi hauke skript hat das früher auch immer geholfen bevor ich neuen cookie holte
                                      danke dir
                                      • O
                                        ooooli last edited by
                                        Bei mir ist die gleiche Situation. Seitdem der Adapter kurz lief geht er nun nicht mehr wegen dem Captcha Fehler und das Script mag mit dem Cookie auch nicht mehr [emoji849]
                                          So kurzer Zwischenstand: Ja der Adapter erlaubt das ändern der Namen und ich habe ein paar Stellen im Code gefunden wo durch komische Konstellationen sowas passieren kann (auch bei mir einmal passiert). Das habe ich jetzt mal bei mir gefixt und spiele noch ein bissl rum.
                                          Wenn das bei mir soweit stabil läuft dann gibt es morgen eine neue Version. Stay tuned
                                          • Mikewolf
                                            Mikewolf last edited by
                                            Hallo habe was probiert, weis jedoch nicht ob es helfen kann ? :?: :?: :?:
                                            Zitat:
                                            Ich bin gestern auf das gleiche Problem mit dem Captcha gestoßen und habe alles ausprobiert (einloggen mit versch. IP-Adressen etc.). Nach einigem hin und her hab ich das Problem dann gefixt, in dem ich folgenden User-Agent verwendet habe:
                                            Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36
                                            Vlt. hilft dies ja dem ein oder anderen.
                                            nur so ein gedanke
                                            habe es auf nen 2ten rapsi probiert ,allerdings script von lötzimmer/gehring da hat dieser Tip funktioniert und cookie wurde geschrieben
                                            vorher kam auch die Captcha meldung …..
                                            mfg mikewolf
                                            ps
                                            LANGUAGE="de-DE"
                                            #LANGUAGE="en-US"
                                            AMAZON='amazon.de'
                                            #AMAZON='amazon.com'
                                            ALEXA='layla.amazon.de'
                                            #ALEXA='pitangui.amazon.com'
                                            cURL binary
                                            CURL='/usr/bin/curl'
                                            cURL options
                                            -k : if your cURL cannot verify CA certificates, you'll have to trust any
                                            --compressed : if your cURL was compiled with libz you may use compression
                                            --http1.1 : cURL defaults to HTTP/2 on HTTPS connections if available
                                            OPTS='--compressed --http1.1'
                                            #OPTS='-k --compressed --http1.1'
                                            browser identity
                                            BROWSER='Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:99.0) Gecko/20100101 Firefox/99.0'
                                            BROWSER='Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.103 Safari/537.36'
                                            207
                                            28269
