    4. Test Adapter Philips-TV v0.2.x
    • N
      NemoN last edited by
      aktueller Stand ist nun:
      Was soll ich den noch testen?
      • AlCalzone
        @NemoN:
        Was soll ich den noch testen? `
        Da da ja scheinbar nur pressKey ist und nicht Mute/Volume, funktioniert es wenigstens, damit Befehle zu senden?
        • N
          leider nicht (Log vom Versuch "AmbilightOnOff" zu setzen):
          2018-07-10 22:27:57.491 - debug: philips-tv.0 objectDB connected
          2018-07-10 22:27:57.509 - debug: philips-tv.0 statesDB connected
          2018-07-10 22:27:57.537 - info: philips-tv.0 starting. Version 0.3.0-alpha5 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.14.3
          2018-07-10 22:27:57.565 - debug: philips-tv.0 initializing connection to 192.168.5.127
          2018-07-10 22:27:57.570 - debug: philips-tv.0 checking if connection is alive
          2018-07-10 22:27:57.587 - debug: philips-tv.0 connection is ALIVE
          2018-07-10 22:27:57.588 - debug: philips-tv.0 detecting API version
          2018-07-10 22:27:57.588 - debug: philips-tv.0 testing APIv1
          2018-07-10 22:27:57.599 - debug: philips-tv.0 API test for v1 failed. Reason: [undefined] 404 - "\n\n \n\n\n
          Not Found
          \n
          The server has not found anything matching the request URI
          \n
          You can get technical details here.
          \nPlease continue your visit at our home page.\n
          \n\n\n"
          2018-07-10 22:27:57.701 - debug: philips-tv.0 testing APIv5
          2018-07-10 22:27:57.712 - debug: philips-tv.0 API test for v5 failed. Reason: [undefined] 404 - "\n\n \n\n\n
          Not Found
          \n
          \n
          \n\n\n"
          2018-07-10 22:27:57.813 - debug: philips-tv.0 testing APIv6
          2018-07-10 22:27:57.882 - debug: philips-tv.0 TV has APIv6
          2018-07-10 22:27:57.887 - debug: philips-tv.0 state with id philips-tv.0.info.apiVersion updated: ack=true; val=v6
          2018-07-10 22:27:57.890 - debug: philips-tv.0 state with id philips-tv.0.info.requiresPairing updated: ack=true; val=true
          2018-07-10 22:27:57.892 - debug: philips-tv.0 state with id philips-tv.0.info.paired updated: ack=true; val=true
          2018-07-10 22:27:57.897 - debug: philips-tv.0 state with id philips-tv.0.info.connection updated: ack=true; val=true
          2018-07-10 22:27:57.898 - info: philips-tv.0 The TV at 192.168.5.127 is now reachable.
          2018-07-10 22:28:07.905 - debug: philips-tv.0 checking if connection is alive
          2018-07-10 22:28:07.942 - debug: philips-tv.0 connection is ALIVE
          2018-07-10 22:28:17.952 - debug: philips-tv.0 checking if connection is alive
          2018-07-10 22:28:17.967 - debug: philips-tv.0 connection is ALIVE
          2018-07-10 22:28:27.973 - debug: philips-tv.0 checking if connection is alive
          2018-07-10 22:28:27.983 - debug: philips-tv.0 connection is ALIVE
          2018-07-10 22:28:31.186 - debug: philips-tv.0 state with id philips-tv.0.pressKey updated: ack=false; val=AmbilightOnOff
          2018-07-10 22:28:31.188 - error: philips-tv.0 Error handling state change philips-tv.0.pressKey => AmbilightOnOff: Cannot read property 'username' of undefined
          2018-07-10 22:28:37.990 - debug: philips-tv.0 checking if connection is alive
          2018-07-10 22:28:38.039 - debug: philips-tv.0 connection is ALIVE
          2018-07-10 22:28:48.043 - debug: philips-tv.0 checking if connection is alive
          2018-07-10 22:28:48.057 - debug: philips-tv.0 connection is ALIVE
          2018-07-10 22:28:58.064 - debug: philips-tv.0 checking if connection is alive
          2018-07-10 22:28:58.079 - debug: philips-tv.0 connection is ALIVE
          • AlCalzone
            @NemoN:
            Ein Großteil des Logs sieht gut aus. Das hier lässt mich vermuten, dass du nicht alle beschriebenen Schritte durchgeführt hast (Upload und anschließendes manuelles Setzen von Username + Passwort)
              PRozAC last edited by
              Ich komme auch nicht weiter…
              User und pass sind generiert und im skript hinterlegt. Leider werden die Punkte nicht im Adapter system.adapter.philips-tv.0 angelegt.
              Somit meckert das log natürlich, dass der TV erst gepaired werden muss.
              Ich hatte die Punkte obj.native.username und obj.native.password auch schon händisch mit demselben Ergebnis angelegt.
              Was kann ich denn sonst noch tun 🙂
              • AlCalzone
                @PRozAC:
                User und pass sind generiert und im skript hinterlegt. Leider werden die Punkte nicht im Adapter system.adapter.philips-tv.0 angelegt. `
                Zeig mir mal wie das Objekt aussieht (Reiter Raw).
                  Meinst du das?
                  7550_44a9d6a9-4e08-40d8-86aa-9afb766453d1.jpeg 7550_8bcf9d76-5c74-4657-8257-e9070ab750fe.jpeg 7550_9e55f4f1-fdaf-42b3-b23b-d81a47b7152e.jpeg
                  Falls nicht: bitte nochmal genauer erklären was gebraucht wird 😄
                    schmuh last edited by
                    Ich schliesse mich an, ich bekomme die gleiche Fehlermeldung bei pressKey:
                    philips-tv.0 2018-07-11 19:49:10.871 debug connection is ALIVE
                    philips-tv.0 2018-07-11 19:49:10.858 debug checking if connection is alive
                    philips-tv.0 2018-07-11 19:49:00.851 debug connection is ALIVE
                    philips-tv.0 2018-07-11 19:49:00.840 debug checking if connection is alive
                    philips-tv.0 2018-07-11 19:48:56.494 error Error handling state change philips-tv.0.pressKey => Mute: Cannot read property 'username' of undefined
                    philips-tv.0 2018-07-11 19:48:56.494 debug state with id philips-tv.0.pressKey updated: ack=false; val=Mute
                    Hier das RAW aus system.adapter.philips-tv.0
                    ! "from": "system.adapter.admin.0",
                    ! "ts": 1531331139693,
                    ! "common": {
                    ! "name": "philips-tv",
                    ! "version": "0.3.0-alpha4",
                    ! "title": "Philips TV",
                    ! "platform": "Javascript/Node.js",
                    ! "mode": "daemon",
                    ! "extIcon": "https://raw.githubusercontent.com/AlCal … ips-tv.png",
                    ! "readme": "https://github.com/AlCalzone/ioBroker.p ... /README.md",
                    ! "loglevel": "debug",
                    ! "type": "multimedia",
                    ! "installedVersion": "0.3.0-alpha4",
                    ! "host": "SRV-IOB-002",
                    ! "enabled": true,
                    ! "messagebox": true,
                    ! "news": {
                    ! "0.3.0-alpha4": {
                    ! "en": "Support for TVs with API v5",
                    ! "de": "Fernseher mit API v5 unterstützt"
                    ! "0.2.0": {
                    ! "en": "Support sending key presses",
                    ! "de": "Senden von Tastendrücken unterstützt"
                    ! "0.1.0": {
                    ! "en": "Initial release",
                    ! "de": "Initiale Version"
                    ! "desc": {
                    ! "en": "Controls Philips TVs over the network",
                    ! "de": "Steuert Philips Fernseher über das Netzwerk"
                    ! "authors": [
                    ! "AlCalzone d.griesel@gmx.net"
                    ! "keywords": [
                    ! "philips",
                    ! "tv",
                    ! "remote"
                    ! "icon": "philips-tv.png"
                    ! "native": {
                    ! "host": "192.168.1.200",
                    ! "username": "vAGJGsrPDAvAKDZj",
                    ! "password": "e0eb098647dd3f205bb38ce75ada9060e3a6454d4e4423dc2cfcd09b8fa0f1a2"
                    ! "acl": {
                    ! "object": 1636,
                    ! "owner": "system.user.admin",
                    ! "ownerGroup": "system.group.administrator"
                    ! "_id": "system.adapter.philips-tv.0",
                    ! "type": "instance",
                    ! "enums": {}
                    Wenn ich beim Testen helfen kann, dann gerne.
                    • AlCalzone
                      Was soll ich sagen… ich bin dumm :roll:
                      Die Zugangsdaten werden zwar eingelesen, aber nie verwendet. Ich darf euch nochmal bitten zu updaten und es damit zu probieren (alpha7).
                      • U
                        Ulfhednir last edited by
                        Nachdem ich einige Zeit hier abstinent war und nicht wusste, ob es mit v6 weitergeht, bin ich nun doch positiv überrascht.
                        Ich habe mit deiner aktuellen Version soeben angesetzt. Die Pairingdaten konnte ich hinterlegen. Der Adapter ist grün.
                        Beim Tastendruck hänge ich nun auch. Ich habe per VIS versucht den Tastendruck zu simulieren.
                        Der Log sagt:
                        philips-tv.0 2018-07-11 20:11:55.979 error Error handling state change philips-tv.0.pressKey => true: Error: ESOCKETTIMEDOUT
                          @AlCalzone:
                          Die Zugangsdaten werden zwar eingelesen, aber nie verwendet. Ich darf euch nochmal bitten zu updaten und es damit zu probieren (alpha7). `
                          Ach komm, ich bitte dich. Wenn alle sich so einsetzen würden. Top Arbeit und mal herzlichen Dank. Ich versuche es heute Abend und gebe Bescheid.
                          • AlCalzone
                            @Ulfhednir:
                            philips-tv.0 2018-07-11 20:11:55.979 error Error handling state change philips-tv.0.pressKey => true: Error: ESOCKETTIMEDOUT `
                            Danke, dann bitte mal den Adapter auf Loglevel Debug stellen und den kompletten Auszug hier posten (Adapterstart bis Fehlschlagen des Tastendrucks).
                            Wenn es für jemanden möglich ist, wäre auch ein Traffic-Log zwischen Adapter und TV interessant (Wireshark).
                            Und wer ESOCKETTIMEDOUT bekommt und Lust hat darf gerne auch mal diesen Branch testen:
                            https://github.com/AlCalzone/ioBroker.p … stom-agent
                              Hallo AlCalzone
                              mit der neuen Alpha sieht es nun anders aus, allerdings passiert am TV nichts beim sendKey. Hier das debug log.
                              ! philips-tv.0 2018-07-12 09:54:58.595 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:54:58.595 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:54:58.595 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:54:53.579 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:53.579 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:54:53.575 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:54:53.562 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:53.562 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:54:43.557 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:54:43.556 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:54:43.556 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:54:38.544 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:38.544 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:54:38.542 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:54:38.529 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:38.529 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:54:31.410 error Error handling state change philips-tv.0.pressKey => VolumeUp: Error: ESOCKETTIMEDOUT
                              ! philips-tv.0 2018-07-12 09:54:31.410 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:54:31.410 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:54:31.409 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:54:28.528 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:54:28.528 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:54:28.528 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:54:26.392 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:26.392 debug postJSONwithDigestAuth("input/key", {"key":"VolumeUp"})
                              ! philips-tv.0 2018-07-12 09:54:26.391 debug state with id philips-tv.0.pressKey updated: ack=false; val=VolumeUp
                              ! philips-tv.0 2018-07-12 09:54:23.513 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:23.513 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:54:23.511 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:54:23.497 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:23.496 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:54:13.493 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:54:13.492 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:54:13.492 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:54:08.473 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:08.473 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:54:08.471 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:54:08.451 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:54:08.443 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:53:58.435 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:53:58.434 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:53:58.434 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:53:53.419 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:53.419 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:53:53.416 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:53:53.398 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:53.397 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:53:43.396 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:53:43.396 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:53:43.395 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:53:38.380 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:38.380 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:53:38.377 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:53:38.349 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:38.349 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:53:37.958 error Error handling state change philips-tv.0.pressKey => Mute: Error: ESOCKETTIMEDOUT
                              ! philips-tv.0 2018-07-12 09:53:37.957 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:53:37.957 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:53:37.957 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:53:32.900 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:32.900 debug postJSONwithDigestAuth("input/key", {"key":"Mute"})
                              ! philips-tv.0 2018-07-12 09:53:32.899 debug state with id philips-tv.0.pressKey updated: ack=false; val=Mute
                              ! philips-tv.0 2018-07-12 09:53:28.339 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:53:28.339 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:53:28.339 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:53:23.320 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:23.320 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:53:23.319 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:53:23.302 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:23.302 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:53:13.296 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:53:13.296 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:53:13.295 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:53:08.281 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:08.280 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:53:08.278 info The TV at 192.168.1.200 is now reachable.
                              ! philips-tv.0 2018-07-12 09:53:08.277 debug state with id philips-tv.0.info.connection updated: ack=true; val=true
                              ! philips-tv.0 2018-07-12 09:53:08.270 debug state with id philips-tv.0.info.paired updated: ack=true; val=true
                              ! philips-tv.0 2018-07-12 09:53:08.265 debug state with id philips-tv.0.info.requiresPairing updated: ack=true; val=true
                              ! philips-tv.0 2018-07-12 09:53:08.262 debug state with id philips-tv.0.info.apiVersion updated: ack=true; val=v6
                              ! philips-tv.0 2018-07-12 09:53:08.255 debug TV has APIv6
                              ! philips-tv.0 2018-07-12 09:53:08.193 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:08.193 debug get("audio/volume")
                              ! philips-tv.0 2018-07-12 09:53:08.190 debug testing APIv6
                              ! philips-tv.0 2018-07-12 09:53:08.083 debug API test for v5 failed. Reason: [undefined] 404 - "\n\n <title>Status page</title>\n\n\n
                              ! philips-tv.0 2018-07-12 09:53:08.082 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:53:08.082 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:53:08.082 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:53:08.066 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:08.065 debug get("audio/volume")
                              ! philips-tv.0 2018-07-12 09:53:08.063 debug testing APIv5
                              ! philips-tv.0 2018-07-12 09:53:07.906 debug API test for v1 failed. Reason: [undefined] 404 - "\n\n <title>Status page</title>\n\n\n
                              ! philips-tv.0 2018-07-12 09:53:07.905 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:53:07.905 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 09:53:07.905 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 09:53:07.893 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:07.893 debug get("audio/volume")
                              ! philips-tv.0 2018-07-12 09:53:07.891 debug testing APIv1
                              ! philips-tv.0 2018-07-12 09:53:07.891 debug detecting API version
                              ! philips-tv.0 2018-07-12 09:53:07.891 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:53:07.871 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:07.871 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:53:07.869 debug initializing connection to 192.168.1.200
                              ! philips-tv.0 2018-07-12 09:53:07.838 info starting. Version 0.3.0-alpha7 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.14.2
                              ! philips-tv.0 2018-07-12 09:53:07.708 debug statesDB connected
                              ! philips-tv.0 2018-07-12 09:53:07.691 debug objectDB connected
                              ! philips-tv.0 2018-07-12 09:53:04.787 info terminating
                              ! philips-tv.0 2018-07-12 09:53:04.785 debug state with id philips-tv.0.info.connection updated: ack=true; val=false
                              ! philips-tv.0 2018-07-12 09:53:02.211 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:02.210 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 09:53:02.208 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 09:53:02.190 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 09:53:02.189 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 09:52:52.184 debug no further attempts
                              ! philips-tv.0 2018-07-12 09:52:52.184 debug error is not recoverable
                              ! Ich habe dann auch mal die Version installiert:
                              ! https://github.com/AlCalzone/ioBroker.p … stom-agent
                              ! Da kam allerdings folgende Meldung:
                              ! philips-tv.0 2018-07-12 10:03:05.180 debug state with id philips-tv.0.info.apiVersion updated: ack=true; val=unknown
                              ! philips-tv.0 2018-07-12 10:03:05.175 warn The TV at 192.168.1.200 has an API version incompatible with this adapter!
                              ! philips-tv.0 2018-07-12 10:03:05.074 debug API test for v6 failed. Reason: [undefined] Error: Protocol "https:" not supported. Expected "http:"
                              ! philips-tv.0 2018-07-12 10:03:05.074 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:03:05.073 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:03:05.072 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:03:05.066 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:03:05.066 debug get("audio/volume")
                              ! philips-tv.0 2018-07-12 10:03:05.063 debug testing APIv6
                              ! philips-tv.0 2018-07-12 10:03:04.961 debug API test for v5 failed. Reason: [undefined] 404 - "\n\n <title>Status page</title>\n\n\n
                              ! philips-tv.0 2018-07-12 10:03:04.961 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:03:04.961 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:03:04.960 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:03:04.944 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:03:04.944 debug get("audio/volume")
                              ! philips-tv.0 2018-07-12 10:03:04.941 debug testing APIv5
                              ! philips-tv.0 2018-07-12 10:03:04.840 debug API test for v1 failed. Reason: [undefined] 404 - "\n\n <title>Status page</title>\n\n\n
                              ! philips-tv.0 2018-07-12 10:03:04.840 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:03:04.840 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:03:04.840 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:03:04.828 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:03:04.828 debug get("audio/volume")
                              ! philips-tv.0 2018-07-12 10:03:04.827 debug testing APIv1
                              ! philips-tv.0 2018-07-12 10:03:04.827 debug detecting API version
                              ! philips-tv.0 2018-07-12 10:03:04.826 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:03:04.807 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:03:04.806 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:03:04.804 debug initializing connection to 192.168.1.200
                              ! philips-tv.0 2018-07-12 10:03:04.758 info starting. Version 0.3.0-alpha7 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.14.2
                              ! philips-tv.0 2018-07-12 10:03:04.625 debug statesDB connected
                              ! philips-tv.0 2018-07-12 10:03:04.597 debug objectDB connected
                              ! philips-tv.0 2018-07-12 10:03:01.691 info terminating
                              ! philips-tv.0 2018-07-12 10:03:01.690 debug state with id philips-tv.0.info.connection updated: ack=true; val=false
                              ! philips-tv.0 2018-07-12 10:02:59.706 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:02:59.706 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:02:59.705 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:02:54.695 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:02:54.695 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:02:54.693 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:02:54.681 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:02:54.680 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:02:44.677 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:02:44.677 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:02:44.677 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:02:39.666 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:02:39.666 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:02:39.664 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:02:39.652 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:02:39.652 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:02:29.649 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:02:29.649 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:02:29.649 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:02:24.638 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:02:24.638 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:02:24.637 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:02:24.613 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:02:24.613 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:02:14.610 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:02:14.610 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:02:14.609 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:02:09.597 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:02:09.597 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:02:09.594 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:02:09.580 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:02:09.580 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:01:59.569 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:01:59.569 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:01:59.569 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:01:54.555 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:01:54.555 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:01:54.553 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:01:54.540 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:01:54.539 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:01:44.537 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:01:44.536 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:01:44.536 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:01:39.526 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:01:39.526 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:01:39.523 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:01:39.511 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:01:39.511 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:01:29.508 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:01:29.508 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:01:29.508 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:01:24.498 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:01:24.498 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:01:24.496 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:01:24.485 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:01:24.484 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:01:14.482 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:01:14.482 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:01:14.482 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:01:09.471 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:01:09.471 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:01:09.469 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:01:09.452 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:01:09.452 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:00:59.446 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:00:59.446 debug error is not recoverable
                              ! philips-tv.0 2018-07-12 10:00:59.446 debug attempt 1 failed with code undefined
                              ! philips-tv.0 2018-07-12 10:00:54.435 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:00:54.435 debug getWithDigestAuth("audio/volume")
                              ! philips-tv.0 2018-07-12 10:00:54.433 debug connection is ALIVE
                              ! philips-tv.0 2018-07-12 10:00:54.419 debug attempt 1 of 3
                              ! philips-tv.0 2018-07-12 10:00:54.419 debug checking if connection is alive
                              ! philips-tv.0 2018-07-12 10:00:44.397 debug no further attempts
                              ! philips-tv.0 2018-07-12 10:00:44.396 debug error is not recoverable
                              • U
                                Bei mir erfolgt das selbe Spielchen wie bei schmuh.
                                ! philips-tv.0 2018-07-12 17:56:54.779 debug state with id philips-tv.0.info.apiVersion updated: ack=true; val=unknown
                                ! philips-tv.0 2018-07-12 17:56:54.765 warn The TV at 192.168.178.24 has an API version incompatible with this adapter!
                                ! philips-tv.0 2018-07-12 17:56:54.663 debug API test for v6 failed. Reason: [undefined] Error: Protocol "https:" not supported. Expected "http:"
                                ! philips-tv.0 2018-07-12 17:56:54.661 debug no further attempts
                                ! philips-tv.0 2018-07-12 17:56:54.661 debug error is not recoverable
                                ! philips-tv.0 2018-07-12 17:56:54.660 debug attempt 1 failed with code undefined
                                ! philips-tv.0 2018-07-12 17:56:54.650 debug attempt 1 of 3
                                ! philips-tv.0 2018-07-12 17:56:54.649 debug get("audio/volume")
                                ! philips-tv.0 2018-07-12 17:56:54.642 debug testing APIv6
                                ! philips-tv.0 2018-07-12 17:56:54.540 debug API test for v5 failed. Reason: [undefined] 404 - "\n\n <title>Status page</title>\n\n\n
                                ! philips-tv.0 2018-07-12 17:56:54.538 debug no further attempts
                                ! philips-tv.0 2018-07-12 17:56:54.537 debug error is not recoverable
                                ! philips-tv.0 2018-07-12 17:56:54.535 debug attempt 1 failed with code undefined
                                ! philips-tv.0 2018-07-12 17:56:54.512 debug attempt 1 of 3
                                ! philips-tv.0 2018-07-12 17:56:54.511 debug get("audio/volume")
                                ! philips-tv.0 2018-07-12 17:56:54.505 debug testing APIv5
                                ! philips-tv.0 2018-07-12 17:56:54.404 debug API test for v1 failed. Reason: [undefined] 404 - "\n\n <title>Status page</title>\n\n\n
                                ! philips-tv.0 2018-07-12 17:56:54.402 debug no further attempts
                                ! philips-tv.0 2018-07-12 17:56:54.401 debug error is not recoverable
                                ! philips-tv.0 2018-07-12 17:56:54.400 debug attempt 1 failed with code undefined
                                ! philips-tv.0 2018-07-12 17:56:54.366 debug attempt 1 of 3
                                ! philips-tv.0 2018-07-12 17:56:54.365 debug get("audio/volume")
                                ! philips-tv.0 2018-07-12 17:56:54.359 debug testing APIv1
                                ! philips-tv.0 2018-07-12 17:56:54.358 debug detecting API version
                                ! philips-tv.0 2018-07-12 17:56:54.357 debug connection is ALIVE
                                ! philips-tv.0 2018-07-12 17:56:54.182 debug attempt 1 of 3
                                ! philips-tv.0 2018-07-12 17:56:54.178 debug checking if connection is alive
                                ! philips-tv.0 2018-07-12 17:56:54.168 debug initializing connection to 192.168.178.24
                                ! philips-tv.0 2018-07-12 17:56:54.094 info starting. Version 0.3.0-alpha7 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.14.3
                                ! philips-tv.0 2018-07-12 17:56:54.045 debug statesDB connected
                                ! philips-tv.0 2018-07-12 17:56:53.974 debug objectDB connected
                                ! Ich habe auch mal per FritzBox eine .eth aufgenommen und mal kurz mit Wireshark betrachtet. Allerdings bin ich mir unsicher, ob da etwas brauchbares dabei ist. Mal so am Rande: Wäre eine gemeinsame Teamviewer-Session zum Debuggen einmal sinnvoll? :geek:
                                • AlCalzone
                                  https://github.com/AlCalzone/ioBroker.p … stom-agent bitte nochmal testen, ich hatte da was vergessen.
                                  Der ursprüngliche Branch erfordert noch etwas mehr Arbeit meinerseits, da der Fehler nicht richtig erkannt wird.
                                  @Ulfhednir: Magst du mir den Trafficlog mal zukommen lassen?
                                    @AlCalzone:
                                    @Ulfhednir: Magst du mir den Trafficlog mal zukommen lassen? `
                                    Kann leider erst nach dem Urlaub weitertesten. Bis denne.
                                    • U
                                      @AlCalzone:
                                      https://github.com/AlCalzone/ioBroker.p … stom-agent bitte nochmal testen, ich hatte da was vergessen. `
                                      ! philips-tv.0 2018-07-13 17:29:34.372 debug attempt 1 of 3
                                      ! philips-tv.0 2018-07-13 17:29:34.370 debug getWithDigestAuth("audio/volume")
                                      ! philips-tv.0 2018-07-13 17:29:34.362 info The TV at 192.168.178.24 is now reachable.
                                      ! philips-tv.0 2018-07-13 17:29:34.358 debug state with id philips-tv.0.info.connection updated: ack=true; val=true
                                      ! philips-tv.0 2018-07-13 17:29:34.328 debug state with id philips-tv.0.info.paired updated: ack=true; val=true
                                      ! philips-tv.0 2018-07-13 17:29:34.314 debug state with id philips-tv.0.info.requiresPairing updated: ack=true; val=true
                                      ! philips-tv.0 2018-07-13 17:29:34.296 debug state with id philips-tv.0.info.apiVersion updated: ack=true; val=v6
                                      ! philips-tv.0 2018-07-13 17:29:34.264 debug TV has APIv6
                                      ! philips-tv.0 2018-07-13 17:29:33.984 debug attempt 1 of 3
                                      ! philips-tv.0 2018-07-13 17:29:33.982 debug get("audio/volume")
                                      ! philips-tv.0 2018-07-13 17:29:33.969 debug testing APIv6
                                      ! philips-tv.0 2018-07-13 17:29:33.866 debug API test for v5 failed. Reason: [undefined] 404 - "\n\n <title>Status page</title>\n\n\n
                                      ! philips-tv.0 2018-07-13 17:29:33.863 debug no further attempts
                                      ! philips-tv.0 2018-07-13 17:29:33.861 debug error is not recoverable
                                      ! philips-tv.0 2018-07-13 17:29:33.858 debug attempt 1 failed with code undefined
                                      ! philips-tv.0 2018-07-13 17:29:33.824 debug attempt 1 of 3
                                      ! philips-tv.0 2018-07-13 17:29:33.822 debug get("audio/volume")
                                      ! philips-tv.0 2018-07-13 17:29:33.811 debug testing APIv5
                                      ! philips-tv.0 2018-07-13 17:29:33.707 debug API test for v1 failed. Reason: [undefined] 404 - "\n\n <title>Status page</title>\n\n\n
                                      ! philips-tv.0 2018-07-13 17:29:33.704 debug no further attempts
                                      ! philips-tv.0 2018-07-13 17:29:33.702 debug error is not recoverable
                                      ! philips-tv.0 2018-07-13 17:29:33.699 debug attempt 1 failed with code undefined
                                      ! philips-tv.0 2018-07-13 17:29:33.652 debug attempt 1 of 3
                                      ! philips-tv.0 2018-07-13 17:29:33.650 debug get("audio/volume")
                                      ! philips-tv.0 2018-07-13 17:29:33.636 debug testing APIv1
                                      ! philips-tv.0 2018-07-13 17:29:33.635 debug detecting API version
                                      ! philips-tv.0 2018-07-13 17:29:33.631 debug connection is ALIVE
                                      ! philips-tv.0 2018-07-13 17:29:33.517 debug attempt 1 of 3
                                      ! philips-tv.0 2018-07-13 17:29:33.508 debug checking if connection is alive
                                      ! philips-tv.0 2018-07-13 17:29:33.489 debug initializing connection to 192.168.178.24
                                      ! philips-tv.0 2018-07-13 17:29:33.292 info starting. Version 0.3.0-alpha7 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.14.3
                                      ! philips-tv.0 2018-07-13 17:29:33.157 debug statesDB connected
                                      ! philips-tv.0 2018-07-13 17:29:32.990 debug objectDB connected
                                      ! Beim Klick über VIS passiert noch nicht viel. Der Ereignisse-Log ist allerdings interessant, da Zustandsänderungen (Lautstärke mit Fernseh-Fernbedienung geändert) am TV erkannt werden.
                                      ! >! stateChange system.adapter.philips-tv.0.outputCount 9 true philips-tv.0 2018-07-13 19:31:48.417 2018-07-13 19:31:48.417
                                      ! stateChange system.adapter.philips-tv.0.inputCount 1 true philips-tv.0 2018-07-13 19:31:48.413 2018-07-13 19:31:18.426
                                      ! stateChange system.adapter.philips-tv.0.uptime 139 true philips-tv.0 2018-07-13 19:31:48.404 2018-07-13 19:31:48.404
                                      ! stateChange system.adapter.philips-tv.0.memHeapUsed 15.43 true philips-tv.0 2018-07-13 19:31:48.403 2018-07-13 19:31:48.403
                                      ! stateChange system.adapter.philips-tv.0.memHeapTotal 17.98 true philips-tv.0 2018-07-13 19:31:48.401 2018-07-13 19:31:48.401
                                      ! stateChange system.adapter.philips-tv.0.memRss 38.26 true philips-tv.0 2018-07-13 19:31:48.399 2018-07-13 19:31:48.399
                                      ! stateChange system.adapter.philips-tv.0.connected true true philips-tv.0 2018-07-13 19:31:48.398 2018-07-13 19:29:33.398
                                      ! stateChange system.adapter.philips-tv.0.alive true true philips-tv.0 2018-07-13 19:31:48.393 2018-07-13 19:29:33.394
                                      ! stateChange philips-tv.0.volume 40 true philips-tv.0 2018-07-13 19:31:46.592 2018-07-13 19:31:46.592
                                      ! stateChange system.adapter.philips-tv.0.outputCount 8 true philips-tv.0 2018-07-13 19:31:33.403 2018-07-13 19:31:03.390
                                      ! stateChange system.adapter.philips-tv.0.inputCount 1 true philips-tv.0 2018-07-13 19:31:33.401 2018-07-13 19:31:18.426
                                      ! stateChange system.adapter.philips-tv.0.uptime 124 true philips-tv.0 2018-07-13 19:31:33.400 2018-07-13 19:31:33.400
                                      ! stateChange system.adapter.philips-tv.0.memHeapUsed 20.59 true philips-tv.0 2018-07-13 19:31:33.398 2018-07-13 19:31:33.398
                                      ! stateChange system.adapter.philips-tv.0.memHeapTotal 30.98 true philips-tv.0 2018-07-13 19:31:33.396 2018-07-13 19:29:48.321
                                      ! stateChange system.adapter.philips-tv.0.memRss 46.81 true philips-tv.0 2018-07-13 19:31:33.395 2018-07-13 19:31:33.395
                                      ! stateChange system.adapter.philips-tv.0.connected true true philips-tv.0 2018-07-13 19:31:33.393 2018-07-13 19:29:33.398
                                      ! stateChange system.adapter.philips-tv.0.alive true true philips-tv.0 2018-07-13 19:31:33.389 2018-07-13 19:29:33.394
                                      ! stateChange philips-tv.0.pressKey
                                      ! @AlCalzone: `
                                      ! > @Ulfhednir: Magst du mir den Trafficlog mal zukommen lassen?
                                      ! Auf meiner Fritte ist einiges an Traffic, auch einige unverschlüsselte Dienste. Die eth-Datei müsste ich erst entsprechend aufbereiten.
                                        Jan201 last edited by
                                        @AlCalzone:
                                        Du hast einen Fernseher mit v6-API, welcher ein initiales Pairing mit dem ioBroker-Gerät benötigt. Bin leider noch nicht dazu gekommen, das ins Admin-Interface einzubauen.
                                        Es gibt einen Workaround, den andere Poster in diesem Thread beschrieben haben:
                                        • Pairing über ein Python-Skript
                                        • "manuelles" Eintragen von Username/Passwort mittels Skript (siehe vorvorletzer Beitrag).
                                        Wichtig ist außerdem, dass du nach Github-Installationen immer noch einen Upload des Adapters durchführst (Adapter-Liste/Expertenmodus). ` Moin,
                                        Also ich hänge derzeit dabei einen Username und password zu generieren. und wo muss der eingetragen werden? und das mit dem pairing über Python verstehe ich ach nicht bzw habe da nix zu gefunden
                                        • AlCalzone
                                          @Ulfhednir:
                                          Beim Klick über VIS passiert noch nicht viel. Der Ereignisse-Log ist allerdings interessant, da Zustandsänderungen (Lautstärke mit Fernseh-Fernbedienung geändert) am TV erkannt werden. `
                                          Auch wenn nichts viel passiert, sollte doch zumindest was im Debug-Log auftauchen, oder? Diese Infos sind für mich interessant.
                                          Kannst du den Traffic limitieren auf bestimmte IPs? So kann man bspw. in Wireshark nur das nötigste aufnehmen.
                                            akr1983 last edited by
                                            Hiho,
                                            also erstmal Respekt vor der Arbeit die du dir da gemacht hast und dass du jetzt auch den Ehrgeiz hast es weiter zu machen. Ich bin einer der Api V6 Kandidaten 😉
                                            Leider war ich auf dem Pi zu doof das Python Script ans laufen zu bekommen, allerdings kann ich beim mitschneiden mit der Fritzbox helfen. Sofern vorhanden auf der Kommandozeile folgendes eingeben:
                                            tcpdump host "<ip vom/fernseher="">" -w output.dat</ip>
                                            Dann wird nur der Verkehr vom Fernseher und dem Host mitgeschnitten (wenn er denn über die FB läuft). Die Output.dat musst du dann nur runterladen und alcazone zur Verfügung stellen.
                                            Liebe Grüße
                                            Arne
                                            philips philips tv
                                            84
                                            550
                                            131218
