    4. Adapter: iobroker.backitup (stable Release)
    • Peoples
      Peoples last edited by
      @Homoran:
      Welces ioBroker.Dir?
      /opt/iobroker??? `
      genau!
        minimal|||192.168.138.71|public/backups|Mein_usr|Mein_PW~|||||||||||||/opt/iobroker
        backitup.sh: line 94: [: ==: unary operator expected
        --- Es wurde ein Normales Backup gestartet ---
        Backup created: /opt/iobroker/backups/2018_07_17-23_04_22_backupiobroker.tar.gz
        success --- Ein normales Backup wurde erstellt ---
        --- Es werden keine alten Backups geloescht ---
        backitup.sh: line 285: [: ==: unary operator expected
        backitup.sh: line 319: [: ==: unary operator expected
        • Peoples
          Mein Fehler!
          Die Angabe für CIFS oder FTP hat gefehlt :````
          sudo bash backitup.sh "minimal|||deine nas ip|dein Verzeichnis|Dein_NAS_User|Dein_NAS_PW||||CIFS|false|false|||| | | |dein_IoBroker_Dir"
          • simatec
            Und was sagt die Logausgabe zwecks mount?
              Das sieht schon interessanter aus:
               minimal|||192.168.138.71|public/backups|Mein_usr|Mein_pw||||CIFS|false|false|||| | | |/opt/iobroker
              --- Mount Backup-Path on CIFS ---
              mount: wrong fs type, bad option, bad superblock on //192.168.138.71/public/backups,
                     missing codepage or helper program, or other error
                     (for several filesystems (e.g. nfs, cifs) you might
                     need a /sbin/mount. <type>helper program)
                     In some cases useful info is found in syslog - try
                     dmesg | tail or so.
                     dmesg | tail or so.
              error --- Backup-Pfad wurde nicht auf CIFS-Server verbunden ---
              Backup created: /opt/iobroker/backups/2018_07_17-23_16_00_backupiobroker.tar.gz
              find: invalid argument `+ ' to `-mtime'
              --- Es werden keine alten Backups geloescht ---</type></type>
                Hab noch was:
                [ 7126.470039] No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old ser    vers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
                HTH
                Gute Nacht in …
                Rainer
                • simatec
                  vers=1.0 ist eigentlich definiert in der shell
                    J Riemann last edited by
                    Nach dem neuen Update erscheint folgende Meldung im Log:
                    backitup.0	2018-07-17 23:31:29.984	warn	Please translate ind words.js: CIFS-Mount: JA
                    backitup.0	2018-07-17 23:31:29.983	warn	Please translate ind words.js: Typ
                    backitup.0	2018-07-17 23:31:29.981	warn	Please translate ind words.js: Noch keine Backups erstellt
                    backitup.0	2018-07-17 23:31:29.957	info	[ccu] oneClick backup started
                    Weitere Einträge gibt es nicht obwohl das Backup erstellt und auf die NAS geschrieben wurde.
                      Unter Instanzen als Experte loglevel auf debug stellen!
                      Rainer
                        Das erweitert zwar die Ausgabe, aber nach der "warn" Meldung ist Schluss und die Erfolgsmeldungen werden nicht ausgegeben.
                        Vor dem Update sah es im Log so aus:
                        backitup.0	2018-07-17 22:37:09.255	info	success --- Umount CIFS Server ---
                        backitup.0	2018-07-17 22:37:09.255	info	success --- Ueberpruefung auf alte Dateien und loeschen erfolgreich ---
                        backitup.0	2018-07-17 22:37:09.255	info	--- Alte Backups entfernen ---
                        backitup.0	2018-07-17 22:37:09.255	info	success --- Ein Homematic-CCU Backup wurde erstellt ---
                        backitup.0	2018-07-17 22:37:09.255	info	success --- Login Homematic-CCU erfolgreich ---
                        backitup.0	2018-07-17 22:37:09.255	info	--- Es wurde ein Homematic CCU Backup gestartet ---
                        backitup.0	2018-07-17 22:37:09.255	info	success --- CIFS-Server verbunden ---
                        backitup.0	2018-07-17 22:37:09.255	info	--- Backup-Pfad auf CIFS mounten ---
                        backitup.0	2018-07-17 22:37:09.255	info	exec: ccu||30|192.168.178.215|Sicherungen/RaspberyMatic|Riemann|xxxxx|192.168.178.217|Admin||CIFS||||||5|localhost|3307
                        backitup.0	2018-07-17 22:36:39.158	info	OneClick CCU Backup gestartet
                        Jetzt ist es so:
                        backitup.0	2018-07-17 23:46:46.851	warn	Please translate ind words.js: CIFS-Mount: JA
                        backitup.0	2018-07-17 23:46:46.850	warn	Please translate ind words.js: Typ
                        backitup.0	2018-07-17 23:46:46.849	warn	Please translate ind words.js: Noch keine Backups erstellt
                        backitup.0	2018-07-17 23:46:46.807	info	[ccu] bash /opt/iobroker/node_modules/iobroker.backitup/backitup.sh "ccu||30|192.168.178.215|Sicherungen/RaspberyMatic|Riemann|xxx|192.168.178.217|Admin||CIFS|||||||||/opt/iobroker"
                        backitup.0	2018-07-17 23:46:46.802	info	[ccu] oneClick backup started
                        Nach dem Update waren auch alle Einstellungen verschwunden und alle Objekte waren doppelt vorhanden.
                        Geändert: passwort entfernt; Homoran (Admin)
                        • Peoples
                          Durch die übernommenen Änderungen ist einiges durcheinander gekommen und läuft nicht mehr ganz rund.
                          Auch ist irgendwo noch ein Fehler bei der Werteübergabe von JS nach Shell schau ich mir alles morgen an!
                          Gut Nacht
                            Ok, danke!
                            Das Backup läuft sauber durch.
                            • simatec
                              Heute gab es von bluefox große Änderungen, damit der Adapter es vielleicht in die Iobroker Repro schafft.
                              Leider haben sich dabei einige Fehler eingeschlichen, an denen peoples und ich aber dran sind.
                              • Z
                                Zipkart last edited by
                                @Lenny.CB:
                                hier mal mein Kurzfeedback:
                                Adapterversion 0.2.0, Fritzbox mit HDD dran
                                FTP –> funktioniert (gleich auf Anhieb)
                                CIFS --> funktioniert (hier hatte ich eine Weile gebraucht habe bis die Einstellungen (Fritzbox und Pfad im Adapter) korrekt waren.
                                Grüße, Lenny `
                                Hallon Lenny.
                                Hier würde ich gerne mal eingrätschen. Meine Config ist ähnlich an der Fritzbox ist eine Platte angeschlossen.
                                Den FTP zugriff habe ich auch gut hinbekommen.
                                An CIFS bin ich gescheitert.
                                Ich habe sowohl
                                Fritz.nas/backupordner/
                                Als auch 192.168.178.254/backupordner probiert.
                                Leider bis jetzt ohne Erfolg
                                Was hast du denn eingetrageb bzw. Bei der Fritzbox aktiviert?
                                Stefan
                                • Lenny.CB
                                  Lenny.CB Most Active last edited by
                                  @Zipkart:
                                  Stefan `
                                  Hallo Stefan,
                                  hier mal meine Einstellungen mit ein paar Anmerkungen…
                                  Nutzer in der Fritzbox anlegen
                                  --> System/FRITZ!Box-Benutzer/Benutzer aufrufen und Benutzer hinzufügen
                                  --> Hacken bei "Zugang zu NAS-Inhalten" setzen
                                  --> Verzeichnis hinzufügen
                                  --> Verzeichnis auswählen ("Alle an der FRITZ!Box verfügbaren Speicher" hat bei mir nicht funktioniert, daher Freigabe zweier einzelner Ordner)
                                  --> Beispiel: /WD-MyPassport25E2-01/FRITZ/backup_iobroker/minimal
                                  --> "OK" klicken
                                  Heimnetzfreigabe erstellen
                                  --> Heimnetz/Speicher (NAS) aufrufen
                                  --> Hacken bei "Zugriff über ein Netzlaufwerk (SMB) aktiv" setzen
                                  --> Beispiel: "Name" fritzbox, "Arbeitsgruppe" fritzbox (was unter "Name" eingetragen ist, brauchen wir noch im Adapter)
                                  --> "Übernehmen" klicken
                                  Adaptereinstellungen
                                  --> "Verbindungstyp" CIFS
                                  --> "Host" IP der Fritzbox (habe hier nur mit der IP getestet, nicht mit dem Namen)
                                  --> "Benutzername" der, der in der Fritzbox unter "Benutzer" angelegt wurde
                                  --> "Passwort" das, was in der Fritzbox unter "Benutzer" angelegt wurde
                                  --> "NAS-Pfad für Standard-Backup" Freigabe und Pfad zum freigegebenen Ordner OHNE dem ersten "/"
                                  --> Beispiel: fritzbox/WD-MyPassport25E2-01/FRITZ/backup_iobroker/minimal
                                  --> "NAS-Pfad für Komplett-Backup" hier noch für das Komplett-Backup falls getrennte Ordner
                                  --> "Speichern"
                                  Dann sollte das schon alles funktionieren. Testen kann man das, indem man in den backitup-Objekten den betreffenden "OneClick" kurz auf "true" toggelt.
                                  Getestet habe ich mit Version 0.2.0
                                  Grüße, Lenny
                                  • Z
                                    Dankeschön.
                                    Werde ich mal testen.
                                    Gruss Stefan
                                    • simatec
                                      @Homoran:
                                      Hab noch was:
                                      HTH
                                      Gute Nacht in …
                                      Rainer `
                                      Hi Rainer,
                                      hast die cifs zum laufen bekommen?
                                        Nein!
                                        ich habe diverse CIFS auf der Syno noch von v3 auf v2 zurückgestellt, diverse andere Konfigurationen getestet, aber der Fehler bleibt.
                                        von Windows aus kann ich da zugreifen.
                                        rainer
                                        • simatec
                                          Hast du mal im bash geschaut.
                                          Eventuell musst du die Versionsnummer anpassen.
                                          Da gibt es im backitup.sh zwei mount Befehle.
                                          Falls es mit einer anderen Version gehen sollte, dann muss ich da ne for Schleife einbauen.
                                          Im shell ist aktuell vers=1.0
                                            @simatec:
                                            Da gibt es im backitup.sh zwei mount Befehle. `
                                            Ist ja lieb gemeint - aber das kann ich leider nicht.
                                            Ich hatte es immer mit deinem Befehl gemacht.
                                            das backitup.sh habe ich mir noch nicht angesehen, da würde ich zu viel kaputt machen 😉
                                            Rainer
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1173181
