    4. Adapter: iobroker.backitup (stable Release)
    • chucky666
      chucky666 last edited by
      er zeigt mir viele Fehler an , macht aber das backup und packt es auf das Nas
      <code>backitup.0	2018-07-23 22:12:42.381	error	[minimal] * Connection #0 to host 192.168.178.50 left intact
      backitup.0	2018-07-23 22:12:42.380	error	[minimal] < 226 Transfer complete.
      backitup.0	2018-07-23 22:12:42.365	error	[minimal] * Remembering we are in dir "Disk/Iobroker/"
      backitup.0	2018-07-23 22:12:42.363	error	[minimal] * We are completely uploaded and fine
      backitup.0	2018-07-23 22:12:42.340	error	[minimal] } [16384 bytes data]
      backitup.0	2018-07-23 22:12:42.339	error	[minimal] < 150 Opening BINARY mode data connection for 'minimal-2018_07_23-22_12_20_backupiobroker.tar.gz'.
      backitup.0	2018-07-23 22:12:42.332	error	[minimal] > STOR minimal-2018_07_23-22_12_20_backupiobroker.tar.gz
      backitup.0	2018-07-23 22:12:42.330	error	[minimal] < 200 Type set to I.
      backitup.0	2018-07-23 22:12:42.329	error	[minimal] > TYPE I
      backitup.0	2018-07-23 22:12:42.328	error	[minimal] * Connected to 192.168.178.50 (192.168.178.50) port 21 (#0)
      backitup.0	2018-07-23 22:12:42.318	error	[minimal] * Connecting to 192.168.178.50 (192.168.178.50) port 55536
      backitup.0	2018-07-23 22:12:42.317	error	[minimal] * Trying 192.168.178.50...
      backitup.0	2018-07-23 22:12:42.316	error	[minimal] < 227 Entering Passive Mode (192,168,178,50,216,240)
      backitup.0	2018-07-23 22:12:42.315	error	[minimal] * Connect data stream passively
      backitup.0	2018-07-23 22:12:42.314	error	[minimal] > PASV
      backitup.0	2018-07-23 22:12:42.314	error	[minimal] < 250 CWD command successful.
      backitup.0	2018-07-23 22:12:42.313	error	[minimal] > CWD Iobroker
      backitup.0	2018-07-23 22:12:42.310	error	[minimal] < 250 CWD command successful.
      backitup.0	2018-07-23 22:12:42.287	error	[minimal] * ftp_perform ends with SECONDARY: 0
      backitup.0	2018-07-23 22:12:42.286	error	[minimal] > CWD Disk
      backitup.0	2018-07-23 22:12:42.273	error	[minimal] * Entry path is '/'
      backitup.0	2018-07-23 22:12:42.271	error	[minimal] < 257 "/" is current directory.
      backitup.0	2018-07-23 22:12:42.162	error	[minimal] > PWD
      backitup.0	2018-07-23 22:12:42.159	error	[minimal] < 230 User admin logged in./code]</code>
      • simatec
        Wo zeigt er die Fehler an?
        Im Log?
        • chucky666
          Ja genau im log
          Gesendet von iPad mit Tapatalk Pro
          • simatec
            Von welcher Version bist du auf 0.2.4 gewechselt?
            Hast du nach dem Update aus dem github noch einmal ein upload vom Adapter gemacht?
            Probiere mal eine weitere Instanz vom Adapter zu installieren und teste es damit mal bitte
            • chucky666
              Da mein System geschrottet war , musste ich alles neu machen .
              2.4 ist die erste Version die ich installiert habe auf dem System
              • simatec
                OK schauen wir uns mal an.
                Keine dieser Meldungen ist ein error. Darum wundern mich die Meldungen.
                • chucky666
                  Auch mit einer weiteren Instanz kommen diese Meldungen.
                  Backup wird gemacht und auf das NAS kopiert
                  • Peoples
                    Peoples last edited by
                    @chucky666:
                    Also rein Inhaltlich lese ich das so als wären das alles Statusmeldungen die eben mit einem error vorne dran stehen. Oder siehst du das anders, denn ein wirklicher Fehler steh da ja nicht oder? Kommt aber bei mir auch wenn ich das über die Konsole ausführe
                    • chucky666
                      Habe ich mir auch gedacht
                      • simatec
                        So wie ich das sehe betrifft es alles den ftp Upload.
                        Da haben wir ein Pull Request von bluefox bekommen, der das beheben sollte.
                        • chucky666
                          Ok Danke , und Danke für den geilen Adapter
                          • Peoples
                            Was komisch ist, die Meldung sollte nicht auftauchen da hier:
                                        if (text[0] == '*' || text[0] == '<' || text[0] == '>') {
                            Eigentlich alles abgefangen werden sollte, ich werde mal suchen
                              JackWolfskind last edited by
                              Der Adapter erstellt jetzt fleissig Backups, aber übertragen per FTP oder CIFS wo anders hin geht leider nicht. Kann das sein das FTP und CIFS im Standard Raspberry/ioBroker Image gar nicht installiert bzw. enabled ist?
                              Dummerweise habe ich auch noch festgestellt das meine SD Karte mal wieder vollläuft von daher kann ich zu allem Unglück auch nix mehr installieren, d.h. ich hab ein Backup aber komme leider nicht ran :shock:
                                @JackWolfskind:
                                Kann das sein das FTP und CIFS im Standard Raspberry/ioBroker Image gar nicht installiert bzw. enabled ist? `
                                Ja! (siehe oben!) Da war ich auch dran gescheitert.
                                apt install cifs-utils)
                                auch nicht mit filezilla auf den PC sichern??
                                und dann die unnötigen Backups löschen
                                Rainer
                                  Moin Rainer,
                                  cifs-utils ist sogar schon drauf - da werde ich mich mal in die config einlesen und hoffentlich so drankommen 8-)
                                  Filezilla lässt mich vom PC leider nicht auf den RPi, fehlt wohl mal wieder irgendwas im Linux :roll:
                                    @JackWolfskind:
                                    Filezilla lässt mich vom PC leider nicht auf den RPi, fehlt wohl mal wieder irgendwas im Linux :roll: `
                                    Die Standardimages haben (siehe ReadMe) keinen Rootzugang per ftp; nur für den User pi
                                    Damit klappt es aber.
                                    @JackWolfskind:
                                    da werde ich mich mal in die config einlesen und hoffentlich so drankommen 8-) `
                                    Da muss nichts konfiguriert werden. Wie sind denn deine Konfigs im Adapter?
                                    Rainer
                                      @Homoran:
                                      Damit klappt es aber. `
                                      Achso, das erkärt schonmal das Problem mit FTP zum RPi. Dann muss ich das heute abend nochmal zuhause mit Filezilla ausprobieren.
                                      @Homoran:
                                      Da muss nichts konfiguriert werden. Wie sind denn deine Konfigs im Adapter? `
                                      Dachte eigentlich ich hätte endlich die krude Syntax kapiert :lol:
                                      Egal ob CIFS oder FTP, Host und User eingetragen…
                                      und den Pfad ohne führendes "/" und per "/" statt " " auch bei CIFS:
                                      Pfad/Verzeichnis
                                      Aber wenn ich mir dei Daten per FTP runterziehen kann dann setzt ich den Pi mit dem neuesten Image auf eine großen Karte neu auf und spiele das Backup zurück...
                                      Wird eigentlich die Historie Datenbank mit gebackupt?
                                        @JackWolfskind:
                                        Wird eigentlich die Historie Datenbank mit gebackupt? `
                                        Nein!
                                        diese Daten kannst du auch per filezilla runterziehen und wieder auf die neue Installation übernehmen.
                                        @JackWolfskind:
                                        Pfad/Verzeichnis `
                                        Ein Screenshot wäre erhellender :lol:
                                        Rainer
                                          ` > Hallo,
                                          warum habe ich das Backitup in Alexa? `
                                          gibt es da schon eine Lösung?
                                          viewtopic.php?f=23&t=15256&p=161354#p161381
                                            fraeggle last edited by
                                            @Homoran:
                                            @JackWolfskind:
                                            Nein!
                                            Rainer `
                                            Hmm im kompletten ist das bei mir aber drin.
                                            Gruß Peter
                                            1.3k
                                            81.1k
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1185448
