    3. Cloud Dienste
    4. Neuer Adapter: iobroker.alexa2
      apollon77 last edited by
      Vor dem Upload muss mal mindestens mal eine Instanz angelegt sein.
      iobroker add alexa2
      danach das Upload
        LaBamba last edited by
        Ok habe ich gemacht!
        pi@raspberrypi:/opt/iobroker $ iobroker add alexa2
        host.raspberrypi install adapter alexa2
        npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.alexa2"
        got /opt/iobroker/node_modules/iobroker.alexa2/admin
        upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
        upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index.html index.html text/html
        upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
        host.raspberrypi object system.adapter.alexa2 created
        host.raspberrypi create instance alexa2
        host.raspberrypi object alexa2.0.info.csrf created
        host.raspberrypi object alexa2.0.info.cookie created
        host.raspberrypi object alexa2.0.info.connection created
        host.raspberrypi object alexa2.0.info created
        host.raspberrypi object system.adapter.alexa2.0.outputCount created
        host.raspberrypi object system.adapter.alexa2.0.inputCount created
        host.raspberrypi object system.adapter.alexa2.0.uptime created
        host.raspberrypi object system.adapter.alexa2.0.memRss created
        host.raspberrypi object system.adapter.alexa2.0.memHeapTotal created
        host.raspberrypi object system.adapter.alexa2.0.memHeapUsed created
        host.raspberrypi object system.adapter.alexa2.0.connected created
        host.raspberrypi object system.adapter.alexa2.0.alive created
        host.raspberrypi object system.adapter.alexa2.0 created
        pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.alexa2
        - arr-diff@4.0.0 node_modules/iobroker.alexa2/node_modules/arr-diff
        - arr-flatten@1.1.0 node_modules/iobroker.alexa2/node_modules/arr-flatten
        - arr-union@3.1.0 node_modules/iobroker.alexa2/node_modules/arr-union
        - array-flatten@1.1.1 node_modules/iobroker.alexa2/node_modules/array-flatten
        - array-unique@0.3.2 node_modules/iobroker.alexa2/node_modules/array-unique
        - assign-symbols@1.0.0 node_modules/iobroker.alexa2/node_modules/assign-symbols
        - atob@2.1.1 node_modules/iobroker.alexa2/node_modules/atob
        - buffer-from@1.1.0 node_modules/iobroker.alexa2/node_modules/buffer-from
        - bufferhelper@0.2.1 node_modules/iobroker.alexa2/node_modules/bufferhelper
        - bytes@3.0.0 node_modules/iobroker.alexa2/node_modules/bytes
        - component-emitter@1.2.1 node_modules/iobroker.alexa2/node_modules/component-emitter
        - content-disposition@0.5.2 node_modules/iobroker.alexa2/node_modules/content-disposition
        - content-type@1.0.4 node_modules/iobroker.alexa2/node_modules/content-type
        - cookie@0.3.1 node_modules/iobroker.alexa2/node_modules/cookie
        - cookie-signature@1.0.6 node_modules/iobroker.alexa2/node_modules/cookie-signature
        - copy-descriptor@0.1.1 node_modules/iobroker.alexa2/node_modules/copy-descriptor
        - core-util-is@1.0.2 node_modules/iobroker.alexa2/node_modules/core-util-is
        - decode-uri-component@0.2.0 node_modules/iobroker.alexa2/node_modules/decode-uri-component
        - depd@1.1.2 node_modules/iobroker.alexa2/node_modules/depd
        - destroy@1.0.4 node_modules/iobroker.alexa2/node_modules/destroy
        - ee-first@1.1.1 node_modules/iobroker.alexa2/node_modules/ee-first
        - encodeurl@1.0.2 node_modules/iobroker.alexa2/node_modules/encodeurl
        - escape-html@1.0.3 node_modules/iobroker.alexa2/node_modules/escape-html
        - etag@1.8.1 node_modules/iobroker.alexa2/node_modules/etag
        - eventemitter3@3.1.0 node_modules/iobroker.alexa2/node_modules/eventemitter3
        - for-in@1.0.2 node_modules/iobroker.alexa2/node_modules/for-in
        - forwarded@0.1.2 node_modules/iobroker.alexa2/node_modules/forwarded
        - fresh@0.5.2 node_modules/iobroker.alexa2/node_modules/fresh
        - get-value@2.0.6 node_modules/iobroker.alexa2/node_modules/get-value
        - https@1.0.0 node_modules/iobroker.alexa2/node_modules/https
        - iconv-lite@0.4.19 node_modules/iobroker.alexa2/node_modules/iconv-lite
        - inherits@2.0.3 node_modules/iobroker.alexa2/node_modules/inherits
        - ipaddr.js@1.6.0 node_modules/iobroker.alexa2/node_modules/ipaddr.js
        - is-buffer@1.1.6 node_modules/iobroker.alexa2/node_modules/is-buffer
        - kind-of@4.0.0 node_modules/iobroker.alexa2/node_modules/has-values/node_modules/kind-of
        - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/is-accessor-descriptor/node_modules/kind-of
        - is-accessor-descriptor@0.1.6 node_modules/iobroker.alexa2/node_modules/is-accessor-descriptor
        - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/is-data-descriptor/node_modules/kind-of
        - is-data-descriptor@0.1.4 node_modules/iobroker.alexa2/node_modules/is-data-descriptor
        - kind-of@5.1.0 node_modules/iobroker.alexa2/node_modules/is-descriptor/node_modules/kind-of
        - is-descriptor@0.1.6 node_modules/iobroker.alexa2/node_modules/is-descriptor
        - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/class-utils/node_modules/define-property
        - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/expand-brackets/node_modules/define-property
        - is-extendable@0.1.1 node_modules/iobroker.alexa2/node_modules/is-extendable
        - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/braces/node_modules/extend-shallow
        - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/expand-brackets/node_modules/extend-shallow
        - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/extend-shallow
        - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/fill-range/node_modules/extend-shallow
        - is-extglob@2.1.1 node_modules/iobroker.alexa2/node_modules/is-extglob
        - is-glob@4.0.0 node_modules/iobroker.alexa2/node_modules/is-glob
        - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/is-number/node_modules/kind-of
        - is-number@3.0.0 node_modules/iobroker.alexa2/node_modules/is-number
        - has-values@1.0.0 node_modules/iobroker.alexa2/node_modules/has-values
        - is-windows@1.0.2 node_modules/iobroker.alexa2/node_modules/is-windows
        - isarray@1.0.0 node_modules/iobroker.alexa2/node_modules/isarray
        - isobject@3.0.1 node_modules/iobroker.alexa2/node_modules/isobject
        - has-value@1.0.0 node_modules/iobroker.alexa2/node_modules/has-value
        - is-plain-object@2.0.4 node_modules/iobroker.alexa2/node_modules/is-plain-object
        - is-extendable@1.0.1 node_modules/iobroker.alexa2/node_modules/extend-shallow/node_modules/is-extendable
        - extend-shallow@3.0.2 node_modules/iobroker.alexa2/node_modules/extend-shallow
        - kind-of@6.0.2 node_modules/iobroker.alexa2/node_modules/kind-of
        - is-accessor-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/base/node_modules/is-accessor-descriptor
        - is-data-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/base/node_modules/is-data-descriptor
        - is-descriptor@1.0.2 node_modules/iobroker.alexa2/node_modules/base/node_modules/is-descriptor
        - define-property@1.0.0 node_modules/iobroker.alexa2/node_modules/base/node_modules/define-property
        - is-accessor-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/define-property/node_modules/is-accessor-descriptor
        - is-data-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/define-property/node_modules/is-data-descriptor
        - is-descriptor@1.0.2 node_modules/iobroker.alexa2/node_modules/define-property/node_modules/is-descriptor
        - define-property@2.0.2 node_modules/iobroker.alexa2/node_modules/define-property
        - is-accessor-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/is-accessor-descriptor
        - is-data-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/is-data-descriptor
        - is-descriptor@1.0.2 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/is-descriptor
        - define-property@1.0.0 node_modules/iobroker.alexa2/node_modules/extglob/node_modules/define-property
        - lodash@4.17.10 node_modules/iobroker.alexa2/node_modules/lodash
        - map-cache@0.2.2 node_modules/iobroker.alexa2/node_modules/map-cache
        - fragment-cache@0.2.1 node_modules/iobroker.alexa2/node_modules/fragment-cache
        - media-typer@0.3.0 node_modules/iobroker.alexa2/node_modules/media-typer
        - merge-descriptors@1.0.1 node_modules/iobroker.alexa2/node_modules/merge-descriptors
        - methods@1.1.2 node_modules/iobroker.alexa2/node_modules/methods
        - mime@1.4.1 node_modules/iobroker.alexa2/node_modules/mime
        - mime-db@1.35.0 node_modules/iobroker.alexa2/node_modules/mime-db
        - mime-types@2.1.19 node_modules/iobroker.alexa2/node_modules/mime-types
        - is-extendable@1.0.1 node_modules/iobroker.alexa2/node_modules/mixin-deep/node_modules/is-extendable
        - mixin-deep@1.3.1 node_modules/iobroker.alexa2/node_modules/mixin-deep
        - ms@2.0.0 node_modules/iobroker.alexa2/node_modules/ms
        - debug@2.6.9 node_modules/iobroker.alexa2/node_modules/debug
        - debug@3.1.0 node_modules/iobroker.alexa2/node_modules/follow-redirects/node_modules/debug
        - follow-redirects@1.5.1 node_modules/iobroker.alexa2/node_modules/follow-redirects
        - negotiator@0.6.1 node_modules/iobroker.alexa2/node_modules/negotiator
        - accepts@1.3.5 node_modules/iobroker.alexa2/node_modules/accepts
        - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/object-copy/node_modules/define-property
        - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/object-copy/node_modules/kind-of
        - object-copy@0.1.0 node_modules/iobroker.alexa2/node_modules/object-copy
        - object-visit@1.0.1 node_modules/iobroker.alexa2/node_modules/object-visit
        - map-visit@1.0.0 node_modules/iobroker.alexa2/node_modules/map-visit
        - collection-visit@1.0.0 node_modules/iobroker.alexa2/node_modules/collection-visit
        - object.pick@1.3.0 node_modules/iobroker.alexa2/node_modules/object.pick
        - on-finished@2.3.0 node_modules/iobroker.alexa2/node_modules/on-finished
        - parseurl@1.3.2 node_modules/iobroker.alexa2/node_modules/parseurl
        - pascalcase@0.1.1 node_modules/iobroker.alexa2/node_modules/pascalcase
        - path-to-regexp@0.1.7 node_modules/iobroker.alexa2/node_modules/path-to-regexp
        - posix-character-classes@0.1.1 node_modules/iobroker.alexa2/node_modules/posix-character-classes
        - process-nextick-args@2.0.0 node_modules/iobroker.alexa2/node_modules/process-nextick-args
        - proxy-addr@2.0.3 node_modules/iobroker.alexa2/node_modules/proxy-addr
        - qs@6.5.1 node_modules/iobroker.alexa2/node_modules/qs
        - querystring@0.2.0 node_modules/iobroker.alexa2/node_modules/querystring
        - range-parser@1.2.0 node_modules/iobroker.alexa2/node_modules/range-parser
        - depd@1.1.1 node_modules/iobroker.alexa2/node_modules/raw-body/node_modules/depd
        - setprototypeof@1.0.3 node_modules/iobroker.alexa2/node_modules/raw-body/node_modules/setprototypeof
        - repeat-element@1.1.2 node_modules/iobroker.alexa2/node_modules/repeat-element
        - repeat-string@1.6.1 node_modules/iobroker.alexa2/node_modules/repeat-string
        - requires-port@1.0.0 node_modules/iobroker.alexa2/node_modules/requires-port
        - http-proxy@1.17.0 node_modules/iobroker.alexa2/node_modules/http-proxy
        - resolve-url@0.2.1 node_modules/iobroker.alexa2/node_modules/resolve-url
        - ret@0.1.15 node_modules/iobroker.alexa2/node_modules/ret
        - safe-buffer@5.1.1 node_modules/iobroker.alexa2/node_modules/safe-buffer
        - safe-regex@1.1.0 node_modules/iobroker.alexa2/node_modules/safe-regex
        - regex-not@1.0.2 node_modules/iobroker.alexa2/node_modules/regex-not
        - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/set-value/node_modules/extend-shallow
        - setprototypeof@1.1.0 node_modules/iobroker.alexa2/node_modules/setprototypeof
        - is-accessor-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/snapdragon-node/node_modules/is-accessor-descriptor
        - is-data-descriptor@1.0.0 node_modules/iobroker.alexa2/node_modules/snapdragon-node/node_modules/is-data-descriptor
        - is-descriptor@1.0.2 node_modules/iobroker.alexa2/node_modules/snapdragon-node/node_modules/is-descriptor
        - define-property@1.0.0 node_modules/iobroker.alexa2/node_modules/snapdragon-node/node_modules/define-property
        - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/snapdragon-util/node_modules/kind-of
        - snapdragon-util@3.0.1 node_modules/iobroker.alexa2/node_modules/snapdragon-util
        - snapdragon-node@2.1.1 node_modules/iobroker.alexa2/node_modules/snapdragon-node
        - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/snapdragon/node_modules/define-property
        - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/snapdragon/node_modules/extend-shallow
        - source-map@0.5.7 node_modules/iobroker.alexa2/node_modules/source-map
        - source-map-url@0.4.0 node_modules/iobroker.alexa2/node_modules/source-map-url
        - split-string@3.1.0 node_modules/iobroker.alexa2/node_modules/split-string
        - set-value@2.0.0 node_modules/iobroker.alexa2/node_modules/set-value
        - define-property@0.2.5 node_modules/iobroker.alexa2/node_modules/static-extend/node_modules/define-property
        - static-extend@0.1.2 node_modules/iobroker.alexa2/node_modules/static-extend
        - class-utils@0.3.6 node_modules/iobroker.alexa2/node_modules/class-utils
        - statuses@1.4.0 node_modules/iobroker.alexa2/node_modules/statuses
        - http-errors@1.6.3 node_modules/iobroker.alexa2/node_modules/http-errors
        - http-errors@1.6.2 node_modules/iobroker.alexa2/node_modules/raw-body/node_modules/http-errors
        - send@0.16.2 node_modules/iobroker.alexa2/node_modules/send
        - serve-static@1.13.2 node_modules/iobroker.alexa2/node_modules/serve-static
        - string_decoder@1.1.1 node_modules/iobroker.alexa2/node_modules/string_decoder
        - kind-of@3.2.2 node_modules/iobroker.alexa2/node_modules/to-object-path/node_modules/kind-of
        - to-object-path@0.3.0 node_modules/iobroker.alexa2/node_modules/to-object-path
        - to-regex@3.0.2 node_modules/iobroker.alexa2/node_modules/to-regex
        - to-regex-range@2.1.1 node_modules/iobroker.alexa2/node_modules/to-regex-range
        - fill-range@4.0.0 node_modules/iobroker.alexa2/node_modules/fill-range
        - type-is@1.6.16 node_modules/iobroker.alexa2/node_modules/type-is
        - typedarray@0.0.6 node_modules/iobroker.alexa2/node_modules/typedarray
        - extend-shallow@2.0.1 node_modules/iobroker.alexa2/node_modules/union-value/node_modules/extend-shallow
        - set-value@0.4.3 node_modules/iobroker.alexa2/node_modules/union-value/node_modules/set-value
        - union-value@1.0.0 node_modules/iobroker.alexa2/node_modules/union-value
        - unpipe@1.0.0 node_modules/iobroker.alexa2/node_modules/unpipe
        - finalhandler@1.1.1 node_modules/iobroker.alexa2/node_modules/finalhandler
        - raw-body@2.3.2 node_modules/iobroker.alexa2/node_modules/raw-body
        - body-parser@1.18.2 node_modules/iobroker.alexa2/node_modules/body-parser
        - isobject@2.1.0 node_modules/iobroker.alexa2/node_modules/unset-value/node_modules/has-value/node_modules/isobject
        - has-values@0.1.4 node_modules/iobroker.alexa2/node_modules/unset-value/node_modules/has-values
        - has-value@0.3.1 node_modules/iobroker.alexa2/node_modules/unset-value/node_modules/has-value
        - unset-value@1.0.0 node_modules/iobroker.alexa2/node_modules/unset-value
        - cache-base@1.0.1 node_modules/iobroker.alexa2/node_modules/cache-base
        - base@0.11.2 node_modules/iobroker.alexa2/node_modules/base
        - urix@0.1.0 node_modules/iobroker.alexa2/node_modules/urix
        - source-map-resolve@0.5.2 node_modules/iobroker.alexa2/node_modules/source-map-resolve
        - use@3.1.1 node_modules/iobroker.alexa2/node_modules/use
        - snapdragon@0.8.2 node_modules/iobroker.alexa2/node_modules/snapdragon
        - braces@2.3.2 node_modules/iobroker.alexa2/node_modules/braces
        - expand-brackets@2.1.4 node_modules/iobroker.alexa2/node_modules/expand-brackets
        - extglob@2.0.4 node_modules/iobroker.alexa2/node_modules/extglob
        - nanomatch@1.2.13 node_modules/iobroker.alexa2/node_modules/nanomatch
        - micromatch@3.1.10 node_modules/iobroker.alexa2/node_modules/micromatch
        - http-proxy-middleware@0.18.0 node_modules/iobroker.alexa2/node_modules/http-proxy-middleware
        - util-deprecate@1.0.2 node_modules/iobroker.alexa2/node_modules/util-deprecate
        - readable-stream@2.3.6 node_modules/iobroker.alexa2/node_modules/readable-stream
        - concat-stream@1.6.2 node_modules/iobroker.alexa2/node_modules/concat-stream
        - http-proxy-response-rewrite@0.0.1 node_modules/iobroker.alexa2/node_modules/http-proxy-response-rewrite
        - utils-merge@1.0.1 node_modules/iobroker.alexa2/node_modules/utils-merge
        - vary@1.1.2 node_modules/iobroker.alexa2/node_modules/vary
        - express@4.16.3 node_modules/iobroker.alexa2/node_modules/express
        - alexa-cookie2@0.2.2 node_modules/iobroker.alexa2/node_modules/alexa-cookie2
        - alexa-remote2@0.2.4 node_modules/iobroker.alexa2/node_modules/alexa-remote2
        iobroker.inst@1.1.2 /opt/iobroker
        └── iobroker.alexa2@0.2.4
           │   Update available 4.6.1 → 6.2.0    │
           │     Run npm i -g npm to update      │
        Soll ich das update von 4.6.1 → 6.2.0 machen?
          @apollon77:
          iobroker add alexa2
          danach das Upload `
          Jetzt taucht der Adapter schon einmal in den Instanzen auf!
          Aus meiner Sicht wäre es hilfreich, wenn ihr diesen Punkt noch in der Adapterbeschreibung hinzufügt.
            Wenn es läuft, bitte im Moment nicht.
            Da scheint ein Bug/Inkompatibilität in npm 6.x zu sein
            Rainer
              @LaBamba:
              Aus meiner Sicht wäre es hilfreich, wenn ihr diesen Punkt noch in der Adapterbeschreibung hinzufügt. `
              Wieso?
              Es ist doch normal, dass eine Installation eines Adapters noch keine Instanz erzeugt.
              Eine Instanz muss immer händisch angelegt werdn (Außer beim Admin)
              Rainer
              • chucky666
                chucky666 last edited by
                Ja warte lieber die 6.2 hat bei mir auch Probleme gemacht
                Gesendet von iPad mit Tapatalk Pro
                  @Homoran:
                  @LaBamba:
                  Wieso?
                  Rainer `
                  Ihr seit Profis! Als Anfänger kann man an solchen kleinen Problemen scheitern.
                    @[url=http://www.iobroker.net/docu/?page_id=5473⟨=de#Adapter:
                    Doku"]http://www.iobroker.net/docu/?page_id=5379&lang=de
                    Hier werden die verfügbaren und installierten Adapter angezeigt und verwaltet.
                    http://www.iobroker.net/docu/?page_id=5474&lang=de
                    Hier werden die bereits über den Reiter Adapter installierten Instanzen aufgelistet und können entsprechend konfiguriert werden. `
                      stephan last edited by
                      @stephan:
                      Hallo, war lange nicht mehr an meinem Iobroker…
                      Doch durch den neuen Adapter bin ich wieder munter geworden.
                      Installiert bekomme ich ihn nur wirft er mir nur Fehler im Log.
                      Habe nur meinen Benutzer und Passwort im Adapter eingegeben, oder fehlen da noch mehr eingaben.
                      host.ioBroker-Pi 2018-07-23 17:17:17.129 info Restart adapter system.adapter.alexa2.0 because enabled
                      host.ioBroker-Pi 2018-07-23 17:17:17.129 error instance system.adapter.alexa2.0 terminated with code 1 ()
                      host.ioBroker-Pi 2018-07-23 17:17:16.791 info instance system.adapter.alexa2.0 started with pid 20703
                      host.ioBroker-Pi 2018-07-23 17:16:46.762 info Restart adapter system.adapter.alexa2.0 because enabled
                      host.ioBroker-Pi 2018-07-23 17:16:46.761 error instance system.adapter.alexa2.0 terminated with code 1 ()
                      host.ioBroker-Pi 2018-07-23 17:16:46.380 info instance system.adapter.alexa2.0 started with pid 20634
                      Was mache ich denn da verkehrt ?
                      Danke schon mal im vorrauss `
                      Hat keiner eine Antwort auf mein Problem…
                        chrizzel last edited by
                        sudo apt-get install git
                        wird das beheben.
                        rainer `
                        Ich danke dir! Das hat geholfen!
                          @stephan:
                          Interessant. Welche js.controller Version?
                          mach mal: Kommandozeile ins iobroker verzeichnis. Dort dann
                          node node_modules/iobroker.alexa2/main.js --force --logs
                          Was ist die Ausgabe?
                            sorry bin absoluter Anfänger…wie mache ich das
                              @apollon77:
                              @stephan:
                              Was ist die Ausgabe? `
                                SSH auf deinen Raspi oder was such immer du nutzt
                                cd /opt/iobroker
                                Dann das was oben steht.
                                Gesendet vom Handy …
                                  A Former User last edited by
                                  Changelog
                                  0.3.0 (2018-07-23)
                                      (Bluefox) Admin3 fixes and slight changes to roles and code
                                      (Apollon77) Combine Player-Control and Player-Info into channel Player to support better detection and material support
                                  :shock: Das heisst, wir bauen nun unsere Views und Skripte wieder um.
                                    Die 0.3.0 ist noch nicht fertig also bitte Finger weg vom GitHub heute 😉
                                    Aber ja leider. Es wurde nötig weil Bluefox gerade für Material einige dinge standardisiert und wie sind jetzt immer noch eher früh unterwegs.
                                    Sollte aber die letzte Anpassung sein. Sorry.
                                    • Merlin123
                                      Merlin123 last edited by
                                      @apollon77:
                                      @Merlin123:
                                      Danke, hab es gerade kurz vorher gefunden und den Post geändert.
                                      Dauert jetzt nur noch recht lange, bis die Konfig aufgerufen wird. Nur bei der konfig von diesem Adapter? Oder auch andere? Sollte an sich nicht am Adapter liegen.
                                      Nur bei dem. Das hat mich ja so gewundert….
                                        @apollon77:
                                        cd /opt/iobroker
                                        Gesendet vom Handy … `
                                        Das kommt bei mir…
                                          Kochenmitmusik last edited by
                                          habe eine Verständnisfrage: kommt das was von Alexa gesprochen werden soll hier rein:
                                          oder hier
                                          • dslraser
                                            @Kochenmitmusik:
                                            Danke `
                                            kommt in das Script. Das Script schreibt es dann (wenn der Trigger ausgelöst wird) in den Datenpunkt.
                                            581
                                            161529
