    3. Cloud Dienste
    4. Neuer Adapter: iobroker.alexa2
    • O
      ooooli last edited by
      Hier das Script nochmal als Export. Sollte nun iimportierbar sein…
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="create" id="RUoTzvo?H17}CcoV|M]y" x="-262" y="-137"><field name="NAME">AnsageErfolgt</field>
          <next><block type="on" id="|[-@.==-%lkD3p#NA/|D"><field name="OID">hue.0.Philips_hue.Flur.on</field>
              <statement name="STATEMENT"><block type="controls_if" id="@218=IkE/qsKmRu{pA[)"><value name="IF0"><block type="logic_operation" id="h;:?sO;C*QR++sFvwlmj"><field name="OP">AND</field>
                      <value name="A"><block type="logic_compare" id="bEb2TgS_Vzfgrm4@YL,K"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="K.gTsCV12F:_5Ncs6-+#"><field name="ATTR">val</field>
                              <field name="OID">hue.0.Philips_hue.Flur.on</field></block></value>
                          <value name="B"><block type="logic_boolean" id="M2k`x?^@ELd;?/_Yx!O?"><field name="BOOL">TRUE</field></block></value></block></value>
                      <value name="B"><block type="logic_compare" id="G{)dWgjJ#+._~Hgk8mSQ"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="7=/x-BQ.v3Xa7@cb#N72"><field name="ATTR">val</field>
                              <field name="OID">javascript.0.AnsageErfolgt</field></block></value>
                          <value name="B"><block type="logic_boolean" id=".k]H{IFel`:;,S)b)d%z"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                  <statement name="DO0"><block type="control" id="?WB3cxnc1VW;,;wpT7.m"><mutation delay_input="true"></mutation>
                      <field name="OID">alexa2.0.Echo-Devices.G090LV036445004S.Commands.speak</field>
                      <field name="DELAY_MS">5</field>
                      <value name="VALUE"><block type="text_join" id="(6p7BX#~~2P}xj7Wn1@;"><mutation items="5"></mutation>
                          <value name="ADD0"><block type="text" id="M76-)zYehBG]!LdyeY5q"><field name="TEXT">Hallo! willkommen zu Hause!</field></block></value>
                          <value name="ADD1"><block type="text" id="E|w.AEkyy_)gieFW[B1@"><field name="TEXT">Es sind</field></block></value>
                          <value name="ADD2"><block type="get_value" id="+23FeR%/`)Vy3Ni[(7za"><field name="ATTR">val</field>
                              <field name="OID">netatmo.0.zu-Hause.Wetterstation.Temperature.Temperature</field></block></value>
                          <value name="ADD3"><block type="text" id="7-:u)+Rn,a.REn{7XAl."><field name="TEXT">Grad in der Wohnung und der Zehohzweiwert beträgt</field></block></value>
                          <value name="ADD4"><block type="get_value" id="ss#R)QpEW`@hPOuqB`[%"><field name="ATTR">val</field>
                              <field name="OID">netatmo.0.zu-Hause.Wetterstation.CO2.CO2</field></block></value></block></value>
                      <next><block type="control" id=":+sw;3]O*:2=m;}oY-`%"><mutation delay_input="false"></mutation>
                          <value name="VALUE"><block type="logic_boolean" id="V:ezxxg{L.az[68LgO]E"><field name="BOOL">FALSE</field></block></value></block></next></block></statement></block></statement>
              <next><block type="on" id="5%2sw2vN~IUt?:~nLn56"><field name="OID">geofency.0.Handy_[priv_].entry</field>
                  <statement name="STATEMENT"><block type="controls_if" id="2.o(9=pF;72dQLlZd{Z}"><mutation elseif="1"></mutation>
                      <value name="IF0"><block type="logic_compare" id="n-3QfDqel51,DR:78:lE"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="[@ZAwx3Q~-5cnVrQn2e}"><field name="ATTR">val</field>
                              <field name="OID">geofency.0.Handy_[priv_].entry</field></block></value>
                          <value name="B"><block type="logic_boolean" id="/LqU`_{.-!+4G?=ARrER"><field name="BOOL">FALSE</field></block></value></block></value>
                      <statement name="DO0"><block type="control" id="+Kxc%`:x3XPxhj30^E:e"><mutation delay_input="false"></mutation>
                          <value name="VALUE"><block type="logic_boolean" id="Klxp/+JSwFl*I#}Muk^Q"><field name="BOOL">FALSE</field></block></value></block></statement>
                      <value name="IF1"><block type="logic_compare" id="C!EKDYHnHg)X@@cAeOT{"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="pd4|+~n%5WOdi_QxvPsU"><field name="ATTR">val</field>
                          <value name="B"><block type="logic_boolean" id="ZZkwi~iV+!bc0KV]7A)i"><field name="BOOL">TRUE</field></block></value></block></value>
                      <statement name="DO1"><block type="control" id="EoUSPk1}^Oly6`[a[k^%"><mutation delay_input="false"></mutation>
                          <value name="VALUE"><block type="logic_boolean" id="]PIxRNdgc/#6E`|nuw^B"><field name="BOOL">TRUE</field></block></value></block></statement></block></statement></block></next></block></next></block></xml>
        hhilde last edited by
        @apollon77:
        Alte Version ist keine sinnvolle Option.
        Es hat sich glaube zwischen 0.2 und 0.3 der Name von history.#trigger nach History.#trigger geändert.
        Weiterhin wird jetzt strenger geprüft was in die datenpunkte reingeschrieben wird. Der Datentype muss stimmen. Da gibts debug im log.
        Bitte alexa2 Instanz loglevel auf debug. Dann bitte aus node red heraus ändern und log senden an der Änderung ein bissl.
        Bitte log nicht aus admin kopieren sondern von der Platte.
        Gesendet vom Handy … `
        Danke für die schnelle Antwort, und die Hinweise.
        Name war klar.
        Ich hab mir die Log-Datei mal angeschaut, und es lag tatsächlich an einem falschen Datentyp.
        Jetzt funktioniert es wieder.
        Danke!!!
          ltsalvatore last edited by
          @ooooli:
          Hier das Script nochmal als Export. Sollte nun iimportierbar sein… `
          super, danke fürs hochladen.
          ich überlege gerade, ob ich anstatt mit dem geofencing das ganze mit dem tr-064 adapter umsetze.
          dort gibt es zu jedem device die beiden werte lastactive und lastinactive.
          so spare ich mir die installation eines weiteren adapters.
          müsste jetzt nur noch überlegen, wie die abfrage auszusehen hat. :roll: :?
          edit:
          ok,.. vielleicht habe ich mich doch zu früh gefreut?
          dachte die beiden werte würden anzeigen, wann das geräte das letzte mal erreichbar (lastactive) und das letzte mal bevor das gerät nicht mehr erreichbar war (lastinactive) anzeigen wüürde….
            Lucky last edited by
            Sehr schöne Arbeit, vielen dank dafür !
            ich würde mir wünschen, (falls möglich) einen Datenpunkt der mit true oder false den jeweiligen Aktivzustand eines Device anzeigt.
            Also wenn ich "Alexa" sage und der Statusring am Gerät leuchtet, das der Datenpunkt auf true wechselt und wider zurück
            Ein nutzen wäre z.b. das kurzfristige Stumm schalten z.b. des Fernsehers oder Verstärkers zum besseren Verständnis des gesprochenen
              apollon77 last edited by
              GitHub issue bitte … vielleicht geht sowas in der Art ... verspreche aber nichts.
              Und ich weiß auch nicht ob man das unbedingt will. So oft wie alexa bei uns beim Fernsehen oder auch mal nebenher an geht ... hm ...
              Gesendet vom Handy ...
                @apollon77:
                Gesendet vom Handy ... `
                ok mach ich !
                wofür man es nutzt ist ja jedem selbst überlassen, man könnte damit auch z.b. das optische Feedback des Echo auf eine Hue Leute auslagern usw..
                  @ltsalvatore:
                  @ooooli:
                  edit:
                  dachte die beiden werte würden anzeigen, wann das geräte das letzte mal erreichbar (lastactive) und das letzte mal bevor das gerät nicht mehr erreichbar war (lastinactive) anzeigen wüürde…. `
                  so.. es scheint doch zu funktionieren bzw. aktualisieren sich die werte der objekte in dem tr-064 adapters wie gewünscht.
                  meine idee nun, wenn das gerät 6 stunden inaktiv war, dann erst alexa befehlen, dass sie guten abend sagen soll.
                  um das jetzt umzusetzen, würde es mich freuen, etwas hilfe von den blockly experten zu bekommen, auch wenn es eine einzige und evtl. recht simple abfrage ist.
                  umsetzen wollte ich das ganze so:
                  Wenn wert von "lastInactive-ts" - "lastActive-ts" >= 21600, dann "guten abend"
                  danke schon mal
                    csamaggi last edited by
                    @Lucky:
                    Ein nutzen wäre z.b. das kurzfristige Stumm schalten z.b. des Fernsehers oder Verstärkers zum besseren Verständnis des gesprochenen ` Hallo lucky, gute Idee wenn du sonos Geräte besitzt geht dies automatisch sobald du alexa ansprichst dann wird der Ton gesenkt. Nur beim TV geht dies leider nicht beim hören von Musik schon. Warum auch immer.
                    Wie gesagt gebe dir recht wäre eine feine Sache.
                    Mfg Maggi
                    Gesendet von meinem SM-G955F mit Tapatalk
                      @ltsalvatore:
                      @ltsalvatore:
                      @ooooli:
                      edit:
                      danke schon mal `
                      ich hoffe es funktioniert 😄
                        Granten last edited by
                        wie ist es möglich über Alexa und die Routinen Werte eines Objekts abzurufen?
                        • haselchen
                          haselchen Most Active last edited by
                          @apollon77
                          Ich habe über den Adapter Bluetooth Datenpunkte meiner gespeichterten Geräte mit Alexa.
                          Nun verbinde ich eines, trotzdem bleibt der Datenpunkt connected auf false.
                          Er ändert sich auch nicht automatisch wenn ich den "Button" drücke oder als Wert selber true eingebe.
                          Habe ich da was übersehen?
                            @Granten:
                            wie ist es möglich über Alexa und die Routinen Werte eines Objekts abzurufen? `
                            Routinen Gar nicht meines Wissens nach.
                              @haselchen:
                              @apollon77
                              Habe ich da was übersehen? `
                              Bluetooth Status wird aktuell noch nur beim Adapter Start aktualisiert. Im GitHub abstimmen bitte. Issue gib’s schon.
                              • haselchen
                                Alles klar, danke für die schnelle Antwort .
                                • sissiwup
                                  sissiwup last edited by
                                  habe leider das Update auf Alexa 2 gemacht.
                                  Wie komme ich denn auf den Alexa 1 Adapter zurück?
                                  Vlt. stehe ich auch auf dem Schlauch: Habe jetzt Alexa zugemüllt mit technischen Geräten, die nie zu steuern sind Z.B. HM RCV 50 BidCoS RF 21.LEVEL
                                  und div. andere.
                                  Ich hatte bisher im Alexa nur eine Hand voll Geräte aufgenommen und auch alle mit neuen Namen.
                                  Diese sind teilweise übernommen worden (nicht alle korrekt geschrieben aber immerhin).
                                  Wie füge ich denn einzelne Geräte zu Alexa 2 hinzu, wie ändere ich den Namen (oder geht das nur über die Objekt-Sicht?)
                                  Der Alexa 1 Adapter war erheblich einfacher zu bedienen.
                                  Noch eine Frage: Warum sind so ca. 30% der Geräte offline. Muster für mich nicht erkennbar ein paar Schalter, eine Rollo, ein paar Szenen…
                                  Hat sich etwas beim cloud-Adapter geändert? Wie ist das Zusammenspiel?
                                    Bei den smart devices unterscheiden sich Version 1 und 2 nicht. Die Liste ist die gleiche die auch in der alexa app angezeigt wird. Wenn du da schon „Müll“ drin hast dann wird der auch da angezeigt. Also schau mal in die App. Und wenn musst du da aufräumen.
                                    • dslraser
                                      Hat mal Jemand ein kurzes Blockly Beispiel wie ich den History trigger sinnvoll nutze ?
                                      Ich möchte eine Abfrage an einem Echo starten und dann von genau dem gleichen Echo eine Antwort bekommen.
                                      PS: also Konkret frage ich einen Echo z.B. im Wohnzimmer ob alle Fenster geschlossen sind und bekomme dann aus einem bestehenden Datenpunkt (Fensterscript) die offenen Fenster angesagt. Nur wie steuere ich jetzt Speak, das die Rückmeldung auch vom gleichen Echo kommt, ohne das ich einen angeben muß ? Ich denke ich müsste den History trigger auf wahr triggern, aber wann bzw. an welcher Stelle ? Der angefragte Echo hat ja nicht zwangsläufig als letzter gesabbelt…
                                      PS: ich habe es nun hinbekommen. Falls es Jemand nachbauen möchte, hier einmal eine Temperaturabfrage und die Abfrage nach offenen Fenstern/ Türen (mit dem Fensterscript aus dem Forum)
                                      Bei mir reichen die 500 ms und Alexa antwortet brav an dem Echo wo sie gefragt wurde.
                                      https://youtu.be/Zv1blw2ASF4
                                      https://youtu.be/8g6xmpQW8ew
                                      • Matten Matten
                                        Matten Matten last edited by
                                        @csamaggi:
                                        Danke sigi das war wieder mal so nah und doch so fern die Funktion hatte ich nicht in betracht gezogen.
                                        Danke für den Antsoss.
                                        Was natürlich noch etwas geiler wäre wenn der IO prüft in einem Script und sie dann eben nur das jeweilige ausspricht mal sehen ob man dass hin bekommt.
                                        MFG Maggi `
                                        Hab ich wie folgt programmiert
                                        Matten Matten
                                          COOL 🙂
                                          Kannst du mir das exportieren?
                                          Wobei mir das Objekt noch nicht klar ist….
                                          • dslraser
                                            na ja, da das Fensterscript hier aus dem Forum (ich glaube von Pix) über die Gewerke bei mir eh läuft, sind ja bei jeder Veränderung die geöffneten Fenster schon als Ausgabe vorhanden. Aufbereit als Texxt für Sayit und Telegram.
                                            Nur diese Punkte greife ich bei mir ab.
                                            1.0k
                                            581
                                            161509
