    4. (gelöst) Multihost + Z-Wave-Adapter
      Kueppert last edited by
      letzte Rückmeldung von mir heute…hab mal auf Debug gestellt. Anbei das Log. Mir fällt nix mehr ein 😞
      zwave.0 2018-08-07 21:14:48.658 debug node255: timeout
      zwave.0 2018-08-07 21:14:47.658 debug node255: timeout
      zwave.0 2018-08-07 21:14:46.153 debug node255: timeout
      zwave.0 2018-08-07 21:14:44.663 debug node255: timeout
      zwave.0 2018-08-07 21:14:36.092 debug received all objects
      zwave.0 2018-08-07 21:14:36.026 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.11.1
      zwave.0 2018-08-07 21:14:30.231 info terminating
      zwave.0 2018-08-07 21:09:40.720 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.11.1
      zwave.0 2018-08-07 21:09:25.962 info terminating
      zwave.0 2018-08-07 20:59:02.740 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.11.1
      zwave.0 2018-08-07 20:46:22.627 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.11.1
      zwave.0 2018-08-07 20:45:49.382 info terminating
      zwave.0 2018-08-07 20:45:49.346 error at Module.load (module.js:565:32)
      zwave.0 2018-08-07 20:45:49.346 error at Object.Module._extensions..js (module.js:663:10)
      zwave.0 2018-08-07 20:45:49.346 error at Module._compile (module.js:652:30)
      zwave.0 2018-08-07 20:45:49.346 error at Object. <anonymous>(/opt/iobroker/node_modules/openzwave-shared/lib/openzwave-shared.js:24:22)
      zwave.0 2018-08-07 20:45:49.346 error at require (internal/module.js:11:18)
      zwave.0 2018-08-07 20:45:49.346 error at Module.require (module.js:596:17)
      zwave.0 2018-08-07 20:45:49.346 error at Function.Module._load (module.js:497:3)
      zwave.0 2018-08-07 20:45:49.346 error at tryModuleLoad (module.js:505:12)
      zwave.0 2018-08-07 20:45:49.346 error at Object.Module._extensions..node (module.js:681:18)
      zwave.0 2018-08-07 20:45:49.346 error Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0 2018-08-07 20:45:49.345 error uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
      zwave.0 2018-08-07 20:45:49.271 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.zwave, node: v8.11.1
      zwave.0 2018-08-07 20:45:15.999 info terminating</anonymous>
        apollon77 last edited by
        Neben
        sudo ldconfig /usr/local/lib64
        stehen auf der Readme vom zwave noch weitere. Alle mal versucht?
          @apollon77:
          Neben
          stehen auf der Readme vom zwave noch weitere. Alle mal versucht? ` Hallo Apollon, ja hab alle drei ausprobiert…
          Das einzige was ich nicht gefunden habe ist die Datei, die ich ggf. mit nano ändern soll?! Wenn ich die öffne, ist die bei nur leer. Bin nicht sicher, ob ich die neu erstellen soll...
            node: v8.11.1 das wird dein problem sein
              @arteck:
              node: v8.11.1 das wird dein problem sein ` Hmmm…Mist...
              1. Dann mache ich den Slave nochmal komplett neu oder
              2. Ich nehme mein altes Backup, wo zwave vorher drauf lief (rpi3, ehemaliges Hauptsystem) entferne alle Adapter außer Admin und mache den dann zum Slave?
              Was würdet ihr machen? Waf rutscht gerade wieder ab lol
              Danke und Grüße, Thorsten
                stephan61 last edited by
                @Kueppert:
                @arteck:
                Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk ` hallo kueppert in der instalationsanleitung von Zwave auf github ist dein Fehler beschrieben
                libopenzwave
                https://github.com/ioBroker/ioBroker.zwave
                gruss Stephan
                Gesendet von meinem MediaPad T1 8.0 Pro mit Tapatalk
                  Hallo Stephan, danke für den Hinweis. Aber weiter oben habe ich ja bereits beschrieben, dass ich die Punkte schon alle durch habe 😕
                  • AlCalzone
                    Node 8 sollte kein Problem sein, das hab ich auch im Einsatz. Gab es möglicherweise Fehler während der Installation? Wenn OpenZWave nicht erfolgreich installiert wurde, kann die Lib auch nicht gefunden werden.
                      Hab nichts bei der Installation von zwave Adapter nichts gesehen… Kann ich manuell drüber installieren in der Konsole??
                      • AlCalzone
                        @Kueppert:
                        Kann ich manuell drüber installieren in der Konsole?? `
                        Kaputt machen kannst du jedenfalls aktuell nix 😉
                        cd /opt/iobroker
                        sudo npm i iobroker.zwave --production --unsafe-perm
                          Lol, ja das stimmt wohl 😉
                          Soll ich das auf dem master oder Slave in der Konsole ausführen??
                          • AlCalzone
                            Da, wo der Adapter laufen soll und die Platine / USB-Stick angesteckt ist. Vermutlich Slave.
                              @AlCalzone:
                              Da, wo der Adapter laufen soll und die Platine / USB-Stick angesteckt ist. Vermutlich Slave. `
                              AlCalzone, DAS WAR DIE LÖSUNG.
                              1. auf Slave, auf dem die Platine montiert ist (Razberry), per SSH-Konsole zugreifen
                              2.cd /opt/iobrokerund dort````
                              iobroker stop
                              3\. dann ausführen````
                              4. zur Sicherheit hinterher noch````
                              5\. zur Sicherheit nochmal folgende Schritte gem. ReadMe bearbeitet:
                              5.1.1````
                              sudo nano /boot/cmdline.txt
                              5.1.2 remove console=serial0,115200
                              5.1.3 save the file and close it
                              5.2.1````
                              sudo nano /boot/config.txt
                              5.2.2 Look for each of the following lines. If they are commented out with a #, remove that. If they don't exist, add them to the end of the file:
                              5.2.3 dtoverlay=pi3-miniuart-bt
                              5.2.4 enable_uart=1
                              5.2.5 force_turbo=1
                              6\.````
                              reboot
                              ````vom RPi3
                              Ich hoffe, das hilft jemandem weiter. Nochmal danke euch für die Unterstützung. Damit läuft mein NUC inkl. RPi3-Slave nun, juhuuu. Hat nur paar Monate gedauert, bis ich wegen kleiner Tochter die Zeit aufbringen konnte…immer Stück für Stück ^^
                              VG Thorsten
                              1379
