    4. [Projekt] ioGo # Smarthome to go
    • N
      NightWatcher last edited by
      Super, habs.
      also app geschlossen (richtig beendet).
      log gelöscht.
      app gestartet.
      dreht sich immer noch alles und überall steht syncing data im subtitle. Im Bild leider nicht gut sichtbar, aber statt der Symbole ist links jeweils ein sich drehender Kreis.
      ! 10:31:43:145 V/EnumRepository - 49: instance created
      ! 10:31:43:151 V/StateRepository - 49: instance created
      ! 10:31:43:171 V/EnumRepository - 81: getFavoriteEnums called
      ! 10:31:43:175 D/EnumRepository - 84: getFunctionEnums: load favorite enums from database
      ! 10:31:43:179 V/StateRepository - 77: getFavoriteStates called
      ! 10:31:43:184 D/StateRepository - 80: getFavoriteStates: load favorite states from database
      ! 10:31:43:212 V/SocketService - 51: instance created
      ! 10:31:43:217 V/SocketService - 56: onCreate called
      ! 10:31:43:222 V/StateRepository - 135: saveSocketState called
      ! 10:31:43:226 V/SocketService - 142: onStartCommand called
      ! 10:31:43:231 V/SocketService$NetworkAs - 364: doInBackground called
      ! 10:31:43:235 V/SocketService - 68: init called
      ! 10:31:43:238 V/NetworkUtils - 135: cleanUrl called
      ! 10:31:43:242 V/SocketService - 84: init_mobile called
      ! 10:31:43:245 V/SocketService - 124: createSocket called
      ! 10:31:43:248 V/NetworkUtils - 150: getSocket called
      ! 10:31:43:492 V/StateRepository - 58: getAllStateIds called
      ! 10:31:43:492 V/StateRepository - 135: saveSocketState called
      ! 10:31:43:496 I/SocketService - 182: connected
      ! 10:31:43:497 V/SocketService - 241: syncStates called
      ! 10:31:43:501 V/SocketService - 317: getStates called
      ! 10:31:43:505 V/StateRepository - 58: getAllStateIds called
      ! 10:31:43:510 I/SocketService - 328: getStates: reuquesting 95 states from server
      ! 10:31:49:211 V/SocketService - 142: onStartCommand called
      ! 10:31:51:789 V/EnumRepository - 71: getRoomEnums called
      ! 10:31:51:797 D/EnumRepository - 74: getFunctionEnums: load room enums from database
      ! 10:31:51:803 V/EnumRepository - 76: getRoomEnums
      ! 10:31:53:847 V/EnumRepository - 53: getEnum called
      ! 10:31:53:852 D/EnumRepository - 56: getEnum: load enum from database enumId:enum.rooms.vorratskammer
      ! 10:31:53:858 V/StateRepository - 68: getStatesByEnum called
      ! 10:31:53:863 D/StateRepository - 71: getStatesByEnum: load states from database enumId:enum.rooms.vorratskammer
      ! 10:31:53:884 V/SocketService - 142: onStartCommand called
      ! 10:32:09:293 V/SocketService - 51: instance created
      ! 10:32:09:302 V/SocketService - 56: onCreate called
      ! 10:32:09:310 V/EnumRepository - 49: instance created
      ! 10:32:09:317 V/StateRepository - 49: instance created
      ! 10:32:09:324 V/StateRepository - 135: saveSocketState called
      ! 10:32:09:330 V/SocketService - 151: onDestroy called
        A Former User last edited by
        beim Öffnen der App ist das normal.
        Es muss ja erstmal alles synchronisiert werden.
        Sollte dann aber eigentlich nach wenigen Sekunden verschwinden.
        • N
          tut es eben nicht. Es bleibt so. Ich kann die app Minuten lang offen lassen.
          Ich kann trotz allem Objekte schalten. Die stati werden in der App jedoch nicht aktualisiert, wenn ich sie auf andere Weise schalte, als aus der App, zb aus der vis oder direkt am Lichtschalter.
          es scheint als wenn die app Daten senden kann, aber nichts empfängt, bis auf der initiale sync beim Knopfdruck auf "sync Object".
          und noch eine Ergänzung. Es passiert nur mit aktivierter Authentifizierung.
            @NightWatcher:
            und noch eine Ergänzung. Es passiert nur mit aktivierter Authentifizierung. `
            kann ich nicht nachstellen…
            Wie viele Objekte und States hast du insgesamt?
            Das steht oben rechts auf der Seite im iobroker admin wenn man in dem Bereich Objekte ist
            • N
              Objekte: 1261, Zustände: 998
              wobei es ja schon komisch ist, dass es offensichtlich nur bei aktiver Authentifizierung auftritt. Kann da nicht irgendwo das Problem sein? Die Anzahl der Objekte dürfte da doch egal sein?
                @NightWatcher:
                wobei es ja schon komisch ist, dass es offensichtlich nur bei aktiver Authentifizierung auftritt. Kann da nicht irgendwo das Problem sein? Die Anzahl der Objekte dürfte da doch egal sein? ` Die Anzahl ist okay.
                Vermutung war eine langsame Verbindung mit vielen Objekten und dadurch vielleicht ein Timeout.
                Steht zufällig im iobroker-log etwas hilfreiches bei dir?
                Gesendet von meinem Pixel 2 mit Tapatalk
                  @NightWatcher:
                  Super, habs.
                  log gelöscht.
                  app gestartet.
                  ! 10:32:09:330 V/SocketService - 151: onDestroy called `
                  Scheinbar wird die Verbindung aufgebaut.
                  Anschließend wird dann ein "subscribe" mit der Liste aller States geschickt, nur dies klappt nicht. Daher werden auch keine Updates erhalten.
                  Vielleicht steht im iobroker-log etwas zu dem subscribe Befehl als Fehler.
                  • N
                    evtl aufgrund der Authentifizierung? Das die nur Initial aufgebaut wird und beim subscribe evtl ohne username und Passwort versucht wird zu verbinden kann nicht sein?
                    im iobroker log gucke ich gleich morgen nach.
                    • N
                      Also der ioBroker Log gibt leider nichts sinnvolles aus, Obwohl ich das Debuglevel bereits auf Debug gestellt habe.
                      Aber es scheint mit der Authentifizierung zu tun haben. Denn ich habe das Problem nur dann, wenn eben diese aktiv ist.
                        @NightWatcher:
                        Aber es scheint mit der Authentifizierung zu tun haben. Denn ich habe das Problem nur dann, wenn eben diese aktiv ist. `
                        Ich hab nun einige Stunden mit Debugging verbracht.
                        Das Gute ist ich kann dein Verhalten Nachstellen 🙂
                        Es kommt meistens dann vor wenn ich ein sehr langsames und verzögertes Netzwerk am Handy simuliere.
                        Das kann die Ursache sein.
                        Probier es mal ohne https, da https die Verbindung zusätzlich verlangsamt.
                        Geht es bei dir ohne SSL besser?
                        • N
                          Habe es gerade für dich getestet. Ob mit oder ohne ssl ist egal.
                          an der Geschwindigkeit liegt es glaube ich nicht. Das Problem habe ich auch im lokalen Netz nachstellen können. Dann hinterlege ich direkt die lokale IP in der App.
                            Um die Probleme mit der Authentication einzugrenzen hab ich in v0.19.7 die verwendete socket.io lib mal wieder zurück auf 0.8.3 gedreht.
                            Damit gehen nun hoffentlich http Verbindungen mit username/passwort.
                            Leider geht damit vorerst https nicht.
                            Eine Ursache könnte folgender Bug sein:
                            https://github.com/socketio/socket.io-c … issues/268
                            • N
                              Tut mir leid es sagen zu müssen, aber mit der 0.19.7 funktioniert es auch nicht.
                              Verhalten ist das gleiche. Bin Verbunden (ohne SSL), kann schalten, aber erhalte keine Rückantwort. Nur initial bei der Syncronisierung.
                              Kann man das Subscribe nicht einfach mal genauer debuggen? Evtl. hängt er sich ja in irgend einer Schleife auf oder verliert die Socket Session usw…
                              Entgegen deiner Aussage kann ich übrigens SSL noch mit der Version 0.19.7 nutzen.
                              Kann es ggf. sein, dass die APP nur 1x den Status der Objekte nach dem Ändern abfragt und dann nie wieder? Bedeutet, wenn syncing data kommt, bleibt das immer, bis zum nächsten globalen subscribe?
                              Heute sehe ich zudem das erste mal im Log von ioBroker ein Subscribe aller Objekte, die in der App sind. Wie oft sollte er die globale subscribe Funktion aufrufen? Gerade bei einigen Tests doch tatsächlich mal hinbekommen, dass er 5x hintereinander im Abstand von etwa 500ms das subscribe aufruft.
                              Wenn ich das richtig verstehe, pollt die App ja nur.
                                @NightWatcher:
                                Wenn ich das richtig verstehe, pollt die App ja nur. ` Vielen Dank für deine ganzen Tests.
                                Man kann ganz viel debuggen. Aber auch mein Tag hat nur 24Std und ich hab auch noch andere Hobbies.
                                Jeder darf den Quellcode von GitHub laden und selber debuggen.
                                Ich bleibe dran an dem Bug, bin aber gerade etwas ratlos… Wird schon werden
                                • N
                                  Um gottes Willen, ich will hier auch niemanden in seiner Freizeit einschränken. Habe lediglich helfen wollen. 🙂 Nicht falsch verstehen.
                                  Ich war auf die App bis nie angewiesen und hätte Sie auch nur als Nice2Have gesehen. So kann ich Sie natürlich eh nicht verwenden. Ohne Authentifizierung oder SSL ist es für mich sowieso ein NOGO.
                                  Bin leider kein Java Entwickler und habe nur Erfahrung in PHP, HTML usw… Mal sehen, wenn ich irgendwann mal ganz viel Motivation verspüre und du immer noch nichts gefunden hast, arbeite ich mich mal in deinen Quellcode ein.
                                    @NightWatcher:
                                    Bin leider kein Java Entwickler und habe nur Erfahrung in PHP, HTML usw… Mal sehen, wenn ich irgendwann mal ganz viel Motivation verspüre und du immer noch nichts gefunden hast, arbeite ich mich mal in deinen Quellcode ein. ` Alles gut.
                                    Bin für deine Tests wirklich sehr dankbar.
                                    Das Problem lässt sich garantiert lösen, nur leider nicht so schnell wie wir alle es gerne hätten.
                                    • N
                                      Übrigens, wenn ich dein git in Android Studio clonen möchte, kann ich keine APK erstellen oder Simulator laufen lassen, da einige wichtige Dateien in der gitignore liegen.
                                        @NightWatcher:
                                        Übrigens, wenn ich dein git in Android Studio clonen möchte, kann ich keine APK erstellen oder Simulator laufen lassen, da einige wichtige Dateien in der gitignore liegen. `
                                        Es müsste funktionieren wenn du in dieser Datei:
                                        https://github.com/nisiode/ioGo/blob/ma … ild.gradle
                                        folgende zwei Zeilen entfernst.
                                        1. apply plugin: 'io.fabric'
                                        2. apply plugin: 'com.google.gms.google-services'
                                        • Bluefox
                                          Bluefox last edited by
                                          Ich weiß immer noch nicht warum bei mir nicht geht.
                                          Und nein, ich weiß nicht wie man debug einschaltet.
                                          Android 8.0.0
                                            @Bluefox:
                                            Android 8.0.0 `
                                            Das sieht nach einer ganz altern Version aus.
                                            Probier mal bitte die aus dem playstore:
                                            https://play.google.com/store/apps/deta … nagel.iogo
                                            android app iogo
                                            61
                                            1140
                                            359018
