    4. [gefixt] Parser-Adapter (1.0.3) stürzt ab
      Karl_999 last edited by
      Ich verwende den Parser-Adpater zum Einlesen der Temperaturwerte einer DS1820-Sensoren
      Nun habe ich gerade auf die aktuelle Version 1.0.3 des Parser-Adapters (von 1.0.2) aktualisiert.
      Die bislang funktionstüchtige Konfiguration habe ich dabei nicht geändert.
      Nach der Aktualisierung stürzt der Adapter allerdings hart ab (Ausgaben im Debug-Modus):
      host.ioBroker-RasPi	2018-08-10 21:16:00.388	error	instance system.adapter.parser.0 terminated with code 0 (OK)
      Caught	2018-08-10 21:16:00.387	error	by controller[0]: at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
      Caught	2018-08-10 21:16:00.387	error	by controller[0]: at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:265:49)
      Caught	2018-08-10 21:16:00.387	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
      Caught	2018-08-10 21:16:00.386	error	by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.parser/main.js:351:21)
      Caught	2018-08-10 21:16:00.386	error	by controller[0]: at poll (/opt/iobroker/node_modules/iobroker.parser/main.js:319:9)
      Caught	2018-08-10 21:16:00.386	error	by controller[0]: at readLink (/opt/iobroker/node_modules/iobroker.parser/main.js:294:13)
      Caught	2018-08-10 21:16:00.386	error	by controller[0]: at readLink (/opt/iobroker/node_modules/iobroker.parser/main.js:319:54)
      Caught	2018-08-10 21:16:00.385	error	by controller[0]: at analyseDataForStates (/opt/iobroker/node_modules/iobroker.parser/main.js:145:5)
      Caught	2018-08-10 21:16:00.385	error	by controller[0]: at _analyseDataForStates (/opt/iobroker/node_modules/iobroker.parser/main.js:127:9)
      Caught	2018-08-10 21:16:00.385	error	by controller[0]: at analyseData (/opt/iobroker/node_modules/iobroker.parser/main.js:195:29)
      Caught	2018-08-10 21:16:00.384	error	by controller[0]: TypeError: (data || "").replace is not a function
      parser.0	2018-08-10 21:16:00.358	info	terminating
      parser.0	2018-08-10 21:15:59.849	error	at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
      parser.0	2018-08-10 21:15:59.849	error	at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:265:49)
      parser.0	2018-08-10 21:15:59.849	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
      parser.0	2018-08-10 21:15:59.849	error	at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.parser/main.js:351:21)
      parser.0	2018-08-10 21:15:59.849	error	at poll (/opt/iobroker/node_modules/iobroker.parser/main.js:319:9)
      parser.0	2018-08-10 21:15:59.849	error	at readLink (/opt/iobroker/node_modules/iobroker.parser/main.js:294:13)
      parser.0	2018-08-10 21:15:59.849	error	at readLink (/opt/iobroker/node_modules/iobroker.parser/main.js:319:54)
      parser.0	2018-08-10 21:15:59.849	error	at analyseDataForStates (/opt/iobroker/node_modules/iobroker.parser/main.js:145:5)
      parser.0	2018-08-10 21:15:59.849	error	at _analyseDataForStates (/opt/iobroker/node_modules/iobroker.parser/main.js:127:9)
      parser.0	2018-08-10 21:15:59.849	error	at analyseData (/opt/iobroker/node_modules/iobroker.parser/main.js:195:29)
      parser.0	2018-08-10 21:15:59.849	error	TypeError: (data || "").replace is not a function
      parser.0	2018-08-10 21:15:59.848	error	uncaught exception: (data || "").replace is not a function
      parser.0	2018-08-10 21:15:59.824	debug	analyseData CHECK for parser.0.Temp_KiZi_1_b, old=25.700000000000003
      parser.0	2018-08-10 21:15:59.820	debug	Process ["parser.0.Temp_KiZi_1_b"] for link /sys/bus/w1/devices/10-000802c38ff9/w1_slave
      parser.0	2018-08-10 21:15:58.939	debug	Read file: /sys/bus/w1/devices/10-000802c38ff9/w1_slave
      parser.0	2018-08-10 21:15:58.937	debug	Do Link: /sys/bus/w1/devices/10-000802c38ff9/w1_slave
      parser.0	2018-08-10 21:15:58.936	debug	States for current Interval (10000): ["parser.0.Temp_KiZi_1_b","parser.0.Temp_KiZi_1_a","parser.0.Temp_KiZi_1_w"]
      parser.0	2018-08-10 21:15:58.798	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.parser, node: v8.11.3
      Hat jemand eine Idee, an was das liegen kann?
        Dazu existiert beteits ein issue suf github
        Gruß Rainer
          @Homoran:
          Dazu existiert beteits ein issue suf github `
          Danke für die Info.
          Und scheint auch in 1.0.4 gefixt zu sein.
