    4. [Aufruf] deConz Adapter Testen 1.1.2
      Kugelkopf last edited by
      @Jey Cee:
      @Kugelkopf stell mal das Loglevel des Adapters auf debug und schick es mir dann, aber nimm es dann aus der Log Datei damit ich alles sehen kann.
      Gesendet von meinem m8 mit Tapatalk `
      Ok!
      Hier also einmal den Sensor hinzugefügt via deconz Adapter. Danach Adapter neu gestartet. Nachdem der Sensor neue Daten übermittelt hat haben sich wieder 3 neue Objekte gebildet die nur "lastupdated" beinhalten. (Sensor ID 22,23,24) Der eigentlich Sensor, hier noch: Temerature,Humidity,Pressure ID 3,4,8.
      2018-08-01 16:36:56.652 - info: deconz.0 terminating
      2018-08-01 16:36:56.667 - info: host.raspi2 instance system.adapter.deconz.0 terminated with code 0 (OK)
      2018-08-01 16:36:58.674 - info: host.raspi2 instance system.adapter.deconz.0 started with pid 16747
      2018-08-01 16:37:00.261 - debug: deconz.0 objectDB connected
      2018-08-01 16:37:00.325 - debug: deconz.0 statesDB connected
      2018-08-01 16:37:00.437 - info: deconz.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v8.11.3
      2018-08-01 16:37:00.485 - debug: deconz.0 API version: 1.0.9
      2018-08-01 16:37:00.522 - debug: deconz.0 getAllLights: {"1":{"ctmax":454,"ctmin":250,"etag":"f34525ab6743b572c04a036c8b1d027c","hascolor":true,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E14 WS opal 400lm","name":"TradfriE14","state":{"alert":"none","bri":1,"colormode":"ct","ct":454,"on":false,"reachable":true},"swversion":"1.2.217","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:8a:31:88-01"},"2":{"etag":"ca3902ccd5759a5ab0ff6c689a73eb51","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug2","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03"},"4":{"etag":"26c0aa793ba4700c4acf490c0fadfbd6","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug3","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:ad:3e:d6-03"},"5":{"etag":"005b16f73342226dbd8c5a4d6e0cf681","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug4","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:ad:1a:3f-03"}}
      2018-08-01 16:37:00.545 - debug: deconz.0 getAllSensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"9114d4ecec5cf33ad47aa8fdfc5d1074","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2018-08-01T13:58:01","status":170},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:01:3e:51-01"},"10":{"config":{"on":true,"reachable":false},"ep":3,"etag":"22096ccd35318095bd63a2435959fa20","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 10","state":{"lastupdated":"2018-07-31T22:45:48","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:a7:7e:71-03-0b04"},"11":{"config":{"on":true,"reachable":true},"ep":3,"etag":"314e195c23c7b142062a7e341e16df83","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 11","state":{"lastupdated":"2018-08-01T14:36:39","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:ad:3e:d6-03-0b04"},"12":{"config":{"on":true,"reachable":true},"ep":3,"etag":"b6611b451f93ce8ea72de502fcd430ad","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 12","state":{"lastupdated":"2018-08-01T14:36:45","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:ad:1a:3f-03-0b04"},"13":{"config":{"battery":91,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"d45f011f1392e6e946ecf6cd48a4fe2d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"lastupdated":"2018-08-01T14:08:20","temperature":2731},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0402"},"14":{"config":{"battery":91,"on":true,"reachable":true},"ep":1,"etag":"d45f011f1392e6e946ecf6cd48a4fe2d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"humidity":4126,"lastupdated":"2018-08-01T14:08:20"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0405"},"15":{"config":{"battery":91,"on":true,"reachable":true},"ep":1,"etag":"d45f011f1392e6e946ecf6cd48a4fe2d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"lastupdated":"2018-08-01T14:08:20","pressure":1015},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0403"},"16":{"config":{"battery":100,"on":true,"reachable":true,"temperature":3300},"ep":1,"etag":"515344668b0508bd9bb2bc4b88cb7d24","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"SensorDoor1","state":{"lastupdated":"2018-08-01T14:31:57","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:b9:7a:01-01-0006"},"2":{"config":{"on":true,"reachable":true},"ep":3,"etag":"b4b994fb5385a4d25cc085b2c6846d43","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 2","state":{"lastupdated":"2018-08-01T14:36:17","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03-0b04"},"3":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"e4b9ee55a968bcda76f0afedcbedfd17","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperature 3","state":{"lastupdated":"2018-08-01T14:35:48","temperature":2865},"type":"ZHATemperature","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0402"},"4":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"e4b9ee55a968bcda76f0afedcbedfd17","manufacturername":"LUMI","modelid":"lumi.weather","name":"Humidity 4","state":{"humidity":3967,"lastupdated":"2018-08-01T14:35:48"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0405"},"5":{"config":{"battery":98,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"4b0bd540cd0ae8941469ceef0c492fb1","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"lastupdated":"2018-08-01T14:02:36","temperature":2600},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f5:20:07-01-0402"},"6":{"config":{"battery":98,"on":true,"reachable":true},"ep":1,"etag":"9e3a7418a9e55c4d93a6a7ab54db1011","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"humidity":4915,"lastupdated":"2018-08-01T14:00:55"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f5:20:07-01-0405"},"7":{"config":{"battery":98,"on":true,"reachable":true},"ep":1,"etag":"9e3a7418a9e55c4d93a6a7ab54db1011","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"lastupdated":"2018-08-01T14:00:55","pressure":1015},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f5:20:07-01-0403"},"8":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"e4b9ee55a968bcda76f0afedcbedfd17","manufacturername":"LUMI","modelid":"lumi.weather","name":"Pressure 8","state":{"lastupdated":"2018-08-01T14:35:48","pressure":1014},"type":"ZHAPressure","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0403"},"9":{"config":{"battery":100,"group":"24194","on":true,"reachable":true},"ep":2,"etag":"132dbdf16d1d99f5ad2c6a4a5879a2a3","manufacturername":"Philips","mode":1,"modelid":"RWL021","name":"Dimmschalter","state":{"buttonevent":4002,"lastupdated":"2018-07-31T02:54:12"},"swversion":"5.45.1.17846","type":"ZHASwitch","uniqueid":"00:17:88:01:04:f6:d6:3e-02-fc00"}}
      2018-08-01 16:37:00.574 - debug: deconz.0 getAllGroups: {"24194":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"class":"Other","devicemembership":["9"],"etag":"9114d4ecec5cf33ad47aa8fdfc5d1074","hidden":false,"id":"24194","lights":[],"lightsequence":[],"multideviceids":[],"name":"RWL021 2","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
      2018-08-01 16:37:00.777 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"class":"Other","devicemembership":["9"],"etag":"9114d4ecec5cf33ad47aa8fdfc5d1074","hidden":false,"id":"24194","lights":[],"lightsequence":[],"multideviceids":[],"name":"RWL021 2","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
      2018-08-01 16:37:14.612 - debug: deconz.0 system.adapter.admin.0: logging false
      2018-08-01 16:37:17.169 - debug: deconz.0 Websocket message: {"config":{"battery":100,"offset":0,"on":true,"reachable":true},"e":"changed","id":"22","r":"sensors","t":"event"}
      2018-08-01 16:37:17.178 - debug: deconz.0 Websocket message: {"e":"changed","id":"22","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:17","temperature":2904},"t":"event"}
      2018-08-01 16:37:17.186 - debug: deconz.0 Websocket message: {"config":{"battery":100,"on":true,"reachable":true},"e":"changed","id":"23","r":"sensors","t":"event"}
      2018-08-01 16:37:17.189 - debug: deconz.0 Websocket message: {"e":"changed","id":"23","r":"sensors","state":{"humidity":4456,"lastupdated":"2018-08-01T14:37:17"},"t":"event"}
      2018-08-01 16:37:17.192 - debug: deconz.0 Websocket message: {"config":{"battery":100,"on":true,"reachable":true},"e":"changed","id":"24","r":"sensors","t":"event"}
      2018-08-01 16:37:17.194 - debug: deconz.0 Websocket message: {"e":"changed","id":"24","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:17","pressure":1014},"t":"event"}
      2018-08-01 16:37:17.195 - debug: deconz.0 Websocket message: {"config":{"battery":100,"offset":0,"on":true,"reachable":true},"e":"changed","id":"3","r":"sensors","t":"event"}
      2018-08-01 16:37:17.197 - debug: deconz.0 Websocket message: {"e":"changed","id":"3","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:17","temperature":2904},"t":"event"}
      2018-08-01 16:37:17.217 - debug: deconz.0 Websocket message: {"config":{"battery":100,"on":true,"reachable":true},"e":"changed","id":"4","r":"sensors","t":"event"}
      2018-08-01 16:37:17.219 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"humidity":4456,"lastupdated":"2018-08-01T14:37:17"},"t":"event"}
      2018-08-01 16:37:17.221 - debug: deconz.0 Websocket message: {"config":{"battery":100,"on":true,"reachable":true},"e":"changed","id":"8","r":"sensors","t":"event"}
      2018-08-01 16:37:17.223 - debug: deconz.0 Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:17","pressure":1014},"t":"event"}
      2018-08-01 16:37:17.511 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:17","power":0},"t":"event"}
      2018-08-01 16:37:21.526 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:21","power":0},"t":"event"}
      2018-08-01 16:37:25.542 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:25","power":0},"t":"event"}
      2018-08-01 16:37:27.420 - debug: deconz.0 Websocket message: {"e":"changed","id":"3","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:27","temperature":2947},"t":"event"}
      2018-08-01 16:37:27.451 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"humidity":5028,"lastupdated":"2018-08-01T14:37:27"},"t":"event"}
      2018-08-01 16:37:27.464 - debug: deconz.0 Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:27","pressure":1014},"t":"event"}
      2018-08-01 16:37:37.679 - debug: deconz.0 Websocket message: {"e":"changed","id":"3","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:37","temperature":2943},"t":"event"}
      2018-08-01 16:37:37.704 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"humidity":4101,"lastupdated":"2018-08-01T14:37:37"},"t":"event"}
      2018-08-01 16:37:37.736 - debug: deconz.0 Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:37","pressure":1014},"t":"event"}
      2018-08-01 16:37:40.514 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:40","power":0},"t":"event"}
      2018-08-01 16:37:52.575 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:52","power":0},"t":"event"}
      2018-08-01 16:37:56.510 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:37:56","power":0},"t":"event"}
      2018-08-01 16:38:00.538 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:38:00","power":0},"t":"event"}
      2018-08-01 16:38:20.527 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:38:20","power":0},"t":"event"}
      2018-08-01 16:38:35.605 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:38:35","power":0},"t":"event"}
      2018-08-01 16:38:41.745 - debug: deconz.0 Websocket message: {"config":{"on":true,"reachable":false},"e":"changed","id":"10","r":"sensors","t":"event"}
      2018-08-01 16:38:42.516 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:38:42","power":0},"t":"event"}
      2018-08-01 16:38:47.565 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:38:47","power":0},"t":"event"}
      2018-08-01 16:39:02.512 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:39:02","power":0},"t":"event"}
      2018-08-01 16:39:20.584 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:39:20","power":0},"t":"event"}
      2018-08-01 16:39:24.513 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:39:24","power":0},"t":"event"}
      2018-08-01 16:39:27.438 - debug: deconz.0 Websocket message: {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-08-01T14:39:27","temperature":2731},"t":"event"}
      2018-08-01 16:39:27.480 - debug: deconz.0 Websocket message: {"e":"changed","id":"14","r":"sensors","state":{"humidity":4033,"lastupdated":"2018-08-01T14:39:27"},"t":"event"}
      2018-08-01 16:39:27.501 - debug: deconz.0 Websocket message: {"e":"changed","id":"15","r":"sensors","state":{"lastupdated":"2018-08-01T14:39:27","pressure":1015},"t":"event"}
      2018-08-01 16:39:30.563 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:39:30","power":0},"t":"event"}
      2018-08-01 16:39:49.566 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:39:49","power":0},"t":"event"}
      2018-08-01 16:39:54.564 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:39:54","power":0},"t":"event"}
      2018-08-01 16:40:04.569 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:40:04","power":0},"t":"event"}
      2018-08-01 16:40:08.516 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:40:08","power":0},"t":"event"}
      2018-08-01 16:40:14.570 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:40:14","power":0},"t":"event"}
      2018-08-01 16:40:20.586 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:40:20","power":0},"t":"event"}
      2018-08-01 16:40:21.963 - debug: deconz.0 system.adapter.admin.0: logging true
      2018-08-01 16:40:41.563 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:40:41","power":0},"t":"event"}
      Umbenennung in Phoscon und löschen aller deconz Objekte in der Objekt-Ansicht des iobroker admin. Danach Neustart des Adapters.
      Sensor funktioniert unter neuen Namen: "Sensor2" (ID 3-4-8) . Nach der ersten Werteänderung wieder 3 neue Sensoren (ID 22-23-24).
      undefined2018-08-01 16:43:50.517 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:43:50","power":0},"t":"event"}
      2018-08-01 16:43:55.559 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:43:55","power":0},"t":"event"}
      2018-08-01 16:44:00.582 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:44:00","power":0},"t":"event"}
      2018-08-01 16:44:01.285 - debug: deconz.0 Websocket message: {"e":"changed","id":"3","name":"Sensor2","r":"sensors","t":"event"}
      2018-08-01 16:44:01.294 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","name":"Sensor2","r":"sensors","t":"event"}
      2018-08-01 16:44:01.299 - debug: deconz.0 Websocket message: {"e":"changed","id":"8","name":"Sensor2","r":"sensors","t":"event"}
      2018-08-01 16:44:24.267 - debug: deconz.0 system.adapter.admin.0: logging false
      2018-08-01 16:44:28.409 - info: host.raspi2 object change system.adapter.deconz.0
      2018-08-01 16:44:28.410 - info: host.raspi2 stopInstance system.adapter.deconz.0
      2018-08-01 16:44:28.411 - info: host.raspi2 stopInstance system.adapter.deconz.0 killing pid 16747
      2018-08-01 16:44:28.436 - info: yahka.0 objectChange system.adapter.deconz.0 {"_id":"system.adapter.deconz.0","type":"instance","common":{"name":"deconz","version":"0.2.0","news":{"0.2.1":{"en":"Added new elements to config; Changed some small things","de":"Neue Elemente zur Konfiguration hinzugefügt; Einige kleine Dinge geändert","ru":"Добавлены новые элементы в config; Изменены некоторые мелочи","pt":"Adicionado novos elementos à configuração; Mudou algumas pequenas coisas","nl":"Nieuwe elementen toegevoegd aan config; Een paar kleine dingen veranderd","fr":"Ajout de nouveaux éléments à config; Changé quelques petites choses","it":"Aggiunti nuovi elementi alla configurazione; Cambiato alcune piccole cose","es":"Se agregaron nuevos elementos a config; Cambió algunas cosas pequeñas","pl":"Dodano nowe elementy do konfiguracji; Zmieniono kilka małych rzeczy"},"0.2.0":{"en":"next Try with Xiaomi Sensors; Added \"pressure\" sensor; Added create group to adapter config;","de":"nächster Versuch mit Xiaomi Sensoren; Hinzugefügt \"Druck\" -Sensor; Gruppe zu Adapterkonfiguration hinzugefügt hinzugefügt;","ru":"следующее Попробуйте с датчиками Xiaomi; Добавлен датчик давления; Добавлена ​​возможность создания группы в конфигурацию адаптера;","pt":"next Experimente com o Xiaomi Sensors; Adicionado sensor de \"pressão\"; Adicionado criar grupo para configuração do adaptador;","nl":"volgende Probeer met Xiaomi-sensoren; Toegevoegd \"druk\" sensor; Groep toevoegen aan adapterconfiguratie toegevoegd;","fr":"suivant Essayez avec Xiaomi Sensors; Ajout d'un capteur \"pression\" Ajout du groupe de création à la configuration de l'adaptateur;","it":"avanti Prova con Xiaomi Sensors; Aggiunto sensore \"pressione\"; Aggiunto creare un gruppo per la configurazione dell'adattatore;","es":"Siguiente Prueba con Xiaomi Sensors; Sensor de \"presión\" agregado; Se agregó crear grupo a la configuración del adaptador;","pl":"dalej Wypróbuj Xiaomi Sensors; Dodano czujnik \"ciśnienia\"; Dodano tworzenie grupy do konfiguracji adaptera;"},"0.1.7":{"en":"add possibility to delete devices from deConz; fix issue on getAll... functions when there are is nothing;","de":"Möglichkeit hinzufügen, Geräte von deConz zu löschen; Problem beheben bei getAll ... Funktionen, wenn es nichts gibt;","ru":"добавить возможность удаления устройств из deConz; исправить проблему на getAll ... функции, когда есть ничего;","pt":"adicionar possibilidade de excluir dispositivos de deConz; corrigir problema em funções getAll ... quando não há nada;","nl":"mogelijkheid toevoegen om apparaten van deConz te verwijderen; probleem oplossen op getAll ... functies wanneer er niets is;","fr":"ajouter la possibilité de supprimer des périphériques de deConz; résoudre le problème sur getAll ... fonctions quand il n'y a rien;","it":"aggiungere la possibilità di eliminare i dispositivi da DeConz; risolvere il problema su getAll ... funzioni quando non ci sono nulla;","es":"agregar la posibilidad de eliminar dispositivos de deConz; soluciona el problema en las funciones getAll ... cuando no hay nada;","pl":"dodaj możliwość usunięcia urządzeń z deConz; Napraw problem na getAll ... funkcje, gdy nie ma nic;"},"0.1.6":{"en":"fix Xiaomi Sensor recognition","de":"Xiaomi Sensorerkennung beheben","ru":"исправить распознавание датчика Xiaomi","pt":"conserte o reconhecimento do sensor Xiaomi","nl":"fix Xiaomi sensorherkenning","fr":"Correction de la reconnaissance du capteur Xiaomi","it":"correggere il riconoscimento del sensore Xiaomi","es":"arreglar el reconocimiento del sensor Xiaomi","pl":"naprawić rozpoznawanie czujnika Xiaomi"},"0.1.5":{"en":"Try to fix Sensors","de":"Versuchen Sie, Sensoren zu reparieren","ru":"Попробуйте исправить датчики","pt":"Tente corrigir os sensores","nl":"Probeer sensoren te repareren","fr":"Essayez de réparer les capteurs","it":"Prova a sistemare i sensori","es":"Intenta reparar los sensores","pl":"Spróbuj naprawić czujniki"},"0.1.4":{"en":"Added support for Admin v3","de":"Unterstützung für Admin v3 hinzugefügt","ru":"Добавлена ​​поддержка Admin v3","pt":"Adicionado suporte para Admin v3","nl":"Ondersteuning toegevoegd voor Admin v3","fr":"Ajout du support pour Admin v3","it":"Aggiunto supporto per Admin v3","es":"Se agregó soporte para Admin v3","pl":"Dodano obsługę administratora v3"},"0.1.3":{"en":"Stop Spam in log; Added filter for name to id conversation","de":"Stoppen Sie Spam im Protokoll; Filter für Name zu ID-Konversation hinzugefügt","ru":"Остановить спам в журнале; Добавлен фильтр для диалога id в id","pt":"Pare Spam no log; Filtro adicionado para o nome para id conversação","nl":"Stop Spam in het logboek; Filter toegevoegd voor naam- en id-conversatie","fr":"Arrêter le spam dans le journal; Filtre ajouté pour le nom à la conversation d'identification","it":"Interrompi spam nel registro; Aggiunto filtro per il nome alla conversazione id","es":"Detener el spam en el registro; Filtro agregado para el nombre de la conversación de id.","pl":"Zatrzymaj spam w dzienniku; Dodano filtr do konwersacji nazw do ID"},"0.1.2":{"en":"Added new datapoints for sensors (experimental)","de":"Neue Datenpunkte für Sensoren hinzugefügt (Experimentell)","ru":"Добавлены новые точки данных для датчиков (Experimental)"},"0.1.1":{"en":"Complete adapter rewritten","de":"Adapter Vollständig neu geschrieben","ru":"Полный адаптер переписан"},"0.1.0":{"en":"alpha version","de":"alpha version","ru":"альфа-версия"}},"title":"deConz ZigBee","titleLang":{"en":"deConz ZigBee","de":"deConz ZigBee","ru":"deConz ZigBee","pt":"deConz ZigBee","nl":"deConz ZigBee","fr":"deConz ZigBee","it":"deConz ZigBee","es":"deConz ZigBee","pl":"deConz ZigBee"},"desc":{"en":"Connects to the deConz Software that is an gateway solution for ZigBee. deConz works with ConBee USB stick and RaspBee modul for Raspberry Pi which is also from Dresden-Elektronik.","de":"Verbindet sich mit der deConz-Software, die eine Gateway-Lösung für ZigBee ist. deConz arbeitet mit dem ConBee USB Stick und dem RaspBee Modul für den Raspberry Pi, die ebenfalls von Dresden-Elektronik sind.","ru":"Подключается к программному обеспечению deConz, которое является шлюзовым решением для ZigBee. deConz работает с ConBee и RaspBee, который также из Дрездена-Электроника.","pt":"Conecta ao software deConz que é uma solução de gateway para o ZigBee. DeConz trabalha com o conwee USB stick e RaspBee modul para Raspberry Pi que também é de Dresden-Elektronik.","nl":"Maakt verbinding met de deConz-software die een gateway-oplossing is voor ZigBee. deConz werkt met ConBee USB-stick en RaspBee-module voor Raspberry Pi, die ook van Dresden-Elektronik is.","fr":"Se connecte au logiciel deConz qui est une solution de passerelle pour ZigBee. deConz fonctionne avec la clé USB ConBee et le module RaspBee pour Raspberry Pi, également de Dresden-Elektronik.","it":"Si collega al software deConz che è una soluzione gateway per ZigBee. deConz funziona con ConBee USB stick e RaspBee modul per Raspberry Pi, anch'esso di Dresden-Elektronik.","es":"Se conecta al software deConz que es una solución de puerta de enlace para ZigBee. deConz funciona con el dispositivo USB ConBee y el módulo RaspBee para Raspberry Pi, que también es de Dresden-Elektronik.","pl":"Łączy się z oprogramowaniem deConz, które jest rozwiązaniem bramkowym dla ZigBee. deConz współpracuje z pamięcią USB ConBee i modułem RaspBee dla Raspberry Pi, który jest również z firmy Dresden-Elektronik."},"authors":["Jey Cee "],"license":"Apache 2.0","platform":"Javascript/Node.js","mode":"daemon","messagebox":true,"enabled":true,"readme":"https://github.com/jey-cee/ioBroker.deconz/blob/master/README.md","loglevel":"debug","keywords":["deconz","philips","tradfri","lightify","dresden-elektronik","hue","led","rgb","smartlink","zigbee"],"icon":"deconz.png","materialize":true,"extIcon":"https://raw.githubusercontent.com/jey-cee/ioBroker.deconz/master/admin/deconz.png","type":"hardware","installedVersion":"0.2.0","host":"raspi2"},"native":{"bridge":"127.0.0.1","port":"8080","user":"660A8C71E2","polling":true,"pollingInterval":30,"openNetwork":false,"websocketport":443,"sw_version":"2.5.32","channel":"1","api_version":"1.0.9","permit":"60","gw_name":"dummy","group_name":""},"from":"system.adapter.admin.0","ts":1533134668393,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2018-08-01 16:44:28.924 - info: deconz.0 terminating
      2018-08-01 16:44:28.950 - info: host.raspi2 instance system.adapter.deconz.0 terminated with code 0 (OK)
      2018-08-01 16:44:30.930 - info: host.raspi2 instance system.adapter.deconz.0 started with pid 20089
      2018-08-01 16:44:32.470 - debug: deconz.0 objectDB connected
      2018-08-01 16:44:32.534 - debug: deconz.0 statesDB connected
      2018-08-01 16:44:32.646 - info: deconz.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v8.11.3
      2018-08-01 16:44:32.691 - debug: deconz.0 API version: 1.0.9
      2018-08-01 16:44:32.729 - debug: deconz.0 getAllLights: {"1":{"ctmax":454,"ctmin":250,"etag":"f34525ab6743b572c04a036c8b1d027c","hascolor":true,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E14 WS opal 400lm","name":"TradfriE14","state":{"alert":"none","bri":1,"colormode":"ct","ct":454,"on":false,"reachable":true},"swversion":"1.2.217","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:8a:31:88-01"},"2":{"etag":"ca3902ccd5759a5ab0ff6c689a73eb51","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug2","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03"},"4":{"etag":"26c0aa793ba4700c4acf490c0fadfbd6","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug3","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:ad:3e:d6-03"},"5":{"etag":"005b16f73342226dbd8c5a4d6e0cf681","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug4","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:ad:1a:3f-03"}}
      2018-08-01 16:44:32.768 - debug: deconz.0 getAllSensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"9114d4ecec5cf33ad47aa8fdfc5d1074","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2018-08-01T13:58:01","status":170},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:01:3e:51-01"},"10":{"config":{"on":true,"reachable":false},"ep":3,"etag":"aa4d99e15dd98bbd85672239a92f0712","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 10","state":{"lastupdated":"2018-07-31T22:45:48","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:a7:7e:71-03-0b04"},"11":{"config":{"on":true,"reachable":true},"ep":3,"etag":"4f48fd5be65591b0659e11da5f5cf27f","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 11","state":{"lastupdated":"2018-08-01T14:43:55","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:ad:3e:d6-03-0b04"},"12":{"config":{"on":true,"reachable":true},"ep":3,"etag":"8ffcf2c4ed66c97a693f195a353dc0a0","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 12","state":{"lastupdated":"2018-08-01T14:44:00","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:ad:1a:3f-03-0b04"},"13":{"config":{"battery":91,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"809bcd1dc67f07b1a0877aaddb6d6962","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"lastupdated":"2018-08-01T14:39:27","temperature":2731},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0402"},"14":{"config":{"battery":91,"on":true,"reachable":true},"ep":1,"etag":"809bcd1dc67f07b1a0877aaddb6d6962","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"humidity":4033,"lastupdated":"2018-08-01T14:39:27"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0405"},"15":{"config":{"battery":91,"on":true,"reachable":true},"ep":1,"etag":"809bcd1dc67f07b1a0877aaddb6d6962","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"lastupdated":"2018-08-01T14:39:27","pressure":1015},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0403"},"16":{"config":{"battery":100,"on":true,"reachable":true,"temperature":3300},"ep":1,"etag":"515344668b0508bd9bb2bc4b88cb7d24","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"SensorDoor1","state":{"lastupdated":"2018-08-01T14:31:57","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:b9:7a:01-01-0006"},"2":{"config":{"on":true,"reachable":true},"ep":3,"etag":"ef5d6227fd84eca7adbfb245a9a770dc","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 2","state":{"lastupdated":"2018-08-01T14:43:50","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03-0b04"},"3":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"682901eeceeb7d871e26ec1bcf25d1c7","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor2","state":{"lastupdated":"2018-08-01T14:41:18","temperature":2892},"type":"ZHATemperature","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0402"},"4":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"682901eeceeb7d871e26ec1bcf25d1c7","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor2","state":{"humidity":4007,"lastupdated":"2018-08-01T14:41:18"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0405"},"5":{"config":{"battery":98,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"4b0bd540cd0ae8941469ceef0c492fb1","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"lastupdated":"2018-08-01T14:02:36","temperature":2600},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f5:20:07-01-0402"},"6":{"config":{"battery":98,"on":true,"reachable":true},"ep":1,"etag":"9e3a7418a9e55c4d93a6a7ab54db1011","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"humidity":4915,"lastupdated":"2018-08-01T14:00:55"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f5:20:07-01-0405"},"7":{"config":{"battery":98,"on":true,"reachable":true},"ep":1,"etag":"9e3a7418a9e55c4d93a6a7ab54db1011","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"lastupdated":"2018-08-01T14:00:55","pressure":1015},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f5:20:07-01-0403"},"8":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"682901eeceeb7d871e26ec1bcf25d1c7","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor2","state":{"lastupdated":"2018-08-01T14:41:18","pressure":1014},"type":"ZHAPressure","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0403"},"9":{"config":{"battery":100,"group":"24194","on":true,"reachable":true},"ep":2,"etag":"65d4dd8152ddcb0fd317fe52f9d1ad02","manufacturername":"Philips","mode":1,"modelid":"RWL021","name":"Dimmschalter","state":{"buttonevent":4002,"lastupdated":"2018-07-31T02:54:12"},"swversion":"5.45.1.17846","type":"ZHASwitch","uniqueid":"00:17:88:01:04:f6:d6:3e-02-fc00"}}
      2018-08-01 16:44:32.802 - debug: deconz.0 getAllGroups: {"24194":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"class":"Other","devicemembership":["9"],"etag":"9114d4ecec5cf33ad47aa8fdfc5d1074","hidden":false,"id":"24194","lights":[],"lightsequence":[],"multideviceids":[],"name":"RWL021 2","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
      2018-08-01 16:44:32.972 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"class":"Other","devicemembership":["9"],"etag":"9114d4ecec5cf33ad47aa8fdfc5d1074","hidden":false,"id":"24194","lights":[],"lightsequence":[],"multideviceids":[],"name":"RWL021 2","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
      2018-08-01 16:44:54.589 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:44:54","power":0},"t":"event"}
      2018-08-01 16:45:00.527 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:45:00","power":0},"t":"event"}
      2018-08-01 16:45:05.561 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:45:05","power":0},"t":"event"}
      2018-08-01 16:45:10.573 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:45:10","power":0},"t":"event"}
      2018-08-01 16:45:31.547 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:45:31","power":0},"t":"event"}
      2018-08-01 16:45:35.607 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:45:35","power":0},"t":"event"}
      2018-08-01 16:45:46.595 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:45:46","power":0},"t":"event"}
      2018-08-01 16:45:52.511 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:45:52","power":0},"t":"event"}
      2018-08-01 16:46:03.395 - debug: deconz.0 system.adapter.admin.0: logging true
      2018-08-01 16:46:05.573 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:05","power":0},"t":"event"}
      2018-08-01 16:46:12.550 - debug: deconz.0 Websocket message: {"config":{"battery":100,"offset":0,"on":true,"reachable":true},"e":"changed","id":"22","r":"sensors","t":"event"}
      2018-08-01 16:46:12.560 - debug: deconz.0 Websocket message: {"e":"changed","id":"22","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:12","temperature":2879},"t":"event"}
      2018-08-01 16:46:12.564 - debug: deconz.0 Websocket message: {"config":{"battery":100,"on":true,"reachable":true},"e":"changed","id":"23","r":"sensors","t":"event"}
      2018-08-01 16:46:12.567 - debug: deconz.0 Websocket message: {"e":"changed","id":"23","r":"sensors","state":{"humidity":3974,"lastupdated":"2018-08-01T14:46:12"},"t":"event"}
      2018-08-01 16:46:12.586 - debug: deconz.0 Websocket message: {"config":{"battery":100,"on":true,"reachable":true},"e":"changed","id":"24","r":"sensors","t":"event"}
      2018-08-01 16:46:12.589 - debug: deconz.0 Websocket message: {"e":"changed","id":"24","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:12","pressure":1014},"t":"event"}
      2018-08-01 16:46:12.592 - debug: deconz.0 Websocket message: {"config":{"battery":100,"offset":0,"on":true,"reachable":true},"e":"changed","id":"3","r":"sensors","t":"event"}
      2018-08-01 16:46:12.594 - debug: deconz.0 Websocket message: {"e":"changed","id":"3","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:12","temperature":2879},"t":"event"}
      2018-08-01 16:46:12.595 - debug: deconz.0 Websocket message: {"config":{"battery":100,"on":true,"reachable":true},"e":"changed","id":"4","r":"sensors","t":"event"}
      2018-08-01 16:46:12.597 - debug: deconz.0 Websocket message: {"e":"changed","id":"4","r":"sensors","state":{"humidity":3974,"lastupdated":"2018-08-01T14:46:12"},"t":"event"}
      2018-08-01 16:46:12.599 - debug: deconz.0 Websocket message: {"config":{"battery":100,"on":true,"reachable":true},"e":"changed","id":"8","r":"sensors","t":"event"}
      2018-08-01 16:46:12.634 - debug: deconz.0 Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:12","pressure":1014},"t":"event"}
      2018-08-01 16:46:15.722 - debug: deconz.0 system.adapter.admin.0: logging false
      2018-08-01 16:46:30.586 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:30","power":0},"t":"event"}
      2018-08-01 16:46:34.563 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:34","power":0},"t":"event"}
      2018-08-01 16:46:42.591 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:42","power":0},"t":"event"}
      2018-08-01 16:46:46.519 - debug: deconz.0 Websocket message: {"e":"changed","id":"2","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:46","power":0},"t":"event"}
      2018-08-01 16:46:50.548 - debug: deconz.0 Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:50","power":0},"t":"event"}
      2018-08-01 16:46:53.789 - debug: deconz.0 system.adapter.admin.0: logging true
      2018-08-01 16:46:54.628 - debug: deconz.0 Websocket message: {"e":"changed","id":"12","r":"sensors","state":{"lastupdated":"2018-08-01T14:46:54","power":0},"t":"event"}
      • Jey Cee
        @Kugelkopf:
        Nachdem der Sensor neue Daten übermittelt hat haben sich wieder 3 neue Objekte gebildet die nur "lastupdated" beinhalten. (Sensor ID 22,23,24) ` Also die Sensoren existieren dann wohl, zumindest liefert deConz für die Sensoren Daten mit den ID's.
        Ich habe jetzt eine neue Version hochgeladen damit sollten die Objekte auch angelegt werden während der Adapter läuft.
          @Jey Cee:
          @Kugelkopf:
          Ich habe jetzt eine neue Version hochgeladen damit sollten die Objekte auch angelegt werden während der Adapter läuft. `
          Habe Ihn gerade probiert. Der Adapter startet immer wieder neu nun. Adapter erst gelöscht dann neu hinzugefügt.
          deconz 2.5.32 api 1.0.9
          2018-08-02 02:39:50.822 - info: deconz.0 starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.deconz, node: v8.11.3
          2018-08-02 02:39:50.937 - debug: deconz.0 API version: 1.0.9
          2018-08-02 02:39:51.012 - debug: deconz.0 getAllLights: {"1":{"ctmax":454,"ctmin":250,"etag":"359f655e37332ee164e301a03f02bcc4","hascolor":true,"manufacturername":"IKEA of Sweden","modelid":"TRADFRI bulb E14 WS opal 400lm","name":"TradfriE14","state":{"alert":"none","bri":79,"colormode":"ct","ct":400,"on":true,"reachable":true},"swversion":"1.2.217","type":"Color temperature light","uniqueid":"90:fd:9f:ff:fe:8a:31:88-01"},"2":{"etag":"3cca15350c84c8261241a036ba1457a7","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug2","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03"},"3":{"etag":"5da05d8b66eecb21a0b161453a404cbb","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug1","state":{"alert":"none","on":false,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:a7:7e:71-03"},"4":{"etag":"fb3fbf8fbdaae955f9a67d03f7bc6cdc","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug3","state":{"alert":"none","on":true,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:ad:3e:d6-03"},"5":{"etag":"735f5ae0be778b1234da90ce1c3510a8","hascolor":false,"manufacturername":"OSRAM","modelid":"Plug 01","name":"Plug4","state":{"alert":"none","on":true,"reachable":true},"swversion":"V1.04.12","type":"On/Off plug-in unit","uniqueid":"7c:b0:3e:aa:00:ad:1a:3f-03"}}
          2018-08-02 02:39:51.044 - debug: deconz.0 getAllSensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"7ea8dd0d0ec0c1b6154b9f32ccc29874","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":true,"daylight":false,"lastupdated":"2018-08-02T00:17:07","status":100},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:01:3e:51-01"},"10":{"config":{"on":true,"reachable":true},"ep":3,"etag":"889586f85b500e820a59182de5d8865b","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 10","state":{"lastupdated":"2018-08-02T00:39:22","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:a7:7e:71-03-0b04"},"11":{"config":{"on":true,"reachable":true},"ep":3,"etag":"e6b2a3ab8b00ab5a66b0fe01f56ba936","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 11","state":{"lastupdated":"2018-08-02T00:39:18","power":40},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:ad:3e:d6-03-0b04"},"12":{"config":{"on":true,"reachable":true},"ep":3,"etag":"45d2fbdba937d5aa6dba10f5197de672","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 12","state":{"lastupdated":"2018-08-02T00:39:27","power":40},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:ad:1a:3f-03-0b04"},"13":{"config":{"battery":95,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"751e0202ff9b4e68440065c05c54147d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"lastupdated":"2018-07-31T22:34:45","temperature":2197},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0402"},"14":{"config":{"battery":95,"on":true,"reachable":true},"ep":1,"etag":"751e0202ff9b4e68440065c05c54147d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"humidity":5741,"lastupdated":"2018-07-31T22:34:45"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0405"},"15":{"config":{"battery":95,"on":true,"reachable":true},"ep":1,"etag":"751e0202ff9b4e68440065c05c54147d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor1","state":{"lastupdated":"2018-07-31T22:34:45","pressure":1015},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f2:3d:52-01-0403"},"16":{"config":{"battery":100,"on":true,"reachable":true,"temperature":3200},"ep":1,"etag":"84a365eefbbb7698007e0d5cc681c5ba","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"SensorDoor1","state":{"lastupdated":"2018-08-02T00:39:20","open":false},"type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:b9:7a:01-01-0006"},"2":{"config":{"battery":100,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"4329516ddd0d91b9d7a6c808dcae8c0d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor2","state":{"lastupdated":"2018-08-02T00:39:12","temperature":2763},"type":"ZHATemperature","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0402"},"3":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"4329516ddd0d91b9d7a6c808dcae8c0d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor2","state":{"humidity":4343,"lastupdated":"2018-08-02T00:39:12"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0405"},"4":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"4329516ddd0d91b9d7a6c808dcae8c0d","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor2","state":{"lastupdated":"2018-08-02T00:39:12","pressure":1014},"type":"ZHAPressure","uniqueid":"00:15:8d:00:02:2c:c8:a3-01-0403"},"5":{"config":{"battery":98,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"304d87aa521bc3b25e4db659f03d2cdf","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"lastupdated":"2018-08-02T00:32:22","temperature":2583},"type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f5:20:07-01-0402"},"6":{"config":{"battery":98,"on":true,"reachable":true},"ep":1,"etag":"304d87aa521bc3b25e4db659f03d2cdf","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"humidity":5002,"lastupdated":"2018-08-02T00:32:22"},"type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f5:20:07-01-0405"},"7":{"config":{"battery":98,"on":true,"reachable":true},"ep":1,"etag":"304d87aa521bc3b25e4db659f03d2cdf","manufacturername":"LUMI","modelid":"lumi.weather","name":"Sensor3","state":{"lastupdated":"2018-08-02T00:32:22","pressure":1015},"type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f5:20:07-01-0403"},"8":{"config":{"on":true,"reachable":true},"ep":3,"etag":"51253506204e0eaee1700225ebe0e066","manufacturername":"OSRAM","modelid":"Plug 01","name":"Power 8","state":{"lastupdated":"2018-08-02T00:39:17","power":0},"swversion":"V1.04.12","type":"ZHAPower","uniqueid":"7c:b0:3e:aa:00:b1:a0:7d-03-0b04"},"9":{"config":{"battery":100,"group":"24194","on":true,"reachable":true},"ep":2,"etag":"2805d00b26a51abe95e99bdd0eaa550f","manufacturername":"Philips","mode":1,"modelid":"RWL021","name":"Dimmschalter","state":{"buttonevent":4002,"lastupdated":"2018-07-31T02:54:12"},"swversion":"5.45.1.17846","type":"ZHASwitch","uniqueid":"00:17:88:01:04:f6:d6:3e-02-fc00"}}
          2018-08-02 02:39:51.094 - debug: deconz.0 getAllGroups: {"24194":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"class":"Other","devicemembership":["9"],"etag":"7ea8dd0d0ec0c1b6154b9f32ccc29874","hidden":false,"id":"24194","lights":[],"lightsequence":[],"multideviceids":[],"name":"RWL021 2","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}}
          2018-08-02 02:39:51.263 - debug: deconz.0 getGroupAttributes: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"class":"Other","devicemembership":["9"],"etag":"7ea8dd0d0ec0c1b6154b9f32ccc29874","hidden":false,"id":"24194","lights":[],"lightsequence":[],"multideviceids":[],"name":"RWL021 2","scenes":[],"state":{"all_on":false,"any_on":false},"type":"LightGroup"}
          2018-08-02 02:40:18.683 - debug: deconz.0 Websocket message: {"e":"changed","id":"10","r":"sensors","state":{"lastupdated":"2018-08-02T00:40:18","power":0},"t":"event"}
          2018-08-02 02:40:18.702 - error: deconz.0 uncaught exception: list is not defined
          2018-08-02 02:40:18.702 - error: deconz.0 ReferenceError: list is not defined
          at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.deconz/main.js:425:67)
          at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
          at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
          at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
          at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
          at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
          at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
          at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
          2018-08-02 02:40:19.214 - error: deconz.0 server error
          2018-08-02 02:40:19.217 - error: deconz.0 Error: server error
          at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:450:19)
          at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
          at WS.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
          at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
          at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
          at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
          at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
          at emitOne (events.js:116:13)
          at WebSocket.emit (events.js:211:7)
          at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
          2018-08-02 02:40:19.725 - error: Caught by controller[0]: ReferenceError: list is not defined
          2018-08-02 02:40:19.727 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.deconz/main.js:425:67)
          2018-08-02 02:40:19.727 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
          2018-08-02 02:40:19.727 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
          2018-08-02 02:40:19.728 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          2018-08-02 02:40:19.728 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
          2018-08-02 02:40:19.728 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
          2018-08-02 02:40:19.728 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          2018-08-02 02:40:19.728 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
          2018-08-02 02:40:19.728 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
          2018-08-02 02:40:19.728 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
          2018-08-02 02:40:19.729 - error: host.raspi2 instance system.adapter.deconz.0 terminated with code 6 (uncaught exception)
          2018-08-02 02:40:19.729 - info: host.raspi2 Restart adapter system.adapter.deconz.0 because enabled
            comchris last edited by
            Hab soeben die Verison 0.2.4 getestet und meine Skripte angepasst irgendwie sind es mittlerweile echt viele 😄 (Lüftungsempfehlungen / Statusmeldungen usw.) Bis jetzt schaut alles prima aus Adapter läuft. Ein kleiner Fehler sagt das Log:
            ! deconz.0 2018-08-02 20:01:17.230 error SyntaxError: Unexpected token � in JSON at position 0 at Object.parse (native) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:324:29) at WebSocket.onMessage
            ! deconz.0 2018-08-02 20:01:17.230 error uncaught exception: Unexpected token � in JSON at position 0
            ! deconz.0 2018-08-02 20:01:17.230 error ReferenceError: sensorId is not defined at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:590:82) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.deconz
            ! deconz.0 2018-08-02 20:01:17.230 error uncaught exception: sensorId is not defined
            Wobei ich dabei sagen muss das dies evtl. "Geisterobjekte" bereits in der Deconz Api sind zumindest sehe ich diese in der Deconz Software auf dem Raspberry nicht. Hab diese Geräte in der Geräteliste Adapter gelöscht und daraufhin den Adapter angehalten und alle Objekte von Deconz gelöscht und den Adapter neu gestartet. Nun sind die vermeindlichen Geisterobjekte verschwunden und das Log bringt nach einiger Zeit wiederrum.
            ! host.debianiobroker 2018-08-02 20:10:50.460 error instance system.adapter.deconz.0 terminated with code 0 (OK)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at Receiver.add (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:117:10)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:143:16)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at Receiver.getData (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:347:12)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:409:14)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:137:47)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at WebSocket.emit (events.js:188:7)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at emitOne (events.js:96:13)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/event-target.js:120:16)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:324:29)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: at Object.parse (native)
            ! Caught 2018-08-02 20:10:50.460 error by controller[1]: SyntaxError: Unexpected token � in JSON at position 0
            ! Caught 2018-08-02 20:10:50.460 error by controller[0]: at emitOne (events.js:96:13)
            ! Caught 2018-08-02 20:10:50.460 error by controller[0]: at Receiver.add (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:117:10)
            ! Caught 2018-08-02 20:10:50.460 error by controller[0]: at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:143:16)
            ! Caught 2018-08-02 20:10:50.460 error by controller[0]: at Receiver.getData (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:347:12)
            ! Caught 2018-08-02 20:10:50.460 error by controller[0]: at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:409:14)
            ! Caught 2018-08-02 20:10:50.460 error by controller[0]: at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:137:47)
            ! Caught 2018-08-02 20:10:50.460 error by controller[0]: at WebSocket.emit (events.js:188:7)
            ! Caught 2018-08-02 20:10:50.459 error by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/event-target.js:120:16)
            ! Caught 2018-08-02 20:10:50.459 error by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:590:82)
            ! Caught 2018-08-02 20:10:50.459 error by controller[0]: ReferenceError: sensorId is not defined
            ! deconz.0 2018-08-02 20:10:50.450 info terminating
            ! deconz.0 2018-08-02 20:10:49.947 error at Receiver.add (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:117:10)
            ! deconz.0 2018-08-02 20:10:49.947 error at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:143:16)
            ! deconz.0 2018-08-02 20:10:49.947 error at Receiver.getData (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:347:12)
            ! deconz.0 2018-08-02 20:10:49.947 error at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:409:14)
            ! deconz.0 2018-08-02 20:10:49.947 error at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:137:47)
            ! deconz.0 2018-08-02 20:10:49.947 error at WebSocket.emit (events.js:188:7)
            ! deconz.0 2018-08-02 20:10:49.947 error at emitOne (events.js:96:13)
            ! deconz.0 2018-08-02 20:10:49.947 error at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/event-target.js:120:16)
            ! deconz.0 2018-08-02 20:10:49.947 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:324:29)
            ! deconz.0 2018-08-02 20:10:49.947 error at Object.parse (native)
            ! deconz.0 2018-08-02 20:10:49.947 error SyntaxError: Unexpected token � in JSON at position 0
            ! deconz.0 2018-08-02 20:10:49.947 error uncaught exception: Unexpected token � in JSON at position 0
            ! deconz.0 2018-08-02 20:10:49.945 error at emitOne (events.js:96:13)
            ! deconz.0 2018-08-02 20:10:49.945 error at Receiver.add (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:117:10)
            ! deconz.0 2018-08-02 20:10:49.945 error at Receiver.startLoop (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:143:16)
            ! deconz.0 2018-08-02 20:10:49.945 error at Receiver.getData (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:347:12)
            ! deconz.0 2018-08-02 20:10:49.945 error at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/receiver.js:409:14)
            ! deconz.0 2018-08-02 20:10:49.945 error at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/websocket.js:137:47)
            ! deconz.0 2018-08-02 20:10:49.945 error at WebSocket.emit (events.js:188:7)
            ! deconz.0 2018-08-02 20:10:49.945 error at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.deconz/node_modules/ws/lib/event-target.js:120:16)
            ! deconz.0 2018-08-02 20:10:49.945 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:590:82)
            ! deconz.0 2018-08-02 20:10:49.945 error ReferenceError: sensorId is not defined
            ! deconz.0 2018-08-02 20:10:49.945 error uncaught exception: sensorId is not defined
            ! deconz.0 2018-08-02 20:10:49.937 debug Websocket message: {"config":{"battery":100,"duration":60,"on":true,"reachable":true,"temperature":2800},"e":"changed","id":"78","r":"sensors","t":"event"}
            Muss mal gucken wie oft dieser neu startet oder ob dies ggf. eine einmalige Geschichte ist….
            • Jey Cee
              Bitte nicht mehr von Github installieren. Ich hab mich damit heute schon beschäftigt und weiss noch nicht wie ich das sinnvoll ändere.
                goohnie last edited by
                @iobrokermark:
                Freut mich zu hören dass es klappt. Jetzt würde mich allerdings interessieren welchen Dual-Taster du verwendest. Ist dieser auch von Xiaomi?
                Kenne nur den Sonoff Touch. `
                Ich verwende den Xiaomi WXKG02LM Aqara Smart Lichtschalter, gibts als Single und Dualversion und kosten
                bei Garbst gerade mal 12 Euro zur Zeit. Ich bin hoch zufrieden damit.
                Wenn man einen kleinen Nachteil sehen will, dann ist es die Tatsache, des es nur Taster sind, True und False ist nicht.
                Aber es werden im Deconzadapter Zahlenwerte für die verschiedenen Tasten dargestellt, die man dann umschalten kann.
                Dafür bietet der Single-Taster noch eine Doppeltast Funktion und bietet somit zwei Schaltzustände und der Dual hat ein dritte
                Schaltfunktion, in dem man zwei Tasten gleichzeitig drückt. Feine Sache insgesamt.
                cu goohnie
                  Dani83 last edited by
                  @comchris:
                  Muss mal gucken wie oft dieser neu startet oder ob dies ggf. eine einmalige Geschichte ist…. `
                  Moin,
                  ich hab festgestellt, dass in der Main.js noch ein Fehler ist, der zu dem error führt.
                  Zeile 590: Muss nur id stehen, nicht sensorId.
                  Dann läuft es bei mir jetzt super 🙂
                  • Jey Cee
                    Neue Version 0.2.5 behebt das Problem mit dem Absturz.
                    Kann von Github installiert werden.
                    @comchris:
                    Wobei ich dabei sagen muss das dies evtl. "Geisterobjekte" bereits in der Deconz Api sind zumindest sehe ich diese in der Deconz Software auf dem Raspberry nicht. Hab diese Geräte in der Geräteliste Adapter gelöscht und daraufhin den Adapter angehalten und alle Objekte von Deconz gelöscht und den Adapter neu gestartet. ` Ich hab diese Geisterobjekte auch gesehen. Mit der Aktuellen Version werden dazu auch die restlichen Objekte dazu angelegt, aber kein Name vergeben.
                    Jetzt kann ich sicher sagen das dieses Phänomen von deConz kommt.
                      Kugelkopf last edited by
                      Hab auf meinem 2. Test Raspi die V 0.2.5 getestet. Api:1.0.9 deconz: 2.5.32.
                      Ich weiß nicht ob es nur ein Zufall ist, aber die "Geisterobjekte" sind bisher nicht aufgetaucht.
                      Habe einen der Aqara Multisensoren gelöscht und via deconz Adapter hinzugefügt.
                      Der Sensor erschien zwar in Phoscon aber nicht in der Objekte liste (trotz reload). Nach einem umbenennen in Phoscon und eines Neustarts des deconz Adapters erschien der Sensor in den Objekten. Allerdings ohne Werte. Ein neustart des iobroker Hosts war von Nöten damit er nun auch Werte liefert.
                      Dies scheint zu funktionieren. Fehler sind im Log bisher nicht aufgetreten.
                      Wollte dir kurz meine Erfahrungen mit der neuen Version mitteilen.
                      Was mir übrigens auch aufgefallen ist: Früher konnte ich den Knopf des Aqara Sensors kurz drücken damit er neue Daten übermittelt. Das wurde auch sofort in ioBroker angezeigt. Dies scheint nun nicht mehr zu gehen. Puste ich allerdings hinein, werden die Daten in iobroker aktualisiert.
                      Nur als kleiner Hinweis.
                      • Jey Cee
                        Danke für die info, endlich mal nicht gleich Probleme.
                        Gesendet von meinem m8 mit Tapatalk
                          DocGame last edited by
                          Hallo miteinander,
                          ich habe folgendes Problem:
                          Ich habe ein Windows 10 NUC mit Conbeestick am laufen.
                          Einige Dinge sind mir immer noch nicht ganz Klar.
                          5 Osram Plug+, 5 Xiaomi Fensterkontakte, 2 Xiaomi Bewegungsmelder und den Xiaomi MagicCube habe ich problemlos in der Phoscon App anlernen können und sehe diese dort auch.
                          Einen Xiaomi Wassersensor und einen Xiaomi-Honeywell Rauchmelder findet er beim anlernen, zeigt diese aber in Phoscon nicht an und diese lassen sich dadurch auch nicht umbenennen.
                          2 Xiaomi Button-Taster(rund) werden in der Phoscon App nicht erkannt erscheinen aber ohne Name in Deconz.
                          Bis auf die Xiaomi-Buttons sehe ich alle Objekte in IOBroker.
                          Mache ich etwas falsch und wie funktionier das Anlernen in dem Deconz.Adapter? In diesem Konnte ich kein einziges Gerät anlernen. Gibt es hier einen Trick?
                          Danke schon ein mal im Voraus…
                          Doc Game
                          • Jey Cee
                            @DocGame:
                            wie funktionier das Anlernen in dem Deconz.Adapter? In diesem Konnte ich kein einziges Gerät anlernen. Gibt es hier einen Trick? ` Instanzen->deConz->Geräte verwalten->Netzwerk öffnen
                            WICHTIG: Es muss bei Dauer eine Zeit (in Sekunden) angegeben sein.
                            Mit dem Anlernen von Geräten hatte ich in letzter Zeit häufiger Problem, das ging soweit das bestimmte Geräte gar nicht anlernbar waren. Dabei war es egal ob Phoscon, WebAPP oder Adapter, da half einfach nur ein Neustart von deConz.
                            @DocGame:
                            Mache ich etwas falsch ` Glaube ich nicht. Wenn du alle Geräte mit Phoscon angelernt hast und sie werden nicht angezeigt liegt es an Phoscon/deConz.
                            • Schuko80
                              Schuko80 last edited by
                              Die Frage ist, ob die Geräte von Deconz überhaupt schon unterstützt werden… mit der aktuellen Beta hast du die größte Unterstützung, mußt aber mit Fehlern rechnen, die Stable ist schon recht alt.
                                wollinator last edited by
                                der deconz Adapter wirft mir "index.html not found" entgegen, wenn ich versuch die Configseite zu öffnen.
                                Any hints?
                                Dankeschön….
                                • Jey Cee
                                  Admin 3 installiert?
                                    Ne, aber Admin 1 und damit gings nicht.
                                    Admin 2 probiert und es funktioniert!
                                    Vielen Dank!
                                      Fatmax last edited by
                                      Ich bin nun spät aber doch von Version 0.2.0 auf 0.2.5 umgestiegen.
                                      Bisher haben die Sensoren einwandfrei funktioniert.
                                      Ich hatte die Sensoren vor dem Update im Adapter angelernt, diese hatten dann automatisch Namen wie "Temperature_5" bekommen - der Name im Adapter und die Objekt-ID unter Objekte war immer die Messgröße und die ID-Nummer z.B. eben "Temperature_5".
                                      Seit dem Update sind diese Objekte zwar noch vorhanden, werden aber nicht mehr aktualisiert.
                                      Im Adapter scheinen diese jedoch nach wie vor unter diesem Namen auf.
                                      Zusätzlich sind im Adapter die selben Sensoren mit dem selben Namen (z.B.: "Temperature_5" nun doppelt vorhanden.
                                      Unter Objekte sind nun neue Objekte aufgetaucht mit der Objekt-ID "Sensor_1", "Sensor_2",… -> bei diesen werden nun die Werte auch aktualisiert.
                                      Ich habe herausgefunden, dass die Sensornummer gleich ist wie die alte ID-Nummer, z.B.: Unter Sensor_5 wird die selbe Messgröße vom selben Sensor angezeigt wie bei "Temperature_5".
                                      Unter dem Adapter steht jedoch nicht die Sensor-Bezeichnung, sondern die alte ursprüngliche Bezeichnung (was nun doppelte Einträge verursacht).
                                      Könnte man das ändern, dass im Objektbaum unter "ID" wieder der "Name" aus dem Adapter aufscheint?
                                      • Jey Cee
                                        Zuerst mal, hast du den Adapter vorher gelöscht? Wenn ja sollten die alten Objekte nicht mehr auftauchen.
                                        Nein die IDs können nicht der Name sein. Das musste ich Komplett Umbauen um Probleme zu umgehen.
                                          @Jey Cee:
                                          Gesendet von meinem m8 mit Tapatalk `
                                          Nein den Adapter habe ich nicht gelöscht, sondern einfach ein Update gemacht.
                                          Das heißt ich muss die Instanz löschen, neu installieren und anschließend im Adapter die Sensoren neu anlernen?
                                          Haben die dann nun ab jetzt die Bezeichnung "Sensor_1",…?
                                          Kann ich die Bezeichnung danach manuell ändern oder wäre das schlecht?
                                          Ich will nicht meinen ganzen View in Vis und die Scripte ändern. <emoji seq="1f914">🤔</emoji>
                                          • Jey Cee
                                            Wenn du die Instanz löscht werden nur die Objekte gelöscht, die Sensoren sind ja an deConz angemeldet. Der Adapter zieht sich das alles automatisch.
                                            Die ID kannst du nicht ändern, das heißt die IDs sind weiterhin Sensor_x.
                                            deconz zigbee
                                            57
                                            532
                                            118963
