    4. [Aufruf] ZigBee CC253x Adapter
      Sinalco last edited by
      Leider habe ich es noch nicht hinbekommen, die Osram RGBW mit dem zigbee Adapter zu steuern, hab mehrmals versucht über das Symbol mit der Katze unter dem Reiter "beliebig" Zigbee neu zu installieren.
      Davor hab ich den Adapter natürlich gelöscht.
      Hab mal die debug Ausgabe angemacht:
      $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee" --debug
      install https://github.com/ioBroker/ioBroker.zigbee/tarball/master
      npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      iobroker.inst@1.0.8 /opt/iobroker└── iobroker.zigbee@0.6.0
      npm
      WARN
      optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      process exited with code 0
      und das ist die Ausgabe beim hinzufügen einer Instanz:
      $ ./iobroker add zigbee
      host.raspberrypi install adapter zigbee
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.zigbee"
      prebuild-install
       WARN install No prebuilt binaries found (target=6.14.3 runtime=node arch=arm platform=linux)
      ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:../src/serialport.cpp:95:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
         data->callback.Call(2, argv);
      In file included from ../src/./serialport.h:6:0,
                       from ../src/serialport.cpp:1:
      ../../nan/nan.h:1618:3: note: declared here
         Call(int argc, v8::Local <v8::value>argv[]) const {
      ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:../src/serialport.cpp:150:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
         data->callback.Call(1, argv);
      In file included from ../src/./serialport.h:6:0,                 from ../src/serialport.cpp:1:
      ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:../src/serialport.cpp:188:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:../src/serialport.cpp:231:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:../src/serialport.cpp:285:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:../src/serialport.cpp:336:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:../src/serialport.cpp:383:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:../src/serialport.cpp:424:30: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:../src/poller.cpp:69:29: warning: ‘v8::Local <v8::value>Nan::Callback::Call(int, v8::Local<v8::value>*) const’ is deprecated [-Wdeprecated-declarations]
         obj->callback.Call(2, argv);
      In file included from ../src/poller.cpp:1:0:../../nan/nan.h:1618:3: note: declared here
      got /opt/iobroker/node_modules/iobroker.zigbee/admin
      upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smoke.png img/smoke.png image/png
      upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lst002.png img/philips_hue_lst002.png image/png
      upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-par16.png img/lightify-par16.png image/png
      upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hive.png img/hive.png image/png
      upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/contact.png img/contact.png image/png
      upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
      upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
      upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_temperature_sensor.png img/aqara_temperature_sensor.png image/png
      upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
      upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara.switch.png img/aqara.switch.png image/png
      upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.remote.control.png img/TRADFRI.remote.control.png image/png
      upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.bulb.E27.png img/TRADFRI.bulb.E27.png image/png
      upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
      upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
      upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
      upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
      upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
      host.raspberrypi object system.adapter.zigbee created
      host.raspberrypi create instance zigbee
      host.raspberrypi object zigbee.0.info.pairingMessage created
      host.raspberrypi object zigbee.0.info.pairingCountdown created
      host.raspberrypi object zigbee.0.info.pairingMode created
      host.raspberrypi object zigbee.0.info.connection created
      host.raspberrypi object zigbee.0.info created
      host.raspberrypi object system.adapter.zigbee.0.outputCount created
      host.raspberrypi object system.adapter.zigbee.0.inputCount created
      host.raspberrypi object system.adapter.zigbee.0.uptime created
      host.raspberrypi object system.adapter.zigbee.0.memRss created
      host.raspberrypi object system.adapter.zigbee.0.memHeapTotal created
      host.raspberrypi object system.adapter.zigbee.0.memHeapUsed created
      host.raspberrypi object system.adapter.zigbee.0.connected created
      host.raspberrypi object system.adapter.zigbee.0.alive created
      host.raspberrypi object system.adapter.zigbee.0 created
      process exited with code 0</v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value></v8::value>
      komisch ist auch das meine Geräte nachdem man den Port in der Adapter Einstellung eingegeben hat, immer noch im Adapter angezeigt werden.
      Auch nach einem erneuten anlernen des Osram RGBW LED Bands wird kein Ordner bei Objekte erstellt.
        es ist eine neue Version 0.7.1verfügbar..
        Ilya hat eine super Arbeit geleistet.. er hat eine "Network Map" erzeugen lassen..somit ist es möglich nachzuvollziehen welches Gerät über welchen Router kommuniziert..
        unter Settings kann man auch die LED Abschalten..
          leider funktioniert jetzt der Adapter nicht mehr:
          host.raspberrypi	2018-08-14 20:00:25.513	info	Restart adapter system.adapter.zigbee.0 because enabled
          host.raspberrypi	2018-08-14 20:00:25.513	error	instance system.adapter.zigbee.0 terminated with code 0 (OK)
          host.raspberrypi	2018-08-14 20:00:25.512	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/devices.js:5:12)
          host.raspberrypi	2018-08-14 20:00:25.512	error	Caught by controller[0]: at require (internal/module.js:20:19)
          host.raspberrypi	2018-08-14 20:00:25.512	error	Caught by controller[0]: at Module.require (module.js:504:17)
          host.raspberrypi	2018-08-14 20:00:25.512	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
          host.raspberrypi	2018-08-14 20:00:25.511	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
          host.raspberrypi	2018-08-14 20:00:25.511	error	Caught by controller[0]: at Module.load (module.js:494:32)
          host.raspberrypi	2018-08-14 20:00:25.511	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
          host.raspberrypi	2018-08-14 20:00:25.511	error	Caught by controller[0]: at Module._compile (module.js:549:28)
          host.raspberrypi	2018-08-14 20:00:25.510	error	Caught by controller[0]: at Object.runInThisContext (vm.js:97:10)
          host.raspberrypi	2018-08-14 20:00:25.510	error	Caught by controller[0]: at createScript (vm.js:56:10)
          host.raspberrypi	2018-08-14 20:00:25.510	error	Caught by controller[0]: SyntaxError: Unexpected token ...
          host.raspberrypi	2018-08-14 20:00:25.509	error	Caught by controller[0]: ^^^
          host.raspberrypi	2018-08-14 20:00:25.509	error	Caught by controller[0]: value = {...value, ...rgbToXY(value.r, value.g, value.b)};
          host.raspberrypi	2018-08-14 20:00:25.508	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/converters/toZigbee.js:95
          zigbee.0	2018-08-14 20:00:25.230	info	starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v6.14.3
          host.raspberrypi	2018-08-14 20:00:22.807	info	instance system.adapter.zigbee.0 started with pid 30259
          musiccast.0	2018-08-14 19:59:56.550	debug	system.adapter.admin.0: logging true
          host.raspberrypi	2018-08-14 19:59:52.784	info	Restart adapter system.adapter.zigbee.0 because enabled
          host.raspberrypi	2018-08-14 19:59:52.784	error	instance system.adapter.zigbee.0 terminated with code 0 (OK)
          Caught	2018-08-14 19:59:52.783	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/devices.js:5:12)
          Caught	2018-08-14 19:59:52.783	error	by controller[0]: at require (internal/module.js:20:19)
          Caught	2018-08-14 19:59:52.783	error	by controller[0]: at Module.require (module.js:504:17)
          Caught	2018-08-14 19:59:52.783	error	by controller[0]: at Function.Module._load (module.js:445:3)
          Caught	2018-08-14 19:59:52.783	error	by controller[0]: at tryModuleLoad (module.js:453:12)
          Caught	2018-08-14 19:59:52.782	error	by controller[0]: at Module.load (module.js:494:32)
          Caught	2018-08-14 19:59:52.782	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
          Caught	2018-08-14 19:59:52.782	error	by controller[0]: at Module._compile (module.js:549:28)
          Caught	2018-08-14 19:59:52.780	error	by controller[0]: at Object.runInThisContext (vm.js:97:10)
          Caught	2018-08-14 19:59:52.780	error	by controller[0]: at createScript (vm.js:56:10)
          Caught	2018-08-14 19:59:52.780	error	by controller[0]: SyntaxError: Unexpected token ...
          Caught	2018-08-14 19:59:52.780	error	by controller[0]: ^^^
          Caught	2018-08-14 19:59:52.779	error	by controller[0]: value = {...value, ...rgbToXY(value.r, value.g, value.b)};
          Caught	2018-08-14 19:59:52.779	error	by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-shepherd-converters/converters/toZigbee.js:95
          zigbee.0	2018-08-14 19:59:52.676	info	terminating
          zigbee.0	2018-08-14 19:59:52.525	info	starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v6.14.3</anonymous></anonymous>
          Es ist jetzt übrigens eine neue Version 0.7.0
          Muss ich eine andere node Version installieren?
            du hast genau die defekte Version erwischt…. 0.7.1 ist online
              Ok, schlechtes Timing…
              Jetzt funktioniert es 😄 😄 , hmm fast...
              Mit 0.7.1 kann ich jetzt das Osram Band steuern, allerdings mit ein paar Einschränkungen.
              On/Off, Helligkeit und Farbtemp. geht soweit.
              Allerdings bin ich mir nicht sicher welches die min. und max. Werte sind.
              Die Farbe kann ich überhaupt nicht ändern bei deConz ging die Fabe von 0 bis glaub 65000 wobei ich nur bis 63000 benutz habe.
              Für die Sättigung gibt es wohl keinen Parameter.
              Folgende Fehlermeldung meldet der Zigbee Adapter:
              zigbee.0	2018-08-14 21:51:23.915	error	Zigbee publish to '0x7cb03eaa000024ef', genLevelCtrl - moveToLevel - {"level":256,"transtime":0} - 3 failed with error TypeError: "value" argument is out of bounds
              admin.0	2018-08-14 21:50:42.840	info	successful connection to socket.io from ::ffff:93.239.112.40
              musiccast.0	2018-08-14 21:50:35.397	debug	system.adapter.admin.0: logging false
              zigbee.0	2018-08-14 21:50:26.793	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:233:12)
              zigbee.0	2018-08-14 21:50:26.793	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:275:10)
              zigbee.0	2018-08-14 21:50:26.793	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
              zigbee.0	2018-08-14 21:50:26.793	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
              zigbee.0	2018-08-14 21:50:26.793	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3400:34)
              zigbee.0	2018-08-14 21:50:26.793	error	at Adapter.emit (events.js:188:7)
              zigbee.0	2018-08-14 21:50:26.793	error	at emitOne (events.js:96:13)
              zigbee.0	2018-08-14 21:50:26.793	error	at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.zigbee/main.js:114:21)
              zigbee.0	2018-08-14 21:50:26.793	error	at getMap (/opt/iobroker/node_modules/iobroker.zigbee/main.js:320:19)
              zigbee.0	2018-08-14 21:50:26.793	error	at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:273:23)
              zigbee.0	2018-08-14 21:50:26.793	error	TypeError: this.shepherd.lqiScan is not a function
              zigbee.0	2018-08-14 21:50:26.791	error	message messagebox.system.adapter.zigbee.0 [object Object] this.shepherd.lqiScan is not a function
              admin.0	2018-08-14 21:50:26.321	info	successful connection to socket.io from ::ffff:93.239.112.40
              zigbee.0	2018-08-14 21:50:07.813	error	Join failure.. Error: Not a valid type.
              zigbee.0	2018-08-14 21:50:07.807	info	Zigbee: allowing new devices to join.
              zigbee.0	2018-08-14 21:49:22.613	info	new dev 0x7cb03eaa000024ef 36959 Flex RGBW
              zigbee.0	2018-08-14 21:49:04.734	info	Zigbee: allowing new devices to join.</anonymous></anonymous>
              Hier mal ein Bild von meinem vis:
                worfinator last edited by
                Ich nutze nun auch erfolgreich diesen Adapter. Läuft bislang problemlos an meinem NUC.
                Habe im Moment erstmal drei GU10 Tradfri Lampen verbunden.
                3 Fragen hätte ich:
                1. Die Tradfri-Fernbedienungen krieg ich nicht gepairt. Gibt es da einen Weg?
                2. Die Brightness geht von 0 bis 254. Der Homekit-Adapter Yahka erwartet für Helligkeit aber 0 bis 100 %. Gibt es da eine einfache Lösung oder muss ich mir da was für basteln?
                3. Kann man Zigbee-Leuchtmittel gruppieren? Die drei GU10 sind in einer Lampe bei mir. Muss sie derzeit einzeln ansprechen.
                Danke für eure Hilfe und den klasse Adapter!
                  @worfinator:
                  3. Kann man Zigbee-Leuchtmittel gruppieren? Die drei GU10 sind in einer Lampe bei mir. Muss sie derzeit einzeln ansprechen. `
                  Das geht ganz einfach mit dem Szenen Adapter:
                  http://www.iobroker.net/docu/?page_id=1950&lang=de
                    @worfinator:
                    3 Fragen hätte ich:
                    1. Die Tradfri-Fernbedienungen krieg ich nicht gepairt. Gibt es da einen Weg? `
                    sollte aber gehen.. ist auch im Adapter implementiert..
                    @worfinator:
                    2. Die Brightness geht von 0 bis 254. Der Homekit-Adapter Yahka erwartet für Helligkeit aber 0 bis 100 %. Gibt es da eine einfache Lösung oder muss ich mir da was für basteln? `
                    0 - 254 ist so.. müsste man umrechnen .. ich frag Ilya
                    @worfinator:
                    ne Gruppen gehen nicht .. nimm den Scenen adapter ..
                      @Sinalco:
                      1.PNG `
                      die Farbe ist HEX codiert wie hue
                      z.b: 99FF00 ist Grün
                      die Sättigung ergibt sich aus den Werten
                        @arteck:
                        @worfinator:
                        sollte aber gehen.. ist auch im Adapter implementiert.. `
                        Das krieg ich nicht hin. Wenn ich die Pair-Taste an der Fernbedienung drücke und im Adapter passiert genau nichts.
                        Was ist da der Trick?
                        Habe gerade eine "TRADFRI bulb E14 WS opal 400lm" angelernt. Wird vom Adapter leider noch nicht unterstützt.
                        Das Ding hat genau die gleichen Eigenschaften wie die bereits unterstütze "TRADFRI bulb GU10 WS 400lm". Könnt ihr den Support da einprogrammieren?
                        Danke für eure Hilfe!
                          @worfinator:
                          Das Ding hat genau die gleichen Eigenschaften wie die bereits unterstütze "TRADFRI bulb GU10 WS 400lm". Könnt ihr den Support da einprogrammieren? `
                          Dazu habe ich direkt ein Update. Mittlerweile kann ich die Lampe steuern. Nur das Icon fehlt…warum auch immer geht sie jetzt. Wie gesagt nur ohne Icon... :mrgreen:
                            @worfinator:
                            @worfinator:
                            Das Ding hat genau die gleichen Eigenschaften wie die bereits unterstütze "TRADFRI bulb GU10 WS 400lm". Könnt ihr den Support da einprogrammieren? Dazu habe ich direkt ein Update. Mittlerweile kann ich die Lampe steuern. Nur das Icon fehlt…warum auch immer geht sie jetzt. Wie gesagt nur ohne Icon... :mrgreen:
                            icon fehlt weil path ist verkehrt..habs korrigiert.. musst bist nächste Version mit leben..
                            für deine Tradfri-Fernbedienung seh ich gerade .. es ist nicht ausprogrammiert..
                            • umbm
                              umbm last edited by
                              Hat es schon jemand geschafft, die Network Map vollständig angezeigt zu bekommen?
                              Ich sehe zwar alle devices aber keine Verbindungen, der refresh-Button ist auch inaktiv.
                              Issue habe ich auf github schon geöffnet mit Logauszug.
                                installiere den Adapter neu 0.7.1 ist die gültige Version.. da gabs ein Problem.. mit den Libs
                                aber ja hier meine
                                • umbm
                                  umbm last edited by
                                  Habe ich inzwischen komplett neu installiert und konfiguriert mit 0.7.1.
                                  Fehlermeldungen im Log sind keine mehr, aber Verbindungen werden noch immer nicht angezeigt.
                                  Habe Chrome, Firefox und EDGE versucht… :?:
                                    ok also….
                                    chrome auf
                                    Adapter zigbee stoppen...
                                    auf debug stellen Adapter starten
                                    jetzt LOG beobachten.. es müssen alle Geräte aufgelistet werden die Zigbee findet
                                    warten bei mir ca 3 min. bis sich Der stick mit allen Geräten konnectet hat
                                    jetzt kannst du im Adapter schauen auf der Map wenn nicht s da
                                    zurück ins Log und schauen ob Fehlermeldung vorhanden
                                      @arteck:
                                      für deine Tradfri-Fernbedienung seh ich gerade .. es ist nicht ausprogrammiert.. `
                                      Was kann ich tun, damit die Fernbedienung da einprogrammiert wird?
                                      Mir ist eine Sache aufgefallen:
                                      Angenommen ich schalte drei Lampen ein. Egal ob per Szene oder Skript. Geht 1a.
                                      Wenn ich nun direkt danach noch die Helligkeit bei allen drei Lampen umstelle, klappt das oft bei mindestens einer der drei Lampen nicht.
                                      Mache ich einen Delay von 3 Sekunden dazwischen gibt es das Problem nicht. Wo dran kann das liegen? Mit dem originalen Tradfri-Gateway an selber Stelle hatte ich das Problem nicht.
                                      • chucky666
                                        chucky666 last edited by
                                        Hallo
                                        Hat jemand den Xiaomi Aqara Double Schalter gepairt bekommen ?
                                        Gesendet von iPad mit Tapatalk Pro
                                          milonga last edited by
                                          wie bekomme ich die 0.7.1 installiert?
                                          Sorry für dumme Frage - bin neu…
                                            @milonga:
                                            wie bekomme ich die 0.7.1 installiert? `
                                            iobroker upgrade zigbee@0.7.1
                                            1078
                                            342985
