    3. Cloud Dienste
    4. Iobroker.alexa2 v0.4+
      @eve11:
      • Verschiedene Versionen von Alexa 2 Adapter
      eve11 `
      Warum verschiedene Versionen, sind die zuvor deinstalliert worden, und die Objekte gelöscht?
      Welches System verwendest du ,Adapter alle aktuell?
      NPM Version?
      Node Version?
      Sigi
        eve11 last edited by
        Hier alles was ich nach einer Lautstärken Änderung bekomme. In diesem Fall auf "20".
        alexa2.0	2018-08-16 13:01:34.822	debug	Alexa-Remote WS-MQTT: Received Pong
        alexa2.0	2018-08-16 13:01:34.720	debug	Alexa-Remote WS-MQTT: Send Ping
        alexa2.0	2018-08-16 13:01:06.210	debug	State changed alexa2.0.Echo-Devices.G000MW0xxxxxxxxxx.Player.muted: {"val":false,"ack":true,"ts":1534417266207,"q":0,"from":"system.adapter.alexa2.0","lc":1534413932342}
        alexa2.0	2018-08-16 13:01:06.208	debug	State changed alexa2.0.Echo-Devices.G000MW0xxxxxxxxxx.Player.volume: {"val":50,"ack":true,"ts":1534417266205,"q":0,"from":"system.adapter.alexa2.0","lc":1534417266205}
        alexa2.0	2018-08-16 13:01:06.204	info	Alexa-Push-Connection Device Volume change for G000MW0xxxxxxxxxx -> 50/false
        alexa2.0	2018-08-16 13:01:06.204	debug	Alexa-Remote WS-MQTT: Command PUSH_VOLUME_CHANGE: { "destinationUserId": "A2Z9TULxxxxxxx", "dopplerId": { "deviceSerialNumber": "G000MW0xxxxxxxxxx", "deviceType": "A1NL4xxxxxxxx
        alexa2.0	2018-08-16 13:01:06.204	info	Alexa-Push-Connection Unknown Command - send to Developer: {"destinationUserId":"A2Z9TULxxxxxxx","bass":0,"treble":0,"dopplerId":{"deviceSerialNumber":"G000MW0xxxxxxxxxx","deviceType":"A1NL4Bxxxxxxxx"}
        alexa2.0	2018-08-16 13:01:06.204	debug	Alexa-Remote WS-MQTT: Command PUSH_EQUALIZER_STATE_CHANGE: { "destinationUserId": "A2Z9TULxxxxxxx", "bass": 0, "treble": 0, "dopplerId": { "deviceSerialNumber": "G000MW07xxxxxx
        alexa2.0	2018-08-16 12:58:34.817	debug	Alexa-Remote WS-MQTT: Received Pong
        alexa2.0	2018-08-16 12:58:34.716	debug	Alexa-Remote WS-MQTT: Send Ping
        alexa2.0	2018-08-16 12:58:34.055	debug	system.adapter.admin.0: logging true
        alexa2.0	2018-08-16 12:58:11.680	debug	Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/behaviors/preview","method":"POST","timeout":10000,"headers":{}}and data={"behaviorId":"PREVIEW","sequenceJson":"{\"@type\":\
        alexa2.0	2018-08-16 12:58:11.680	debug	Alexa-Remote: No authentication check needed (time elapsed 530645)
        alexa2.0	2018-08-16 12:58:11.680	debug	State changed alexa2.0.Echo-Devices.G000MW0xxxxxxxxxx.Player.volume: {"val":20,"ack":false,"ts":1534417091678,"q":0,"from":"system.adapter.admin.0","lc":1534417091678
        Node.js: v6.12.2
        NPM: 3.10.10
        Ja, ich habe den kompletten Adapter und Objekte einmal gelöscht und wieder neu installiert.Vorher hatte ich auch andere Versionen vom Adapter probiert, aber immer das selbe Ergebnis.
        eve11
          Apropo last edited by
          Ich benutze aktuell noch die Version 0.3.8
          Bisher ist alles gut gelaufen. Heute morgen dann ohne irgendwas zu ändern folgene Meldung in den Logs
          javascript.0	2018-08-16 13:33:40.852	warn	at Object. <anonymous>(script.js.Meine_Schalter.Anrufer:24:7)
          javascript.0	2018-08-16 13:33:40.842	warn	Wrong type of alexa2.0.Echo-Devices.G090LF1174660MWC.Player.volume: "string". Please fix, while deprecated and will not work in next versions.
          javascript.0	2018-08-16 13:32:47.993	info	script.js.Meine_Schalter.Anrufer: registered 1 subscription and 0 schedules
          javascript.0	2018-08-16 13:32:47.982	info	Start javascript script.js.Meine_Schalter.Anrufer
          javascript.0	2018-08-16 13:32:41.009	info	Stop script script.js.Meine_Schalter.Anrufer
          javascript.0	2018-08-16 13:23:55.514	info	Stop script script.js.Meine_Schalter.Skript1
          alexa2.0	2018-08-16 11:39:49.949	warn	Device-type:A2M4YX06LWP8WI (MICROPHONE,PEONY,ASX_TIME_ZONE,VOLUME_SETTING,SUPPORTS_SOFTWARE_VERSION)
          alexa2.0	2018-08-16 11:39:49.946	warn	Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
          alexa2.0	2018-08-16 11:39:46.755	info	starting. Version 0.3.8 in /opt/iobroker/node_modules/iobroker.alexa2, node: v6.14.3
          host.iobrokervm	2018-08-16 11:39:45.702	info	instance system.adapter.alexa2.0 started with pid 4774
          host.iobrokervm	2018-08-16 11:39:15.668	info	Restart adapter system.adapter.alexa2.0 because enabled
          host.iobrokervm	2018-08-16 11:39:15.668	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
          Caught	2018-08-16 11:39:15.668	error	by controller[1]: at TCP.done [as _onclose] (_tls_wrap.js:332:7)
          Caught	2018-08-16 11:39:15.668	error	by controller[1]: at _handle.close (net.js:509:12)
          Caught	2018-08-16 11:39:15.668	error	by controller[1]: at TLSSocket.emit (events.js:188:7)
          Caught	2018-08-16 11:39:15.668	error	by controller[1]: at emitOne (events.js:101:20)
          Caught	2018-08-16 11:39:15.667	error	by controller[1]: at TLSSocket.socketCloseListener (_http_client.js:290:9)
          Caught	2018-08-16 11:39:15.667	error	by controller[1]: at ClientRequest.emit (events.js:188:7)
          Caught	2018-08-16 11:39:15.667	error	by controller[1]: at emitOne (events.js:96:13)
          Caught	2018-08-16 11:39:15.667	error	by controller[1]: at ClientRequest. <anonymous>(/opt/iobroker/node_modules/alexa-remote2/alexa-remote.js:377:24)
          Caught	2018-08-16 11:39:15.667	error	by controller[1]: at /opt/iobroker/node_modules/alexa-remote2/alexa-remote.js:392:16
          Caught	2018-08-16 11:39:15.667	error	by controller[1]: at /opt/iobroker/node_modules/alexa-remote2/alexa-remote.js:283:52
          Caught	2018-08-16 11:39:15.667	error	by controller[1]: TypeError: Cannot read property 'password' of undefined
          Caught	2018-08-16 11:39:15.666	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
          Caught	2018-08-16 11:39:15.666	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:80:11)
          Caught	2018-08-16 11:39:15.666	error	by controller[0]: at emitErrorNT (net.js:1290:8)
          Caught	2018-08-16 11:39:15.666	error	by controller[0]: at TLSSocket.emit (events.js:188:7)
          Caught	2018-08-16 11:39:15.666	error	by controller[0]: at emitOne (events.js:96:13)
          Caught	2018-08-16 11:39:15.666	error	by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:314:9)
          Caught	2018-08-16 11:39:15.666	error	by controller[0]: at ClientRequest.emit (events.js:188:7)
          Caught	2018-08-16 11:39:15.665	error	by controller[0]: at emitOne (events.js:96:13)
          Caught	2018-08-16 11:39:15.665	error	by controller[0]: at ClientRequest. <anonymous>(/opt/iobroker/node_modules/alexa-remote2/alexa-remote.js:377:24)
          Caught	2018-08-16 11:39:15.665	error	by controller[0]: at /opt/iobroker/node_modules/alexa-remote2/alexa-remote.js:392:16
          Caught	2018-08-16 11:39:15.664	error	by controller[0]: at /opt/iobroker/node_modules/alexa-remote2/alexa-remote.js:283:52
          Caught	2018-08-16 11:39:15.659	error	by controller[0]: TypeError: Cannot read property 'password' of undefined</anonymous></anonymous></anonymous>
          Da ich jetzt gelesen habe, dass die Version 0.4 wohl auch noch nicht richtig läuft … Soll ich lieber noch auf ein weiteres Update warten, oder schon das Update auf 0.4 machen?
            apollon77 last edited by
            @eve11:
            Node.js: v6.12.2
            NPM: 3.10.10
            eve11 `
            Tja, scheinbar hat Alexa die Volume Änderung nicht akzeptiert weil Sie im Event den Wert 50 zurückliefert …
            Kannst Du per Alexa-App eine Routine anlegen die für dieses Device die Lautstärke ändert und tut das? Wenn ja bitte Routine lassen und Debug log vom Adapterstart (komplett und aus dem Logfile unter /opt/iobroker/log/ senden als PN oder so.
              @Apropo:
              Da ich jetzt gelesen habe, dass die Version 0.4 wohl auch noch nicht richtig läuft … Soll ich lieber noch auf ein weiteres Update warten, oder schon das Update auf 0.4 machen? `
              Meldung im Log ist das eine … Läuft es denn wieder? Der Fehler kommt bei der Erneuerung des Cookies, aber der Adapter sollte automatisch neu starten und dann ist wieder alles gut.
              Versionstechnisch am besten auf 0.5 warten (heute abend oder morgen)
                Ja, soweit ich sehen kann läuft es wieder. Dann warte ich mit dem Update mal noch.
                Danke dir
                  @apollon77: Ja, die Routine funktioniert wenn ich sie im Adapter mittels Push button auslöse. Die Lautstärke wird verändert.
                  Das Log habe ich per PN geschickt.
                  eve11
                    mellus last edited by
                    Ich komme leider nicht klar. Auch die manuelle Ermittlung der Cookie Variante klappt nicht, da die Url aus dem Log nicht aufgerufen wird. Anbei die LogDatei.
                      Scroll mal auf dieser Forum-Thread-Seite (nein du musst nicht mal die Seite wechseln) nach fast ganz oben …
                        oh … danke. Peinlich :oops:
                          smarti2015 last edited by
                          Hm seit zwei Tagen geht der Adapter nicht mehr, Alex bleibt stumm. Ich glaub seit der 0.4 Version. Ist da was bekannt?
                            Blätter mal eine Seite zurück
                              So liebe lexa Freunde,
                              Version 0.5.0 ist erstmal auf Github verfügbar. Bitte testen uns Feedback geben damit ich es dann wenn ok auf npm schieben kann.
                              Changelog 0.5.0:
                              • Viele kleine Verbesserungen und Bugfixes
                              • Fehler beim Holen eines neuen Cookies behoben
                              • Alle Music-Provider haben jetzt noch einen "Playlist" stat um Playlisten einfacher anzusprechen
                              • Unterstützung für "Reminder" und "Alarme" (Wecker) hinzugefügt. Alle existierenden Reminder/Alarme werden angelegt und können aktiviert/deaktiviert werden und die Zeit geändert werden. Weiterhin ein State der auf true gesetzt wird wenn der Wecker/Reminder getriggert wird … geht aber nur wenn Echo und ioBroker-Server-Zeit zusammenpassen weil der Adapter sich die Zeit raussucht und dann selbst auslöst ... bei Zeitunterschieden kommt da also müll raus. Geht aber gerade nicht anders weil es keinen Trigger gibt. Beim Anlegen von neuen Weckern/Remindern per App oder Sprache werden die States passend angelegt, beim löschen wieder gelöscht. Timer habe ich nicht hinbekommen. Als Werte bei Weckern eine Uhrzeit angeben (z.B. "10:00:00"), bei Remindern kann auch der text danach mit Komma getrennt angegeben werden ("10:00:00, Test").
                              Viel Spass.
                                installiert…........... 🙂
                                  masc1249 last edited by
                                  Hey,
                                  vielen Dank für diesen wahnsinns Adapter 😄 !!
                                  Habe ihn erst vor ein paar Tagen entdeckt und direkt installiert (Vers. 0.4), hatte allerdings auch den Fehler beim Cookie holen.
                                  Als ich mich eben nochmal damit beschäftigt habe, fiel mir auf dass es auf einmal eine neue Version gibt 8-) !
                                  Mit Version 0.5.0 läuft nun alles! Super Arbeit.
                                  Push funktioniert auch.
                                  Falls dennoch Fehler auftreten melde ich mich <emoji seq="1f609">😉</emoji>
                                  Edit: Hab gerade gemerkt, dass Reminder neu anlegen nicht funktioniert. Habe folgendes eingegeben "10:00:00, Test", doch bis auf dass sich das Feld leert und die anderen Felder aktualisiert werden (ohne Änderung) passiert nichts. Füge ich per Alexa einen neuen Reminder hinzu wird dieser allerdings angelegt.
                                    @masc1249:
                                    Edit: Hab gerade gemerkt, dass Reminder neu anlegen nicht funktioniert. Habe folgendes eingegeben "10:00:00, Test", doch bis auf dass sich das Feld leert und die anderen Felder aktualisiert werden (ohne Änderung) passiert nichts. Füge ich per Alexa einen neuen Reminder hinzu wird dieser allerdings angelegt. `
                                    Bitte leg mal ein Github issue an.
                                    Die Thematik ist: Eine Zeitangabe am gleichen Tag später als jetzt und es geht. Also 23:30:00 oder so.
                                    Bei einer Zeitangabe kleiner als die aktuelle Zeit entsteht noch ein Zeitpunkt in der Vergangenheit 😞 Muss ich fixen
                                      Erinnerung geht bei mir,….....
                                        @apollon77:
                                        @masc1249:
                                        Bei einer Zeitangabe kleiner als die aktuelle Zeit entsteht noch ein Zeitpunkt in der Vergangenheit 😞 Muss ich fixen `
                                        Ok, 0.5.1 auf Github sollte das fixen
                                        • N
                                          Nikoxx last edited by
                                          Guten Morgen,
                                          Version 0.5.1 funktioniert soweit super, nur leider funktioniert mein "speak" Datenpunkt immer noch nicht.
                                          Log sagt folgendes:
                                          alexa2.0	2018-08-17 08:14:07.322	debug	Alexa-Remote: No authentication check needed (time elapsed 27145)
                                          alexa2.0	2018-08-17 08:14:07.322	warn	Device-type:A21Z3CGI8UIP0F (AUDIO_PLAYER,AMAZON_MUSIC,PANDORA,CHANGE_NAME,REMINDERS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,I_HEART_RADIO,VOLUME_SETTING,TUNE_IN,LAMBDA_DOWNCHANNEL,PEONY)
                                          alexa2.0	2018-08-17 08:14:07.322	warn	Disabling some commands for device because of unknown type. Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                                          alexa2.0	2018-08-17 08:14:07.319	debug	Alexa-Remote: Response: {"devices":[{"accountName":"Nikolais Fire","appDeviceList":[],"capabilities":["ASX_TIME_ZONE","ASCENDING_ALARM_VOLUME","SUPPORTS_SOFTWARE_VERSION","REMINDERS","VOLUME_SETTING",
                                          alexa2.0	2018-08-17 08:14:06.125	debug	State changed alexa2.0.Echo-Devices.G2A0QU068215011M.Player.mediaProgressStr: {"val":"20:53","ack":true,"ts":1534486446108,"q":0,"from":"system.adapter.alexa2.0","lc":1534486446108}
                                          alexa2.0	2018-08-17 08:14:06.110	debug	State changed alexa2.0.Echo-Devices.G2A0QU068215011M.Player.mediaProgress: {"val":1253,"ack":true,"ts":1534486446101,"q":0,"from":"system.adapter.alexa2.0","lc":1534486446101}
                                          alexa2.0	2018-08-17 08:14:06.102	debug	State changed alexa2.0.Echo-Devices.G2A0QU068215011M.Player.mediaProgressPercent: {"val":0,"ack":true,"ts":1534486446092,"q":0,"from":"system.adapter.alexa2.0","lc":1534460338902}
                                          alexa2.0	2018-08-17 08:14:06.016	debug	Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/devices-v2/device?cached=true&_=1534486446006","method":"GET","timeout":10000,"headers":{}}
                                          alexa2.0	2018-08-17 08:14:06.015	debug	Alexa-Remote: No authentication check needed (time elapsed 25861)
                                          alexa2.0	2018-08-17 08:14:04.120	debug	State changed alexa2.0.Echo-Devices.G2A0QU068215011M.Player.mediaProgressStr: {"val":"20:51","ack":true,"ts":1534486444105,"q":0,"from":"system.adapter.alexa2.0","lc":1534486444105}
                                          alexa2.0	2018-08-17 08:14:04.107	debug	State changed alexa2.0.Echo-Devices.G2A0QU068215011M.Player.mediaProgress: {"val":1251,"ack":true,"ts":1534486444098,"q":0,"from":"system.adapter.alexa2.0","lc":1534486444098}
                                          alexa2.0	2018-08-17 08:14:04.099	debug	State changed alexa2.0.Echo-Devices.G2A0QU068215011M.Player.mediaProgressPercent: {"val":0,"ack":true,"ts":1534486444090,"q":0,"from":"system.adapter.alexa2.0","lc":1534460338902}
                                          alexa2.0	2018-08-17 08:14:03.005	debug	Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/behaviors/preview","method":"POST","timeout":10000,"headers":{}}and data={"behaviorId":"PREVIEW","sequenceJson":"{\"@type\":\"
                                          alexa2.0	2018-08-17 08:14:03.005	debug	Alexa-Remote: No authentication check needed (time elapsed 22849)
                                          alexa2.0	2018-08-17 08:14:03.004	debug	State changed alexa2.0.Echo-Devices.G2A0QU068215011M.Commands.speak: {"val":"guten morgen","ack":false,"ts":1534486442979,"q":0,"from":"system.adapter.admin.0","lc":1534484116883}
                                          mfg Niko
                                            Naja die korrekte Aussage wäre "der speak State ist weg" oder ?!
                                            Was ist das denn für ein Gerät?
                                            Langsam fange ich an Amazon zu hassen bzw bin am überlegen ob unbekannte Device-Typen nicht einfach erstmal alles bekommen und nur wenn einer meldet das was nicht geht man es aussortiert …
                                            618
                                            153397
