    4. Modbus adapter
    Modbus adapter
    • smartboart
      smartboart last edited by
      Hallo, ich habe heute mein Raspy heruntergefahren und wieder hoch gefahren, seit dem meldet der Modbusadapter folgende Fehler..
      Hat jemand ne Idee?
      Habe nichts an den Einstellungen geändert…
      modbus.0	2018-08-11 19:23:32.092	debug	Cleaning up request fifo.
      modbus.0	2018-08-11 19:23:32.091	debug	Clearing timeout of the current request.
      modbus.0	2018-08-11 19:23:32.079	info	Disconnected from slave
      modbus.0	2018-08-11 19:23:31.081	warn	Poll error count: 41 code: {"err":"timeout"}
      modbus.0	2018-08-11 19:23:31.081	error	Request timed out.
      modbus.0	2018-08-11 19:23:31.080	warn	Error: undefined
      modbus.0	2018-08-11 19:23:26.085	debug	Poll holdingRegs DevID(1) address 8200 - 46 bytes
      modbus.0	2018-08-11 19:23:26.085	debug	Poll device 1
      modbus.0	2018-08-11 19:23:26.083	info	Connected to slave
      modbus.0	2018-08-11 19:23:26.065	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0	2018-08-11 19:23:20.067	debug	Cleaning up request fifo.
      modbus.0	2018-08-11 19:23:20.066	debug	Clearing timeout of the current request.
      modbus.0	2018-08-11 19:23:20.061	info	Disconnected from slave
      modbus.0	2018-08-11 19:23:19.069	warn	Poll error count: 40 code: {"err":"timeout"}
      modbus.0	2018-08-11 19:23:19.069	error	Request timed out.
      modbus.0	2018-08-11 19:23:19.068	warn	Error: undefined
      modbus.0	2018-08-11 19:23:14.070	debug	Poll holdingRegs DevID(1) address 8200 - 46 bytes
      modbus.0	2018-08-11 19:23:14.070	debug	Poll device 1
      modbus.0	2018-08-11 19:23:14.068	info	Connected to slave
      modbus.0	2018-08-11 19:23:14.045	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0	2018-08-11 19:23:08.046	debug	Cleaning up request fifo.
      modbus.0	2018-08-11 19:23:08.044	debug	Clearing timeout of the current request.
      modbus.0	2018-08-11 19:23:08.039	info	Disconnected from slave
      modbus.0	2018-08-11 19:23:07.042	warn	Poll error count: 39 code: {"err":"timeout"}
      modbus.0	2018-08-11 19:23:07.042	error	Request timed out.
      modbus.0	2018-08-11 19:23:07.041	warn	Error: undefined
      modbus.0	2018-08-11 19:23:02.046	debug	Poll holdingRegs DevID(1) address 8200 - 46 bytes
      modbus.0	2018-08-11 19:23:02.046	debug	Poll device 1
      modbus.0	2018-08-11 19:23:02.044	info	Connected to slave
      modbus.0	2018-08-11 19:23:02.021	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0	2018-08-11 19:22:56.022	debug	Cleaning up request fifo.
      modbus.0	2018-08-11 19:22:56.021	debug	Clearing timeout of the current request.
      modbus.0	2018-08-11 19:22:56.016	info	Disconnected from slave
      modbus.0	2018-08-11 19:22:55.019	warn	Poll error count: 38 code: {"err":"timeout"}
      modbus.0	2018-08-11 19:22:55.019	error	Request timed out.
      modbus.0	2018-08-11 19:22:55.017	warn	Error: undefined
      modbus.0	2018-08-11 19:22:50.026	debug	Poll holdingRegs DevID(1) address 8200 - 46 bytes
      modbus.0	2018-08-11 19:22:50.025	debug	Poll device 1
      modbus.0	2018-08-11 19:22:50.024	info	Connected to slave
      modbus.0	2018-08-11 19:22:50.001	debug	connect to serial /dev/ttyUSB0 with 9600
      modbus.0	2018-08-11 19:22:44.001	debug	Cleaning up request fifo.
      modbus.0	2018-08-11 19:22:44.000	debug	Clearing timeout of the current request.
      modbus.0	2018-08-11 19:22:43.993	info	Disconnected from slave
      modbus.0	2018-08-11 19:22:43.009	warn	Poll error count: 37 code: {"err":"timeout"}
      modbus.0	2018-08-11 19:22:43.008	error	Request timed out.
      modbus.0	2018-08-11 19:22:43.007	warn	Error: undefined
      modbus.0	2018-08-11 19:22:38.065	debug	Poll holdingRegs DevID(1) address 8200 - 46 bytes
      modbus.0	2018-08-11 19:22:38.065	debug	Poll device 1
      modbus.0	2018-08-11 19:22:38.064	info	Connected to slave
      modbus.0	2018-08-11 19:22:37.979	debug	connect to serial /dev/ttyUSB0 with 9600
      • smartboart
        Hat sich erledigt….Der USB to RS485 Adapter ist defekt....Hatte einen anderen ausprobiert, welcher jetzt wieder funktioniert...
        • Jensen
          Jensen last edited by
          Hallo Modbus-Fans, ich bin ein wenig am Verzweifeln.
          Ich versuche eine laufende Installation von einer VM auf einen realen W10 Rechner zu duplizieren.
          Beim Einrichten der Instanz modbus.1 komme ich nicht weiter, obwohl alles so konfiguriert wurde, wie auf der VM.
          Was bedeutet die Meldung im Anhang?
          Wo kann ich noch nach Problemen suchen?
          Wozu dient die neue Eingabe Start Addresse, die gab's bei 1.1.0 noch nicht.
          Bin für jeden Tip dankbar.
          Gruß Jens
          • Jensen
            Entwarnung, habe Version 2.0.7 von GitHub installiert und die Instanz nochmal ganz neu eingerichtet.
            Nun hat's auf Anhieb geklappt.
            Keine Ahnung, was ich wieder falsch gemacht habe.
              sivroglou last edited by
              Hallo Leute,
              ich habe seit einiger Zeit angefangen mit iobroker zu arbeiten.
              Konkret mit Beckhoff (CX8090 und Modbus)
              Bis gestern hatte ich auch alles im Griff, bis ich den iobroker mit den Modbus Adapter auf den neusten Stand gebracht habe.
              Seitdem bekomme ich die folgende Fehlermeldung:
              Verbunden mit Host: Wahr
              Lebenszeichen : Wahr
              Verbunden mit Modbus: Falsch
              In der Log steht immer folgendes:
              modbus.0 2018-08-16 18:49:28.336 info Disconnected from slave 192.168.178.25
              modbus.0 2018-08-16 18:49:28.333 info Connected to slave 192.168.178.2
              kann mir jemand von den Experten hier sagen wo ich anfangen soll zu suchen?
              Vielen Dank schon Mal!
              • Jensen
                Zu den Experten gehöre ich nicht, aber so sah' das bei mir auch aus, als ich noch keine Ausgänge oder Register konfiguriert hatte.
                Nachdem was konfiguriert war, verschwanden diese Meldungen.
                Gruß Jens
                  Vielen Dank Jens für die schnelle Antwort.
                  Tatsächlich war, dass der Fehler der mich in die Irre geführt hat, da keine Eingänge und Ausgänge merh konfiguriert waren.
                  Jetzt habe ich noch eine Frage.
                  Ich habe die Programmierung auf der SPS schon seit einiger Zeit, sie funktioniert auch so wie ich das haben will.
                  Wenn ich beim Iobroker einen Taster in der Visualisierung platziere und ihn betätige, kommt das Signal in der SPS erst an wenn ich vom Taster gehe und zwar für die eingestelle Zeit "Pulstime" vom Adapter Modbus.
                  Es muss sicherlich möglich sein, dass ein Taster in der Visu sich auch wie ein Taster bei der SPS verhält.
                  Sprich ich betätige den Taster in der Visu und so lange ich drauf bleibe kommt auch das Signal TRUE an der SPS an, sobald ich nicht mehr den Taster betätige geht das Signal auf FALSE.
                  Vielen Dank
                  • Jensen
                    Das ist bei mir auch so, habe ich soeben durch Versuch festgestellt.
                    Hatte mir darüber noch gar keine Gedanken gemacht. Das bedeutet, alles was ich über 'Tastendruck lang' in der SPS programmiert habe, funktioniert über die ioBroker-Visu nicht.
                    Nachdem ich mir das nun noch mal alles angeschaut habe (ist schon lange her, daß ich das programmiert habe), ist meine Theorie wie folgt:
                    In der Wago-Visu kann man die Taster unterschiedlich programmieren, Wert toggeln oder Wert tasten. Diese Möglichkeit habe ich in der ioBroker-Visu noch bei keinem Widget gefunden. Somit scheinen mir die Widgets, die man zum Licht schalten so verwendet, alle als Schalter programmiert zu sein. Erst die Logik in der SPS macht es möglich, daß das Ganze halbwegs funktioniert. Dort benutze ich für die Hardware- und WagoVisu-Taster einen Baustein aus der OscatLib (FbKurzLang), dessen Ergebnis dann zusammen mit dem Merker-Flag (was die ioBrokerVisu schaltet) in einem weiteren Baustein (auch aus irgendeinem Forum) verarbeitet wird. Das Merker-Flag stellt letztlich auch den Zustand der entsprechenden Lampe dar.
                    Sicherlich wäre es für die Experten möglich, ein Widget als reinen Taster zu programmieren, aber ich glaube durch die ganzen Poll und Delay Zeiten wird das über Modbus nicht funktionieren. Außerdem bräuchte man ein zweites Flag (Object), welches dann den Zustand (vom Licht) darstellt.
                    Zurück zu deiner Frage, ja, das Signal kommt in der SPS an, wenn du vom Taster gehst, offensichtlich ist MouseUp der Trigger zum Umschalten. Allerdings was du mit "für die eingestellte Zeit 'Pulstime'" meinst, verstehe ich nicht. Das Flag müßte doch solange den Zustand behalten, bis es wieder jemand aktiv umsetzt?
                    Gruß Jens
                    der Licht Baustein stammt übrigens von hier:
                    viewtopic.php?t=7943
                      Hey Jens,
                      danke nochmals für die schnelle Antwort.
                      Ja ich will jetzt ungern in meine bestehende Programmierung anfangen etwas zu verändern.
                      Ich will, dass immer noch die SPS entscheidet ob ein gewisser Ausgang geschaltet werden darf oder nicht.
                      Ich habe es so programmiert, dass z.B die Jaloousie bei mir nur mit bestimmten Voraussetzungen verfahren darf.
                      Dazu gehört unter anderem, Bsp. wenn der "Taster_WZ kürzer als 2sec. betätigt wird fährt die Jalousie auf Handmodus besser gesagt sie fährt nur so lange der Taster_WZ betätigt ist.
                      Wird der Taster_WZ länger als 2 sec. betätigt schaltet die Jalousie auf Automatikmodus und man braucht nicht mehr den Taster betätigen damit die Jalousie auf ihre Endlage fährt."
                      Diesen FB habe ich indivisuell für mich erstellt und ist mit weiteren Voraussetzungen geknüpft.
                      In diese Richtung bewegt sich der Rest meiner Programmierung. Mit Sicherheit kann man das anderes in der SPS programmieren, da will ich aber jetzt nicht anfagen Sachen umzuprogrammieren damit es für Iobroker i.O ist.
                      Ich habe leider noch keine Erfahrungen mit "Skripte/CSS" gemacht bestimmt lässt sich da so ein Taster ohne Weiteres programmieren.
                      Ich wäre über weitere Antworten sehr dankbar 😄 😄 😄 Vielleicht sind hier Leute mit der selben Problematik.
                      • Jensen
                        Sollten wir vielleicht ein neues Thema anfangen?
                        z.Bsp.: Wago und ioBroker
                        Denn zum Thema Jalousien fallen mir sofort viele Fragen ein.
                          Wäre sofort dabei, ich glaube allgemein in Sachen Modbus und SPS in Kombination mit iobroker sind sehr viele Fragen offen.
                          • wendy2702
                            wendy2702 last edited by
                            Zum Thema Modbus - Wago gibt es aber auch schon Themen.
                            Ist das vielleicht schon etwas dabei?
                            search.php?keywords=Wago
                              Ich habe nicht alles durchgelesen aber gefunden habe ich nichts zu diesem Thema mit dem Taster.
                              • Jensen
                                hier
                                viewtopic.php?f=37&t=7943&p=83578&hilit … ter#p83578
                                gibt's ein Script, das könnte auch was für deinen Taster sein.
                                • Mr. Burns
                                  Mr. Burns last edited by
                                  ich habe nach der Aktualisierung des Adapters in unregelmäßigen Abständen Abstürze bzw. Fehlermeldungen im Log. Ist das bereits bekannt?
                                  Der Adapter läßt sich nach wie vor bedienen.
                                  Der Adapter ist wirklich toll. Funktioniert schnell und sehr stabil. Was man von manchen kommerziellen OPC Servern wirklich nicht behaupten kann.
                                  Hab den Debuglog mal eingeschaltet. Bei Interesse kann ich den gerne zur Verfügung stellen.
                                  Thomas
                                    Marc_St last edited by
                                    Ich habe heute festgestellt, dass der Adapter jedenfalls in v 2.0.9 reproduzierbar abstürzt, wenn negative Werte via "Eingangsregister" geschrieben werde sollen. ich übertrage so etwa die Außentemperatur an meine UVR1611. Das Problem lässt sich einfach reproduzieren, indem irgendein Wert per Offset ins Negative gezogen wird. Das Log sieht so aus:
                                    ` > host.tinkerboard 2018-11-03 17:03:44.681 error instance system.adapter.modbus.0 terminated with code 6 (uncaught exception)
                                    Caught 2018-11-03 17:03:44.681 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                    Caught 2018-11-03 17:03:44.681 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                    Caught 2018-11-03 17:03:44.680 error by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                    Caught 2018-11-03 17:03:44.680 error by controller[0]: at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4632:61)
                                    Caught 2018-11-03 17:03:44.680 error by controller[0]: at adapter.getStates (/opt/iobroker/node_modules/iobroker.modbus/lib/slave.js:387:18)
                                    Caught 2018-11-03 17:03:44.680 error by controller[0]: at Slave._initValues (/opt/iobroker/node_modules/iobroker.modbus/lib/slave.js:362:22)
                                    Caught 2018-11-03 17:03:44.679 error by controller[0]: at Slave.write (/opt/iobroker/node_modules/iobroker.modbus/lib/slave.js:89:29)
                                    Caught 2018-11-03 17:03:44.679 error by controller[0]: at Object.writeValue (/opt/iobroker/node_modules/iobroker.modbus/lib/common.js:168:20)
                                    Caught 2018-11-03 17:03:44.679 error by controller[0]: at Buffer.writeUInt16BE (buffer.js:1254:5)
                                    Caught 2018-11-03 17:03:44.679 error by controller[0]: at checkInt (buffer.js:1185:11)
                                    Caught 2018-11-03 17:03:44.678 error by controller[0]: TypeError: "value" argument is out of bounds
                                    modbus.0 2018-11-03 17:03:43.617 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                                    modbus.0 2018-11-03 17:03:43.617 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                                    modbus.0 2018-11-03 17:03:43.617 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                    modbus.0 2018-11-03 17:03:43.617 error at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4632:61)
                                    modbus.0 2018-11-03 17:03:43.617 error at adapter.getStates (/opt/iobroker/node_modules/iobroker.modbus/lib/slave.js:387:18)
                                    modbus.0 2018-11-03 17:03:43.617 error at Slave._initValues (/opt/iobroker/node_modules/iobroker.modbus/lib/slave.js:362:22)
                                    modbus.0 2018-11-03 17:03:43.617 error at Slave.write (/opt/iobroker/node_modules/iobroker.modbus/lib/slave.js:89:29)
                                    modbus.0 2018-11-03 17:03:43.617 error at Object.writeValue (/opt/iobroker/node_modules/iobroker.modbus/lib/common.js:168:20)
                                    modbus.0 2018-11-03 17:03:43.617 error at Buffer.writeUInt16BE (buffer.js:1254:5)
                                    modbus.0 2018-11-03 17:03:43.617 error at checkInt (buffer.js:1185:11)
                                    modbus.0 2018-11-03 17:03:43.617 error TypeError: "value" argument is out of bounds
                                    modbus.0 2018-11-03 17:03:43.616 error uncaught exception: "value" argument is out of bounds</anonymous></anonymous> `
                                      sol21 last edited by
                                      Ich habe die gleichen Meldungen wie Mr. Burns.
                                      Ich vermute bis jetzt, dass das Problem auf der Cient Seite liegt und sich mein Solaredge Wechselrichter für einige Zeit vom Bus verabschiedet.
                                      @Mr. Burns: was für ein Gerät ist angeschlossen? Wechselrichter von Solaredge?
                                        Teamgeist610 last edited by
                                        ich versuche zur Zeit meine Vallox Lüftungsanlage mit dem Modbus Adapter abzufragen (Modbus RTU). Leider gelingt mir das nur zum Teil. Wenn ich den Adapter starte, bekomme ich ca. 10-15 Minuten Werte geliefert. Danach disconnected sich der Adapter und versucht danach erfolglos wieder eine Verbindung aufzubauen. Anbei das Log:
                                        modbus.0 2018-11-12 21:40:59.402 info Disconnected from slave
                                        modbus.0 2018-11-12 21:40:58.404 warn Poll error count: 2 code: {"err":"timeout"}
                                        modbus.0 2018-11-12 21:40:58.404 error Request timed out.
                                        modbus.0 2018-11-12 21:40:58.403 warn Error: undefined
                                        modbus.0 2018-11-12 21:40:48.388 info Connected to slave
                                        modbus.0 2018-11-12 21:39:48.198 info Disconnected from slave
                                        modbus.0 2018-11-12 21:39:47.197 warn Poll error count: 1 code: {"err":"timeout"}
                                        modbus.0 2018-11-12 21:39:47.196 error Request timed out.
                                        modbus.0 2018-11-12 21:39:47.192 warn Error: undefined
                                        modbus.0 2018-11-12 21:30:13.981 info Connected to slave
                                        modbus.0 2018-11-12 21:30:13.547 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.12.0
                                        IOBroker läuft auf einem Debian, welches mittels Virtual Box auf einem Windows 10 visualisiert ist. Die Lüftungsanlage ist via RS485 USB Adapter angeschlossen.
                                        Hat jemand eine Idee warum es zu den Verbindungsabbrüchen kommt?
                                        Bis jetzt konnte ich immer die passende Antworten für meine ioBroker Projekte im Forum finden (Bis jetzt 😉 ). Ich habe schon gefühlt mit sämtliche Einstellungen ausprobiert, leider ohne Erfolg.
                                        • I
                                          IchBinsDoch last edited by
                                          ich habe exakt die gleichen Fehler wie Teamgeist610 beschrieben hat.
                                          Mitlerweile connected der Adapter überhaupt nicht mehr.
                                          Neuinstallation brachte auch nichts.
                                          • I
                                            iLOVEioBROKER last edited by
                                            @Teamgeist610:
                                            Bis jetzt konnte ich immer die passende Antworten für meine ioBroker Projekte im Forum finden (Bis jetzt 😉 ). Ich habe schon gefühlt mit sämtliche Einstellungen ausprobiert, leider ohne Erfolg. `
                                            konnten ihr zu dem Fehler schon was raus finden? Ich habe den gleichen Fehler. Bei mir läuft der Adapter nach einem Neustart ca. einen halben Tag ohne Probleme und dann bekomme ich immer die "Request timed out"-Fehler. Nach einem Neustart funktioniert wieder alles.
                                            Danke euch!
                                            Viele Grüße
                                            Michael
                                            modbus modbus adapter
                                            140
                                            978
                                            369170
