    4. [Aufruf] ioBroker.ham (Homebridge Accessory Manager) testen
      A Former User last edited by
      > Naja, dann zuerst mal ins Log schauen. Was steht da? Steht da was wenn Du die Instanz startest?
      So habe den Adapter nochmal gestartet und folgenden Log erhalten…
      2018-08-22 19:42:47.230 - error: ham.0 uncaught exception: listen EADDRINUSE :::8087
      2018-08-22 19:42:47.421 - error: Caught by controller[0]: [2018-8-22 19:42:45] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
      2018-08-22 19:42:47.421 - error: Caught by controller[1]: [2018-8-22 19:42:45] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: { Error: listen EADDRINUSE :::8087
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at Object._errnoException (util.js:992:11)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at _exceptionWithHostPort (util.js:1014:20)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at Server.setupListenHandle [as _listen2] (net.js:1355:14)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at listenInCluster (net.js:1396:12)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at Server.listen (net.js:1480:7)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at new NotificationListener (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-homewizard/dist/notificationListener.js:58:8)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at new HomeWizardPlatform (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-homewizard/dist/platform.js:61:21)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at Server._loadPlatforms (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:326:32)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:86:36)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:215:17)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:111:23)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:229:35)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:175:27)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2434:25)
      2018-08-22 19:42:47.422 - error: Caught by controller[2]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
      2018-08-22 19:42:47.423 - error: Caught by controller[2]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
      2018-08-22 19:42:47.423 - error: Caught by controller[2]: code: 'EADDRINUSE',
      2018-08-22 19:42:47.423 - error: Caught by controller[2]: errno: 'EADDRINUSE',
      2018-08-22 19:42:47.423 - error: Caught by controller[2]: syscall: 'listen',
      2018-08-22 19:42:47.423 - error: Caught by controller[2]: address: '::',
      2018-08-22 19:42:47.423 - error: Caught by controller[2]: port: 8087 }
      2018-08-22 19:42:47.423 - error: host.ioBroker instance system.adapter.ham.0 terminated with code 0 (OK)
      2018-08-22 19:42:47.423 - info: host.ioBroker Restart adapter system.adapter.ham.0 because enabled
        apollon77 last edited by
        Jetzt liegt es daran das das homebridge Plugin scheinbar Port 8087 belegen will dieser aber schon belegt ist.
        Entweder ändern falls das geht oder local den prozesss auf dem Port wegmachen (socket.io?!)
        Gesendet vom Handy …
          ` > Jetzt liegt es daran das das homebridge Plugin scheinbar Port 8087 belegen will dieser aber schon belegt ist.
          Entweder ändern falls das geht oder local den prozesss auf dem Port wegmachen (socket.io?!) `
          Noch ein Tipp wie ich das anstelle :shock:
          Danke das du dir das Problem so schnell angeschaut hast…
            > "pushServer": {"http": 8087, "udp": 33333, "period": 5}
            Das ist ja das was ich aus dem Beispiel kopiert habe. Reicht es dort den Port zu ändern? Wenn ja welchen?
              Klingt sinnvoll. Ob es dann aber noch tut hab ch keine Ahnung. Ich kenne das Plugin und auch homeWizard nicht.
                Manchmal ist die Lösung so einfach 😄 Habe den Port auf 8090 geändert und schon lief die Kiste. Danke für deine Hilfe…
                  Kochenmitmusik last edited by
                  kann mir mal eine behilflich sein wie ich dieses Plugin (AppleTV) : https://www.npmjs.com/package/homebridge-theater-mode installiere?
                  Mein Wemo Plugin läuft:
                    "description": "Add configuration for your accessories or platforms according to the docs of the plugins.",
                    "accessories": [],
                    "platforms": [
                        "platform": "BelkinWeMo",
                        "name": "WeMo Platform"
                  Danke.
                    Ich bin jetzt mal böse und sage: nach der Anleitung des Plugins?!
                    Du trägst im HAM-Adapter den namen des Plugins in die Liste der Plugins ein und startest den Adapter neu.
                    Dann folgst Du dem was unter https://www.npmjs.com/package/homebridg … de#pairing und dem folgenden Abschnitt steht
                      Erhalte beim Pairing folgende Fehler:
                      <code>pi@ioBroker-Pi:~ $ sudo npm install -g node-appletv
                      > sodium@2.0.3 preinstall /usr/lib/node_modules/node-appletv/node_modules/sodium
                      > node install.js --preinstall
                      Static libsodium was not found at /usr/lib/node_modules/node-appletv/node_modules/sodium/deps/build/lib/libsodium so compiling libsodium from source.
                      libtool is required, but wasn't found on this system
                      Makefile:61: die Regel für Ziel „libsodium“ scheiterte
                      make: *** [libsodium] Fehler 1
                      /usr/lib/node_modules/node-appletv/node_modules/sodium/install.js:287
                                  throw new Error(cmdLine + ' exited with code ' + code);
                      Error: make libsodium exited with code 2
                          at ChildProcess. <anonymous>(/usr/lib/node_modules/node-appletv/node_modules/sodium/install.js:287:19)
                          at emitTwo (events.js:126:13)
                          at ChildProcess.emit (events.js:214:7)
                          at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! sodium@2.0.3 preinstall: `node install.js --preinstall`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the sodium@2.0.3 preinstall script.
                      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      npm ERR!     /root/.npm/_logs/2018-08-24T12_39_20_931Z-debug.log
                      /code]</anonymous></code>
                        Ich entschuldige mich im Vorfeld für die folgenden zeilen:
                        Googling … please wait ...
                        Googling ... please wait ...
                        https://github.com/paixaop/node-sodium/ ... -372206338
                        Wenn die gewünschten Plugins Dinge brauchen und sorry da muss man sich dann mal damit beschäftigen ... und Google ist echt einfach hab ich gehört.
                          Kueppert last edited by
                          Google? Hab gehört, ist böse, soll man nicht benutzen [emoji23]
                            stoepselinho last edited by
                            hallo
                            ich möchte gerne meinen irobot rommba 675 einbinden.
                            wie bekomm ich denn an die erforderlichen Angaben?
                            ` > "platform": "Roomba",
                            "name": "Roomba",
                            "robots": [
                            "name": "Name of the robot in the Home app",
                            "blid":"123456789abcdefg",
                            "password": ":1:2345678901:ABCDEFGHIJKLMNOP",
                            "address": "192.168.x.xx" `
                              Also wenn Du das homebridge-roomba nimmst dann so wie es dort beschrieben ist:
                              https://www.npmjs.com/package/homebridg … stallation ?!
                                Ist das denn eine Anleitung für iobroker?
                                  Im ham Adapter musst du eine valide homebridge Konfiguration eintragen und wie das für dieses Plugin aussehen muss steht auf dieser Seite weilendes hat mit ioBroker nix zu tun. Es geht da um das Plugin.
                                    Bei mir funktioniert es irgendwie nicht. Kann mir da jemand helfen?
                                      Jupp, das homebridge Modul was funds Inder konfig in das Feld für den npm Namen schreibst, heisst nicht Roomba.
                                      Da muss homebridge_roomba oder welches Modul du auch immer nehmen willst rein
                                      • O
                                        OliTheo last edited by
                                        Hallo zusammen.
                                        Ham bei mir installiert sowie homebridge_devolo
                                        Es geht, bis es einen Fehler gibt und die Instanz neu startet.
                                        Hier mal das Problem:
                                        2018-09-24 23:00:26.847 - [32minfo[39m: ham.0 updateState Schalter-Küche.Schalter-Küche-2.Name: value = /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                        2018-09-24 23:00:26.912 - [31merror[39m: ham.0 uncaught exception: Device has no suitable sensor.
                                        2018-09-24 23:00:26.913 - [31merror[39m: ham.0 Error: Device has no suitable sensor.
                                        at Relay2Device.Device.getCurrentValue (/home/pi/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloDevice.js:206:19)
                                        at Array.HBQubinoRelay2Device.getDevoloCurrentConsumption (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/devices/HBQubinoRelay2Device.js:80:44)
                                        at Characteristic.DevoloCurrentConsumption.emit (events.js:180:13)
                                        at Characteristic.DevoloCurrentConsumption.Characteristic.getValue (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/Characteristic.js:163:10)
                                        at registerEventsForCharacteristic (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:128:28)
                                        at WrapperBridge.addBridgedAccessory (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:138:17)
                                        at Server. <anonymous>(/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:399:24)
                                        at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/util/once.js:16:19
                                        at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/index.js:71:17
                                        at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/HBDevoloCentralUnit.js:52:13
                                        2018-09-24 23:00:26.915 - [32minfo[39m: ham.0 cleaned everything up…
                                        2018-09-24 23:00:26.928 - [33mwarn[39m: ham.0 Exception: Error: Device has no suitable sensor.
                                        2018-09-24 23:00:29.581 - [31merror[39m: Caught by controller[0]: [2018-9-24 23:00:13] Plugin /home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                                        2018-09-24 23:00:29.582 - [31merror[39m: Caught by controller[1]: [2018-9-24 23:00:15] Plugin /home/pi/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                                        2018-09-24 23:00:29.583 - [31merror[39m: Caught by controller[2]: [2018-9-24 23:00:15] Warning: skipping plugin found at '/usr/local/lib/node_modules/homebridge-devolo' since we already loaded the same plugin from '/home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo'.
                                        2018-09-24 23:00:29.584 - [31merror[39m: Caught by controller[3]: Error: Device has no suitable sensor.
                                        2018-09-24 23:00:29.584 - [31merror[39m: Caught by controller[3]: at Relay2Device.Device.getCurrentValue (/home/pi/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloDevice.js:206:19)
                                        2018-09-24 23:00:29.585 - [31merror[39m: Caught by controller[3]: at Array.HBQubinoRelay2Device.getDevoloCurrentConsumption (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/devices/HBQubinoRelay2Device.js:80:44)
                                        2018-09-24 23:00:29.585 - [31merror[39m: Caught by controller[3]: at Characteristic.DevoloCurrentConsumption.emit (events.js:180:13)
                                        2018-09-24 23:00:29.586 - [31merror[39m: Caught by controller[3]: at Characteristic.DevoloCurrentConsumption.Characteristic.getValue (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/Characteristic.js:163:10)
                                        2018-09-24 23:00:29.586 - [31merror[39m: Caught by controller[3]: at registerEventsForCharacteristic (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:128:28)
                                        2018-09-24 23:00:29.587 - [31merror[39m: Caught by controller[3]: at WrapperBridge.addBridgedAccessory (/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:138:17)
                                        2018-09-24 23:00:29.587 - [31merror[39m: Caught by controller[3]: at Server. <anonymous>(/home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:399:24)
                                        2018-09-24 23:00:29.587 - [31merror[39m: Caught by controller[3]: at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/hap-nodejs/lib/util/once.js:16:19
                                        2018-09-24 23:00:29.588 - [31merror[39m: Caught by controller[3]: at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/index.js:71:17
                                        2018-09-24 23:00:29.588 - [31merror[39m: Caught by controller[3]: at /home/pi/node_modules/iobroker.ham/node_modules/homebridge-devolo/dist/HBDevoloCentralUnit.js:52:13
                                        2018-09-24 23:00:29.588 - [31merror[39m: host.raspberrypi instance system.adapter.ham.0 terminated with code 6 (uncaught exception)
                                        2018-09-24 23:00:29.589 - [32minfo[39m: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
                                        Hat jemand eine Idee. Evtl. hängt es auch mit der Version von Node ab. Habe Node Version 9.9.0 bekomme kein update hin access Fehler.
                                        Ausserdem habe ich eine 10 version von nodejs
                                        danke für eure Hilfe
                                        Gruss
                                        OliTheo</anonymous></anonymous>
                                          Also erst einmal kommt der Fehler wohl eher aus dem Devolo Modul und wäre daher beim Entwickler davon am besten aufgehoben.
                                          Weiterhin:Was hast Du jetzt node 9.9 oder node 10? Beides ist nicht ideal … 9.9 ist eine Dev-Version die keinen SUpport mehr hat und node 10 hat einiges an Problemen immer noch.
                                          Also node 8 ist die aktuelle Empfehlung ...
                                          • O
                                            so HAM noch einmal installiert und vorher node korrigiert:
                                            folgende Warungen:
                                            1. WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                                            2. WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                            3. WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                            4. WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                            5. npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                            Hat jemand eine Idee wie ich die updaten kan punkt 2-5 und was mit Punkt 1 ist.
                                            Zusätzlich habe ich noch 6) npm notice created a lockfile as package-lock.json. You should commit this file.
                                            Punkt 6 kann ich wohl ignorieren.
                                            Vielen Dank für die Hilfe
                                            Gruss
                                            OliTheo
                                            343
                                            85720
