    4. [Aufruf] Neuer Adapter für den Wiffi-wz, den Weatherman und den Rainyman von Stall.biz bereit zum testen
    • willi5
      willi5 last edited by
      HI,
      ich habe den Ordner Ordner "node_modules/iobroker.wiffi-wz" gelöscht. Der wiffi-wz ist weiterhin vorhanden, es fehlt nur das Löschsymbol.
      Auf der SSD und in der Registry ist wiffi-wz nicht vorhanden.
      • X
        x4tlaoguo last edited by
        Hey, wo genau ist der vorhanden? Ist der unter Adapter oder Instanzen vorhanden?
          Farmer-cb last edited by
          Hallo
          hab mir die Station auch besorgt
          leider kommen bei mir im adapter wiffi-wz keine Daten an
          daten sind im weatherman
          json liefert:
          ! {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.xxx.yy"},{"name":"1","homematic_name":"w_temperature","desc":"aussentemperatur","type":"number","unit":"gradC","value":16.9},{"name":"21","homematic_name":"w_windchill","desc":"gefuehlte_temperatur","type":"number","unit":"gradC","value":16.9},{"name":"9","homematic_name":"w_taupunkt","desc":"taupunkt_temperatur","type":"number","unit":"gradC","value":9.1},{"name":"29","homematic_name":"w_temp_gestern","desc":"temp_m_gestern","type":"number","unit":"gradC","value":0.0},{"name":"14","homematic_name":"w_sky_temp","desc":"himmel_temperatur","type":"number","unit":"gradC","value":0.0},{"name":"2","homematic_name":"w_humidity","desc":"rel_feuchte","type":"number","unit":"%","value":60.0},{"name":"17","homematic_name":"w_hum_abs","desc":"abs_feuchte","type":"number","unit":"g/m3","value":8.6},{"name":"18","homematic_name":"w_rain_activity","desc":"regenmelderwert","type":"number","unit":"","value":6},{"name":"7","homematic_name":"w_rain_status","desc":"regenstatus","type":"boolean","unit":"","value":false},{"name":"8","homematic_name":"w_rain_intensity","desc":"regenstaerke","type":"number","unit":"mm/h","value":0.0},{"name":"19","homematic_name":"w_rain_volume_1","desc":"regen_pro_h","type":"number","unit":"mm","value":0.0},{"name":"20","homematic_name":"w_rain_volume_24","desc":"regen_pro_24h","type":"number","unit":"mm","value":0.0},{"name":"27","homematic_name":"w_rain_yesterday","desc":"regen_gestern","type":"number","unit":"mm","value":0.0},{"name":"3","homematic_name":"w_barometer","desc":"nn_luftdruck","type":"number","unit":"mb","value":1300.00},{"name":"11","homematic_name":"w_barotrend","desc":"luftdrucktrend","type":"string","unit":"","value":"not_valid"},{"name":"4","homematic_name":"w_wind_avg","desc":"avg_windgeschwindigkeit","type":"number","unit":"m/s","value":0.0},{"name":"5","homematic_name":"w_wind_peak","desc":"peak_windgeschwindigkeit","type":"number","unit":"m/s","value":0.0},{"name":"24","homematic_name":"w_windstaerke","desc":"bft_windgeschwindigkeit","type":"number","unit":"bft","value":0},{"name":"23","homematic_name":"w_wind_direction","desc":"windrichtung","type":"string","unit":"","value":"N"},{"name":"6","homematic_name":"w_wind_dir","desc":"windwinkel","type":"number","unit":"grad","value":0},{"name":"10","homematic_name":"w_lux","desc":"helligkeit","type":"number","unit":"lux","value":0.0},{"name":"15","homematic_name":"w_sun_temp","desc":"sonnentemperatur","type":"number","unit":"gradC","value":18.0},{"name":"22","homematic_name":"w_diff_temp","desc":"sonnen_difftemperatur","type":"number","unit":"gradC","value":1.1},{"name":"16","homematic_name":"w_sonne_scheint","desc":"sonne_scheint","type":"boolean","unit":"","value":false},{"name":"26","homematic_name":"w_sonne_heute","desc":"sonne_heute","type":"number","unit":"h","value":0.0},{"name":"28","homematic_name":"w_sonne_gestern","desc":"sonne_gestern","type":"number","unit":"h","value":0.0},{"name":"12","homematic_name":"w_elevation","desc":"sonne_elevation","type":"number","unit":"grad","value":-2.7},{"name":"13","homematic_name":"w_azimut","desc":"sonne_azimut","type":"number","unit":"grad","value":81.5}],"Systeminfo":{"MAC-Adresse":"9:ee:17:22:66:44","Homematic_CCU_ip":"192.168.xxx.yyy","WLAN_ssid":"meine_ssid","WLAN_Signal_dBm":-50,"sec_seit_reset":1960,"zeitpunkt":"2018-08-31 07:42:19","firmware":"weatherman_66"}} !
          denke ich habe den weatherman richtig konfiguriert:
          hab den adapter bereits auf debug, leider kommen aktuell keine aussagekräftige daten an:
          ! 2018-08-31 07:33:00.588 - debug: wiffi-wz.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1535693580586,"q":0,"from":"system.adapter.admin.0","lc":1535693580586} 2018-08-31 07:33:00.590 - debug: wiffi-wz.0 system.adapter.admin.0: logging false 2018-08-31 07:46:16.845 - debug: wiffi-wz.0 redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1535694376844,"q":0,"from":"system.adapter.admin.0","lc":1535694376844} 2018-08-31 07:46:16.846 - debug: wiffi-wz.0 system.adapter.admin.0: logging true !
          ach ja adapter-version 1.2.4
          mir ist gerade noch aufgefallen, das, jedesmal wenn ich den adapter neustarte error-meldung im log auftauchen:
          wiffi-wz.0 2018-08-31 07:56:44.121 info Server listening on 0.0.0.0:8181
          wiffi-wz.0 2018-08-31 07:56:44.121 info Opening local server on 0.0.0.0:8181
          wiffi-wz.0 2018-08-31 07:56:44.120 info Opening socket ...
          wiffi-wz.0 2018-08-31 07:56:44.055 info starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.wiffi-wz, node: v6.14.3
          host.iobroker 2018-08-31 07:56:42.255 info instance system.adapter.wiffi-wz.0 started with pid 820
          host.iobroker 2018-08-31 07:56:39.855 info instance system.adapter.wiffi-wz.0 terminated with code 0 (OK)
          Caught 2018-08-31 07:56:39.854 error by controller[4]: at processImmediate [as _immediateCallback] (timers.js:617:5)
          Caught 2018-08-31 07:56:39.854 error by controller[4]: at tryOnImmediate (timers.js:645:5)
          Caught 2018-08-31 07:56:39.854 error by controller[4]: at runCallback (timers.js:672:20)
          Caught 2018-08-31 07:56:39.853 error by controller[4]: at Immediate._tickCallback (internal/process/next_tick.js:104:9)
          Caught 2018-08-31 07:56:39.853 error by controller[4]: at _combinedTickCallback (internal/process/next_tick.js:77:11)
          Caught 2018-08-31 07:56:39.853 error by controller[4]: at emitCloseNT (net.js:1568:8)
          Caught 2018-08-31 07:56:39.853 error by controller[4]: at Server.emit (events.js:185:7)
          Caught 2018-08-31 07:56:39.852 error by controller[4]: at emitNone (events.js:86:13)
          Caught 2018-08-31 07:56:39.852 error by controller[4]: at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:221:36)
          Caught 2018-08-31 07:56:39.851 error by controller[4]: ReferenceError: sock is not defined
          Caught 2018-08-31 07:56:39.851 error by controller[3]: at process._tickCallback (internal/process/next_tick.js:104:9)
          Caught 2018-08-31 07:56:39.850 error by controller[3]: at _combinedTickCallback (internal/process/next_tick.js:77:11)
          Caught 2018-08-31 07:56:39.849 error by controller[3]: at emitCloseNT (net.js:1568:8)
          Caught 2018-08-31 07:56:39.849 error by controller[3]: at Server.emit (events.js:185:7)
          Caught 2018-08-31 07:56:39.848 error by controller[3]: at emitNone (events.js:86:13)
          Caught 2018-08-31 07:56:39.848 error by controller[3]: at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:221:36)
          Caught 2018-08-31 07:56:39.848 error by controller[3]: ReferenceError: sock is not defined
          Caught 2018-08-31 07:56:39.847 error by controller[2]: at process._tickCallback (internal/process/next_tick.js:104:9)
          Caught 2018-08-31 07:56:39.847 error by controller[2]: at _combinedTickCallback (internal/process/next_tick.js:77:11)
          Caught 2018-08-31 07:56:39.846 error by controller[2]: at emitCloseNT (net.js:1568:8)
          Caught 2018-08-31 07:56:39.846 error by controller[2]: at Server.emit (events.js:185:7)
          Caught 2018-08-31 07:56:39.846 error by controller[2]: at emitNone (events.js:86:13)
          Caught 2018-08-31 07:56:39.845 error by controller[2]: at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:221:36)
          Caught 2018-08-31 07:56:39.845 error by controller[2]: ReferenceError: sock is not defined
          Caught 2018-08-31 07:56:39.845 error by controller[1]: at processImmediate [as _immediateCallback] (timers.js:617:5)
          Caught 2018-08-31 07:56:39.844 error by controller[1]: at tryOnImmediate (timers.js:645:5)
          Caught 2018-08-31 07:56:39.844 error by controller[1]: at runCallback (timers.js:672:20)
          Caught 2018-08-31 07:56:39.844 error by controller[1]: at Immediate._tickCallback (internal/process/next_tick.js:104:9)
          Caught 2018-08-31 07:56:39.843 error by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:77:11)
          Caught 2018-08-31 07:56:39.843 error by controller[1]: at emitCloseNT (net.js:1568:8)
          Caught 2018-08-31 07:56:39.843 error by controller[1]: at Server.emit (events.js:185:7)
          Caught 2018-08-31 07:56:39.842 error by controller[1]: at emitNone (events.js:86:13)
          Caught 2018-08-31 07:56:39.842 error by controller[1]: at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:221:36)
          Caught 2018-08-31 07:56:39.842 error by controller[1]: ReferenceError: sock is not defined
          Caught 2018-08-31 07:56:39.841 error by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
          Caught 2018-08-31 07:56:39.841 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:77:11)
          Caught 2018-08-31 07:56:39.841 error by controller[0]: at emitCloseNT (net.js:1568:8)
          Caught 2018-08-31 07:56:39.840 error by controller[0]: at Server.emit (events.js:185:7)
          Caught 2018-08-31 07:56:39.840 error by controller[0]: at emitNone (events.js:86:13)
          Caught 2018-08-31 07:56:39.840 error by controller[0]: at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:221:36)
          Caught 2018-08-31 07:56:39.839 error by controller[0]: ReferenceError: sock is not defined
          wiffi-wz.0 2018-08-31 07:56:39.811 info Stopping adapter ...
          wiffi-wz.0 2018-08-31 07:56:39.810 error at process._tickCallback (internal/process/next_tick.js:104:9)
          wiffi-wz.0 2018-08-31 07:56:39.810 error at _combinedTickCallback (internal/process/next_tick.js:77:11)
          wiffi-wz.0 2018-08-31 07:56:39.810 error at emitCloseNT (net.js:1568:8)
          wiffi-wz.0 2018-08-31 07:56:39.810 error at Server.emit (events.js:185:7)
          wiffi-wz.0 2018-08-31 07:56:39.810 error at emitNone (events.js:86:13)
          wiffi-wz.0 2018-08-31 07:56:39.810 error at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:221:36)
          wiffi-wz.0 2018-08-31 07:56:39.810 error ReferenceError: sock is not defined
          wiffi-wz.0 2018-08-31 07:56:39.809 error uncaught exception: sock is not defined
          wiffi-wz.0 2018-08-31 07:56:39.800 info Stopping adapter ...
          wiffi-wz.0 2018-08-31 07:56:39.799 error at processImmediate [as _immediateCallback] (timers.js:617:5)
          wiffi-wz.0 2018-08-31 07:56:39.799 error at tryOnImmediate (timers.js:645:5)
          wiffi-wz.0 2018-08-31 07:56:39.799 error at runCallback (timers.js:672:20)
          wiffi-wz.0 2018-08-31 07:56:39.799 error at Immediate._tickCallback (internal/process/next_tick.js:104:9)
          wiffi-wz.0 2018-08-31 07:56:39.799 error at _combinedTickCallback (internal/process/next_tick.js:77:11)
          wiffi-wz.0 2018-08-31 07:56:39.799 error at emitCloseNT (net.js:1568:8)
          wiffi-wz.0 2018-08-31 07:56:39.799 error at Server.emit (events.js:185:7)
          wiffi-wz.0 2018-08-31 07:56:39.799 error at emitNone (events.js:86:13)
          wiffi-wz.0 2018-08-31 07:56:39.799 error at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:221:36)
          wiffi-wz.0 2018-08-31 07:56:39.799 error ReferenceError: sock is not defined
          wiffi-wz.0 2018-08-31 07:56:39.799 error uncaught exception: sock is not defined
          wiffi-wz.0 2018-08-31 07:56:39.793 info Stopping adapter ...
          wiffi-wz.0 2018-08-31 07:56:39.792 error at process._tickCallback (internal/process/next_tick.js:104:9)
          wiffi-wz.0 2018-08-31 07:56:39.792 error at _combinedTickCallback (internal/process/next_tick.js:77:11)
          wiffi-wz.0 2018-08-31 07:56:39.792 error at emitCloseNT (net.js:1568:8)
          wiffi-wz.0 2018-08-31 07:56:39.792 error at Server.emit (events.js:185:7)
          wiffi-wz.0 2018-08-31 07:56:39.792 error at emitNone (events.js:86:13)
          wiffi-wz.0 2018-08-31 07:56:39.792 error at Server. <anonymous>(/opt/iobroker/node_modules/iobroker.wiffi-wz/main.js:221:36)
          wiffi-wz.0 2018-08-31 07:56:39.792 error ReferenceError: sock is not defined
          wiffi-wz.0 2018-08-31 07:56:39.782 error uncaught exception: sock is not defined
          wiffi-wz.0 2018-08-31 07:56:39.744 info Stopping adapter ...</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
          und dann bleibt der adapter gelb
          • coyote
            coyote Most Active last edited by
            Gerät im Adapter eingetragen? Port ist auf 8181
            Dann musst du auch im Weatherman den Port eintragen und die IP von iobroker.
            Also den ccu Parameter auf IP von iobroker und param12 auf 8181
            • X
              Hey farmer,
              dies ist tatsächlich ein blöder Fehler. Ich konnte den Fehler reproduzieren und habe eine hoffentlich gefixte Version auf Github hinterlegt.
              Vielen Dank fürs Testen!
                leider hab ich ein neues Problem,
                ich depp :oops: , wollte jetzt den adapter löschen und neu installieren, geht leider nicht 😢 .
                wenn ich den adapter lösche, läuft es zwar durch, aber der adapter bleibt sichtbar, nur das löschsymbol verschwindet.
                neu installieren lässt er sich auch nicht, da bleibt er hängen:
                $ ./iobroker url "https://github.com/t4qjXH8N/ioBroker.wiffi-wz/tarball/master" wiffi-wz
                install https://github.com/t4qjXH8N/ioBroker.wiffi-wz/tarball/master
                npm install https://github.com/t4qjXH8N/ioBroker.wiffi-wz/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                beim löschen sagt er:
                $ ./iobroker del wiffi-wz
                Delete adapter "wiffi-wz"
                host.iobroker no instances of adapter wiffi-wz found
                host.iobroker Counted 1 devices of wiffi-wz
                host.iobroker Counted 1 states of wiffi-wz
                host.iobroker Counted 1 states (wiffi-wz.*) from states
                host.iobroker Counted 7 states (system.adapter.wiffi-wz.*) from states
                host.iobroker Deleting 2 object(s).
                host.iobroker Deleting 8 state(s).
                npm uninstall iobroker.wiffi-wz --silent --save --prefix "/opt/iobroker" (System call)
                anschliessend steht er in tab-adapters so (ohne das löschsymbol:
                was kann ich sonst machen um den adapter wieder zu installieren???? :?: :?: :?:
                • Stabilostick
                  Stabilostick last edited by
                  Ich sag doch, dass da ein Problem mit dem Setup ist. [emoji56]
                    @Stabilostick:
                    Ich sag doch, dass da ein Problem mit dem Setup ist. [emoji56] `
                    hattest/hast du das selbe problem :?:
                    • X
                      Ok, ich konnte das Problem teilweise nachvollziehen.
                      Der BUSY-Fehler tritt auf, wenn man im Admin-Interface den Adapter von Github installieren/aktualisieren will, und die Wiffi-Instanz noch läuft.
                      Lösung: iobroker admin stop, iobroker admin start, Wiffi-Instanz stoppen und dann aktualisieren
                        ich hab keine Instance von wiffi-wz laufen
                        root@iobroker:~# ps -ef | grep io.*.0
                        root         9     2  0 10:18 ?        00:00:00 [migration/0]
                        root       459   395  1 10:18 ?        00:00:25 io.admin.0
                        root       467   395  0 10:18 ?        00:00:19 io.web.0
                        root       501   395  6 10:18 ?        00:02:26 io.javascript.0
                        root       507   395  0 10:18 ?        00:00:05 io.socketio.0
                        root       523   395  0 10:18 ?        00:00:08 io.cloud.0
                        root       529   395  1 10:18 ?        00:00:31 io.tr-064.0
                        root       551   395  0 10:18 ?        00:00:19 io.sql.0
                        root       587   395  1 10:19 ?        00:00:31 io.s7.0
                        root       609   395  0 10:19 ?        00:00:05 io.simple-api.0
                        root       623   395  0 10:19 ?        00:00:18 io.parser.0
                        root       663   395  0 10:19 ?        00:00:08 io.telegram.0
                        root       669   395  0 10:19 ?        00:00:07 io.sonos.0
                        root       679   395  0 10:19 ?        00:00:04 io.sayit.0
                        root       693   395  0 10:19 ?        00:00:19 io.sonoff.0
                        root       703   395  0 10:19 ?        00:00:13 io.mihome-vacuum.0
                        root       730   395  0 10:19 ?        00:00:04 io.backitup.0
                        root       751   395  0 10:19 ?        00:00:06 io.broadlink2.0
                        root       772   395  0 10:20 ?        00:00:11 io.alexa2.0
                        root       792   395  1 10:20 ?        00:00:37 io.sonnen.0
                        root       859   517  0 10:54 pts/0    00:00:00 grep io.*.0
                        • X
                          stimmt, jetzt nicht mehr 😉
                            beim aktualisieren bleibt er immernoch hängen
                            • Stabilostick
                              War viewtopic.php?t=16504#p173494
                              • coyote
                                Hey x4tlaoguo,
                                konntest du schon mal nach dem Wiffi-Pump schauen um den einzufügen?
                                  habs jetzt geschafft
                                  anscheind hat sich die adapteroberfläche nur nicht aktualisiert, nach einem manuellen aktualisieren (F5) der Seite, war die installation abgeschlossen.
                                  jetzt konnte ich die Instance installieren und meine Daten eingeben.
                                  leider kam jetzt die Fehlermeldung Instance allready running
                                  nach einem iobroker stop
                                  iobroker start ging es anscheinend, zumindest legt er die Datenpunkte an.
                                  aber leider aktualisiert er die Daten nicht.
                                  also noch im weatherman den param:12:8181 (param:12:Port der im wiffi-wz-adapter eingestellt ist) angeben
                                  und siehe da
                                  es funzt :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: 😄 😄
                                  • X
                                    Super, danke fürs Probieren!
                                    • Stabilostick
                                      Schaust du bitte noch nach dem Beenden von Node nach dem Setup? Damit man nicht den ioBroker manuell stoppen muss wie oben geschehen.
                                      • X
                                        Habe mir das gerade angeschaut und kurz bei mir getestet. Der "Adapter already running Fehler" sollte nicht mehr auftreten, es darf getestet werden. Zudem wird jetzt noch der Wiffi Pump unterstützt.
                                        • Stabilostick
                                          Ganz ohne Test schonmal ein herzliches Danke!
                                          • willi5
                                            wiffi-wz steht unter den Adaptern, installieren (Instanzen)läßt er sich nicht, auch wenn er unter Adapter installiert ist.
                                            109
                                            12805
