    4. Probleme mit Wecker (erledigt)
      Blackeye last edited by
      mein Wecker will nicht um 6:00 auslösen???
      Ich will den Wecker um 6:00 oder manuell den Weckvorgang starten können:
      Hier der komplette Code:
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="%z/LwTYQAAai?H9OrWZ/" x="-337" y="-87"><mutation items="2"></mutation>
          <value name="OID0"><shadow type="field_oid" id="SI/S3|C%+~3jmLni:5}o"><field name="oid">default</field></shadow>
            <block type="field_cron" id="kgJ/{zL54A450|TOU*O?"><field name="CRON">0 6 * * *</field></block></value>
          <value name="OID1"><shadow type="field_oid" id="dGGmK#d*)zs3[[jwcUAb"><field name="oid">javascript.0.Alexa_ruft.Melissa_aufstehen</field></shadow></value>
          <statement name="STATEMENT"><block type="controls_if" id="X7^j7K]M}EwpNCaht|)p"><value name="IF0"><block type="logic_operation" id="Dv=Uc,m7l59nVRe`d2?a" inline="false"><field name="OP">AND</field>
                  <value name="A"><block type="logic_operation" id="G82#6%)Wf*NAx**0G56R" inline="false"><field name="OP">AND</field>
                      <value name="A"><block type="logic_compare" id="@D/=*{z|is_Z3vA`@-Fz"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="]~Mape-R2duT/W=-iJ4-"><field name="ATTR">val</field>
                              <field name="OID">javascript.0.Berechnungen.Freier_Tag</field></block></value>
                          <value name="B"><block type="logic_boolean" id="KRWIdTZ^aLff#mn_{FZP"><field name="BOOL">FALSE</field></block></value></block></value>
                      <value name="B"><block type="logic_compare" id="Ude?1z%jDt]Gqc{6RUs4"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="jRDa^fMG3OpNt}/Nlve;"><field name="ATTR">val</field>
                              <field name="OID">ical.0.events.Kinder bei mir</field></block></value>
                          <value name="B"><block type="logic_boolean" id="RLIXwdwyaS`zUq,YMa?j"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                  <value name="B"><block type="logic_operation" id="[pjyGpA=NPN5Z}vorPgr"><field name="OP">AND</field>
                      <value name="A"><block type="time_compare_ex" id="rm|z,0+i@bs%lJAk5W};"><mutation end_time="false" actual_time="true"></mutation>
                          <field name="OPTION">>=</field>
                          <value name="START_TIME"><shadow type="text" id="P}^^#wIOGALm^?Ct(`V/"><field name="TEXT">06:00</field></shadow></value></block></value>
                      <value name="B"><block type="time_compare_ex" id="1(X.wy2^KOAC@kP#G7=v"><mutation end_time="false" actual_time="true"></mutation>
                          <field name="OPTION"><=</field>
                          <value name="START_TIME"><shadow type="text" id="nD6ycIDk]JqhCZC/n/ti"><field name="TEXT">06:03</field></shadow></value></block></value></block></value></block></value>
              <statement name="DO0"><block type="controls_if" id="NRJU[-_/uB.k9XM^1?Xd"><value name="IF0"><block type="logic_operation" id="iZZiE~kZ0r+!pNZl{LJc" inline="false"><field name="OP">AND</field>
                      <value name="A"><block type="logic_compare" id="o:b?K[rZ;8Z6rm5:DVJv"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="g/zk9axlVdl9|b:DN-?p"><field name="ATTR">val</field>
                          <value name="B"><block type="logic_boolean" id="fS%E2pW4*a,oxht0?67%"><field name="BOOL">FALSE</field></block></value></block></value>
                      <value name="B"><block type="logic_compare" id="i0*BL0|0Mb3,K/v*h=O+"><field name="OP">EQ</field>
                          <value name="A"><block type="get_value" id="EUqL,P+l?!#{Sy@N,vf="><field name="ATTR">val</field>
                          <value name="B"><block type="logic_boolean" id="V)y0;mdE?-uV_OJp1MH;"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
                  <statement name="DO0"><block type="control" id="SS:I*J)DHzmmBklzW9hK"><mutation delay_input="false"></mutation>
                      <field name="OID">hm-rpc.0.OEQ0541831.1.LEVEL</field>
                      <value name="VALUE"><block type="math_number" id="}1ww5-@.M^jwt8e4Cbhy"><field name="NUM">100</field></block></value>
                      <next><block type="control" id="?0{UlHNV~d?F|Virf~8p"><mutation delay_input="true"></mutation>
                          <field name="OID">hm-rpc.0.MEQ0361861.1.STATE</field>
                          <field name="DELAY_MS">2</field>
                          <value name="VALUE"><block type="logic_boolean" id="f#AQzUvV/t0b;M1J3.5t"><field name="BOOL">TRUE</field></block></value>
                          <next><block type="control" id="-vO*)Fr}x^bmrE{(;%Le"><mutation delay_input="true"></mutation>
                              <field name="OID">alexa2.1.Echo-Devices.G090L910720405N1.Music-Provider.Spotify</field>
                              <value name="VALUE"><block type="text" id="FD{og+CQ,)Kei@Jkl`8L"><field name="TEXT">Guten Morgen liebe Sorgen</field></block></value>
                              <next><block type="control" id="B_|OKlO8v=%ywD/H@h6L"><mutation delay_input="false"></mutation>
                                  <field name="OID">alexa2.0.Echo-Devices.G090LB097414030P.Commands.speak</field>
                                  <value name="VALUE"><block type="text" id="ML1m/~=elV7Wj9m~mdwy"><field name="TEXT">Melissa wurde geweckt</field></block></value>
                                  <next><block type="control" id="w}Wyp4+]~=)|Z1?@z}Je"><mutation delay_input="false"></mutation>
                                      <field name="OID">alexa2.0.Echo-Devices.G070RQ118097068H.Commands.speak</field>
                                      <value name="VALUE"><block type="text" id="8=hI|CI=Xs0U6JZ:NjGs"><field name="TEXT">Melissa wurde geweckt</field></block></value>
                                      <next><block type="control" id="F%Us7]AUE)g8.,~c5K#@"><mutation delay_input="false"></mutation>
                                          <field name="OID">alexa2.0.Echo-Devices.G000MW0773420FA7.Commands.speak</field>
                                          <value name="VALUE"><block type="text" id="~tzad;}#0`sEC`,]rwTR"><field name="TEXT">Melissa wurde geweckt</field></block></value>
                                          <next><block type="controls_if" id="[Hex,sc,B(`O2,rKT@.o"><value name="IF0"><block type="logic_compare" id="@:xEG;^5~Y2U_anV)s*O"><field name="OP">EQ</field>
                                                  <value name="A"><block type="get_value" id="oC[oNSPg9gIs4f53YCXJ"><field name="ATTR">val</field>
                                                      <field name="OID">javascript.0.Alexa_ruft.Melissa_aufstehen</field></block></value>
                                                  <value name="B"><block type="logic_boolean" id="vA%vUC(^-c*8UXh=5x.t"><field name="BOOL">TRUE</field></block></value></block></value>
                                              <statement name="DO0"><block type="control" id="a6J(jl7Ds7m;DLruasOV"><mutation delay_input="true"></mutation>
                                                  <field name="DELAY_MS">4</field>
                                                  <value name="VALUE"><block type="logic_boolean" id="6~gGT?mQrTcx.5?;nQaQ"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block></statement></block></statement></block></xml>
      Der Hinweis mit Ausführen war Gold wert, aber dann war da noch die falsche Zeitzone auf dem PI eingestellt. Auf Europa/Berlin geändert und es passt.
        paul53 last edited by
        Falls Object ist ein Datenpunkttrigger und kann nicht mit CRON verwendet werden. Dazu braucht es zwei Trigger. Die Prüfungen und Aktionen "Wecken" packt man am Besten in eine Funktion, die aus beiden Triggern aufgerufen wird.
          verstehe leider nur Bahnhof….
          @paul53:
          Falls Object ist ein Datenpunkttrigger und kann nicht mit CRON verwendet werden. Dazu braucht es zwei Trigger. Die Prüfungen und Aktionen "Wecken" packt man am Besten in eine Funktion, die aus beiden Triggern aufgerufen wird. `
            oder meinst du so?
              @Blackeye:
              meinst du so? `
              Nein, so
                ich denke ich habe es genau so umgesetzt, aber funktionieren will da gar nichts…..
                PS: Über den Zeitplan wie du habe ich es auch probiert, aber der Triggert auch nicht.
                @paul53:
                @Blackeye:
                meinst du so? `
                Nein, so
                Blockly_Trigger_DP_oder_Schedule.JPG `
                  ich bin jetzt gerade zu Hause und gerade ist der Wecker angesprungen….
                  Wieso geht der 2 Stunden nach? Kann ich irgendwo eine Uhrzeit einstellen?
