    4. Skriptsammlung für den neuen ALEXA2.0 Adapter
    • sissiwup
      sissiwup last edited by
      anbei ein Skript der die letzten Anrufe vorliest inkl. Uhrzeit. Es werden nur Anrufe vom aktuellen Datum berücksichtigt.
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id=";azz=uCTGBXNyd/0SAEt" x="-688" y="-87"><mutation items="1"></mutation>
          <value name="OID0"><shadow type="field_oid" id="sW!}aU3Gi9+ka~_!Wa99"><field name="oid">javascript.0.vAlexaSagAnrufListe</field></shadow></value>
          <statement name="STATEMENT"><block type="variables_set" id="H^Wy%qAv/BmW;sE/nZ;k"><field name="VAR">alexatext</field>
              <value name="VALUE"></value>
              <next><block type="variables_set" id="Gx/mw:m_izOpYx{@Lk)p"><field name="VAR">anz</field>
                  <value name="VALUE"><block type="math_number" id="}+UH7L;^VthYU]z=g0*F"><field name="NUM">0</field></block></value>
                  <next><block type="controls_forEach" id="xR/0#,CUOGLHQK=!Q-w4"><field name="VAR">i</field>
                      <value name="LIST"><block type="convert_json2object" id="@C6w/;8o)*%oxJ@UT,8_"><value name="VALUE"><block type="get_value" id="/qU/gkpQm,.]-YY_L1(X"><field name="ATTR">val</field>
                              <field name="OID">tr-064.0.calllists.all.json</field></block></value></block></value>
                      <statement name="DO"><block type="variables_set" id="Otd~Mlm|z]3g8Q0p^`=s"><field name="VAR">pos</field>
                          <value name="VALUE"><block type="math_number" id="*FRuMmk(T8;v+VQc3DM~"><field name="NUM">0</field></block></value>
                          <next><block type="variables_set" id="%]9yo5qM?m^}^74-D/oY"><field name="VAR">anrufer</field>
                              <value name="VALUE"><block type="text" id=")-o_KuQG)qLQ_:,)m_OG"><field name="TEXT">unbekannt</field></block></value>
                              <next><block type="variables_set" id="fAU|Ej;;bY3%?[4T%.yR"><field name="VAR">anrufdatum</field>
                                  <next><block type="controls_forEach" id="orz4mSV=gNl%mayt{k=}"><field name="VAR">j</field>
                                      <value name="LIST"><block type="variables_get" id="-@5CcHPA:B{WFGD?9}QI"><field name="VAR">i</field></block></value>
                                      <statement name="DO"><block type="controls_if" id="[=SFT;CG~Z!}Qv_6!%~e"><value name="IF0"><block type="logic_operation" id="nE-NMM;w9-939EBoh[^/"><field name="OP">AND</field>
                                              <value name="A"><block type="logic_compare" id="EXHXJkT)K*3D%y[V8/Ax"><field name="OP">EQ</field>
                                                  <value name="A"><block type="variables_get" id="3J;!g!2(]ul{N2+L{CU;"><field name="VAR">pos</field></block></value>
                                                  <value name="B"><block type="math_number" id=",^J=^x]oT1BuIuccep(u"><field name="NUM">1</field></block></value></block></value>
                                              <value name="B"><block type="logic_compare" id="5ffi|wi3RT^.P{H`@L@/"><field name="OP">NEQ</field>
                                                  <value name="A"><block type="variables_get" id=":%j4u:bAtqB{.d=-/d.r"><field name="VAR">j</field></block></value>
                                                  <value name="B"></value></block></value></block></value>
                                          <statement name="DO0"><block type="variables_set" id="j1HH[{w}==ujX:swZf=K"><field name="VAR">typ</field>
                                              <value name="VALUE"><block type="variables_get" id="iZm34~7lg:`~-|Qj+XL7"><field name="VAR">j</field></block></value></block></statement>
                                          <next><block type="controls_if" id="yU_?RKy~M]Byp+z20m;1"><value name="IF0"><block type="logic_operation" id="w1CkK4,G=~U2PSI5};L0"><field name="OP">AND</field>
                                                  <value name="A"><block type="logic_compare" id="}Ic~-io[2ya;!`#Dt-XB"><field name="OP">EQ</field>
                                                      <value name="A"><block type="variables_get" id="mT}DaeA?j-]w@jqhR;yp"><field name="VAR">pos</field></block></value>
                                                      <value name="B"><block type="math_number" id="g9=0@+{xcO#s-zQp0nHe"><field name="NUM">2</field></block></value></block></value>
                                                  <value name="B"><block type="logic_compare" id="Ok)G~.gN_S@?4Z{-VP+P"><field name="OP">NEQ</field>
                                                      <value name="A"><block type="variables_get" id="pgmkX`^RjBM;Vss.ka;9"><field name="VAR">j</field></block></value>
                                              <statement name="DO0"><block type="variables_set" id="D-(}L)F;.KF!P4.6XKcK"><field name="VAR">anrufer</field>
                                                  <value name="VALUE"><block type="variables_get" id=",[sZ/c2H:,)#VSe9-OgI"><field name="VAR">j</field></block></value></block></statement>
                                              <next><block type="controls_if" id="SS`Ca]=@Q!%UKD%=SQHm"><value name="IF0"><block type="logic_operation" id="S9LFfiQG/g/-J(~uA!/e"><field name="OP">AND</field>
                                                      <value name="A"><block type="logic_compare" id="DCfM=V|@1#9pRWH779nh"><field name="OP">EQ</field>
                                                          <value name="A"><block type="variables_get" id="E/c3a1-%;H{hy9If!HL%"><field name="VAR">pos</field></block></value>
                                                          <value name="B"><block type="math_number" id="H@+MR5PLO_STRYHR/(B+"><field name="NUM">5</field></block></value></block></value>
                                                      <value name="B"><block type="logic_compare" id="w*s!SSWTdc-svcQ)MsGy"><field name="OP">NEQ</field>
                                                          <value name="A"><block type="variables_get" id="DJ~z`c`lBy4A5(}3)i_*"><field name="VAR">j</field></block></value>
                                                  <statement name="DO0"><block type="variables_set" id="FqA%[#fq/LyMm+;I*RRP"><field name="VAR">anrufer</field>
                                                      <value name="VALUE"><block type="variables_get" id="jKU-Ur+A(gzJH=Xx:JXe"><field name="VAR">j</field></block></value></block></statement>
                                                  <next><block type="controls_if" id="_w?7*llOp[6)e)o5jO,w"><value name="IF0"><block type="logic_compare" id=":hBS5;Nx4%_14RC:eGx3"><field name="OP">EQ</field>
                                                          <value name="A"><block type="variables_get" id="0Gy{gheR5u}iF!6)cMxz"><field name="VAR">pos</field></block></value>
                                                          <value name="B"><block type="math_number" id="eVEtOt#W=Qs?L?j?p(i#"><field name="NUM">9</field></block></value></block></value>
                                                      <statement name="DO0"><block type="variables_set" id="+V98jJzLkcjdwxve][aa"><field name="VAR">anrufdatum</field>
                                                          <value name="VALUE"><block type="variables_get" id="u6S]DGC|xjW,5;;IAR%."><field name="VAR">j</field></block></value>
                                                          <next><block type="controls_flow_statements" id="eJd]I^WE;L3x`;N1=svx"><field name="FLOW">BREAK</field></block></next></block></statement>
                                                      <next><block type="math_change" id="SOSx!Tp,ww0F=Ipoxq84"><field name="VAR">pos</field>
                                                          <value name="DELTA"><shadow type="math_number" id=",`a^zzH0LZcBY@M8;uJC"><field name="NUM">1</field></shadow></value></block></next></block></next></block></next></block></next></block></statement>
                                      <next><block type="comment" id="mI7wi{z/b;#{OB.TkXq+"><field name="COMMENT">Typ 1 = angenommen, Typ 2 = missed (Typ 1 auch AB!)</field>
                                          <next><block type="controls_if" id="HnqX;*3~~sS;v[o8*Zb5"><value name="IF0"><block type="logic_compare" id=")uo92MC7.#C9_=1@Pd+2"><field name="OP">LTE</field>
                                                  <value name="A"><block type="variables_get" id="_Cv6!Q9ZD8`VVr0g#]0L"><field name="VAR">typ</field></block></value>
                                                  <value name="B"><block type="math_number" id="}aCLu#a2rc=|kgv|+{sI"><field name="NUM">2</field></block></value></block></value>
                                              <statement name="DO0"><block type="controls_if" id="k|!G/Xj?oA`b(/Kc-|1R"><value name="IF0"><block type="logic_compare" id="uHRur!#y`^X?vc3mNKW*"><field name="OP">EQ</field>
                                                      <value name="A"><block type="convert_tostring" id="psi^4GjR6xXmU9rLPUAy"><value name="VALUE"><block type="time_get" id="NYBw`pidAU~K#eutu?zY"><mutation format="false" language="false"></mutation>
                                                              <field name="OPTION">DD.MM.YY</field></block></value></block></value>
                                                      <value name="B"><block type="text_getSubstring" id="!|(mm1/Xp?y3`k2=W+@."><mutation at1="true" at2="true"></mutation>
                                                          <field name="WHERE1">FROM_START</field>
                                                          <field name="WHERE2">FROM_START</field>
                                                          <value name="STRING"><block type="variables_get" id=";-^a@}aIM5mKBWNjtX:m"><field name="VAR">anrufdatum</field></block></value>
                                                          <value name="AT1"><block type="math_number" id="=I;t4NntB/E_jilatK*{"><field name="NUM">1</field></block></value>
                                                          <value name="AT2"><block type="math_number" id="z#ll|XhXTWf*X2st=hK+"><field name="NUM">8</field></block></value></block></value></block></value>
                                                  <statement name="DO0"><block type="variables_set" id="4MqQA#su!5x*fg`QEaR2"><field name="VAR">tmp</field>
                                                      <value name="VALUE"><block type="text_join" id="_{fO%DcZHDv(YjqN|+.U"><mutation items="6"></mutation>
                                                          <value name="ADD0"><block type="variables_get" id="~|0|%^ZzX~%[oOm5;!%J"><field name="VAR">anrufer</field></block></value>
                                                          <value name="ADD1"><block type="text" id="?YhfYv}KVbo|5CRZywXf"><field name="TEXT">hat um</field></block></value>
                                                          <value name="ADD2"><block type="text_getSubstring" id="{L:3[y{3D}ibA]mMtGc="><mutation at1="true" at2="true"></mutation>
                                                              <value name="STRING"><block type="variables_get" id="5|yY+vuWW}:_0i%xYqQ#"><field name="VAR">anrufdatum</field></block></value>
                                                              <value name="AT1"><block type="math_number" id="]v/aOee-W1K_lHC[wD:o"><field name="NUM">10</field></block></value>
                                                              <value name="AT2"><block type="math_number" id="Cv?R*(FV#bD6s,bQXAR;"><field name="NUM">11</field></block></value></block></value>
                                                          <value name="ADD3"><block type="text" id="u5fZHU#/xM|I/zXzT.W_"><field name="TEXT">Uhr und</field></block></value>
                                                          <value name="ADD4"><block type="text_getSubstring" id="csz?P)@/[_=osgekZdNE"><mutation at1="true" at2="true"></mutation>
                                                              <value name="STRING"><block type="variables_get" id="8Qr2nQ]7V1.D/B5rKFFj"><field name="VAR">anrufdatum</field></block></value>
                                                              <value name="AT1"><block type="math_number" id="`kMkBT[35quqk~N3H}A}"><field name="NUM">13</field></block></value>
                                                              <value name="AT2"><block type="math_number" id="3gRaKyCY^^O,j9LaaatH"><field name="NUM">14</field></block></value></block></value>
                                                          <value name="ADD5"><block type="text" id="RvwRh)|Wf*z|odx6hXqT"><field name="TEXT"> Minuten angerufen</field></block></value></block></value>
                                                      <next><block type="variables_set" id="Re~~rNq{gaD7SF0MM]-T"><field name="VAR">alexatext</field>
                                                          <value name="VALUE"><block type="logic_ternary" id="1!5a5vst3!y`Wl{IFTt-"><value name="IF"><block type="logic_compare" id="myxaS.9u5t`8ZwV;3pK2"><field name="OP">EQ</field>
        <value name="A"><block type="variables_get" id="R8GYMX}F`g!ZBo{D+k]_"><field name="VAR">anz</field></block></value>
        <value name="B"><block type="math_number" id="tSW1iA{d5EVQHN[Z+-tV"><field name="NUM">0</field></block></value></block></value>
                                                              <value name="THEN"><block type="variables_get" id=":t%z[.];H-|t/WU%FE^)"><field name="VAR">tmp</field></block></value>
                                                              <value name="ELSE"><block type="text_join" id="`1mJO@vgR)fU#CsbTy-m"><mutation items="3"></mutation>
        <value name="ADD0"><block type="variables_get" id="!k^RkI_Tp+tQLrJb~clx"><field name="VAR">alexatext</field></block></value>
        <value name="ADD1"><block type="text" id="9FXixkB1O.uj=W!zWhUc"><field name="TEXT">;</field></block></value>
        <value name="ADD2"><block type="variables_get" id="O7*;5,?x_]UOIEkj7OV0"><field name="VAR">tmp</field></block></value></block></value></block></value>
                                                          <next><block type="math_change" id="BXCqiU7*0-%cE]@0M]!q"><field name="VAR">anz</field>
                                                              <value name="DELTA"><shadow type="math_number" id="[kq,k~/SLxO,g_:DMu}r"><field name="NUM">1</field></shadow></value>
                                                              <next><block type="controls_if" id="~Yq8]Xgt4y+k+(7IUKd!"><value name="IF0"><block type="logic_compare" id="42859)|d|Y6bHZG2}o?7"><field name="OP">EQ</field>
        <value name="A"><block type="variables_get" id="a7~!mlyA)h1A6ODLFLDJ"><field name="VAR">anz</field></block></value>
        <value name="B"><block type="math_number" id="08yPn#v84mn0=0q)[r]R"><field name="NUM">5</field></block></value></block></value>
        <statement name="DO0"><block type="controls_flow_statements" id="tBE}?*}^gMtd;1q`ApNS"><field name="FLOW">BREAK</field></block></statement></block></next></block></next></block></next></block></statement></block></statement></block></next></block></next></block></next></block></next></block></next></block></statement>
                      <next><block type="control" id="`Qg!CDbvO0.dV/`|!D3d"><mutation delay_input="false"></mutation>
                          <field name="OID">alexa2.0.Echo-Devices.G090LF1174832X09.Commands.speak</field>
                          <value name="VALUE"><block type="variables_get" id="mjJFF5P]=q46l?dg`Tj~"><field name="VAR">alexatext</field></block></value>
                          <next><block type="debug" id="Ns0b*WC0f!TpiS%JQ^[d"><field name="Severity">log</field>
                              <value name="TEXT"><shadow type="text" id="2JciUzD(4a1E=jF@1vyY"><field name="TEXT">test</field></shadow>
                                <block type="variables_get" id="#6H6rD3{_zs~oG}dO4S^"><field name="VAR">alexatext</field></block></value></block></next></block></next></block></next></block></next></block></statement></block></xml>
      • haselchen
        haselchen Most Active last edited by
        @sissiwup
        Wie sieht Dein Tipp praktisch aus?
        Ich weiss nämlich nicht wo ich ansetzen soll.
        Ganz unterschiedlich bekomme ich diesen Error , der vermutlich von der Alexa Einkaufsliste stammt. Jedenfalls startet der Adapter dann neu und Alexa fängt jetzt an dann die Fenster aufzuzählen.
        Kann leider kein Log schicken, weil der letzte Fehler-Neustart von heute morgen ist und der steht nicht mehr im Log.
        Alle 4minuten startet das Einkaufslisten Skript.
        Und irgendwann im Laufe des Tages kommt mal ein Fehler bei der Ausführung und dann ist es wieder auf unbestimmte Zeit gut.
        So sieht es aus, wenn alles gut ist:
        In einem der Einkaufsskripts habe ich 1 gelbes Warndreieck. Eventuell ist das der Fehler? :?:
        Was müsste ich da korrigieren in der Zeile?
        • dslraser
          Log sollte auch von gestern da sein.
          LOG herunter laden anklicken.![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201809 ... 042fc2.jpg">https://uploads.tapatalk-cdn.com/20180908/2d92fb62bd6cfc6793164cac2b042fc2.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201809 ... 51f066.jpg">https://uploads.tapatalk-cdn.com/20180908/7e42e66a27e98e116b374b3d1151f066.jpg</link_text>" />
          PS: das Warndreieck kannst Du auch anklicken oder mit der Maus drüber fahren, da steht dann der Fehlerhinweis.~~~~
          • haselchen
            Wenn es Dich nicht gäbe dslraser….klasse support 🙂
            "Dont make functions within a loop" ist die Meldung.
            Ich muss leider alles erfragen,weil ich davon keinen Plan habe 😢
            • dslraser
              @haselchen:
              filename="Unbenannt1.PNG" index="0">~~
              Ich muss leider alles erfragen,weil ich davon keinen Plan habe 😢 ` Das Log wäre dann für den Adapterentwickler hilfreich.
              Und mit dem Javascript Fehler bin ich ebenfalls überfordert. Kannst ja mal paul53 hier im Forum fragen, er ist richtig fit.
                mk120 last edited by
                Halli Hallo,
                ich sehe glaube ich sehe den Wald vor lauter Bäumen nicht. Ich bekomme das Fensterscript was von der Idee und Umsetzung richtig cool ist nicht ans laufen. Könnte von euch mal jemand rüberschauen und mir einen Tipp geben? Vielen Dank und ein schönen Sonntag
                • haselchen
                  Hab noch nicht alles bei dir angesehen , aber du solltest auf jedenfall deinen Räumen vernünftige Namen geben.
                  Damit würde ich als allererstes anfangen.
                  Dann habe ich es mal bei mir verglichen, da heisst es im Wert OPEN(1) oder CLOSED(0)
                  Bei dir steht true oder false.
                  Ich denke damit hat es wohl auch zu tun.
                  Aber dslraser als Skript Profi kennt sich damit besser aus 😉
                  • dslraser
                    @mk120:
                    Halli Hallo,
                    gewerk_fenster.PNG `
                    Also hier mal was von mir dazu. Das mit den Raumnamen und Gewerken würde ich auch anpassen. (sonst bekommst Du als Raum leer, oder leer1 und roomBathroom usw…)
                    Hier mal meine Gewerke
                    und hier mal meine Räume
                    filename="Räume.JPG" index="2">~~
                    Schau mal unter Aufzählungen wie da Deine Räume und Funktionen heissen. Wenn Du die aus der CCU hast, dann solltest Du es dort anpassen(Räume und Gewerke) danach Geräte neu einlesen von Deiner Instanz.
                    Dann musst Du schauen wie bei Dir die STATE oder eben state heißen. Bei mir sind die .STATE groß geschrieben.
                    So ist es dann auch im Script anzupassen
                    Und eben wie Dein Gewerk heißt(bei mir Fenster, so auch im Script(genaue Schreibweise)
                    Dann hast Du auch eine bessere Übersicht in den Objekten
                      @dslraser,
                      kommt mir bekannt vor…........... 🙂
                        Jungs, vielen Dank für die schnellen Antworten. Ich habe die Kontakte jetzt auf der CCU sauber zugeordenet (Gewerk/Raum) die Leer1 etc waren erstmal für ein Test, da ich dachte das Script zeigt deshalb keine Werte. Ich habe mal geschaut kann es wirklich mit der Open/Closed Geschichte zu tun haben? Bei mir steht true/false statt wie bei dir open/close. Ich habe den STATE im Script auch jetzt großgeschrieben. DANKE für eure Hilfe
                        • dslraser
                          Wenn noch keine Werte nach dem Scriptstart kommen starte mal den Javascript Adapter einmal neu. (nach solchen Änderungen kommt erst dann bei mir sauber was an)
                          PS: und schaue bitte in die Aufzählungen unter Funktionen wie Dein Gewerk da heisst (Bei manchen steht es dort in englisch)
                          Mach mal bitte einen Screeshot von den Aufzählungen und Deiner Funktion Fenster
                            Script/Javascript neugestartet. Leider ohne Erfolg im Log steht auch nichts wildes..
                            • dslraser
                              Bei Dir ist fenster klein geschrieben.
                              enum.functions.fenster
                              Dann muss es im Script auch so geschrieben werden.
                              Bei mir ist es groß geschrieben
                              Dann da ändern (habe ich oben aber geschrieben)
                                Fenster in fenster umbenannt. Script und Javascript neugestartet Fensterstatus = 0. Oh man eventuell mag das Script mich nicht :twisted:
                                Ich habe nun das Gewerk und die Datenpunkte Rega neu eingelesen. Nun wird das Gewerk auch Fenster geschrieben aber er möchte einfach nicht. Mir ist zu dem false/true Unterschied zu Open/Closed bei dir aufgefallen dass unter Objekte der Datenpunkt Sensor heißt. Wenn ich ihn als ID einbinden möchte steht halt xxx.hm2.sensor. Ist das eventuell ein Problem?
                                Anbei meine aktuellen Einstellungen:
                                Danke für die Mithilfe am Sonntag
                                • dslraser
                                  ich bin nur am Handy und kann an den Screenshots nicht so richtig was sehen. Aber Du kannst es ja auch mal mit id=.sensor oder id=.SENSOR propieren…
                                  Ich weiss gerade nicht aus dem Kopf ob dann auch noch andere Stellen geändert werden müssen, ich glaube aber nicht. (ich benutze das gleiche Script für Hue Lampen und da läuft es über id=*.on)
                                  Und wenn Du am Script was änderst starte den JS Adapter neu, das war bei mir immer der Grund wenn es nicht übernommen wurde...
                                  • dslraser
                                    kannst auch gerne mal hier nachlesen, das ist das gleiche Script aber da haben auch Andere in der betroffenen Zeile was angepasst, je nachdem…
                                    viewtopic.php?f=21&t=5735&share_tid=573 ... are_type=t
                                    • haselchen
                                      @ dslraser
                                      Ich habe mal das Skript getestet , als alle Fenster geschlossen waren.
                                      Da kommt dann von Alexa: Es sind…... und dann nichts mehr.
                                      Ähm, es wäre schön wenn sie sagt , es ist alles geschlossen oder es ist nichts geöffnet.
                                      • dslraser
                                        @haselchen:
                                        @ dslraser
                                        Ähm, es wäre schön wenn sie sagt , es ist alles geschlossen oder es ist nichts geöffnet. `
                                        Ich lasse mir nur Räume mit geöffneten Fenstern ansagen(Fenster sind mir zu viel) und eben ob alle Fenster geschlossen sind. Kommt wahrscheinlich drauf an auf was Du in Deinem Blockly bei der Ansage zeigst.
                                        Mein aktuelles FensterScript
                                        // Status Fenster. Das Script zählt alle Fenster im Gewerk Fenster (Aufzählungen-Funktion)
                                        // Telegramnachricht bei Abwesenheit wenn sich der Fensterstatus ändert. Bei Anwesenheit in der Homezone keine Nachricht senden.
                                        // Anwesenheit Datenpunkte separat erstellt und durch die Adapter google-sharedlocation und Places geschaltet
                                        ! var logging = true;
                                        ! var
                                        idAnzahlAuf = 'javascript.0.Status.Fenster.Anzahl_auf',
                                        idAnzahl = 'javascript.0.Status.Fenster.Anzahl',
                                        idText = 'javascript.0.Status.Fenster.Text',
                                        idRaum = 'javascript.0.Status.Fenster.Raum',
                                        idAnsage = 'javascript.0.Status.Fenster.Ansage';
                                        ! // Ab hier nix mehr ändern
                                        createState(idAnzahl, { // wenn benötigt: Anzahl der vorhandenen Fenster
                                        type: 'number',
                                        name: 'Anzahl aller Fenster',
                                        min: 0,
                                        def: 0,
                                        role: 'value'
                                        createState(idAnzahlAuf, { // Anzahl der Fenster, die auf sind als Variable unter Javascript.0 anlegen
                                        type: 'number',
                                        name: 'Anzahl der geoeffneten Fenster',
                                        min: 0,
                                        def: 0,
                                        role: 'value'
                                        createState(idText, { // Anzahl der geoeffneten Fenster und deren Namen als Variable unter Javascript.0 anlegen
                                        type: 'string',
                                        name: 'geoeffnete Fenster',
                                        desc: 'Namen der geoeffneten Fenster',
                                        def: ' ',
                                        role: 'value'
                                        createState(idAnsage, {
                                        type: 'string',
                                        name: 'geoeffnete Fenster (Ansage)',
                                        desc: 'Namen der geoeffneten Fenster (für Ansage aufbereitet)',
                                        def: ' ',
                                        role: 'value'
                                        createState(idRaum, { // Räume, in denen Fenster geoeffnet sind
                                        type: 'string',
                                        name: 'Räume mit geoeffneten Fenster',
                                        desc: 'Namen der Räume, in denen Fenster geoeffnet sind',
                                        def: ' ',
                                        role: 'value'
                                        ! var cacheSelectorState = $('channelstate.id=*.STATE'); // Gewerk Fenster
                                        ! function checkDevices(obj) {
                                        // Setzt die Zähler vor dem Durchlauf aller Elemente *.STATE im Gewerk Fenster auf 0
                                        var anzahlFensterAuf = 0;
                                        var anzahlFenster = 0;
                                        var textFensterAuf = [];
                                        var textRaum = [];
                                        if (logging) {
                                        log('++++++ Fenster Anzahl ++++ ');
                                        log('#### SCHALTER ##### ');
                                        cacheSelectorState.each(function(id, i) { // Schleife für jedes gefundenen Element *.STATE im Gewerk Fenster
                                        var obj = getObject(id);
                                        var name = getObject(id).common.name;
                                        var status = getState(id).val; // Zustand *.STATE abfragen (jedes Element)
                                        var devicename = name.substring(0, name.indexOf(".STATE")); //.state aus Text entfernen
                                        var raumname = getObject(id, "rooms");
                                        ! if (logging) {
                                        log('-------');
                                        log('Kanal: ' + name);
                                        log('Status: ' + status);
                                        if (status) { // wenn Zustand = true, dann wird die Anzahl der Fenster hochgezählt
                                        ++anzahlFensterAuf;
                                        textFensterAuf.push(devicename); // Zu Array hinzufügen
                                        textRaum.push(raumname.enumNames); //
                                        ++anzahlFenster; // Zählt die Anzahl der vorhandenen Fenster unabhängig vom Status
                                        textRaum = deleteDuplicates(textRaum);
                                        // Array mit Fensternamen sortieren
                                        textFensterAuf.sort();
                                        textRaum.sort();
                                        // Schleife ist durchlaufen. Im Log wird der aktuelle Status (Anzahl, davon auf) ausgegeben
                                        if (logging) log("Text: " + textFensterAuf);
                                        if (logging) log("Anzahl Fenster: " + anzahlFenster + " # davon Fenster auf: " + anzahlFensterAuf);
                                        // die ermittelten Werte werden als javascript.0\. Variable in ioBroker gespeichert (z.B. für die Verarbeitung in VIS)
                                        setState(idText, textFensterAuf.join(',\nund\n')); // Schreibt die aktuelle Namen der geoeffneten Fenster
                                        setState(idAnzahlAuf, textFensterAuf.length); // Schreibt die aktuelle Anzahl der geoeffneten Fenster
                                        setState(idAnzahl, anzahlFenster); // Schreibt die aktuelle Anzahl der vorhandene Elemente im Gewerk Fenster
                                        // setState(idRaum, textRaum.join(',
                                        ')); // Räume, in denen Fenster geoeffnet sind
                                        setState(idRaum, textRaum.join(',\nund\n')); // Räume, in denen Fenster geoeffnet sind
                                        ! // Trigger
                                        cacheSelectorState.on(function(obj) { // bei Zustandänderung *.STATE im Gewerk Fenster
                                        if (logging) log('Auslösender Schalter: ' + obj.id + ': ' + obj.state.val); // Info im Log, welcher Zustand sich geändert hat
                                        checkDevices();
                                        ! function main() {
                                        setTimeout(function() {
                                        if (logging) log('Auslöser Skriptstart');
                                        checkDevices();
                                        }, 2000);
                                        ! main(); // Skriptstart-Auslöser
                                        ! // Aufbereitung für Ansage
                                        function strip_tags(data) {
                                        var rueckgabe = data.replace(/( |<([^>]+)>)/ig, " ");
                                        return (rueckgabe);
                                        ! on(idText, function(obj) {
                                        var text = obj.state.val;
                                        text = (text.length > 1) ? ' ' + strip_tags(text) : 'Alle Fenster geschlossen';
                                        setState(idAnsage, text);
                                        ! // Bei Anwesenheit zu Hause keine Telegramnachricht---Bei Abwesenheit sendet Telegram eine Nachricht
                                        // on({id: 'javascript.0.Status.Fenster.Ansage', change: "ne"}, function (obj) {
                                        // var value = obj.state.val;
                                        // var oldValue = obj.oldState.val;
                                        // if (getState("javascript.0.Anwesenheit.Heiko.Home.Heiko_Home").val === false) {
                                        // sendTo("telegram", "send", {
                                        // text: getState("javascript.0.Status.Fenster.Ansage").val,
                                        // disable_notification: true // ohne Ton am Handy
                                        Ich nehme diese, so passt es bei mir
                                        alle Fenster geschlossen = Datenpunkt geöffnete Fenster (Ansage)
                                         ![3822_fenster_zu.jpg](/assets/uploads/files/3822_fenster_zu.jpg)
                                         ![3822_alle_fenster_geschlossen.jpg](/assets/uploads/files/3822_alle_fenster_geschlossen.jpg)
                                        mindestens ein Raum mit geöffnetem Fenster = Datenpunkt Räume mit geöffneten Fenster
                                         ![3822_fenster_auf.jpg](/assets/uploads/files/3822_fenster_auf.jpg)
                                         ![3822_ein_fenster_auf.jpg](/assets/uploads/files/3822_ein_fenster_auf.jpg)
                                        • haselchen
                                          Bei welchem Blocky Punkt sagt sie denn, dass alles geschlossen ist?
                                          • dslraser
                                            @haselchen:
                                            Bei welchem Blocky Punkt sagt sie denn, dass alles geschlossen ist? `
                                            Schau nochmal in meinen Beitrag über Deinem (da war beim Bilder einfügen was verdreht–-sollte jetzt passen)
                                            79.9k
                                            184
                                            40603
