    4. Tr-064 Adapter Fehler
      Ace-k last edited by
      Ich habe auch zZ das Problem. weiß aber auch nicht wirklich weiter.
      In der Fritzbox freigegeben, Neustart Fritzbox bereits gemacht.
      Node -v
      v6.14.2
      Nodejs -v
      v6.14.2
      Npm -v
      3.10.10
      JS-Controller
      v1.4.2
      hat noch jemand nen ansatz?
      host.raspberrypi	2018-08-28 12:41:46.258	error	instance system.adapter.tr-064.0 terminated with code 1 ()
      host.raspberrypi	2018-08-28 12:41:46.258	error	Caught by controller[0]: at startup (bootstrap_node.js:160:9)
      host.raspberrypi	2018-08-28 12:41:46.257	error	Caught by controller[0]: at run (bootstrap_node.js:394:7)
      host.raspberrypi	2018-08-28 12:41:46.257	error	Caught by controller[0]: at Module.runMain (module.js:611:10)
      host.raspberrypi	2018-08-28 12:41:46.256	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
      host.raspberrypi	2018-08-28 12:41:46.255	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
      host.raspberrypi	2018-08-28 12:41:46.255	error	Caught by controller[0]: at Module.load (module.js:494:32)
      host.raspberrypi	2018-08-28 12:41:46.255	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10)
      host.raspberrypi	2018-08-28 12:41:46.254	error	Caught by controller[0]: at Module._compile (module.js:577:32)
      host.raspberrypi	2018-08-28 12:41:46.254	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
      host.raspberrypi	2018-08-28 12:41:46.253	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
      host.raspberrypi	2018-08-28 12:41:46.253	error	Caught by controller[0]: TypeError: fns.adapter is not a function
      host.raspberrypi	2018-08-28 12:41:46.252	error	Caught by controller[0]: ^
      host.raspberrypi	2018-08-28 12:41:46.252	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
      host.raspberrypi	2018-08-28 12:41:46.250	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383</anonymous>
        apollon77 last edited by
        Habt Ihr irgendwelche andere Updates gemacht vorher? Mal Github Version vom Adapter versucht?
          du meisnt den TR 064 adapter löschen und von Github neu installieren?
          naja 1-2 adapter brauchten n update und hatte den JS controller n update gegeben.
            Nix löschen, einfach update vom Github und dann instanz neu starten (was in dem Fall aber eher unnötig ist weil es ja eh nicht läuft)
              tja.. so ganz werd ich auch nicht schlau!
              • AlCalzone
                @Ace-k:
                tja.. so ganz werd ich auch nicht schlau! `
                Wo hängts? Was verstehst du nicht? Installation von Github geht wie folgt:
                Adapterliste -> Button "aus eigener Quelle installieren" -> im Dropdown den Adapter auswählen -> OK drücken.
                  ja, danke das hab ich gemacht, aber bringt keine besserung
                    so alles mal "neu gemacht" nach
                    http://www.iobroker.net/docu/?page_id=5106&lang=de
                    neue 8.x Nodejs und Npm 4
                    aber leider keine änderung.
                    der Befehl
                    sudo ./reinstall.sh
                    ist leider nicht ausführbar..
                      HauptstadtRocker last edited by
                      <u><size size="150">Problem Gelöst!!!</size></u>
                      Halli Hallo…..
                      ich bin von der Fritz.box 7490 auf die 7590 umgestiegen und habe das backup von der 7490 auf die 7590 gezogen und alles lief tadellos... das einzige problem was ich habe ist dieser LOG eintrag :
                      Alle Adapter sind auf dem Aktuellsten Stand vom 15.09.2018
                      Kennt jemand diesen Fehler?
                        Jan1 last edited by
                        @Ace-k:
                        der Befehl
                        sudo ./reinstall.sh
                        ist leider nicht ausführbar.. `
                        Nein hast Du nicht, sonst würdet nicht schreiben, dass der Befehl nicht ausführbar ist 😉
                          frank62 last edited by
                          @vauvau07:
                          Der tr-064-Adapter mit Fritz!OS 7.00 funktioniert bei mir nach einigen internen Schwierigkeiten
                          Gruß Volkmar `
                          und welche wären das?
                          • smartboart
                            smartboart last edited by
                            Läuft bei mir auch mit der Fritz OS 7.hab die neue Fritte im Netz, welche den Zugang zum Internet über eine andere erreicht. Ich habe das Problem das die Namen der Teilnehmer nicht wie mit der alten Fritte eingelesen werden. Nur die IP.. Ebenfalls müssten alle überwachten Geräte einmal eingeschaltet werden um die Fehler im tr064 Adapter weg zu bekommen. Wegen der fehlenden klartext namen musste ich auch scripte mit der IP als Namen anpassen..
                            Soviel zu meinen Erfahrungen…
                            Gesendet von meinem CLT-L09 mit Tapatalk
                            • Plasmachef
                              Plasmachef last edited by
                              hallo zusammen
                              ich hab die o.g. Problem seit heute auch.
                              musste den iobroker komplett neu aufsetzen weil der iot nicht wollte … jetzt klappt er, aber der tr-064 streikt.
                              host.raspberrypi	2018-09-30 12:06:37.210	info	Do not restart adapter system.adapter.tr-064.0 because disabled or deleted
                              host.raspberrypi	2018-09-30 12:06:37.210	error	instance system.adapter.tr-064.0 terminated with code 1 ()
                              Caught	2018-09-30 12:06:37.210	error	by controller[0]: at startup (bootstrap_node.js:153:9)
                              Caught	2018-09-30 12:06:37.210	error	by controller[0]: at run (bootstrap_node.js:387:7)
                              Caught	2018-09-30 12:06:37.210	error	by controller[0]: at Module.runMain (module.js:611:10)
                              Caught	2018-09-30 12:06:37.209	error	by controller[0]: at Function.Module._load (module.js:445:3)
                              Caught	2018-09-30 12:06:37.209	error	by controller[0]: at tryModuleLoad (module.js:453:12)
                              Caught	2018-09-30 12:06:37.209	error	by controller[0]: at Module.load (module.js:494:32)
                              Caught	2018-09-30 12:06:37.209	error	by controller[0]: at Object.Module._extensions..js (module.js:586:10)
                              Caught	2018-09-30 12:06:37.207	error	by controller[0]: at Module._compile (module.js:577:32)
                              Caught	2018-09-30 12:06:37.203	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
                              Caught	2018-09-30 12:06:37.203	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
                              Caught	2018-09-30 12:06:37.202	error	by controller[0]: TypeError: fns.adapter is not a function
                              Caught	2018-09-30 12:06:37.202	error	by controller[0]: ^
                              Caught	2018-09-30 12:06:37.202	error	by controller[0]: fns.adapter = fns.adapter(options);
                              Caught	2018-09-30 12:06:37.201	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
                              host.raspberrypi	2018-09-30 12:06:21.957	info	object change system.adapter.tr-064.0
                              host.raspberrypi	2018-09-30 12:06:05.666	info	Restart adapter system.adapter.tr-064.0 because enabled</anonymous>
                              hab es über die repo (latest) und über githud installiert … immer das selbe Problem.
                              an der fritzbox hab ich nichts geändert
                              die Installation hab ich auf einer neuen speicherkarte (raspberrypi) vorgenommen.
                              jetzt funktioniert zwar der iot, aber der tr-064 will nicht mehr ... wenn ich die alte karte wieder einsetze, dann klappt tr-064 perfekt!
                              somit würde ich die fritzbox ausschließen.
                              kann mir bitte jemand helfen?
                              grüße plasma
                              • modmax
                                modmax last edited by
                                @Plasmachef
                                Versuch mal die 0.4.14 zu installieren.
                                Man muß ja nicht immer alle Adapter aus dem latest installieren; es sei denn man will die testen,
                                zum Test beitragen oder braucht neue Features des Adapters.
                                Sonst reicht meist der default-Zweig aus; der auch als "stable" gelten kann,
                                während latest eher sowas wie "in der Testphase" bedeutet.
                                Adapter kannste über die Seite "Adapter" selber downgraden:
                                Erweiterte Einstellungen aktivieren und dann ganz rechts den +-Button benutzen.
                                MfG Markus
                                • Plasmachef
                                  herzlichen dank für den tipp!
                                  …das hat geholfen 🙂
                                  als ich jedoch nach der stable-version die latest zum test nochmals drübergelegt hatte, war der fehler auch weg.
                                  Dankeschön !!!
                                    mcdance last edited by
                                    leider bin ich auch von einem Fehler betroffen, die vorschläge den Adapter zu Aktualisieren oder zu downgraden habe ich schon gemacht.
                                    Ich habe nur den Server (Debian) neu gestartet, zuvor lief alles ohne probleme….
                                    anbei der LOG
                                    host.debianIOBroker	2018-10-06 15:28:23.898	info	Restart adapter system.adapter.tr-064.0 because enabled
                                    host.debianIOBroker	2018-10-06 15:28:23.898	error	instance system.adapter.tr-064.0 terminated with code 0 (OK)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:322:31)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at Object.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at Object.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at Parser.emit (events.js:188:7)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at emitOne (events.js:96:13)
                                    Caught	2018-10-06 15:28:23.898	error	(/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)" style="">by controller[0]: at Parser. <anonymous>(/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                                    Caught	2018-10-06 15:28:23.898	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064/lib/phonebook.js:144:82
                                    Caught	2018-10-06 15:28:23.897	error	by controller[0]: TypeError: Cannot read property 'length' of undefined
                                    tr-064.0	2018-10-06 15:28:23.888	info	terminating
                                    tr-064.0	2018-10-06 15:28:23.885	error	at Parser.exports.Parser.Parser.parseString (/opt/iobroker/node_modules/xml2js/lib/parser.js:322:31)
                                    tr-064.0	2018-10-06 15:28:23.885	error	at Object.write (/opt/iobroker/node_modules/sax/lib/sax.js:1436:13)
                                    tr-064.0	2018-10-06 15:28:23.885	error	at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                    tr-064.0	2018-10-06 15:28:23.885	error	at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                    tr-064.0	2018-10-06 15:28:23.885	error	at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                    tr-064.0	2018-10-06 15:28:23.885	error	at Object.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:261:26)
                                    tr-064.0	2018-10-06 15:28:23.885	error	at Parser.emit (events.js:188:7)
                                    tr-064.0	2018-10-06 15:28:23.885	error	at emitOne (events.js:96:13)
                                    tr-064.0	2018-10-06 15:28:23.885	error	(/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)" style="">at Parser. <anonymous>(/opt/iobroker/node_modules/xml2js/lib/parser.js:303:18)
                                    tr-064.0	2018-10-06 15:28:23.885	error	at /opt/iobroker/node_modules/iobroker.tr-064/lib/phonebook.js:144:82
                                    tr-064.0	2018-10-06 15:28:23.885	error	TypeError: Cannot read property 'length' of undefined
                                    tr-064.0	2018-10-06 15:28:23.883	error	uncaught exception: Cannot read property 'length' of undefined
                                    tr-064.0	2018-10-06 15:28:21.761	info	starting. Version 0.4.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v6.14.4
                                    host.debianIOBroker	2018-10-06 15:28:21.029	info	instance system.adapter.tr-064.0 started with pid 3366</anonymous></anonymous>
                                      Ich glaube den Fehler gefunden zu haben:
                                      Hatte in der FB mehrere Telefonbücher angelegt, je Mobilteil eins, damit kommt der Adapter scheinbar nicht klar,
                                      nachdem ich "Verwende Telefonbuch (Namensauflösung)" den hacken genommen hatte, läuft der Adapter wieder wie gehabt
                                        Supermicha last edited by
                                        Moin. Hab auch ein paar Probleme mit dem tr-064 Adapter.
                                        Problem 1: Die externe IP wird nicht angezeigt.
                                        Das Problem hatte ich schon vor einiger Zeit einmal, damals hatte sich das Problem von selbst gelöst..
                                        Mittlerweile ist seit ca. 2 oder 3 Wochen die Anzeige wieder futsch.
                                        Problem 2: Die json-Liste der vorhandenen Geräte wird nicht aktualisiert.
                                        In der Objektübersicht werden bei "Devices" alle Geräte korrekt mit ihrem aktuellen Status "active" true oder false angezeigt.
                                        Anwesenheitsscripte, die auf diese Werte zugreifen, laufen auch problemlos.
                                        Aber ich json-Liste, welche ich mit im meinem VIS anzeigen lassen, listet alle Geräte aus "active = true". Der Timestamp ist immer aktuell, trotzdem ändert sich an der Liste nichts…
                                        Problem 3: Aktualisierte Werte werden gelb.
                                        Also die Objekte werden richtig aktualisiert, aber nachdem sie kurz grün waren, werden sie gelb und Quality sagt "not connected [0x12]"
                                        Im Log tauchen kein Fehlermeldungen auf.
                                        Log auf Debug gestellt, und es werden, wie gewünscht, alle 10 Sekunden alle Geräte abgefragt und aktive/inaktive Geräte auch entsprechend zu erkennen….
                                        2018-10-20 19:36:30.946 - debug: tr-064.0 forEachConfiguredDevice: i=18 Laserdrucker active=0
                                        node und nodejs v8.11.1
                                        npm v4.6.1
                                        js-controller 1.5.3
                                          Thosch last edited by
                                          habe am Wochenende meine Fritzbox 7490 auf 7.01 geupdatet.
                                          Seidem funktioniert allerdings der tr-064 adapter nicht mehr.
                                          Der log schreibt, dass er nicht zur box verbinden kann:
                                          host.server	2018-11-12 23:33:05.381	error	instance system.adapter.tr-064.0 terminated with code 1 ()
                                          tr-064.0	2018-11-12 23:33:00.371	error	~
                                          tr-064.0	2018-11-12 23:33:00.371	error	~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
                                          tr-064.0	2018-11-12 23:33:00.371	error	~~ Fatal error. Can not connect to your FritzBox.
                                          tr-064.0	2018-11-12 23:33:00.371	error	!device - "!device"
                                          Mir scheint, dass der tr-064 Zugang der box nicht mehr aktiv ist. In den Netzwerkeinstellungen der box finde ich auch keine passage mehr, in der man tr-064 aktiviere kann.
                                          Neustart der box oder neuinstallation des Adapters brachten leider auch keine Abhilfe.
                                          Hat jemand eine Idee, oder funktioniert tr064 evtl mit der neuen FritzOS Version nicht mehr?
                                            Ich habe auch 7.0 und alles tut. Checke doch mal de Einstellungen bei dem User mit dem Du zugreifst das da die korrekten Häckchen (noch) gesetzt sind
                                            81.1k
                                            90
                                            22291
