    4. [Aufruf] ZigBee CC253x Adapter
      A Former User last edited by
      Page not found 404
      https://github.com/Koenkk/Z-Stack-firmw … sed_buffer
        ahh er hat es gemerget … hab gerade die Seite aktualisiert.. schau mal jetzt
        das ist wichtig````
        Update buffer sizes.
          der_Auge last edited by
          zigbee.0	2018-09-16 19:16:17.497	info	new dev 0x000b57fffecae610 60323 TRADFRI bulb E27 W opal 1000lm
          zigbee.0	2018-09-16 19:16:13.386	info	(0x00158d000243526d): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
          zigbee.0	2018-09-16 19:16:13.386	info	(0x00158d000245ad73): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
          zigbee.0	2018-09-16 19:16:13.386	info	(0x00158d000245ac95): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
          zigbee.0	2018-09-16 19:16:13.386	info	(0x000b57fffecae610): LED1623G12 - IKEA TRADFRI LED bulb E27 1000 lumen, dimmable, opal white (Router)
          zigbee.0	2018-09-16 19:16:13.384	info	(0x7cb03eaa00ac2638): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
          zigbee.0	2018-09-16 19:16:13.372	info	zigbee-shepherd ready
          zigbee.0	2018-09-16 19:16:13.366	info	zigbee-shepherd started!
          zigbee.0	2018-09-16 19:16:12.826	info	Start on port: /dev/ttyACM0 with panID 6754 channel 11
          zigbee.0	2018-09-16 19:16:12.796	info	starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.12.0
          host.NUC	2018-09-16 19:16:11.705	info	instance system.adapter.zigbee.0 started with pid 31517
          host.NUC	2018-09-16 19:16:09.304	info	instance system.adapter.zigbee.0 terminated with code 0 (OK)
          Caught	2018-09-16 19:16:09.304	error	by controller[8]: Sun, 16 Sep 2018 17:16:09 GMT zigbee:controller info zigbee-shepherd stopped undefined
          Caught	2018-09-16 19:16:09.304	error	by controller[8]: Sun, 16 Sep 2018 17:16:09 GMT cc-znp The serialport /dev/ttyACM0 is closed.
          Caught	2018-09-16 19:16:09.304	error	by controller[7]: Sun, 16 Sep 2018 17:16:09 GMT cc-znp:SREQ --> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
          Caught	2018-09-16 19:16:09.304	error	by controller[7]: Sun, 16 Sep 2018 17:16:09 GMT zigbee-shepherd:request REQ --> ZDO:mgmtPermitJoinReq
          Caught	2018-09-16 19:16:09.304	error	by controller[6]: Sun, 16 Sep 2018 17:15:40 GMT zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
          Caught	2018-09-16 19:16:09.304	error	by controller[6]: Sun, 16 Sep 2018 17:15:40 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
          Caught	2018-09-16 19:16:09.304	error	by controller[5]: Sun, 16 Sep 2018 17:15:40 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 1030, srcaddr: 64321, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 49, securi
          Caught	2018-09-16 19:16:09.304	error	by controller[4]: Sun, 16 Sep 2018 17:15:40 GMT zigbee-shepherd:msgHdlr IND <-- ZDO:srcRtgInd
          Caught	2018-09-16 19:16:09.304	error	by controller[3]: Sun, 16 Sep 2018 17:15:40 GMT cc-znp:AREQ <-- ZDO:srcRtgInd, { dstaddr: 64321, relaycount: 1, relaylist: <buffer a3/eb="">}
          Caught	2018-09-16 19:16:09.303	error	by controller[2]: Sun, 16 Sep 2018 17:15:39 GMT zigbee:controller debug Join countdown 0
          zigbee.0	2018-09-16 19:16:09.280	info	zigbee-shepherd stopped
          zigbee.0	2018-09-16 19:16:09.190	debug	cleaned everything up...
          host.NUC	2018-09-16 19:16:09.188	info	stopInstance system.adapter.zigbee.0 killing pid 27604
          host.NUC	2018-09-16 19:16:09.187	info	object change system.adapter.zigbee.0</buffer>
          Ist hier ein Problem?
          erst hat er das Device in der Liste dann meint er es ist neu.
          Frage: Wie kann das neue CC2531ZNP-Prod.hex übertragen werden?
          Benötigt man das Debug-Gerät?
          Jürgen
            Sinalco last edited by
            Bei meinem Osram Band bekomme ich momentan immer die Fehlermeldung (siehe unten), ich kann grad gar nichts mehr machen, es ist grad an aber egal welchen Wert ich setze es passiert nichts:
            zigbee.0	2018-09-16 20:16:57.427	error	Zigbee publish to '0x7cb03eaa000024ef', lightingColorCtrl - moveToColor - {"colorx":37800.587999999996,"colory":25499.6685,"transtime":0} - 3 failed with error Error: AF data request fails, status cod
            zigbee.0	2018-09-16 20:16:55.051	error	Zigbee publish to '0x7cb03eaa000024ef', genLevelCtrl - moveToLevel - {"level":254,"transtime":0} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
            zigbee.0	2018-09-16 20:16:52.427	error	Zigbee publish to '0x7cb03eaa000024ef', lightingColorCtrl - moveToColorTemp - {"colortemp":370,"transtime":0} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
            zigbee.0	2018-09-16 20:16:49.946	error	Zigbee publish to '0x7cb03eaa000024ef', genOnOff - on - {} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
            zigbee.0	2018-09-16 20:16:47.987	error	Zigbee publish to '0x7cb03eaa000024ef', lightingColorCtrl - moveToColorTemp - {"colortemp":370,"transtime":0} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
            zigbee.0	2018-09-16 20:16:46.568	error	Zigbee publish to '0x7cb03eaa000024ef', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
            zigbee.0	2018-09-16 20:16:44.142	error	Zigbee publish to '0x7cb03eaa000024ef', genOnOff - off - {} - 3 failed with error Error: AF data request fails, status code: 233\. MAC no ack.
            EDIT:
            Hab wohl auf das grüne Pairing Zeichen des Osram Bandes geklickt.
            Für was auch immer der Button ist??? Wenn man da drauf klickt funktioniert wohl das Gerät nicht mehr. Bei meinen Sensoren gibt es keinen so einen grünen Button.
            Jetzt hab ich auf den normalen Pairing Button oben rechts geklickt und das Band neu verbunden.
            Jetzt funktioniert es wieder!
            Übrigens funktionieren auch nur 6 Stellige Hex Farbcodes, wie auf der Seite und auch nicht alle:
            http://www.december.com/html/spec/colorhslhex10.html
            Weis jemand wie man das konvertieren kann um es in vis darzustellen?
              @der_Auge:
              new dev 0x000b57fffecae610 `
              nein das passiert ab und an bei mir auch nach dem Adapter neustart..warum auc himmer.. aber dann auch nur mit den Osram Teilen.. ich vermute die werden nicht richtig in den Betrieb zustan genommen.. ergo laufen die in den Erkennungsmodus rein… funktionieren aber ganz normal
              und ja man Benötigt ein DEbug modul
              wobei ALLE DIE DEN STICK VON MIR HABEN DIESES FILE DRAUF
              zu dem Band Problem.. hast du mal den Stecker gezogen.. und wieder rein.. das Band müsste sich dann rekonnencten..
              der grüne Button am Gerät sollte das auch machen ..
                Feliiix last edited by
                habe ein Problem mit dem Tradfri Dimmer von IKEA. Er wird erkannt jedoch werden keine Objekte angelegt. Gibt es dafür eine Lösung?
                Gruß Felix
                  der geht nicht… bist nich der erste der das feststellt
                    @arteck:
                    der geht nicht… bist nich der erste der das feststellt `
                    Bei zigbee2mqtt wird der Dimmer unterstützt: https://github.com/Koenkk/zigbee2mqtt/w … ed-devices
                    Woran liegt es, dass das Gerät mit dem ioBroker Adapter nicht funktioniert?
                      weil er noch nicht implementiert ist im Adapter..
                      stell bitte auf GIT ein issue
                        Okay. Das hat schon jemand für mich erledigt 😉
                        https://github.com/ioBroker/ioBroker.zigbee/issues/54
                        axelbub created this issue in ioBroker/ioBroker.zigbee
                        closed TRADFRI wireless dimmer #54
                        • a200
                          a200 last edited by
                          Moin,
                          wie ist jetzt der Stand?
                          @der_Auge:
                          Ist zwar keine Antwort auf deine Frage:
                          Aber:
                          Was hast du für Bewegungsmelder?
                          1. Generation
                          2. Generation des Bewegungsmelders , da diese einen Lichtsensor besitzt.
                          Ich habe :
                          Jürgen `
                          welche Generation ist jetzt dein Bewegungsmelder? Ich habe welche mit einem Loch (wie bei deinem Foto) und mit einem Taster gesehen.
                          Welche Version ist jetzt die aktuelle und lassen sich beide einbinden?
                          Vielen herzlichen Dank für die Infos.
                          a200.
                            hawi1981 last edited by
                            Ich habe beide Versionen und beide angebunden. Der mit dem Taster von Aquara ist einfacher einzubinden, da man bei den Sensoren nur einmal den Taster für 3 Sekunden drücken muss und geht es. Bei den anderen ist es ein wenig schwieriger, wie auch auf der Adapterseite bei Github beschrieben:
                            https://github.com/Koenkk/zigbee2mqtt/w … ng-devices
                            ` > Xiaomi
                            Different devices require different pairing methods. In case you get an Error [ERR_UNHANDLED_ERROR]: Unhandled error. (Cannot get the Node Descriptor of the Device: 0x00158d0001720111) you should try a different pairing method. See Supported devices to figure out if your device is MiJia or Aqara.
                            Most MiJia devices: press and hold the reset button on the device for +- 5 seconds (until the blue light starts blinking). IMPORTANT: Release and start pressing the reset button every second. This keeps the device awake, otherwise pairing will fail!.
                            Most Aqara devices: press and hold reset button on the device for +- 5 seconds (until the blue light starts blinking), release and wait.
                            Most Aqara wall switches: press and hold the button on the device for +- 10 seconds (until the blue light starts blinking and stops blinking), release and wait. `
                              mafe68 last edited by
                              Konnte mein Problem jetzt lösen mit den Fenster Türkontakte da sie nach kurzen Zeit keine Verbindern mehr aufgebaut haben und ich sie dann jedes mal neu Anlernen musste. Die Lösung war ich habe nach dem Tipp von @arteck die aktuelle Firmware auf den CC2531 Zigbee Stick geflasht und jetzt geht es. Danke an @arteck nochmal für den Tipp
                              • Lenny.CB
                                Lenny.CB Most Active last edited by
                                seit gestern macht mein zigbee-Adapter faxen…
                                Woher kommt das?
                                Caught	2018-09-22 09:11:24.014	error	by controller[33]: Sat, 22 Sep 2018 07:11:23 GMT cc-znp:SREQ --> ZDO:mgmtPermitJoinReq, { addrmode: 15, dstaddr: 65532, duration: 0, tcsignificance: 0 }
                                Caught	2018-09-22 09:11:24.014	error	by controller[33]: Sat, 22 Sep 2018 07:11:23 GMT zigbee-shepherd:request REQ --> ZDO:mgmtPermitJoinReq
                                Caught	2018-09-22 09:11:24.014	error	by controller[32]: data: { '16': 10068, '20': -1, measuredValue: 1006 } } } { cid: 'msPressureMeasurement', modelId: 'lumi.weather' }
                                Caught	2018-09-22 09:11:24.014	error	by controller[32]: { cid: 'msPressureMeasurement',
                                Caught	2018-09-22 09:11:24.014	error	by controller[32]: report: [Function] } ],
                                Caught	2018-09-22 09:11:24.009	error	by controller[32]: write: [Function],
                                Caught	2018-09-22 09:11:24.004	error	by controller[32]: read: [Function],
                                Caught	2018-09-22 09:11:24.004	error	by controller[32]: unbind: [Function],
                                Caught	2018-09-22 09:11:24.003	error	by controller[32]: bind: [Function],
                                Caught	2018-09-22 09:11:24.003	error	by controller[32]: functional: [Function],
                                Caught	2018-09-22 09:11:24.003	error	by controller[32]: foundation: [Function],
                                Caught	2018-09-22 09:11:24.003	error	by controller[32]: onZclFunctional: null,
                                Caught	2018-09-22 09:11:24.003	error	by controller[32]: onZclFoundation: null,
                                Caught	2018-09-22 09:11:24.003	error	by controller[32]: onAfIncomingMsgExt: null,
                                Caught	2018-09-22 09:11:24.003	error	by controller[32]: onAfIncomingMsg: null,
                                Caught	2018-09-22 09:11:24.002	error	by controller[32]: onAfReflectError: null,
                                Caught	2018-09-22 09:11:24.002	error	by controller[32]: onAfDataConfirm: null,
                                Caught	2018-09-22 09:11:24.002	error	by controller[32]: clusters: [Object],
                                Caught	2018-09-22 09:11:24.002	error	by controller[32]: outClusterList: [Object],
                                Caught	2018-09-22 09:11:24.002	error	by controller[32]: inClusterList: [Object],
                                Caught	2018-09-22 09:11:24.002	error	by controller[32]: devId: 24321,
                                Caught	2018-09-22 09:11:24.002	error	by controller[32]: epId: 1,
                                Caught	2018-09-22 09:11:24.002	error	by controller[32]: profId: 260,
                                Caught	2018-09-22 09:11:24.001	error	by controller[32]: device: [Object],
                                Caught	2018-09-22 09:11:24.001	error	by controller[32]: isLocal: [Function],
                                Caught	2018-09-22 09:11:24.001	error	by controller[32]: [ Endpoint {
                                Caught	2018-09-22 09:11:24.001	error	by controller[32]: endpoints:
                                Caught	2018-09-22 09:11:24.001	error	by controller[32]: 2018-09-22T07:11:15.646Z zigbee:controller event devChange { type: 'devChange',
                                Caught	2018-09-22 09:11:24.001	error	by controller[31]: data: { '16': 10068, '20': -1, measuredValue: 1006 } } }
                                Caught	2018-09-22 09:11:24.001	error	by controller[31]: { cid: 'msPressureMeasurement',
                                Caught	2018-09-22 09:11:24.000	error	by controller[31]: report: [Function] } ],
                                Caught	2018-09-22 09:11:24.000	error	by controller[31]: write: [Function],
                                Caught	2018-09-22 09:11:24.000	error	by controller[31]: read: [Function],
                                Caught	2018-09-22 09:11:24.000	error	by controller[31]: unbind: [Function],
                                Caught	2018-09-22 09:11:24.000	error	by controller[31]: bind: [Function],
                                Caught	2018-09-22 09:11:24.000	error	by controller[31]: functional: [Function],
                                Caught	2018-09-22 09:11:24.000	error	by controller[31]: foundation: [Function],
                                Caught	2018-09-22 09:11:23.999	error	by controller[31]: onZclFunctional: null,
                                Caught	2018-09-22 09:11:23.999	error	by controller[31]: onZclFoundation: null,
                                Caught	2018-09-22 09:11:23.999	error	by controller[31]: onAfIncomingMsgExt: null,
                                Caught	2018-09-22 09:11:23.999	error	by controller[31]: onAfIncomingMsg: null,
                                Caught	2018-09-22 09:11:23.999	error	by controller[31]: onAfReflectError: null,
                                Caught	2018-09-22 09:11:23.999	error	by controller[31]: onAfDataConfirm: null,
                                Caught	2018-09-22 09:11:23.999	error	by controller[31]: clusters: [Object],
                                Caught	2018-09-22 09:11:23.999	error	by controller[31]: outClusterList: [Object],
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: inClusterList: [Object],
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: devId: 24321,
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: epId: 1,
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: profId: 260,
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: device: [Object],
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: isLocal: [Function],
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: [ Endpoint {
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: endpoints:
                                Caught	2018-09-22 09:11:23.998	error	by controller[31]: 2018-09-22T07:11:15.643Z zigbee:controller debug handleMessage { type: 'devChange',
                                Caught	2018-09-22 09:11:23.997	error	by controller[30]: data: { cid: 'msRelativeHumidity', data: { measuredValue: 4402 } } } { cid: 'msRelativeHumidity', modelId: 'lumi.weather' }
                                Caught	2018-09-22 09:11:23.997	error	by controller[30]: report: [Function] } ],
                                Caught	2018-09-22 09:11:23.997	error	by controller[30]: write: [Function],
                                Caught	2018-09-22 09:11:23.997	error	by controller[30]: read: [Function],
                                Caught	2018-09-22 09:11:23.997	error	by controller[30]: unbind: [Function],
                                Caught	2018-09-22 09:11:23.997	error	by controller[30]: bind: [Function],
                                Caught	2018-09-22 09:11:23.997	error	by controller[30]: functional: [Function],
                                Caught	2018-09-22 09:11:23.996	error	by controller[30]: foundation: [Function],
                                Caught	2018-09-22 09:11:23.996	error	by controller[30]: onZclFunctional: null,
                                Caught	2018-09-22 09:11:23.996	error	by controller[30]: onZclFoundation: null,
                                Caught	2018-09-22 09:11:23.996	error	by controller[30]: onAfIncomingMsgExt: null,
                                Caught	2018-09-22 09:11:23.996	error	by controller[30]: onAfIncomingMsg: null,
                                Caught	2018-09-22 09:11:23.996	error	by controller[30]: onAfReflectError: null,
                                Caught	2018-09-22 09:11:23.996	error	by controller[30]: onAfDataConfirm: null,
                                Caught	2018-09-22 09:11:23.996	error	by controller[30]: clusters: [Object],
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: outClusterList: [Object],
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: inClusterList: [Object],
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: devId: 24321,
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: epId: 1,
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: profId: 260,
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: device: [Object],
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: isLocal: [Function],
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: [ Endpoint {
                                Caught	2018-09-22 09:11:23.995	error	by controller[30]: endpoints:
                                Caught	2018-09-22 09:11:23.994	error	by controller[30]: 2018-09-22T07:11:15.639Z zigbee:controller event devChange { type: 'devChange',
                                Caught	2018-09-22 09:11:23.994	error	by controller[29]: data: { cid: 'msRelativeHumidity', data: { measuredValue: 4402 } } }
                                Caught	2018-09-22 09:11:23.994	error	by controller[29]: report: [Function] } ],
                                Caught	2018-09-22 09:11:23.994	error	by controller[29]: write: [Function],
                                Caught	2018-09-22 09:11:23.994	error	by controller[29]: read: [Function],
                                Caught	2018-09-22 09:11:23.994	error	by controller[29]: unbind: [Function],
                                Caught	2018-09-22 09:11:23.994	error	by controller[29]: bind: [Function],
                                Caught	2018-09-22 09:11:23.994	error	by controller[29]: functional: [Function],
                                Caught	2018-09-22 09:11:23.993	error	by controller[29]: foundation: [Function],
                                Caught	2018-09-22 09:11:23.993	error	by controller[29]: onZclFunctional: null,
                                Caught	2018-09-22 09:11:23.993	error	by controller[29]: onZclFoundation: null,
                                Caught	2018-09-22 09:11:23.993	error	by controller[29]: onAfIncomingMsgExt: null,
                                Caught	2018-09-22 09:11:23.993	error	by controller[29]: onAfIncomingMsg: null,
                                Caught	2018-09-22 09:11:23.993	error	by controller[29]: onAfReflectError: null,
                                Caught	2018-09-22 09:11:23.993	error	by controller[29]: onAfDataConfirm: null,
                                Caught	2018-09-22 09:11:23.993	error	by controller[29]: clusters: [Object],
                                Caught	2018-09-22 09:11:23.992	error	by controller[29]: outClusterList: [Object],
                                Caught	2018-09-22 09:11:23.992	error	by controller[29]: inClusterList: [Object],
                                Caught	2018-09-22 09:11:23.992	error	by controller[29]: devId: 24321,
                                Caught	2018-09-22 09:11:23.992	error	by controller[29]: epId: 1,
                                Caught	2018-09-22 09:11:23.992	error	by controller[29]: profId: 260,
                                Caught	2018-09-22 09:11:23.992	error	by controller[29]: device: [Object],
                                Caught	2018-09-22 09:11:23.992	error	by controller[29]: isLocal: [Function],
                                Caught	2018-09-22 09:11:23.992	error	by controller[29]: [ Endpoint {
                                Caught	2018-09-22 09:11:23.991	error	by controller[29]: endpoints:
                                Caught	2018-09-22 09:11:23.991	error	by controller[29]: 2018-09-22T07:11:15.636Z zigbee:controller debug handleMessage { type: 'devChange',
                                Caught	2018-09-22 09:11:23.991	error	by controller[28]: data: { '16': 10068, '20': -1, measuredValue: 1006 } } } { cid: 'msPressureMeasurement', modelId: 'lumi.weather' }
                                Caught	2018-09-22 09:11:23.991	error	by controller[28]: { cid: 'msPressureMeasurement',
                                Caught	2018-09-22 09:11:23.991	error	by controller[28]: report: [Function] } ],
                                Caught	2018-09-22 09:11:23.991	error	by controller[28]: write: [Function],
                                Caught	2018-09-22 09:11:23.991	error	by controller[28]: read: [Function],
                                Caught	2018-09-22 09:11:23.990	error	by controller[28]: unbind: [Function],
                                Caught	2018-09-22 09:11:23.990	error	by controller[28]: bind: [Function],
                                Caught	2018-09-22 09:11:23.990	error	by controller[28]: functional: [Function],
                                Caught	2018-09-22 09:11:23.990	error	by controller[28]: foundation: [Function],
                                Caught	2018-09-22 09:11:23.990	error	by controller[28]: onZclFunctional: null,
                                Caught	2018-09-22 09:11:23.990	error	by controller[28]: onZclFoundation: null,
                                Caught	2018-09-22 09:11:23.990	error	by controller[28]: onAfIncomingMsgExt: null,
                                Caught	2018-09-22 09:11:23.990	error	by controller[28]: onAfIncomingMsg: null,
                                Caught	2018-09-22 09:11:23.989	error	by controller[28]: onAfReflectError: null,
                                Caught	2018-09-22 09:11:23.989	error	by controller[28]: onAfDataConfirm: null,
                                Caught	2018-09-22 09:11:23.989	error	by controller[28]: clusters: [Object],
                                Caught	2018-09-22 09:11:23.989	error	by controller[28]: outClusterList: [Object],
                                Caught	2018-09-22 09:11:23.989	error	by controller[28]: inClusterList: [Object],
                                Caught	2018-09-22 09:11:23.989	error	by controller[28]: devId: 24321,
                                Caught	2018-09-22 09:11:23.989	error	by controller[28]: epId: 1,
                                Caught	2018-09-22 09:11:23.989	error	by controller[28]: profId: 260,
                                Caught	2018-09-22 09:11:23.988	error	by controller[28]: device: [Object],
                                Caught	2018-09-22 09:11:23.988	error	by controller[28]: isLocal: [Function],
                                Caught	2018-09-22 09:11:23.988	error	by controller[28]: [ Endpoint {
                                Caught	2018-09-22 09:11:23.988	error	by controller[28]: endpoints:
                                Caught	2018-09-22 09:11:23.988	error	by controller[28]: 2018-09-22T07:11:15.631Z zigbee:controller event attReport { type: 'attReport',
                                Caught	2018-09-22 09:11:23.988	error	by controller[27]: data: { '16': 10068, '20': -1, measuredValue: 1006 } } }
                                Caught	2018-09-22 09:11:23.988	error	by controller[27]: { cid: 'msPressureMeasurement',
                                Caught	2018-09-22 09:11:23.987	error	by controller[27]: report: [Function] } ],
                                Caught	2018-09-22 09:11:23.987	error	by controller[27]: write: [Function],
                                Caught	2018-09-22 09:11:23.987	error	by controller[27]: read: [Function],
                                Caught	2018-09-22 09:11:23.987	error	by controller[27]: unbind: [Function],
                                Caught	2018-09-22 09:11:23.987	error	by controller[27]: bind: [Function],
                                Caught	2018-09-22 09:11:23.987	error	by controller[27]: functional: [Function],
                                Caught	2018-09-22 09:11:23.987	error	by controller[27]: foundation: [Function],
                                Caught	2018-09-22 09:11:23.987	error	by controller[27]: onZclFunctional: null,
                                Caught	2018-09-22 09:11:23.986	error	by controller[27]: onZclFoundation: null,
                                Caught	2018-09-22 09:11:23.986	error	by controller[27]: onAfIncomingMsgExt: null,
                                Caught	2018-09-22 09:11:23.986	error	by controller[27]: onAfIncomingMsg: null,
                                Caught	2018-09-22 09:11:23.986	error	by controller[27]: onAfReflectError: null,
                                Caught	2018-09-22 09:11:23.986	error	by controller[27]: onAfDataConfirm: null,
                                Caught	2018-09-22 09:11:23.986	error	by controller[27]: clusters: [Object],
                                Caught	2018-09-22 09:11:23.986	error	by controller[27]: outClusterList: [Object],
                                Caught	2018-09-22 09:11:23.986	error	by controller[27]: inClusterList: [Object],
                                Caught	2018-09-22 09:11:23.985	error	by controller[27]: devId: 24321,
                                Caught	2018-09-22 09:11:23.985	error	by controller[27]: epId: 1,
                                Caught	2018-09-22 09:11:23.985	error	by controller[27]: profId: 260,
                                Caught	2018-09-22 09:11:23.985	error	by controller[27]: device: [Object],
                                Caught	2018-09-22 09:11:23.985	error	by controller[27]: isLocal: [Function],
                                Caught	2018-09-22 09:11:23.985	error	by controller[27]: [ Endpoint {
                                Caught	2018-09-22 09:11:23.985	error	by controller[27]: endpoints:
                                Caught	2018-09-22 09:11:23.985	error	by controller[27]: 2018-09-22T07:11:15.629Z zigbee:controller debug handleMessage { type: 'attReport',
                                Caught	2018-09-22 09:11:23.984	error	by controller[26]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                                Caught	2018-09-22 09:11:23.984	error	by controller[25]: data: { cid: 'msRelativeHumidity', data: { measuredValue: 4402 } } } { cid: 'msRelativeHumidity', modelId: 'lumi.weather' }
                                Caught	2018-09-22 09:11:23.984	error	by controller[25]: report: [Function] } ],
                                Caught	2018-09-22 09:11:23.984	error	by controller[25]: write: [Function],
                                Caught	2018-09-22 09:11:23.984	error	by controller[25]: read: [Function],
                                Caught	2018-09-22 09:11:23.984	error	by controller[25]: unbind: [Function],
                                Caught	2018-09-22 09:11:23.984	error	by controller[25]: bind: [Function],
                                Caught	2018-09-22 09:11:23.984	error	by controller[25]: functional: [Function],
                                Caught	2018-09-22 09:11:23.983	error	by controller[25]: foundation: [Function],
                                Caught	2018-09-22 09:11:23.983	error	by controller[25]: onZclFunctional: null,
                                Caught	2018-09-22 09:11:23.983	error	by controller[25]: onZclFoundation: null,
                                Caught	2018-09-22 09:11:23.983	error	by controller[25]: onAfIncomingMsgExt: null,
                                Caught	2018-09-22 09:11:23.983	error	by controller[25]: onAfIncomingMsg: null,
                                Caught	2018-09-22 09:11:23.983	error	by controller[25]: onAfReflectError: null,
                                Caught	2018-09-22 09:11:23.983	error	by controller[25]: onAfDataConfirm: null,
                                Caught	2018-09-22 09:11:23.983	error	by controller[25]: clusters: [Object],
                                Caught	2018-09-22 09:11:23.982	error	by controller[25]: outClusterList: [Object],
                                Caught	2018-09-22 09:11:23.982	error	by controller[25]: inClusterList: [Object],
                                Caught	2018-09-22 09:11:23.982	error	by controller[25]: devId: 24321,
                                Caught	2018-09-22 09:11:23.982	error	by controller[25]: epId: 1,
                                Caught	2018-09-22 09:11:23.982	error	by controller[25]: profId: 260,
                                Caught	2018-09-22 09:11:23.982	error	by controller[25]: device: [Object],
                                Caught	2018-09-22 09:11:23.982	error	by controller[25]: isLocal: [Function],
                                Caught	2018-09-22 09:11:23.982	error	by controller[25]: [ Endpoint {
                                Caught	2018-09-22 09:11:23.981	error	by controller[25]: endpoints:
                                Caught	2018-09-22 09:11:23.981	error	by controller[25]: 2018-09-22T07:11:15.624Z zigbee:controller event attReport { type: 'attReport',
                                Caught	2018-09-22 09:11:23.981	error	by controller[24]: data: { cid: 'msRelativeHumidity', data: { measuredValue: 4402 } } }
                                Caught	2018-09-22 09:11:23.981	error	by controller[24]: report: [Function] } ],
                                Caught	2018-09-22 09:11:23.981	error	by controller[24]: write: [Function],
                                Caught	2018-09-22 09:11:23.981	error	by controller[24]: read: [Function],
                                Caught	2018-09-22 09:11:23.981	error	by controller[24]: unbind: [Function],
                                Caught	2018-09-22 09:11:23.981	error	by controller[24]: bind: [Function],
                                Caught	2018-09-22 09:11:23.980	error	by controller[24]: functional: [Function],
                                Caught	2018-09-22 09:11:23.980	error	by controller[24]: foundation: [Function],
                                Caught	2018-09-22 09:11:23.980	error	by controller[24]: onZclFunctional: null,
                                Caught	2018-09-22 09:11:23.980	error	by controller[24]: onZclFoundation: null,
                                Caught	2018-09-22 09:11:23.980	error	by controller[24]: onAfIncomingMsgExt: null,
                                Caught	2018-09-22 09:11:23.980	error	by controller[24]: onAfIncomingMsg: null,
                                Caught	2018-09-22 09:11:23.980	error	by controller[24]: onAfReflectError: null,
                                Caught	2018-09-22 09:11:23.980	error	by controller[24]: onAfDataConfirm: null,
                                Caught	2018-09-22 09:11:23.979	error	by controller[24]: clusters: [Object],
                                Caught	2018-09-22 09:11:23.979	error	by controller[24]: outClusterList: [Object],
                                Caught	2018-09-22 09:11:23.979	error	by controller[24]: inClusterList: [Object],
                                Caught	2018-09-22 09:11:23.979	error	by controller[24]: devId: 24321,
                                Caught	2018-09-22 09:11:23.979	error	by controller[24]: epId: 1,
                                Caught	2018-09-22 09:11:23.979	error	by controller[24]: profId: 260,
                                Caught	2018-09-22 09:11:23.979	error	by controller[24]: device: [Object],
                                Caught	2018-09-22 09:11:23.979	error	by controller[24]: isLocal: [Function],
                                Caught	2018-09-22 09:11:23.978	error	by controller[24]: [ Endpoint {
                                Caught	2018-09-22 09:11:23.978	error	by controller[24]: endpoints:
                                Caught	2018-09-22 09:11:23.978	error	by controller[24]: 2018-09-22T07:11:15.621Z zigbee:controller debug handleMessage { type: 'attReport',
                                Caught	2018-09-22 09:11:23.978	error	by controller[23]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: zclIncomingMsg, msg: [object Object]
                                Caught	2018-09-22 09:11:23.978	error	by controller[22]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                                Caught	2018-09-22 09:11:23.978	error	by controller[21]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                                Caught	2018-09-22 09:11:23.978	error	by controller[20]: Sat, 22 Sep 2018 07:11:15 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 1027, srcaddr: 23198, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 55, secur
                                Caught	2018-09-22 09:11:23.977	error	by controller[19]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:msgHdlr IND <-- AF:incomingMsg, transId: 0
                                Caught	2018-09-22 09:11:23.977	error	by controller[18]: Sat, 22 Sep 2018 07:11:15 GMT zigbee-shepherd:af dispatchIncomingMsg(): type: incomingMsg, msg: [object Object]
                                Caught	2018-09-22 09:11:23.977	error	by controller[17]: Sat, 22 Sep 2018 07:11:15 GMT cc-znp:AREQ <-- AF:incomingMsg, { groupid: 0, clusterid: 1029, srcaddr: 23198, srcendpoint: 1, dstendpoint: 1, wasbroadcast: 0, linkquality: 55, secur
                                Caught	2018-09-22 09:11:23.977	error	by controller[16]: data: { measuredValue: 2319 } } } { cid: 'msTemperatureMeasurement', modelId: 'lumi.weather' }
                                Caught	2018-09-22 09:11:23.977	error	by controller[16]: { cid: 'msTemperatureMeasurement',
                                Caught	2018-09-22 09:11:23.977	error	by controller[16]: report: [Function] } ],
                                Caught	2018-09-22 09:11:23.977	error	by controller[16]: write: [Function],
                                Caught	2018-09-22 09:11:23.976	error	by controller[16]: read: [Function],
                                Caught	2018-09-22 09:11:23.976	error	by controller[16]: unbind: [Function],
                                Caught	2018-09-22 09:11:23.976	error	by controller[16]: bind: [Function],
                                  hmm auch nach restart ?? des adapters ??
                                  • Lenny.CB
                                    nach restart ist es weg. kommt aber im laufe der Zeit wieder…
                                      das ist doch der eckige temp sensor der meckert….
                                      stoppe mal den adapter lösche das das eine Object und starte den adapter wieder..
                                      ansonsten was für firmware hast du drauf ?? die aus wiki ??
                                      • Lenny.CB
                                        im Moment läuft es…
                                        ja ist alles aus dem Wiki...
                                        die FW ist von der Seite: https://github.com/Koenkk/zigbee2mqtt/w … ng-started
                                        hier der Direktdownload: https://github.com/Koenkk/Z-Stack-firmw … CC2531/bin
                                          daniello last edited by
                                          Hallo allerseits, ich würde gerne einen Aqara Cutbe von 03.2018 pairen .. sehe im Log aber nur "Zigbee: allowing new devices to join." Bin auch schon dichter an den Stick gegangen (noch keine Ahnung über die ReichweiteI .. passiert aber nüscht. Könnte sein, das sich mich zu doof anstelle den Linkmodus zu initiieren .. diese chinesische Anleitung hilft nicht weiter.
                                            Lupla last edited by
                                            @daniello:
                                            passiert aber nüscht. Könnte sein, das sich mich zu doof anstelle den Linkmodus zu initiieren .. diese chinesische Anleitung hilft nicht weiter. `
                                            Hast Du den Knopf im Cube zum pairen gedrückt?
                                            1078
                                            343665
