    4. [Aufruf] Xbox Adapter testen
    • foxriver76
      @Dutchman:
      na dan mal los
      Ubuntu 16.4 LTS
      Nodejs 6.14.1
      NPM 3.10.10
      Installation ging direct aus dem admin raus per git ohne probleme, hier mal der log dazu:
      $ ./iobroker url "https://github.com/foxriver76/ioBroker.xbox" --debug
      install https://github.com/foxriver76/ioBroker.xbox/tarball/master
      npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --production --save --prefix "/opt/iobroker" (System call)
      npm WARN lifecycle iobroker.xbox@0.0.5~preinstall: cannot run in wd %s %s (wd=%s) iobroker.xbox@0.0.5 apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.' /opt/iobroker/node_modules/.staging/iobroker.xbox-4a3b83e7
      authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
      node-gyp rebuild
      ! make: Entering directory '/opt/iobroker/node_modules/authenticate-pam/build'
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
      ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: No such file or directory
      compilation terminated.
      authenticate_pam.target.mk:94: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failedmake: Leaving directory '/opt/iobroker/node_modules/authenticate-pam/build'
      make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
      ! gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack at emitTwo (events.js:106:13)
      gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
      ! gyp ERR! System Linux 4.4.0-62-genericgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      gyp ERR! node -v v6.14.1
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      ! > iobroker.xbox@0.0.5 install /opt/iobroker/node_modules/iobroker.xbox
      npip install
      ! No python_modules directory; installing pip locally if needed.
      Successfully completed pip check.
      Collecting xbox-smartglass-rest
      Downloading https://files.pythonhosted.org/packages/d4/f6/73521851d42496d7d703036bc5cb79a49144602bf4fffd85ba3bfb4afa8f/xbox_smartglass_rest-0.9.5-py2.py3-none-any.whl
      Collecting xbox-smartglass-core
      Downloading https://files.pythonhosted.org/packages/3f/9f/2e9c16dce7523dabf37dd8f1cdff44de42851d5970534baf0fe2a4f9badb/xbox_smartglass_core-1.0.10-py2.py3-none-any.whl (56kB)
      Collecting xbox-smartglass-stump>=0.9.4 (from xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/7e/ea/fae9ae03e3ef0afc3c27638e8872254bf96bd14f06dc1ba5bce08b7916c7/xbox_smartglass_stump-0.9.4-py2.py3-none-any.whl
      Collecting Flask (from xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/7f/e7/08578774ed4536d3242b14dacb4696386634607af824ea997202cd0edb4b/Flask-1.0.2-py2.py3-none-any.whl (91kB)
      Collecting construct==2.9.41 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/e6/f5/064be5013506d54212b396e8fc3e9890e60ed6a27df6d52529f0b8361cd5/construct-2.9.41.tar.gz (54kB)
      Collecting aenum==2.1.2; python_version <= "3.5" (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/0d/46/5b6a6c13fee40f9dfaba84de1394bfe082c0c7d95952ba0ffbd56ce3a3f7/aenum-2.1.2-py3-none-any.whl
      Collecting urwid==2.0.1 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/c7/90/415728875c230fafd13d118512bde3184d810d7bf798a631abc05fac09d0/urwid-2.0.1.tar.gz (604kB)
      Collecting cryptography==2.2.2 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/fa/f4/3cde3604972dfa2b0fea85b9711948bb4fb70ab64095322aef35071bd254/cryptography-2.2.2-cp34-abi3-manylinux1_x86_64.whl (2.2MB)
      Collecting dpkt==1.9.1 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/bf/a4/8e4622fac4841b5e4a347fa9da4c057a7974258df247031280008d6ac0d0/dpkt-1.9.1.tar.gz (115kB)
      Collecting gevent==1.2.2 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/13/a9/81166b3ad2d344882ab42eb222e7723f93838fdf641b17b319b3a84821a7/gevent-1.2.2-cp35-cp35m-manylinux1_x86_64.whl (1.7MB)
      Collecting xbox-webapi>=1.1.2 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/04/9c/bd60a0093db35f32263306987cb6776ac12e0d9a8911a4be1c5856ff6d0b/xbox_webapi-1.1.5-py2.py3-none-any.whl (44kB)
      Collecting appdirs==1.4.3 (from xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/56/eb/810e700ed1349edde4cbdc1b2a21e28cdf115f9faf263f6bbf8447c1abf3/appdirs-1.4.3-py2.py3-none-any.whl
      Collecting marshmallow-objects (from xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/2a/46/710e3383d1216f1f066ee16da24d144c04c2d3180bdd962f08194f123849/marshmallow_objects-1.0.14-py2.py3-none-any.whl
      Collecting itsdangerous>=0.24 (from Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/dc/b4/a60bcdba945c00f6d608d8975131ab3f25b22f2bcfe1dab221165194b2d4/itsdangerous-0.24.tar.gz (46kB)
      Collecting Werkzeug>=0.14 (from Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/20/c4/12e3e56473e52375aa29c4764e70d1b8f3efa6682bef8d0aae04fe335243/Werkzeug-0.14.1-py2.py3-none-any.whl (322kB)
      Collecting Jinja2>=2.10 (from Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/7f/ff/ae64bacdfc95f27a016a7bed8e8686763ba4d277a78ca76f32659220a731/Jinja2-2.10-py2.py3-none-any.whl (126kB)
      Collecting click>=5.1 (from Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/34/c1/8806f99713ddb993c5366c362b2f908f18269f8d792aff1abfd700775a77/click-6.7-py2.py3-none-any.whl (71kB)
      Collecting cffi>=1.7; platform_python_implementation != "PyPy" (from cryptography==2.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/59/cc/0e1635b4951021ef35f5c92b32c865ae605fac2a19d724fb6ff99d745c81/cffi-1.11.5-cp35-cp35m-manylinux1_x86_64.whl (420kB)
      Requirement already satisfied: six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography==2.2.2->xbox-smartglass-core) (1.10.0)
      Collecting asn1crypto>=0.21.0 (from cryptography==2.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/ea/cd/35485615f45f30a510576f1a56d1e0a7ad7bd8ab5ed7cdc600ef7cd06222/asn1crypto-0.24.0-py2.py3-none-any.whl (101kB)
      Collecting idna>=2.1 (from cryptography==2.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/4b/2a/0276479a4b3caeb8a8c1af2f8e4355746a97fab05a372e4a2c6a6b876165/idna-2.7-py2.py3-none-any.whl (58kB)
      Collecting greenlet>=0.4.10 (from gevent==1.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/2e/65/27f35497cc0102a792390d056e793e064da95fc9eae45d75ae0ba49c0a0d/greenlet-0.4.15-cp35-cp35m-manylinux1_x86_64.whl (41kB)
      Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from xbox-webapi>=1.1.2->xbox-smartglass-core) (2.9.1)
      Collecting demjson (from xbox-webapi>=1.1.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/96/67/6db789e2533158963d4af689f961b644ddd9200615b8ce92d6cad695c65a/demjson-2.2.4.tar.gz (131kB)
      Collecting marshmallow (from marshmallow-objects->xbox-smartglass-stump>=0.9.4->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/d5/32/57d464c250d7a15705d8eb3be9b8b002c611e414940d452b8756e3879bcd/marshmallow-2.15.5-py2.py3-none-any.whl (44kB)
      Collecting MarkupSafe>=0.23 (from Jinja2>=2.10->Flask->xbox-smartglass-rest)
      Downloading https://files.pythonhosted.org/packages/4d/de/32d741db316d8fdb7680822dd37001ef7a448255de9699ab4bfcbdf4172b/MarkupSafe-1.0.tar.gz
      Collecting pycparser (from cffi>=1.7; platform_python_implementation != "PyPy"->cryptography==2.2.2->xbox-smartglass-core)
      Downloading https://files.pythonhosted.org/packages/68/9e/49196946aee219aead1290e00d1e7fdeab8567783e83e1b9ab5585e6206a/pycparser-2.19.tar.gz (158kB)
      Building wheels for collected packages: construct, urwid, dpkt, itsdangerous, demjson, MarkupSafe, pycparser
      Running setup.py bdist_wheel for construct: started
      Running setup.py bdist_wheel for construct: finished with status 'done' Stored in directory: /root/.cache/pip/wheels/13/cd/02/acabe4bfa9899d53c3e3b13675610d2e2dcb9ae110359d4f61
      ! Running setup.py bdist_wheel for urwid: started
      Running setup.py bdist_wheel for urwid: finished with status 'done'
      Stored in directory: /root/.cache/pip/wheels/34/06/50/24011714e101b5ad8518c69175d117a257413e3c15a92983f0
      Running setup.py bdist_wheel for dpkt: started
      Running setup.py bdist_wheel for dpkt: finished with status 'done' Stored in directory: /root/.cache/pip/wheels/0a/5f/3c/e0ffceb6554711f12a7101384f29ec13b85136dfcf1f692b8f
      ! Running setup.py bdist_wheel for itsdangerous: started
      Running setup.py bdist_wheel for itsdangerous: finished with status 'done'
      Stored in directory: /root/.cache/pip/wheels/2c/4a/61/5599631c1554768c6290b08c02c72d7317910374ca602ff1e5
      Running setup.py bdist_wheel for demjson: started
      Running setup.py bdist_wheel for demjson: finished with status 'done' Stored in directory: /root/.cache/pip/wheels/c5/d2/ab/a54fb5ea53ac3badba098160e8452fa126a51febda80440ded
      ! Running setup.py bdist_wheel for MarkupSafe: started
      Running setup.py bdist_wheel for MarkupSafe: finished with status 'done'
      Stored in directory: /root/.cache/pip/wheels/33/56/20/ebe49a5c612fffe1c5a632146b16596f9e64676768661e4e46
      Running setup.py bdist_wheel for pycparser: started
      Running setup.py bdist_wheel for pycparser: finished with status 'done'
      Stored in directory: /root/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511
      Successfully built construct urwid dpkt itsdangerous demjson MarkupSafe pycparser
      Installing collected packages: construct, aenum, urwid, pycparser, cffi, asn1crypto, idna, cryptography, dpkt, greenlet, gevent, demjson, appdirs, xbox-webapi, xbox-smartglass-core, marshmallow, marshmallow-objects, xbox-smartglass-stump, itsdangerous, Werkzeug, MarkupSafe, Jinja2, click, Flask, xbox-smartglass-rest
      Successfully installed Flask-1.0.2 Jinja2-2.10 MarkupSafe-1.0 Werkzeug-0.14.1 aenum-2.1.2 appdirs-1.4.3 asn1crypto-0.24.0 cffi-1.11.5 click-6.7 construct-2.9.41 cryptography-2.2.2 demjson-2.2.4 dpkt-1.9.1 gevent-1.2.2 greenlet-0.4.15 idna-2.7 itsdangerous-0.24 marshmallow-2.15.5 marshmallow-objects-1.0.14 pycparser-2.19 urwid-2.0.1 xbox-smartglass-core-1.0.10 xbox-smartglass-rest-0.9.5 xbox-smartglass-stump-0.9.4 xbox-webapi-1.1.5
      iobroker.core@1.0.0 /opt/iobroker└─┬ iobroker.xbox@0.0.5
      ├── nopy@0.2.6
      └─┬ request@2.88.0
      ├── aws4@1.8.0
      ├── combined-stream@1.0.7
      ├── extend@3.0.2
      ├─┬ form-data@2.3.2
      │ └── combined-stream@1.0.6
      ├─┬ har-validator@5.1.0
      │ └─┬ ajv@5.5.2
      │ └── fast-json-stable-stringify@2.0.0
      ├─┬ mime-types@2.1.20
      │ └── mime-db@1.36.0
      ├── oauth-sign@0.9.0
      ├── qs@6.5.2
      ├── safe-buffer@5.1.2
      ├─┬ tough-cookie@2.4.3
      │ └── psl@1.1.29
      └── uuid@3.3.2
      ! npm
      WARN
      optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: node-gyp rebuild
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      ! process exited with code 0
      Die installation des ubuntu systems leider nicht, spuckt diese fehlelrmeldung aus:
      xbox.0	2018-09-20 20:37:33.063	error	[START] Restarting adapter in 30 seconds
      xbox.0	2018-09-20 20:37:33.062	error	[START] Failed starting REST server: /bin/sh: 1: /opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/src/nopy.js: not found
      Wahrscheinlich gibt es den Ordner "/opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/" dann bei dir auf dem Ubuntu System gar nicht oder? Ich hätte eher erwartet, dass der Server nicht läuft, weil er am Anfang apt install nicht ausführen konnte.
      Genau, also das ganze basiert auf dem Smartglass Protokoll von Xbox. Kann in Spielen selbst also 'leider' nicht genutzt werden, wäre wohl zu einfach sich daraus was zum mogeln zu programmieren 😄
      • Dutchman
        @foxriver76:
        Wahrscheinlich gibt es den Ordner "/opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/" dann bei dir auf dem Ubuntu System gar nicht oder? Ich hätte eher erwartet, dass der Server nicht läuft, weil er am Anfang apt install nicht ausführen konnte. `
        doch der ordner ist da :
        @foxriver76:
        Genau, also das ganze basiert auf dem Smartglass Protokoll von Xbox. Kann in Spielen selbst also 'leider' nicht genutzt werden, wäre wohl zu einfach sich daraus was zum mogeln zu programmieren 😄 `
        lol, jup dan koennte man automatisieren oder mit 2 leuten einen controller bedienen :lol:
        • foxriver76
          @Dutchman:
          @foxriver76:
          Capture.JPG `
          Ahhh… okay...
          ja bei dir ist der Ordner /opt/iobroker/node_modules/nopy/, ich suche /opt/iobroker/node_modules/iobroker.xbox/node_modules/nopy/
          hmm Änderungsdatum 20.17 also ja schon von der Installation.. muss mal schauen woran das liegt.
          • Dutchman
            @foxriver76:
            hmm Änderungsdatum 20.17 also ja schon von der Installation.. muss mal schauen woran das liegt. `
            jup, im iobroker.xbox ordner fehlt er :
            xxx@xxx:~$ ls -l /opt/iobroker/node_modules/iobroker.xbox/node_modules/
            ajv/             extend/          mime-types/      safe-buffer/
            aws4/            form-data/       oauth-sign/      tough-cookie/
            .bin/            har-validator/   qs/              uuid/
            combined-stream/ mime-db/         request/
            • foxriver76
              @Dutchman:
              @foxriver76:
              Würdest du mir bei Gelegenheit mal die Ausgabe von````
              ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/.bin/
              • Dutchman
                @foxriver76:
                Würdest du mir bei Gelegenheit mal die Ausgabe vonls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/.bin/ posten? `
                sure
                xxx@xxx:~$ ls -lah /opt/iobroker/node_modules/iobroker.xbox/node_modules/.bin/
                total 8.0K
                drwxrwxrwx  2 root root 4.0K Sep 20 20:17 .
                drwxrwxrwx 17 root root 4.0K Sep 20 20:17 ..
                lrwxrwxrwx  1 root root   16 Sep 20 20:17 uuid -> ../uuid/bin/uuid
                xxx@xxx:~$
                • foxriver76
                  @Dutchman:
                  @foxriver76:
                  sure
                  total 8.0K
                  xxx@xxx:~$
                  Okay, leider kein Link für nopy vorhanden.. another try:
                  Wenn du dich in /opt/iobroker/node_modules/iobroker.xbox/ befindest und den Befehl````
                  npm root
                  • foxriver76
                    Lasse eben die Tests noch laufen und dann veröffentliche ich eine neue Version, die sollte das Problem hoffentlich beheben.
                    Probier trotzdem vorher mal das aus dem Post, würde mich interessieren was er als root angibt. Wirkt auf mich etwas inkonsistent, was die Installation da gemacht hat.
                    • foxriver76
                      Wäre cool, wenn sich hier noch der ein oder andere Tester findet. Vorallem die Installation + Betrieb auf Mac und Windows.
                      Zocke dafür auch eine Runde Battlefield mit euch :lol:
                      • Jey Cee
                        Ich kann auf Windows Testen.
                        Mal sehen ob mein Kopf es zu lässt und die Xbox nicht wieder Stunden lang Updates macht. Bei mir ist das Ding eigentlich nie an, weiss gar nicht warum ich sie noch hab.
                        Gesendet von meinem m8 mit Tapatalk
                        • Dutchman
                          @Jey Cee:
                          Bei mir ist das Ding eigentlich nie an, weiss gar nicht warum ich sie noch hab. `
                          Schicke dir gerne meine Adresse zum Recycling meinenkiddoes streiten sich immer über die eine hier 😉
                          Desweiteren läuft auch nach einem Tag alles, ein und ausschalten funzt auch super.
                          Ich reiche die gefragten Informationen noch später nach
                          • Jey Cee
                            Mein Installationsversuch unter Windows scheitert:
                            2018-09-21 18:10:14.025 - [32minfo[39m: iobroker url "https://github.com/foxriver76/ioBroker.xbox" --debug 2018-09-21 18:10:14.444 - [32minfo[39m: iobroker install https://github.com/foxriver76/ioBroker.xbox/tarball/master 2018-09-21 18:10:15.519 - [32minfo[39m: iobroker npm install https://github.com/foxriver76/ioBroker.xbox/tarball/master --production --save --prefix "C:/iobroker" (System call) 2018-09-21 18:10:29.841 - [32minfo[39m: iobroker > iobroker.xbox@0.0.6 preinstall C:\iobroker\node_modules\iobroker.xbox apt install -y build-essential libssl-dev libffi-dev python3-dev || echo -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.' ! 2018-09-21 18:10:29.874 - [32minfo[39m: iobroker Der Befehl "apt" ist entweder falsch geschrieben oder konnte nicht gefunden werden. ! 2018-09-21 18:10:29.874 - [32minfo[39m: iobroker -e '[INFO] Cant install build-essential libssl-dev libffi-dev python3-dev Debian packages. If you are on a Linux system, try installing the package via: sudo npm i iobroker.xbox --unsafe-perm, otherwise you have to manage to install the packages by yourself. If you are not running on Linux, you can ignore this INFO.' ! 2018-09-21 18:10:29.935 - [32minfo[39m: iobroker > iobroker.xbox@0.0.6 install C:\iobroker\node_modules\iobroker.xbox npip install ! 2018-09-21 18:10:30.149 - [32minfo[39m: iobroker No python_modules directory; installing pip locally if needed. 2018-09-21 18:10:30.161 - [32minfo[39m: iobroker Error: No python executable. at getPythonInfo (C:\iobroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:52:11) at Promise.then.catch.error (C:\iobroker\node_modules\iobroker.xbox\node_modules\nopy\src\api.js:115:14) at <anonymous> at process._tickCallback (internal/process/next_tick.js:188:7) ! 2018-09-21 18:10:30.326 - [32minfo[39m: iobroker npm 2018-09-21 18:10:30.326 - [32minfo[39m: iobroker ERR! code ELIFECYCLEnpm ERR! errno 1 ! 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker npm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! iobroker.xbox@0.0.6 install: npip installnpm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! Exit status 1npm ERR! npm 2018-09-21 18:10:30.327 - [32minfo[39m: iobroker ERR! Failed at the iobroker.xbox@0.0.6 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above. ! 2018-09-21 18:10:30.344 - [32minfo[39m: iobroker 2018-09-21 18:10:30.344 - [32minfo[39m: iobroker npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2018-09-21T16_10_30_331Z-debug.log ! 2018-09-21 18:10:30.624 - [32minfo[39m: iobroker exit 0[/code]</anonymous>
                            ! [quote]
                            😉 das behalte ich mal im Hinterkopf, für den Fall das ich so los werden will.
                            • Dutchman
                              Ich glaube der Fehler bei dir ist, wen ich den Log richtig lese, das dir die Python Sachen fehlen und die Installation kein apt ausführen kann (logisch ist ein Linux Commando).
                              Hast du per Admin oder per console installiert?
                              • Jey Cee
                                Hab per admin installiert.
                                Python hab ich 3.6.4 installiert.
                                • Dutchman
                                  @Jey Cee:
                                  Python hab ich 3.6.4 installiert. `
                                  Mal in der command Line probiert?
                                  • Jey Cee
                                    C:\iobroker>npm install https://github.com/foxriver76/ioBroker.xbox
                                    npm WARN enoent ENOENT: no such file or directory, open 'C:\iobroker\node_module
                                    s\admin\package.json'
                                    s\lib\package.json'
                                    s\tasks\package.json'
                                    s\scripts\package.json'
                                    s\test\package.json'
                                    npm ERR! path C:\iobroker\node_modules\ioBroker.deconz
                                    npm ERR! code EISGIT
                                    npm ERR! git C:\iobroker\node_modules\ioBroker.deconz: Appears to be a git repo
                                    or submodule.
                                    npm ERR! git Refusing to remove it. Update manually,
                                    npm ERR! git or move it out of the way first.
                                    npm ERR!     C:\Users\Jey Cee\AppData\Roaming\npm-cache\_logs\2018-09-21T17_31_3
                                    8_444Z-debug.log
                                    • Dutchman
                                      Alles Fehler bezüglich fehlender Ordner, console als Admin gestartet?
                                      • Jey Cee
                                        @Dutchman:
                                        console als Admin gestartet? ` Nein, war auch mein erster Gedanke und mit Admin rechten aber genau das gleiche.
                                        • Dutchman
                                          @Jey Cee:
                                          Nein, war auch mein erster Gedanke und mit Admin rechten aber genau das gleiche. `
                                          Hmm okay sorry dann bin ich raus habe selber keine Windows Installation und auf Basis der Fehler kam ich keine anderen Schritte mehr bedenken.
                                          Finde es nur komisch das er die allgemeine node Module Ordner und paclage json nicht findet
                                          • Jey Cee
                                            @Dutchman:
                                            Finde es nur komisch das er die allgemeine node Module Ordner und paclage json nicht findet ` Scheint ein Problem mit meiner installation zu sein, hat aber bisher nie die Installation eines Adapters verhindert.
                                            adapter xbox
                                            13
                                            205
                                            31283
