    4. (gelöst) Nach Update JS-Controller 1.51: HTTPS Web Instance startet nicht mehr
    • JohGre
      JohGre last edited by
      Auch bei mir seit dem Update bei den Adaptern rpc, Alexa und gardena immer wieder Fehlermeldungen.
      2018-09-14 16:52:03.798 - error: alexa2.0 uncaught exception: Cannot read property 'startsWith' of undefined
      2018-09-14 16:52:03.799 - error: alexa2.0 TypeError: Cannot read property 'startsWith' of undefined
      at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.alexa2/main.js:308:19)
      at emitTwo (events.js:106:13)
      at Adapter.emit (events.js:191:7)
      at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3725:38)
      at runCallback (timers.js:672:20)
      at tryOnImmediate (timers.js:645:5)
      at processImmediate [as _immediateCallback] (timers.js:617:5)
      2018-09-14 16:52:03.802 - warn: alexa2.0 Exception: TypeError: Cannot read property 'startsWith' of undefined
      2018-09-14 16:52:03.854 - error: Caught by controller[0]: TypeError: Cannot read property 'startsWith' of undefined
      2018-09-14 16:52:03.859 - error: Caught by controller[0]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.alexa2/main.js:308:19)
      2018-09-14 16:52:03.860 - error: Caught by controller[0]: at emitTwo (events.js:106:13)
      2018-09-14 16:52:03.861 - error: Caught by controller[0]: at Adapter.emit (events.js:191:7)
      2018-09-14 16:52:03.861 - error: Caught by controller[0]: at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3725:38)
      2018-09-14 16:52:03.861 - error: Caught by controller[0]: at runCallback (timers.js:672:20)
      2018-09-14 16:52:03.861 - error: Caught by controller[0]: at tryOnImmediate (timers.js:645:5)
      2018-09-14 16:52:03.861 - error: Caught by controller[0]: at processImmediate [as _immediateCallback] (timers.js:617:5)
      2018-09-14 16:52:03.861 - error: host.ioBroker instance system.adapter.alexa2.0 terminated with code 0 (OK)
      2018-09-14 16:52:03.862 - info: host.ioBroker Restart adapter system.adapter.alexa2.0 because enabled
      2018-09-14 17:27:33.048 - error: gardena.0 uncaught exception: Cannot read property 'split' of undefined
      2018-09-14 17:27:33.129 - error: Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
      2018-09-14 17:27:33.134 - error: Caught by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.gardena/main.js:65:38)
      2018-09-14 17:27:33.135 - error: Caught by controller[0]: at emitTwo (events.js:106:13)
      2018-09-14 17:27:33.136 - error: Caught by controller[0]: at Adapter.emit (events.js:191:7)
      2018-09-14 17:27:33.136 - error: Caught by controller[0]: at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3725:38)
      2018-09-14 17:27:33.136 - error: Caught by controller[0]: at runCallback (timers.js:672:20)
      2018-09-14 17:27:33.136 - error: Caught by controller[0]: at tryOnImmediate (timers.js:645:5)
      2018-09-14 17:27:33.136 - error: Caught by controller[0]: at processImmediate [as _immediateCallback] (timers.js:617:5)
      2018-09-14 17:27:33.136 - error: host.ioBroker instance system.adapter.gardena.0 terminated with code 0 (OK)
      2018-09-14 18:36:46.494 - error: hm-rpc.0 Cannot call setValue: :TypeError: argument 'obj' must be type number, string, boolean or object
      2018-09-14 18:36:46.506 - error: hm-rpc.0 Cannot call setValue: :TypeError: argument 'obj' must be type number, string, boolean or object
      2018-09-14 18:36:46.511 - error: hm-rpc.0 Cannot call setValue: :TypeError: argument 'obj' must be type number, string, boolean or object
      Außerdem immer wieder warnings
      2018-09-14 19:29:33.720 - warn: admin.0 Disable logging, because no one socket connected
      2018-09-14 19:35:12.104 - info: host.ioBroker Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      2018-09-14 19:35:14.025 - warn: admin.0 Repository cannot be read. Invalid "system.config" object.
      • Holger76
        Holger76 last edited by
        viewtopic.php?f=20&t=16863&p=177222&hil … er#p177224
        • cvidal
          Ich bekomme seit dem Update auch Fehler wenn ich den Vacuum Adapter Starte.
          NodeJS Version: V10.2.1
          NPM Version: 4.6.1
          Alle Adapter sind Aktuell auf latest.
          host.Vidal	2018-09-14 20:58:58.736	error	instance system.adapter.mihome-vacuum.0 terminated with code 0 (OK)
          Caught	2018-09-14 20:58:58.735	error	by controller[0]: at processImmediate [as _immediateCallback] (timers.js:617:5)
          Caught	2018-09-14 20:58:58.735	error	by controller[0]: at tryOnImmediate (timers.js:645:5)
          Caught	2018-09-14 20:58:58.735	error	by controller[0]: at runCallback (timers.js:672:20)
          Caught	2018-09-14 20:58:58.735	error	by controller[0]: at Immediate. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3725:38)
          Caught	2018-09-14 20:58:58.735	error	by controller[0]: at Adapter.emit (events.js:191:7)
          Caught	2018-09-14 20:58:58.735	error	by controller[0]: at emitTwo (events.js:106:13)
          Caught	2018-09-14 20:58:58.735	error	by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:131:13)
          Caught	2018-09-14 20:58:58.734	error	by controller[0]: at parseGoTo (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:204:31)
          Caught	2018-09-14 20:58:58.734	error	by controller[0]: TypeError: Cannot read property 'split' of null
          mihome-vacuum.0	2018-09-14 20:58:58.667	info	terminating
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	at processImmediate [as _immediateCallback] (timers.js:617:5)
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	at tryOnImmediate (timers.js:645:5)
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	at runCallback (timers.js:672:20)
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	at Immediate. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3725:38)
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	at Adapter.emit (events.js:191:7)
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	at emitTwo (events.js:106:13)
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:131:13)
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	at parseGoTo (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:204:31)
          mihome-vacuum.0	2018-09-14 20:58:58.640	error	TypeError: Cannot read property 'split' of null
          mihome-vacuum.0	2018-09-14 20:58:58.637	error	uncaught exception: Cannot read property 'split' of null</anonymous></anonymous></anonymous></anonymous>
          Edit hm-rpc wirft auch fehler:
          hm-rpc.0	2018-09-14 21:50:42.849	error	Error: XML-RPC fault: Failure
          hm-rpc.0	2018-09-14 21:50:42.849	error	xmlrpc -> setValue ["3","STATE",false] BOOL
          Gruß Christian
            Buhu91 last edited by
            @cvidal:
            NPM Version: 4.6.1
            Bei mir das selbe Bild.
            Bin nun wieder auf 1.4.2 zurück. Läuft nun wieder.
              aftershowman last edited by
              Hallo Buhu91,
              kannnst Du kurz den Befehl/e posten wie man auf 1.42 zurück kommt.
                bin auf 1.42 zurück gegangen.
                HAb das so gemacht:
                cd /opt/iobroker
                iobroker stop
                npm i iobroker.js-controller@1.4.2 –production
                iobroker start
                Die HTTPS Instance des Webserves startet aber immer noch nicht.
                Bekomme Lets encrypt bezoge Fehlermeldungen.
                Was muß ich noch tiun?
                Hier die Fehlermeldungen:
                host.wg6-wetter 2018-09-20 22:15:44.955 error instance system.adapter.web.1 terminated with code 0 (OK)
                Caught 2018-09-20 22:15:44.954 error by controller[1]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
                Caught 2018-09-20 22:15:44.954 error by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                Caught 2018-09-20 22:15:44.954 error by controller[1]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                Caught 2018-09-20 22:15:44.953 error by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                Caught 2018-09-20 22:15:44.953 error by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                Caught 2018-09-20 22:15:44.953 error by controller[1]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                Caught 2018-09-20 22:15:44.952 error by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                Caught 2018-09-20 22:15:44.952 error by controller[1]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                Caught 2018-09-20 22:15:44.952 error by controller[1]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:705:21)
                Caught 2018-09-20 22:15:44.951 error by controller[1]: at adapter.getCertificates (/opt/iobroker/node_modules/iobroker.web/main.js:239:29)
                Caught 2018-09-20 22:15:44.950 error by controller[1]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:847:28)
                Caught 2018-09-20 22:15:44.950 error by controller[1]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:55:26)
                Caught 2018-09-20 22:15:44.950 error by controller[1]: at Object.Greenlock.create (/opt/iobroker/node_modules/greenlock/index.js:258:13)
                Caught 2018-09-20 22:15:44.949 error by controller[1]: at promisifyAllSelf (/opt/iobroker/node_modules/greenlock/index.js:15:20)
                Caught 2018-09-20 22:15:44.949 error by controller[1]: at Array.forEach (native)
                Caught 2018-09-20 22:15:44.947 error by controller[1]: at /opt/iobroker/node_modules/greenlock/index.js:17:33
                Caught 2018-09-20 22:15:44.947 error by controller[1]: TypeError: util.promisify is not a function
                Caught 2018-09-20 22:15:44.947 error by controller[0]: Please update to Let's Encrypt v2 (ACME draft 12)
                Caught 2018-09-20 22:15:44.946 error by controller[0]: Let's Encrypt v1 is deprecated.
                Caught 2018-09-20 22:15:44.946 error by controller[0]: === WARNING ===
                Caught 2018-09-20 22:15:44.944 error by controller[0]: Detected Let's Encrypt v01 URL (deprecated). Changing version to v01.
                Caught 2018-09-20 22:15:44.944 error by controller[0]: This will be required in versions v2.3+
                Caught 2018-09-20 22:15:44.943 error by controller[0]: (also 'npm install –save le-acme-core' as this legacy dependency will soon be removed)
                Caught 2018-09-20 22:15:44.943 error by controller[0]: 'v01' for Let's Encrypt v1 (deprecated)
                Caught 2018-09-20 22:15:44.943 error by controller[0]: or
                Caught 2018-09-20 22:15:44.942 error by controller[0]: ('v02' is an alias of 'draft-12'
                Caught 2018-09-20 22:15:44.942 error by controller[0]: 'draft-12' for Let's Encrypt v2 and ACME draft 12
                Caught 2018-09-20 22:15:44.941 error by controller[0]: Please specify 'version' option:
                Caught 2018-09-20 22:15:44.941 error by controller[0]: ==========================================================
                Caught 2018-09-20 22:15:44.940 error by controller[0]: == greenlock.js (v2.2.0+) ==
                Caught 2018-09-20 22:15:44.939 error by controller[0]: ==========================================================
                web.1 2018-09-20 22:15:44.854 error uncaught exception: util.promisify is not a function
                host.wg6-wetter 2018-09-20 22:15:39.975 info instance system.adapter.web.1 started with pid 8672</anonymous></anonymous></anonymous>
                • Stabilostick
                  Stabilostick last edited by
                  npm install --save le-acme-core --force
                  im ioBroker-Ordner.
                    hab "sudo npm install –save le-acme-core --force" ausgeführt
                    und anschließende den PI gebootet.
                    es kommen immer noch die gleichen fehlermedlungen, wenn ich die HTTPS Instance vom Webserver starte.
                    Wer kann helfen?
                    Grüße, Frank
                    host.wg6-wetter 2018-09-21 18:40:28.160 error instance system.adapter.web.1 terminated with code 0 (OK)
                    Caught 2018-09-21 18:40:28.160 error by controller[9]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
                    Caught 2018-09-21 18:40:28.160 error by controller[9]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                    Caught 2018-09-21 18:40:28.160 error by controller[9]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                    Caught 2018-09-21 18:40:28.160 error by controller[9]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                    Caught 2018-09-21 18:40:28.159 error by controller[9]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                    Caught 2018-09-21 18:40:28.159 error by controller[9]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                    Caught 2018-09-21 18:40:28.159 error by controller[9]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                    Caught 2018-09-21 18:40:28.159 error by controller[9]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                    Caught 2018-09-21 18:40:28.159 error by controller[9]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:705:21)
                    Caught 2018-09-21 18:40:28.158 error by controller[9]: at adapter.getCertificates (/opt/iobroker/node_modules/iobroker.web/main.js:239:29)
                    Caught 2018-09-21 18:40:28.158 error by controller[9]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:847:28)
                    Caught 2018-09-21 18:40:28.158 error by controller[9]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:55:26)
                    Caught 2018-09-21 18:40:28.158 error by controller[9]: at Object.Greenlock.create (/opt/iobroker/node_modules/greenlock/index.js:258:13)
                    Caught 2018-09-21 18:40:28.158 error by controller[9]: at promisifyAllSelf (/opt/iobroker/node_modules/greenlock/index.js:15:20)
                    Caught 2018-09-21 18:40:28.157 error by controller[9]: at Array.forEach (native)
                    Caught 2018-09-21 18:40:28.157 error by controller[9]: at /opt/iobroker/node_modules/greenlock/index.js:17:33
                    Caught 2018-09-21 18:40:28.157 error by controller[9]: TypeError: util.promisify is not a function
                    Caught 2018-09-21 18:40:28.157 error by controller[8]: Please update to Let's Encrypt v2 (ACME draft 12)
                    Caught 2018-09-21 18:40:28.156 error by controller[8]: Let's Encrypt v1 is deprecated.
                    Caught 2018-09-21 18:40:28.156 error by controller[8]: === WARNING ===
                    Caught 2018-09-21 18:40:28.156 error by controller[6]: Detected Let's Encrypt v01 URL (deprecated). Changing version to v01.
                    Caught 2018-09-21 18:40:28.156 error by controller[5]: This will be required in versions v2.3+
                    Caught 2018-09-21 18:40:28.156 error by controller[4]: (also 'npm install –save le-acme-core' as this legacy dependency will soon be removed)
                    Caught 2018-09-21 18:40:28.155 error by controller[4]: 'v01' for Let's Encrypt v1 (deprecated)
                    Caught 2018-09-21 18:40:28.155 error by controller[3]: or
                    Caught 2018-09-21 18:40:28.155 error by controller[3]: ('v02' is an alias of 'draft-12'
                    Caught 2018-09-21 18:40:28.155 error by controller[3]: 'draft-12' for Let's Encrypt v2 and ACME draft 12
                    Caught 2018-09-21 18:40:28.155 error by controller[2]: Please specify 'version' option:
                    Caught 2018-09-21 18:40:28.154 error by controller[2]: ==========================================================
                    Caught 2018-09-21 18:40:28.154 error by controller[2]: == greenlock.js (v2.2.0+) ==
                    Caught 2018-09-21 18:40:28.153 error by controller[1]: ==========================================================
                    host.wg6-wetter 2018-09-21 18:40:23.740 info instance system.adapter.web.1 started with pid 1308</anonymous></anonymous></anonymous>
                      hast mal geschaut ob die Zertifikte noch da sind.. ??
                        denek das die Zerrtificate da sind .
                        unter den System Einstellungne Reiter Zertificate sehe ich "defaultPrivate" und defaultPublic"
                        unter dem Ordner ".. encrypt" liegen auch entsprechnde DAteien vom 9.5.2018
                        HAb auch mal das hier probiert und den JsController anschließend neu gestartet .
                        npm cache clean
                        npm install –save greenlock@2.x
                        hat auch nicht genutzt.
                        Die Fehler meldungen sind immer noch da.
                        Hier die letzten Logs:
                        ! host.wg6-wetter 2018-09-21 21:45:42.166 info Restart adapter system.adapter.web.1 because enabled
                        ! host.wg6-wetter 2018-09-21 21:45:42.166 error instance system.adapter.web.1 terminated with code 0 (OK)
                        ! Caught 2018-09-21 21:45:42.165 error by controller[9]: at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
                        ! Caught 2018-09-21 21:45:42.165 error by controller[9]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                        ! Caught 2018-09-21 21:45:42.165 error by controller[9]: at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        ! Caught 2018-09-21 21:45:42.164 error by controller[9]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                        ! Caught 2018-09-21 21:45:42.164 error by controller[9]: at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                        ! Caught 2018-09-21 21:45:42.164 error by controller[9]: at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        ! Caught 2018-09-21 21:45:42.164 error by controller[9]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                        ! Caught 2018-09-21 21:45:42.164 error by controller[9]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                        ! Caught 2018-09-21 21:45:42.163 error by controller[9]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:705:21)
                        ! Caught 2018-09-21 21:45:42.163 error by controller[9]: at adapter.getCertificates (/opt/iobroker/node_modules/iobroker.web/main.js:239:29)
                        ! Caught 2018-09-21 21:45:42.163 error by controller[9]: at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:847:28)
                        ! Caught 2018-09-21 21:45:42.163 error by controller[9]: at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:55:26)
                        ! Caught 2018-09-21 21:45:42.163 error by controller[9]: at Object.Greenlock.create (/opt/iobroker/node_modules/greenlock/index.js:258:13)
                        ! Caught 2018-09-21 21:45:42.162 error by controller[9]: at promisifyAllSelf (/opt/iobroker/node_modules/greenlock/index.js:15:20)
                        ! Caught 2018-09-21 21:45:42.161 error by controller[9]: at Array.forEach (native)
                        ! Caught 2018-09-21 21:45:42.161 error by controller[9]: at /opt/iobroker/node_modules/greenlock/index.js:17:33
                        ! Caught 2018-09-21 21:45:42.160 error by controller[9]: TypeError: util.promisify is not a function
                        ! Caught 2018-09-21 21:45:42.160 error by controller[8]: Please update to Let's Encrypt v2 (ACME draft 12)
                        ! Caught 2018-09-21 21:45:42.160 error by controller[8]: Let's Encrypt v1 is deprecated.
                        ! Caught 2018-09-21 21:45:42.160 error by controller[8]: === WARNING ===
                        ! Caught 2018-09-21 21:45:42.159 error by controller[6]: Detected Let's Encrypt v01 URL (deprecated). Changing version to v01.
                        ! Caught 2018-09-21 21:45:42.159 error by controller[4]: This will be required in versions v2.3+
                        ! Caught 2018-09-21 21:45:42.159 error by controller[4]: (also 'npm install –save le-acme-core' as this legacy dependency will soon be removed)
                        ! Caught 2018-09-21 21:45:42.159 error by controller[3]: 'v01' for Let's Encrypt v1 (deprecated)
                        ! Caught 2018-09-21 21:45:42.159 error by controller[3]: or
                        ! Caught 2018-09-21 21:45:42.158 error by controller[2]: ('v02' is an alias of 'draft-12'
                        ! Caught 2018-09-21 21:45:42.158 error by controller[2]: 'draft-12' for Let's Encrypt v2 and ACME draft 12
                        ! Caught 2018-09-21 21:45:42.158 error by controller[2]: Please specify 'version' option:
                        ! Caught 2018-09-21 21:45:42.158 error by controller[2]: ==========================================================
                        ! Caught 2018-09-21 21:45:42.157 error by controller[2]: == greenlock.js (v2.2.0+) ==
                        ! Caught 2018-09-21 21:45:42.156 error by controller[1]: ==========================================================
                        ! web.1 2018-09-21 21:45:42.102 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
                        ! web.1 2018-09-21 21:45:42.102 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                        ! web.1 2018-09-21 21:45:42.102 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        ! web.1 2018-09-21 21:45:42.102 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                        ! web.1 2018-09-21 21:45:42.102 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
                        ! web.1 2018-09-21 21:45:42.102 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
                        ! web.1 2018-09-21 21:45:42.102 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                        ! web.1 2018-09-21 21:45:42.102 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                        ! web.1 2018-09-21 21:45:42.102 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:705:21)
                        ! web.1 2018-09-21 21:45:42.102 error at adapter.getCertificates (/opt/iobroker/node_modules/iobroker.web/main.js:239:29)
                        ! web.1 2018-09-21 21:45:42.102 error at initWebServer (/opt/iobroker/node_modules/iobroker.web/main.js:847:28)
                        ! web.1 2018-09-21 21:45:42.102 error at Object.createServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/letsencrypt.js:55:26)
                        ! web.1 2018-09-21 21:45:42.102 error at Object.Greenlock.create (/opt/iobroker/node_modules/greenlock/index.js:258:13)
                        ! web.1 2018-09-21 21:45:42.102 error at promisifyAllSelf (/opt/iobroker/node_modules/greenlock/index.js:15:20)
                        ! web.1 2018-09-21 21:45:42.102 error at Array.forEach (native)
                        ! web.1 2018-09-21 21:45:42.102 error at /opt/iobroker/node_modules/greenlock/index.js:17:33
                        ! web.1 2018-09-21 21:45:42.102 error TypeError: util.promisify is not a function
                        ! web.1 2018-09-21 21:45:42.098 error uncaught exception: util.promisify is not a function
                        ! web.1 2018-09-21 21:45:39.610 info starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v6.12.3
                        ! host.wg6-wetter 2018-09-21 21:45:37.259 info instance system.adapter.web.1 started with pid 12146</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
                        81.1k
                        3146
