    4. [Projekt] ioGo # Smarthome to go
      A Former User last edited by
      @liv-in-sky:
      schliesse mich bbtown an!
      das mit dem einloggen war mir schon klar - das mit dem sync nicht
      aber die states schalten geht nicht, wenn ich nicht im lokalen netzwerk bin `
      lass den iogo adapter mal bitte in "debug" laufen und schau ob was im log passiert.
      Dort sollten alle Ereignisse geloggt werden.
        liv-in-sky last edited by
        das ist das log des adapters - die LEDLampe wird in der app geschaltet
        ! iogo.0 2018-09-24 20:58:30.151 debug controll-own.0.LEDLampe saved successfully
        ! iogo.0 2018-09-24 20:58:30.010 debug send state: controll-own.0.LEDLampe
        ! iogo.0 2018-09-24 20:58:30.002 debug data received: {"ack":false,"from":"app","id":"controll-own.0.LEDLampe","lc":0,"q":0,"ts":0,"val":"true"}
        ! iogo.0 2018-09-24 20:58:28.229 debug controll-own.0.LEDLampe saved successfully
        ! iogo.0 2018-09-24 20:58:28.087 debug send state: controll-own.0.LEDLampe
        ! iogo.0 2018-09-24 20:58:28.083 debug data received: {"ack":false,"from":"app","id":"controll-own.0.LEDLampe","lc":0,"q":0,"ts":0,"val":"false"}
        ! iogo.0 2018-09-24 20:58:17.296 info database initialized with 17 states
        ! iogo.0 2018-09-24 20:58:17.152 info database initialized with 17 objects
        ! iogo.0 2018-09-24 20:58:16.907 info database initialized with 15 enums
        ! iogo.0 2018-09-24 20:58:15.161 debug system.adapter.admin.0: logging true
        ! iogo.0 2018-09-24 20:58:15.161 info removed enums from remote database
        ! iogo.0 2018-09-24 20:58:15.161 info removed objects from remote database
        ! iogo.0 2018-09-24 20:58:15.161 info removed states from remote database
        ! iogo.0 2018-09-24 20:58:15.159 info logged in as: EzxxxxxxxxxxxxxxxxxxxxxxxtXb2
        ! iogo.0 2018-09-24 20:58:14.606 info device edge captured
        ! iogo.0 2018-09-24 20:58:14.606 info device armin captured
        ! iogo.0 2018-09-24 20:58:14.131 info initialize app devices
        ! iogo.0 2018-09-24 20:58:14.048 info starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.iogo, node: v8.11.2
        ! iogo.0 2018-09-24 20:58:13.921 debug statesDB connected
        ! iogo.0 2018-09-24 20:58:13.831 debug objectDB connected
        ! iogo.0 2018-09-24 20:58:07.960 info terminating
        ! iogo.0 2018-09-24 20:58:07.952 info signed out
        ! iogo.0 2018-09-24 20:58:07.939 info cleaned everything up…
        ! iogo.0 2018-09-24 20:58:04.225 debug system.adapter.admin.0: logging false
          @liv-in-sky:
          ! iogo.0 2018-09-24 20:58:04.225 debug system.adapter.admin.0: logging false `
          Ankommen tut es ja schonmal.
          Das könnte mal wieder ein Datentyp Problem sein…
          Funktioniert es bei number oder string States?
            dacht ich auch schon - mit number gehts
              schön langsam verstehe ich den vorteil der firebase sache
                @liv-in-sky:
                dacht ich auch schon - mit number gehts `
                neue version in github v0.0.10
                damit ist es behoben
                  adapter installiert und neugestartet - numbers gehen noch - switch nicht - syncing data - unter dem state beim schalten bleibt ! log einträge in iobroker gleich wie vorher - auch der eigentliche state-zustand wird nicht mehr angezeigt
                  egal ob lokales oder externes netz
                    moin,
                    app 26.4
                    adapter 0.0.10
                    mit firebase werden kein children states in der app angezeigt, switch kann nicht geschalten werden
                      @liv-in-sky:
                      moin,
                      app 26.4
                      adapter 0.0.10
                      mit firebase werden kein children states in der app angezeigt, switch kann nicht geschalten werden ` Kannst du Mal den RAW von dem state posten bitte
                      Gesendet von meinem Pixel 2 mit Tapatalk
                        bitteschön - der state - LEDLampe
                        ! "from": "system.adapter.admin.0",
                        ! "ts": 1515425682436,
                        ! "common": {
                        ! "name": "LEDLampe",
                        ! "role": "switch",
                        ! "type": "boolean",
                        ! "desc": "Manuell erzeugt",
                        ! "read": true,
                        ! "write": true,
                        ! "def": false,
                        ! "smartName": {
                        ! "de": "led, led schreibtisch"
                        ! "native": {},
                        ! "acl": {
                        ! "object": 1636,
                        ! "owner": "system.user.admin",
                        ! "ownerGroup": "system.group.administrator",
                        ! "state": 1636
                        ! "_id": "controll-own.0.LEDLampe",
                        ! "type": "state"
                          hab einen netten nebeneffekt bei deinem adapter bemerkt - schaltet man debug ein - und filtert im log nur die iogo.adapter meldungen erkennt man sehr schon, welche states unfug treiben bzw ob ein script unsinn treibt. anscheinend wird (ich nehme an , dass liegt an firebase) jede änderung der states dadurch sichbar gemacht - habe ich heute gut gebrauchen können zur fehlersuche bzw. dadurch ist mir der fehler erst aufgefallen
                          • N
                            NightWatcher last edited by
                            moin, vorgestern bemerkt, dass die app abstürzt, wenn man einen "click" Button drückt. Version 0.26.04
                            ebenfalls reagieren die Schieberegler komisch. klicke ich z. b von 255 nach 0 wird der Wert zwar in der App gesetzt5, kommt aber in iobroker nicht an. "schiebe" ich den regler von 0 nach 255,dann klappt es.
                              @NightWatcher:
                              moin, vorgestern bemerkt, dass die app abstürzt, wenn man einen "click" Button drückt. Version 0.26.04 `
                              Hat der Button zufällig in common.type was anderes als "boolean" stehen?
                              @NightWatcher:
                              ebenfalls reagieren die Schieberegler komisch. klicke ich z. b von 255 nach 0 wird der Wert zwar in der App gesetzt5, kommt aber in iobroker nicht an. "schiebe" ich den regler von 0 nach 255,dann klappt es. `
                              Wie sieht der RAW des State aus?
                              Gibt es Fehler im Log?
                              • N
                                @nisio:
                                @NightWatcher:
                                moin, vorgestern bemerkt, dass die app abstürzt, wenn man einen "click" Button drückt. Version 0.26.04 Hat der Button zufällig in common.type was anderes als "boolean" stehen?
                                Ja stimmt, deine Vermutung ist richtig. Da scheint nen Bug im Harmony Adapter zu sein: https://github.com/Pmant/ioBroker.harmo … ny.js#L513
                                Warum definiert man nen Button mit dem type number?! Müsste dass nicht eher Type boolean sein und value auf false und nicht auf '0' (was ja auch streng genommen wieder nen String wäre).
                                @nisio:
                                @NightWatcher:
                                Gibt es Fehler im Log? `
                                Mhh bekomme ich gerade nicht mehr nachgestellt. Gerade klappt es irgendwie. Ist wie mit meinem Induktionskochfeld. Das Touchpad mag manchmal nicht wie ich. Wenn ich es dann vorführe, klappt es wunderbar :evil:
                                  @NightWatcher:
                                  Warum definiert man nen Button mit dem type number?! Müsste dass nicht eher Type boolean sein und value auf false und nicht auf '0' (was ja auch streng genommen wieder nen String wäre). `
                                  button sollte immer boolean sein:
                                  https://github.com/ioBroker/ioBroker/bl … write-only
                                  • N
                                    jepp, macht ja auch Sinn. Habe es bereits als pull request eingereicht.
                                      Neue BetaVersion 0.27.x ist unterwegs.
                                      Ich habe einiges unter der Haube angepasst um für die nächsten Features vorbereitet zu sein.
                                      Es hat sich einiges in den Einstellungen geändert.
                                      Vermutlich müssen etliche Eingaben neu vorgenommen werden.
                                      Für die Kommunikation mit dem iogo-adapter wird dieser in Version 0.0.12 benötigt.
                                      Aktuell ist das Feature "sync-children" leider noch deaktiviert.
                                      Vielen Dank an alle neugierigen Betatester
                                      • N
                                        habe irgendwie das gefühl dass mit der neuen version wieder alte probleme auftreten. teilweise ist wieder der Kreis nach dem schalten eines Objektes zu sehen oder werden vorher erst gar nicht aktualisiert . schalten geht aber dennoch. Ich nutze den iogo adapter als Verbindungsmetode (auch bereits vorher).
                                        Der Adapter in iobroker wurde natürlich auch aktualisiert.
                                          dito
                                          27.05
                                          0.12
                                            @NightWatcher:
                                            Der Adapter in iobroker wurde natürlich auch aktualisiert. `
                                            Das habe ich bei mir noch nicht wieder gesehen.
                                            Was steht denn so in den logs?
                                            android app iogo
                                            61
                                            1140
                                            359124
