    4. [Projekt] Alarmanlage mit mehreren Alarmstufen
        "from": "system.adapter.hm-rpc.1",
        "ts": 1536258965916,
        "common": {
          "name": "Haustuer.STATE",
          "type": "boolean",
          "role": "state",
          "def": false,
          "read": true,
          "write": false,
          "custom": {
            "history.0": {
              "enabled": true,
              "changesOnly": false,
              "debounce": "1000",
              "maxLength": "10",
              "retention": 0,
              "changesRelogInterval": 0,
              "changesMinDelta": 0
            "material": {
              "admin": {
                "inverted": false,
                "name": "Haustuer",
                "colorOn": "rgba(0,0,0,1)",
                "doubleSize": true,
                "colorOff": "rgba(0,0,0,1)",
                "icon": "",
                "iconOff": "",
                "background": "/material.0/admin/hm-rpc_1_NEQ1818500_1_STATE.jpg",
                "enabled": true
        "native": {
          "CONTROL": "DOOR_SENSOR.STATE",
          "ID": "STATE",
          "TYPE": "BOOL",
          "UNIT": "",
          "FLAGS": 1,
          "OPERATIONS": 5,
          "TAB_ORDER": 0,
          "DEFAULT": false,
          "MAX": true,
          "MIN": false
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "state": 1636
        "_id": "hm-rpc.1.NEQ1818500.1.STATE",
        "type": "state"
        A Former User last edited by
        Ist der State einem Raum zugeordnet?
        Dann bitte auch mal den RAW von dem Raum posten. Danke
            "type": "enum",
            "common": {
              "name": {
                "en": "Vorraum",
                "de": "Vorraum"
              "desc": "",
              "members": [
                "hm-rpc.1.NEQ1818500.1",
                "hm-rpc.1.OEQ0473764.1"
              "custom": {
                "material": {
                  "admin": {
                    "align": "",
                    "newLine": false,
                    "name": "Vorraum",
                    "color": "",
                    "background": "/material.0/admin/enum.rooms.Garten.jpg",
                    "backgroundColor": "",
                    "icon": ""
              "color": "#e4428d"
            "native": {
              "Name": "Vorraum",
              "TypeName": "ENUM",
              "EnumInfo": ""
            "ts": 1535716516586,
            "_id": "enum.rooms.Vorraum",
            "acl": {
              "object": 1636,
            @sigi234:
              "type": "enum",
              "common": {
                "name": {
                  "en": "Vorraum",
                  "de": "Vorraum"
                "desc": "",
                "members": [
                "custom": {
                  "material": {
                    "admin": {
                      "align": "",
                      "newLine": false,
                      "name": "Vorraum",
                      "color": "",
                      "icon": ""
                "color": "#e4428d"
              "native": {
                "Name": "Vorraum",
                "TypeName": "ENUM",
                "EnumInfo": ""
              "acl": {
                "object": 1636,
            Versuche mal, wenn du die verschiedenen Sprachen nicht angibst:
            "common": {
                "name": "Vorraum",
                "desc": "",
                ErazorVIP last edited by
                Nur mal so eine Frage, wo kann ich denn die Verzögerungszeit einstellen?
                :shock:
                  @ErazorVIP:
                  Nur mal so eine Frage, wo kann ich denn die Verzögerungszeit einstellen? `
                  Du kannst für jeden Ausgang die Verzögerung einstellen.
                  Das passiert in _loadSettings für jedes Profil einzeln.
                  motion: 0 => keine Verzögerung
                  motion: 30 => 30sec Verzögerung
                  function _loadSettings(profile) {
                          switch (profile) {
                              case 'silent':
                                  sensorDelay = {
                                      motion: 0,
                                      facade: 0
                                  alarmDelay = {
                                      silent: 0
                                  break;
                              case 'night':
                                  sensorDelay = {
                                      facade: 0
                                  alarmDelay = {
                                      silent: 0,
                                      strobe: 0
                    Super 😉 Danke
                    Mit den Logs hab ich noch ein kleines Problem…
                    Wenn aus auf 5 eigestellt ist funktioniert auch soweit alles super...
                    var maxLogEntries = 5;
                    Leider bleibt es dann bei den 5 Logs - ein neues Ereignis wird dann nicht mehr gelogt?
                      flat1984 last edited by
                      @ErazorVIP:
                      Leider bleibt es dann bei den 5 Logs - ein neues Ereignis wird dann nicht mehr gelogt? `
                      das kann ich nachvollziehen - nach erster Untersuchung vermute ich die Ursache in der Funktion````
                      _logsensor(obj)
                      Dort wird mittels````
                      alarmLog.push(time+' '+sensor+' '+room);
                      ````die aktuelles Meldung an das Ende des Arrays geschrieben, mittels````
                      alarmLog.splice(maxLogEntries)
                      ````wird die Anzahl der Elemente des Arrays auf maxLogEntries (default: 5) begrenzt.
                      Dadurch wird der neue Eintrag gleich wieder abgeschnitten / gelöscht, sobald 5 Einträge im Array sind.
                      Da ich das Log lieber in umgekehrter Reihenfolge sehen möchte (aktuellster Alarm oben), habe ich es wie folgt gelöst:
                      Ich lasse mittels````
                      alarmLog.unshift(time+' '+sensor+' '+room);
                      ````die aktuellste Logmeldung an den Array-Anfang stellen.
                      Ich hoffe ich liege mit meinem Verdacht richtig :-)
                        Centurytt last edited by
                        Echt genial Jungs,- wirklich. Tolle Arbeit. Das inspiriert micht total.
                        Allerdings bin ich schon fast am verzweifeln, weil ich keine entsprechende Outdoor Sirene finde. Ich suche immer nach entweder Zigbee fähigen Sirenen, da gibts bei Amazon genau zwei, oder Wifi und die senden meist auf 433mhz was wiederum voraussetzt, dass ich mir diese Infrastruktur auch noch zulegen muss. Ausserdem sollte die Sirene mit longlife Batterien ausgestattet sein. Lupusec Alarmanlagen sind z.B. komplett Wireless aber da ich mir das ganze ja selber baue, brauche ich eben eine Sirene die hier integrierbar ist.
                        Hat da jemand eine Idee ? habt ihr schon Sirenen im Einsatz ?
                        Danke Euch
                        lg
                        Tom
                          bumbumb last edited by
                          dein Script ist toll es funktioniert super. Ist es möglich das Logbuch von den Alarmmeldungen in eine Systemvariable der CCu2 zusenden? dort habe ich eine Zeichenkette angelegt. Wie bekomme ich den Log jetzt in die ccu2 Systemvariable.
                          Wäre super wer mir helfen kann.
                          Vielen Dank
                            @bumbumb:
                            Vielen Dank `
                            ich habe keine ccu2… Aber sowas in die Richtung müsste es sein:
                            on('alarm.out.log', function (obj) {
                                setState('your_ccu_variable', obj.state.val);
                              ich habe es versucht, leider funktioniert es nicht.
                              ` > on('alarm.out.log', function (obj) {
                              setState("hm-rega.0.15738"/Alarmanlage_Log/, obj.state.val);
                              • smartboart
                                smartboart last edited by
                                @Centurytt:
                                Danke Euch
                                lg
                                Tom ` Selber bauen… Blitzlicht und Sirene von Bosch im Gehäuse, 1 x 4 kanalaktor von hm mit Relais und ne passende Batterie fertig is... Als sabotageschalter ein fenstersensor.. Und damit autark noch nen ladegleichrichter mit solarpanel...
                                Ne LED fuern 3. Kanal und ne LKW Rückwärtsgang Sirene als voralarm bevor die grosse TRÖTE losgeht..
                                Alle 4 Kanäle benutzt... Saubere Sache sieht gut aus...
                                Hab noch ne externe Antenne für den aktor montiert...
                                Gesendet von meinem CLT-L09 mit Tapatalk
                                  Hallo
                                  leider geht es nicht was kann ich denn machen damit die Alarmlogs in der Zeichenkette der CCU laden?
                                  Habt ihr ne Idee?
                                    kurze Frage noch am Rande
                                    und mit
                                    on('javascript.0.alarm.out.alarm_sound', function(obj){
                                    var sensor = getState('javascript.0.alarm.out.last_sensor').state.val;
                                    sendTo("pushover", "send", {
                                    message: 'alarm triggered by '+sensor,
                                    sound: ""
                                    wird nicht .alarm.out.last_sensor gesendet sondern [object Object] was muss ich machen, damit das Auslösende Gerät bekomme?
                                    • lobomau
                                      lobomau last edited by
                                      @nisio:
                                      Hallo @sckibo,
                                      hast du das Material Design von Uhula eingebunden als CSS in deinem Projekt? `
                                      Kann man das mit einfachen Worten kurz erklären oder muss ich mich hier einarbeiten?
                                      viewtopic.php?f=30&t=7739&hilit=Material+design
                                      Ich hatte damals mit angefangen, es sieht sehr genial aus, aber irgendwie kam ich nicht klar
                                        @lobomau:
                                        @nisio:
                                        Hallo @sckibo,
                                        Ich hatte damals mit angefangen, es sieht sehr genial aus, aber irgendwie kam ich nicht klar ` Schau mal in dem Material Thread direkt nach…viewtopic.php?f=30&t=7739
                                        Uhula hat eine Anleitung geschrieben für den Einstieg
                                        Gesendet von meinem Pixel 2 mit Tapatalk
                                          LJSven last edited by
                                          Frage - ist das Script aus Post 1 immer noch das aktuellste? Blicke nicht mehr durch - geht die Aktivierung / Deaktivierung via Code schon?!
                                            @LJSven:
                                            Frage - ist das Script aus Post 1 immer noch das aktuellste? Blicke nicht mehr durch - geht die Aktivierung / Deaktivierung via Code schon?! ` Ist immernoch aktuell.
                                            Aktivierung via Code ist dort nicht drin
                                            138
                                            34618
