    4. Adapter: iobroker.backitup (stable Release)
    • Bluefox
      Bluefox last edited by
      Wie speichert FHEM die Configuration?
        ltsalvatore last edited by
        so, ich habe nun die v0.3.2 inst. und leider die gleichen probleme wie bei der v0.3.0 version.
        wie gesagt, bei der v0.2.7 hatte ich null probleme mit CCU und NAS backup
        das logfile spuckt folgendes aus
        backitup.0	2018-09-26 22:47:57.468	debug	system.adapter.admin.0: logging true
        backitup.0	2018-09-26 22:47:56.366	debug	[ccu/ccu] Requesting backup from CCU
        backitup.0	2018-09-26 22:47:56.363	debug	[ccu/ccu] CCU Version: 2.35.16
        backitup.0	2018-09-26 22:47:55.597	debug	[ccu/mount] For more details see mount(8).
        backitup.0	2018-09-26 22:47:55.597	debug	[ccu/mount] --make-runbindable recursively mark a whole subtree as unbindable
        backitup.0	2018-09-26 22:47:55.597	debug	[ccu/mount] --make-rprivate recursively mark a whole subtree as private
        backitup.0	2018-09-26 22:47:55.597	debug	[ccu/mount] --make-rslave recursively mark a whole subtree as slave
        backitup.0	2018-09-26 22:47:55.596	debug	[ccu/mount] --make-rshared recursively mark a whole subtree as shared
        backitup.0	2018-09-26 22:47:55.596	debug	[ccu/mount] --make-unbindable mark a subtree as unbindable
        backitup.0	2018-09-26 22:47:55.596	debug	[ccu/mount] --make-private mark a subtree as private
        backitup.0	2018-09-26 22:47:55.595	debug	[ccu/mount] --make-slave mark a subtree as slave
        backitup.0	2018-09-26 22:47:55.595	debug	[ccu/mount] --make-shared mark a subtree as shared
        backitup.0	2018-09-26 22:47:55.595	debug	[ccu/mount] -R, --rbind mount a subtree and all submounts somewhere else
        backitup.0	2018-09-26 22:47:55.594	debug	[ccu/mount] -M, --move move a subtree to some other place
        backitup.0	2018-09-26 22:47:55.594	debug	[ccu/mount] -B, --bind mount a subtree somewhere else (same as -o bind)
        backitup.0	2018-09-26 22:47:55.594	debug	[ccu/mount] Operations:
        backitup.0	2018-09-26 22:47:55.594	debug	[ccu/mount] <file>regular file for loopdev setup
        backitup.0	2018-09-26 22:47:55.593	debug	[ccu/mount] <directory>mountpoint for bind mounts (see --bind/rbind)
        backitup.0	2018-09-26 22:47:55.593	debug	[ccu/mount] <device>specifies device by path
        backitup.0	2018-09-26 22:47:55.593	debug	[ccu/mount] PARTUUID= <uuid>specifies device by partition UUID
        backitup.0	2018-09-26 22:47:55.593	debug	[ccu/mount] PARTLABEL= <label>specifies device by partition label
        backitup.0	2018-09-26 22:47:55.592	debug	[ccu/mount] UUID= <uuid>specifies device by filesystem UUID
        backitup.0	2018-09-26 22:47:55.592	debug	[ccu/mount] LABEL= <label>specifies device by filesystem label
        backitup.0	2018-09-26 22:47:55.592	debug	[ccu/mount] -U, --uuid <uuid>synonym for UUID= <uuid>backitup.0	2018-09-26 22:47:55.592	debug	[ccu/mount] -L, --label <label>synonym for LABEL= <label>backitup.0	2018-09-26 22:47:55.591	debug	[ccu/mount] Source:
        backitup.0	2018-09-26 22:47:55.591	debug	[ccu/mount] -V, --version output version information and exit
        backitup.0	2018-09-26 22:47:55.590	debug	[ccu/mount] -h, --help display this help and exit
        backitup.0	2018-09-26 22:47:55.590	debug	[ccu/mount] -w, --rw, --read-write mount the filesystem read-write (default)
        backitup.0	2018-09-26 22:47:55.590	debug	[ccu/mount] -v, --verbose say what is being done
        backitup.0	2018-09-26 22:47:55.590	debug	[ccu/mount] --target <target>explicitly specifies mountpoint
        backitup.0	2018-09-26 22:47:55.589	debug	[ccu/mount] --source <src>explicitly specifies source (path, label, uuid)
        backitup.0	2018-09-26 22:47:55.589	debug	[ccu/mount] -t, --types limit the set of filesystem types
        backitup.0	2018-09-26 22:47:55.589	debug	[ccu/mount] -r, --read-only mount the filesystem read-only (same as -o ro)
        backitup.0	2018-09-26 22:47:55.589	debug	[ccu/mount] -O, --test-opts limit the set of filesystems (use with -a)
        backitup.0	2018-09-26 22:47:55.589	debug	[ccu/mount] -o, --options comma-separated list of mount options
        backitup.0	2018-09-26 22:47:55.588	debug	[ccu/mount] -n, --no-mtab don't write to /etc/mtab
        backitup.0	2018-09-26 22:47:55.588	debug	[ccu/mount] -l, --show-labels show also filesystem labels
        backitup.0	2018-09-26 22:47:55.588	debug	[ccu/mount] -i, --internal-only don't call the mount. <type>helpers
        backitup.0	2018-09-26 22:47:55.588	debug	[ccu/mount] -T, --fstab <path>alternative file to /etc/fstab
        backitup.0	2018-09-26 22:47:55.587	debug	[ccu/mount] -F, --fork fork off for each device (use with -a)
        backitup.0	2018-09-26 22:47:55.587	debug	[ccu/mount] -f, --fake dry run; skip the mount(2) syscall
        backitup.0	2018-09-26 22:47:55.586	debug	[ccu/mount] -c, --no-canonicalize don't canonicalize paths
        backitup.0	2018-09-26 22:47:55.586	debug	[ccu/mount] -a, --all mount all filesystems mentioned in fstab
        backitup.0	2018-09-26 22:47:55.585	debug	[ccu/mount] Options:
        backitup.0	2018-09-26 22:47:55.585	debug	[ccu/mount] Mount a filesystem.
        backitup.0	2018-09-26 22:47:55.584	debug	[ccu/mount] mount <operation><mountpoint>[<target>]
        backitup.0	2018-09-26 22:47:55.584	debug	[ccu/mount] mount [options] <source> <directory>backitup.0	2018-09-26 22:47:55.583	debug	[ccu/mount] mount [options] [--source] <source> | [--target] <directory>backitup.0	2018-09-26 22:47:55.582	debug	[ccu/mount] mount -a [options]
        backitup.0	2018-09-26 22:47:55.582	debug	[ccu/mount] mount [-lhV]
        backitup.0	2018-09-26 22:47:55.582	debug	[ccu/mount] Usage:
        backitup.0	2018-09-26 22:47:55.581	debug	[ccu/mount] [IGNORED] Error: Command failed: mount -t cifs -o user=iobroker,password=passwort,rw,file_mode=0777,dir_mode=0777 //192.168.111.100/prv\Salva\P1\Backup Apps Settings\Server - iobroker
        backitup.0	2018-09-26 22:47:55.574	debug	[ccu/mount] For more details see mount(8).
        backitup.0	2018-09-26 22:47:55.574	debug	[ccu/mount] --make-runbindable recursively mark a whole subtree as unbindable
        backitup.0	2018-09-26 22:47:55.574	debug	[ccu/mount] --make-rprivate recursively mark a whole subtree as private
        backitup.0	2018-09-26 22:47:55.573	debug	[ccu/mount] --make-rslave recursively mark a whole subtree as slave
        backitup.0	2018-09-26 22:47:55.573	debug	[ccu/mount] --make-rshared recursively mark a whole subtree as shared
        backitup.0	2018-09-26 22:47:55.573	debug	[ccu/mount] --make-unbindable mark a subtree as unbindable
        backitup.0	2018-09-26 22:47:55.573	debug	[ccu/mount] --make-private mark a subtree as private
        backitup.0	2018-09-26 22:47:55.572	debug	[ccu/mount] --make-slave mark a subtree as slave
        backitup.0	2018-09-26 22:47:55.572	debug	[ccu/mount] --make-shared mark a subtree as shared
        backitup.0	2018-09-26 22:47:55.571	debug	[ccu/mount] -R, --rbind mount a subtree and all submounts somewhere else
        backitup.0	2018-09-26 22:47:55.570	debug	[ccu/mount] -M, --move move a subtree to some other place
        backitup.0	2018-09-26 22:47:55.569	debug	[ccu/mount] -B, --bind mount a subtree somewhere else (same as -o bind)
        backitup.0	2018-09-26 22:47:55.568	debug	[ccu/mount] Operations:
        backitup.0	2018-09-26 22:47:55.562	debug	[ccu/mount] <file>regular file for loopdev setup
        backitup.0	2018-09-26 22:47:55.561	debug	[ccu/mount] <directory>mountpoint for bind mounts (see --bind/rbind)
        backitup.0	2018-09-26 22:47:55.560	debug	[ccu/mount] <device>specifies device by path
        backitup.0	2018-09-26 22:47:55.560	debug	[ccu/mount] PARTUUID= <uuid>specifies device by partition UUID
        backitup.0	2018-09-26 22:47:55.560	debug	[ccu/mount] PARTLABEL= <label>specifies device by partition label
        backitup.0	2018-09-26 22:47:55.560	debug	[ccu/mount] UUID= <uuid>specifies device by filesystem UUID
        backitup.0	2018-09-26 22:47:55.559	debug	[ccu/mount] LABEL= <label>specifies device by filesystem label
        backitup.0	2018-09-26 22:47:55.559	debug	[ccu/mount] -U, --uuid <uuid>synonym for UUID= <uuid>backitup.0	2018-09-26 22:47:55.558	debug	[ccu/mount] -L, --label <label>synonym for LABEL= <label>backitup.0	2018-09-26 22:47:55.558	debug	[ccu/mount] Source:
        backitup.0	2018-09-26 22:47:55.556	debug	[ccu/mount] -V, --version output version information and exit
        backitup.0	2018-09-26 22:47:55.556	debug	[ccu/mount] -h, --help display this help and exit
        backitup.0	2018-09-26 22:47:55.556	debug	[ccu/mount] -w, --rw, --read-write mount the filesystem read-write (default)
        backitup.0	2018-09-26 22:47:55.556	debug	[ccu/mount] -v, --verbose say what is being done
        backitup.0	2018-09-26 22:47:55.555	debug	[ccu/mount] --target <target>explicitly specifies mountpoint
        backitup.0	2018-09-26 22:47:55.555	debug	[ccu/mount] --source <src>explicitly specifies source (path, label, uuid)
        backitup.0	2018-09-26 22:47:55.555	debug	[ccu/mount] -t, --types limit the set of filesystem types
        backitup.0	2018-09-26 22:47:55.554	debug	[ccu/mount] -r, --read-only mount the filesystem read-only (same as -o ro)
        backitup.0	2018-09-26 22:47:55.554	debug	[ccu/mount] -O, --test-opts limit the set of filesystems (use with -a)
        backitup.0	2018-09-26 22:47:55.553	debug	[ccu/mount] -o, --options comma-separated list of mount options
        backitup.0	2018-09-26 22:47:55.553	debug	[ccu/mount] -n, --no-mtab don't write to /etc/mtab
        backitup.0	2018-09-26 22:47:55.553	debug	[ccu/mount] -l, --show-labels show also filesystem labels
        backitup.0	2018-09-26 22:47:55.553	debug	[ccu/mount] -i, --internal-only don't call the mount. <type>helpers
        backitup.0	2018-09-26 22:47:55.552	debug	[ccu/mount] -T, --fstab <path>alternative file to /etc/fstab
        backitup.0	2018-09-26 22:47:55.552	debug	[ccu/mount] -F, --fork fork off for each device (use with -a)
        backitup.0	2018-09-26 22:47:55.552	debug	[ccu/mount] -f, --fake dry run; skip the mount(2) syscall
        backitup.0	2018-09-26 22:47:55.552	debug	[ccu/mount] -c, --no-canonicalize don't canonicalize paths
        backitup.0	2018-09-26 22:47:55.551	debug	[ccu/mount] -a, --all mount all filesystems mentioned in fstab
        backitup.0	2018-09-26 22:47:55.551	debug	[ccu/mount] Options:
        backitup.0	2018-09-26 22:47:55.550	debug	[ccu/mount] Mount a filesystem.
        backitup.0	2018-09-26 22:47:55.549	debug	[ccu/mount] mount <operation><mountpoint>[<target>]
        backitup.0	2018-09-26 22:47:55.549	debug	[ccu/mount] mount [options] <source> <directory>backitup.0	2018-09-26 22:47:55.548	debug	[ccu/mount] mount [options] [--source] <source> | [--target] <directory>backitup.0	2018-09-26 22:47:55.547	debug	[ccu/mount] mount -a [options]
        backitup.0	2018-09-26 22:47:55.546	debug	[ccu/mount] mount [-lhV]
        backitup.0	2018-09-26 22:47:55.546	debug	[ccu/mount] Usage:
        backitup.0	2018-09-26 22:47:55.545	debug	[ccu/mount] [undefined</directory></directory></target></mountpoint></operation></path></type></src></target></label></label></uuid></uuid></label></uuid></label></uuid></device></directory></file></directory></directory></target></mountpoint></operation></path></type></src></target></label></label></uuid></uuid></label></uuid></label></uuid></device></directory></file>
        • simatec
          Also beim cifs Problem würde ich auf die Lerrzeichen in der Pfadangabe tippen.
          Ändere mal den Pfad in was vernünftiges
          Beim ccu backup prüfe bitte deine Benutzerdaten.
          Du brauchst als Logindaten die Daten Des Weblogins.
          Und da ist der Benutzername definitiv „Admin“
          • Peoples
            Peoples last edited by
            Ich vermute auch dass das die weboberflächen Login-Daten sind.
            Die Daten der Ccu-Weboberfläche hast du ganz zu Anfang Mal festgelegt und ich persönlich habe die seit dem nie mehr benötigt
            • simatec
              Hier mal noch die Einstellungen, wie es eigentlich aussehen sollte.
              Deine Backslashs in dem Pfad wundern mich ehrlich gesagt auch.
              Hast du mal mit diesen Einstellungen probiert einen manuellen mount zumachen?
              Sprich über Konsole …
              backitup.1	2018-09-27 08:57:38.498	debug	[ccu] exec: done
              backitup.1	2018-09-27 08:57:38.496	debug	[ccu/umount] done
              backitup.1	2018-09-27 08:57:28.267	debug	[ccu/history] done
              backitup.1	2018-09-27 08:57:28.210	debug	[ccu/telegram] done
              backitup.1	2018-09-27 08:57:28.210	debug	sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.1
              backitup.1	2018-09-27 08:57:28.209	debug	[ccu/telegram] [ccu] used Telegram-Instance: telegram.0
              backitup.1	2018-09-27 08:57:28.183	debug	[ccu/clean] done
              backitup.1	2018-09-27 08:57:28.152	debug	[ccu/ccu] done
              backitup.1	2018-09-27 08:57:12.444	debug	[ccu/ccu] Requesting backup from CCU
              backitup.1	2018-09-27 08:57:12.444	debug	[ccu/ccu] CCU Version: 2.31.25
              backitup.1	2018-09-27 08:57:12.223	debug	[ccu/mount] done
                @peoples:
                Die Daten der Ccu-Weboberfläche hast du ganz zu Anfang Mal festgelegt und ich persönlich habe die seit dem nie mehr benötigt `
                @simatec:
                Gesendet von iPhone mit Tapatalk `
                ich habe für die CCU extra einen account mit administrativen rechten angelegt.
                hätte natürlich auch den admin account nehmen können, aber ich wollte für das backup einen extra account benutzen.
                und selbst mit dem admin account funktioniert das backup nicht.
                ich find es seltsam, dass wenn ich zurück auf die v0.2.7 gehe, das sichern anstandslos funktioniert. sowohl für die CCU als auch für die iobroker sicherung
                und bei der v0.2.7 habe ich bez. der pfadangaben, leerzeichen und backslashes drin.
                die bilder, die ich weiter oben gepostet hatte sind von der v0.2.7; und bei den einstellungen funktioniert, wie gesagt, alles prima. :?
                • simatec
                  Probiere mal keine Backslash zu verwenden und die Leerzeichen in deinem Pfad zu entfernen. Leerzeichen sind in Pfaden und Dateinamen nie gut.
                  Es kann sein, dass shell bei der 0.2.7 damit weniger ein Problem hat.
                  Der Adapter macht aber nun alles über Java und da sollten die Angaben schon richtig sauber sein.
                  Schaue dir mal meine Screenshots an.
                  Verwende statt Leerzeichen lieber Unterstriche.
                  Natürlich müssen die Ordner und Unterordner auch auf deinem NAS umbenannt werden.
                    @simatec:
                    ich habe nun festgestellt, dass wenn ich den pfad einfach in anführungszeichen setze, das backup problemlos funktioniert.
                    die dateien sind auch auf meiner nas existent und inhaltlich OK.
                    das logfile, wenn ich es richtig verstehe, gibt mir dennoch zu bedenken.
                    Gestartet...
                    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.111.100","deleteOldBackup":true,"dir":"\"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker\"","user":"iobroker","pass":"****"}
                    [DEBUG] [mount] - done
                    [DEBUG] [minimal] start with {"type":"creator","time":"03:30","debugging":false,"everyXDays":"14","nameSuffix":"_backitup_","deleteBackupAfter":0,"extensionsEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.111.100","deleteOldBackup":true,"dir":"\"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker\"","user":"iobroker","pass":"****","context":{"fileNames":[],"errors":{},"done":["mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"192.168.111.100","deleteOldBackup":false,"dir":"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker","user":"iobroker","pass":"passwort","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.111.100","deleteOldBackup":true,"dir":"\"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker\"","user":"iobroker","pass":"passwort"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":""},"path":"/var/lib/redis/dump.rdb"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [minimal] - Backup created: /opt/iobroker/backups/minimal__backitup__2018_09_27-12_41_08_backupiobroker.tar.gz
                    [DEBUG] [minimal] - done
                    [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.111.100","deleteOldBackup":true,"dir":"\"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker\"","user":"iobroker","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                    [ERROR] [cifs] - [IGNORED] Path ""prv\Salva\P1\Backup Apps Settings\Server - iobroker"" not found
                    [DEBUG] [clean] start with {"deleteBackupAfter":0}
                    [DEBUG] [clean] - done
                    [DEBUG] [history] start with {"type":"creator","time":"03:30","debugging":false,"everyXDays":"14","nameSuffix":"_backitup_","deleteBackupAfter":0,"extensionsEnabled":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.111.100","deleteOldBackup":true,"dir":"\"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker\"","user":"iobroker","pass":"****","context":{"fileNames":["/opt/iobroker/backups/minimal__backitup__2018_09_27-12_41_08_backupiobroker.tar.gz"],"errors":{},"done":["mount","minimal"],"types":["minimal"]},"adapter":null},"dir":"/opt/iobroker","redis":{"enabled":false,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"Local","host":"192.168.111.100","deleteOldBackup":false,"dir":"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker","user":"iobroker","pass":"passwort","port":"21"},"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"192.168.111.100","deleteOldBackup":true,"dir":"\"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker\"","user":"iobroker","pass":"passwort"},"dropbox":{"enabled":false,"type":"storage","source":"Local","deleteOldBackup":false,"accessToken":""},"path":"/var/lib/redis/dump.rdb"},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"27 September 2018 um 12:41 Uhr"},"backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [history] - backitup.0.history.html
                    [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//192.168.111.100","deleteOldBackup":true,"dir":"\"prv\\Salva\\P1\\Backup Apps Settings\\Server - iobroker\"","user":"iobroker","pass":"****","backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [umount] - done
                    [EXIT] 0
                    • simatec
                      Nein das kannst du ignorieren.
                      Das ist aktuell nur eine reine debug Ausgabe für uns zum testen.
                      Ich werde das mit den Anführungszeichen mal mit in der Doku aufnehmen.
                      Eventuell musst du es durch die Leerzeichen in Anführungszeichen schreiben, damit es im bash auch als Pfad erkannt wird.
                        @simatec:
                        Eventuell musst du es durch die Leerzeichen in Anführungszeichen schreiben, damit es im bash auch als Pfad erkannt wird. `
                        ah ok.. dann funktioniert es bei mir jetzt auch 😄
                        bin halt kein freund von ordnernamen, wo underscore oder bindestrich verwedet werden 😄
                        und das mit den anführungszeichen, wenn leerzeichen benutzt werden, das kannte ich noch aus msdos zeiten 😄
                          daniello last edited by
                          Hmm .. irgendwie fehlt mir bei CIFS das Feld für die HOST-IP. Soll die nun an den Pfad mit rangedengelt werden? OK .. IP unter Mount eintragen .. verstanden. ABER .. bei mir wird noch immer nur Vis.0 gesichert .. ick dreh durch! War beim 2er genauso .. ist auch beim /opt/iobroker/backup so 😞
                          • simatec
                            Mach mal bitte ein Screenshot
                              hier der screen:
                              Und hier mein File-Ordner im Backup:
                              • simatec
                                Das Feld ist weiter unten.
                                Kannst du nicht scrollen?
                                  Da kommen nur noch die Pfade. Um Missverständnisse zu vermeiden: Bei 2.x hieß das Feld in das man die IP des NAS eintragen musste Host .. hier offenbar Mount .. funktioniert aber genau so. Nur um dieses Feld ging es .. bei den Pfaden ist alles wie gewohnt.
                                  • Peoples
                                    @ltsalvatore:
                                    und das mit den anführungszeichen, wenn leerzeichen benutzt werden, das kannte ich noch aus msdos zeiten 😄 `
                                    Ich möchte das gerne nochmal aufgreifen, generell sind Ordner/Dateinamen mit Leerzeichen immer eine schlechte / unprofessionelle Wahl die an und für sich beim Durchschnittsuser nie zu Problemen führen sollte aber es wird problematisch wenn der Pfad als URI benötigt wird, denn muss man den String erst entsprechend als URI kodiert werden. Wenn nun irgendwann unser Backitup - Adapter oder irgendein Anderer mit einer Funktion ausgestattet werden sollte die soetwas nutzt wirst du dann bestimmt Schwierigkeiten bekommen.
                                    Deshalb empfehle ich dir deine Ordner / Dateinamen lieber regelkonform zu benennen, das soll jedoch wirklich nur eine Empfehlung sein und ich hoffe du kriegst das nicht in den falschen Hals.
                                    • simatec
                                      @daniello:
                                      Da kommen nur noch die Pfade. Um Missverständnisse zu vermeiden: Bei 2.x hieß das Feld in das man die IP des NAS eintragen musste Host .. hier offenbar Mount .. funktioniert aber genau so. Nur um dieses Feld ging es .. bei den Pfaden ist alles wie gewohnt. `
                                      Du musst bei mount die IP oder dein host eintragen.
                                      • nieIP
                                        nieIP last edited by
                                        Hallo
                                        ich habe den Adapter auf die aktuelle Version angehoben.
                                        Leider sind alle CIFS Einstellungen verschwunden. Das habe ich jetzt aber wieder hin bekommen. Und das funktioniert auch.
                                        Ist es richtig, das nach einem komplett backup von ioBroker alle Instanzen die eingerichtet sind neu gestartet werden? Deshalb habe ich erst mal nur das Minimale backup eingeschaltet.
                                        Nun unterstützt mein NAS auch NFS. Also wollte ich das mal testen. Die Verbindung kommt aber nicht zu stande.
                                        Kann mir jemand einen Screenshot mit Beispieldaten (Pfade) hier rein stellen? Für Extrapfade für alle backups? Ich habe alle möglichen mount Pfade mit und ohne "/" getestet.
                                        Bei mir kommt nicht mal der mount zu stande 😞
                                        • common-nfs ist auf dem RasPi installiert.
                                        • auf dem NAS ist für den Zugriff "Auth_sys" eingetragen. Wie funktioniert das mit der Authentifizierung?
                                        • nieIP
                                          ie Zustände im Objekt backitup sind immer noch falsch. Trotz erfolgreichem backup
                                          • simatec
                                            Lösche mal die Objekte und starte backitup neu.
                                            Das sind noch dir alten Objekte und die müssen neu angelegt werden.
                                            Das cifs Einstellungen neu eingetragen werden müssen, hatten wir geschrieben.
                                            NFS mount findest du in der Doku beschrieben.
                                            Was bei deinem NAS beachtet werden muss, kann ich leider nicht beantworten.
                                            Da muss aber sicher dein iobroker auch freigegeben werden.
                                            Bei mir funktioniert nfs ohne Probleme mit dem Tinker Board, pi3 ubd auf einem debian.
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1179569
