    4. Adapter: iobroker.backitup (stable Release)
    • simatec
      Bitte mal einen Log posten
      • Homer.J.
        Homer.J. last edited by
        ! Gestartet…
        ! [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"","backupDir":"/opt/iobroker/backups"}
        ! [ERROR] [mount] - [undefined Unable to apply new capability set.
        ! [ERROR] [mount] - [IGNORED] Error: Command failed: mount -t cifs -o user=steffen,password=!!!!,rw,file_mode=0777,dir_mode=0777 //DiskStation1517/sharename/backupDir /opt/iobroker/backups
        ! Unable to apply new capability set.
        ! [DEBUG] [ccu] start with {"type":"creator","time":"10:25","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"
        ","context":{"fileNames":[],"errors":{},"done":[],"types":[]},"adapter":null},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de"},"host":"192.168.178.51","user":"Admin","pass":"","backupDir":"/opt/iobroker/backups"}
        ! [DEBUG] [ccu] - CCU Version: 3.37.8.20180929
        ! [DEBUG] [ccu] - Requesting backup from CCU
        ! [DEBUG] [ccu] - done
        ! [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"
        ","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
        ! [DEBUG] [cifs] - done
        ! [DEBUG] [clean] start with {"deleteBackupAfter":0}
        ! [DEBUG] [clean] - done
        ! [DEBUG] [telegram] start with {"type":"creator","time":"10:25","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"","context":{"fileNames":["/opt/iobroker/backups/homematic_2018_10_11-10_27_20_3.37.8.20180929_backupiobroker.tar.sbk"],"errors":{},"done":["ccu"],"types":["homematic"]},"adapter":null},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de","time":"11 Oktober 2018 um 10:27 Uhr"},"host":"192.168.178.51","user":"Admin","pass":"","backupDir":"/opt/iobroker/backups"}
        ! [DEBUG] [telegram] - [ccu] used Telegram-Instance: telegram.0
        ! [DEBUG] [telegram] - done
        ! [DEBUG] [history] start with {"type":"creator","time":"10:25","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"","context":{"fileNames":["/opt/iobroker/backups/homematic_2018_10_11-10_27_20_3.37.8.20180929_backupiobroker.tar.sbk"],"errors":{},"done":["ccu"],"types":["homematic"]},"adapter":null},"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"11 Oktober 2018 um 10:27 Uhr"},"telegram":{"enabled":true,"type":"message","instance":"telegram.0","systemLang":"de"},"host":"192.168.178.51","user":"Admin","pass":"","backupDir":"/opt/iobroker/backups"}
        ! [DEBUG] [history] - backitup.0.history.html
        ! [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"Local","mount":"//DiskStation1517","deleteOldBackup":false,"dir":"sharename/backupDir","user":"steffen","pass":"****","backupDir":"/opt/iobroker/backups"}
        ! [ERROR] [umount] - umount: /opt/iobroker/backups: must be superuser to unmount
        ! [ERROR] [umount] - [IGNORED] Error: Command failed: umount /opt/iobroker/backups
        ! umount: /opt/iobroker/backups: must be superuser to unmount
        ! [EXIT] 0
        • Homer.J.
          Das ist jetzt die Log Datei von manuellen Backup, wie bekomme ich vom autom. Backup die Log Datei. ?
          • simatec
            Bei dir fehlt in den Einstellungen die Pfadangabe zu deinem NAS.
            • Homer.J.
              Hat bis vor 3 Tagen mit den Einstellungen so funktioniert, wenn ich manuell Anstoße wird das Backup auch in den Ordner wie vorher gespeichert, beim automatischen löscht er mir zwar das alte legt aber eben kein neues an.Ich gebe mal einen neuen Pfad an und versuche es nochmal so.
              Bei mir läuft aber auch IoBroker im docker weiß nicht ob es da Unterschiede gibt. ?
              • simatec
                Kann sein, dass durch ein Update deine Pfadangabe verloren gegangen ist.
                Da wurde was geändert.
                • Homer.J.
                  Kannst du mir vielleicht einen Tipp geben über die Pfadeingabe habe die Ordner so Angelegt.
                  • simatec
                    Ich kenne Diskstation leider nicht.
                    Aber theoretisch sollte der Pfad „Sicherung/iobroker_…..“ sein.
                    • Homer.J.
                      Hab das noch im Log stehen, heißt denke ich das ich keine Verbindung zur Diskstation habe.
                      Benutzer und Passwort sind richtig woran könnte es noch liegen.
                      ! backitup.0
                      ! 2018-10-11 15:45:55.374
                      ! error
                      ! backitup.0
                      ! error
                      ! Error: Command failed: mount -t cifs -o user=steffen,password=!!!!!,rw,file_mode=0777,dir_mode=0777 //192.168.178.33/volume3/Sicherung/ioBroker_minimal /opt/iobroker/backups
                      • simatec
                        Ist das dein Passwort oder nur blind gemacht?
                        Hast du das Paket cifs-utils installiert?
                        „sudo apt-get install cifs-utils“
                        Siehe Doku
                        • Homer.J.
                          Ist nur Blind gemacht.
                          Paket ist übers Terminal installiert.
                          Hab auch keine Ahnung was ich noch machen soll.
                          • simatec
                            Wenn dein Passwort Sonderzeichen hat, setze es mal in den Einstellungen in Anführungszeichen.
                            Statt der IP kannst du auch den Hostname deiner Diskstation mal probieren.
                            Sind die Freigaben in der Diskstation alle eingerichtet?
                            Probiere mal alternativ die nfs Freigabe in deiner Diskstation.
                            • Bluefox
                              Bluefox last edited by
                              Kommando ist fehlgeschlagen, weil vermutlich schon gemountet ist.
                              Und umount nicht funktioniert, weil
                              • dslraser
                                @Bluefox:
                                ```` `  Aha, jetzt kommen wir der Sache näher.
                                Mein ioBroker läuft auf einer Synology Diskstation im Docker, welcher gemountet ist.
                                Ich bekomme die gleichen Fehlermeldungen. FTP hingegen funktioniert.
                                Wie kann man das nun über Cifs oder NFS lösen ?
                                • Homer.J.
                                  Ich hatte vorher das Script von buanet laufen im Aufgabenplaner auf der DS und es jetzt deaktiviert, hat es damit etwas zu tun. ?
                                  • simatec
                                    Eventuell ist da noch der mount vorhanden.
                                    Mach mal ein „sudo umount /opt/iobroker/backups“ über Konsole
                                    Und dann probiere mal manuell zu mounten, damit du erstmal testen kannst, ob deine ganzen Pfade stimmen.
                                      jeti last edited by
                                      ich hatte gestern einen selbstverschuldeten Stromausfall, hier ist so einiges nun durcheinander… wo finde ich denn in einem alten Backup, ja diese habe ich, möchte ich aber nicht komplett einspielen, die configuration von backitup?
                                      Ich hänge an der CIFS Konfiguration die ich vorher am laufen hatte, aber in den Backups nicht finde ...
                                      Danke und Gruß
                                      EDIT: ok, CIFS geht wieder -> aber interessehalber, wo legt iobroker die ganzen configs ab?
                                      • simatec
                                        In dem minimal backup ist eine json.
                                        In der könntest du mit einem Editor schauen.
                                        Bin aber gerade nicht am Rechner, um selber zu schauen.
                                          Ritter last edited by
                                          ich habe iobroker unter Windows laufen. Braucht man hierfür auch cifs-utils? Wenn ja, wie installiert man das? Bekomme nämlich die Synology Diskstation nicht gemountet.
                                          • Homer.J.
                                            hab es jetzt mal auf meiner Testumgebung installiert Pfad eingegeben, die Testumgebung habe ich auf einem Tinker laufen und funktioniert wunderbar.
                                            Die selbe Einstellung auf der DS funktioniert nicht was muss ich ändern.
                                            1.3k
                                            81.1k
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1185571
