    4. IoBroker mach nur noch Probleme
      Elektroman last edited by
      Platform: linux
      Architecture: arm
      CPUs: 2
      Speed: 0 MHz
      Model: Marvell PJ4Bv7 Processor rev 2 (v7l)
      RAM: 1009.4 MB
      System uptime: 4 T. 08:33:45
      Node.js: v6.12.3
      NPM: 4.6.1
      adapters count: 198
      Uptime: 03:57:02
        Ich komme nicht mehr weiter
        Es kommen immer neue Fehlermeldungen dazu:
        m-rpc.3	2018-10-11 20:37:24.517	error	Error: You are sending too fast
        hm-rpc.3	2018-10-11 20:37:24.517	error	Error: You are sending too fast
        hm-rpc.3	2018-10-11 20:37:24.517	error	binrpc -> setValue ["1","ON_TIME",30] FLOAT
        hm-rpc.3	2018-10-11 20:37:24.516	error	Error: You are sending too fast
        hm-rpc.3	2018-10-11 20:37:24.515	error	binrpc -> setValue ["1","STATE",true] BOOL
        hm-rpc.3	2018-10-11 20:37:24.515	error	Error: You are sending too fast
        hm-rpc.3	2018-10-11 20:37:24.515	error	binrpc -> setValue ["1","ON_TIME",30] FLOAT
        hm-rpc.3	2018-10-11 20:37:24.514	error	binrpc -> setValue ["1","ON_TIME",30] FLOAT
        hm-rpc.3	2018-10-11 20:37:24.514	error	Error: You are sending too fast
        hm-rpc.3	2018-10-11 20:37:24.514	error	binrpc -> setValue ["1","STATE",true] BOOL
        hm-rpc.3	2018-10-11 20:37:24.513	error	Error: You are sending too fast
        hm-rpc.3	2018-10-11 20:37:24.513	error	binrpc -> setValue ["1","ON_TIME",30] FLOAT
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:17.429	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:17.167	info	Restart adapter system.adapter.hm-rpc.0 because enabled
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:17.167	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:17.043	info	Restart adapter system.adapter.hm-rega.0 because enabled
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:17.042	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:14.197	info	Restart adapter system.adapter.javascript.1 because enabled
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:14.196	error	instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:16.648	info	Restart adapter system.adapter.javascript.2 because enabled
          host.ioBroker-Pi3-slave-sw	2018-10-11 20:38:16.646	error	instance system.adapter.javascript.2 terminated with code 7 (Adapter already running)
            apollon77 last edited by
            @Elektroman:
            was soll ich sagen, die Ram Probleme sind weg.
            Ich habe aber leider weiterhin Adapter die nicht mehr funktionieren u.a. "s7" bzw. Adapter die immer mal wieder neu starten (grün-rot-grün)
            host.raspberrypi	2018-10-11 18:39:59.376	error	instance system.adapter.s7.0 terminated with code 0 (OK)
            host.raspberrypi	2018-10-11 18:39:59.376	error	Caught by controller[0]: at Module._compile (module.js:577:32)
            host.raspberrypi	2018-10-11 18:39:59.376	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/lib/node-snap7.js:9:45)
            host.raspberrypi	2018-10-11 18:39:59.375	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.s7/node_modules/node-snap7/node_modules/bindings/bindings.js:76:44)
            host.raspberrypi	2018-10-11 18:39:59.375	error	Caught by controller[0]: at require (internal/module.js:20:19)
            host.raspberrypi	2018-10-11 18:39:59.375	error	Caught by controller[0]: at Module.require (module.js:504:17)
            host.raspberrypi	2018-10-11 18:39:59.374	error	Caught by controller[0]: at Function.Module._load (module.js:445:3)
            host.raspberrypi	2018-10-11 18:39:59.374	error	Caught by controller[0]: at tryModuleLoad (module.js:453:12)
            host.raspberrypi	2018-10-11 18:39:59.374	error	Caught by controller[0]: at Module.load (module.js:494:32)
            host.raspberrypi	2018-10-11 18:39:59.373	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:604:18)
            host.raspberrypi	2018-10-11 18:39:59.373	error	Caught by controller[0]: at Error (native)
            host.raspberrypi	2018-10-11 18:39:59.372	error	Caught by controller[0]: Error: Module version mismatch. Expected 48, got 46.</anonymous>
            Kann es sein das du nodejs Update gemacht hast?
            Betroffenen Adapter Neu installieren sollte das fixen.
            Oder in das Verzeichnis des Adapters in node_modules und npm rebuild eingeben.
            Gesendet vom Handy …
              @Elektroman:
              Welches deiner Skripte setzt diese States? Dann checke diese Skripte. Scheinbar läuft da was Amok und sendet viel zu schnell Kommandos an hm-rpc.3. Und genau so ein Skript Problem kann die Ursache für „reconnection to dB“ sein.
                @Elektroman:
                Siehe letzter Post. Ich tippe darauf das bei dir irgend ein Skript Müll baut und das der verursacher ist.
                  Ok, vielen Dank für die schnelle Hilfe
                  Ich schaue morgen mal weiter.
                  Ich habe für heute die Nase voll. Ich drehe mich jetzt schon seit Wochen im Kreis
                    @apollon77:
                    @Elektroman:
                    Gesendet vom Handy … `
                    Beim Master oder bei einem der Slaves?
                      Na da Wonder s7 Adapter installiert ist der da meckert …
                      Gesendet vom Handy ...
                        Neuer Tag neues Glück
                        ich habe beim Master und bei einem der zwei Slave das Verzeichnis "iobroker.s7" vorhanden? Habe es bei beiden es ausgeführt
                          Es sind mehrere Adapter 😢
                          npm rebuild ergab keine Besserung
                          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:39.388	info	Restart adapter system.adapter.admin.0 because enabled
                          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:39.387	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
                          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:38.401	info	Restart adapter system.adapter.hm-rega.0 because enabled
                          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:38.401	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
                          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:36.886	info	instance system.adapter.hm-rega.0 started with pid 3386
                          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:36.439	info	instance system.adapter.admin.0 started with pid 3380
                          host.ioBroker-Pi3-slave-sw	2018-10-12 18:40:35.691	info	Restart adapter system.adapter.hm-rpc.0 because enabled
                            npm rebuild von s7 sorgt erstmal nur dafür das s7 wieder tut … alles andere ist was anderes.
                            Schau Die betroffenen Adapter an die mit error 7 gemeckert werden und kille die prozesse die da laufen oder mach nen reboot
                              Ich bin gerade vorsichtig optimistisch. 😉
                              Habe vor ca. 3 Std einen reboot an allen Hosts durchgeführt, bis jetzt bleibt es ruhig
                              Hat doch was gebracht, danke dafür
                              81.1k
                              4313
