    4. Adapter: iobroker.backitup (stable Release)
      tempestas last edited by
      ! backitup.0 2018-10-13 10:34:10.960 debug system.adapter.admin.0: logging true
      ! backitup.0 2018-10-13 10:27:29.567 debug [minimal] exec: done
      ! backitup.0 2018-10-13 10:27:29.564 debug [minimal/umount] done
      ! backitup.0 2018-10-13 10:27:29.563 debug [minimal/history] backitup.0.history.html
      ! backitup.0 2018-10-13 10:27:29.532 debug [minimal/telegram] done
      ! backitup.0 2018-10-13 10:27:29.532 debug sendTo "send" to system.adapter.telegram.0 from system.adapter.backitup.0
      ! backitup.0 2018-10-13 10:27:29.526 debug [minimal/telegram] [minimal] used Telegram-Instance: telegram.0
      ! backitup.0 2018-10-13 10:27:29.517 debug [minimal/clean] done
      ! backitup.0 2018-10-13 10:27:29.515 debug [minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      ! backitup.0 2018-10-13 10:27:29.507 debug [minimal/cifs] [IGNORED] Path "FRITZ-NAS/fritz.nas/INTENSO/iob_auto_backup/back_it_up" not found
      ! backitup.0 2018-10-13 10:27:29.502 debug [minimal/ftp] done
      ! backitup.0 2018-10-13 10:27:29.498 debug [minimal/ftp] Error: /FRITZ-NAS/fritz.nas/INTENSO/iob_auto_backup/back_it_up/ftp/minimal/minimal_2018_10_13-10_27_10_backupiobroker.tar.gz: Permission denied.
      ! backitup.0 2018-10-13 10:27:29.479 debug [minimal/ftp] Send minimal_2018_10_13-10_27_10_backupiobroker.tar.gz
      ! backitup.0 2018-10-13 10:27:29.476 debug [minimal/ftp] FTP connected.
      ! backitup.0 2018-10-13 10:27:28.998 debug [minimal/minimal] done
      ! backitup.0 2018-10-13 10:27:28.948 debug [minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2018_10_13-10_27_10_backupiobroker.tar.gz
      ! backitup.0 2018-10-13 10:27:10.830 debug [minimal/mount] done
      ! backitup.0 2018-10-13 10:27:06.543 debug [total] 10 00 03 */5 * *
      liegt wohl am Pfad?
      • simatec
        Ja deine Pfadangabe zum FTP Server stimmt nicht.
        • haselchen
          haselchen Most Active last edited by
          Probier mal im Pfad nur das einzutragen /iob_auto_backup/back_it_up/ftp
          Wenn das dein ftp Pfad ist…..
            Danke für die Antworten.
            er sagt mir jetzt immer "permission denied". Habe nun alle möglichen fritz box Anmeldedaten ausprobiert, die direkt an der Box auch alle funktionieren. Was mache ich falsch?
            • simatec
              Was willst du genau tun? Cifs oder ftp?
              • haselchen
                In der Fritzbox , für was genau hast du dem FritzBox Benutzer Freigaben erteilt?
                Nur für einen Ordner auf der Festplatte oder auf die ganze Festplatte?
                Wenn auf die ganze Festplatte, dann sollte /Ordner für Dein Backup reichen in der Pfadangabe im Backitup Adapter.
                Meine Festplatte habe ich Buddha genannt und der Ordner heisst bei mir IOBrokerBackup. Ich habe dem Benutzer die Freigabe für die ganze Festplatte erteilt in der FritzBox (Haken bei Zugriff auf NAS Inhalten nicht vergessen) und wichtig FTP Freigabe in der Fritzbox auch erteilen.
                Mein Pfad im Adapter heisst nur /IOBrokerBackup
                  ftp wäre für mich ok, da habe ich wenigstens ne grobe Vorstellung, was das ist. bei cifs habe ich zwar die sachen auf dem nuc installiert, aber was das nun ist, weiß ich nicht..
                  @haselchen: habs mit verschiedenen nutzern inklusive admin versucht, der alles kann und darf… immer "permission denied".
                  • simatec
                    Poste mal bitte ein Screenshot deiner FTP Konfiguration in backitup.
                    Ich denke da stimmt der Host und auch der Pfad nicht
                      Für Standard und voll sind auf dem Screen zwei verschieden Pfade angegeben, weil ich am Beispiel des normalen alle möglichen Pfade ausprobiert habe.
                      • simatec
                        Ich denke das fritz.nas muss oben als host rein und unten aus dem Pfad raus.
                          es bleibt leider bei permission denied.. ich verstehe es nicht..
                          • simatec
                            Hast du denn mal deine FTP Verbindung über einen FTP Client getestet?
                            Damit würdest du sicher den genauen Pfad rausbekommen
                              war eine gute idee… auch da erhalte ich immer "verbindung abgelehnt..."
                              keine Ahnung wieso, bin jetzt nicht übermäßig PC affin.
                              ÜBer den Explorer kann ich Dinge auf den stick an der Fritz Box verschieben
                              • simatec
                                Denke da stimmt denn was mit deinen Zugangsdaten und Berechtigungen nicht.
                                  Guten Morgen,
                                  es hat endlich geklappt.
                                  Zum einen war wohl der Stick an der FB kaputt. Habe jetzt ein Platte dran und alles rennt.
                                  Ebenfalls war nach wie vor der Pfad falsch. Das möchte ich gerne als Anregung aufnehmen. In einigen Konstellationen wurde gesagt "falscher Pfad" (siehe eines meiner ersten Postings". Danach kam aber immer "permission denied", was für Laien wie mich klingt, als wären user oder pw falsch. Es war aber der Pfad.
                                  Jedenfalls herzlichen Dank für die Hilfestellung und den tollen Adapter!
                                  Richtig geile Sache!
                                  • simatec
                                    Sehr schön zu lesen, dass es jetzt funktioniert.
                                    Viel Spaß mit dem Adapter [emoji4]
                                    • simatec
                                      Ab sofort ist auf dem Github die Version 0.3.6 verfügbar und ab heute Nacht auch im latest.
                                      0.3.6 (16.10.2018)
                                      __(simatec) Fix Dropbox Backup
                                      (simatec) Fix Restore path for ownDir
                                      (simatec) Fix FTP and NAS path
                                      (simatec) Fix Access Token for dropbox__
                                      Ab dieser Version ist es nicht mehr erforderlich bei der Pfadangabe darauf zu achten, dass die Pfade mit oder ohne "/" beginnen.
                                      Der Adapter erkennt dies nun allein und passt sich das ganze beim mount oder FTP an.
                                      Viel Spaß beim testen …
                                        daniello last edited by
                                        Hi .. erste Nacht mit v0.3.6 .. da fällt mir dies auf (womöglich war es schon vorher da?!)
                                        host.ioBroker	2018-10-19 02:00:17.595	error	instance system.adapter.backitup.0 terminated with code 0 (OK)
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: path: '/opt/iobroker/backups' }
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: syscall: 'mkdir',
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: code: 'EEXIST',
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: errno: -17,
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at Timer.listOnTimeout (timers.js:290:5)
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at tryOnTimeout (timers.js:323:5)
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at ontimeout (timers.js:498:11)
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule/lib/schedule.js:501:7)
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule/lib/schedule.js:543:11
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at Job.invoke (/opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule/lib/schedule.js:173:10)
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at Job.backupTimeSchedules.(anonymous function).schedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.backitup/main.js:148:17)
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at startBackup (/opt/iobroker/node_modules/iobroker.backitup/main.js:36:9)
                                        Caught	2018-10-19 02:00:17.595	error	by controller[0]: at executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:46:16)
                                        Caught	2018-10-19 02:00:17.594	error	by controller[0]: at Object.fs.mkdirSync (fs.js:885:18)
                                        Caught	2018-10-19 02:00:17.594	error	by controller[0]: { Error: EEXIST: file already exists, mkdir '/opt/iobroker/backups'
                                        backitup.0	2018-10-19 02:00:17.589	info	terminating
                                        backitup.0	2018-10-19 02:00:17.086	error	at Timer.listOnTimeout (timers.js:290:5)
                                        backitup.0	2018-10-19 02:00:17.086	error	at tryOnTimeout (timers.js:323:5)
                                        backitup.0	2018-10-19 02:00:17.086	error	at ontimeout (timers.js:498:11)
                                        backitup.0	2018-10-19 02:00:17.086	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule/lib/schedule.js:501:7)
                                        backitup.0	2018-10-19 02:00:17.086	error	at /opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule/lib/schedule.js:543:11
                                        backitup.0	2018-10-19 02:00:17.086	error	at Job.invoke (/opt/iobroker/node_modules/iobroker.backitup/node_modules/node-schedule/lib/schedule.js:173:10)
                                        backitup.0	2018-10-19 02:00:17.086	error	at Job.backupTimeSchedules.(anonymous function).schedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.backitup/main.js:148:17)
                                        backitup.0	2018-10-19 02:00:17.086	error	at startBackup (/opt/iobroker/node_modules/iobroker.backitup/main.js:36:9)
                                        backitup.0	2018-10-19 02:00:17.086	error	at executeScripts (/opt/iobroker/node_modules/iobroker.backitup/lib/execute.js:46:16)
                                        backitup.0	2018-10-19 02:00:17.086	error	at Object.fs.mkdirSync (fs.js:885:18)
                                        backitup.0	2018-10-19 02:00:17.086	error	Error: EEXIST: file already exists, mkdir '/opt/iobroker/backups'
                                        backitup.0	2018-10-19 02:00:17.086	error	uncaught exception: EEXIST: file already exists, mkdir '/opt/iobroker/backups'
                                          schittl last edited by
                                          Moin,
                                          kleiner Hinweis(nur ggf. zur Abrundung):
                                          Die Telegram-Message ist noch (habe Version 0.3.5) nicht korrigiert worden, wenn man CIFS nutzt. Ist ja kein funktionaler Fehler. Hier mal mein Beitrag von damals dazu:
                                          viewtopic.php?f=23&t=15256&p=173291#p173106
                                          Oder ist das mit 0.3.6 eventuell korrigiert?
                                          vg
                                          Falk
                                          • simatec
                                            @daniello:
                                            Wann trat denn diese Meldung auf?
                                            81.1k
                                            adapter backitup backup iobroker backup iobroker.backitup
                                            185
                                            2335
                                            1186387
