    4. [Aufruf] DENON & Marantz Adapter
    • foxriver76
      @BlueEssi:
      Adapter startet nicht mehr in Version 0.4.0.
      Fehlerlog:
      uncaught exception: Cannot read property 'common' of null
      Version 0.3.9 installiert und es läuft. `
      Kannst du bitte die entsprechenden Zeilen aus dem Log posten?
        BlueEssi last edited by
        @foxriver76:
        @BlueEssi:
        Fehlerlog:
        Kannst du bitte die entsprechenden Zeilen aus dem Log posten? `
        2018-09-23 20:35:06.604 - error: denon.0 uncaught exception: Cannot read property 'common' of null
        2018-09-23 20:35:06.605 - error: denon.0 TypeError: Cannot read property 'common' of null
        at Socket.adapter.getObject (C:\ioBroker\node_modules\iobroker.denon\main.js:767:62)
        at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:319:9)
        at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:244:12)
        at Manager. (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
        at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
        at Manager.ondecoded (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:345:8)
        at Decoder. (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
        at Decoder.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
        at Decoder.add (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\socket.io-parser\index.js:251:12)
        at Manager.ondata (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:335:16)
        2018-09-23 20:35:06.605 - info: denon.0 [END] Stopping Denon AVR adapter...
        • foxriver76
          Danke, werde es mir anschauen.
          Fehler gefunden, werde gleich was pushen.
          • foxriver76
            Falls keiner mit 0.4.1 Probleme hat, werde ich sie in knapp einer Woche auf stable setzen. Ansonsten bitte melden. 😉
            Ab sofort gibt es eine umfangreiche deutsche Dokumentation: https://github.com/foxriver76/ioBroker. … /README.md
            Diese ist nun auch im ersten Beitrag verlinkt. In diesem Zusammenhang weiße ich gerne nochmal auf folgenden Thread hin: viewtopic.php?f=8&t=16933
            beste Grüße fox
              Sorry, wusste nicht, dass ich hätte etwas testen können.
              Der Fehler trat beim ersten Start immer noch auf. Fehlerlog:
              denon.0 2018-09-28 22:25:58.256 error at Manager.ondata (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:335:16)
              denon.0 2018-09-28 22:25:58.256 error at Decoder.add (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\socket.io-parser\index.js:251:12)
              denon.0 2018-09-28 22:25:58.256 error at Decoder.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
              denon.0 2018-09-28 22:25:58.256 error at Decoder. <anonymous>(C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
              denon.0 2018-09-28 22:25:58.256 error at Manager.ondecoded (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\manager.js:345:8)
              denon.0 2018-09-28 22:25:58.256 error at Manager.Emitter.emit (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-emitter\index.js:133:20)
              denon.0 2018-09-28 22:25:58.256 error at Manager. <anonymous>(C:\ioBroker\node_modules\iobroker.js-controller\node_modules\component-bind\index.js:21:15)
              denon.0 2018-09-28 22:25:58.256 error at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:244:12)
              denon.0 2018-09-28 22:25:58.256 error at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:319:9)
              denon.0 2018-09-28 22:25:58.256 error at Socket.adapter.getObject (C:\ioBroker\node_modules\iobroker.denon\main.js:762:66)
              denon.0 2018-09-28 22:25:58.256 error TypeError: Cannot read property 'common' of null
              denon.0 2018-09-28 22:25:58.256 error uncaught exception: Cannot read property 'common' of null</anonymous></anonymous>
              Beim zweiten Start der Instanz ging es dann aber.
              • foxriver76
                Oh gerade mindestens noch ein Copy Paste Fehler entdeckt, Picture Mode wird als Button angelegt.
                Ich schaue eben mal.
                • foxriver76
                  Tests laufen eben durch, danach ist die Sache gefixt. Wenn du sowieso einen fähigen Receiver hast, wäre es cool wenn du dann mal probierst den pictureMode zu setzen.
                  beste Grüße
                  fox
                  • foxriver76
                    Aufgrund von https://github.com/foxriver76/ioBroker.denon/issues/25 bietet 0.5.0 nun die Funktionalität die Speaker Level anzupassen und auszulesen für das aktuelle selectInput.
                    Dies ist derzeit möglich für 1x Center 2x Front Speaker und 2x Surround Speaker.
                    beste Grüße
                    fox
                    Mazze85 created this issue in foxriver76/ioBroker.denon
                    closed Speaker Level #25
                      Eloee last edited by
                      Habe einen Marantz NR1506 bei welchem auch das meiste funktioniert, vielen Dank dafür schonmal!
                      Allerdings habe ich auf der Fernbedienung 4 "Smart Select" Knöpfe, auf welche ich mir Internetradio Sender programmiert habe, weil ich die sonst nicht eingeschaltet bekomme da man da immer wieder den Sender neu auswählen muss…
                      Habe nun schon mit den quickSelect1-5 States versucht diese Smartselect Einstellungen zu triggern, funktioniert aber leider nicht :?
                      Kannst du die SmartSelect Knöpfe auch noch irgendwie aufnehmen?
                      Liebe Grüße
                      Eloee
                      • foxriver76
                        @Eloee:
                        Liebe Grüße
                        Eloee `
                        "Smart Select" ist wohl Marantz Äquivalent zu "Quick Select"?
                        Probier mal bitte mittels settings.exertCommand z. B.
                        ZMSMART1
                        oder nur
                        SMART1
                        • foxriver76
                          Habe in dem Zusammenhang sogar herausgefunden, dass man die Quick Select Source anscheinend doch abfragen kann. Somit könnte man aus den Buttons einen Key-Value state machen, der auch einen acknowledge bekommt. Leider kommt der nicht von selbst und muss mit gepollt werden.
                          Dies scheint man mittels
                          MSQUICK ?
                          für DENON zu erfragen. Bei Marantz entsprechend
                          MSSMART ?
                          Das würde ebenfalls ermöglichen, für die jeweiligen Marken die Funktionalität zu wechseln.
                          • foxriver76
                            Bitte GitHub 0.6.0 probieren. Die Buttons werden nicht mehr funktionieren, sondern dafür der quickSelect Datenpunkt, mit Nummern von 1-5.
                            Die quickSelect Buttons bitte manuell löschen, nach einem Upgrade.
                              Habe es gestern Nacht noch getestet, funktioniert nun super mit der 0.6.0, vielen Dank für die Mühen !!!!!!
                              Falls sonst jemand weiß, wie man bei einem NR1506 (nicht über SmartSelect) einen Internetradio Sender auswählen kann, immer her damit 🙂
                              Liebe Grüße
                              Eloee
                              • foxriver76
                                Mir ist vorhin aufgefallen, dass man Bluetooth nicht über selectInput ansteuern konnte. Habe es nun hinzugefügt, via:
                                setState('denon.0.zoneMain.selectInput', '22', false);
                                oder
                                setState('denon.0.zoneMain.selectInput', 'BT', false);
                                möglich ab 1.1.0. Wer BT nutzen möchte, ohne den Adapter neu hinzuzufügen, sollte die betroffenen States (zoneMain.selectInput + evtl. die der anderen Zones) ein mal löschen.
                                beste Grüße
                                fox
                                • foxriver76
                                  @Eloee:
                                  Liebe Grüße
                                  Eloee `
                                  Ab morgen im Latest, was auch dir helfen könnte, falls von dir nicht sogar der Wunsch auf Github kam:
                                  Version 1.2.0 mit den folgenden neuen States:
                                  • info.onlinePresets
                                  • settings.savePreset
                                  • settings.loadPreset
                                  Erklärung der States findet ihr hier: https://github.com/foxriver76/ioBroker. … /README.md
                                  Einfach mit Strg+F den gewünschten State suchen.
                                  beste Grüße
                                  fox
                                    church last edited by
                                    Ich muss mal blöd fragen:
                                    Wo finde ich "mute"?
                                    Wurde ja öfters hier im Thread erwähnt, ich sehe aber nur "muteIndicator", was scheinbar readonly ist?!
                                    • foxriver76
                                      @church:
                                      Wurde ja öfters hier im Thread erwähnt, ich sehe aber nur "muteIndicator", was scheinbar readonly ist?! `
                                      Ich habe im Post oben drüber die Doku verlinkt, ist sogar auf Deutsch.
                                      • Mic
                                        Mic Developer last edited by
                                        @foxriver76:
                                        • settings.loadPreset `
                                        Klasse, vielen Dank für diese neue Funktion! Läuft soweit sehr gut bei mir 🙂 Endlich kann ich damit über VIS die Online-Musik ansteuern.
                                        • foxriver76
                                          @Mic:
                                          @foxriver76:
                                          Klasse, vielen Dank für diese neue Funktion! Läuft soweit sehr gut bei mir 🙂 Endlich kann ich damit über VIS die Online-Musik ansteuern. `
                                          Freut mich, vielen Dank fürs Feedback.
                                          • hg6806
                                            hg6806 Most Active last edited by
                                            Klasse Funktion!
                                            Ich hatte mir die Sender als Buttons programmiert, und über HTTP Get kann man dann den entspr. Sender auswählen.
                                            Mit der neuen Funktion ist es natürlich eleganter.
                                            Wie stellt ihr denn das JSON Widget "Basic table" ein?
                                            Ich bekomme da nichts angezeigt wenn ich da unter Tablr Object ID den Datenpunkt einsetze.
                                            31.7k
                                            79.8k
                                            denon
                                            28
                                            335
                                            51862
