    4. [Aufruf] ZigBee CC253x Adapter
    • N
      NetFritz last edited by
      Hallo
      @ arteck
      Objekt upload, gelöscht u Adapter neustart hatte ich schon gemacht.
      Jetzt alles nochmal nach deiner Anweisung durchgeführt.
      Das Fragezeichen ist jetzt aus der Kachel weg.
      Im Objekt sind jetzt alle Objekte der Fernbedienung da, aber keine Werte.
      Die Dateien sind mit den Eintragungen "lumi.remote" da.
      In der Log habe ich noch Fehlermeldungen wenn ich den Taster betätige.
      2018-10-19 10:44:44.540  - [34mdebug[39m: zigbee.0 handleMessage. {"type":"attReport","endpoints":[{"device":{"_id":5,"type":"EndDevice","ieeeAddr":"0x00158d0001ef5edd","nwkAddr":16447,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.remote.b1acn01\u0000\u0000\u0000\u0000\u0000\u0000","epList":[1],"status":"online","joinTime":1539937493,"endpoints":{"1":"[Circular]"}},"profId":260,"epId":1,"devId":259,"inClusterList":[0,3,18],"outClusterList":[0],"clusters":{"zapp":null,"genBasic":{"dir":{"cid":"genBasic","sid":"dir","value":3},"attrs":{"65281":[null,null,null,null,null,null,[null,3]],"cid":"genBasic","sid":"attrs","modelId":"lumi.remote.b1acn01"}},"genIdentify":{"dir":{"cid":"genIdentify","sid":"dir","value":1},"attrs":{"cid":"genIdentify","sid":"attrs"}},"genMultistateInput":{"dir":{"cid":"genMultistateInput","sid":"dir","value":1},"attrs":{"cid":"genMultistateInput","sid":"attrs","presentValue":1}}},"onAfDataConfirm":null,"onAfReflectError":null,"onAfIncomingMsg":null,"onAfIncomingMsgExt":null,"onZclFoundation":null,"onZclFunctional":null}],"data":{"cid":"genMultistateInput","data":{"presentValue":1}},"linkquality":94}
      2018-10-19 10:44:44.542  - [34mdebug[39m: zigbee.0 Device 0x00158d0001ef5edd emit event attReport with data:{"cid":"genMultistateInput","data":{"presentValue":1}}
      2018-10-19 10:44:44.543  - [31merror[39m: zigbee.0 Unknown device model lumi.remote.b1acn01       emit event attReport with data:{"cid":"genMultistateInput","data":{"presentValue":1}}
      Gruß NetFritz
        h2okopfmt last edited by
        Leider kein erfolg !
        hab es ca 5x versucht.
        aber diesen Eintrag
        ob du den Eintrag
        CODE: ALLES AUSWÄHLEN
        lumi.remote
        gibt es bei mir nicht in den beiden Dateien !!
        kann ich diese händisch hinzufügen ?
        wenn ja wie muss der block aussehen ?
        oder kann man die beiden Dateien
        /opt/iobroker/node_modules/iobroker.zigbee/lib/devstates.js
        und
        /opt/iobroker/node_modules/zigbee-shepherd-converters/devices.js
        einfach austauschen ?
        • N
          Hallo
          Hast Du unter Instanzen Devices nach den anlernen die Kachel mit lumi.remonte ?
          Gruß NetFritz
            Wenn Du diese meinst, ja 😉
            ich hab jetzt mal einfach die beiden Dateien ergänzt 😉
            mit :
            in Zeile 692
            vendor: 'Xiaomi',
            models: ['lumi.remote_b1acn01'],
            icon: 'img/aqara.switch.png',
            states: [states.click, states.double_click, states.triple_click, states.quad_click,
            states.voltage, states.battery
            und
            mit :
            in Zeile 85
            zigbeeModel: ['lumi.remote.b1acn01'],
            model: 'WXKG11LM',
            vendor: 'Xiaomi',
            description: 'Aqara wireless switch',
            supports: 'single, double, triple, quadruple click',
            fromZigbee: [fz.xiaomi_battery_3v, fz.WXKG11LM_click, fz.ignore_onoff_change, fz.ignore_basic_change],
            toZigbee: [],
            und was soll ich sagen 😉
            wäre zu einfach gewesen 😞
            klappt auch nicht !
            • N
              Hallo
              ` > @arteck
              weiter gehts… den Adapter hast du über GIT installiert..also über die Katze ?? die Versionsnummer ist hier irrelevant.. es muss über Git installiert sein
              https://github.com/arteck/ioBroker.zigbee
              hast du upload gemacht
              iobroker zigbee.0 upload
              dach nochmal schauen (also objekt löschen neustarten) `
              Hast Du das gemacht, bei mir hat das geholfen, das die Objekte da sind aber noch keine Werte.
              Gruß NetFritz
                @NetFritz:
                Hallo
                @ arteck
                Gruß NetFritz `
                ok das ist schon mal wichtig… jetzt müssen wir rausfinden woran es ligt das die zigbee schnitstelle nicht mitmacht...
                poste mal die db aus zigbee
                /opt/iobroker/iobroker-data/zigbee_0/shepherd.db
                in dieser stehen alle Geräte
                • N
                  Hallo
                  Hier die /opt/iobroker/iobroker-data/zigbee_0/shepherd.db
                  {"id":5,"type":"EndDevice","ieeeAddr":"0x00158d0001ef5edd","nwkAddr":16447,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.remote.b1acn01\u0000\u0000\u0000\u0000\u0000\u0000","epList":[1],"status":"online","joinTime":1539882127,"endpoints":{"1":{"profId":260,"epId":1,"devId":259,"inClusterList":[0,3,18],"outClusterList":[0],"clusters":{"genBasic":{"dir":{"value":3},"attrs":{}},"genIdentify":{"dir":{"value":1},"attrs":{}},"genMultistateInput":{"dir":{"value":1},"attrs":{}}}}},"_id":"94VAz5kMw68NP6Ol"}
                  {"id":4,"type":"Router","ieeeAddr":"0x7cb03eaa00ad2bc9","nwkAddr":29077,"manufId":48042,"manufName":"OSRAM","powerSource":"Mains (single phase)","modelId":"Plug 01","epList":[3],"status":"online","joinTime":1539744548,"endpoints":{"3":{"profId":49246,"epId":3,"devId":16,"inClusterList":[0,3,4,5,6,2820,4096,64527],"outClusterList":[25],"clusters":{"64527":{"dir":{"value":1},"attrs":{"0":0}},"genBasic":{"dir":{"value":1},"attrs":{"zclVersion":1,"appVersion":12,"stackVersion":2,"hwVersion":1,"manufacturerName":"OSRAM","modelId":"Plug 01","dateCode":"20140331DEOS****","powerSource":1,"deviceEnabled":1,"swBuildId":"V1.04.12"}},"genIdentify":{"dir":{"value":1},"attrs":{"identifyTime":0}},"genGroups":{"dir":{"value":1},"attrs":{"nameSupport":0}},"genScenes":{"dir":{"value":1},"attrs":{"count":0,"currentScene":0,"currentGroup":0,"sceneValid":0,"nameSupport":0}},"genOnOff":{"dir":{"value":1},"attrs":{"onOff":0,"globalSceneCtrl":1,"onTime":0,"offWaitTime":0}},"genOta":{"dir":{"value":2},"attrs":{}},"haElectricalMeasurement":{"dir":{"value":1},"attrs":{"measurementType":8,"activePower":28000}},"lightLink":{"dir":{"value":1},"attrs":{}}}}},"_id":"HKuxE1LqO7iW7v70"}
                  {"id":2,"type":"EndDevice","ieeeAddr":"0x00158d0001e73c0a","nwkAddr":57807,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.sensor_magnet","epList":[1],"status":"offline","joinTime":null,"endpoints":{"1":{"profId":260,"epId":1,"devId":260,"inClusterList":[0,3,25,65535],"outClusterList":[0,3,4,5,6,8,25],"clusters":{"genBasic":{"dir":{"value":3},"attrs":{}},"genIdentify":{"dir":{"value":3},"attrs":{}},"genGroups":{"dir":{"value":2},"attrs":{}},"genScenes":{"dir":{"value":2},"attrs":{}},"genOnOff":{"dir":{"value":2},"attrs":{}},"genLevelCtrl":{"dir":{"value":2},"attrs":{}},"genOta":{"dir":{"value":3},"attrs":{}},"manuSpecificCluster":{"dir":{"value":1},"attrs":{}}}}},"_id":"Qt8Y7AbTnWyl5faQ"}
                  {"id":1,"type":"Coordinator","ieeeAddr":"0x00124b0018ed2eef","nwkAddr":0,"manufId":0,"epList":[1,2,3,4,5,6],"status":"online","joinTime":1539744546,"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"2":{"profId":257,"epId":2,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"3":{"profId":261,"epId":3,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"4":{"profId":263,"epId":4,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"5":{"profId":264,"epId":5,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"6":{"profId":265,"epId":6,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}}},"_id":"m2jdfqVfRcq7YCg8"}
                  {"$indexCreated":{"fieldName":"id","unique":true,"sparse":false}}
                  {"id":1,"type":"Coordinator","ieeeAddr":"0x00124b0018ed2eef","nwkAddr":0,"manufId":0,"epList":[1,2,3,4,5,6],"status":"online","joinTime":1539937493,"endpoints":{"1":{"profId":260,"epId":1,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"2":{"profId":257,"epId":2,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"3":{"profId":261,"epId":3,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"4":{"profId":263,"epId":4,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"5":{"profId":264,"epId":5,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}},"6":{"profId":265,"epId":6,"devId":5,"inClusterList":[],"outClusterList":[],"clusters":{}}},"_id":"m2jdfqVfRcq7YCg8"}
                  {"id":5,"type":"EndDevice","ieeeAddr":"0x00158d0001ef5edd","nwkAddr":16447,"manufId":4151,"manufName":"LUMI","powerSource":"Battery","modelId":"lumi.remote.b1acn01\u0000\u0000\u0000\u0000\u0000\u0000","epList":[1],"status":"offline","joinTime":null,"endpoints":{"1":{"profId":260,"epId":1,"devId":259,"inClusterList":[0,3,18],"outClusterList":[0],"clusters":{"genBasic":{"dir":{"value":3},"attrs":{}},"genIdentify":{"dir":{"value":1},"attrs":{}},"genMultistateInput":{"dir":{"value":1},"attrs":{}}}}},"_id":"94VAz5kMw68NP6Ol"}
                  {"id":4,"type":"Router","ieeeAddr":"0x7cb03eaa00ad2bc9","nwkAddr":29077,"manufId":48042,"manufName":"OSRAM","powerSource":"Mains (single phase)","modelId":"Plug 01","epList":[3],"status":"offline","joinTime":null,"endpoints":{"3":{"profId":49246,"epId":3,"devId":16,"inClusterList":[0,3,4,5,6,2820,4096,64527],"outClusterList":[25],"clusters":{"64527":{"dir":{"value":1},"attrs":{"0":0}},"genBasic":{"dir":{"value":1},"attrs":{"zclVersion":1,"appVersion":12,"stackVersion":2,"hwVersion":1,"manufacturerName":"OSRAM","modelId":"Plug 01","dateCode":"20140331DEOS****","powerSource":1,"deviceEnabled":1,"swBuildId":"V1.04.12"}},"genIdentify":{"dir":{"value":1},"attrs":{"identifyTime":0}},"genGroups":{"dir":{"value":1},"attrs":{"nameSupport":0}},"genScenes":{"dir":{"value":1},"attrs":{"count":0,"currentScene":0,"currentGroup":0,"sceneValid":0,"nameSupport":0}},"genOnOff":{"dir":{"value":1},"attrs":{"onOff":0,"globalSceneCtrl":1,"onTime":0,"offWaitTime":0}},"genOta":{"dir":{"value":2},"attrs":{}},"haElectricalMeasurement":{"dir":{"value":1},"attrs":{"measurementType":8,"activePower":28000}},"lightLink":{"dir":{"value":1},"attrs":{}}}}},"_id":"HKuxE1LqO7iW7v70"}
                  {"id":4,"type":"Router","ieeeAddr":"0x7cb03eaa00ad2bc9","nwkAddr":29077,"manufId":48042,"manufName":"OSRAM","powerSource":"Mains (single phase)","modelId":"Plug 01","epList":[3],"status":"online","joinTime":1539937494,"endpoints":{"3":{"profId":49246,"epId":3,"devId":16,"inClusterList":[0,3,4,5,6,2820,4096,64527],"outClusterList":[25],"clusters":{"64527":{"dir":{"value":1},"attrs":{"0":0}},"genBasic":{"dir":{"value":1},"attrs":{"zclVersion":1,"appVersion":12,"stackVersion":2,"hwVersion":1,"manufacturerName":"OSRAM","modelId":"Plug 01","dateCode":"20140331DEOS****","powerSource":1,"deviceEnabled":1,"swBuildId":"V1.04.12"}},"genIdentify":{"dir":{"value":1},"attrs":{"identifyTime":0}},"genGroups":{"dir":{"value":1},"attrs":{"nameSupport":0}},"genScenes":{"dir":{"value":1},"attrs":{"count":0,"currentScene":0,"currentGroup":0,"sceneValid":0,"nameSupport":0}},"genOnOff":{"dir":{"value":1},"attrs":{"onOff":0,"globalSceneCtrl":1,"onTime":0,"offWaitTime":0}},"genOta":{"dir":{"value":2},"attrs":{}},"haElectricalMeasurement":{"dir":{"value":1},"attrs":{"measurementType":8,"activePower":28000}},"lightLink":{"dir":{"value":1},"attrs":{}}}}},"_id":"HKuxE1LqO7iW7v70"}
                  Gruß NetFritz
                    Guten morgen zusammen ,
                    ich hab auf FB eine Anleitung gefunden die bei mir Funktioniert hat :
                    https://www.facebook.com/groups/4404991 … cation=ufi
                    wenn bei euch der Xiaomi Lichtschalter nicht funktioniert, dann die Lösung ist hier.
                    1. https://github.com/ioBroker/ioBroker.zi ... all/master installieren.
                    2. Adapter upload.
                    3. Adapter restart.
                    ...ohne Garantie..
                    • N
                      Hallo
                      Ich warte erstmal ab was @arteck dazu sagt.
                      Fahre jetzt erstmal übers Wochenende weg,
                      Bin Montag wieder vor Ort.
                      Gruß NetFritz
                        es gibt eine neue Version auf GIT 0.7.6
                        https://github.com/ioBroker/ioBroker.zigbee
                        installiere die erstmal
                        den Upload kannst du auch machen.. der rest ist irrelevant.
                        ich muss mit Ilya reden..
                        das ist dein Schalter.. dieser wird als online erkannt.. aber es kommen keine Aktionen rüber..
                        • a200
                          a200 last edited by
                          Kann man irgendwo die Fw-Version eines Gerätes sehen?
                          Gesendet mit Tapatalk
                            macjoshua last edited by
                            Ich klinge mich mal mit meinem "Problemchen" hier ein.
                            Ich habe einen Zigbee-Stick (CC2530) im Einsatz und möchte ihn zur Steuerung von Hue-Lampen nutzen.
                            Die Lampen mit dem Typ "LTW010" habe ich bereits erfolgreich angemeldet und alles funktioniert (ZigBee Adapter 0.7.6).
                            Leider werden die Lampen mit dem Typ "LTW012" nicht erkannt.
                            Kann mir bitte jemand dabei helfen?
                            Danke!
                              Kueppert last edited by
                              Hallo in die Runde,
                              kurze Frage von mir: habe die Yeelight Ceilinglight an der Decke. Da ist auch eine Fernbedienung dabei. Kann ich die FB noch nutzen wenn ich die Lampe am artek-Stick angelernt hab und die Lampe über FB sowie ioBroker steuern? Wenn ja, wie geht das 🙂
                              Danke und Grüße, Thorsten
                                @Kueppert:
                                Hallo in die Runde,
                                Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk `
                                gute frage.. ich würde sagen nein.. die Geräte sind exklusiv mit dem Stick verbunden.. sonst könnte man die Hue Lampen an der Bridge lassen und diese hierdurch schalten… aber Probier aus..
                                  @a200:
                                  Gesendet mit Tapatalk `
                                  Nö..
                                    @macjoshua:
                                    Danke! `
                                    ist das eine E14 ?? und was kann die … Farbe ?? Helligkeit ?? Temperatur??
                                      Oh, sorry: Ja, ist eine E14 Kerzenlampe, "White ambiance". Keine Farbe (nur weiß), mit Farbtemperatur und Helligkeit.
                                      Habe die gleichen Leuchtmittel auch mit Farbe und werde das heute Abend mal testen.
                                      Gestern habe ich auch versucht den Hue Bewegungsmelder (https://www2.meethue.com/de-de/p/hue-be … 8696743171)
                                      anzulernen. Er wurde erkannt, ein Bild wurde nicht angezeigt (wurde nicht gefunden) und die Datenpunkte waren in iobroker angelegt.
                                      Allerdings wurden diese nicht mit Werten aktualisiert.
                                      Wenn ich beim Testen helfen kann, dann gerne! Danke für deine Hilfe!
                                        Torsten_MG last edited by
                                        Ich habe hier auch noch 2 Fragen, sollten die schon irgendwo beantwortet worden sein und ich habe es übersehen, möchte ich mich schon mal dafür entschuldigen!
                                        Nun meine Fragen:
                                        1. Kann ich jedes Zigbee Gerät anlernen?
                                        2. Wenn Ja, wie muß ich vorgehen, wenn diese noch nicht vom Adapter unterstützt werden.
                                        Sollten schon antworten zu diesen Fragen existieren, reichen mir auch die Links dorthin, wenn man die Antworten nicht nochmal aufschreiben möchte.
                                        Gesendet von meinem SM-J730F mit Tapatalk
                                          @Torsten_MG:
                                          1. Kann ich jedes Zigbee Gerät anlernen? `
                                          jaein.. es sind viele aber nicht alle.. es schien als ob das Protokoll eine Auslegung zulässt.
                                          @Torsten_MG:
                                          2. Wenn Ja, wie muß ich vorgehen, wenn diese noch nicht vom Adapter unterstützt werden. `
                                          ich brauche die genaue Bezeichnung des erkannten Gerätes.. am besten so ne Kachel. wie oben
                                            @arteck:
                                            @Torsten_MG:
                                            @Torsten_MG:
                                            ich brauche die genaue Bezeichnung des erkannten Gerätes.. am besten so ne Kachel. wie oben `
                                            Ok, da du das vom Protokoll aghängig machst, ich gehe mal davon aus, dass das Protokoll von allen Osram-Geräten gleich ist und da ja die Lampen alle funktionieren, sollte es also kein Problem sein, den BWM von Osram https://www.amazon.de/gp/product/B01KOA4YE8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 oder den Switch https://www.amazon.de/gp/product/B00YSXBROI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&th=1 einzubinden? Ich hatte es mit dem BWM bei Fhem schonmal versucht, aber irgendwie habe ich keine Verbindung hinbekommen, kann aber auch sein, dass ich was beim pairen falsch gemacht habe.
                                            1078
                                            343538
