    4. Bild wechsel Garagentor Stellung [gelöst]
      lutzer last edited by
      Ich danke dir.
      Doofe Fragen: wo hin damit? Und welches widget muss ich dafür nehmen?
      Sorry bin wirklich Anfänger
        paul53 last edited by
        @lutzer:
        wo hin damit? `
        Im Javascript-Adapter ein neues Skript anlegen (unter der Gruppe common) und das Skript aus dem Forum in das Editor-Fenster kopieren (copy & paste).
        @lutzer:
        Und welches widget muss ich dafür nehmen? `
        Mit Vis kenne ich mich nicht aus.
          Nimm das Widget und passe es an :
          [{"tpl":"tplMfdDoor","data":{"oid":"nothing_selected","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"closed_icon":"/icons-mfd-svg/fts_sliding_gate_l_closed.svg","closed_iconColor":"#29ff33","tilted_icon":"/icons-mfd-svg/fts_sliding_gate.svg","opened_icon":"/icons-mfd-svg/fts_sliding_gate_open.svg","opened_iconColor":"#e60000","invert_icon":false,"invert_state":false,"tilted_iconColor":"#fdbb12"},"style":{"left":"231px","top":"461px","width":"139px","height":"128px"},"widgetSet":"jqui-mfd"}]
            Irgendwie wird der Zustand nicht verändert.
            Das sagt die log:
            javascript.0	2018-10-20 19:58:51.255	info	script.js.common.garage: registered 2 subscriptions and 0 schedules
            javascript.0	2018-10-20 19:58:51.255	warn	at script.js.common.garage:17:1
            javascript.0	2018-10-20 19:58:51.255	warn	at tor (script.js.common.garage:14:4)
            javascript.0	2018-10-20 19:58:51.253	warn	State "javascript.0.Tor" not found
            javascript.0	2018-10-20 19:58:51.250	info	Start javascript script.js.common.garage
            Ist das so richtig im Vis?
              @lutzer:
              Mein Garagentor hat drei Stellungen die es auch Zurückmeldet (Zu,Lüftung,Auf). `
              Wohin meldet es den?
                Problem ist eben das es zwei verschiedene "Devices" sind. Ist ein "HmIP-MOD-RC8" der auf Kanal 1 und 2 die entsprechenden Rückmeldungen gibt.
                Hier mal meine IDs/Abhängigkeiten:
                Tor zu
                hm-rpc.1.xxx.2.STATE
                false
                /vis.0/main/img/garage_zu.png
                Tor Lüftung
                true
                /vis.0/main/img/garage_lueftung.png
                Tor auf
                hm-rpc.1.xxx.1.STATE
                true
                /vis.0/main/img/garage_auf.png
                  Zeig mir mal bitte den Objektbaum…....
                      Ich habe es auch mal als Homematic Programm mit einer Variable getestet. Dauert aber ewig bis die aktuelle Variable im iobroker ankommt.
                      Ich habe es auch mit Signalbildern geschummelt, aber da kann man ja immer nur einen Teil ersetzen. Signal halt…
                        Na ja du hast ja alle Datenpunkte, warum braucht du dann noch ein Skript?
                        Die DP ändern sich in true oder false wenn du das Garagentor auf oder zu machst?
                        Stoppe mal das Skript und setze vom deinen Objekt den DP in das Widget ein.
                          Weil ich zwei verschiedene Objekt IDs brauche und eine kann man ja nur anwählen.
                          Zu und Lüftung kommt von einem Kanal 2 (true/false), aber Auf kommt von Kanal 1 (true)
                          Tor zu
                          2.STATE = false
                          Tor Lüftung
                          2.STATE = true
                          Tor auf
                          1.STATE = true
                          Ein Script könnte mir die Zustände sammeln und dann eben nur noch 0,1,2 ausgeben. Und bei entsprechnder Zahl kann ich dann im Widget ein Bild zuordnen. So dachte ich es mir :?
                            Dann leg 2 Widget an, und setze sie übereinander und stelle die Sichtbarkeit ein….........
                              Wenn aus dem Script von Paul tatsächlich Zahlen rauskommen würden, dann könnte ich doch prima mit deinem Widget arbeiten.
                                Kannst du mir bitte noch sagen wie ich mit dem Script arbeite?
                                Ich verstehe leider zu wenig von Javascript.
                                Was erzeugt das "javascript.0.Tor"? Da steht leider immer nur eine 0. - Sorry passt, es erzeugt 0,1,2 - Ich hatte den Haken bei Debug…. :?
                                  Hier noch mal als Zusammenfassung, weil es funktioniert und mit Sicherheit weiterhilft.
                                  Aufgabenstellung:
                                  Es sind zwei verschiedene "Devices": von einem Homematic Sender "HmIP-MOD-RC8" der auf Kanal 1 und 2 die entsprechenden Rückmeldungen
                                  Tor zu
                                  false
                                  Tor Lüftung
                                  true
                                  Tor auf
                                  true
                                  Ich habe von paul53 folgendes Script bekommen, was unter "Objekte" einen State mit entsprechendem Wert (0,1,2) erzeugt.
                                  Ein neues Script unter Javascript/common erzeugen und folgenden Code einfügen:
                                  const idAuf   = 'hm-rpc.1.xxx.1.STATE';
                                  const idLueft = 'hm-rpc.1.xxx.2.STATE`;
                                  const idVis   = 'javascript.0.Tor'; // Datenpunkt für VIS
                                  createState(idVis, 0, {type: 'number', min: 0, max: 2});
                                  var auf = getState(idAuf).val;
                                  var lueft = getState(idLueft).val;
                                  function tor() {
                                     var vis = 0;       // Tor zu
                                     if(lueft) vis = 1; // Lüftung
                                     if(auf) vis = 2;   // Tor auf
                                     setState(idVis, vis, true);
                                  tor(); // Skriptstart
                                  on(idAuf, function(dp) {
                                     auf = dp.state.val;
                                     tor();
                                  on(idLueft, function(dp) {
                                     lueft = dp.state.val;
                                     tor();
                                  Nun kann man im Vis folgendes Widget importieren:
                                  Hinweis - vorher "vis-jqui-mfd.0" Adapter installieren, sonst sieht man nichts…
                                  Jetzt die Parameter im widget einstellen:
                                  Danke an paul53 und sigi234 für den Support.
                                  Ich denke das ich mit der Zusammenfassung etwas wieder zurück geben kann. Das fällt mir auch immer sehr schwer Beiträge ohne happy end zu lesen. 😉
                                    Das freut mich das es geklappt hat…........... 🙂
                                      @lutzer:
                                      Zusammenfassung, weil es funktioniert `
                                      Dann markiere bitte das Thema im Betreff des ersten Beitrags als [gelöst].
                                      1264
