    4. Bekomme Noble nicht richtig installiert.
      apollon77 last edited by
      Dann such mal in node_modules den noble ordner und versuch es dort
        Belei last edited by
        auch keine Reaktion,
        dafür ging heute morgen die Lichter nicht an und die Rolläden nicht hoch.
        Der Log wird mit Fehlern vollgespüllt und diverse Adapter wie Zigbee, RFLink, Dashbutton, Cloud usw gehen nicht mehr: 😮
        host.ioBroker-Pi3	2018-10-26 07:49:05.706	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
        host.ioBroker-Pi3	2018-10-26 07:49:05.706	error	Caught by controller[0]: at Module.load (module.js:566:32)
        host.ioBroker-Pi3	2018-10-26 07:49:05.706	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
        host.ioBroker-Pi3	2018-10-26 07:49:05.706	error	Caught by controller[0]: at Module._compile (module.js:653:30)
        host.ioBroker-Pi3	2018-10-26 07:49:05.706	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
        host.ioBroker-Pi3	2018-10-26 07:49:05.706	error	Caught by controller[0]: at require (internal/module.js:11:18)
        host.ioBroker-Pi3	2018-10-26 07:49:05.705	error	Caught by controller[0]: at Module.require (module.js:597:17)
        host.ioBroker-Pi3	2018-10-26 07:49:05.705	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
        host.ioBroker-Pi3	2018-10-26 07:49:05.705	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
        host.ioBroker-Pi3	2018-10-26 07:49:05.705	error	Caught by controller[0]: at Module.load (module.js:566:32)
        host.ioBroker-Pi3	2018-10-26 07:49:05.705	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
        host.ioBroker-Pi3	2018-10-26 07:49:05.705	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
        host.ioBroker-Pi3	2018-10-26 07:49:05.705	error	Caught by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
        host.ioBroker-Pi3	2018-10-26 07:49:05.705	error	Caught by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
        host.ioBroker-Pi3	2018-10-26 07:49:05.704	error	Caught by controller[0]: was compiled against a different Node.js version using
        host.ioBroker-Pi3	2018-10-26 07:49:05.704	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/p</anonymous>
        Das ging heute Nacht um 3 Uhr los, nach dem neustart vom ioBroker durch den Backitup Adapter.
        Ich habe gestern beim versuch noble zum laufen zu bringen, auf Nodejs 8 upgedatet.
        pi@ioBroker-Pi3:~ $ nodejs -v
        v8.12.0
        pi@ioBroker-Pi3:~ $ npm -v
        6.4.1
        Könnte das damit zusammenhängen?
          Was dsagt
          node -v
          Die Fehlermeldung sagt alles: Das amazon dash ist auch für dfie falsche nodejs version compiliert. auch hier "npm rebuild"
            pi@ioBroker-Pi3:~ $  node -v
            v8.12.0
            Ausgabe aus amazon dash:
            pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.amazon-dash $ npm rebuild
            > pcap@2.0.0 install /opt/iobroker/node_modules/iobroker.amazon-dash/node_module        s/pcap
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/        pcap/build“ wird betreten
              CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
              CXX(target) Release/obj.target/pcap_binding/pcap_session.o
            ../pcap_session.cc: In static member function ‘static void PcapSession::New(const Nan::FunctionCallbackInfo<v8::value>&)’:
            ../pcap_session.cc:46:49: warning: ‘v8::Local <v8::object>v8::Function::NewInstance() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                 info.GetReturnValue().Set(cons->NewInstance());
            In file included from /home/pi/.node-gyp/8.12.0/include/node/v8.h:26:0,
                             from /home/pi/.node-gyp/8.12.0/include/node/node.h:63,
                             from ../../nan/nan.h:51,
                             from ../pcap_session.h:4,
                             from ../pcap_session.cc:7:
            /home/pi/.node-gyp/8.12.0/include/node/v8.h:3901:52: note: declared here
               V8_DEPRECATED("Use maybe version", Local <object>NewInstance() const);
            /home/pi/.node-gyp/8.12.0/include/node/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
               declarator __attribute__((deprecated(message)))
            ../pcap_session.cc: In static member function ‘static void PcapSession::PacketReady(u_char*, const pcap_pkthdr*, const u_char*)’:
            ../pcap_session.cc:85:102: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated  -Wdeprecated-declarations]
             n::GetCurrentContext()->Global(), Nan::New(session->packet_ready_cb), 0, NULL);
            In file included from ../pcap_session.h:4:0,
            ../../nan/nan.h:929:46: note: declared here
               NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback(
              SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
              COPY Release/pcap_binding.node
            make: Verzeichnis „/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build“ wird verlassen
            > socketwatcher@0.3.0 install /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher/build“ wird betreten
              CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
            ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::Callback(uv_poll_t*, int, int)’:
            ../socket_watcher.cpp:77:60: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated [-Wdeprecated-declarations]
               Nan::MakeCallback(watcher->handle(), callback, argc, argv);
            In file included from ../socket_watcher.hpp:8:0,
                             from ../socket_watcher.cpp:5:
            ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::New(const Nan::FunctionCallbackInfo<v8::value>&)’:
            ../socket_watcher.cpp:104:49: warning: ‘v8::Local <v8::object>v8::Function::NewInstance() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                             from ../socket_watcher.hpp:8,
              SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
              COPY Release/socketwatcher.node
            make: Verzeichnis „/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher/build“ wird verlassen
            pcap@2.0.0 /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap
            nan@2.10.0 /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/nan
            socketwatcher@0.3.0 /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher
            pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.amazon-dash $</object></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></object></v8::object></v8::value>
              geht denn dash jetzt?
                ja dash läuft wieder, hab system mal neugestartet.
                Jetzt meckert der RFLINK Adapter: Bzw wird die USB Hardware nicht mehr gefunden, im RFLINK und Zigbee Adapter.
                host.ioBroker-Pi3	2018-10-26 11:52:09.822	error	instance system.adapter.zigbee.0 terminated with code 1 ()
                host.ioBroker-Pi3	2018-10-26 11:52:09.822	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at Module._compile (module.js:653:30)
                host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
                host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at require (internal/module.js:11:18)
                host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at Module.require (module.js:597:17)
                host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
                host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
                host.ioBroker-Pi3	2018-10-26 11:52:09.820	error	Caught by controller[0]: at Module.load (module.js:566:32)
                host.ioBroker-Pi3	2018-10-26 11:52:09.820	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
                host.ioBroker-Pi3	2018-10-26 11:52:09.820	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                host.ioBroker-Pi3	2018-10-26 11:52:09.820	error	Caught by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
                host.ioBroker-Pi3	2018-10-26 11:52:09.818	error	Caught by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
                host.ioBroker-Pi3	2018-10-26 11:52:09.816	error	Caught by controller[0]: was compiled against a different Node.js version using
                host.ioBroker-Pi3	2018-10-26 11:52:09.813	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                host.ioBroker-Pi3	2018-10-26 11:52:09.812	error	Caught by controller[0]: ^
                host.ioBroker-Pi3	2018-10-26 11:52:09.810	error	Caught by controller[0]: throw e
                host.ioBroker-Pi3	2018-10-26 11:52:09.810	error	Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88</anonymous>
                Da warscheinleich auch rebuild? aber in welchem Ordner genau?
                  Wenn Du ein node upgrade machst muss alles was nativ kompilierte Pakete sind neu kompiliert werden und ja, damit npm rebuild
                    Da kommt nur das?
                    pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport/build/Release $ npm rebuild
                    bindings@1.3.0 /opt/iobroker/node_modules/serialport/node_modules/bindings
                    debug@3.2.5 /opt/iobroker/node_modules/serialport/node_modules/debug
                    ms@2.1.1 /opt/iobroker/node_modules/serialport/node_modules/ms
                    nan@2.11.0 /opt/iobroker/node_modules/serialport/node_modules/nan
                    prebuild-install@4.0.0 /opt/iobroker/node_modules/serialport/node_modules/prebuild-install
                    minimist@1.2.0 /opt/iobroker/node_modules/serialport/node_modules/minimist
                    prompt-list@3.2.0 /opt/iobroker/node_modules/serialport/node_modules/prompt-list
                    safe-buffer@5.1.2 /opt/iobroker/node_modules/serialport/node_modules/safe-buffer
                    Und im io Log steht:
                    rflink.0	2018-10-26 13:34:30.101	warn	Module serialport is not available
                    Somit keine ansteuerung des RFLINK Hardware Adapters.
                      Und tuts?
                        Ich habs jetzt mal im RFLINK Ordner gemacht, jetzt läuft der auch wieder 😉
                          Aktuelle Fehlermeldung beim starten des Zigbee Adapters:
                          host.ioBroker-Pi3	2018-10-26 14:02:38.958	info	Restart adapter system.adapter.zigbee.0 because enabled
                          host.ioBroker-Pi3	2018-10-26 14:02:38.958	error	instance system.adapter.zigbee.0 terminated with code 1 ()
                          Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                          Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Module._compile (module.js:653:30)
                          Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                          Caught	2018-10-26 14:02:38.958	error	by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
                          Caught	2018-10-26 14:02:38.957	error	by controller[0]: at require (internal/module.js:11:18)
                          Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Module.require (module.js:597:17)
                          Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Function.Module._load (module.js:498:3)
                          Caught	2018-10-26 14:02:38.957	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                          Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Module.load (module.js:566:32)
                          Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Object.Module._extensions..node (module.js:682:18)
                          Caught	2018-10-26 14:02:38.956	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                          Caught	2018-10-26 14:02:38.956	error	by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
                          Caught	2018-10-26 14:02:38.956	error	by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
                          Caught	2018-10-26 14:02:38.956	error	by controller[0]: was compiled against a different Node.js version using
                          Caught	2018-10-26 14:02:38.956	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                          Caught	2018-10-26 14:02:38.956	error	by controller[0]: ^
                          Caught	2018-10-26 14:02:38.955	error	by controller[0]: throw e
                          Caught	2018-10-26 14:02:38.955	error	by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
                          host.ioBroker-Pi3	2018-10-26 14:02:37.949	info	instance system.adapter.zigbee.0 started with pid 929</anonymous>
                          npm im Zigbee Ordner Ergebniss:
                          pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.zigbee $ npm rebuild
                          debug@3.2.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/debug
                          ms@2.1.1 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/ms
                          npm im /opt/iobroker/node_modules/serialport/node_modules/bindings
                          keine Reaktion
                          npm rebuild im /opt/iobroker/node_modules/serialport/build/Release
                          Im Zigbee Adapter ist nicht der USB anschluss zur auswahl vorhanden somit bleibt der Bursche rot
                            Fürhre das rebuild mal eher in
                            aus
                              Dann kommt
                              pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport $ npm rebuild
                              Aber der Fehler im Log ist immer noch da und adapter bleibt rot!
                                dann such mal ob in node_modules des Adapters selbst ggf nochmal ein serialport drin ist
                                  Nichts zu finden. Nur debug und ms
                                  Auch eine neuinstallation von zigbee hat nix gebracht.
                                    ich meine in /opt/iobroker/node_modules
                                      Da gibts nur ein serialport
                                        Dann kann ich nur sagen: lösch den serialport malund installiere adapter nochmal. Dann wäre ich am Ende der Ideen
                                          öhmm also den Ordner Serialport löschen und dann zigbee adapter neuinstallieren?
                                          installiert der dan den serialport wieder mit?
                                          Gleich fliegt das Ding aus dem Fenster... Jetzt geht wieder gar nix... nach folgender Aktion:
                                          sudo apt-get update
                                          sudo apt-get install build-essential git
                                          cd /opt/iobroker
                                          npm install iobroker.Zigbee
                                          http://www.iobroker.net/docu/?page_id=5510&lang=de
                                          Jetzt startet io nicht mehr….
                                          pi@ioBroker-Pi3:~ $ iobroker start
                                          module.js:550
                                              throw err;
                                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                              at Function.Module._resolveFilename (module.js:548:15)
                                              at Function.Module._load (module.js:475:25)
                                              at Function.Module.runMain (module.js:694:10)
                                              at startup (bootstrap_node.js:204:16)
                                              at bootstrap_node.js:625:3
                                            Ich habe ein Backup eingespielt, und die ganzen rebuilds nochmal gemacht, diesmal immer den betreffenden adapter vorher ausgeschaltet.
                                            Jetzt läuft es wieder und siehe da:
                                            RADAR erkennt endlich auch meine beiden BT Anhänger und auch diverse Unknown Devices 😛
                                            Noble wird auch als aktiv angezeigt und ich bin auf
                                            Node.js: v8.12.0
                                            NPM: 6.4.1
                                            Sind die Versionen OK?
                                            PUH was ein Krampf wird Zeit für eine Virtuelle Umgebung um mal eben was zu testen :lol:
                                            Danke an apollon77 😉
                                            81.1k
                                            3574
