    4. Bekomme Noble nicht richtig installiert.
      apollon77 last edited by
      Was dsagt
      node -v
      Die Fehlermeldung sagt alles: Das amazon dash ist auch für dfie falsche nodejs version compiliert. auch hier "npm rebuild"
        Belei last edited by
        pi@ioBroker-Pi3:~ $  node -v
        v8.12.0
        Ausgabe aus amazon dash:
        pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.amazon-dash $ npm rebuild
        > pcap@2.0.0 install /opt/iobroker/node_modules/iobroker.amazon-dash/node_module        s/pcap
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/        pcap/build“ wird betreten
          CXX(target) Release/obj.target/pcap_binding/pcap_binding.o
          CXX(target) Release/obj.target/pcap_binding/pcap_session.o
        ../pcap_session.cc: In static member function ‘static void PcapSession::New(const Nan::FunctionCallbackInfo<v8::value>&)’:
        ../pcap_session.cc:46:49: warning: ‘v8::Local <v8::object>v8::Function::NewInstance() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
             info.GetReturnValue().Set(cons->NewInstance());
        In file included from /home/pi/.node-gyp/8.12.0/include/node/v8.h:26:0,
                         from /home/pi/.node-gyp/8.12.0/include/node/node.h:63,
                         from ../../nan/nan.h:51,
                         from ../pcap_session.h:4,
                         from ../pcap_session.cc:7:
        /home/pi/.node-gyp/8.12.0/include/node/v8.h:3901:52: note: declared here
           V8_DEPRECATED("Use maybe version", Local <object>NewInstance() const);
        /home/pi/.node-gyp/8.12.0/include/node/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../pcap_session.cc: In static member function ‘static void PcapSession::PacketReady(u_char*, const pcap_pkthdr*, const u_char*)’:
        ../pcap_session.cc:85:102: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated  -Wdeprecated-declarations]
         n::GetCurrentContext()->Global(), Nan::New(session->packet_ready_cb), 0, NULL);
        In file included from ../pcap_session.h:4:0,
        ../../nan/nan.h:929:46: note: declared here
           NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback(
          SOLINK_MODULE(target) Release/obj.target/pcap_binding.node
          COPY Release/pcap_binding.node
        make: Verzeichnis „/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build“ wird verlassen
        > socketwatcher@0.3.0 install /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher/build“ wird betreten
          CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
        ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::Callback(uv_poll_t*, int, int)’:
        ../socket_watcher.cpp:77:60: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated [-Wdeprecated-declarations]
           Nan::MakeCallback(watcher->handle(), callback, argc, argv);
        In file included from ../socket_watcher.hpp:8:0,
                         from ../socket_watcher.cpp:5:
        ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::New(const Nan::FunctionCallbackInfo<v8::value>&)’:
        ../socket_watcher.cpp:104:49: warning: ‘v8::Local <v8::object>v8::Function::NewInstance() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
                         from ../socket_watcher.hpp:8,
          SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
          COPY Release/socketwatcher.node
        make: Verzeichnis „/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher/build“ wird verlassen
        pcap@2.0.0 /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap
        nan@2.10.0 /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/nan
        socketwatcher@0.3.0 /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher
        pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.amazon-dash $</object></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></object></v8::object></v8::value>
          geht denn dash jetzt?
            ja dash läuft wieder, hab system mal neugestartet.
            Jetzt meckert der RFLINK Adapter: Bzw wird die USB Hardware nicht mehr gefunden, im RFLINK und Zigbee Adapter.
            host.ioBroker-Pi3	2018-10-26 11:52:09.822	error	instance system.adapter.zigbee.0 terminated with code 1 ()
            host.ioBroker-Pi3	2018-10-26 11:52:09.822	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
            host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at Module._compile (module.js:653:30)
            host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
            host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
            host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at require (internal/module.js:11:18)
            host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at Module.require (module.js:597:17)
            host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
            host.ioBroker-Pi3	2018-10-26 11:52:09.821	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
            host.ioBroker-Pi3	2018-10-26 11:52:09.820	error	Caught by controller[0]: at Module.load (module.js:566:32)
            host.ioBroker-Pi3	2018-10-26 11:52:09.820	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:682:18)
            host.ioBroker-Pi3	2018-10-26 11:52:09.820	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
            host.ioBroker-Pi3	2018-10-26 11:52:09.820	error	Caught by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
            host.ioBroker-Pi3	2018-10-26 11:52:09.818	error	Caught by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
            host.ioBroker-Pi3	2018-10-26 11:52:09.816	error	Caught by controller[0]: was compiled against a different Node.js version using
            host.ioBroker-Pi3	2018-10-26 11:52:09.813	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
            host.ioBroker-Pi3	2018-10-26 11:52:09.812	error	Caught by controller[0]: ^
            host.ioBroker-Pi3	2018-10-26 11:52:09.810	error	Caught by controller[0]: throw e
            host.ioBroker-Pi3	2018-10-26 11:52:09.810	error	Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88</anonymous>
            Da warscheinleich auch rebuild? aber in welchem Ordner genau?
              Wenn Du ein node upgrade machst muss alles was nativ kompilierte Pakete sind neu kompiliert werden und ja, damit npm rebuild
                Da kommt nur das?
                pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport/build/Release $ npm rebuild
                bindings@1.3.0 /opt/iobroker/node_modules/serialport/node_modules/bindings
                debug@3.2.5 /opt/iobroker/node_modules/serialport/node_modules/debug
                ms@2.1.1 /opt/iobroker/node_modules/serialport/node_modules/ms
                nan@2.11.0 /opt/iobroker/node_modules/serialport/node_modules/nan
                prebuild-install@4.0.0 /opt/iobroker/node_modules/serialport/node_modules/prebuild-install
                minimist@1.2.0 /opt/iobroker/node_modules/serialport/node_modules/minimist
                prompt-list@3.2.0 /opt/iobroker/node_modules/serialport/node_modules/prompt-list
                safe-buffer@5.1.2 /opt/iobroker/node_modules/serialport/node_modules/safe-buffer
                Und im io Log steht:
                rflink.0	2018-10-26 13:34:30.101	warn	Module serialport is not available
                Somit keine ansteuerung des RFLINK Hardware Adapters.
                  Und tuts?
                    Ich habs jetzt mal im RFLINK Ordner gemacht, jetzt läuft der auch wieder 😉
                      Aktuelle Fehlermeldung beim starten des Zigbee Adapters:
                      host.ioBroker-Pi3	2018-10-26 14:02:38.958	info	Restart adapter system.adapter.zigbee.0 because enabled
                      host.ioBroker-Pi3	2018-10-26 14:02:38.958	error	instance system.adapter.zigbee.0 terminated with code 1 ()
                      Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Object.Module._extensions..js (module.js:664:10)
                      Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Module._compile (module.js:653:30)
                      Caught	2018-10-26 14:02:38.958	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                      Caught	2018-10-26 14:02:38.958	error	by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
                      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at require (internal/module.js:11:18)
                      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Module.require (module.js:597:17)
                      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Function.Module._load (module.js:498:3)
                      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at tryModuleLoad (module.js:506:12)
                      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Module.load (module.js:566:32)
                      Caught	2018-10-26 14:02:38.957	error	by controller[0]: at Object.Module._extensions..node (module.js:682:18)
                      Caught	2018-10-26 14:02:38.956	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                      Caught	2018-10-26 14:02:38.956	error	by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
                      Caught	2018-10-26 14:02:38.956	error	by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
                      Caught	2018-10-26 14:02:38.956	error	by controller[0]: was compiled against a different Node.js version using
                      Caught	2018-10-26 14:02:38.956	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                      Caught	2018-10-26 14:02:38.956	error	by controller[0]: ^
                      Caught	2018-10-26 14:02:38.955	error	by controller[0]: throw e
                      Caught	2018-10-26 14:02:38.955	error	by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
                      host.ioBroker-Pi3	2018-10-26 14:02:37.949	info	instance system.adapter.zigbee.0 started with pid 929</anonymous>
                      npm im Zigbee Ordner Ergebniss:
                      pi@ioBroker-Pi3:/opt/iobroker/node_modules/iobroker.zigbee $ npm rebuild
                      debug@3.2.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/debug
                      ms@2.1.1 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/ms
                      npm im /opt/iobroker/node_modules/serialport/node_modules/bindings
                      keine Reaktion
                      npm rebuild im /opt/iobroker/node_modules/serialport/build/Release
                      Im Zigbee Adapter ist nicht der USB anschluss zur auswahl vorhanden somit bleibt der Bursche rot
                        Fürhre das rebuild mal eher in
                        aus
                          Dann kommt
                          pi@ioBroker-Pi3:/opt/iobroker/node_modules/serialport $ npm rebuild
                          Aber der Fehler im Log ist immer noch da und adapter bleibt rot!
                            dann such mal ob in node_modules des Adapters selbst ggf nochmal ein serialport drin ist
                              Nichts zu finden. Nur debug und ms
                              Auch eine neuinstallation von zigbee hat nix gebracht.
                                ich meine in /opt/iobroker/node_modules
                                  Da gibts nur ein serialport
                                    Dann kann ich nur sagen: lösch den serialport malund installiere adapter nochmal. Dann wäre ich am Ende der Ideen
                                      öhmm also den Ordner Serialport löschen und dann zigbee adapter neuinstallieren?
                                      installiert der dan den serialport wieder mit?
                                      Gleich fliegt das Ding aus dem Fenster... Jetzt geht wieder gar nix... nach folgender Aktion:
                                      sudo apt-get update
                                      sudo apt-get install build-essential git
                                      cd /opt/iobroker
                                      npm install iobroker.Zigbee
                                      http://www.iobroker.net/docu/?page_id=5510&lang=de
                                      Jetzt startet io nicht mehr….
                                      pi@ioBroker-Pi3:~ $ iobroker start
                                      module.js:550
                                          throw err;
                                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          at Function.Module._resolveFilename (module.js:548:15)
                                          at Function.Module._load (module.js:475:25)
                                          at Function.Module.runMain (module.js:694:10)
                                          at startup (bootstrap_node.js:204:16)
                                          at bootstrap_node.js:625:3
                                        Ich habe ein Backup eingespielt, und die ganzen rebuilds nochmal gemacht, diesmal immer den betreffenden adapter vorher ausgeschaltet.
                                        Jetzt läuft es wieder und siehe da:
                                        RADAR erkennt endlich auch meine beiden BT Anhänger und auch diverse Unknown Devices 😛
                                        Noble wird auch als aktiv angezeigt und ich bin auf
                                        Node.js: v8.12.0
                                        NPM: 6.4.1
                                        Sind die Versionen OK?
                                        PUH was ein Krampf wird Zeit für eine Virtuelle Umgebung um mal eben was zu testen :lol:
                                        Danke an apollon77 😉
                                          Komischer Tag heute 🙂
                                          Ja die Versionen sind perfekt so
                                          81.1k
                                          3574
